global_page_state is error prone as a recent bug report pointed out [1].
It only returns proper values for zone based counters as the enum it
gets suggests. We already have global_node_page_state so let's rename
global_page_state to global_zone_page_state to be more explicit here.
All existing users seems to be correct:
$ git grep "global_page_state(NR_" | sed 's@.*(\(NR_[A-Z_]*\)).*@\1@' | sort | uniq -c
2 NR_BOUNCE
2 NR_FREE_CMA_PAGES
11 NR_FREE_PAGES
1 NR_KERNEL_STACK_KB
1 NR_MLOCK
2 NR_PAGETABLE
This patch shouldn't introduce any functional change.
[1] http://lkml.kernel.org/r/201707260628.v6Q6SmaS030814@www262.sakura.ne.jp
Link: http://lkml.kernel.org/r/20170801134256.5400-2-hannes@cmpxchg.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Cc: Josef Bacik <josef@toxicpanda.com>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
__vmalloc* allows users to provide gfp flags for the underlying
allocation. This API is quite popular
$ git grep "=[[:space:]]__vmalloc\|return[[:space:]]*__vmalloc" | wc -l
77
The only problem is that many people are not aware that they really want
to give __GFP_HIGHMEM along with other flags because there is really no
reason to consume precious lowmemory on CONFIG_HIGHMEM systems for pages
which are mapped to the kernel vmalloc space. About half of users don't
use this flag, though. This signals that we make the API unnecessarily
too complex.
This patch simply uses __GFP_HIGHMEM implicitly when allocating pages to
be mapped to the vmalloc space. Current users which add __GFP_HIGHMEM
are simplified and drop the flag.
Link: http://lkml.kernel.org/r/20170307141020.29107-1-mhocko@kernel.org
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Cristopher Lameter <cl@linux.com>
Patch series "kvmalloc", v5.
There are many open coded kmalloc with vmalloc fallback instances in the
tree. Most of them are not careful enough or simply do not care about
the underlying semantic of the kmalloc/page allocator which means that
a) some vmalloc fallbacks are basically unreachable because the kmalloc
part will keep retrying until it succeeds b) the page allocator can
invoke a really disruptive steps like the OOM killer to move forward
which doesn't sound appropriate when we consider that the vmalloc
fallback is available.
As it can be seen implementing kvmalloc requires quite an intimate
knowledge if the page allocator and the memory reclaim internals which
strongly suggests that a helper should be implemented in the memory
subsystem proper.
Most callers, I could find, have been converted to use the helper
instead. This is patch 6. There are some more relying on __GFP_REPEAT
in the networking stack which I have converted as well and Eric Dumazet
was not opposed [2] to convert them as well.
[1] http://lkml.kernel.org/r/20170130094940.13546-1-mhocko@kernel.org
[2] http://lkml.kernel.org/r/1485273626.16328.301.camel@edumazet-glaptop3.roam.corp.google.com
This patch (of 9):
Using kmalloc with the vmalloc fallback for larger allocations is a
common pattern in the kernel code. Yet we do not have any common helper
for that and so users have invented their own helpers. Some of them are
really creative when doing so. Let's just add kv[mz]alloc and make sure
it is implemented properly. This implementation makes sure to not make
a large memory pressure for > PAGE_SZE requests (__GFP_NORETRY) and also
to not warn about allocation failures. This also rules out the OOM
killer as the vmalloc is a more approapriate fallback than a disruptive
user visible action.
This patch also changes some existing users and removes helpers which
are specific for them. In some cases this is not possible (e.g.
ext4_kvmalloc, libcfs_kvzalloc) because those seems to be broken and
require GFP_NO{FS,IO} context which is not vmalloc compatible in general
(note that the page table allocation is GFP_KERNEL). Those need to be
fixed separately.
While we are at it, document that __vmalloc{_node} about unsupported gfp
mask because there seems to be a lot of confusion out there.
kvmalloc_node will warn about GFP_KERNEL incompatible (which are not
superset) flags to catch new abusers. Existing ones would have to die
slowly.
[sfr@canb.auug.org.au: f2fs fixup]
Link: http://lkml.kernel.org/r/20170320163735.332e64b7@canb.auug.org.au
Link: http://lkml.kernel.org/r/20170306103032.2540-2-mhocko@kernel.org
Reviewed-by: Andreas Dilger <adilger@dilger.ca> [ext4 part]
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: John Hubbard <jhubbard@nvidia.com>
Pull sched.h split-up from Ingo Molnar:
"The point of these changes is to significantly reduce the
<linux/sched.h> header footprint, to speed up the kernel build and to
have a cleaner header structure.
