path: root/mm/kmsan
2023-04-26mm: kmsan: handle alloc failures in kmsan_vmap_pages_range_noflush()Alexander Potapenko
commit 47ebd0310e89c087f56e58c103c44b72a2f6b216 upstream. As reported by Dipanjan Das, when KMSAN is used together with kernel fault injection (or, generally, even without the latter), calls to kcalloc() or __vmap_pages_range_noflush() may fail, leaving the metadata mappings for the virtual mapping in an inconsistent state. When these metadata mappings are accessed later, the kernel crashes. To address the problem, we return a non-zero error code from kmsan_vmap_pages_range_noflush() in the case of any allocation/mapping failure inside it, and make vmap_pages_range_noflush() return an error if KMSAN fails to allocate the metadata. This patch also removes KMSAN_WARN_ON() from vmap_pages_range_noflush(), as these allocation failures are not fatal anymore. Link: https://lkml.kernel.org/r/20230413131223.4135168-1-glider@google.com Fixes: b073d7f8aee4 ("mm: kmsan: maintain KMSAN metadata for page operations") Signed-off-by: Alexander Potapenko <glider@google.com> Reported-by: Dipanjan Das <mail.dipanjan.das@gmail.com> Link: https://lore.kernel.org/linux-mm/CANX2M5ZRrRA64k0hOif02TjmY9kbbO2aCBPyq79es34RXZ=cAw@mail.gmail.com/ Reviewed-by: Marco Elver <elver@google.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Uladzislau Rezki (Sony) <urezki@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2023-04-26mm: kmsan: handle alloc failures in kmsan_ioremap_page_range()Alexander Potapenko
commit fdea03e12aa2a44a7bb34144208be97fc25dfd90 upstream. Similarly to kmsan_vmap_pages_range_noflush(), kmsan_ioremap_page_range() must also properly handle allocation/mapping failures. In the case of such, it must clean up the already created metadata mappings and return an error code, so that the error can be propagated to ioremap_page_range(). Without doing so, KMSAN may silently fail to bring the metadata for the page range into a consistent state, which will result in user-visible crashes when trying to access them. Link: https://lkml.kernel.org/r/20230413131223.4135168-2-glider@google.com Fixes: b073d7f8aee4 ("mm: kmsan: maintain KMSAN metadata for page operations") Signed-off-by: Alexander Potapenko <glider@google.com> Reported-by: Dipanjan Das <mail.dipanjan.das@gmail.com> Link: https://lore.kernel.org/linux-mm/CANX2M5ZRrRA64k0hOif02TjmY9kbbO2aCBPyq79es34RXZ=cAw@mail.gmail.com/ Reviewed-by: Marco Elver <elver@google.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Uladzislau Rezki (Sony) <urezki@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2023-01-04kmsan: include linux/vmalloc.hArnd Bergmann
commit aaa746ad8b30f38ef89a301faf339ef1c19cf33a upstream. This is needed for the vmap/vunmap declarations: mm/kmsan/kmsan_test.c:316:9: error: implicit declaration of function 'vmap' is invalid in C99 [-Werror,-Wimplicit-function-declaration] vbuf = vmap(pages, npages, VM_MAP, PAGE_KERNEL); ^ mm/kmsan/kmsan_test.c:316:29: error: use of undeclared identifier 'VM_MAP' vbuf = vmap(pages, npages, VM_MAP, PAGE_KERNEL); ^ mm/kmsan/kmsan_test.c:322:3: error: implicit declaration of function 'vunmap' is invalid in C99 [-Werror,-Wimplicit-function-declaration] vunmap(vbuf); ^ Link: https://lkml.kernel.org/r/20221215163046.4079767-1-arnd@kernel.org Fixes: 8ed691b02ade ("kmsan: add tests for KMSAN") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Alexander Potapenko <glider@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Marco Elver <elver@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2023-01-04kmsan: export kmsan_handle_urbArnd Bergmann
commit 7ba594d700998bafa96a75360d2e060aa39156d2 upstream. USB support can be in a loadable module, and this causes a link failure with KMSAN: ERROR: modpost: "kmsan_handle_urb" [drivers/usb/core/usbcore.ko] undefined! Export the symbol so it can be used by this module. Link: https://lkml.kernel.org/r/20221215162710.3802378-1-arnd@kernel.org Fixes: 553a80188a5d ("kmsan: handle memory sent to/from USB") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Alexander Potapenko <glider@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Marco Elver <elver@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2022-11-08kmsan: core: kmsan_in_runtime() should return true in NMI contextAlexander Potapenko
