commit 888cf2db475a256fb0cda042140f73d7881f81fe upstream.
If a page is marked for immediate reclaim then it is moved to the tail of
the LRU list. This occurs when the system is under enough memory pressure
for pages under writeback to reach the end of the LRU but we test for this
using atomic operations on every writeback. This patch uses an optimistic
non-atomic test first. It'll miss some pages in rare cases but the
consequences are not severe enough to warrant such a penalty.
While the function does not dominate profiles during a simple dd test the
cost of it is reduced.
73048 0.7428 vmlinux-3.15.0-rc5-mmotm-20140513 end_page_writeback
23740 0.2409 vmlinux-3.15.0-rc5-lessatomic end_page_writeback
possible
commit 2457aec63745e235bcafb7ef312b182d8682f0fc upstream.
aops->write_begin may allocate a new page and make it visible only to have
mark_page_accessed called almost immediately after. Once the page is
visible the atomic operations are necessary which is noticable overhead
when writing to an in-memory filesystem like tmpfs but should also be
noticable with fast storage. The objective of the patch is to initialse
the accessed information with non-atomic operations before the page is
visible.
The bulk of filesystems directly or indirectly use
grab_cache_page_write_begin or find_or_create_page for the initial
allocation of a page cache page. This patch adds an init_page_accessed()
helper which behaves like the first call to mark_page_accessed() but may
called before the page is visible and can be done non-atomically.
The primary APIs of concern in this care are the following and are used
by most filesystems.
find_get_page
find_lock_page
find_or_create_page
grab_cache_page_nowait
All of them are very similar in detail to the patch creates a core helper
pagecache_get_page() which takes a flags parameter that affects its
behavior such as whether the page should be marked accessed or not. Then
old API is preserved but is basically a thin wrapper around this core
function.
Each of the filesystems are then updated to avoid calling
mark_page_accessed when it is known that the VM interfaces have already
done the job. There is a slight snag in that the timing of the
mark_page_accessed() has now changed so in rare cases it's possible a page
gets to the end of the LRU as PageReferenced where as previously it might
have been repromoted. This is expected to be rare but it's worth the
filesystem people thinking about it in case they see a problem with the
timing change. It is also the case that some filesystems may be marking
pages accessed that previously did not but it makes sense that filesystems
have consistent behaviour in this regard.
The test case used to evaulate this is a simple dd of a large file done
multiple times with the file deleted on each iterations. The size of the
file is 1/10th physical memory to avoid dirty page balancing. In the
async case it will be possible that the workload completes without even
hitting the disk and will have variable results but highlight the impact
of mark_page_accessed for async IO. The sync results are expected to be
more stable. The exception is tmpfs where the normal case is for the "IO"
to not hit the disk.
The test machine was single socket and UMA to avoid any scheduling or NUMA
artifacts. Throughput and wall times are presented for sync IO, only wall
times are shown for async as the granularity reported by dd and the
variability is unsuitable for comparison. As async results were variable
do to writback timings, I'm only reporting the maximum figures. The sync
results were stable enough to make the mean and stddev uninteresting.
The performance results are reported based on a run with no profiling.
Profile data is based on a separate run with oprofile running.
async dd
3.15.0-rc3 3.15.0-rc3
vanilla accessed-v2
ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%)
tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%)
btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%)
ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%)
xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%)
The XFS figure is a bit strange as it managed to avoid a worst case by
sheer luck but the average figures looked reasonable.
samples percentage
ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
[akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer]
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
commit 9e8c2af96e0d2d5fe298dd796fb6bc16e888a48d upstream.
... it does that itself (via kmap_atomic())
commit 67f9fd91f93c582b7de2ab9325b6e179db77e4d5 upstream.
