Our machine encountered a panic(addressing exception) after run for a
long time and the calltrace is:
RIP: hugetlb_fault+0x307/0xbe0
RSP: 0018:ffff9567fc27f808 EFLAGS: 00010286
RAX: e800c03ff1258d48 RBX: ffffd3bb003b69c0 RCX: e800c03ff1258d48
RDX: 17ff3fc00eda72b7 RSI: 00003ffffffff000 RDI: e800c03ff1258d48
RBP: ffff9567fc27f8c8 R08: e800c03ff1258d48 R09: 0000000000000080
R10: ffffaba0704c22a8 R11: 0000000000000001 R12: ffff95c87b4b60d8
R13: 00005fff00000000 R14: 0000000000000000 R15: ffff9567face8074
FS: 00007fe2d9ffb700(0000) GS:ffff956900e40000(0000) knlGS:0000000000000000
CR2: ffffd3bb003b69c0 CR3: 000000be67374000 CR4: 00000000003627e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
follow_hugetlb_page+0x175/0x540
__get_user_pages+0x2a0/0x7e0
__get_user_pages_unlocked+0x15d/0x210
__gfn_to_pfn_memslot+0x3c5/0x460 [kvm]
try_async_pf+0x6e/0x2a0 [kvm]
tdp_page_fault+0x151/0x2d0 [kvm]
kvm_arch_vcpu_ioctl_run+0x330/0x490 [kvm]
kvm_vcpu_ioctl+0x309/0x6d0 [kvm]
do_vfs_ioctl+0x3f0/0x540
SyS_ioctl+0xa1/0xc0
system_call_fastpath+0x22/0x27
For 1G hugepages, huge_pte_offset() wants to return NULL or pudp, but it
may return a wrong 'pmdp' if there is a race. Please look at the
following code snippet:
pud = pud_offset(p4d, addr);
if (sz != PUD_SIZE && pud_none(*pud))
return NULL;
/* hugepage or swap? */
if (pud_huge(*pud) || !pud_present(*pud))
return (pte_t *)pud;
pmd = pmd_offset(pud, addr);
if (sz != PMD_SIZE && pmd_none(*pmd))
return NULL;
if (pmd_huge(*pmd) || !pmd_present(*pmd))
return (pte_t *)pmd;
The following sequence would trigger this bug:
- CPU0: sz = PUD_SIZE and *pud = 0 , continue
- CPU0: "pud_huge(*pud)" is false
- CPU1: calling hugetlb_no_page and set *pud to xxxx8e7(PRESENT)
- CPU0: "!pud_present(*pud)" is false, continue
- CPU0: pmd = pmd_offset(pud, addr) and maybe return a wrong pmdp
However, we want CPU0 to return NULL or pudp in this case.
We must make sure there is exactly one dereference of pud and pmd.
Signed-off-by: Longpeng <longpeng2@huawei.com>
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
Reviewed-by: Jason Gunthorpe <jgg@mellanox.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Sean Christopherson <sean.j.christopherson@intel.com>
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/20200413010342.771-1-longpeng2@huawei.com
Commit 944d9fec8d7a ("hugetlb: add support for gigantic page allocation
at runtime") has added the run-time allocation of gigantic pages.
However it actually works only at early stages of the system loading,
when the majority of memory is free. After some time the memory gets
fragmented by non-movable pages, so the chances to find a contiguous 1GB
block are getting close to zero. Even dropping caches manually doesn't
help a lot.
At large scale rebooting servers in order to allocate gigantic hugepages
is quite expensive and complex. At the same time keeping some constant
percentage of memory in reserved hugepages even if the workload isn't
using it is a big waste: not all workloads can benefit from using 1 GB
pages.
The following solution can solve the problem:
1) On boot time a dedicated cma area* is reserved. The size is passed
as a kernel argument.
2) Run-time allocations of gigantic hugepages are performed using the
cma allocator and the dedicated cma area
In this case gigantic hugepages can be allocated successfully with a
high probability, however the memory isn't completely wasted if nobody
is using 1GB hugepages: it can be used for pagecache, anon memory, THPs,
etc.
* On a multi-node machine a per-node cma area is allocated on each node.
Following gigantic hugetlb allocation are using the first available
numa node if the mask isn't specified by a user.
Usage:
1) configure the kernel to allocate a cma area for hugetlb allocations:
pass hugetlb_cma=10G as a kernel argument
2) allocate hugetlb pages as usual, e.g.
echo 10 > /sys/kernel/mm/hugepages/hugepages-1048576kB/nr_hugepages
If the option isn't enabled or the allocation of the cma area failed,
the current behavior of the system is preserved.
x86 and arm-64 are covered by this patch, other architectures can be
trivially added later.
The patch contains clean-ups and fixes proposed and implemented by Aslan
Bakirov and Randy Dunlap. It also contains ideas and suggestions
proposed by Rik van Riel, Michal Hocko and Mike Kravetz. Thanks!
Signed-off-by: Roman Gushchin <guro@fb.com>
Tested-by: Andreas Schaufler <andreas.schaufler@gmx.de>
Acked-by: Mike Kravetz <mike.kravetz@oracle.com>
Acked-by: Michal Hocko <mhocko@kernel.org>
Cc: Aslan Bakirov <aslan@fb.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Rik van Riel <riel@surriel.com>
Cc: Joonsoo Kim <js1304@gmail.com>
Link: http://lkml.kernel.org/r/20200407163840.92263-3-guro@fb.com
Sparse reports a warning at gather_surplus_pages()
warning: context imbalance in hugetlb_cow() - unexpected unlock
The root cause is the missing annotation at gather_surplus_pages()
Add the missing __must_hold(&hugetlb_lock)
Signed-off-by: Jules Irenge <jbi.octave@gmail.com>
Link: http://lkml.kernel.org/r/20200214204741.94112-7-jbi.octave@gmail.com
Commit f1e61557f023 ("mm: pack compound_dtor and compound_order into one
word in struct page") changed compound_dtor from a pointer to an array
index in order to pack it. To check if page has the hugeltbfs
compound_dtor, we can just compare the index directly without fetching the
function pointer. Said commit did that with PageHuge() and we can do the
same with PageHeadHuge() to make the code a bit smaller and faster.
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: David Rientjes <rientjes@google.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Neha Agarwal <nehaagarwal@google.com>
Link: http://lkml.kernel.org/r/20200311172440.6988-1-vbabka@suse.cz
Previously variable 'check_addr' was initialized, but was not read later
before reassigning. So the initialization can be removed.
Signed-off-by: Mateusz Nosek <mateusznosek0@gmail.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Link: http://lkml.kernel.org/r/20200303212354.25226-1-mateusznosek0@gmail.com
An earlier patch in this series disabled file_region coalescing in order
to hang the hugetlb_cgroup uncharge info on the file_region entries.
This patch re-adds support for coalescing of file_region entries.
Essentially everytime we add an entry, we call a recursive function that
tries to coalesce the added region with the regions next to it. The worst
case call depth for this function is 3: one to coalesce with the region
next to it, one to coalesce to the region prev, and one to reach the base
case.
This is an important performance optimization as private mappings add
their entries page by page, and we could incur big performance costs for
large mappings with lots of file_region entries in their resv_map.
[almasrymina@google.com: fix CONFIG_CGROUP_HUGETLB ifdefs]
Link: http://lkml.kernel.org/r/20200214204544.231482-1-almasrymina@google.com
[almasrymina@google.com: remove check_coalesce_bug debug code]
Link: http://lkml.kernel.org/r/20200219233610.13808-1-almasrymina@google.com
Signed-off-by: Mina Almasry <almasrymina@google.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Sandipan Das <sandipan@linux.ibm.com>
Cc: Shakeel Butt <shakeelb@google.com>
Cc: Shuah Khan <shuah@kernel.org>
Link: http://lkml.kernel.org/r/20200211213128.73302-7-almasrymina@google.com
Support MAP_NORESERVE accounting as part of the new counter.
