path: root/lib
2007-04-25[NETLINK]: Switch cb_lock spinlock to mutex and allow to override itPatrick McHardy
Switch cb_lock to mutex and allow netlink kernel users to override it with a subsystem specific mutex for consistent locking in dump callbacks. All netlink_dump_start users have been audited not to rely on any side-effects of the previously used spinlock. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[S390]: Fix build on 31-bit.David S. Miller
Allow s390 to properly override the generic __div64_32() implementation by: 1) Using obj-y for div64.o in s390's makefile instead of lib-y 2) Adding the weak attribute to the generic implementation. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[LIB]: div64_64 optimizationStephen Hemminger
Minor optimization of div64_64. do_div() already does optimization for the case of 32 by 32 divide, so no need to do it here. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: div64_64 consolidate (rev3)Stephen Hemminger
Here is the current version of the 64 bit divide common code. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-09kobject: new_device->kref wasn't putted after error in kobject_move()Dmitriy Monakhov
If error happen we jump to "out" label, in this case new_device not yet became the parent but it wasn't putted. Signed-off-by: Monakhov Dmitriy <dmonakhov@openvz.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-06Revert "[IA64] swiotlb abstraction (e.g. for Xen)"Tony Luck
This reverts commit 51099005ab8e09d68a13fea8d55bc739c1040ca6.
2007-03-01[PATCH] kernel-doc fixes for 2.6.20-git15 (non-drivers)Randy Dunlap
Fix kernel-doc warnings in 2.6.20-git15 (lib/, mm/, kernel/, include/). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] genalloc warning fixesAndrew Morton
lib/genalloc.c: In function 'gen_pool_alloc': lib/genalloc.c:151: warning: passing argument 2 of '__set_bit' from incompatible pointer type lib/genalloc.c: In function 'gen_pool_free': lib/genalloc.c:190: warning: passing argument 2 of '__clear_bit' from incompatible pointer type Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] fault injection: split up stacktrace filter Kconfig optionAkinobu Mita
There is no prompt for CONFIG_STACKTRACE, so FAULT_INJECTION cannot be selected without LOCKDEP enabled. (found by Paolo 'Blaisorblade' Giarrusso) In order to fix such broken Kconfig dependency, this patch splits up the stacktrace filter support for fault injection by new Kconfig option, which enables to use fault injection on the architecture which doesn't have general stacktrace support. Cc: "Paolo 'Blaisorblade' Giarrusso" <blaisorblade@yahoo.it> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] Convert highest_possible_processor_id to nr_cpu_idsChristoph Lameter
We frequently need the maximum number of possible processors in order to allocate arrays for all processors. So far this was done using highest_possible_processor_id(). However, we do need the number of processors not the highest id. Moreover the number was so far dynamically calculated on each invokation. The number of possible processors does not change when the system is running. We can therefore calculate that number once. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Frederik Deweerdt <frederik.deweerdt@gmail.com> Cc: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits) Documentation/kernel-docs.txt update. arch/cris: typo in KERN_INFO Storage class should be before const qualifier kernel/printk.c: comment fix update I/O sched Kconfig help texts - CFQ is now default, not AS. Remove duplicate listing of Cris arch from README kbuild: more doc. cleanups doc: make doc. for maxcpus= more visible drivers/net/eexpress.c: remove duplicate comment add a help text for BLK_DEV_GENERIC correct a dead URL in the IP_MULTICAST help text fix the BAYCOM_SER_HDX help text fix SCSI_SCAN_ASYNC help text trivial documentation patch for platform.txt Fix typos concerning hierarchy Fix comment typo "spin_lock_irqrestore". Fix misspellings of "agressive". drivers/scsi/a100u2w.c: trivial typo patch Correct trivial typo in log2.h. Remove useless FIND_FIRST_BIT() macro from cardbus.c. ...