This patch removes read_cache_page_async() which wasn't really needed
anywhere and simplifies the code around it a bit.
read_cache_page_async() is useful when we want to read a page into the
cache without waiting for it to complete. This happens when the
appropriate callback 'filler' doesn't complete its read operation and
releases the page lock immediately, and instead queues a different
completion routine to do that. This never actually happened anywhere in
the code.
read_cache_page_async() had 3 different callers:
- read_cache_page() which is the sync version, it would just wait for
the requested read to complete using wait_on_page_read().
- JFFS2 would call it from jffs2_gc_fetch_page(), but the filler
function it supplied doesn't do any async reads, and would complete
before the filler function returns - making it actually a sync read.
- CRAMFS would call it using the read_mapping_page_async() wrapper, with
a similar story to JFFS2 - the filler function doesn't do anything that
reminds async reads and would always complete before the filler function
returns.
To sum it up, the code in mm/filemap.c never took advantage of having
read_cache_page_async(). While there are filler callbacks that do async
reads (such as the block one), we always called it with the
read_cache_page().
This patch adds a mandatory wait for read to complete when adding a new
page to the cache, and removes read_cache_page_async() and its wrappers.
commit 0cd6144aadd2afd19d1aca880153530c52957604 upstream.
shmem mappings already contain exceptional entries where swap slot
information is remembered.
To be able to store eviction information for regular page cache, prepare
every site dealing with the radix trees directly to handle entries other
than pages.
The common lookup functions will filter out non-page entries and return
NULL for page cache holes, just as before. But provide a raw version of
the API which returns non-page entries as well, and switch shmem over to
use it.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
commit e7b563bb2a6f4d974208da46200784b9c5b5a47e upstream.
The radix tree hole searching code is only used for page cache, for
example the readahead code trying to get a a picture of the area
surrounding a fault.
It sufficed to rely on the radix tree definition of holes, which is
"empty tree slot". But this is about to change, though, as shadow page
descriptors will be stored in the page cache after the actual pages get
evicted from memory.
Move the functions over to mm/filemap.c and make them native page cache
operations, where they can later be adapted to handle the new definition
of "page cache hole".
commit 7fcbbaf18392f0b17c95e2f033c8ccf87eecde1d upstream.
In some testing I ran today (some fio jobs that spread over two nodes),
we end up spending 40% of the time in filemap_check_errors(). That
smells fishy. Looking further, this is basically what happens:
blkdev_aio_read()
generic_file_aio_read()
filemap_write_and_wait_range()
if (!mapping->nr_pages)
and filemap_check_errors() always attempts two test_and_clear_bit() on
the mapping flags, thus dirtying it for every single invocation. The
patch below tests each of these bits before clearing them, avoiding this
issue. In my test case (4-socket box), performance went from 1.7M IOPS
to 4.0M IOPS.
Signed-off-by: Jens Axboe <axboe@fb.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
commit d26914d11751b23ca2e8747725f2cae10c2f2c1b upstream.
Since put_mems_allowed() is strictly optional, its a seqcount retry, we
don't need to evaluate the function if the allocation was in fact
successful, saving a smp_rmb some loads and comparisons on some relative
fast-paths.
Since the naming, get/put_mems_allowed() does suggest a mandatory
pairing, rename the interface, as suggested by Mel, to resemble the
seqcount interface.
This gives us: read_mems_allowed_begin() and read_mems_allowed_retry(),
where it is important to note that the return value of the latter call
is inverted from its previous incarnation.
Commit 3812c8c8f395 ("mm: memcg: do not trap chargers with full
callstack on OOM") assumed that only a few places that can trigger a
memcg OOM situation do not return VM_FAULT_OOM, like optional page cache
readahead. But there are many more and it's impractical to annotate
them all.
First of all, we don't want to invoke the OOM killer when the failed
allocation is gracefully handled, so defer the actual kill to the end of
the fault handling as well. This simplifies the code quite a bit for
added bonus.