For each hugepage allocation, at allocation time we check if there is a
reservation for this allocation or not. If there is a reservation for
this allocation, then this allocation was charged at reservation time, and
we don't re-account it. If there is no reserevation for this allocation,
we charge the appropriate hugetlb_cgroup.
The hugetlb_cgroup to uncharge for this allocation is stored in
page[3].private. We use new APIs added in an earlier patch to set this
pointer.
Link: http://lkml.kernel.org/r/20200211213128.73302-6-almasrymina@google.com
For shared mappings, the pointer to the hugetlb_cgroup to uncharge lives
in the resv_map entries, in file_region->reservation_counter.
After a call to region_chg, we charge the approprate hugetlb_cgroup, and
if successful, we pass on the hugetlb_cgroup info to a follow up
region_add call. When a file_region entry is added to the resv_map via
region_add, we put the pointer to that cgroup in
file_region->reservation_counter. If charging doesn't succeed, we report
the error to the caller, so that the kernel fails the reservation.
On region_del, which is when the hugetlb memory is unreserved, we also
uncharge the file_region->reservation_counter.
[akpm@linux-foundation.org: forward declare struct file_region]
Link: http://lkml.kernel.org/r/20200211213128.73302-5-almasrymina@google.com
A follow up patch in this series adds hugetlb cgroup uncharge info the
file_region entries in resv->regions. The cgroup uncharge info may differ
for different regions, so they can no longer be coalesced at region_add
time. So, disable region coalescing in region_add in this patch.
Behavior change:
Say a resv_map exists like this [0->1], [2->3], and [5->6].
Then a region_chg/add call comes in region_chg/add(f=0, t=5).
Old code would generate resv->regions: [0->5], [5->6].
New code would generate resv->regions: [0->1], [1->2], [2->3], [3->5],
[5->6].
Special care needs to be taken to handle the resv->adds_in_progress
variable correctly. In the past, only 1 region would be added for every
region_chg and region_add call. But now, each call may add multiple
regions, so we can no longer increment adds_in_progress by 1 in
region_chg, or decrement adds_in_progress by 1 after region_add or
region_abort. Instead, region_chg calls add_reservation_in_range() to
count the number of regions needed and allocates those, and that info is
passed to region_add and region_abort to decrement adds_in_progress
correctly.
We've also modified the assumption that region_add after region_chg never
fails. region_chg now pre-allocates at least 1 region for region_add. If
region_add needs more regions than region_chg has allocated for it, then
it may fail.
[almasrymina@google.com: fix file_region entry allocations]
Link: http://lkml.kernel.org/r/20200219012736.20363-1-almasrymina@google.com
Cc: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com>
Link: http://lkml.kernel.org/r/20200211213128.73302-4-almasrymina@google.com
Normally the pointer to the cgroup to uncharge hangs off the struct page,
and gets queried when it's time to free the page. With hugetlb_cgroup
reservations, this is not possible. Because it's possible for a page to
be reserved by one task and actually faulted in by another task.
The best place to put the hugetlb_cgroup pointer to uncharge for
reservations is in the resv_map. But, because the resv_map has different
semantics for private and shared mappings, the code patch to
charge/uncharge shared and private mappings is different. This patch
implements charging and uncharging for private mappings.
For private mappings, the counter to uncharge is in
resv_map->reservation_counter. On initializing the resv_map this is set
to NULL. On reservation of a region in private mapping, the tasks
hugetlb_cgroup is charged and the hugetlb_cgroup is placed is
On hugetlb_vm_op_close, we uncharge resv_map->reservation_counter.
[akpm@linux-foundation.org: forward declare struct resv_map]
Link: http://lkml.kernel.org/r/20200211213128.73302-3-almasrymina@google.com
Augments hugetlb_cgroup_charge_cgroup to be able to charge hugetlb usage
or hugetlb reservation counter.
Adds a new interface to uncharge a hugetlb_cgroup counter via
hugetlb_cgroup_uncharge_counter.
Integrates the counter with hugetlb_cgroup, via hugetlb_cgroup_init,
hugetlb_cgroup_have_usage, and hugetlb_cgroup_css_offline.
Link: http://lkml.kernel.org/r/20200211213128.73302-2-almasrymina@google.com
hugetlbfs page faults can race with truncate and hole punch operations.
Current code in the page fault path attempts to handle this by 'backing
out' operations if we encounter the race. One obvious omission in the
current code is removing a page newly added to the page cache. This is
pretty straight forward to address, but there is a more subtle and
difficult issue of backing out hugetlb reservations. To handle this
correctly, the 'reservation state' before page allocation needs to be
noted so that it can be properly backed out. There are four distinct
possibilities for reservation state: shared/reserved, shared/no-resv,
private/reserved and private/no-resv. Backing out a reservation may
require memory allocation which could fail so that needs to be taken
into account as well.
Instead of writing the required complicated code for this rare
occurrence, just eliminate the race. i_mmap_rwsem is now held in read
mode for the duration of page fault processing. Hold i_mmap_rwsem in
write mode when modifying i_size. In this way, truncation can not
proceed when page faults are being processed. In addition, i_size
will not change during fault processing so a single check can be made
to ensure faults are not beyond (proposed) end of file. Faults can
still race with hole punch, but that race is handled by existing code
and the use of hugetlb_fault_mutex.
With this modification, checks for races with truncation in the page
fault path can be simplified and removed. remove_inode_hugepages no
longer needs to take hugetlb_fault_mutex in the case of truncation.
Comments are expanded to explain reasoning behind locking.
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Cc: "Aneesh Kumar K . V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Prakash Sangappa <prakash.sangappa@oracle.com>
Link: http://lkml.kernel.org/r/20200316205756.146666-3-mike.kravetz@oracle.com
Patch series "hugetlbfs: use i_mmap_rwsem for more synchronization", v2.
While discussing the issue with huge_pte_offset [1], I remembered that
there were more outstanding hugetlb races. These issues are:
1) For shared pmds, huge PTE pointers returned by huge_pte_alloc can become
invalid via a call to huge_pmd_unshare by another thread.
2) hugetlbfs page faults can race with truncation causing invalid global
reserve counts and state.
A previous attempt was made to use i_mmap_rwsem in this manner as
described at [2]. However, those patches were reverted starting with [3]
due to locking issues.
To effectively use i_mmap_rwsem to address the above issues it needs to be
held (in read mode) during page fault processing. However, during fault
processing we need to lock the page we will be adding. Lock ordering
requires we take page lock before i_mmap_rwsem. Waiting until after
taking the page lock is too late in the fault process for the
synchronization we want to do.
To address this lock ordering issue, the following patches change the lock
ordering for hugetlb pages. This is not too invasive as hugetlbfs
processing is done separate from core mm in many places. However, I don't
really like this idea. Much ugliness is contained in the new routine
hugetlb_page_mapping_lock_write() of patch 1.
The only other way I can think of to address these issues is by catching
all the races. After catching a race, cleanup, backout, retry ... etc,
as needed. This can get really ugly, especially for huge page
reservations. At one time, I started writing some of the reservation
backout code for page faults and it got so ugly and complicated I went
down the path of adding synchronization to avoid the races. Any other
suggestions would be welcome.
[1] https://lore.kernel.org/linux-mm/1582342427-230392-1-git-send-email-longpeng2@huawei.com/
[2] https://lore.kernel.org/linux-mm/20181222223013.22193-1-mike.kravetz@oracle.com/
[3] https://lore.kernel.org/linux-mm/20190103235452.29335-1-mike.kravetz@oracle.com
[4] https://lore.kernel.org/linux-mm/1584028670.7365.182.camel@lca.pw/
[5] https://lore.kernel.org/lkml/20200312183142.108df9ac@canb.auug.org.au/
This patch (of 2):
While looking at BUGs associated with invalid huge page map counts, it was
discovered and observed that a huge pte pointer could become 'invalid' and
point to another task's page table. Consider the following:
A task takes a page fault on a shared hugetlbfs file and calls
huge_pte_alloc to get a ptep. Suppose the returned ptep points to a
shared pmd.