2007-02-19Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: PCI: Make PCI device numa-node attribute visible in sysfs PCI: add systems for automatic breadth-first device sorting PCI: PCI devices get assigned redundant IRQs PCI: Make CARDBUS_MEM_SIZE and CARDBUS_IO_SIZE boot options PCI: pci.txt fix __devexit() usage PCI/sysfs/kobject kernel-doc fixes
2007-02-17Various typo fixes.Robert P. J. Day
Correct mis-spellings of "algorithm", "appear", "consistent" and (shame, shame) "kernel". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-16PCI/sysfs/kobject kernel-doc fixesRandy Dunlap
Fix kernel-doc warnings in PCI, sysfs, and kobject files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16kobject: kobj->k_name verification fixMartin Stoilov
The function 'kobject_add' tries to verify the name of a new kobject instance is properly set before continuing. if (!kobj->k_name) kobj->k_name = kobj->name; if (!kobj->k_name) { pr_debug("kobject attempted to be registered with no name!\n"); WARN_ON(1); return -EINVAL; } The statement: if (!kobj->k_name) { pr_debug("kobject attempted to be registered with no name!\n"); WARN_ON(1); return -EINVAL; } is useless the way it is right now, because it can never be true. I think the code was intended to be: if (!kobj->k_name) kobj->k_name = kobj->name; if (!*kobj->k_name) { pr_debug("kobject attempted to be registered with no name!\n"); WARN_ON(1); return -EINVAL; } because this would make sure the kobj->name buffer has something in it. So the missing '*' is just a typo. Although, I would much prefer expression like: if (*kobj->k_name == '\0') { pr_debug("kobject attempted to be registered with no name!\n"); WARN_ON(1); return -EINVAL; } because this would've made the intention clear, in this patch I just restore the missing '*' without changing the coding style of the function. Signed-off-by: Martin Stoilov <mstoilov@odesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16[PATCH] Add debugging feature /proc/timer_statIngo Molnar
Add /proc/timer_stats support: debugging feature to profile timer expiration. Both the starting site, process/PID and the expiration function is captured. This allows the quick identification of timer event sources in a system. Sample output: # echo 1 > /proc/timer_stats # cat /proc/timer_stats Timer Stats Version: v0.1 Sample period: 4.010 s 24, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick) 11, 0 swapper sk_reset_timer (tcp_delack_timer) 6, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick) 2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) 17, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick) 2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) 4, 2050 pcscd do_nanosleep (hrtimer_wakeup) 5, 4179 sshd sk_reset_timer (tcp_write_timer) 4, 2248 yum-updatesd schedule_timeout (process_timeout) 18, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick) 3, 0 swapper sk_reset_timer (tcp_delack_timer) 1, 1 swapper neigh_table_init_no_netlink (neigh_periodic_timer) 2, 1 swapper e1000_up (e1000_watchdog) 1, 1 init schedule_timeout (process_timeout) 100 total events, 25.24 events/sec [ cleanups and hrtimers support from Thomas Gleixner <tglx@linutronix.de> ] [bunk@stusta.de: nr_entries can become static] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] pci_iomap_regions() error handling fixFrederik Deweerdt
It appears that the pcim_iomap_regions() function doesn't get the error handling right. It BUGs early at boot with a backtrace along the lines of: ahci_init pci_register_driver driver_register [...] ahci_init_one pcim_iomap_region pcim_iounmap The following patch allows me to boot. Only the if(mask..) continue; part fixes the problem actually, the gotos where changed so that we don't try to unmap something we couldn't map anyway. Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Tejun Heo <htejun@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] swiotlb uninliningsAndrew Morton
Optimise swiotlb.c for size. text data bss dec hex filename 5009 89 64 5162 142a lib/swiotlb.o-before 4666 89 64 4819 12d3 lib/swiotlb.o-after For some reason my gcc (4.0.2) doesn't want to tailcall these things. swiotlb_sync_sg_for_device: pushq %rbp # movl $1, %r8d #, movq %rsp, %rbp #, call swiotlb_sync_sg # leave ret .size swiotlb_sync_sg_for_device, .-swiotlb_sync_sg_for_device .section .text.swiotlb_sync_sg_for_cpu,"ax",@progbits .globl swiotlb_sync_sg_for_cpu .type swiotlb_sync_sg_for_cpu, @function swiotlb_sync_sg_for_cpu: pushq %rbp # xorl %r8d, %r8d # movq %rsp, %rbp #, call swiotlb_sync_sg # leave ret Cc: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Debug shared irqsDavid Woodhouse
Drivers registering IRQ handlers with SA_SHIRQ really ought to be able to handle an interrupt happening before request_irq() returns. They also ought to be able to handle an interrupt happening during the start of their call to free_irq(). Let's test that hypothesis.... [bunk@stusta.de: Kconfig fixes] Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] scnprintf(): fix a commentMartin Peschke
The return value of scnprintf() never exceeds @size. Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] sort the devres mess outAl Viro