Without that, every call to __msan_poison_alloca() in NMI may end up allocating memory, which is NMI-unsafe. Link: https://lkml.kernel.org/r/20221102110611.1085175-1-glider@google.com Link: https://lore.kernel.org/lkml/20221025221755.3810809-1-glider@google.com/ Signed-off-by: Alexander Potapenko <glider@google.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Marco Elver <elver@google.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Kees Cook <keescook@chromium.org> Cc: Masahiro Yamada <masahiroy@kernel.org> Cc: Nick Desaulniers <ndesaulniers@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2022-10-28x86: fortify: kmsan: fix KMSAN fortify buildsAlexander Potapenko
Ensure that KMSAN builds replace memset/memcpy/memmove calls with the respective __msan_XXX functions, and that none of the macros are redefined twice. This should allow building kernel with both CONFIG_KMSAN and CONFIG_FORTIFY_SOURCE. Link: https://lkml.kernel.org/r/20221024212144.2852069-5-glider@google.com Link: https://github.com/google/kmsan/issues/89 Signed-off-by: Alexander Potapenko <glider@google.com> Reported-by: Tamas K Lengyel <tamas.lengyel@zentific.com> Cc: Nathan Chancellor <nathan@kernel.org> Cc: Nick Desaulniers <ndesaulniers@google.com> Cc: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2022-10-28mm: kmsan: export kmsan_copy_page_meta()Alexander Potapenko
Certain modules call copy_user_highpage(), which calls kmsan_copy_page_meta() under KMSAN, so we need to export the latter. Link: https://lkml.kernel.org/r/20221024212144.2852069-1-glider@google.com Link: https://github.com/google/kmsan/issues/89 Fixes: b073d7f8aee4 ("mm: kmsan: maintain KMSAN metadata for page operations") Signed-off-by: Alexander Potapenko <glider@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2022-10-03x86: kmsan: handle CPU entry areaAlexander Potapenko
Among other data, CPU entry area holds exception stacks, so addresses from this area can be passed to kmsan_get_metadata(). This previously led to kmsan_get_metadata() returning NULL, which in turn resulted in a warning that triggered further attempts to call kmsan_get_metadata() in the exception context, which quickly exhausted the exception stack. This patch allocates shadow and origin for the CPU entry area on x86 and introduces arch_kmsan_get_meta_or_null(), which performs arch-specific metadata mapping. Link: https://lkml.kernel.org/r/20220928123219.1101883-1-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Fixes: 21d723a7c1409 ("kmsan: add KMSAN runtime core") Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Andrey Konovalov <andreyknvl@gmail.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers@google.com> Cc: Eric Biggers <ebiggers@kernel.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Ilya Leoshkevich <iii@linux.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kees Cook <keescook@chromium.org> Cc: Marco Elver <elver@google.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vasily Gorbik <gor@linux.ibm.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2022-10-03entry: kmsan: introduce kmsan_unpoison_entry_regs()Alexander Potapenko
struct pt_regs passed into IRQ entry code is set up by uninstrumented asm functions, therefore KMSAN may not notice the registers are initialized. kmsan_unpoison_entry_regs() unpoisons the contents of struct pt_regs, preventing potential false positives. Unlike kmsan_unpoison_memory(), it can be called under kmsan_in_runtime(), which is often the case in IRQ entry code. Link: https://lkml.kernel.org/r/20220915150417.722975-41-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Andrey Konovalov <andreyknvl@gmail.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers@google.com> Cc: Eric Biggers <ebiggers@kernel.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Ilya Leoshkevich <iii@linux.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kees Cook <keescook@chromium.org> Cc: Marco Elver <elver@google.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vasily Gorbik <gor@linux.ibm.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2022-10-03kmsan: add tests for KMSANAlexander Potapenko
The testing module triggers KMSAN warnings in different cases and checks that the errors are properly reported, using console probes to capture the tool's output. Link: https://lkml.kernel.org/r/20220915150417.722975-25-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Andrey Konovalov <andreyknvl@gmail.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers@google.com> Cc: Eric Biggers <ebiggers@kernel.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Ilya Leoshkevich <iii@linux.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kees Cook <keescook@chromium.org> Cc: Marco Elver <elver@google.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vasily Gorbik <gor@linux.ibm.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2022-10-03kmsan: handle memory sent to/from USBAlexander Potapenko