Second, since a failed allocation might not be the abrupt end of the
fault, the memcg OOM handler needs to be re-entrant until the fault
finishes for subsequent allocation attempts. If an allocation is
attempted after the task already OOMed, allow it to bypass the limit so
that it can quickly finish the fault and invoke the OOM killer.
Reported-by: azurIt <azurit@pobox.sk>
Cc: <stable@kernel.org>
Make add_to_page_cache_locked() cleaner:
- unindent most code of the function by inverting one condition;
- streamline code no-error path;
- move insert error path outside normal code path;
- call radix_tree_preload_end() earlier;
No functional changes.
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Hillf Danton <dhillf@gmail.com>
System calls and kernel faults (uaccess, gup) can handle an out of memory
situation gracefully and just return -ENOMEM.
Enable the memcg OOM killer only for user faults, where it's really the
only option available.
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: azurIt <azurit@pobox.sk>
With users of radix_tree_preload() run from interrupt (block/blk-ioc.c is
one such possible user), the following race can happen:
radix_tree_insert()
radix_tree_node_alloc()
if (rtp->nr) {
ret = rtp->nodes[rtp->nr - 1];
<interrupt>
radix_tree_insert()
if (rtp->nr) {
And we give out one radix tree node twice. That clearly results in radix
tree corruption with different results (usually OOPS) depending on which
two users of radix tree race.
We fix the problem by making radix_tree_node_alloc() always allocate fresh
radix tree nodes when in interrupt. Using preloading when in interrupt
doesn't make sense since all the allocations have to be atomic anyway and
we cannot steal nodes from process-context users because some users rely
on radix_tree_insert() succeeding after radix_tree_preload().
in_interrupt() check is somewhat ugly but we cannot simply key off passed
gfp_mask as that is acquired from root_gfp_mask() and thus the same for
all preload users.
Another part of the fix is to avoid node preallocation in
radix_tree_preload() when passed gfp_mask doesn't allow waiting. Again,
preallocation in such case doesn't make sense and when preallocation would
happen in interrupt we could possibly leak some allocated nodes. However,
some users of radix_tree_preload() require following radix_tree_insert()
to succeed. To avoid unexpected effects for these users,
radix_tree_preload() only warns if passed gfp mask doesn't allow waiting
and we provide a new function radix_tree_maybe_preload() for those users
which get different gfp mask from different call sites and which are
prepared to handle radix_tree_insert() failure.
Cc: Jens Axboe <jaxboe@fusionio.com>
Call generic_write_sync() from the deferred I/O completion handler if
O_DSYNC is set for a write request. Also make sure various callers
don't call generic_write_sync if the direct I/O code returns
-EIOCBQUEUED.
Based on an earlier patch from Jan Kara <jack@suse.cz> with updates from
Jeff Moyer <jmoyer@redhat.com> and Darrick J. Wong <darrick.wong@oracle.com>.
These VM_<READfoo> macros aren't used very often and three of them
aren't used at all.
Expand the ones that are used in-place, and remove all the now unused
#define VM_<foo> macros.
VM_READHINTMASK, VM_NormalReadHint and VM_ClearReadHint were added just
before 2.4 and appears have never been used.
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
There are two convenient ways to report errors to userspace
1) retun error to original syscall for example write(2)
2) mark mapping with error flag and return it on later fsync(2)
Second one is broken if (mapping->nrpages == 0) This is real-life
situation because after error pages are likey to be truncated or
invalidated.
We have to return an error regardless to number of pages in the mapping.
#Original testcase: git@github.com:dmonakhov/xfstests.git
MOUNT_OPTIONS="-b1024"
./check shared/305
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Use the events API to trace filemap loading and unloading of file pieces
into the page cache.
This patch aims at tracing the eviction reload cycle of executable and
shared libraries pages in a memory constrained environment.
The typical usage is to spot a specific device and inode (for example
/lib/libc.so) to see the eviction cycles, and find out if frequently
used code is rather spread across many pages (bad) or coallesced (good).