Now, another task truncates the hugetlbfs file. As part of truncation, it
unmaps everyone who has the file mapped. If the range being truncated is
covered by a shared pmd, huge_pmd_unshare will be called. For all but the
last user of the shared pmd, huge_pmd_unshare will clear the pud pointing
to the pmd. If the task in the middle of the page fault is not the last
user, the ptep returned by huge_pte_alloc now points to another task's
page table or worse. This leads to bad things such as incorrect page
map/reference counts or invalid memory references.
To fix, expand the use of i_mmap_rwsem as follows:
- i_mmap_rwsem is held in read mode whenever huge_pmd_share is called.
huge_pmd_share is only called via huge_pte_alloc, so callers of
huge_pte_alloc take i_mmap_rwsem before calling. In addition, callers
of huge_pte_alloc continue to hold the semaphore until finished with
the ptep.
- i_mmap_rwsem is held in write mode whenever huge_pmd_unshare is called.
One problem with this scheme is that it requires taking i_mmap_rwsem
before taking the page lock during page faults. This is not the order
specified in the rest of mm code. Handling of hugetlbfs pages is mostly
isolated today. Therefore, we use this alternative locking order for
PageHuge() pages.
mapping->i_mmap_rwsem
hugetlb_fault_mutex (hugetlbfs specific page fault mutex)
page->flags PG_locked (lock_page)
To help with lock ordering issues, hugetlb_page_mapping_lock_write() is
introduced to write lock the i_mmap_rwsem associated with a page.
In most cases it is easy to get address_space via vma->vm_file->f_mapping.
However, in the case of migration or memory errors for anon pages we do
not have an associated vma. A new routine _get_hugetlb_page_mapping()
will use anon_vma to get address_space in these cases.
Link: http://lkml.kernel.org/r/20200316205756.146666-2-mike.kravetz@oracle.com
The existing gup code does not react to the fatal signals in many code
paths. For example, in one retry path of gup we're still using
down_read() rather than down_read_killable(). Also, when doing page
faults we don't pass in FAULT_FLAG_KILLABLE as well, which means that
within the faulting process we'll wait in non-killable way as well. These
were spotted by Linus during the code review of some other patches.
Let's allow the gup code to react to fatal signals to improve the
responsiveness of threads when during gup and being killed.
Signed-off-by: Peter Xu <peterx@redhat.com>
Tested-by: Brian Geffon <bgeffon@google.com>
Cc: Bobby Powers <bobbypowers@gmail.com>
Cc: David Hildenbrand <david@redhat.com>
Cc: Denis Plotnikov <dplotnikov@virtuozzo.com>
Cc: "Dr . David Alan Gilbert" <dgilbert@redhat.com>
Cc: Jerome Glisse <jglisse@redhat.com>
Cc: "Kirill A . Shutemov" <kirill@shutemov.name>
Cc: Martin Cracauer <cracauer@cons.org>
Cc: Marty McFadden <mcfadden8@llnl.gov>
Cc: Maya Gokhale <gokhale2@llnl.gov>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Link: http://lkml.kernel.org/r/20200220160256.9887-1-peterx@redhat.com
This is the gup counterpart of the change that allows the VM_FAULT_RETRY
to happen for more than once. One thing to mention is that we must check
the fatal signal here before retry because the GUP can be interrupted by
that, otherwise we can loop forever.
Link: http://lkml.kernel.org/r/20200220195357.16371-1-peterx@redhat.com
Patch series "mm: Page fault enhancements", v6.
This series contains cleanups and enhancements to current page fault
logic. The whole idea comes from the discussion between Andrea and Linus
on the bug reported by syzbot here:
https://lkml.org/lkml/2017/11/2/833
Basically it does two things:
(a) Allows the page fault logic to be more interactive on not only
SIGKILL, but also the rest of userspace signals, and,
(b) Allows the page fault retry (VM_FAULT_RETRY) to happen for more
than once.
For (a): with the changes we should be able to react faster when page
faults are working in parallel with userspace signals like SIGSTOP and
SIGCONT (and more), and with that we can remove the buggy part in
userfaultfd and benefit the whole page fault mechanism on faster signal
processing to reach the userspace.
For (b), we should be able to allow the page fault handler to loop for
even more than twice. Some context: for now since we have
FAULT_FLAG_ALLOW_RETRY we can allow to retry the page fault once with the
same interrupt context, however never more than twice. This can be not
only a potential cleanup to remove this assumption since AFAIU the code
itself doesn't really have this twice-only limitation (though that should
be a protective approach in the past), at the same time it'll greatly
simplify future works like userfaultfd write-protect where it's possible
to retry for more than twice (please have a look at [1] below for a
possible user that might require the page fault to be handled for a third
time; if we can remove the retry limitation we can simply drop that patch
and those complexity).
This patch (of 16):
There's plenty of places around __get_user_pages() that has a parameter
"nonblocking" which does not really mean that "it won't block" (because it
can really block) but instead it shows whether the mmap_sem is released by
up_read() during the page fault handling mostly when VM_FAULT_RETRY is
returned.
We have the correct naming in e.g. get_user_pages_locked() or
get_user_pages_remote() as "locked", however there're still many places
that are using the "nonblocking" as name.
Renaming the places to "locked" where proper to better suite the
functionality of the variable. While at it, fixing up some of the
comments accordingly.
Reviewed-by: Mike Rapoport <rppt@linux.vnet.ibm.com>
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
Link: http://lkml.kernel.org/r/20200220155353.8676-2-peterx@redhat.com
For huge pages (and in fact, any compound page), the GUP_PIN_COUNTING_BIAS
scheme tends to overflow too easily, each tail page increments the head
page->_refcount by GUP_PIN_COUNTING_BIAS (1024). That limits the number
of huge pages that can be pinned.
This patch removes that limitation, by using an exact form of pin counting
for compound pages of order > 1. The "order > 1" is required because this
approach uses the 3rd struct page in the compound page, and order 1
compound pages only have two pages, so that won't work there.
A new struct page field, hpage_pinned_refcount, has been added, replacing
a padding field in the union (so no new space is used).
This enhancement also has a useful side effect: huge pages and compound
pages (of order > 1) do not suffer from the "potential false positives"
problem that is discussed in the page_dma_pinned() comment block. That is
because these compound pages have extra space for tracking things, so they
get exact pin counts instead of overloading page->_refcount.
Documentation/core-api/pin_user_pages.rst is updated accordingly.
Suggested-by: Jan Kara <jack@suse.cz>
Signed-off-by: John Hubbard <jhubbard@nvidia.com>
Cc: Ira Weiny <ira.weiny@intel.com>
Cc: Jérôme Glisse <jglisse@redhat.com>
Cc: "Matthew Wilcox (Oracle)" <willy@infradead.org>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Jason Gunthorpe <jgg@ziepe.ca>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Michal Hocko <mhocko@suse.com>
Link: http://lkml.kernel.org/r/20200211001536.1027652-8-jhubbard@nvidia.com
Add tracking of pages that were pinned via FOLL_PIN. This tracking is
implemented via overloading of page->_refcount: pins are added by adding
GUP_PIN_COUNTING_BIAS (1024) to the refcount. This provides a fuzzy
indication of pinning, and it can have false positives (and that's OK).
Please see the pre-existing Documentation/core-api/pin_user_pages.rst for
details.
As mentioned in pin_user_pages.rst, callers who effectively set FOLL_PIN
(typically via pin_user_pages*()) are required to ultimately free such
pages via unpin_user_page().
Please also note the limitation, discussed in pin_user_pages.rst under the
"TODO: for 1GB and larger huge pages" section. (That limitation will be
removed in a following patch.)
The effect of a FOLL_PIN flag is similar to that of FOLL_GET, and may be
thought of as "FOLL_GET for DIO and/or RDMA use".
Pages that have been pinned via FOLL_PIN are identifiable via a new
function call:
bool page_maybe_dma_pinned(struct page *page);
What to do in response to encountering such a page, is left to later
patchsets. There is discussion about this in [1], [2], [3], and [4].