After these changes the new <linux/sched.h>'s typical preprocessed
size goes down from a previous ~0.68 MB (~22K lines) to ~0.45 MB (~15K
lines), which is around 40% faster to build on typical configs.
Not much changed from the last version (-v2) posted three weeks ago: I
eliminated quirks, backmerged fixes plus I rebased it to an upstream
SHA1 from yesterday that includes most changes queued up in -next plus
all sched.h changes that were pending from Andrew.
I've re-tested the series both on x86 and on cross-arch defconfigs,
and did a bisectability test at a number of random points.
I tried to test as many build configurations as possible, but some
build breakage is probably still left - but it should be mostly
limited to architectures that have no cross-compiler binaries
available on kernel.org, and non-default configurations"
* 'WIP.sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (146 commits)
sched/headers: Clean up <linux/sched.h>
sched/headers: Remove #ifdefs from <linux/sched.h>
sched/headers: Remove the <linux/topology.h> include from <linux/sched.h>
sched/headers, hrtimer: Remove the <linux/wait.h> include from <linux/hrtimer.h>
sched/headers, x86/apic: Remove the <linux/pm.h> header inclusion from <asm/apic.h>
sched/headers, timers: Remove the <linux/sysctl.h> include from <linux/timer.h>
sched/headers: Remove <linux/magic.h> from <linux/sched/task_stack.h>
sched/headers: Remove <linux/sched.h> from <linux/sched/init.h>
sched/core: Remove unused prefetch_stack()
sched/headers: Remove <linux/rculist.h> from <linux/sched.h>
sched/headers: Remove the 'init_pid_ns' prototype from <linux/sched.h>
sched/headers: Remove <linux/signal.h> from <linux/sched.h>
sched/headers: Remove <linux/rwsem.h> from <linux/sched.h>
sched/headers: Remove the runqueue_is_locked() prototype
sched/headers: Remove <linux/sched.h> from <linux/sched/hotplug.h>
sched/headers: Remove <linux/sched.h> from <linux/sched/debug.h>
sched/headers: Remove <linux/sched.h> from <linux/sched/nohz.h>
sched/headers: Remove <linux/sched.h> from <linux/sched/stat.h>
sched/headers: Remove the <linux/gfp.h> include from <linux/sched.h>
sched/headers: Remove <linux/rtmutex.h> from <linux/sched.h>
Pull vfs pile two from Al Viro:
- orangefs fix
- series of fs/namei.c cleanups from me
- VFS stuff coming from overlayfs tree
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
orangefs: Use RCU for destroy_inode
vfs: use helper for calling f_op->fsync()
mm: use helper for calling f_op->mmap()
vfs: use helpers for calling f_op->{read,write}_iter()
vfs: pass type instead of fn to do_{loop,iter}_readv_writev()
vfs: extract common parts of {compat_,}do_readv_writev()
vfs: wrap write f_ops with file_{start,end}_write()
vfs: deny copy_file_range() for non regular files
vfs: deny fallocate() on directory
vfs: create vfs helper vfs_tmpfile()
namei.c: split unlazy_walk()
namei.c: fold the check for DCACHE_OP_REVALIDATE into d_revalidate()
lookup_fast(): clean up the logics around the fallback to non-rcu mode
namei: fold unlazy_link() into its sole caller
Overlayfs-related series from Miklos and Amir
<linux/sched/mm.h>
We are going to split <linux/sched/mm.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/mm.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
The APIs that are going to be moved first are:
mm_alloc()
__mmdrop()
mmdrop()
mmdrop_async_fn()
mmdrop_async()
mmget_not_zero()
mmput()
mmput_async()
get_task_mm()
mm_access()
mm_release()
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
<linux/sched.h> to <linux/mm_types>
The <linux/sched.h> header includes various vmacache related defines,
which are arguably misplaced.
Move them to mm_types.h and minimize the sched.h impact by putting
all task vmacache state into a new 'struct vmacache' structure.
No change in functionality.
When a non-cooperative userfaultfd monitor copies pages in the
background, it may encounter regions that were already unmapped.
Addition of UFFD_EVENT_UNMAP allows the uffd monitor to track precisely
changes in the virtual memory layout.
Since there might be different uffd contexts for the affected VMAs, we
first should create a temporary representation for the unmap event for
each uffd context and then notify them one by one to the appropriate
userfault file descriptors.