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
Create a helper function to check if a backing device requires stable
page writes and, if so, performs the necessary wait. Then, make it so
that all points in the memory manager that handle making pages writable
use the helper function. This should provide stable page write support
to most filesystems, while eliminating unnecessary waiting for devices
that don't require the feature.
Before this patchset, all filesystems would block, regardless of whether
or not it was necessary. ext3 would wait, but still generate occasional
checksum errors. The network filesystems were left to do their own
thing, so they'd wait too.
After this patchset, all the disk filesystems except ext3 and btrfs will
wait only if the hardware requires it. ext3 (if necessary) snapshots
pages instead of blocking, and btrfs provides its own bdi so the mm will
never wait. Network filesystems haven't been touched, so either they
provide their own stable page guarantees or they don't block at all.
The blocking behavior is back to what it was before 3.0 if you don't
have a disk requiring stable page writes.
Here's the result of using dbench to test latency on ext2:
3.8.0-rc3:
Operation Count AvgLat MaxLat
WriteX 109347 0.028 59.817
ReadX 347180 0.004 3.391
Flush 15514 29.828 287.283
Throughput 57.429 MB/sec 4 clients 4 procs max_latency=287.290 ms
3.8.0-rc3 + patches:
WriteX 105556 0.029 4.273
ReadX 335004 0.005 4.112
Flush 14982 30.540 298.634
Throughput 55.4496 MB/sec 4 clients 4 procs max_latency=298.650 ms
As you can see, the maximum write latency drops considerably with this
patch enabled. The other filesystems (ext3/ext4/xfs/btrfs) behave
similarly, but see the cover letter for those results.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
The function does not modify iov_iter which 'i' points to.
Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
.fault now can retry. The retry can break state machine of .fault. In
filemap_fault, if page is miss, ra->mmap_miss is increased. In the second
try, since the page is in page cache now, ra->mmap_miss is decreased. And
these are done in one fault, so we can't detect random mmap file access.
Add a new flag to indicate .fault is tried once. In the second try, skip
ra->mmap_miss decreasing. The filemap_fault state machine is ok with it.
I only tested x86, didn't test other archs, but looks the change for other
archs is obvious, but who knows :)
Signed-off-by: Shaohua Li <shaohua.li@fusionio.com>
Move actual pte filling for non-linear file mappings into the new special
vma operation: ->remap_pages().
Filesystems must implement this method to get non-linear mapping support,
if it uses filemap_fault() then generic_file_remap_pages() can be used.
Now device drivers can implement this method and obtain nonlinear vma support.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Chris Metcalf <cmetcalf@tilera.com> #arch/tile
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Eric Paris <eparis@redhat.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: Jason Baron <jbaron@redhat.com>
Cc: Kentaro Takeda <takedakn@nttdata.co.jp>
Cc: Matt Helsley <matthltc@us.ibm.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Venkatesh Pallipadi <venki@google.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Move unplugging for direct I/O from around ->direct_IO() down to
do_blockdev_direct_IO(). This implicitly adds plugging for direct
writes.
CC: Li Shaohua <shli@fusionio.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Buffered write(2) is not directly tied to IO, so it's not suitable to
handle plug in generic_file_aio_write().
Note that plugging for O_SYNC writes is also removed. The user may pass
arbitrary @size arguments, which may be much larger than the preferable
I/O size, or may cross extent/device boundaries. Let the lower layers
handle the plugging. The plugging code here actually turns them into
no-ops.
There are several entry points which dirty pages in a filesystem. mmap
(handled by block_page_mkwrite()), buffered write (handled by
__generic_file_aio_write()), splice write (generic_file_splice_write),
truncate, and fallocate (these can dirty last partial page - handled inside
each filesystem separately). Protect these places with sb_start_write() and
sb_end_write().