This also changes a BUG_ON(), to a WARN_ON(), in follow_page_mask().
[1] Some slow progress on get_user_pages() (Apr 2, 2019):
https://lwn.net/Articles/784574/
[2] DMA and get_user_pages() (LPC: Dec 12, 2018):
https://lwn.net/Articles/774411/
[3] The trouble with get_user_pages() (Apr 30, 2018):
https://lwn.net/Articles/753027/
[4] LWN kernel index: get_user_pages():
https://lwn.net/Kernel/Index/#Memory_management-get_user_pages
[jhubbard@nvidia.com: add kerneldoc]
Link: http://lkml.kernel.org/r/20200307021157.235726-1-jhubbard@nvidia.com
[imbrenda@linux.ibm.com: if pin fails, we need to unpin, a simple put_page will not be enough]
Link: http://lkml.kernel.org/r/20200306132537.783769-2-imbrenda@linux.ibm.com
[akpm@linux-foundation.org: fix put_compound_head defined but not used]
Suggested-by: Jérôme Glisse <jglisse@redhat.com>
Signed-off-by: Claudio Imbrenda <imbrenda@linux.ibm.com>
Link: http://lkml.kernel.org/r/20200211001536.1027652-7-jhubbard@nvidia.com
The following lockdep splat was observed when a certain hugetlbfs test
was run:
WARNING: inconsistent lock state
4.18.0-159.el8.x86_64+debug #1 Tainted: G W --------- - -
inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
swapper/30/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
ffffffff9acdc038 (hugetlb_lock){+.?.}, at: free_huge_page+0x36f/0xaa0
{SOFTIRQ-ON-W} state was registered at:
lock_acquire+0x14f/0x3b0
_raw_spin_lock+0x30/0x70
__nr_hugepages_store_common+0x11b/0xb30
hugetlb_sysctl_handler_common+0x209/0x2d0
proc_sys_call_handler+0x37f/0x450
vfs_write+0x157/0x460
ksys_write+0xb8/0x170
do_syscall_64+0xa5/0x4d0
entry_SYSCALL_64_after_hwframe+0x6a/0xdf
irq event stamp: 691296
hardirqs last enabled at (691296): [<ffffffff99bb034b>] _raw_spin_unlock_irqrestore+0x4b/0x60
hardirqs last disabled at (691295): [<ffffffff99bb0ad2>] _raw_spin_lock_irqsave+0x22/0x81
softirqs last enabled at (691284): [<ffffffff97ff0c63>] irq_enter+0xc3/0xe0
softirqs last disabled at (691285): [<ffffffff97ff0ebe>] irq_exit+0x23e/0x2b0
Possible unsafe locking scenario:
CPU0
lock(hugetlb_lock);
<Interrupt>
lock(hugetlb_lock);
*** DEADLOCK ***
Call Trace:
<IRQ>
__lock_acquire+0x146b/0x48c0
bio_check_pages_dirty+0x2fc/0x5c0
clone_endio+0x17f/0x670 [dm_mod]
blk_update_request+0x276/0xe50
scsi_end_request+0x7b/0x6a0
scsi_io_completion+0x1c6/0x1570
blk_done_softirq+0x22e/0x350
__do_softirq+0x23d/0xad8
do_IRQ+0x11a/0x200
common_interrupt+0xf/0xf
</IRQ>
Both the hugetbl_lock and the subpool lock can be acquired in
free_huge_page(). One way to solve the problem is to make both locks
irq-safe. However, Mike Kravetz had learned that the hugetlb_lock is
held for a linear scan of ALL hugetlb pages during a cgroup reparentling
operation. So it is just too long to have irq disabled unless we can
break hugetbl_lock down into finer-grained locks with shorter lock hold
times.
Another alternative is to defer the freeing to a workqueue job. This
patch implements the deferred freeing by adding a free_hpage_workfn()
work function to do the actual freeing. The free_huge_page() call in a
non-task context saves the page to be freed in the hpage_freelist linked
list in a lockless manner using the llist APIs.
The generic workqueue is used to process the work, but a dedicated
workqueue can be used instead if it is desirable to have the huge page
freed ASAP.
Thanks to Kirill Tkhai <ktkhai@virtuozzo.com> for suggesting the use of
llist APIs which simplfy the code.
Link: http://lkml.kernel.org/r/20191217170331.30893-1-longman@redhat.com
Signed-off-by: Waiman Long <longman@redhat.com>
Acked-by: Davidlohr Bueso <dbueso@suse.de>
Reviewed-by: Kirill Tkhai <ktkhai@virtuozzo.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com>
When mmapping an existing hugetlbfs file with MAP_POPULATE, we find it
is very time consuming. For example, mmapping a 128GB file takes about
50 milliseconds. Sampling with perfevent shows it spends 99% time in
the same_page loop in follow_hugetlb_page().
samples: 205 of event 'cycles', Event count (approx.): 136686374
- 99.04% test_mmap_huget [kernel.kallsyms] [k] follow_hugetlb_page
follow_hugetlb_page
__get_user_pages
__mlock_vma_pages_range
__mm_populate
vm_mmap_pgoff
sys_mmap_pgoff
sys_mmap
__mmap64
follow_hugetlb_page() is called with pages=NULL and vmas=NULL, so for
each hugepage, we run into the same_page loop for pages_per_huge_page()
times, but doing nothing. With this change, it takes less then 1
millisecond to mmap a 128GB file in hugetlbfs.
Link: http://lkml.kernel.org/r/1567581712-5992-1-git-send-email-totty.lu@gmail.com
Signed-off-by: Zhigang Lu <tonnylu@tencent.com>
Reviewed-by: Haozhong Zhang <hzhongzhang@tencent.com>
Reviewed-by: Zongming Zhang <knightzhang@tencent.com>
Acked-by: Matthew Wilcox <willy@infradead.org>
The first parameter hstate in function hugetlb_fault_mutex_hash() is not
used anymore.
This patch removes it.
[akpm@linux-foundation.org: various build fixes]
[cai@lca.pw: fix a GCC compilation warning]
Link: http://lkml.kernel.org/r/1570544108-32331-1-git-send-email-cai@lca.pw
Link: http://lkml.kernel.org/r/20191005003302.785-1-richardw.yang@linux.intel.com
Signed-off-by: Wei Yang <richardw.yang@linux.intel.com>
Signed-off-by: Qian Cai <cai@lca.pw>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Remove duplicated code between region_chg and region_add, and refactor
it into a common function, add_reservation_in_range. This is mostly
done because there is a follow up change in another series that disables
region coalescing in region_add, and I want to make that change in one
place only. It should improve maintainability anyway on its own.
[akpm@linux-foundation.org: coding style fixes]
Link: http://lkml.kernel.org/r/20190919200428.188797-3-almasrymina@google.com
Current behavior is that region_chg provides both a cache entry in
resv->region_cache, AND a placeholder entry in resv->regions.
region_add first tries to use the placeholder, and if it finds that the
placeholder has been deleted by a racing region_del call, it uses the
cache entry.
This behavior is completely unnecessary and is removed in this patch for
a couple of reasons:
1. region_add needs to either find a cached file_region entry in
resv->region_cache, or find an entry in resv->regions to expand. It
does not need both.
2. region_chg adding a placeholder entry in resv->regions opens up
a possible race with region_del, where region_chg adds a placeholder
region in resv->regions, and this region is deleted by a racing call
to region_del during region_chg execution or before region_add is
called. Removing the race makes the code easier to reason about and
maintain.
In addition, a follow up patch in another series that disables region
coalescing, which would be further complicated if the race with
region_del exists.
Link: http://lkml.kernel.org/r/20190919200428.188797-2-almasrymina@google.com
A customer with large SMP systems (up to 16 sockets) with application
that uses large amount of static hugepages (~500-1500GB) are
experiencing random multisecond delays. These delays were caused by the
long time it took to scan the VMA interval tree with mmap_sem held.
The sharing of huge PMD does not require changes to the i_mmap at all.