The event notification occurs after the mmap_sem has been released.
[arnd@arndb.de: fix nommu build]
Link: http://lkml.kernel.org/r/20170203165141.3665284-1-arnd@arndb.de
[mhocko@suse.com: fix nommu build]
Link: http://lkml.kernel.org/r/20170202091503.GA22823@dhcp22.suse.cz
Link: http://lkml.kernel.org/r/1485542673-24387-3-git-send-email-rppt@linux.vnet.ibm.com
Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com>
Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Pavel Emelyanov <xemul@virtuozzo.com>
mmap_init() is no longer associated with VMA slab. So fix it.
Link: http://lkml.kernel.org/r/1485182601-9294-1-git-send-email-iamyooon@gmail.com
Signed-off-by: seokhoon.yoon <iamyooon@gmail.com>
->fault(), ->page_mkwrite(), and ->pfn_mkwrite() calls do not need to
take a vma and vmf parameter when the vma already resides in vmf.
Remove the vma parameter to simplify things.
[arnd@arndb.de: fix ARM build]
Link: http://lkml.kernel.org/r/20170125223558.1451224-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/148521301778.19116.10840599906674778980.stgit@djiang5-desk3.ch.intel.com
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Darrick J. Wong <darrick.wong@oracle.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Jan Kara <jack@suse.com>
Cc: Dan Williams <dan.j.williams@intel.com>
show_mem() allows to filter out node specific data which is irrelevant
to the allocation request via SHOW_MEM_FILTER_NODES. The filtering is
done in skip_free_areas_node which skips all nodes which are not in the
mems_allowed of the current process. This works most of the time as
expected because the nodemask shouldn't be outside of the allocating
task but there are some exceptions. E.g. memory hotplug might want to
request allocations from outside of the allowed nodes (see
new_node_page).
Get rid of this hardcoded behavior and push the allocation mask down the
show_mem path and use it instead of cpuset_current_mems_allowed. NULL
nodemask is interpreted as cpuset_current_mems_allowed.
Link: http://lkml.kernel.org/r/20170117091543.25850-5-mhocko@kernel.org
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Merge more updates from Andrew Morton:
- a few misc things
- kexec updates
- DMA-mapping updates to better support networking DMA operations
- IPC updates
- various MM changes to improve DAX fault handling
- lots of radix-tree changes, mainly to the test suite. All leading up
to reimplementing the IDA/IDR code to be a wrapper layer over the
radix-tree. However the final trigger-pulling patch is held off for
4.11.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (114 commits)
radix tree test suite: delete unused rcupdate.c
radix tree test suite: add new tag check
radix-tree: ensure counts are initialised
radix tree test suite: cache recently freed objects
radix tree test suite: add some more functionality
idr: reduce the number of bits per level from 8 to 6
rxrpc: abstract away knowledge of IDR internals
tpm: use idr_find(), not idr_find_slowpath()
idr: add ida_is_empty
radix tree test suite: check multiorder iteration
radix-tree: fix replacement for multiorder entries
radix-tree: add radix_tree_split_preload()
radix-tree: add radix_tree_join
radix-tree: delete radix_tree_range_tag_if_tagged()
radix-tree: delete radix_tree_locate_item()
radix-tree: improve multiorder iterators
btrfs: fix race in btrfs_free_dummy_fs_info()
radix-tree: improve dump output
radix-tree: make radix_tree_find_next_bit more useful
Currently we have two different structures for passing fault information
around - struct vm_fault and struct fault_env. DAX will need more
information in struct vm_fault to handle its faults so the content of
that structure would become event closer to fault_env. Furthermore it
would need to generate struct fault_env to be able to call some of the
generic functions. So at this point I don't think there's much use in
keeping these two structures separate. Just embed into struct vm_fault
all that is needed to use it for both purposes.
Link: http://lkml.kernel.org/r/1479460644-25076-2-git-send-email-jack@suse.cz
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Unexport the low-level __get_user_pages_unlocked() function and replaces
invocations with calls to more appropriate higher-level functions.
In hva_to_pfn_slow() we are able to replace __get_user_pages_unlocked()
with get_user_pages_unlocked() since we can now pass gup_flags.
In async_pf_execute() and process_vm_rw_single_vec() we need to pass
different tsk, mm arguments so get_user_pages_remote() is the sane
replacement in these cases (having added manual acquisition and release
of mmap_sem.)