->page_mkwrite() calls are particularly complex since they are called with
mmap_sem held and thus we cannot use standard sb_start_write() due to lock
ordering constraints. We solve the problem by using a special freeze protection
sb_start_pagefault() which ranks below mmap_sem.
BugLink: https://bugs.launchpad.net/bugs/897421
Tested-by: Kamal Mostafa <kamal@canonical.com>
Tested-by: Peter M. Petrakis <peter.petrakis@canonical.com>
Tested-by: Dann Frazier <dann.frazier@canonical.com>
Tested-by: Massimo Morana <massimo.morana@canonical.com>
Make default vm_ops provide ->page_mkwrite handler. Currently it only updates
file's modification times and gets locked page but later it will also handle
filesystem freezing.
Pull vfs changes from Al Viro.
"A lot of misc stuff. The obvious groups:
* Miklos' atomic_open series; kills the damn abuse of
->d_revalidate() by NFS, which was the major stumbling block for
all work in that area.
* ripping security_file_mmap() and dealing with deadlocks in the
area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in
general.
* ->encode_fh() switched to saner API; insane fake dentry in
mm/cleancache.c gone.
* assorted annotations in fs (endianness, __user)
* parts of Artem's ->s_dirty work (jff2 and reiserfs parts)
* ->update_time() work from Josef.
* other bits and pieces all over the place.
Normally it would've been in two or three pull requests, but
signal.git stuff had eaten a lot of time during this cycle ;-/"
Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the
'truncate_range' inode method was removed by the VM changes, the VFS
update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due
to sparse fix added twice, with other changes nearby).
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits)
nfs: don't open in ->d_revalidate
vfs: retry last component if opening stale dentry
vfs: nameidata_to_filp(): don't throw away file on error
vfs: nameidata_to_filp(): inline __dentry_open()
vfs: do_dentry_open(): don't put filp
vfs: split __dentry_open()
vfs: do_last() common post lookup
vfs: do_last(): add audit_inode before open
vfs: do_last(): only return EISDIR for O_CREAT
vfs: do_last(): check LOOKUP_DIRECTORY
vfs: do_last(): make ENOENT exit RCU safe
vfs: make follow_link check RCU safe
vfs: do_last(): use inode variable
vfs: do_last(): inline walk_component()
vfs: do_last(): make exit RCU safe
vfs: split do_lookup()
Btrfs: move over to use ->update_time
fs: introduce inode operation ->update_time
reiserfs: get rid of resierfs_sync_super
reiserfs: mark the superblock as dirty a bit later
Btrfs has to make sure we have space to allocate new blocks in order to modify
the inode, so updating time can fail. We've gotten around this by having our
own file_update_time but this is kind of a pain, and Christoph has indicated he
would like to make xfs do something different with atime updates. So introduce
->update_time, where we will deal with i_version an a/m/c time updates and
indicate which changes need to be made. The normal version just does what it
has always done, updates the time and marks the inode dirty, and then
filesystems can choose to do something different.
I've gone through all of the users of file_update_time and made them check for
errors with the exception of the fault code since it's complicated and I wasn't
quite sure what to do there, also Jan is going to be pushing the file time
updates into page_mkwrite for those who have it so that should satisfy btrfs and
make it not a big deal to check the file_update_time() return code in the
generic fault path. Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
file_remove_suid() is a generic function operates on struct file,
it almost has no relations with file mapping, so move it to fs/inode.c.
It is better to define readahead(2) in mm/readahead.c than in
mm/filemap.c.
Cc: Fengguang Wu <fengguang.wu@intel.com>
Replace radix_tree_gang_lookup_slot() and
radix_tree_gang_lookup_tag_slot() in page-cache lookup functions with
brand-new radix-tree direct iterating. This avoids the double-scanning
and pointer copying.
Iterator don't stop after nr_pages page-get fails in a row, it continue
lookup till the radix-tree end. Thus we can safely remove these restart
conditions.
