Commit 3268c63 ("mm: fix move/migrate_pages() race on task struct") has
added an odd construct where 'mm' is checked for being NULL, and if it is,
it would get dereferenced anyways by mput()ing it.
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Acked-by: Christoph Lameter <cl@linux.com>
Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
When moving tasks from old memcg (with move_charge_at_immigrate on new
memcg), followed by removal of old memcg, hit General Protection Fault in
mem_cgroup_lru_del_list() (called from release_pages called from
free_pages_and_swap_cache from tlb_flush_mmu from tlb_finish_mmu from
exit_mmap from mmput from exit_mm from do_exit).
Somewhat reproducible, takes a few hours: the old struct mem_cgroup has
been freed and poisoned by SLAB_DEBUG, but mem_cgroup_lru_del_list() is
still trying to update its stats, and take page off lru before freeing.
A task, or a charge, or a page on lru: each secures a memcg against
removal. In this case, the last task has been moved out of the old memcg,
and it is exiting: anonymous pages are uncharged one by one from the
memcg, as they are zapped from its pagetables, so the charge gets down to
0; but the pages themselves are queued in an mmu_gather for freeing.
Most of those pages will be on lru (and force_empty is careful to
lru_add_drain_all, to add pages from pagevec to lru first), but not
necessarily all: perhaps some have been isolated for page reclaim, perhaps
some isolated for other reasons. So, force_empty may find no task, no
charge and no page on lru, and let the removal proceed.
There would still be no problem if these pages were immediately freed; but
typically (and the put_page_testzero protocol demands it) they have to be
added back to lru before they are found freeable, then removed from lru
and freed. We don't see the issue when adding, because the
mem_cgroup_iter() loops keep their own reference to the memcg being
scanned; but when it comes to mem_cgroup_lru_del_list().
I believe this was not an issue in v3.2: there, PageCgroupAcctLRU and
PageCgroupUsed flags were used (like a trick with mirrors) to deflect view
of pc->mem_cgroup to the stable root_mem_cgroup when neither set.
38c5d72f3ebe ("memcg: simplify LRU handling by new rule") mercifully
removed those convolutions, but left this General Protection Fault.
But it's surprisingly easy to restore the old behaviour: just check
PageCgroupUsed in mem_cgroup_lru_add_list() (which decides on which lruvec
to add), and reset pc to root_mem_cgroup if page is uncharged. A risky
change? just going back to how it worked before; testing, and an audit of
uses of pc->mem_cgroup, show no problem.
And there's a nice bonus: with mem_cgroup_lru_add_list() itself making
sure that an uncharged page goes to root lru, mem_cgroup_reset_owner() no
longer has any purpose, and we can safely revert 4e5f01c2b9b9 ("memcg:
clear pc->mem_cgroup if necessary").
Calling update_page_reclaim_stat() after add_page_to_lru_list() in swap.c
is not strictly necessary: the lru_lock there, with RCU before memcg
structures are freed, makes mem_cgroup_get_reclaim_stat_from_page safe
without that; but it seems cleaner to rely on one dependency less.
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
Postpone resetting page->mapping until the final remove_migration_ptes().
Otherwise the expression PageAnon(migration_entry_to_page(entry)) does not
work.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
This patch adds a lightweight sync migrate operation MIGRATE_SYNC_LIGHT
mode that avoids writing back pages to backing storage. Async compaction
maps to MIGRATE_ASYNC while sync compaction maps to MIGRATE_SYNC_LIGHT.
For other migrate_pages users such as memory hotplug, MIGRATE_SYNC is
used.
This avoids sync compaction stalling for an excessive length of time,
particularly when copying files to a USB stick where there might be a
large number of dirty pages backed by a filesystem that does not support
->writepages.
[aarcange@redhat.com: This patch is heavily based on Andrea's work]
[akpm@linux-foundation.org: fix fs/nfs/write.c build]
[akpm@linux-foundation.org: fix fs/btrfs/disk-io.c build]
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Andy Isaacson <adi@hexapodia.org>
Cc: Nai Xia <nai.xia@gmail.com>
Cc: Johannes Weiner <jweiner@redhat.com>
within ->migratepage
Asynchronous compaction is used when allocating transparent hugepages to
avoid blocking for long periods of time. Due to reports of stalling,
there was a debate on disabling synchronous compaction but this severely
impacted allocation success rates. Part of the reason was that many dirty
pages are skipped in asynchronous compaction by the following check;
if (PageDirty(page) && !sync &&
mapping->a_ops->migratepage != migrate_page)
rc = -EBUSY;
This skips over all mapping aops using buffer_migrate_page() even though
it is possible to migrate some of these pages without blocking. This
patch updates the ->migratepage callback with a "sync" parameter. It is
the responsibility of the callback to fail gracefully if migration would
block.