Additionally get_user_pages_remote() reintroduces use of the FOLL_TOUCH
flag. However, this flag was originally silently dropped by commit
1e9877902dc7 ("mm/gup: Introduce get_user_pages_remote()"), so this
appears to have been unintentional and reintroducing it is therefore not
an issue.
Link: http://lkml.kernel.org/r/20161027095141.2569-3-lstoakes@gmail.com
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Radim Krcmar <rkrcmar@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace updates from Eric Biederman:
"After a lot of discussion and work we have finally reachanged a basic
understanding of what is necessary to make unprivileged mounts safe in
the presence of EVM and IMA xattrs which the last commit in this
series reflects. While technically it is a revert the comments it adds
are important for people not getting confused in the future. Clearing
up that confusion allows us to seriously work on unprivileged mounts
of fuse in the next development cycle.
The rest of the fixes in this set are in the intersection of user
namespaces, ptrace, and exec. I started with the first fix which
started a feedback cycle of finding additional issues during review
and fixing them. Culiminating in a fix for a bug that has been present
since at least Linux v1.0.
Potentially these fixes were candidates for being merged during the rc
cycle, and are certainly backport candidates but enough little things
turned up during review and testing that I decided they should be
handled as part of the normal development process just to be certain
there were not any great surprises when it came time to backport some
of these fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
Revert "evm: Translate user/group ids relative to s_user_ns when computing HMAC"
exec: Ensure mm->user_ns contains the execed files
ptrace: Don't allow accessing an undumpable mm
ptrace: Capture the ptracer's creds not PT_PTRACE_CAP
mm: Add a user_ns owner to mm_struct and fix ptrace permission checks
It is the reasonable expectation that if an executable file is not
readable there will be no way for a user without special privileges to
read the file. This is enforced in ptrace_attach but if ptrace
is already attached before exec there is no enforcement for read-only
executables.
As the only way to read such an mm is through access_process_vm
spin a variant called ptrace_access_vm that will fail if the
target process is not being ptraced by the current process, or
the current process did not have sufficient privileges when ptracing
began to read the target processes mm.
In the ptrace implementations replace access_process_vm by
ptrace_access_vm. There remain several ptrace sites that still use
access_process_vm as they are reading the target executables
instructions (for kernel consumption) or register stacks. As such it
does not appear necessary to add a permission check to those calls.
This bug has always existed in Linux.
Fixes: v1.0
Cc: stable@vger.kernel.org
Reported-by: Andy Lutomirski <luto@amacapital.net>
The flush_icache_range() API is meant to be used on kernel addresses
only as it may not have the infrastructure (exception entries) to handle
user memory faults.
The lkdtm execute_user_location() function tests the kernel execution of
user space addresses by mmap'ing an anonymous page, copying some code
together with cache maintenance and attempting to run it. However, the
cache maintenance step may fail because of the incorrect API usage
described above. The patch changes lkdtm to use access_process_vm() for
copying the code into user space which would take care of the necessary
cache maintenance.
[kees: export access_process_vm() for module use]
This patch unexports the low-level __get_user_pages() function.
Recent refactoring of the get_user_pages* functions allow flags to be
passed through get_user_pages() which eliminates the need for access to
this function from its one user, kvm.
We can see that the two calls to get_user_pages() which replace
__get_user_pages() in kvm_main.c are equivalent by examining their call
stacks:
get_user_page_nowait():
get_user_pages(start, 1, flags, page, NULL)
__get_user_pages_locked(current, current->mm, start, 1, page, NULL, NULL,
false, flags | FOLL_TOUCH)
__get_user_pages(current, current->mm, start, 1,
flags | FOLL_TOUCH | FOLL_GET, page, NULL, NULL)
check_user_page_hwpoison():
get_user_pages(addr, 1, flags, NULL, NULL)
__get_user_pages_locked(current, current->mm, addr, 1, NULL, NULL, NULL,
__get_user_pages(current, current->mm, addr, 1, flags | FOLL_TOUCH, NULL,
NULL, NULL)
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
This removes the 'write' argument from access_process_vm() and replaces
it with 'gup_flags' as use of this function previously silently implied
FOLL_FORCE, whereas after this patch callers explicitly pass this flag.
