path: root/mm/nommu.c
2015-11-05mm/nommu.c: drop unlikely inside BUG_ON()Geliang Tang
(1) For !CONFIG_BUG cases, the bug call is a no-op, so we couldn't care less and the change is ok. (2) ppc and mips, which HAVE_ARCH_BUG_ON, do not rely on branch predictions as it seems to be pointless[1] and thus callers should not be trying to push an optimization in the first place. (3) For CONFIG_BUG and !HAVE_ARCH_BUG_ON cases, BUG_ON() contains an unlikely compiler flag already. Hence, we can drop unlikely behind BUG_ON(). [1] http://lkml.iu.edu/hypermail/linux/kernel/1101.3/02289.html Signed-off-by: Geliang Tang <geliangtang@163.com> Acked-by: Davidlohr Bueso <dave@stgolabs.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05mm/nommu: use offset_in_page macroAlexander Kuleshov
linux/mm.h provides offset_in_page() macro. Let's use already predefined macro instead of (addr & ~PAGE_MASK). Signed-off-by: Alexander Kuleshov <kuleshovmail@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10mm, mpx: add "vm_flags_t vm_flags" arg to do_mmap_pgoff()Oleg Nesterov
Add the additional "vm_flags_t vm_flags" argument to do_mmap_pgoff(), rename it to do_mmap(), and re-introduce do_mmap_pgoff() as a simple wrapper on top of do_mmap(). Perhaps we should update the callers of do_mmap_pgoff() and kill it later. This way mpx_mmap() can simply call do_mmap(vm_flags => VM_MPX) and do not play with vm internals. After this change mmap_region() has a single user outside of mmap.c, arch/tile/mm/elf.c:arch_setup_additional_pages(). It would be nice to change arch/tile/ and unexport mmap_region(). [kirill@shutemov.name: fix build] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Dave Hansen <dave.hansen@linux.intel.com> Tested-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Minchan Kim <minchan@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-01Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual stuff from trivial tree for 4.3 (kerneldoc updates, printk() fixes, Documentation and MAINTAINERS updates)" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) MAINTAINERS: update my e-mail address mod_devicetable: add space before */ scsi: a100u2w: trivial typo in printk i2c: Fix typo in i2c-bfin-twi.c treewide: fix typos in comment blocks Doc: fix trivial typo in SubmittingPatches proportions: Spelling s/consitent/consistent/ dm: Spelling s/consitent/consistent/ aic7xxx: Fix typo in error message pcmcia: Fix typo in locking documentation scsi/arcmsr: Fix typos in error log drm/nouveau/gr: Fix typo in nv10.c [SCSI] Fix printk typos in drivers/scsi staging: comedi: Grammar s/Enable support a/Enable support for a/ Btrfs: Spelling s/consitent/consistent/ README: GTK+ is a acronym ASoC: omap: Fix typo in config option description mm: tlb.c: Fix error message ntfs: super.c: Fix error log fix typo in Documentation/SubmittingPatches ...
2015-08-07treewide: fix typos in comment blocksMasahiro Yamada
Looks like the word "contiguous" is often mistyped. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Jiri Kosina <jkosina@suse.com>
2015-07-10vfs: Commit to never having exectuables on proc and sysfs.Eric W. Biederman
Today proc and sysfs do not contain any executable files. Several applications today mount proc or sysfs without noexec and nosuid and then depend on there being no exectuables files on proc or sysfs. Having any executable files show on proc or sysfs would cause a user space visible regression, and most likely security problems. Therefore commit to never allowing executables on proc and sysfs by adding a new flag to mark them as filesystems without executables and enforce that flag. Test the flag where MNT_NOEXEC is tested today, so that the only user visible effect will be that exectuables will be treated as if the execute bit is cleared. The filesystems proc and sysfs do not currently incoporate any executable files so this does not result in any user visible effects. This makes it unnecessary to vet changes to proc and sysfs tightly for adding exectuable files or changes to chattr that would modify existing files, as no matter what the individual file say they will not be treated as exectuable files by the vfs. Not having to vet changes to closely is important as without this we are only one proc_create call (or another goof up in the implementation of notify_change) from having problematic executables on proc. Those mistakes are all too easy to make and would create a situation where there are security issues or the assumptions of some program having to be broken (and cause userspace regressions). Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2015-07-02Merge tag 'module_init-alternate_initcall-v4.1-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull module_init replacement part two from Paul Gortmaker: "Replace module_init with appropriate alternate initcall in non modules. This series converts non-modular code that is using the module_init() call to hook itself into the system to instead use one of our alternate priority initcalls. Unlike the previous series that used device_initcall and hence was a runtime no-op, these commits change to one of the alternate initcalls, because (a) we have them and (b) it seems like the right thing to do. For example, it would seem logical to use arch_initcall for arch specific setup code and fs_initcall for filesystem setup code. This does mean however, that changes in the init ordering will be taking place, and so there is a small risk that some kind of implicit init ordering issue may lie uncovered. But I think it is still better to give these ones sensible priorities than to just assign them all to device_initcall in order to exactly preserve the old ordering. Thad said, we have already made similar changes in core kernel code in commit c96d6660dc65 ("kernel: audit/fix non-modular users of module_init in core code") without any regressions reported, so this type of change isn't without precedent. It has also got the same local testing and linux-next coverage as all the other pull requests that I'm sending for this merge window have got. Once again, there is an unused module_exit function removal that shows up as an outlier upon casual inspection of the diffstat" * tag 'module_init-alternate_initcall-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: x86: perf_event_intel_pt.c: use arch_initcall to hook in enabling x86: perf_event_intel_bts.c: use arch_initcall to hook in enabling mm/page_owner.c: use late_initcall to hook in enabling lib/list_sort: use late_initcall to hook in self tests arm: use subsys_initcall in non-modular pl320 IPC code powerpc: don't use module_init for non-modular core hugetlb code powerpc: use subsys_initcall for Freescale Local Bus x86: don't use module_init for non-modular core bootflag code netfilter: don't use module_init/exit in core IPV4 code fs/notify: don't use module_init for non-modular inotify_user code mm: replace module_init usages with subsys_initcall in nommu.c
2015-06-24mm: nommu: refactor debug and warning printsLeon Romanovsky
kenter/kleave/kdebug are wrapper macros to print functions flow and debug information. This set was written before pr_devel() was introduced, so it was controlled by "#if 0" construction. It is questionable if anyone is using them [1] now. This patch removes these macros, converts numerous printk(KERN_WARNING, ...) to use general pr_warn(...) and removes debug print line from validate_mmap_request() function. Signed-off-by: Leon Romanovsky <leon@leon.nu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-16mm: replace module_init usages with subsys_initcall in nommu.cPaul Gortmaker