Depending on the value of is_out kmsan_handle_urb() KMSAN either marks the data copied to the kernel from a USB device as initialized, or checks the data sent to the device for being initialized. Link: https://lkml.kernel.org/r/20220915150417.722975-24-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Andrey Konovalov <andreyknvl@gmail.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers@google.com> Cc: Eric Biggers <ebiggers@kernel.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Ilya Leoshkevich <iii@linux.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kees Cook <keescook@chromium.org> Cc: Marco Elver <elver@google.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vasily Gorbik <gor@linux.ibm.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2022-10-03dma: kmsan: unpoison DMA mappingsAlexander Potapenko
KMSAN doesn't know about DMA memory writes performed by devices. We unpoison such memory when it's mapped to avoid false positive reports. Link: https://lkml.kernel.org/r/20220915150417.722975-22-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Andrey Konovalov <andreyknvl@gmail.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers@google.com> Cc: Eric Biggers <ebiggers@kernel.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Ilya Leoshkevich <iii@linux.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kees Cook <keescook@chromium.org> Cc: Marco Elver <elver@google.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vasily Gorbik <gor@linux.ibm.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2022-10-03instrumented.h: add KMSAN supportAlexander Potapenko
To avoid false positives, KMSAN needs to unpoison the data copied from the userspace. To detect infoleaks - check the memory buffer passed to copy_to_user(). Link: https://lkml.kernel.org/r/20220915150417.722975-19-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Reviewed-by: Marco Elver <elver@google.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Andrey Konovalov <andreyknvl@gmail.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers@google.com> Cc: Eric Biggers <ebiggers@kernel.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Ilya Leoshkevich <iii@linux.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kees Cook <keescook@chromium.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vasily Gorbik <gor@linux.ibm.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2022-10-03init: kmsan: call KMSAN initialization routinesAlexander Potapenko
kmsan_init_shadow() scans the mappings created at boot time and creates metadata pages for those mappings. When the memblock allocator returns pages to pagealloc, we reserve 2/3 of those pages and use them as metadata for the remaining 1/3. Once KMSAN starts, every page allocated by pagealloc has its associated shadow and origin pages. kmsan_initialize() initializes the bookkeeping for init_task and enables KMSAN. Link: https://lkml.kernel.org/r/20220915150417.722975-18-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Andrey Konovalov <andreyknvl@gmail.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers@google.com> Cc: Eric Biggers <ebiggers@kernel.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Ilya Leoshkevich <iii@linux.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kees Cook <keescook@chromium.org> Cc: Marco Elver <elver@google.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vasily Gorbik <gor@linux.ibm.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2022-10-03kmsan: handle task creation and exitingAlexander Potapenko
Tell KMSAN that a new task is created, so the tool creates a backing metadata structure for that task. Link: https://lkml.kernel.org/r/20220915150417.722975-17-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Andrey Konovalov <andreyknvl@gmail.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers@google.com> Cc: Eric Biggers <ebiggers@kernel.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Ilya Leoshkevich <iii@linux.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kees Cook <keescook@chromium.org> Cc: Marco Elver <elver@google.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vasily Gorbik <gor@linux.ibm.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2022-10-03mm: kmsan: call KMSAN hooks from SLUB codeAlexander Potapenko