Therefore, we can just take the read lock and let other threads
searching for the right VMA share it in parallel. Once the right VMA is
found, either the PMD lock (2M huge page for x86-64) or the
mm->page_table_lock will be acquired to perform the actual PMD sharing.
Lock contention, if present, will happen in the spinlock. That is much
better than contention in the rwsem where the time needed to scan the
the interval tree is indeterminate.
With this patch applied, the customer is seeing significant performance
improvement over the unpatched kernel.
Link: http://lkml.kernel.org/r/20191107211809.9539-1-longman@redhat.com
Suggested-by: Mike Kravetz <mike.kravetz@oracle.com>
A new clang diagnostic (-Wsizeof-array-div) warns about the calculation
to determine the number of u32's in an array of unsigned longs.
Suppress warning by adding parentheses.
While looking at the above issue, noticed that the 'address' parameter
to hugetlb_fault_mutex_hash is no longer used. So, remove it from the
definition and all callers.
No functional change.
Link: http://lkml.kernel.org/r/20190919011847.18400-1-mike.kravetz@oracle.com
Reported-by: Nathan Chancellor <natechancellor@gmail.com>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
Reviewed-by: Davidlohr Bueso <dbueso@suse.de>
Cc: Nick Desaulniers <ndesaulniers@google.com>
Cc: Ilie Halip <ilie.halip@gmail.com>
Cc: David Bolvansky <david.bolvansky@gmail.com>
HugeTLB helper alloc_gigantic_page() implements fairly generic
allocation method where it scans over various zones looking for a large
contiguous pfn range before trying to allocate it with
alloc_contig_range().
Other than deriving the requested order from 'struct hstate', there is
nothing HugeTLB specific in there. This can be made available for
general use to allocate contiguous memory which could not have been
allocated through the buddy allocator.
alloc_gigantic_page() has been split carving out actual allocation
method which is then made available via new alloc_contig_pages() helper
wrapped under CONFIG_CONTIG_ALLOC. All references to 'gigantic' have
been replaced with more generic term 'contig'. Allocated pages here
should be freed with free_contig_range() or by calling __free_page() on
each allocated page.
Link: http://lkml.kernel.org/r/1571300646-32240-1-git-send-email-anshuman.khandual@arm.com
Signed-off-by: Anshuman Khandual <anshuman.khandual@arm.com>
Acked-by: David Hildenbrand <david@redhat.com>
Cc: Oscar Salvador <osalvador@suse.de>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Mike Rapoport <rppt@linux.ibm.com>
Cc: Pavel Tatashin <pavel.tatashin@microsoft.com>
Uninitialized memmaps contain garbage and in the worst case trigger
kernel BUGs, especially with CONFIG_PAGE_POISONING. They should not get
touched.
Let's make sure that we only consider online memory (managed by the
buddy) that has initialized memmaps. ZONE_DEVICE is not applicable.
page_zone() will call page_to_nid(), which will trigger
VM_BUG_ON_PGFLAGS(PagePoisoned(page), page) with CONFIG_PAGE_POISONING
and CONFIG_DEBUG_VM_PGFLAGS when called on uninitialized memmaps. This
can be the case when an offline memory block (e.g., never onlined) is
spanned by a zone.
Note: As explained by Michal in [1], alloc_contig_range() will verify
the range. So it boils down to the wrong access in this function.
[1] http://lkml.kernel.org/r/20180423000943.GO17484@dhcp22.suse.cz
Link: http://lkml.kernel.org/r/20191015120717.4858-1-david@redhat.com
Fixes: f1dd2cd13c4b ("mm, memory_hotplug: do not associate hotadded memory to zones until online") [visible after d0dc12e86b319]
Signed-off-by: David Hildenbrand <david@redhat.com>
Reported-by: Michal Hocko <mhocko@kernel.org>
Cc: Anshuman Khandual <anshuman.khandual@arm.com>
Cc: <stable@vger.kernel.org> [4.13+]
When allocating hugetlbfs pool pages via /proc/sys/vm/nr_hugepages, the
pages will be interleaved between all nodes of the system. If nodes are
not equal, it is quite possible for one node to fill up before the others.
When this happens, the code still attempts to allocate pages from the
full node. This results in calls to direct reclaim and compaction which
slow things down considerably.
When allocating pool pages, note the state of the previous allocation for
each node. If previous allocation failed, do not use the aggressive retry
algorithm on successive attempts. The allocation will still succeed if
there is memory available, but it will not try as hard to free up memory.
Link: http://lkml.kernel.org/r/20190806014744.15446-5-mike.kravetz@oracle.com
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Hillf Danton <hdanton@sina.com>
Li Wang discovered that LTP/move_page12 V2 sometimes triggers SIGBUS in
the kernel-v5.2.3 testing. This is caused by a race between hugetlb
page migration and page fault.
If a hugetlb page can not be allocated to satisfy a page fault, the task
is sent SIGBUS. This is normal hugetlbfs behavior. A hugetlb fault
mutex exists to prevent two tasks from trying to instantiate the same
page. This protects against the situation where there is only one
hugetlb page, and both tasks would try to allocate. Without the mutex,
one would fail and SIGBUS even though the other fault would be
successful.
There is a similar race between hugetlb page migration and fault.
Migration code will allocate a page for the target of the migration. It
will then unmap the original page from all page tables. It does this
unmap by first clearing the pte and then writing a migration entry. The
page table lock is held for the duration of this clear and write
operation. However, the beginnings of the hugetlb page fault code
optimistically checks the pte without taking the page table lock. If
clear (as it can be during the migration unmap operation), a hugetlb
page allocation is attempted to satisfy the fault. Note that the page
which will eventually satisfy this fault was already allocated by the
migration code. However, the allocation within the fault path could
fail which would result in the task incorrectly being sent SIGBUS.
Ideally, we could take the hugetlb fault mutex in the migration code
when modifying the page tables. However, locks must be taken in the
order of hugetlb fault mutex, page lock, page table lock. This would
require significant rework of the migration code. Instead, the issue is
addressed in the hugetlb fault code. After failing to allocate a huge
page, take the page table lock and check for huge_pte_none before
returning an error. This is the same check that must be made further in
the code even if page allocation is successful.
Link: http://lkml.kernel.org/r/20190808000533.7701-1-mike.kravetz@oracle.com
Fixes: 290408d4a250 ("hugetlb: hugepage migration core")
Reported-by: Li Wang <liwang@redhat.com>
Tested-by: Li Wang <liwang@redhat.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Cyril Hrubis <chrubis@suse.cz>
Cc: Xishi Qiu <xishi.qiuxishi@alibaba-inc.com>
madvise(MADV_SOFT_OFFLINE) often returns -EBUSY when calling soft offline
for hugepages with overcommitting enabled. That was caused by the
suboptimal code in current soft-offline code. See the following part:
ret = migrate_pages(&pagelist, new_page, NULL, MPOL_MF_MOVE_ALL,
MIGRATE_SYNC, MR_MEMORY_FAILURE);
if (ret) {
} else {
* We set PG_hwpoison only when the migration source hugepage
* was successfully dissolved, because otherwise hwpoisoned
* hugepage remains on free hugepage list, then userspace will
* find it as SIGBUS by allocation failure. That's not expected
* in soft-offlining.
ret = dissolve_free_huge_page(page);
if (!ret) {
if (set_hwpoison_free_buddy_page(page))
num_poisoned_pages_inc();
return ret;
Here dissolve_free_huge_page() returns -EBUSY if the migration source page
was freed into buddy in migrate_pages(), but even in that case we actually
has a chance that set_hwpoison_free_buddy_page() succeeds. So that means
current code gives up offlining too early now.
dissolve_free_huge_page() checks that a given hugepage is suitable for
dissolving, where we should return success for !PageHuge() case because
the given hugepage is considered as already dissolved.
This change also affects other callers of dissolve_free_huge_page(), which
are cleaned up together.