This is a preparation before removing a flag PCG_ACCT_LRU in page_cgroup
and reducing atomic ops/complexity in memcg LRU handling.
In some cases, pages are added to lru before charge to memcg and pages
are not classfied to memory cgroup at lru addtion. Now, the lru where
the page should be added is determined a bit in page_cgroup->flags and
pc->mem_cgroup. I'd like to remove the check of flag.
To handle the case pc->mem_cgroup may contain stale pointers if pages
are added to LRU before classification. This patch resets
pc->mem_cgroup to root_mem_cgroup before lru additions.
[akpm@linux-foundation.org: fix CONFIG_CGROUP_MEM_CONT=n build]
[hughd@google.com: fix CONFIG_CGROUP_MEM_RES_CTLR=y CONFIG_CGROUP_MEM_RES_CTLR_SWAP=n build]
[akpm@linux-foundation.org: ksm.c needs memcontrol.h, per Michal]
[hughd@google.com: stop oops in mem_cgroup_reset_owner()]
[hughd@google.com: fix page migration to reset_owner]
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Miklos Szeredi <mszeredi@suse.cz>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Ying Han <yinghan@google.com>
lru_to_page is not used in mm/migrate.c.
Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
migration_entry_wait() can also be called from hugetlb_fault() now.
Remove the incorrect comment.
Acked-by: Minchan Kim <minchan@kernel.org>
migrate_page_move_mapping() drops a reference from the old page after
unfreezing its counter. Both operations can be merged into a single
atomic operation by directly unfreezing to one less reference.
The same applies to migrate_huge_page_move_mapping().
Signed-off-by: Jacobo Giralt <jacobo.giralt@gmail.com>
Avoid unlocking and unlocked page if we failed to lock it.
Signed-off-by: Hillf Danton <dhillf@gmail.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
unmap_and_move() is one a big messy function. Clean it up.
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
The files changed within are only using the EXPORT_SYMBOL
macro variants. They are not using core modular infrastructure
and hence don't need module.h but only the export.h header.
I don't usually pay much attention to the stale "? " addresses in
stack backtraces, but this lucky report from Pawel Sikora hints that
mremap's move_ptes() has inadequate locking against page migration.
3.0 BUG_ON(!PageLocked(p)) in migration_entry_to_page():
kernel BUG at include/linux/swapops.h:105!
RIP: 0010:[<ffffffff81127b76>] [<ffffffff81127b76>]
migration_entry_wait+0x156/0x160
[<ffffffff811016a1>] handle_pte_fault+0xae1/0xaf0
[<ffffffff810feee2>] ? __pte_alloc+0x42/0x120
[<ffffffff8112c26b>] ? do_huge_pmd_anonymous_page+0xab/0x310
[<ffffffff81102a31>] handle_mm_fault+0x181/0x310
[<ffffffff81106097>] ? vma_adjust+0x537/0x570
[<ffffffff81424bed>] do_page_fault+0x11d/0x4e0
[<ffffffff81109a05>] ? do_mremap+0x2d5/0x570
[<ffffffff81421d5f>] page_fault+0x1f/0x30
mremap's down_write of mmap_sem, together with i_mmap_mutex or lock,
and pagetable locks, were good enough before page migration (with its
requirement that every migration entry be found) came in, and enough
while migration always held mmap_sem; but not enough nowadays, when
there's memory hotremove and compaction.
The danger is that move_ptes() lets a migration entry dodge around
behind remove_migration_pte()'s back, so it's in the old location when
looking at the new, then in the new location when looking at the old.
Either mremap's move_ptes() must additionally take anon_vma lock(), or
migration's remove_migration_pte() must stop peeking for is_swap_entry()
before it takes pagetable lock.
Consensus chooses the latter: we prefer to add overhead to migration
than to mremapping, which gets used by JVMs and by exec stack setup.
Reported-and-tested-by: Paweł Sikora <pluto@agmk.net>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: stable@vger.kernel.org
swapcache will reach the below code path in migrate_page_move_mapping,
and swapcache is accounted as NR_FILE_PAGES but it's not accounted as
NR_SHMEM.
Hugh pointed out we must use PageSwapCache instead of comparing
mapping to &swapper_space, to avoid build failure with CONFIG_SWAP=n.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: stable@kernel.org
Convert page_lock_anon_vma() over to use refcounts. This is done to
prepare for the conversion of anon_vma from spinlock to mutex.