Unfortunately, old implementation didn't forbid nr_pages == 0, this corner
case does not fit into new code, so the patch adds an extra check at the
beginning.
Tested-by: Hugh Dickins <hughd@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm
Pull cleancache changes from Konrad Rzeszutek Wilk:
"This has some patches for the cleancache API that should have been
submitted a _long_ time ago. They are basically cleanups:
- rename of flush to invalidate
- moving reporting of statistics into debugfs
- use __read_mostly as necessary.
Oh, and also the MAINTAINERS file change. The files (except the
MAINTAINERS file) have been in #linux-next for months now. The late
addition of MAINTAINERS file is a brain-fart on my side - didn't
realize I needed that just until I was typing this up - and I based
that patch on v3.3 - so the tree is on top of v3.3."
* tag 'stable/for-linus-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm:
MAINTAINERS: Adding cleancache API to the list.
mm: cleancache: Use __read_mostly as appropiate.
mm: cleancache: report statistics via debugfs instead of sysfs.
mm: zcache/tmem/cleancache: s/flush/invalidate/
mm: cleancache: s/flush/invalidate/
Commit c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when
changing cpuset's mems") wins a super prize for the largest number of
memory barriers entered into fast paths for one commit.
[get|put]_mems_allowed is incredibly heavy with pairs of full memory
barriers inserted into a number of hot paths. This was detected while
investigating at large page allocator slowdown introduced some time
after 2.6.32. The largest portion of this overhead was shown by
oprofile to be at an mfence introduced by this commit into the page
allocator hot path.
For extra style points, the commit introduced the use of yield() in an
implementation of what looks like a spinning mutex.
This patch replaces the full memory barriers on both read and write
sides with a sequence counter with just read barriers on the fast path
side. This is much cheaper on some architectures, including x86. The
main bulk of the patch is the retry logic if the nodemask changes in a
manner that can cause a false failure.
While updating the nodemask, a check is made to see if a false failure
is a risk. If it is, the sequence number gets bumped and parallel
allocators will briefly stall while the nodemask update takes place.
In a page fault test microbenchmark, oprofile samples from
__alloc_pages_nodemask went from 4.53% of all samples to 1.15%. The
actual results were
3.3.0-rc3 3.3.0-rc3
rc3-vanilla nobarrier-v2r1
Clients 1 UserTime 0.07 ( 0.00%) 0.08 (-14.19%)
Clients 2 UserTime 0.07 ( 0.00%) 0.07 ( 2.72%)
Clients 4 UserTime 0.08 ( 0.00%) 0.07 ( 3.29%)
Clients 1 SysTime 0.70 ( 0.00%) 0.65 ( 6.65%)
Clients 2 SysTime 0.85 ( 0.00%) 0.82 ( 3.65%)
Clients 4 SysTime 1.41 ( 0.00%) 1.41 ( 0.32%)
Clients 1 WallTime 0.77 ( 0.00%) 0.74 ( 4.19%)
Clients 2 WallTime 0.47 ( 0.00%) 0.45 ( 3.73%)
Clients 4 WallTime 0.38 ( 0.00%) 0.37 ( 1.58%)
Clients 1 Flt/sec/cpu 497620.28 ( 0.00%) 520294.53 ( 4.56%)
Clients 2 Flt/sec/cpu 414639.05 ( 0.00%) 429882.01 ( 3.68%)
Clients 4 Flt/sec/cpu 257959.16 ( 0.00%) 258761.48 ( 0.31%)
Clients 1 Flt/sec 495161.39 ( 0.00%) 517292.87 ( 4.47%)
Clients 2 Flt/sec 820325.95 ( 0.00%) 850289.77 ( 3.65%)
Clients 4 Flt/sec 1020068.93 ( 0.00%) 1022674.06 ( 0.26%)
MMTests Statistics: duration
Sys Time Running Test (seconds) 135.68 132.17
User+Sys Time Running Test (seconds) 164.2 160.13
Total Elapsed Time (seconds) 123.46 120.87
The overall improvement is small but the System CPU time is much
improved and roughly in correlation to what oprofile reported (these
performance figures are without profiling so skew is expected). The
actual number of page faults is noticeably improved.