Compiling some arm/m68k configs with "# CONFIG_MMU is not set" reveals two more instances of module_init being used for code that can't possibly be modular, as CONFIG_MMU is either on or off. We replace them with subsys_initcall as per what was done in other mmu-enabled code. Note that direct use of __initcall is discouraged, vs. one of the priority categorized subgroups. As __initcall gets mapped onto device_initcall, our use of subsys_initcall (which makes sense for these files) will thus change this registration from level 6-device to level 4-subsys (i.e. slightly earlier). One might think that core_initcall (l2) or postcore_initcall (l3) would be more appropriate for anything in mm/ but if we look at the actual init functions themselves, we see they are just sysctl setup stuff, and hence the choice of subsys_initcall (l4) seems reasonable. At the same time it minimizes the risk of changing the priority too drastically all at once. We can adjust further in the future. Also, a couple instances of missing ";" at EOL are fixed. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-mm@kvack.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2015-04-11nommu: use __vfs_read()Al Viro
... instead of open-coding the call of ->read() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-12mm/nommu.c: export symbol max_mapnrgchen gchen
Several modules may need max_mapnr, so export, the related error with allmodconfig under c6x: MODPOST 3327 modules ERROR: "max_mapnr" [fs/pstore/ramoops.ko] undefined! ERROR: "max_mapnr" [drivers/media/v4l2-core/videobuf2-dma-contig.ko] undefined! Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-28mm/nommu: fix memory leakJoonsoo Kim
Maxime reported the following memory leak regression due to commit dbc8358c7237 ("mm/nommu: use alloc_pages_exact() rather than its own implementation"). On v3.19, I am facing a memory leak. Each time I run a command one page is lost. Here an example with busybox's free command: / # free total used free shared buffers cached Mem: 7928 1972 5956 0 0 492 -/+ buffers/cache: 1480 6448 / # free total used free shared buffers cached Mem: 7928 1976 5952 0 0 492 -/+ buffers/cache: 1484 6444 / # free total used free shared buffers cached Mem: 7928 1980 5948 0 0 492 -/+ buffers/cache: 1488 6440 / # free total used free shared buffers cached Mem: 7928 1984 5944 0 0 492 -/+ buffers/cache: 1492 6436 / # free total used free shared buffers cached Mem: 7928 1988 5940 0 0 492 -/+ buffers/cache: 1496 6432 At some point, the system fails to sastisfy 256KB allocations: free: page allocation failure: order:6, mode:0xd0 CPU: 0 PID: 67 Comm: free Not tainted 3.19.0-05389-gacf2cf1-dirty #64 Hardware name: STM32 (Device Tree Support) show_stack+0xb/0xc warn_alloc_failed+0x97/0xbc __alloc_pages_nodemask+0x295/0x35c __get_free_pages+0xb/0x24 alloc_pages_exact+0x19/0x24 do_mmap_pgoff+0x423/0x658 vm_mmap_pgoff+0x3f/0x4e load_flat_file+0x20d/0x4f8 load_flat_binary+0x3f/0x26c search_binary_handler+0x51/0xe4 do_execveat_common+0x271/0x35c do_execve+0x19/0x1c ret_fast_syscall+0x1/0x4a Mem-info: Normal per-cpu: CPU 0: hi: 0, btch: 1 usd: 0 active_anon:0 inactive_anon:0 isolated_anon:0 active_file:0 inactive_file:0 isolated_file:0 unevictable:123 dirty:0 writeback:0 unstable:0 free:1515 slab_reclaimable:17 slab_unreclaimable:139 mapped:0 shmem:0 pagetables:0 bounce:0 free_cma:0 Normal free:6060kB min:352kB low:440kB high:528kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:492kB isolated(anon):0ks lowmem_reserve[]: 0 0 Normal: 23*4kB (U) 22*8kB (U) 24*16kB (U) 23*32kB (U) 23*64kB (U) 23*128kB (U) 1*256kB (U) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 6060kB 123 total pagecache pages 2048 pages of RAM 1538 free pages 66 reserved pages 109 slab pages -46 pages shared 0 pages swap cached nommu: Allocation of length 221184 from process 67 (free) failed Normal per-cpu: CPU 0: hi: 0, btch: 1 usd: 0 active_anon:0 inactive_anon:0 isolated_anon:0 active_file:0 inactive_file:0 isolated_file:0 unevictable:123 dirty:0 writeback:0 unstable:0 free:1515 slab_reclaimable:17 slab_unreclaimable:139 mapped:0 shmem:0 pagetables:0 bounce:0 free_cma:0 Normal free:6060kB min:352kB low:440kB high:528kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:492kB isolated(anon):0ks lowmem_reserve[]: 0 0 Normal: 23*4kB (U) 22*8kB (U) 24*16kB (U) 23*32kB (U) 23*64kB (U) 23*128kB (U) 1*256kB (U) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 6060kB 123 total pagecache pages Unable to allocate RAM for process text/data, errno 12 SEGV This problem happens because we allocate ordered page through __get_free_pages() in do_mmap_private() in some cases and we try to free individual pages rather than ordered page in free_page_series(). In this case, freeing pages whose refcount is not 0 won't be freed to the page allocator so memory leak happens. To fix the problem, this patch changes __get_free_pages() to alloc_pages_exact() since alloc_pages_exact() returns physically-contiguous pages but each pages are refcounted. Fixes: dbc8358c7237 ("mm/nommu: use alloc_pages_exact() rather than its own implementation"). Reported-by: Maxime Coquelin <mcoquelin.stm32@gmail.com> Tested-by: Maxime Coquelin <mcoquelin.stm32@gmail.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: <stable@vger.kernel.org> [3.19] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12Merge branch 'for-3.20/bdi' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull backing device changes from Jens Axboe: "This contains a cleanup of how the backing device is handled, in preparation for a rework of the life time rules. In this part, the most important change is to split the unrelated nommu mmap flags from it, but also removing a backing_dev_info pointer from the address_space (and inode), and a cleanup of other various minor bits. Christoph did all the work here, I just fixed an oops with pages that have a swap backing. Arnd fixed a missing export, and Oleg killed the lustre backing_dev_info from staging. Last patch was from Al, unexporting parts that are now no longer needed outside" * 'for-3.20/bdi' of git://git.kernel.dk/linux-block: Make super_blocks and sb_lock static mtd: export new mtd_mmap_capabilities fs: make inode_to_bdi() handle NULL inode staging/lustre/llite: get rid of backing_dev_info fs: remove default_backing_dev_info fs: don't reassign dirty inodes to default_backing_dev_info nfs: don't call bdi_unregister ceph: remove call to bdi_unregister fs: remove mapping->backing_dev_info fs: export inode_to_bdi and use it in favor of mapping->backing_dev_info nilfs2: set up s_bdi like the generic mount_bdev code block_dev: get bdev inode bdi directly from the block device block_dev: only write bdev inode on close fs: introduce f_op->mmap_capabilities for nommu mmap support fs: kill BDI_CAP_SWAP_BACKED fs: deduplicate noop_backing_dev_info
2015-02-11mm/nommu.c: fix arithmetic overflow in __vm_enough_memory()Roman Gushchin
I noticed that "allowed" can easily overflow by falling below 0, because (total_vm / 32) can be larger than "allowed". The problem occurs in OVERCOMMIT_NONE mode. In this case, a huge allocation can success and overcommit the system (despite OVERCOMMIT_NONE mode). All subsequent allocations will fall (system-wide), so system become unusable. The problem was masked out by commit c9b1d0981fcc ("mm: limit growth of 3% hardcoded other user reserve"), but it's easy to reproduce it on older kernels: 1) set overcommit_memory sysctl to 2 2) mmap() large file multiple times (with VM_SHARED flag) 3) try to malloc() large amount of memory It also can be reproduced on newer kernels, but miss-configured sysctl_user_reserve_kbytes is required. Fix this issue by switching to signed arithmetic here. Signed-off-by: Roman Gushchin <klamm@yandex-team.ru> Cc: Andrew Shewmaker <agshew@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11mm: gup: add __get_user_pages_unlocked to customize gup_flagsAndrea Arcangeli