Sadly this inceases the cost of page_lock_anon_vma() from one to two
atomics, a follow up patch addresses this, lets keep that simple for now.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
Remove initialization of vaiable in caller of memory cgroup function.
Actually, it's return value of memcg function but it's initialized in
caller.
Some memory cgroup uses following style to bring the result of start
function to the end function for avoiding races.
mem_cgroup_start_A(&(*ptr))
/* Something very complicated can happen here. */
mem_cgroup_end_A(*ptr)
In some calls, *ptr should be initialized to NULL be caller. But it's
ugly. This patch fixes that *ptr is initialized by _start function.
Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
__GFP_NO_KSWAPD allocations are usually very expensive and not mandatory
to succeed as they have graceful fallback. Waiting for I/O in those,
tends to be overkill in terms of latencies, so we can reduce their latency
by disabling sync migrate.
Unfortunately, even with async migration it's still possible for the
process to be blocked waiting for a request slot (e.g. get_request_wait
in the block layer) when ->writepage is called. To prevent
__GFP_NO_KSWAPD blocking, this patch prevents ->writepage being called on
dirty page cache for asynchronous migration.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=31142
[mel@csn.ul.ie: Avoid writebacks for NFS, retry locked pages, use bool]
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Arthur Marsh <arthur.marsh@internode.on.net>
Cc: Clemens Ladisch <cladisch@googlemail.com>
Reported-by: Alex Villacis Lasso <avillaci@ceibo.fiec.espol.edu.ec>
Tested-by: Alex Villacis Lasso <avillaci@ceibo.fiec.espol.edu.ec>
The normal code pattern used in the kernel is: get/put.
Acked-by: Mel Gorman <mel@csn.ul.ie>
This function basically does:
remove_from_page_cache(old);
page_cache_release(old);
add_to_page_cache_locked(new);
Except it does this atomically, so there's no possibility for the "add" to
fail because of a race.
If memory cgroups are enabled, then the memory cgroup charge is also moved
from the old page to the new.
This function is currently used by fuse to move pages into the page cache
on read, instead of copying the page contents.
[minchan.kim@gmail.com: add freepage() hook to replace_page_cache_page()]
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
The move_pages() usage of find_task_by_vpid() requires rcu_read_lock() to
prevent free_pid() from reclaiming the pid.
Without this patch, RCU warnings are printed in v2.6.38-rc4 move_pages()
with:
CONFIG_LOCKUP_DETECTOR=y
CONFIG_PREEMPT=y
CONFIG_LOCKDEP=y
CONFIG_PROVE_LOCKING=y
CONFIG_PROVE_RCU=y
Previously, migrate_pages() went through a similar transformation
replacing usage of tasklist_lock with rcu read lock:
commit 55cfaa3cbdd29c4919ecb5fb8965c310f357e48c
Author: Zeng Zhaoming <zengzm.kernel@gmail.com>
Date: Thu Dec 2 14:31:13 2010 -0800
mm/mempolicy.c: add rcu read lock to protect pid structure
commit 1e50df39f6e2c3a4a3394df62baa8a213df16c54
Author: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Date: Thu Jan 13 15:46:14 2011 -0800
mempolicy: remove tasklist_lock from migrate_pages
Signed-off-by: Greg Thelen <gthelen@google.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Zeng Zhaoming <zengzm.kernel@gmail.com>
If migrate_huge_page by memory-failure fails , it calls put_page in itself
to decrease page reference and caller of migrate_huge_page also calls
putback_lru_pages. It can do double free of page so it can make page
corruption on page holder.
In addtion, clean of pages on caller is consistent behavior with
migrate_pages by cf608ac19c ("mm: compaction: fix COMPACTPAGEFAILED
counting").
Cc: Christoph Lameter <cl@linux.com>
In some cases migrate_pages could return zero while still leaving a few
pages in the pagelist (and some caller wouldn't notice it has to call
putback_lru_pages after commit cf608ac19c9 ("mm: compaction: fix
COMPACTPAGEFAILED counting")).
Add one missing putback_lru_pages not added by commit cf608ac19c95 ("mm:
compaction: fix COMPACTPAGEFAILED counting").
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Callers of migrate_pages should putback_lru_pages to return pages
isolated to LRU or free list. Now comment is rather confusing. It says
caller always have to call it.
It is more clear to point out that the caller has to call it if
migrate_pages's return value isn't zero.
In the current implementation mem_cgroup_end_migration() decides whether
the page migration has succeeded or not by checking "oldpage->mapping".