For benchmarks like kernel builds, the overall benefit is marginal but
the system CPU time is slightly reduced.
To test the actual bug the commit fixed I opened two terminals. The
first ran within a cpuset and continually ran a small program that
faulted 100M of anonymous data. In a second window, the nodemask of the
cpuset was continually randomised in a loop.
Without the commit, the program would fail every so often (usually
within 10 seconds) and obviously with the commit everything worked fine.
With this patch applied, it also worked fine so the fix should be
functionally equivalent.
Cc: Miao Xie <miaox@cn.fujitsu.com>
Cc: Christoph Lameter <cl@linux.com>
When i_mmap_lock changed to a mutex the locking order in memory failure
was changed to take the sleeping lock first. But the big fat mm lock
ordering comment (BFMLO) wasn't updated. Do this here.
Pointed out by Andrew.
There is not much point in skipping zones during allocation based on the
dirty usage which they'll never contribute to. And we'd like to avoid
page reclaim waits when writing to ramfs/sysfs etc.
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Ying Han <yinghan@google.com>
Acked-by: Minchan Kim <minchan.kim@gmail.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
* stable/cleancache.v13:
Herbert Poetzl reported a performance regression since 2.6.39. The test
is a simple dd read, but with big block size. The reason is:
T1: ra (A, A+128k), (A+128k, A+256k)
T2: lock_page for page A, submit the 256k
T3: hit page A+128K, ra (A+256k, A+384). the range isn't submitted
because of plug and there isn't any lock_page till we hit page A+256k
because all pages from A to A+256k is in memory
T4: hit page A+256k, ra (A+384, A+ 512). Because of plug, the range isn't
submitted again.
T5: lock_page A+256k, so (A+256k, A+512k) will be submitted. The task is
waitting for (A+256k, A+512k) finish.
There is no request to disk in T3 and T4, so readahead pipeline breaks.
We really don't need block plug for generic_file_aio_read() for buffered
I/O. The readahead already has plug and has fine grained control when I/O
should be submitted. Deleting plug for buffered I/O fixes the regression.
One side effect is plug makes the request size 256k, the size is 128k
without it. This is because default ra size is 128k and not a reason we
need plug here.
Vivek said:
: We submit some readahead IO to device request queue but because of nested
: plug, queue never gets unplugged. When read logic reaches a page which is
: not in page cache, it waits for page to be read from the disk
: (lock_page_killable()) and that time we flush the plug list.
: So effectively read ahead logic is kind of broken in parts because of
: nested plugging. Removing top level plug (generic_file_aio_read()) for
: buffered reads, will allow unplugging queue earlier for readahead.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Reported-by: Herbert Poetzl <herbert@13thfloor.at>
Tested-by: Eric Dumazet <eric.dumazet@gmail.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: <stable@vger.kernel.org>
Per akpm suggestions alter the use of the term flush to be
invalidate. The next patch will do this across all MM.
This change is completely cosmetic.
[v9: akpm@linux-foundation.org: change "flush" to "invalidate", part 3]
Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com>
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Jan Beulich <JBeulich@novell.com>
Reviewed-by: Seth Jennings <sjenning@linux.vnet.ibm.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Rik Riel <riel@redhat.com>
[v10: Fixed fs: move code out of buffer.c conflict change]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Commit ef6a3c6311 ("mm: add replace_page_cache_page() function") added a
function replace_page_cache_page(). This function replaces a page in the
radix-tree with a new page. WHen doing this, memory cgroup needs to fix
up the accounting information. memcg need to check PCG_USED bit etc.