[n-horiguchi@ah.jp.nec.com: v3]
Link: http://lkml.kernel.org/r/1560761476-4651-3-git-send-email-n-horiguchi@ah.jp.nec.comLink: http://lkml.kernel.org/r/1560154686-18497-3-git-send-email-n-horiguchi@ah.jp.nec.com
Fixes: 6bc9b56433b76 ("mm: fix race on soft-offlining")
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reported-by: Chen, Jerry T <jerry.t.chen@intel.com>
Tested-by: Chen, Jerry T <jerry.t.chen@intel.com>
Reviewed-by: Oscar Salvador <osalvador@suse.de>
Cc: "Chen, Jerry T" <jerry.t.chen@intel.com>
Cc: "Zhuo, Qiuxu" <qiuxu.zhuo@intel.com>
Cc: <stable@vger.kernel.org> [4.19+]
Add SPDX license identifiers to all files which:
- Have no license information of any form
- Have EXPORT_.*_SYMBOL_GPL inside which was used in the
initial scan/conversion to ignore the file
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
Continuing discussion about 58b6e5e8f1ad ("hugetlbfs: fix memory leak for
resv_map") brought up the issue that inode->i_mapping may not point to the
address space embedded within the inode at inode eviction time. The
hugetlbfs truncate routine handles this by explicitly using inode->i_data.
However, code cleaning up the resv_map will still use the address space
pointed to by inode->i_mapping. Luckily, private_data is NULL for address
spaces in all such cases today but, there is no guarantee this will
continue.
Change all hugetlbfs code getting a resv_map pointer to explicitly get it
from the address space embedded within the inode. In addition, add more
comments in the code to indicate why this is being done.
Link: http://lkml.kernel.org/r/20190419204435.16984-1-mike.kravetz@oracle.com
Reported-by: Yufen Yu <yuyufen@huawei.com>
This updates each existing invalidation to use the correct mmu notifier
event that represent what is happening to the CPU page table. See the
patch which introduced the events to see the rational behind this.
Link: http://lkml.kernel.org/r/20190326164747.24405-7-jglisse@redhat.com
Signed-off-by: Jérôme Glisse <jglisse@redhat.com>
Reviewed-by: Ralph Campbell <rcampbell@nvidia.com>
Reviewed-by: Ira Weiny <ira.weiny@intel.com>
Cc: Christian König <christian.koenig@amd.com>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: Rodrigo Vivi <rodrigo.vivi@intel.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Peter Xu <peterx@redhat.com>
Cc: Felix Kuehling <Felix.Kuehling@amd.com>
Cc: Jason Gunthorpe <jgg@mellanox.com>
Cc: Ross Zwisler <zwisler@kernel.org>
Cc: Radim Krcmar <rkrcmar@redhat.com>
Cc: Christian Koenig <christian.koenig@amd.com>
Cc: John Hubbard <jhubbard@nvidia.com>
CPU page table update can happens for many reasons, not only as a result
of a syscall (munmap(), mprotect(), mremap(), madvise(), ...) but also as
a result of kernel activities (memory compression, reclaim, migration,
Users of mmu notifier API track changes to the CPU page table and take
specific action for them. While current API only provide range of virtual
address affected by the change, not why the changes is happening.
This patchset do the initial mechanical convertion of all the places that
calls mmu_notifier_range_init to also provide the default MMU_NOTIFY_UNMAP
event as well as the vma if it is know (most invalidation happens against
a given vma). Passing down the vma allows the users of mmu notifier to
inspect the new vma page protection.
The MMU_NOTIFY_UNMAP is always the safe default as users of mmu notifier
should assume that every for the range is going away when that event
happens. A latter patch do convert mm call path to use a more appropriate
events for each call.
This is done as 2 patches so that no call site is forgotten especialy
as it uses this following coccinelle patch:
identifier I1, I2, I3, I4;
static inline void mmu_notifier_range_init(struct mmu_notifier_range *I1,
+enum mmu_notifier_event event,
+unsigned flags,
+struct vm_area_struct *vma,
struct mm_struct *I2, unsigned long I3, unsigned long I4) { ... }
-#define mmu_notifier_range_init(range, mm, start, end)
+#define mmu_notifier_range_init(range, event, flags, vma, mm, start, end)
expression E1, E3, E4;
identifier I1;
mmu_notifier_range_init(E1,
+MMU_NOTIFY_UNMAP, 0, I1,
I1->vm_mm, E3, E4)
expression E1, E2, E3, E4;
identifier FN, VMA;
FN(..., struct vm_area_struct *VMA, ...) {
+MMU_NOTIFY_UNMAP, 0, VMA,
E2, E3, E4)
identifier FN, VMA;
FN(...) {
struct vm_area_struct *VMA;
E2, E3, E4)
identifier FN;
FN(...) {
+MMU_NOTIFY_UNMAP, 0, NULL,
E2, E3, E4)
Applied with:
spatch --all-includes --sp-file mmu-notifier.spatch fs/proc/task_mmu.c --in-place
spatch --sp-file mmu-notifier.spatch --dir kernel/events/ --in-place
spatch --sp-file mmu-notifier.spatch --dir mm --in-place
Link: http://lkml.kernel.org/r/20190326164747.24405-6-jglisse@redhat.com
hugetlb uses a fault mutex hash table to prevent page faults of the
same pages concurrently. The key for shared and private mappings is
different. Shared keys off address_space and file index. Private keys
off mm and virtual address. Consider a private mappings of a populated
hugetlbfs file. A fault will map the page from the file and if needed
do a COW to map a writable page.
Hugetlbfs hole punch uses the fault mutex to prevent mappings of file
pages. It uses the address_space file index key. However, private
mappings will use a different key and could race with this code to map
the file page. This causes problems (BUG) for the page cache remove
code as it expects the page to be unmapped. A sample stack is:
page dumped because: VM_BUG_ON_PAGE(page_mapped(page))
kernel BUG at mm/filemap.c:169!
RIP: 0010:unaccount_page_cache_page+0x1b8/0x200
Call Trace:
__delete_from_page_cache+0x39/0x220
delete_from_page_cache+0x45/0x70
remove_inode_hugepages+0x13c/0x380
? __add_to_page_cache_locked+0x162/0x380
hugetlbfs_fallocate+0x403/0x540
? _cond_resched+0x15/0x30
? __inode_security_revalidate+0x5d/0x70
? selinux_file_permission+0x100/0x130
vfs_fallocate+0x13f/0x270
ksys_fallocate+0x3c/0x80
__x64_sys_fallocate+0x1a/0x20
do_syscall_64+0x5b/0x180
entry_SYSCALL_64_after_hwframe+0x44/0xa9
There seems to be another potential COW issue/race with this approach
of different private and shared keys as noted in commit 8382d914ebf7
("mm, hugetlb: improve page-fault scalability").
Since every hugetlb mapping (even anon and private) is actually a file
mapping, just use the address_space index key for all mappings. This
results in potentially more hash collisions. However, this should not
be the common case.
Link: http://lkml.kernel.org/r/20190328234704.27083-3-mike.kravetz@oracle.com
Link: http://lkml.kernel.org/r/20190412165235.t4sscoujczfhuiyt@linux-r8p5
Fixes: b5cec28d36f5 ("hugetlbfs: truncate_hugepages() takes a range of pages")
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
When a huge page is allocated, PagePrivate() is set if the allocation
consumed a reservation. When freeing a huge page, PagePrivate is checked.
If set, it indicates the reservation should be restored. PagePrivate
being set at free huge page time mostly happens on error paths.
When huge page reservations are created, a check is made to determine if
the mapping is associated with an explicitly mounted filesystem. If so,
pages are also reserved within the filesystem. The default action when
freeing a huge page is to decrement the usage count in any associated
explicitly mounted filesystem. However, if the reservation is to be
restored the reservation/use count within the filesystem should not be
decrementd. Otherwise, a subsequent page allocation and free for the same
mapping location will cause the file filesystem usage to go 'negative'.
Filesystem Size Used Avail Use% Mounted on
nodev 4.0G -4.0M 4.1G - /opt/hugepool
To fix, when freeing a huge page do not adjust filesystem usage if
PagePrivate() is set to indicate the reservation should be restored.