But if we are tring to migrate a shmem swapcache, the page->mapping of it
is NULL from the begining, so the check would be invalid. As a result,
mem_cgroup_end_migration() assumes the migration has succeeded even if
it's not, so "newpage" would be freed while it's not uncharged.
This patch fixes it by passing mem_cgroup_end_migration() the result of
the page migration.
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
2.6.37 added an unmap_and_move_huge_page() for memory failure recovery,
but its anon_vma handling was still based around the 2.6.35 conventions.
Update it to use page_lock_anon_vma, get_anon_vma, page_unlock_anon_vma,
drop_anon_vma in the same way as we're now changing unmap_and_move().
I don't particularly like to propose this for stable when I've not seen
its problems in practice nor tested the solution: but it's clearly out of
synch at present.
Cc: "Jun'ichi Nomura" <j-nomura@ce.jp.nec.com>
Cc: <stable@kernel.org> [2.6.37, 2.6.36]
Increased usage of page migration in mmotm reveals that the anon_vma
locking in unmap_and_move() has been deficient since 2.6.36 (or even
earlier). Review at the time of f18194275c39835cb84563500995e0d503a32d9a
("mm: fix hang on anon_vma->root->lock") missed the issue here: the
anon_vma to which we get a reference may already have been freed back to
its slab (it is in use when we check page_mapped, but that can change),
and so its anon_vma->root may be switched at any moment by reuse in
anon_vma_prepare.
Perhaps we could fix that with a get_anon_vma_unless_zero(), but let's
not: just rely on page_lock_anon_vma() to do all the hard thinking for us,
then we don't need any rcu read locking over here.
In removing the rcu_unlock label: since PageAnon is a bit in
page->mapping, it's impossible for a !page->mapping page to be anon; but
insert VM_BUG_ON in case the implementation ever changes.
Reviewed-by: Mel Gorman <mel@csn.ul.ie>
tree slot during file page migration
migrate_pages() -> unmap_and_move() only calls rcu_read_lock() for
anonymous pages, as introduced by git commit
989f89c57e6361e7d16fbd9572b5da7d313b073d ("fix rcu_read_lock() in page
migraton"). The point of the RCU protection there is part of getting a
stable reference to anon_vma and is only held for anon pages as file pages
are locked which is sufficient protection against freeing.
However, while a file page's mapping is being migrated, the radix tree is
double checked to ensure it is the expected page. This uses
radix_tree_deref_slot() -> rcu_dereference() without the RCU lock held
triggering the following warning.
[ 173.674290] ===================================================
[ 173.676016] [ INFO: suspicious rcu_dereference_check() usage. ]
[ 173.676016] ---------------------------------------------------
[ 173.676016] include/linux/radix-tree.h:145 invoked rcu_dereference_check() without protection!
[ 173.676016]
[ 173.676016] other info that might help us debug this:
[ 173.676016]
[ 173.676016]
[ 173.676016] rcu_scheduler_active = 1, debug_locks = 0
[ 173.676016] 1 lock held by hugeadm/2899:
[ 173.676016] #0: (&(&inode->i_data.tree_lock)->rlock){..-.-.}, at: [<c10e3d2b>] migrate_page_move_mapping+0x40/0x1ab
[ 173.676016]
[ 173.676016] stack backtrace:
[ 173.676016] Pid: 2899, comm: hugeadm Not tainted 2.6.37-rc5-autobuild
[ 173.676016] Call Trace:
[ 173.676016] [<c128cc01>] ? printk+0x14/0x1b
[ 173.676016] [<c1063502>] lockdep_rcu_dereference+0x7d/0x86
[ 173.676016] [<c10e3db5>] migrate_page_move_mapping+0xca/0x1ab
[ 173.676016] [<c10e41ad>] migrate_page+0x23/0x39
[ 173.676016] [<c10e491b>] buffer_migrate_page+0x22/0x107
[ 173.676016] [<c10e48f9>] ? buffer_migrate_page+0x0/0x107
[ 173.676016] [<c10e425d>] move_to_new_page+0x9a/0x1ae
[ 173.676016] [<c10e47e6>] migrate_pages+0x1e7/0x2fa
This patch introduces radix_tree_deref_slot_protected() which calls
rcu_dereference_protected(). Users of it must pass in the
mapping->tree_lock that is protecting this dereference. Holding the tree
lock protects against parallel updaters of the radix tree meaning that
rcu_dereference_protected is allowable.