We make this explicit as use of FOLL_FORCE can result in surprising
behaviour (and hence bugs) within the mm subsystem.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
This removes the 'write' argument from access_remote_vm() and replaces
This removes the 'write' argument from __access_remote_vm() and replaces
This removes the 'write' and 'force' from get_user_pages() and replaces
them with 'gup_flags' to make the use of FOLL_FORCE explicit in callers
as use of this flag can result in surprising behaviour (and hence bugs)
Acked-by: Christian König <christian.koenig@amd.com>
This removes the 'write' and 'force' use from get_user_pages_locked()
and replaces them with 'gup_flags' to make the use of FOLL_FORCE
explicit in callers as use of this flag can result in surprising
This removes the 'write' and 'force' use from get_user_pages_unlocked()
This removes the redundant 'write' and 'force' parameters from
__get_user_pages_unlocked() to make the use of FOLL_FORCE explicit in
callers as use of this flag can result in surprising behaviour (and
The idea borrowed from Peter's patch from patchset on speculative page
faults[1]:
Instead of passing around the endless list of function arguments,
replace the lot with a single structure so we can change context without
endless function signature changes.
The changes are mostly mechanical with exception of faultaround code:
filemap_map_pages() got reworked a bit.
This patch is preparation for the next one.
[1] http://lkml.kernel.org/r/20141020222841.302891540@infradead.org
Link: http://lkml.kernel.org/r/1466021202-61880-9-git-send-email-kirill.shutemov@linux.intel.com
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
The do_brk() and vm_brk() return value was "unsigned long" and returned
the starting address on success, and an error value on failure. The
reasons are entirely historical, and go back to it basically behaving
like the mmap() interface does.
However, nobody actually wanted that interface, and it causes totally
pointless IS_ERR_VALUE() confusion.
What every single caller actually wants is just the simpler integer
return of zero for success and negative error number on failure.
So just convert to that much clearer and more common calling convention,
and get rid of all the IS_ERR_VALUE() uses wrt vm_brk().
Pull mm gup cleanup from Ingo Molnar:
"This removes the ugly get-user-pages API hack, now that all upstream
code has been migrated to it"
("ugly" is putting it mildly. But it worked.. - Linus)
* 'mm-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
mm/gup: Remove the macro overload API migration helpers from the get_user*() APIs
APIs
The pkeys changes brought about a truly hideous set of macros in:
cde70140fed8 ("mm/gup: Overload get_user_pages() functions")
... which macros are (ab-)using the fact that __VA_ARGS__ can be used
to shift parameter positions in macro arguments without breaking the
build and so can be used to call separate C functions depending on
the number of arguments of the macro.
This allowed easy migration of these 3 GUP APIs, as both these variants
worked at the C level:
old:
ret = get_user_pages(current, current->mm, address, 1, 1, 0, &page, NULL);
new:
ret = get_user_pages(address, 1, 1, 0, &page, NULL);
... while we also generated a (functionally harmless but noticeable) build
time warning if the old API was used. As there are over 300 uses of these
APIs, this trick eased the migration of the API and avoided excessive
migration pain in linux-next.
Now, with its work done, get rid of all of that complication and ugliness:
3 files changed, 16 insertions(+), 140 deletions(-)
... where the linecount of the migration hack was further inflated by the
fact that there are NOMMU variants of these GUP APIs as well.
Much of the conversion was done in linux-next over the past couple of months,
and Linus recently removed all remaining old API uses from the upstream tree
in the following upstrea commit:
cb107161df3c ("Convert straggling drivers to new six-argument get_user_pages()")
There was one more old-API usage in mm/gup.c, in the CONFIG_HAVE_GENERIC_RCU_GUP
code path that ARM, ARM64 and PowerPC uses.
After this commit any old API usage will break the build.
[ Also fixed a PowerPC/HAVE_GENERIC_RCU_GUP warning reported by Stephen Rothwell. ]
Cc: Dave Hansen <dave@sr71.net>
Cc: linux-mm@kvack.org
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Pull x86 protection key support from Ingo Molnar:
"This tree adds support for a new memory protection hardware feature
that is available in upcoming Intel CPUs: 'protection keys' (pkeys).
There's a background article at LWN.net:
https://lwn.net/Articles/643797/
The gist is that protection keys allow the encoding of
user-controllable permission masks in the pte. So instead of having a
fixed protection mask in the pte (which needs a system call to change
and works on a per page basis), the user can map a (handful of)
protection mask variants and can change the masks runtime relatively
cheaply, without having to change every single page in the affected
virtual memory range.
This allows the dynamic switching of the protection bits of large
amounts of virtual memory, via user-space instructions. It also
allows more precise control of MMU permission bits: for example the
executable bit is separate from the read bit (see more about that
below).