I did not cc stable as the problem has been around since reserves were
added to hugetlbfs and nobody has noticed.
Link: http://lkml.kernel.org/r/20190328234704.27083-2-mike.kravetz@oracle.com
NODEMASK_ALLOC is used to allocate a nodemask bitmap, and it does it by
first determining whether it should be allocated on the stack or
dynamically, depending on NODES_SHIFT. Right now, it goes the dynamic
path whenever the nodemask_t is above 32 bytes.
Although we could bump it to a reasonable value, the largest a nodemask_t
can get is 128 bytes, so since __nr_hugepages_store_common is called from
a rather short stack we can just get rid of the NODEMASK_ALLOC call here.
This reduces some code churn and complexity.
Link: http://lkml.kernel.org/r/20190402133415.21983-1-osalvador@suse.de
Signed-off-by: Oscar Salvador <osalvador@suse.de>
Cc: Alex Ghiti <alex@ghiti.fr>
Cc: Jing Xiangfeng <jingxiangfeng@huawei.com>
The number of node specific huge pages can be set via a file such as:
/sys/devices/system/node/node1/hugepages/hugepages-2048kB/nr_hugepages
When a node specific value is specified, the global number of huge pages
must also be adjusted. This adjustment is calculated as the specified
node specific value + (global value - current node value). If the node
specific value provided by the user is large enough, this calculation
could overflow an unsigned long leading to a smaller than expected number
of huge pages.
To fix, check the calculation for overflow. If overflow is detected, use
ULONG_MAX as the requested value. This is inline with the user request to
allocate as many huge pages as possible.
It was also noticed that the above calculation was done outside the
hugetlb_lock. Therefore, the values could be inconsistent and result in
underflow. To fix, the calculation is moved within the routine
set_max_huge_pages() where the lock is held.
In addition, the code in __nr_hugepages_store_common() which tries to
handle the case of not being able to allocate a node mask would likely
result in incorrect behavior. Luckily, it is very unlikely we will ever
take this path. If we do, simply return ENOMEM.
Link: http://lkml.kernel.org/r/20190328220533.19884-1-mike.kravetz@oracle.com
Reported-by: Jing Xiangfeng <jingxiangfeng@huawei.com>
On systems without CONTIG_ALLOC activated but that support gigantic pages,
boottime reserved gigantic pages can not be freed at all. This patch
simply enables the possibility to hand back those pages to memory
allocator.
Link: http://lkml.kernel.org/r/20190327063626.18421-5-alex@ghiti.fr
Signed-off-by: Alexandre Ghiti <alex@ghiti.fr>
Acked-by: David S. Miller <davem@davemloft.net> [sparc]
Cc: Andy Lutomirsky <luto@kernel.org>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: "H . Peter Anvin" <hpa@zytor.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Rich Felker <dalias@libc.org>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
spinlock recursion happened when do LTP test:
#!/bin/bash
./runltp -p -f hugetlb &
The dtor returned by get_compound_page_dtor in __put_compound_page may be
the function of free_huge_page which will lock the hugetlb_lock, so don't
put_page in lock of hugetlb_lock.
BUG: spinlock recursion on CPU#0, hugemmap05/1079
lock: hugetlb_lock+0x0/0x18, .magic: dead4ead, .owner: hugemmap05/1079, .owner_cpu: 0
Call trace:
dump_backtrace+0x0/0x198
show_stack+0x24/0x30
dump_stack+0xa4/0xcc
spin_dump+0x84/0xa8
do_raw_spin_lock+0xd0/0x108
_raw_spin_lock+0x20/0x30
free_huge_page+0x9c/0x260
__put_compound_page+0x44/0x50
__put_page+0x2c/0x60
alloc_surplus_huge_page.constprop.19+0xf0/0x140
hugetlb_acct_memory+0x104/0x378
hugetlb_reserve_pages+0xe0/0x250
hugetlbfs_file_mmap+0xc0/0x140
mmap_region+0x3e8/0x5b0
do_mmap+0x280/0x460
vm_mmap_pgoff+0xf4/0x128
ksys_mmap_pgoff+0xb4/0x258
__arm64_sys_mmap+0x34/0x48
el0_svc_common+0x78/0x130
el0_svc_handler+0x38/0x78
el0_svc+0x8/0xc
Link: http://lkml.kernel.org/r/b8ade452-2d6b-0372-32c2-703644032b47@huawei.com
Fixes: 9980d744a0 ("mm, hugetlb: get rid of surplus page accounting tricks")
Signed-off-by: Kai Shen <shenkai8@huawei.com>
Signed-off-by: Feilong Lin <linfeilong@huawei.com>
Reported-by: Wang Wang <wangwang2@huawei.com>
Pull unified TLB flushing from Ingo Molnar:
"This contains the generic mmu_gather feature from Peter Zijlstra,
which is an all-arch unification of TLB flushing APIs, via the
following (broad) steps:
- enhance the <asm-generic/tlb.h> APIs to cover more arch details
- convert most TLB flushing arch implementations to the generic
<asm-generic/tlb.h> APIs.
- remove leftovers of per arch implementations
After this series every single architecture makes use of the unified
TLB flushing APIs"
* 'core-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
mm/resource: Use resource_overlaps() to simplify region_intersects()
ia64/tlb: Eradicate tlb_migrate_finish() callback
asm-generic/tlb: Remove tlb_table_flush()
asm-generic/tlb: Remove tlb_flush_mmu_free()
asm-generic/tlb: Remove CONFIG_HAVE_GENERIC_MMU_GATHER
asm-generic/tlb: Remove arch_tlb*_mmu()
s390/tlb: Convert to generic mmu_gather
asm-generic/tlb: Introduce CONFIG_HAVE_MMU_GATHER_NO_GATHER=y
arch/tlb: Clean up simple architectures
um/tlb: Convert to generic mmu_gather
sh/tlb: Convert SH to generic mmu_gather
ia64/tlb: Convert to generic mmu_gather
arm/tlb: Convert to generic mmu_gather
asm-generic/tlb, arch: Invert CONFIG_HAVE_RCU_TABLE_INVALIDATE
asm-generic/tlb, ia64: Conditionally provide tlb_migrate_finish()
asm-generic/tlb: Provide generic tlb_flush() based on flush_tlb_mm()
asm-generic/tlb, arch: Provide generic tlb_flush() based on flush_tlb_range()
asm-generic/tlb, arch: Provide generic VIPT cache flush
asm-generic/tlb, arch: Provide CONFIG_HAVE_MMU_GATHER_PAGE_SIZE
asm-generic/tlb: Provide a comment
Merge page ref overflow branch.
Jann Horn reported that he can overflow the page ref count with
sufficient memory (and a filesystem that is intentionally extremely
slow).
Admittedly it's not exactly easy. To have more than four billion
references to a page requires a minimum of 32GB of kernel memory just
for the pointers to the pages, much less any metadata to keep track of
those pointers. Jann needed a total of 140GB of memory and a specially
crafted filesystem that leaves all reads pending (in order to not ever
free the page references and just keep adding more).
Still, we have a fairly straightforward way to limit the two obvious
user-controllable sources of page references: direct-IO like page
references gotten through get_user_pages(), and the splice pipe page
duplication. So let's just do that.
* branch page-refs:
fs: prevent page refcount overflow in pipe_buf_get
mm: prevent get_user_pages() from overflowing page refcount
mm: add 'try_get_page()' helper function
mm: make page ref count overflow check tighter and more explicit
If the page refcount wraps around past zero, it will be freed while
there are still four billion references to it. One of the possible
avenues for an attacker to try to make this happen is by doing direct IO
on a page multiple times. This patch makes get_user_pages() refuse to
take a new page reference if there are already more than two billion
references to the page.
Reported-by: Jann Horn <jannh@google.com>
Cc: stable@kernel.org
Move the mmu_gather::page_size things into the generic code instead of
PowerPC specific bits.