[akpm@linux-foundation.org: remove unneeded casts]
Cc: Milton Miller <miltonm@bga.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: <stable@kernel.org> [2.6.37.early]
No pmd_trans_huge should ever materialize in migration ptes areas, because
we split the hugepage before migration ptes are instantiated.
sync
With the introduction of the boolean sync parameter, the API looks a
little inconsistent as offlining is still an int. Convert offlining to a
bool for the sake of being tidy.
Cc: Andy Whitcroft <apw@shadowen.org>
synchronous compaction in the faster path
Migration synchronously waits for writeback if the initial passes fails.
Callers of memory compaction do not necessarily want this behaviour if the
caller is latency sensitive or expects that synchronous migration is not
going to have a significantly better success rate.
This patch adds a sync parameter to migrate_pages() allowing the caller to
indicate if wait_on_page_writeback() is allowed within migration or not.
For reclaim/compaction, try_to_compact_pages() is first called
asynchronously, direct reclaim runs and then try_to_compact_pages() is
called synchronously as there is a greater expectation that it'll succeed.
[akpm@linux-foundation.org: build/merge fix]
Lumpy reclaim is disruptive. It reclaims a large number of pages and
ignores the age of the pages it reclaims. This can incur significant
stalls and potentially increase the number of major faults.
Compaction has reached the point where it is considered reasonably stable
(meaning it has passed a lot of testing) and is a potential candidate for
displacing lumpy reclaim. This patch introduces an alternative to lumpy
reclaim whe compaction is available called reclaim/compaction. The basic
operation is very simple - instead of selecting a contiguous range of
pages to reclaim, a number of order-0 pages are reclaimed and then
compaction is later by either kswapd (compact_zone_order()) or direct
compaction (__alloc_pages_direct_compact()).
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: use conventional task_struct naming]
GCC complained about update_mmu_cache() not being defined in migrate.c.
Including <asm/tlbflush.h> seems to solve the problem.
Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com>
The vma returned by find_vma does not necessarily include the target
address. If this happens the code tries to follow a page outside of any
vma and returns ENOENT instead of EFAULT.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Presently update_nr_listpages() doesn't have a role. That's because lists
passed is always empty just after calling migrate_pages. The
migrate_pages cleans up page list which have failed to migrate before
returning by aaa994b3.
[PATCH] page migration: handle freeing of pages in migrate_pages()
Do not leave pages on the lists passed to migrate_pages(). Seems that we will
not need any postprocessing of pages. This will simplify the handling of
pages by the callers of migrate_pages().
At that time, we thought we don't need any postprocessing of pages. But
the situation is changed. The compaction need to know the number of
failed to migrate for COMPACTPAGEFAILED stat
This patch makes new rule for caller of migrate_pages to call
putback_lru_pages. So caller need to clean up the lists so it has a
chance to postprocess the pages. [suggested by Christoph Lameter]
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
This removes more dead code that was somehow missed by commit 0d99519efef
(writeback: remove unused nonblocking and congestion checks). There are
no behavior change except for the removal of two entries from one of the
ext4 tracing interface.
The nonblocking checks in ->writepages are no longer used because the
flusher now prefer to block on get_request_wait() than to skip inodes on
IO congestion. The latter will lead to more seeky IO.
The nonblocking checks in ->writepage are no longer used because it's
redundant with the WB_SYNC_NONE check.
We no long set ->nonblocking in VM page out and page migration, because
a) it's effectively redundant with WB_SYNC_NONE in current code
b) it's old semantic of "Don't get stuck on request queues" is mis-behavior:
that would skip some dirty inodes on congestion and page out others, which
is unfair in terms of LRU age.
Inspired by Christoph Hellwig. Thanks!
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Sage Weil <sage@newdream.net>
Cc: Steve French <sfrench@samba.org>
Cc: Chris Mason <chris.mason@oracle.com>
31bit s390 doesn't have huge pages and failed with:
> mm/migrate.c: In function 'remove_migration_pte':
> mm/migrate.c:143:3: error: implicit declaration of function 'pte_mkhuge'
> mm/migrate.c:143:7: error: incompatible types when assigning to type 'pte_t' from type 'int'
Put that code into a ifdef.
Reported by Heiko Carstens
This patch extends page migration code to support hugepage migration.
One of the potential users of this feature is soft offlining which
is triggered by memory corrected errors (added by the next patch.)
Todo:
- there are other users of page migration such as memory policy,
memory hotplug and memocy compaction.
They are not ready for hugepage support for now.