This tree adds the MM infrastructure and low level x86 glue needed for
that, plus it adds a high level API to make use of protection keys -
if a user-space application calls:
mmap(..., PROT_EXEC);
or
mprotect(ptr, sz, PROT_EXEC);
(note PROT_EXEC-only, without PROT_READ/WRITE), the kernel will notice
this special case, and will set a special protection key on this
memory range. It also sets the appropriate bits in the Protection
Keys User Rights (PKRU) register so that the memory becomes unreadable
and unwritable.
So using protection keys the kernel is able to implement 'true'
PROT_EXEC on x86 CPUs: without protection keys PROT_EXEC implies
PROT_READ as well. Unreadable executable mappings have security
advantages: they cannot be read via information leaks to figure out
ASLR details, nor can they be scanned for ROP gadgets - and they
cannot be used by exploits for data purposes either.
We know about no user-space code that relies on pure PROT_EXEC
mappings today, but binary loaders could start making use of this new
feature to map binaries and libraries in a more secure fashion.
There is other pending pkeys work that offers more high level system
call APIs to manage protection keys - but those are not part of this
pull request.
Right now there's a Kconfig that controls this feature
(CONFIG_X86_INTEL_MEMORY_PROTECTION_KEYS) that is default enabled
(like most x86 CPU feature enablement code that has no runtime
overhead), but it's not user-configurable at the moment. If there's
any serious problem with this then we can make it configurable and/or
flip the default"
* 'mm-pkeys-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (38 commits)
x86/mm/pkeys: Fix mismerge of protection keys CPUID bits
mm/pkeys: Fix siginfo ABI breakage caused by new u64 field
x86/mm/pkeys: Fix access_error() denial of writes to write-only VMA
mm/core, x86/mm/pkeys: Add execute-only protection keys support
x86/mm/pkeys: Create an x86 arch_calc_vm_prot_bits() for VMA flags
x86/mm/pkeys: Allow kernel to modify user pkey rights register
x86/fpu: Allow setting of XSAVE state
x86/mm: Factor out LDT init from context init
mm/core, x86/mm/pkeys: Add arch_validate_pkey()
mm/core, arch, powerpc: Pass a protection key in to calc_vm_flag_bits()
x86/mm/pkeys: Actually enable Memory Protection Keys in the CPU
x86/mm/pkeys: Add Kconfig prompt to existing config option
x86/mm/pkeys: Dump pkey from VMA in /proc/pid/smaps
x86/mm/pkeys: Dump PKRU with other kernel registers
mm/core, x86/mm/pkeys: Differentiate instruction fetches
x86/mm/pkeys: Optimize fault handling in access_error()
mm/core: Do not enforce PKEY permissions on remote mm access
um, pkeys: Add UML arch_*_access_permitted() methods
mm/gup, x86/mm/pkeys: Check VMAs and PTEs for protection keys
x86/mm/gup: Simplify get_user_pages() PTE bit handling
Currently we have two copies of the same code which implements memory
overcommitment logic. Let's move it into mm/util.c and hence avoid
duplication. No functional changes here.
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
max_map_count sysctl unrelated to scheduler. Move its bits from
include/linux/sched/sysctl.h to include/linux/mm.h.
This plumbs a protection key through calc_vm_flag_bits(). We
could have done this in calc_vm_prot_bits(), but I did not feel
super strongly which way to go. It was pretty arbitrary which
one to use.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Arve Hjønnevåg <arve@android.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Chen Gang <gang.chen.5i5j@gmail.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Geliang Tang <geliangtang@163.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Leon Romanovsky <leon@leon.nu>
Cc: Maxime Coquelin <mcoquelin.stm32@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Riley Andrews <riandrews@android.com>
Cc: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: devel@driverdev.osuosl.org
Cc: linux-api@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Link: http://lkml.kernel.org/r/20160212210231.E6F1F0D6@viggo.jf.intel.com
The concept here was a suggestion from Ingo. The implementation
horrors are all mine.
This allows get_user_pages(), get_user_pages_unlocked(), and
get_user_pages_locked() to be called with or without the
leading tsk/mm arguments. We will give a compile-time warning
about the old style being __deprecated and we will also
WARN_ON() if the non-remote version is used for a remote-style
access.
Doing this, folks will get nice warnings and will not break the
build. This should be nice for -next and will hopefully let
developers fix up their own code instead of maintainers needing
to do it at merge time.
The way we do this is hideous. It uses the __VA_ARGS__ macro
functionality to call different functions based on the number
of arguments passed to the macro.