No change in behavior intended.
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Nick Piggin <npiggin@gmail.com>
This patch updates get_user_pages_longterm to migrate pages allocated
out of CMA region. This makes sure that we don't keep non-movable pages
(due to page reference count) in the CMA area.
This will be used by ppc64 in a later patch to avoid pinning pages in
the CMA region. ppc64 uses CMA region for allocation of the hardware
page table (hash page table) and not able to migrate pages out of CMA
region results in page table allocation failures.
One case where we hit this easy is when a guest using a VFIO passthrough
device. VFIO locks all the guest's memory and if the guest memory is
backed by CMA region, it becomes unmovable resulting in fragmenting the
CMA and possibly preventing other guests from allocation a large enough
hash page table.
NOTE: We allocate the new page without using __GFP_THISNODE
Link: http://lkml.kernel.org/r/20190114095438.32470-3-aneesh.kumar@linux.ibm.com
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com>
Cc: Alexey Kardashevskiy <aik@ozlabs.ru>
Cc: David Gibson <david@gibson.dropbear.id.au>
Architectures like ppc64 require to do a conditional tlb flush based on
the old and new value of pte. Follow the regular pte change protection
sequence for hugetlb too. This allows the architectures to override the
update sequence.
Link: http://lkml.kernel.org/r/20190116085035.29729-5-aneesh.kumar@linux.ibm.com
Reviewed-by: Michael Ellerman <mpe@ellerman.id.au>
Cc: Nicholas Piggin <npiggin@gmail.com>
Patch series "arm64/mm: Enable HugeTLB migration", v4.
This patch series enables HugeTLB migration support for all supported
huge page sizes at all levels including contiguous bit implementation.
Following HugeTLB migration support matrix has been enabled with this
patch series. All permutations have been tested except for the 16GB.
CONT PTE PMD CONT PMD PUD
4K: 64K 2M 32M 1G
16K: 2M 32M 1G
64K: 2M 512M 16G
First the series adds migration support for PUD based huge pages. It
then adds a platform specific hook to query an architecture if a given
huge page size is supported for migration while also providing a default
fallback option preserving the existing semantics which just checks for
(PMD|PUD|PGDIR)_SHIFT macros. The last two patches enables HugeTLB
migration on arm64 and subscribe to this new platform specific hook by
defining an override.
The second patch differentiates between movability and migratability
aspects of huge pages and implements hugepage_movable_supported() which
can then be used during allocation to decide whether to place the huge
page in movable zone or not.
This patch (of 5):
During huge page allocation it's migratability is checked to determine
if it should be placed under movable zones with GFP_HIGHUSER_MOVABLE.
But the movability aspect of the huge page could depend on other factors
than just migratability. Movability in itself is a distinct property
which should not be tied with migratability alone.
This differentiates these two and implements an enhanced movability check
which also considers huge page size to determine if it is feasible to be
placed under a movable zone. At present it just checks for gigantic pages
but going forward it can incorporate other enhanced checks.
Link: http://lkml.kernel.org/r/1545121450-1663-2-git-send-email-anshuman.khandual@arm.com
Reviewed-by: Steve Capper <steve.capper@arm.com>
Suggested-by: Michal Hocko <mhocko@kernel.org>
Patch series "Replace all open encodings for NUMA_NO_NODE", v3.
All these places for replacement were found by running the following
grep patterns on the entire kernel code. Please let me know if this
might have missed some instances. This might also have replaced some
false positives. I will appreciate suggestions, inputs and review.
1. git grep "nid == -1"
2. git grep "node == -1"
3. git grep "nid = -1"
4. git grep "node = -1"
This patch (of 2):
At present there are multiple places where invalid node number is
encoded as -1. Even though implicitly understood it is always better to
have macros in there. Replace these open encodings for an invalid node
number with the global macro NUMA_NO_NODE. This helps remove NUMA
related assumptions like 'invalid node' from various places redirecting
them to a common definition.
Link: http://lkml.kernel.org/r/1545127933-10711-2-git-send-email-anshuman.khandual@arm.com
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> [ixgbe]
Acked-by: Jens Axboe <axboe@kernel.dk> [mtip32xx]
Acked-by: Vinod Koul <vkoul@kernel.org> [dmaengine.c]
Acked-by: Michael Ellerman <mpe@ellerman.id.au> [powerpc]
Acked-by: Doug Ledford <dledford@redhat.com> [drivers/infiniband]
Cc: Joseph Qi <jiangqi903@gmail.com>
Cc: Hans Verkuil <hverkuil@xs4all.nl>
hugetlb pages should only be migrated if they are 'active'. The
routines set/clear_page_huge_active() modify the active state of hugetlb
pages.
When a new hugetlb page is allocated at fault time, set_page_huge_active
is called before the page is locked. Therefore, another thread could
race and migrate the page while it is being added to page table by the
fault code. This race is somewhat hard to trigger, but can be seen by
strategically adding udelay to simulate worst case scheduling behavior.
Depending on 'how' the code races, various BUG()s could be triggered.
To address this issue, simply delay the set_page_huge_active call until
after the page is successfully added to the page table.
Hugetlb pages can also be leaked at migration time if the pages are
associated with a file in an explicitly mounted hugetlbfs filesystem.
For example, consider a two node system with 4GB worth of huge pages
available. A program mmaps a 2G file in a hugetlbfs filesystem. It
then migrates the pages associated with the file from one node to
another. When the program exits, huge page counts are as follows:
node0
1024 free_hugepages
1024 nr_hugepages
node1
0 free_hugepages
1024 nr_hugepages
nodev 4.0G 2.0G 2.0G 50% /var/opt/hugepool
That is as expected. 2G of huge pages are taken from the free_hugepages
counts, and 2G is the size of the file in the explicitly mounted
filesystem. If the file is then removed, the counts become:
node0
1024 free_hugepages
1024 nr_hugepages
node1
1024 free_hugepages
1024 nr_hugepages
Note that the filesystem still shows 2G of pages used, while there
actually are no huge pages in use. The only way to 'fix' the filesystem
accounting is to unmount the filesystem
If a hugetlb page is associated with an explicitly mounted filesystem,
this information in contained in the page_private field. At migration
time, this information is not preserved. To fix, simply transfer
page_private from old to new page at migration time if necessary.
There is a related race with removing a huge page from a file and
migration. When a huge page is removed from the pagecache, the
page_mapping() field is cleared, yet page_private remains set until the
page is actually freed by free_huge_page(). A page could be migrated
while in this state. However, since page_mapping() is not set the
hugetlbfs specific routine to transfer page_private is not called and we
leak the page count in the filesystem.
To fix that, check for this condition before migrating a huge page. If
the condition is detected, return EBUSY for the page.
Link: http://lkml.kernel.org/r/74510272-7319-7372-9ea6-ec914734c179@oracle.com
Link: http://lkml.kernel.org/r/20190212221400.3512-1-mike.kravetz@oracle.com
Fixes: bcc54222309c ("mm: hugetlb: introduce page_huge_active")
[mike.kravetz@oracle.com: v2]
Link: http://lkml.kernel.org/r/7534d322-d782-8ac6-1c8d-a8dc380eb3ab@oracle.com
[mike.kravetz@oracle.com: update comment and changelog]
Link: http://lkml.kernel.org/r/420bcfd6-158b-38e4-98da-26d0cd85bd01@oracle.com
hugetlb needs the same fix as faultin_nopage (which was applied in
commit 96312e61282a ("mm/gup.c: teach get_user_pages_unlocked to handle
FOLL_NOWAIT")) or KVM hangs because it thinks the mmap_sem was already
released by hugetlb_fault() if it returned VM_FAULT_RETRY, but it wasn't
in the FOLL_NOWAIT case.
Link: http://lkml.kernel.org/r/20190109020203.26669-2-aarcange@redhat.com
Fixes: ce53053ce378 ("kvm: switch get_user_page_nowait() to get_user_pages_unlocked()")
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Reported-by: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
Reviewed-by: Peter Xu <peterx@redhat.com>