ChangeLog since v4:
- define migrate_huge_pages()
- remove changes on isolation/putback_lru_page()
ChangeLog since v2:
- refactor isolate/putback_lru_page() to handle hugepage
- add comment about race on unmap_and_move_huge_page()
ChangeLog since v1:
- divide migration code path for hugepage
- define routine checking migration swap entry for hugetlb
- replace "goto" with "if/else" in remove_migration_pte()
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
KSM reference counts can cause an anon_vma to exist after the processe it
belongs to have already exited. Because the anon_vma lock now lives in
the root anon_vma, we need to ensure that the root anon_vma stays around
until after all the "child" anon_vmas have been freed.
The obvious way to do this is to have a "child" anon_vma take a reference
to the root in anon_vma_fork. When the anon_vma is freed at munmap or
process exit, we drop the refcount in anon_vma_unlink and possibly free
the root anon_vma.
The KSM anon_vma reference count function also needs to be modified to
deal with the possibility of freeing 2 levels of anon_vma. The easiest
way to do this is to break out the KSM magic and make it generic.
When compiling without CONFIG_KSM, this code is compiled out.
Signed-off-by: Rik van Riel <riel@redhat.com>
Tested-by: Larry Woodman <lwoodman@redhat.com>
Acked-by: Larry Woodman <lwoodman@redhat.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Tested-by: Dave Young <hidave.darkstar@gmail.com>
Always (and only) lock the root (oldest) anon_vma whenever we do something
in an anon_vma. The recently introduced anon_vma scalability is due to
the rmap code scanning only the VMAs that need to be scanned. Many common
operations still took the anon_vma lock on the root anon_vma, so always
taking that lock is not expected to introduce any scalability issues.
However, always taking the same lock does mean we only need to take one
lock, which means rmap_walk on pages from any anon_vma in the vma is
excluded from occurring during an munmap, expand_stack or other operation
that needs to exclude rmap_walk and similar functions.
Also add the proper locking to vma_adjust.
Subsitute a direct call of spin_lock(anon_vma->lock) with an inline
function doing exactly the same.
This makes it easier to do the substitution to the root anon_vma lock in a
following patch.
We will deal with the handful of special locks (nested, dec_and_lock, etc)
separately.
FILE_MAPPED per memcg of migrated file cache is not properly updated,
because our hook in page_add_file_rmap() can't know to which memcg
FILE_MAPPED should be counted.
Basically, this patch is for fixing the bug but includes some big changes
to fix up other messes.
Now, at migrating mapped file, events happen in following sequence.
1. allocate a new page.
2. get memcg of an old page.
3. charge ageinst a new page before migration. But at this point,
no changes to new page's page_cgroup, no commit for the charge.
(IOW, PCG_USED bit is not set.)
4. page migration replaces radix-tree, old-page and new-page.
5. page migration remaps the new page if the old page was mapped.
6. Here, the new page is unlocked.
7. memcg commits the charge for newpage, Mark the new page's page_cgroup
as PCG_USED.
Because "commit" happens after page-remap, we can count FILE_MAPPED
at "5", because we should avoid to trust page_cgroup->mem_cgroup.
if PCG_USED bit is unset.
(Note: memcg's LRU removal code does that but LRU-isolation logic is used
for helping it. When we overwrite page_cgroup->mem_cgroup, page_cgroup is
not on LRU or page_cgroup->mem_cgroup is NULL.)
We can lose file_mapped accounting information at 5 because FILE_MAPPED
is updated only when mapcount changes 0->1. So we should catch it.
BTW, historically, above implemntation comes from migration-failure
of anonymous page. Because we charge both of old page and new page
with mapcount=0, we can't catch
- the page is really freed before remap.
- migration fails but it's freed before remap
or .....corner cases.
New migration sequence with memcg is:
2. mark PageCgroupMigration to the old page.
3. charge against a new page onto the old page's memcg. (here, new page's pc
is marked as PageCgroupUsed.)
4. page migration replaces radix-tree, page table, etc...
5. At remapping, new page's page_cgroup is now makrked as "USED"
We can catch 0->1 event and FILE_MAPPED will be properly updated.
And we can catch SWAPOUT event after unlock this and freeing this
page by unmap() can be caught.
7. Clear PageCgroupMigration of the old page.
So, FILE_MAPPED will be correctly updated.
Then, for what MIGRATION flag is ?
Without it, at migration failure, we may have to charge old page again
because it may be fully unmapped. "charge" means that we have to dive into
memory reclaim or something complated. So, it's better to avoid
charge it again. Before this patch, __commit_charge() was working for
both of the old/new page and fixed up all. But this technique has some
racy condtion around FILE_MAPPED and SWAPOUT etc...