Some callers (like KVM) may want to set the gup_flags like FOLL_HWPOSION to get a proper -EHWPOSION retval instead of -EFAULT to take a more appropriate action if get_user_pages runs into a memory failure. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andres Lagar-Cavilla <andreslc@google.com> Cc: Peter Feiner <pfeiner@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11mm: gup: add get_user_pages_locked and get_user_pages_unlockedAndrea Arcangeli
FAULT_FOLL_ALLOW_RETRY allows the page fault to drop the mmap_sem for reading to reduce the mmap_sem contention (for writing), like while waiting for I/O completion. The problem is that right now practically no get_user_pages call uses FAULT_FOLL_ALLOW_RETRY, so we're not leveraging that nifty feature. Andres fixed it for the KVM page fault. However get_user_pages_fast remains uncovered, and 99% of other get_user_pages aren't using it either (the only exception being FOLL_NOWAIT in KVM which is really nonblocking and in fact it doesn't even release the mmap_sem). So this patchsets extends the optimization Andres did in the KVM page fault to the whole kernel. It makes most important places (including gup_fast) to use FAULT_FOLL_ALLOW_RETRY to reduce the mmap_sem hold times during I/O. The only few places that remains uncovered are drivers like v4l and other exceptions that tends to work on their own memory and they're not working on random user memory (for example like O_DIRECT that uses gup_fast and is fully covered by this patch). A follow up patch should probably also add a printk_once warning to get_user_pages that should go obsolete and be phased out eventually. The "vmas" parameter of get_user_pages makes it fundamentally incompatible with FAULT_FOLL_ALLOW_RETRY (vmas array becomes meaningless the moment the mmap_sem is released). While this is just an optimization, this becomes an absolute requirement for the userfaultfd feature http://lwn.net/Articles/615086/ . The userfaultfd allows to block the page fault, and in order to do so I need to drop the mmap_sem first. So this patch also ensures that all memory where userfaultfd could be registered by KVM, the very first fault (no matter if it is a regular page fault, or a get_user_pages) always has FAULT_FOLL_ALLOW_RETRY set. Then the userfaultfd blocks and it is waken only when the pagetable is already mapped. The second fault attempt after the wakeup doesn't need FAULT_FOLL_ALLOW_RETRY, so it's ok to retry without it. This patch (of 5): We can leverage the VM_FAULT_RETRY functionality in the page fault paths better by using either get_user_pages_locked or get_user_pages_unlocked. The former allows conversion of get_user_pages invocations that will have to pass a "&locked" parameter to know if the mmap_sem was dropped during the call. Example from: down_read(&mm->mmap_sem); do_something() get_user_pages(tsk, mm, ..., pages, NULL); up_read(&mm->mmap_sem); to: int locked = 1; down_read(&mm->mmap_sem); do_something() get_user_pages_locked(tsk, mm, ..., pages, &locked); if (locked) up_read(&mm->mmap_sem); The latter is suitable only as a drop in replacement of the form: down_read(&mm->mmap_sem); get_user_pages(tsk, mm, ..., pages, NULL); up_read(&mm->mmap_sem); into: get_user_pages_unlocked(tsk, mm, ..., pages); Where tsk, mm, the intermediate "..." paramters and "pages" can be any value as before. Just the last parameter of get_user_pages (vmas) must be NULL for get_user_pages_locked|unlocked to be usable (the latter original form wouldn't have been safe anyway if vmas wasn't null, for the former we just make it explicit by dropping the parameter). If vmas is not NULL these two methods cannot be used. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Andres Lagar-Cavilla <andreslc@google.com> Reviewed-by: Peter Feiner <pfeiner@google.com> Reviewed-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-10mm: replace remap_file_pages() syscall with emulationKirill A. Shutemov
remap_file_pages(2) was invented to be able efficiently map parts of huge file into limited 32-bit virtual address space such as in database workloads. Nonlinear mappings are pain to support and it seems there's no legitimate use-cases nowadays since 64-bit systems are widely available. Let's drop it and get rid of all these special-cased code. The patch replaces the syscall with emulation which creates new VMA on each remap_file_pages(), unless they it can be merged with an adjacent one. I didn't find *any* real code that uses remap_file_pages(2) to test emulation impact on. I've checked Debian code search and source of all packages in ALT Linux. No real users: libc wrappers, mentions in strace, gdb, valgrind and this kind of stuff. There are few basic tests in LTP for the syscall. They work just fine with emulation. To test performance impact, I've written small test case which demonstrate pretty much worst case scenario: map 4G shmfs file, write to begin of every page pgoff of the page, remap pages in reverse order, read every page. The test creates 1 million of VMAs if emulation is in use, so I had to set vm.max_map_count to 1100000 to avoid -ENOMEM. Before: 23.3 ( +- 4.31% ) seconds After: 43.9 ( +- 0.85% ) seconds Slowdown: 1.88x I believe we can live with that. Test case: #define _GNU_SOURCE #include <assert.h> #include <stdlib.h> #include <stdio.h> #include <sys/mman.h> #define MB (1024UL * 1024) #define SIZE (4096 * MB) int main(int argc, char **argv) { unsigned long *p; long i, pass; for (pass = 0; pass < 10; pass++) { p = mmap(NULL, SIZE, PROT_READ|PROT_WRITE, MAP_SHARED | MAP_ANONYMOUS, -1, 0); if (p == MAP_FAILED) { perror("mmap"); return -1; } for (i = 0; i < SIZE / 4096; i++) p[i * 4096 / sizeof(*p)] = i; for (i = 0; i < SIZE / 4096; i++) { if (remap_file_pages(p + i * 4096 / sizeof(*p), 4096, 0, (SIZE - 4096 * (i + 1)) >> 12, 0)) { perror("remap_file_pages"); return -1; } } for (i = SIZE / 4096 - 1; i >= 0; i--) assert(p[i * 4096 / sizeof(*p)] == SIZE / 4096 - i - 1); munmap(p, SIZE); } return 0; } [akpm@linux-foundation.org: fix spello] [sasha.levin@oracle.com: initialize populate before usage] [sasha.levin@oracle.com: grab file ref to prevent race while mmaping] Signed-off-by: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Dave Jones <davej@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Armin Rigo <arigo@tunes.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-05mm: export "high_memory" symbol on !MMUArnd Bergmann
The symbol 'high_memory' is provided on both MMU- and NOMMU-kernels, but only one of them is exported, which leads to module build errors in drivers that work fine built-in: ERROR: "high_memory" [drivers/net/virtio_net.ko] undefined! ERROR: "high_memory" [drivers/net/ppp/ppp_mppe.ko] undefined! ERROR: "high_memory" [drivers/mtd/nand/nand.ko] undefined! ERROR: "high_memory" [crypto/tcrypt.ko] undefined! ERROR: "high_memory" [crypto/cts.ko] undefined! This exports the symbol to get these to work on NOMMU as well. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-20fs: introduce f_op->mmap_capabilities for nommu mmap supportChristoph Hellwig