In some(many?) cases, 'newpage' is on LRU before calling
replace_page_cache(). So, memcg's LRU accounting information should be
fixed, too.
This patch adds mem_cgroup_replace_page_cache() and removes the old hooks.
In that function, old pages will be unaccounted without touching
res_counter and new page will be accounted to the memcg (of old page).
WHen overwriting pc->mem_cgroup of newpage, take zone->lru_lock and avoid
races with LRU handling.
Background:
replace_page_cache_page() is called by FUSE code in its splice() handling.
Here, 'newpage' is replacing oldpage but this newpage is not a newly allocated
page and may be on LRU. LRU mis-accounting will be critical for memory cgroup
because rmdir() checks the whole LRU is empty and there is no account leak.
If a page is on the other LRU than it should be, rmdir() will fail.
This bug was added in March 2011, but no bug report yet. I guess there
are not many people who use memcg and FUSE at the same time with upstream
kernels.
The result of this bug is that admin cannot destroy a memcg because of
account leak. So, no panic, no deadlock. And, even if an active cgroup
exist, umount can succseed. So no problem at shutdown.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Miklos Szeredi <mszeredi@suse.cz>
Tell the page allocator that pages allocated through
grab_cache_page_write_begin() are expected to become dirty soon.
Signed-off-by: Johannes Weiner <jweiner@redhat.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: Shaohua Li <shaohua.li@intel.com>
lockdep reports a deadlock in jfs because a special inode's rw semaphore
is taken recursively. The mapping's gfp mask is GFP_NOFS, but is not
used when __read_cache_page() calls add_to_page_cache_lru().
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: stable@kernel.org
Currently write(2) to a file is not interruptible by any signal.
Sometimes this is desirable, e.g. when you want to quickly kill a
process hogging your disk. Also, with commit 499d05ecf990 ("mm: Make
task in balance_dirty_pages() killable"), it's necessary to abort the
current write accordingly to avoid it quickly dirtying lots more pages
at unthrottled rate.
This patch makes write interruptible by SIGKILL. We do not allow write
to be interruptible by any other signal because that has larger
potential of screwing some badly written applications.
Reported-by: Kazuya Mio <k-mio@sx.jp.nec.com>
Tested-by: Kazuya Mio <k-mio@sx.jp.nec.com>
Acked-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
The files changed within are only using the EXPORT_SYMBOL
macro variants. They are not using core modular infrastructure
and hence don't need module.h but only the export.h header.
Currently, when you call iov_iter_advance, then the pointer to the iovec
array can be incremented, but it does not decrement the nr_segs value in
the iov_iter struct. The result is a iov_iter struct with a nr_segs
value that goes beyond the end of the array.
While I'm not aware of anything that's specifically broken by this, it
seems odd and a bit dangerous not to decrement that value. If someone
were to trust the nr_segs value to be correct, then they could end up
walking off the end of the array.
Changing this might also provide some micro-optimization when dealing
with the last iovec in an array. Many of the other routines that deal
with iov_iter have optimized codepaths when nr_segs == 1.
Cc: Nick Piggin <npiggin@suse.de>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
The found entries by find_get_pages() could be all swap entries. In
this case we skip the entries, but make sure the skipped entries are
accounted, so we don't keep looping.
Using nr_found > nr_skip to simplify code as suggested by Eric.
Reported-and-tested-by: Eric Dumazet <eric.dumazet@gmail.com>
Make the radix_tree exceptional cases, mostly in filemap.c, clearer.
It's hard to devise a suitable snappy name that illuminates the use by
shmem/tmpfs for swap, while keeping filemap/pagecache/radix_tree
generality. And akpm points out that /* radix_tree_deref_retry(page) */
comments look like calls that have been commented out for unknown
reason.
Skirt the naming difficulty by rearranging these blocks to handle the
transient radix_tree_deref_retry(page) case first; then just explain the
remaining shmem/tmpfs swap case in a comment.