In order to report uninitialized memory coming from heap allocations KMSAN has to poison them unless they're created with __GFP_ZERO. It's handy that we need KMSAN hooks in the places where init_on_alloc/init_on_free initialization is performed. In addition, we apply __no_kmsan_checks to get_freepointer_safe() to suppress reports when accessing freelist pointers that reside in freed objects. Link: https://lkml.kernel.org/r/20220915150417.722975-16-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Reviewed-by: Marco Elver <elver@google.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Andrey Konovalov <andreyknvl@gmail.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers@google.com> Cc: Eric Biggers <ebiggers@kernel.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Ilya Leoshkevich <iii@linux.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kees Cook <keescook@chromium.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vasily Gorbik <gor@linux.ibm.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2022-10-03mm: kmsan: maintain KMSAN metadata for page operationsAlexander Potapenko
Insert KMSAN hooks that make the necessary bookkeeping changes: - poison page shadow and origins in alloc_pages()/free_page(); - clear page shadow and origins in clear_page(), copy_user_highpage(); - copy page metadata in copy_highpage(), wp_page_copy(); - handle vmap()/vunmap()/iounmap(); Link: https://lkml.kernel.org/r/20220915150417.722975-15-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Andrey Konovalov <andreyknvl@gmail.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers@google.com> Cc: Eric Biggers <ebiggers@kernel.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Ilya Leoshkevich <iii@linux.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kees Cook <keescook@chromium.org> Cc: Marco Elver <elver@google.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vasily Gorbik <gor@linux.ibm.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2022-10-03kmsan: add KMSAN runtime coreAlexander Potapenko
For each memory location KernelMemorySanitizer maintains two types of metadata: 1. The so-called shadow of that location - а byte:byte mapping describing whether or not individual bits of memory are initialized (shadow is 0) or not (shadow is 1). 2. The origins of that location - а 4-byte:4-byte mapping containing 4-byte IDs of the stack traces where uninitialized values were created. Each struct page now contains pointers to two struct pages holding KMSAN metadata (shadow and origins) for the original struct page. Utility routines in mm/kmsan/core.c and mm/kmsan/shadow.c handle the metadata creation, addressing, copying and checking. mm/kmsan/report.c performs error reporting in the cases an uninitialized value is used in a way that leads to undefined behavior. KMSAN compiler instrumentation is responsible for tracking the metadata along with the kernel memory. mm/kmsan/instrumentation.c provides the implementation for instrumentation hooks that are called from files compiled with -fsanitize=kernel-memory. To aid parameter passing (also done at instrumentation level), each task_struct now contains a struct kmsan_task_state used to track the metadata of function parameters and return values for that task. Finally, this patch provides CONFIG_KMSAN that enables KMSAN, and declares CFLAGS_KMSAN, which are applied to files compiled with KMSAN. The KMSAN_SANITIZE:=n Makefile directive can be used to completely disable KMSAN instrumentation for certain files. Similarly, KMSAN_ENABLE_CHECKS:=n disables KMSAN checks and makes newly created stack memory initialized. Users can also use functions from include/linux/kmsan-checks.h to mark certain memory regions as uninitialized or initialized (this is called "poisoning" and "unpoisoning") or check that a particular region is initialized. Link: https://lkml.kernel.org/r/20220915150417.722975-12-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Acked-by: Marco Elver <elver@google.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Andrey Konovalov <andreyknvl@gmail.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers@google.com> Cc: Eric Biggers <ebiggers@kernel.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Ilya Leoshkevich <iii@linux.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kees Cook <keescook@chromium.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vasily Gorbik <gor@linux.ibm.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