Since "BDI: Provide backing device capability information [try #3]" the backing_dev_info structure also provides flags for the kind of mmap operation available in a nommu environment, which is entirely unrelated to it's original purpose. Introduce a new nommu-only file operation to provide this information to the nommu mmap code instead. Splitting this from the backing_dev_info structure allows to remove lots of backing_dev_info instance that aren't otherwise needed, and entirely gets rid of the concept of providing a backing_dev_info for a character device. It also removes the need for the mtd_inodefs filesystem. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Tejun Heo <tj@kernel.org> Acked-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-12-13mm/nommu: use alloc_pages_exact() rather than its own implementationJoonsoo Kim
do_mmap_private() in nommu.c try to allocate physically contiguous pages with arbitrary size in some cases and we now have good abstract function to do exactly same thing, alloc_pages_exact(). So, change to use it. There is no functional change. This is the preparation step for support page owner feature accurately. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Dave Hansen <dave@sr71.net> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Jungsoo Son <jungsoo.son@lge.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-13mm/nommu: share the i_mmap_rwsemDavidlohr Bueso
Shrinking/truncate logic can call nommu_shrink_inode_mappings() to verify that any shared mappings of the inode in question aren't broken (dead zone). afaict the only user being ramfs to handle the size change attribute. Pretty much a no-brainer to share the lock. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Acked-by: "Kirill A. Shutemov" <kirill@shutemov.name> Acked-by: Hugh Dickins <hughd@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-13mm: use new helper functions around the i_mmap_mutexDavidlohr Bueso
Convert all open coded mutex_lock/unlock calls to the i_mmap_[lock/unlock]_write() helpers. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: "Kirill A. Shutemov" <kirill@shutemov.name> Acked-by: Hugh Dickins <hughd@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-08percpu_counter: add @gfp to percpu_counter_init()Tejun Heo
Percpu allocator now supports allocation mask. Add @gfp to percpu_counter_init() so that !GFP_KERNEL allocation masks can be used with percpu_counters too. We could have left percpu_counter_init() alone and added percpu_counter_init_gfp(); however, the number of users isn't that high and introducing _gfp variants to all percpu data structures would be quite ugly, so let's just do the conversion. This is the one with the most users. Other percpu data structures are a lot easier to convert. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jan Kara <jack@suse.cz> Acked-by: "David S. Miller" <davem@davemloft.net> Cc: x86@kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org>
2014-08-08arm64,ia64,ppc,s390,sh,tile,um,x86,mm: remove default gate areaAndy Lutomirski
The core mm code will provide a default gate area based on FIXADDR_USER_START and FIXADDR_USER_END if !defined(__HAVE_ARCH_GATE_AREA) && defined(AT_SYSINFO_EHDR). This default is only useful for ia64. arm64, ppc, s390, sh, tile, 64-bit UML, and x86_32 have their own code just to disable it. arm, 32-bit UML, and x86_64 have gate areas, but they have their own implementations. This gets rid of the default and moves the code into ia64. This should save some code on architectures without a gate area: it's now possible to inline the gate_area functions in the default case. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Acked-by: Nathan Lynch <nathan_lynch@mentor.com> Acked-by: H. Peter Anvin <hpa@linux.intel.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [in principle] Acked-by: Richard Weinberger <richard@nod.at> [for um] Acked-by: Will Deacon <will.deacon@arm.com> [for arm64] Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Nathan Lynch <Nathan_Lynch@mentor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-23mm: nommu: per-thread vma cache fixSteven Miao
mm could be removed from current task struct, using previous vma->vm_mm It will crash on blackfin after updated to Linux 3.15. The commit "mm: per-thread vma caching" caused the crash. mm could be removed from current task struct before mmput()-> exit_mmap()-> delete_vma_from_mm() the detailed fault information: NULL pointer access Kernel OOPS in progress Deferred Exception context CURRENT PROCESS: COMM=modprobe PID=278 CPU=0 invalid mm return address: [0x000531de]; contents of: 0x000531b0: c727 acea 0c42 181d 0000 0000 0000 a0a8 0x000531c0: b090 acaa 0c42 1806 0000 0000 0000 a0e8 0x000531d0: b0d0 e801 0000 05b3 0010 e522 0046 [a090] 0x000531e0: 6408 b090 0c00 17cc 3042 e3ff f37b 2fc8 CPU: 0 PID: 278 Comm: modprobe Not tainted 3.15.0-ADI-2014R1-pre-00345-gea9f446 #25 task: 0572b720 ti: 0569e000 task.ti: 0569e000 Compiled for cpu family 0x27fe (Rev 0), but running on:0x0000 (Rev 0) ADSP-BF609-0.0 500(MHz CCLK) 125(MHz SCLK) (mpu off) Linux version 3.15.0-ADI-2014R1-pre-00345-gea9f446 (steven@steven-OptiPlex-390) (gcc version 4.3.5 (ADI-trunk/svn-5962) ) #25 Tue Jun 10 17:47:46 CST 2014 SEQUENCER STATUS: Not tainted SEQSTAT: 00000027 IPEND: 8008 IMASK: ffff SYSCFG: 2806 EXCAUSE : 0x27 physical IVG3 asserted : <0xffa00744> { _trap + 0x0 } physical IVG15 asserted : <0xffa00d68> { _evt_system_call + 0x0 } logical irq 6 mapped : <0xffa003bc> { _bfin_coretmr_interrupt + 0x0 } logical irq 7 mapped : <0x00008828> { _bfin_fault_routine + 0x0 } logical irq 11 mapped : <0x00007724> { _l2_ecc_err + 0x0 } logical irq 13 mapped : <0x00008828> { _bfin_fault_routine + 0x0 } logical irq 39 mapped : <0x00150788> { _bfin_twi_interrupt_entry + 0x0 } logical irq 40 mapped : <0x00150788> { _bfin_twi_interrupt_entry + 0x0 } RETE: <0x00000000> /* Maybe null pointer? */ RETN: <0x0569fe50> /* kernel dynamic memory (maybe user-space) */ RETX: <0x00000480> /* Maybe fixed code section */ RETS: <0x00053384> { _exit_mmap + 0x28 } PC : <0x000531de> { _delete_vma_from_mm + 0x92 } DCPLB_FAULT_ADDR: <0x00000008> /* Maybe null pointer? */ ICPLB_FAULT_ADDR: <0x000531de> { _delete_vma_from_mm + 0x92 } PROCESSOR STATE: R0 : 00000004 R1 : 0569e000 R2 : 00bf3db4 R3 : 00000000 R4 : 057f9800 R5 : 00000001 R6 : 0569ddd0 R7 : 0572b720 P0 : 0572b854 P1 : 00000004 P2 : 00000000 P3 : 0569dda0 P4 : 0572b720 P5 : 0566c368 FP : 0569fe5c SP : 0569fd74 LB0: 057f523f LT0: 057f523e LC0: 00000000 LB1: 0005317c LT1: 00053172 LC1: 00000002 B0 : 00000000 L0 : 00000000 M0 : 0566f5bc I0 : 00000000 B1 : 00000000 L1 : 00000000 M1 : 00000000 I1 : ffffffff B2 : 00000001 L2 : 00000000 M2 : 00000000 I2 : 00000000 B3 : 00000000 L3 : 00000000 M3 : 00000000 I3 : 057f8000 A0.w: 00000000 A0.x: 00000000 A1.w: 00000000 A1.x: 00000000 USP : 056ffcf8 ASTAT: 02003024 Hardware Trace: 0 Target : <0x00003fb8> { _trap_c + 0x0 } Source : <0xffa006d8> { _exception_to_level5 + 0xa0 } JUMP.L 1 Target : <0xffa00638> { _exception_to_level5 + 0x0 } Source : <0xffa004f2> { _bfin_return_from_exception + 0x6 } RTX 2 Target : <0xffa004ec> { _bfin_return_from_exception + 0x0 } Source : <0xffa00590> { _ex_trap_c + 0x70 } JUMP.S 3 Target : <0xffa00520> { _ex_trap_c + 0x0 } Source : <0xffa0076e> { _trap + 0x2a } JUMP (P4) 4 Target : <0xffa00744> { _trap + 0x0 } FAULT : <0x000531de> { _delete_vma_from_mm + 0x92 } P0 = W[P2 + 2] Source : <0x000531da> { _delete_vma_from_mm + 0x8e } P2 = [P4 + 0x18] 5 Target : <0x000531da> { _delete_vma_from_mm + 0x8e } Source : <0x00053176> { _delete_vma_from_mm + 0x2a } IF CC JUMP pcrel 6 Target : <0x0005314c> { _delete_vma_from_mm + 0x0 } Source : <0x00053380> { _exit_mmap + 0x24 } JUMP.L 7 Target : <0x00053378> { _exit_mmap + 0x1c } Source : <0x00053394> { _exit_mmap + 0x38 } IF !CC JUMP pcrel (BP) 8 Target : <0x00053390> { _exit_mmap + 0x34 } Source : <0xffa020e0> { __cond_resched + 0x20 } RTS 9 Target : <0xffa020c0> { __cond_resched + 0x0 } Source : <0x0005338c> { _exit_mmap + 0x30 } JUMP.L 10 Target : <0x0005338c> { _exit_mmap + 0x30 } Source : <0x0005333a> { _delete_vma + 0xb2 } RTS 11 Target : <0x00053334> { _delete_vma + 0xac } Source : <0x0005507a> { _kmem_cache_free + 0xba } RTS 12 Target : <0x00055068> { _kmem_cache_free + 0xa8 } Source : <0x0005505e> { _kmem_cache_free + 0x9e } IF !CC JUMP pcrel (BP) 13 Target : <0x00055052> { _kmem_cache_free + 0x92 } Source : <0x0005501a> { _kmem_cache_free + 0x5a } IF CC JUMP pcrel 14 Target : <0x00054ff4> { _kmem_cache_free + 0x34 } Source : <0x00054fce> { _kmem_cache_free + 0xe } IF CC JUMP pcrel (BP) 15 Target : <0x00054fc0> { _kmem_cache_free + 0x0 } Source : <0x00053330> { _delete_vma + 0xa8 } JUMP.L Kernel Stack Stack info: SP: [0x0569ff24] <0x0569ff24> /* kernel dynamic memory (maybe user-space) */ Memory from 0x0569ff20 to 056a0000 0569ff20: 00000001 [04e8da5a] 00008000 00000000 00000000 056a0000 04e8da5a 04e8da5a 0569ff40: 04eb9eea ffa00dce 02003025 04ea09c5 057f523f 04ea09c4 057f523e 00000000 0569ff60: 00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000 0569ff80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0569ffa0: 0566f5bc 057f8000 057f8000 00000001 04ec0170 056ffcf8 056ffd04 057f9800 0569ffc0: 04d1d498 057f9800 057f8fe4 057f8ef0 00000001 057f928c 00000001 00000001 0569ffe0: 057f9800 00000000 00000008 00000007 00000001 00000001 00000001 <00002806> Return addresses in stack: address : <0x00002806> { _show_cpuinfo + 0x2d2 } Modules linked in: Kernel panic - not syncing: Kernel exception [ end Kernel panic - not syncing: Kernel exception Signed-off-by: Steven Miao <realmz6@gmail.com> Acked-by: Davidlohr Bueso <davidlohr@hp.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> [3.15.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06mm: convert some level-less printks to pr_*Mitchel Humpherys
printk is meant to be used with an associated log level. There are some instances of printk scattered around the mm code where the log level is missing. Add a log level and adhere to suggestions by scripts/checkpatch.pl by moving to the pr_* macros. Also add the typical pr_fmt definition so that print statements can be easily traced back to the modules where they occur, correlated one with another, etc. This will require the removal of some (now redundant) prefixes on a few print statements. Signed-off-by: Mitchel Humpherys <mitchelh@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07mm: fix 'ERROR: do not initialise globals to 0 or NULL' and coding styleChoi Gi-yong
Signed-off-by: Choi Gi-yong <yong@gnoy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07mm: use macros from compiler.h instead of __attribute__((...))Gideon Israel Dsouza
To increase compiler portability there is <linux/compiler.h> which provides convenience macros for various gcc constructs. Eg: __weak for __attribute__((weak)). I've replaced all instances of gcc attributes with the right macro in the memory management (/mm) subsystem. [akpm@linux-foundation.org: while-we're-there consistency tweaks] Signed-off-by: Gideon Israel Dsouza <gidisrael@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07mm: per-thread vma cachingDavidlohr Bueso
This patch is a continuation of efforts trying to optimize find_vma(), avoiding potentially expensive rbtree walks to locate a vma upon faults. The original approach (https://lkml.org/lkml/2013/11/1/410), where the largest vma was also cached, ended up being too specific and random, thus further comparison with other approaches were needed. There are two things to consider when dealing with this, the cache hit rate and the latency of find_vma(). Improving the hit-rate does not necessarily translate in finding the vma any faster, as the overhead of any fancy caching schemes can be too high to consider. We currently cache the last used vma for the whole address space, which provides a nice optimization, reducing the total cycles in find_vma() by up to 250%, for workloads with good locality. On the other hand, this simple scheme is pretty much useless for workloads with poor locality. Analyzing ebizzy runs shows that, no matter how many threads are running, the mmap_cache hit rate is less than 2%, and in many situations below 1%. The proposed approach is to replace this scheme with a small per-thread cache, maximizing hit rates at a very low maintenance cost. Invalidations are performed by simply bumping up a 32-bit sequence number. The only expensive operation is in the rare case of a seq number overflow, where all caches that share the same address space are flushed. Upon a miss, the proposed replacement policy is based on the page number that contains the virtual address in question. Concretely, the following results are seen on an 80 core, 8 socket x86-64 box: 1) System bootup: Most programs are single threaded, so the per-thread scheme does improve ~50% hit rate by just adding a few more slots to the cache. +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 50.61% | 19.90 | | patched | 73.45% | 13.58 | +----------------+----------+------------------+ 2) Kernel build: This one is already pretty good with the current approach as we're dealing with good locality. +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 75.28% | 11.03 | | patched | 88.09% | 9.31 | +----------------+----------+------------------+ 3) Oracle 11g Data Mining (4k pages): Similar to the kernel build workload. +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 70.66% | 17.14 | | patched | 91.15% | 12.57 | +----------------+----------+------------------+ 4) Ebizzy: There's a fair amount of variation from run to run, but this approach always shows nearly perfect hit rates, while baseline is just about non-existent. The amounts of cycles can fluctuate between anywhere from ~60 to ~116 for the baseline scheme, but this approach reduces it considerably. For instance, with 80 threads: +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 1.06% | 91.54 | | patched | 99.97% | 14.18 | +----------------+----------+------------------+ [akpm@linux-foundation.org: fix nommu build, per Davidlohr] [akpm@linux-foundation.org: document vmacache_valid() logic] [akpm@linux-foundation.org: attempt to untangle header files] [akpm@linux-foundation.org: add vmacache_find() BUG_ON] [hughd@google.com: add vmacache_valid_mm() (from Oleg)] [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: adjust and enhance comments] Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Reviewed-by: Michel Lespinasse <walken@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Tested-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07mm: implement ->map_pages for page cacheKirill A. Shutemov
filemap_map_pages() is generic implementation of ->map_pages() for filesystems who uses page cache. It should be safe to use filemap_map_pages() for ->map_pages() if filesystem use filemap_fault() for ->fault(). Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Dave Chinner <david@fromorbit.com> Cc: Ning Qu <quning@gmail.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-31locks: fix locks_mandatory_locked to respect file-private locksJeff Layton
As Trond pointed out, you can currently deadlock yourself by setting a file-private lock on a file that requires mandatory locking and then trying to do I/O on it. Avoid this problem by plumbing some knowledge of file-private locks into the mandatory locking code. In order to do this, we must pass down information about the struct file that's being used to locks_verify_locked. Reported-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: J. Bruce Fields <bfields@redhat.com>