There's an additional hack to ensure that our EXPORT_SYMBOL()
of the deprecated symbols doesn't trigger a warning.
We should be able to remove this mess as soon as -rc1 hits in
the release after this is merged.
Cc: Alexander Kuleshov <kuleshovmail@gmail.com>
Cc: Dominik Dingel <dingel@linux.vnet.ibm.com>
Cc: Mateusz Guzik <mguzik@redhat.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Xie XiuQi <xiexiuqi@huawei.com>
Link: http://lkml.kernel.org/r/20160212210155.73222EE1@viggo.jf.intel.com
Mark those kmem allocations that are known to be easily triggered from
userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to
memcg. For the list, see below:
- threadinfo
- task_struct
- task_delay_info
- pid
- cred
- mm_struct
- vm_area_struct and vm_region (nommu)
- anon_vma and anon_vma_chain
- signal_struct
- sighand_struct
- fs_struct
- files_struct
- fdtable and fdtable->full_fds_bits
- dentry and external_name
- inode for all filesystems. This is the most tedious part, because
most filesystems overwrite the alloc_inode method.
The list is far from complete, so feel free to add more objects.
Nevertheless, it should be close to "account everything" approach and
keep most workloads within bounds. Malevolent users will be able to
breach the limit, but this was possible even with the former "account
everything" approach (simply because it did not account everything in
fact).
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
(1) For !CONFIG_BUG cases, the bug call is a no-op, so we couldn't
care less and the change is ok.
(2) ppc and mips, which HAVE_ARCH_BUG_ON, do not rely on branch
predictions as it seems to be pointless[1] and thus callers should not
be trying to push an optimization in the first place.
(3) For CONFIG_BUG and !HAVE_ARCH_BUG_ON cases, BUG_ON() contains an
unlikely compiler flag already.
Hence, we can drop unlikely behind BUG_ON().
[1] http://lkml.iu.edu/hypermail/linux/kernel/1101.3/02289.html
Signed-off-by: Geliang Tang <geliangtang@163.com>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
linux/mm.h provides offset_in_page() macro. Let's use already predefined
macro instead of (addr & ~PAGE_MASK).
Signed-off-by: Alexander Kuleshov <kuleshovmail@gmail.com>
Add the additional "vm_flags_t vm_flags" argument to do_mmap_pgoff(),
rename it to do_mmap(), and re-introduce do_mmap_pgoff() as a simple
wrapper on top of do_mmap(). Perhaps we should update the callers of
do_mmap_pgoff() and kill it later.
This way mpx_mmap() can simply call do_mmap(vm_flags => VM_MPX) and do not
play with vm internals.
After this change mmap_region() has a single user outside of mmap.c,
arch/tile/mm/elf.c:arch_setup_additional_pages(). It would be nice to
change arch/tile/ and unexport mmap_region().
[kirill@shutemov.name: fix build]
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Tested-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Minchan Kim <minchan@kernel.org>
Pull trivial tree updates from Jiri Kosina:
"The usual stuff from trivial tree for 4.3 (kerneldoc updates, printk()
fixes, Documentation and MAINTAINERS updates)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits)
MAINTAINERS: update my e-mail address
mod_devicetable: add space before */
scsi: a100u2w: trivial typo in printk
i2c: Fix typo in i2c-bfin-twi.c
treewide: fix typos in comment blocks
Doc: fix trivial typo in SubmittingPatches
proportions: Spelling s/consitent/consistent/
dm: Spelling s/consitent/consistent/
aic7xxx: Fix typo in error message
pcmcia: Fix typo in locking documentation
scsi/arcmsr: Fix typos in error log
drm/nouveau/gr: Fix typo in nv10.c
[SCSI] Fix printk typos in drivers/scsi
staging: comedi: Grammar s/Enable support a/Enable support for a/
Btrfs: Spelling s/consitent/consistent/
README: GTK+ is a acronym
ASoC: omap: Fix typo in config option description
mm: tlb.c: Fix error message
ntfs: super.c: Fix error log
fix typo in Documentation/SubmittingPatches
Looks like the word "contiguous" is often mistyped.
Signed-off-by: Jiri Kosina <jkosina@suse.com>
Today proc and sysfs do not contain any executable files. Several
applications today mount proc or sysfs without noexec and nosuid and
then depend on there being no exectuables files on proc or sysfs.
Having any executable files show on proc or sysfs would cause
a user space visible regression, and most likely security problems.