Now, the kernel use MIGRATION flag and don't uncharge old page until
the end of migration.
I hope this change will make memcg's page migration much simpler. This
page migration has caused several troubles. Worth to add a flag for
simplification.
Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
This patch is the core of a mechanism which compacts memory in a zone by
relocating movable pages towards the end of the zone.
A single compaction run involves a migration scanner and a free scanner.
Both scanners operate on pageblock-sized areas in the zone. The migration
scanner starts at the bottom of the zone and searches for all movable
pages within each area, isolating them onto a private list called
migratelist. The free scanner starts at the top of the zone and searches
for suitable areas and consumes the free pages within making them
available for the migration scanner. The pages isolated for migration are
then migrated to the newly isolated free pages.
[aarcange@redhat.com: Fix unsafe optimisation]
[mel@csn.ul.ie: do not schedule work on other CPUs for compaction]
PageAnon pages that are unmapped may or may not have an anon_vma so are
not currently migrated. However, a swap cache page can be migrated and
fits this description. This patch identifies page swap caches and allows
them to be migrated but ensures that no attempt to made to remap the pages
would would potentially try to access an already freed anon_vma.
rmap_walk_anon() was triggering errors in memory compaction that look like
use-after-free errors. The problem is that between the page being
isolated from the LRU and rcu_read_lock() being taken, the mapcount of the
page dropped to 0 and the anon_vma gets freed. This can happen during
memory compaction if pages being migrated belong to a process that exits
before migration completes. Hence, the use-after-free race looks like
1. Page isolated for migration
2. Process exits
3. page_mapcount(page) drops to zero so anon_vma was no longer reliable
4. unmap_and_move() takes the rcu_lock but the anon_vma is already garbage
4. call try_to_unmap, looks up tha anon_vma and "locks" it but the lock
is garbage.
This patch checks the mapcount after the rcu lock is taken. If the
mapcount is zero, the anon_vma is assumed to be freed and no further
action is taken.
For clarity of review, KSM and page migration have separate refcounts on
the anon_vma. While clear, this is a waste of memory. This patch gets
KSM and page migration to share their toys in a spirit of harmony.
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
This patchset is a memory compaction mechanism that reduces external
fragmentation memory by moving GFP_MOVABLE pages to a fewer number of
pageblocks. The term "compaction" was chosen as there are is a number of
mechanisms that are not mutually exclusive that can be used to defragment
memory. For example, lumpy reclaim is a form of defragmentation as was
slub "defragmentation" (really a form of targeted reclaim). Hence, this
is called "compaction" to distinguish it from other forms of
defragmentation.
In this implementation, a full compaction run involves two scanners
operating within a zone - a migration and a free scanner. The migration
scanner starts at the beginning of a zone and finds all movable pages
within one pageblock_nr_pages-sized area and isolates them on a
migratepages list. The free scanner begins at the end of the zone and
searches on a per-area basis for enough free pages to migrate all the
pages on the migratepages list. As each area is respectively migrated or
exhausted of free pages, the scanners are advanced one area. A compaction
run completes within a zone when the two scanners meet.
This method is a bit primitive but is easy to understand and greater
sophistication would require maintenance of counters on a per-pageblock
basis. This would have a big impact on allocator fast-paths to improve
compaction which is a poor trade-off.
It also does not try relocate virtually contiguous pages to be physically
contiguous. However, assuming transparent hugepages were in use, a
hypothetical khugepaged might reuse compaction code to isolate free pages,
split them and relocate userspace pages for promotion.
Memory compaction can be triggered in one of three ways. It may be
triggered explicitly by writing any value to /proc/sys/vm/compact_memory
and compacting all of memory. It can be triggered on a per-node basis by
writing any value to /sys/devices/system/node/nodeN/compact where N is the
node ID to be compacted. When a process fails to allocate a high-order
page, it may compact memory in an attempt to satisfy the allocation
instead of entering direct reclaim. Explicit compaction does not finish
until the two scanners meet and direct compaction ends if a suitable page
becomes available that would meet watermarks.
The series is in 14 patches. The first three are not "core" to the series
but are important pre-requisites.
Patch 1 reference counts anon_vma for rmap_walk_anon(). Without this
patch, it's possible to use anon_vma after free if the caller is
not holding a VMA or mmap_sem for the pages in question. While
there should be no existing user that causes this problem,
it's a requirement for memory compaction to be stable. The patch
is at the start of the series for bisection reasons.
Patch 2 merges the KSM and migrate counts. It could be merged with patch 1
but would be slightly harder to review.