2014-01-21mm: add overcommit_kbytes sysctl variableJerome Marchand
Some applications that run on HPC clusters are designed around the availability of RAM and the overcommit ratio is fine tuned to get the maximum usage of memory without swapping. With growing memory, the 1%-of-all-RAM grain provided by overcommit_ratio has become too coarse for these workload (on a 2TB machine it represents no less than 20GB). This patch adds the new overcommit_kbytes sysctl variable that allow a much finer grain. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix nommu build] Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: "Quite a lot of other stuff is banked up awaiting further next->mainline merging, but this batch contains: - Lots of random misc patches - OCFS2 - Most of MM - backlight updates - lib/ updates - printk updates - checkpatch updates - epoll tweaking - rtc updates - hfs - hfsplus - documentation - procfs - update gcov to gcc-4.7 format - IPC" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (269 commits) ipc, msg: fix message length check for negative values ipc/util.c: remove unnecessary work pending test devpts: plug the memory leak in kill_sb ./Makefile: export initial ramdisk compression config option init/Kconfig: add option to disable kernel compression drivers: w1: make w1_slave::flags long to avoid memory corruption drivers/w1/masters/ds1wm.cuse dev_get_platdata() drivers/memstick/core/ms_block.c: fix unreachable state in h_msb_read_page() drivers/memstick/core/mspro_block.c: fix attributes array allocation drivers/pps/clients/pps-gpio.c: remove redundant of_match_ptr kernel/panic.c: reduce 1 byte usage for print tainted buffer gcov: reuse kbasename helper kernel/gcov/fs.c: use pr_warn() kernel/module.c: use pr_foo() gcov: compile specific gcov implementation based on gcc version gcov: add support for gcc 4.7 gcov format gcov: move gcov structs definitions to a gcc version specific file kernel/taskstats.c: return -ENOMEM when alloc memory fails in add_del_listener() kernel/taskstats.c: add nla_nest_cancel() for failure processing between nla_nest_start() and nla_nest_end() kernel/sysctl_binary.c: use scnprintf() instead of snprintf() ...
2013-11-13mm: factor commit limit calculationJerome Marchand
The same calculation is currently done in three differents places. Factor that code so future changes has to be made at only one place. [akpm@linux-foundation.org: uninline vm_commit_limit()] Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-24file->f_op is never NULL...Al Viro
2013-07-10mm: remove free_area_cacheMichel Lespinasse
Since all architectures have been converted to use vm_unmapped_area(), there is no remaining use for the free_area_cache. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Helge Deller <deller@gmx.de> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: kill global variable num_physpagesJiang Liu
Now all references to num_physpages have been removed, so kill it. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm/nommu.c: add additional check for vread() just like vwrite() has doneChen Gang
vwrite() checks for overflow. vread() should do the same thing. Since vwrite() checks the source buffer address, vread() should check the destination buffer address. Signed-off-by: Chen Gang <gang.chen@asianux.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull compat cleanup from Al Viro: "Mostly about syscall wrappers this time; there will be another pile with patches in the same general area from various people, but I'd rather push those after both that and vfs.git pile are in." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: syscalls.h: slightly reduce the jungles of macros get rid of union semop in sys_semctl(2) arguments make do_mremap() static sparc: no need to sign-extend in sync_file_range() wrapper ppc compat wrappers for add_key(2) and request_key(2) are pointless x86: trim sys_ia32.h x86: sys32_kill and sys32_mprotect are pointless get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC merge compat sys_ipc instances consolidate compat lookup_dcookie() convert vmsplice to COMPAT_SYSCALL_DEFINE switch getrusage() to COMPAT_SYSCALL_DEFINE switch epoll_pwait to COMPAT_SYSCALL_DEFINE convert sendfile{,64} to COMPAT_SYSCALL_DEFINE switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect make HAVE_SYSCALL_WRAPPERS unconditional consolidate cond_syscall and SYSCALL_ALIAS declarations teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long get rid of duplicate logics in __SC_....[1-6] definitions
2013-04-29mm: replace hardcoded 3% with admin_reserve_pages knobAndrew Shewmaker
Add an admin_reserve_kbytes knob to allow admins to change the hardcoded memory reserve to something other than 3%, which may be multiple gigabytes on large memory systems. Only about 8MB is necessary to enable recovery in the default mode, and only a few hundred MB are required even when overcommit is disabled. This affects OVERCOMMIT_GUESS and OVERCOMMIT_NEVER. admin_reserve_kbytes is initialized to min(3% free pages, 8MB) I arrived at 8MB by summing the RSS of sshd or login, bash, and top. Please see first patch in this series for full background, motivation, testing, and full changelog. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make init_admin_reserve() static] Signed-off-by: Andrew Shewmaker <agshew@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm: limit growth of 3% hardcoded other user reserveAndrew Shewmaker
Add user_reserve_kbytes knob. Limit the growth of the memory reserved for other user processes to min(3% current process size, user_reserve_pages). Only about 8MB is necessary to enable recovery in the default mode, and only a few hundred MB are required even when overcommit is disabled. user_reserve_pages defaults to min(3% free pages, 128MB) I arrived at 128MB by taking the max VSZ of sshd, login, bash, and top ... then adding the RSS of each. This only affects OVERCOMMIT_NEVER mode. Background 1. user reserve __vm_enough_memory reserves a hardcoded 3% of the current process size for other applications when overcommit is disabled. This was done so that a user could recover if they launched a memory hogging process. Without the reserve, a user would easily run into a message such as: bash: fork: Cannot allocate memory 2. admin reserve Additionally, a hardcoded 3% of free memory is reserved for root in both overcommit 'guess' and 'never' modes. This was intended to prevent a scenario where root-cant-log-in and perform recovery operations. Note that this reserve shrinks, and doesn't guarantee a useful reserve. Motivation The two hardcoded memory reserves should be updated to account for current memory sizes. Also, the admin reserve would be more useful if it didn't shrink too much. When the current code was originally written, 1GB was considered "enterprise". Now the 3% reserve can grow to multiple GB on large memory systems, and it only needs to be a few hundred MB at most to enable a user or admin to recover a system with an unwanted memory hogging process. I've found that reducing these reserves is especially beneficial for a specific type of application load: * single application system * one or few processes (e.g. one per core) * allocating all available memory * not initializing every page immediately * long running I've run scientific clusters with this sort of load. A long running job sometimes failed many hours (weeks of CPU time) into a calculation. They weren't initializing all of their memory immediately, and they weren't using calloc, so I put systems into overcommit 'never' mode. These clusters run diskless and have no swap. However, with