Therefore commit to never allowing executables on proc and sysfs by
adding a new flag to mark them as filesystems without executables and
enforce that flag.
Test the flag where MNT_NOEXEC is tested today, so that the only user
visible effect will be that exectuables will be treated as if the
execute bit is cleared.
The filesystems proc and sysfs do not currently incoporate any
executable files so this does not result in any user visible effects.
This makes it unnecessary to vet changes to proc and sysfs tightly for
adding exectuable files or changes to chattr that would modify
existing files, as no matter what the individual file say they will
not be treated as exectuable files by the vfs.
Not having to vet changes to closely is important as without this we
are only one proc_create call (or another goof up in the
implementation of notify_change) from having problematic executables
on proc. Those mistakes are all too easy to make and would create
a situation where there are security issues or the assumptions of
some program having to be broken (and cause userspace regressions).
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull module_init replacement part two from Paul Gortmaker:
"Replace module_init with appropriate alternate initcall in non
modules.
This series converts non-modular code that is using the module_init()
call to hook itself into the system to instead use one of our
alternate priority initcalls.
Unlike the previous series that used device_initcall and hence was a
runtime no-op, these commits change to one of the alternate initcalls,
because (a) we have them and (b) it seems like the right thing to do.
For example, it would seem logical to use arch_initcall for arch
specific setup code and fs_initcall for filesystem setup code.
This does mean however, that changes in the init ordering will be
taking place, and so there is a small risk that some kind of implicit
init ordering issue may lie uncovered. But I think it is still better
to give these ones sensible priorities than to just assign them all to
device_initcall in order to exactly preserve the old ordering.
Thad said, we have already made similar changes in core kernel code in
commit c96d6660dc65 ("kernel: audit/fix non-modular users of
module_init in core code") without any regressions reported, so this
type of change isn't without precedent. It has also got the same
local testing and linux-next coverage as all the other pull requests
that I'm sending for this merge window have got.
Once again, there is an unused module_exit function removal that shows
up as an outlier upon casual inspection of the diffstat"
* tag 'module_init-alternate_initcall-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
x86: perf_event_intel_pt.c: use arch_initcall to hook in enabling
x86: perf_event_intel_bts.c: use arch_initcall to hook in enabling
mm/page_owner.c: use late_initcall to hook in enabling
lib/list_sort: use late_initcall to hook in self tests
arm: use subsys_initcall in non-modular pl320 IPC code
powerpc: don't use module_init for non-modular core hugetlb code
powerpc: use subsys_initcall for Freescale Local Bus
x86: don't use module_init for non-modular core bootflag code
netfilter: don't use module_init/exit in core IPV4 code
fs/notify: don't use module_init for non-modular inotify_user code
mm: replace module_init usages with subsys_initcall in nommu.c
kenter/kleave/kdebug are wrapper macros to print functions flow and debug
information. This set was written before pr_devel() was introduced, so it
was controlled by "#if 0" construction. It is questionable if anyone is
using them [1] now.
This patch removes these macros, converts numerous printk(KERN_WARNING,
...) to use general pr_warn(...) and removes debug print line from
validate_mmap_request() function.
Signed-off-by: Leon Romanovsky <leon@leon.nu>
Compiling some arm/m68k configs with "# CONFIG_MMU is not set" reveals
two more instances of module_init being used for code that can't
possibly be modular, as CONFIG_MMU is either on or off.
We replace them with subsys_initcall as per what was done in other
mmu-enabled code.
Note that direct use of __initcall is discouraged, vs. one of the
priority categorized subgroups. As __initcall gets mapped onto
device_initcall, our use of subsys_initcall (which makes sense for these
files) will thus change this registration from level 6-device to level
4-subsys (i.e. slightly earlier).
One might think that core_initcall (l2) or postcore_initcall (l3) would
be more appropriate for anything in mm/ but if we look at the actual init
functions themselves, we see they are just sysctl setup stuff, and
hence the choice of subsys_initcall (l4) seems reasonable. At the same
time it minimizes the risk of changing the priority too drastically all
at once. We can adjust further in the future.
Also, a couple instances of missing ";" at EOL are fixed.
... instead of open-coding the call of ->read()
Several modules may need max_mapnr, so export, the related error with
allmodconfig under c6x:
MODPOST 3327 modules
ERROR: "max_mapnr" [fs/pstore/ramoops.ko] undefined!
ERROR: "max_mapnr" [drivers/media/v4l2-core/videobuf2-dma-contig.ko] undefined!
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