Patch 3 skips over unmapped anon pages during migration as there are no
guarantees about the anon_vma existing. There is a window between
when a page was isolated and migration started during which anon_vma
could disappear.
Patch 4 notes that PageSwapCache pages can still be migrated even if they
are unmapped.
Patch 5 allows CONFIG_MIGRATION to be set without CONFIG_NUMA
Patch 6 exports a "unusable free space index" via debugfs. It's
a measure of external fragmentation that takes the size of the
allocation request into account. It can also be calculated from
userspace so can be dropped if requested
Patch 7 exports a "fragmentation index" which only has meaning when an
allocation request fails. It determines if an allocation failure
would be due to a lack of memory or external fragmentation.
Patch 8 moves the definition for LRU isolation modes for use by compaction
Patch 9 is the compaction mechanism although it's unreachable at this point
Patch 10 adds a means of compacting all of memory with a proc trgger
Patch 11 adds a means of compacting a specific node with a sysfs trigger
Patch 12 adds "direct compaction" before "direct reclaim" if it is
determined there is a good chance of success.
Patch 13 adds a sysctl that allows tuning of the threshold at which the
kernel will compact or direct reclaim
Patch 14 temporarily disables compaction if an allocation failure occurs
after compaction.
Testing of compaction was in three stages. For the test, debugging,
preempt, the sleep watchdog and lockdep were all enabled but nothing nasty
popped out. min_free_kbytes was tuned as recommended by hugeadm to help
fragmentation avoidance and high-order allocations. It was tested on X86,
X86-64 and PPC64.
Ths first test represents one of the easiest cases that can be faced for
lumpy reclaim or memory compaction.
1. Machine freshly booted and configured for hugepage usage with
a) hugeadm --create-global-mounts
b) hugeadm --pool-pages-max DEFAULT:8G
c) hugeadm --set-recommended-min_free_kbytes
d) hugeadm --set-recommended-shmmax
The min_free_kbytes here is important. Anti-fragmentation works best
when pageblocks don't mix. hugeadm knows how to calculate a value that
will significantly reduce the worst of external-fragmentation-related
events as reported by the mm_page_alloc_extfrag tracepoint.
2. Load up memory
a) Start updatedb
b) Create in parallel a X files of pagesize*128 in size. Wait
until files are created. By parallel, I mean that 4096 instances
of dd were launched, one after the other using &. The crude
objective being to mix filesystem metadata allocations with
the buffer cache.
c) Delete every second file so that pageblocks are likely to
have holes
d) kill updatedb if it's still running
At this point, the system is quiet, memory is full but it's full with
clean filesystem metadata and clean buffer cache that is unmapped.
This is readily migrated or discarded so you'd expect lumpy reclaim
to have no significant advantage over compaction but this is at
the POC stage.
3. In increments, attempt to allocate 5% of memory as hugepages.
Measure how long it took, how successful it was, how many
direct reclaims took place and how how many compactions. Note
the compaction figures might not fully add up as compactions
can take place for orders other than the hugepage size
X86 vanilla compaction
Final page count 913 916 (attempted 1002)
pages reclaimed 68296 9791
X86-64 vanilla compaction
Final page count: 901 902 (attempted 1002)
Total pages reclaimed: 112599 53234
PPC64 vanilla compaction
Final page count: 93 94 (attempted 110)
Total pages reclaimed: 103216 61838
There was not a dramatic improvement in success rates but it wouldn't be
expected in this case either. What was important is that fewer pages were
reclaimed in all cases reducing the amount of IO required to satisfy a
huge page allocation.
The second tests were all performance related - kernbench, netperf, iozone
and sysbench. None showed anything too remarkable.
The last test was a high-order allocation stress test. Many kernel
compiles are started to fill memory with a pressured mix of unmovable and
movable allocations. During this, an attempt is made to allocate 90% of
memory as huge pages - one at a time with small delays between attempts to
avoid flooding the IO queue.
vanilla compaction
Percentage of request allocated X86 98 99
Percentage of request allocated X86-64 95 98
Percentage of request allocated PPC64 55 70
This patch:
rmap_walk_anon() does not use page_lock_anon_vma() for looking up and
locking an anon_vma and it does not appear to have sufficient locking to
ensure the anon_vma does not disappear from under it.
This patch copies an approach used by KSM to take a reference on the
anon_vma while pages are being migrated. This should prevent rmap_walk()
running into nasty surprises later because anon_vma has been freed.
putback_lru_page() never can fail. So it doesn't matter count of "the
number of pages put back".
In addition, users of this functions don't use return value.
Let's remove unnecessary code.