the current reserves, a user wishing to allocate as much memory as possible to one process may be prevented from using, for example, almost 2GB out of 32GB. The effect is less, but still significant when a user starts a job with one process per core. I have repeatedly seen a set of processes requesting the same amount of memory fail because one of them could not allocate the amount of memory a user would expect to be able to allocate. For example, Message Passing Interfce (MPI) processes, one per core. And it is similar for other parallel programming frameworks. Changing this reserve code will make the overcommit never mode more useful by allowing applications to allocate nearly all of the available memory. Also, the new admin_reserve_kbytes will be safer than the current behavior since the hardcoded 3% of available memory reserve can shrink to something useless in the case where applications have grabbed all available memory. Risks * "bash: fork: Cannot allocate memory" The downside of the first patch-- which creates a tunable user reserve that is only used in overcommit 'never' mode--is that an admin can set it so low that a user may not be able to kill their process, even if they already have a shell prompt. Of course, a user can get in the same predicament with the current 3% reserve--they just have to launch processes until 3% becomes negligible. * root-cant-log-in problem The second patch, adding the tunable rootuser_reserve_pages, allows the admin to shoot themselves in the foot by setting it too small. They can easily get the system into a state where root-can't-log-in. However, the new admin_reserve_kbytes will be safer than the current behavior since the hardcoded 3% of available memory reserve can shrink to something useless in the case where applications have grabbed all available memory. Alternatives * Memory cgroups provide a more flexible way to limit application memory. Not everyone wants to set up cgroups or deal with their overhead. * We could create a fourth overcommit mode which provides smaller reserves. The size of useful reserves may be drastically different depending on the whether the system is embedded or enterprise. * Force users to initialize all of their memory or use calloc. Some users don't want/expect the system to overcommit when they malloc. Overcommit 'never' mode is for this scenario, and it should work well. The new user and admin reserve tunables are simple to use, with low overhead compared to cgroups. The patches preserve current behavior where 3% of memory is less than 128MB, except that the admin reserve doesn't shrink to an unusable size under pressure. The code allows admins to tune for embedded and enterprise usage. FAQ * How is the root-cant-login problem addressed? What happens if admin_reserve_pages is set to 0? Root is free to shoot themselves in the foot by setting admin_reserve_kbytes too low. On x86_64, the minimum useful reserve is: 8MB for overcommit 'guess' 128MB for overcommit 'never' admin_reserve_pages defaults to min(3% free memory, 8MB) So, anyone switching to 'never' mode needs to adjust admin_reserve_pages. * How do you calculate a minimum useful reserve? A user or the admin needs enough memory to login and perform recovery operations, which includes, at a minimum: sshd or login + bash (or some other shell) + top (or ps, kill, etc.) For overcommit 'guess', we can sum resident set sizes (RSS) because we only need enough memory to handle what the recovery programs will typically use. On x86_64 this is about 8MB. For overcommit 'never', we can take the max of their virtual sizes (VSZ) and add the sum of their RSS. We use VSZ instead of RSS because mode forces us to ensure we can fulfill all of the requested memory allocations-- even if the programs only use a fraction of what they ask for. On x86_64 this is about 128MB. When swap is enabled, reserves are useful even when they are as small as 10MB, regardless of overcommit mode. When both swap and overcommit are disabled, then the admin should tune the reserves higher to be absolutley safe. Over 230MB each was safest in my testing. * What happens if user_reserve_pages is set to 0? Note, this only affects overcomitt 'never' mode. Then a user will be able to allocate all available memory minus admin_reserve_kbytes. However, they will easily see a message such as: "bash: fork: Cannot allocate memory" And they won't be able to recover/kill their application. The admin should be able to recover the system if admin_reserve_kbytes is set appropriately. * What's the difference between overcommit 'guess' and 'never'? "Guess" allows an allocation if there are enough free + reclaimable pages. It has a hardcoded 3% of free pages reserved for root. "Never" allows an allocation if there is enough swap + a configurable percentage (default is 50) of physical RAM. It has a hardcoded 3% of free pages reserved for root, like "Guess" mode. It also has a hardcoded 3% of the current process size reserved for additional applications. * Why is overcommit 'guess' not suitable even when an app eventually writes to every page? It takes free pages, file pages, available swap pages, reclaimable slab pages into consideration. In other words, these are all pages available, then why isn't overcommit suitable? Because it only looks at the present state of the system. It does not take into account the memory that other applications have malloced, but haven't initialized yet. It overcommits the system. Test Summary There was little change in behavior in the default overcommit 'guess' mode with swap enabled before and after the patch. This was expected. Systems run most predictably (i.e. no oom kills) in overcommit 'never' mode with swap enabled. This also allowed the most memory to be allocated to a user application. Overcommit 'guess' mode without swap is a bad idea. It is easy to crash the system. None of the other tested combinations crashed. This matches my experience on the Roadrunner supercomputer. Without the tunable user reserve, a system in overcommit 'never' mode and without swap does not allow the admin to recover, although the admin can. With the new tunable reserves, a system in overcommit 'never' mode and without swap can be configured to: 1. maximize user-allocatable memory, running close to the edge of recoverability 2. maximize recoverability, sacrificing allocatable memory to ensure that a user cannot take down a system Test Description Fedora 18 VM - 4 x86_64 cores, 5725MB RAM, 4GB Swap System is booted into multiuser console mode, with unnecessary services turned off. Caches were dropped before each test. Hogs are user memtester processes that attempt to allocate all free memory as reported by /proc/meminfo In overcommit 'never' mode, memory_ratio=100 Test Results 3.9.0-rc1-mm1 Overcommit | Swap | Hogs | MB Got/Wanted | OOMs | User Recovery | Admin Recovery ---------- ---- ---- ------------- ---- ------------- -------------- guess yes 1 5432/5432 no yes yes guess yes 4 5444/5444 1 yes yes guess no 1 5302/5449 no yes yes guess no 4 - crash no no never yes 1 5460/5460 1 yes yes never yes 4 5460/5460 1 yes yes never no 1 5218/5432 no no yes never no 4 5203/5448 no no yes 3.9.0-rc1-mm1-tunablereserves User and Admin Recovery show their respective reserves, if applicable. Overcommit | Swap | Hogs | MB Got/Wanted | OOMs | User Recovery | Admin Recovery ---------- ---- ---- ------------- ---- ------------- -------------- guess yes 1 5419/5419 no - yes 8MB yes guess yes 4 5436/5436 1 - yes 8MB yes guess no 1 5440/5440 * - yes 8MB yes guess no 4 - crash - no 8MB no * process would successfully mlock, then the oom killer would pick it never yes 1 5446/5446 no 10MB yes 20MB yes never yes 4 5456/5456 no 10MB yes 20MB yes never no 1 5387/5429 no 128MB no 8MB barely never no 1 5323/5428 no 226MB barely 8MB barely never no 1 5323/5428 no 226MB barely 8MB barely never no 1 5359/5448 no 10MB no 10MB barely never no 1 5323/5428 no 0MB no 10MB barely never no 1 5332/5428 no 0MB no 50MB yes never no 1 5293/5429 no 0MB no 90MB yes never no 1 5001/5427 no 230MB yes 338MB yes never no 4* 4998/5424 no 230MB yes 338MB yes * more memtesters were launched, able to allocate approximately another 100MB Future Work - Test larger memory systems. - Test an embedded image. - Test other architectures. - Time malloc microbenchmarks. - Would it be useful to be able to set overcommit policy for each memory cgroup? - Some lines are slightly above 80 chars. Perhaps define a macro to convert between pages and kb? Other places in the kernel do this. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make init_user_reserve() static] Signed-off-by: Andrew Shewmaker <agshew@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm, vmalloc: export vmap_area_list, instead of vmlistJoonsoo Kim
Although our intention is to unexport internal structure entirely, but there is one exception for kexec. kexec dumps address of vmlist and makedumpfile uses this information. We are about to remove vmlist, then another way to retrieve information of vmalloc layer is needed for makedumpfile. For this purpose, we export vmap_area_list, instead of vmlist. Signed-off-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Dave Anderson <anderson@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-27vm: add no-mmu vm_iomap_memory() stubLinus Torvalds
I think we could just move the full vm_iomap_memory() function into util.h or similar, but I didn't get any reply from anybody actually using nommu even to this trivial patch, so I'm not going to touch it any more than required. Here's the fairly minimal stub to make the nommu case at least potentially work. It doesn't seem like anybody cares, though. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-04mm: prevent mmap_cache race in find_vma()Jan Stancek
find_vma() can be called by multiple threads with read lock held on mm->mmap_sem and any of them can update mm->mmap_cache. Prevent compiler from re-fetching mm->mmap_cache, because other readers could update it in the meantime: thread 1 thread 2 | find_vma() | find_vma() struct vm_area_struct *vma = NULL; | vma = mm->mmap_cache; | if (!(vma && vma->vm_end > addr | && vma->vm_start <= addr)) { | | mm->mmap_cache = vma; return vma; | ^^ compiler may optimize this | local variable out and re-read | mm->mmap_cache | This issue can be reproduced with gcc-4.8.0-1 on s390x by running mallocstress testcase from LTP, which triggers: kernel BUG at mm/rmap.c:1088! Call Trace: ([<000003d100c57000>] 0x3d100c57000) [<000000000023a1c0>] do_wp_page+0x2fc/0xa88 [<000000000023baae>] handle_pte_fault+0x41a/0xac8 [<000000000023d832>] handle_mm_fault+0x17a/0x268 [<000000000060507a>] do_protection_exception+0x1e2/0x394 [<0000000000603a04>] pgm_check_handler+0x138/0x13c [<000003fffcf1f07a>] 0x3fffcf1f07a Last Breaking-Event-Address: [<000000000024755e>] page_add_new_anon_rmap+0xc2/0x168 Thanks to Jakub Jelinek for his insight on gcc and helping to track this down. Signed-off-by: Jan Stancek <jstancek@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-04make do_mremap() staticAl Viro
The extern in sys_sparc_64.c was a rudiment of time when do_mremap() used to exist in MMU case (it doesn't anymore). As for !MMU one, nothing uses it outside of mm/nommu.c... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-23mm: accelerate mm_populate() treatment of THP pagesMichel Lespinasse
This change adds a follow_page_mask function which is equivalent to follow_page, but with an extra page_mask argument. follow_page_mask sets *page_mask to HPAGE_PMD_NR - 1 when it encounters a THP page, and to 0 in other cases. __get_user_pages() makes use of this in order to accelerate populating THP ranges - that is, when both the pages and vmas arrays are NULL, we don't need to iterate HPAGE_PMD_NR times to cover a single THP page (and we also avoid taking mm->page_table_lock that many times). Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23mm: use long type for page counts in mm_populate() and get_user_pages()Michel Lespinasse
Use long type for page counts in mm_populate() so as to avoid integer overflow when running the following test code: int main(void) { void *p = mmap(NULL, 0x100000000000, PROT_READ, MAP_PRIVATE | MAP_ANON, -1, 0); printf("p: %p\n", p); mlockall(MCL_CURRENT); printf("done\n"); return 0; } Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23swap: add per-partition lock for swapfileShaohua Li
swap_lock is heavily contended when I test swap to 3 fast SSD (even slightly slower than swap to 2 such SSD). The main contention comes from swap_info_get(). This patch tries to fix the gap with adding a new per-partition lock. Global data like nr_swapfiles, total_swap_pages, least_priority and swap_list are still protected by swap_lock. nr_swap_pages is an atomic now, it can be changed without swap_lock. In theory, it's possible get_swap_page() finds no swap pages but actually there are free swap pages. But sounds not a big problem. Accessing partition specific data (like scan_swap_map and so on) is only protected by swap_info_struct.lock. Changing swap_info_struct.flags need hold swap_lock and swap_info_struct.lock, because scan_scan_map() will check it. read the flags is ok with either the locks hold. If both swap_lock and swap_info_struct.lock must be hold, we always hold the former first to avoid deadlock. swap_entry_free() can change swap_list. To delete that code, we add a new highest_priority_index. Whenever get_swap_page() is called, we check it. If it's valid, we use it. It's a pity get_swap_page() still holds swap_lock(). But in practice, swap_lock() isn't heavily contended in my test with this patch (or I can say there are other much more heavier bottlenecks like TLB flush). And BTW, looks get_swap_page() doesn't really need the lock. We never free swap_info[] and we check SWAP_WRITEOK flag. The only risk without the lock is we could swapout to some low priority swap, but we can quickly recover after several rounds of swap, so sounds not a big deal to me. But I'd prefer to fix this if it's a real problem. "swap: make each swap partition have one address_space" improved the swapout speed from 1.7G/s to 2G/s. This patch further improves the speed to 2.3G/s, so around 15% improvement. It's a multi-process test, so TLB flush isn't the biggest bottleneck before the patches. [arnd@arndb.de: fix it for nommu] [hughd@google.com: add missing unlock] [minchan@kernel.org: get rid of lockdep whinge on sys_swapon] Signed-off-by: Shaohua Li <shli@fusionio.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23mm: make do_mmap_pgoff return populate as a size in bytes, not as a boolMichel Lespinasse
do_mmap_pgoff() rounds up the desired size to the next PAGE_SIZE multiple, however there was no equivalent code in mm_populate(), which caused issues. This could be fixed by introduced the same rounding in mm_populate(), however I think it's preferable to make do_mmap_pgoff() return populate as a size rather than as a boolean, so we don't have to duplicate the size rounding logic in mm_populate(). Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Rik van Riel <riel@redhat.com> Tested-by: Andy Lutomirski <luto@amacapital.net> Cc: Greg Ungerer <gregungerer@westnet.com.au> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