* Split the implementation-agnostic stuff in separate files. * Make sure that targets using non-default request_irq() pull kernel/irq/devres.o * Introduce new symbols (HAS_IOPORT and HAS_IOMEM) defaulting to positive; allow architectures to turn them off (we needed these symbols anyway for dependencies of quite a few drivers). * protect the ioport-related parts of lib/devres.o with CONFIG_HAS_IOPORT. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Remove references to obsolete kernel config option DEBUG_RWSEMSRobert P. J. Day
Remove the few references to the obsolete kernel config option DEBUG_RWSEMS. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Extract and use wake_up_klogd()Kirill Korotaev
Remove hack with printing space to wake up klogd. Use explicit wake_up_klogd(). See earlier discussion http://groups.google.com/group/fa.linux.kernel/browse_frm/thread/75f496668409f58d/1a8f28983a51e1ff?lnk=st&q=wake_up_klogd+group%3Afa.linux.kernel&rnum=2#1a8f28983a51e1ff Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Consolidate bust_spinlocks()Kirill Korotaev
Part of long forgotten patch http://groups.google.com/group/fa.linux.kernel/msg/e98e941ce1cf29f6?dmode=source Since then, m32r grabbed two copies. Leave s390 copy because of important absence of CONFIG_VT, but remove references to non-existent timerlist_lock. ia64 also loses timerlist_lock. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09iomap: iomap should be in obj-y not in lib-yTejun Heo
devres change moved iomap.o from obj-$(CONFIG_GENERIC_IOMAP) to lib-y making it not linked if no in-kernel driver uses it. Fix it. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09devres: implement pcim_iomap_regions()Tejun Heo
Implement pcim_iomap_regions(). This function takes mask of BARs to request and iomap. No BAR should have length of zero. BARs are iomapped using pcim_iomap_table(). Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09devres: device resource managementTejun Heo
Implement device resource management, in short, devres. A device driver can allocate arbirary size of devres data which is associated with a release function. On driver detach, release function is invoked on the devres data, then, devres data is freed. devreses are typed by associated release functions. Some devreses are better represented by single instance of the type while others need multiple instances sharing the same release function. Both usages are supported. devreses can be grouped using devres group such that a device driver can easily release acquired resources halfway through initialization or selectively release resources (e.g. resources for port 1 out of 4 ports). This patch adds devres core including documentation and the following managed interfaces. * alloc/free : devm_kzalloc(), devm_kzfree() * IO region : devm_request_region(), devm_release_region() * IRQ : devm_request_irq(), devm_free_irq() * DMA : dmam_alloc_coherent(), dmam_free_coherent(), dmam_declare_coherent_memory(), dmam_pool_create(), dmam_pool_destroy() * PCI : pcim_enable_device(), pcim_pin_device(), pci_is_managed() * iomap : devm_ioport_map(), devm_ioport_unmap(), devm_ioremap(), devm_ioremap_nocache(), devm_iounmap(), pcim_iomap_table(), pcim_iomap(), pcim_iounmap() Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-07sysfs: Shadow directory supportEric W. Biederman
The problem. When implementing a network namespace I need to be able to have multiple network devices with the same name. Currently this is a problem for /sys/class/net/*. What I want is a separate /sys/class/net directory in sysfs for each network namespace, and I want to name each of them /sys/class/net. I looked and the VFS actually allows that. All that is needed is for /sys/class/net to implement a follow link method to redirect lookups to the real directory you want. Implementing a follow link method that is sensitive to the current network namespace turns out to be 3 lines of code so it looks like a clean approach. Modifying sysfs so it doesn't get in my was is a bit trickier. I am calling the concept of multiple directories all at the same path in the filesystem shadow directories. With the directory entry really at that location the shadow master. The following patch modifies sysfs so it can handle a directory structure slightly different from the kobject tree so I can implement the shadow directories for handling /sys/class/net/. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07kobject: kobject_put cleanupMariusz Kozlowski
This patch removes redundant argument checks for kobject_put(). Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07driver core: Allow device_move(dev, NULL).Cornelia Huck
If we allow NULL as the new parent in device_move(), we need to make sure that the device is placed into the same place as it would if it was newly registered: - Consider the device virtual tree. In order to be able to reuse code, setup_parent() has been tweaked a bit. - kobject_move() can fall back to the kset's kobject. - sysfs_move_dir() uses the sysfs root dir as fallback. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07Kobject: make kobject apis more robust in handling NULL pointersGreg Kroah-Hartman
It should be ok to pass in NULL for some kobject functions, so add error checking for all exported kobject functions to be more robust. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-05[IA64] swiotlb abstraction (e.g. for Xen)Jan Beulich
Add abstraction so that the file can be used by environments other than IA64 and EM64T, namely for Xen. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-05[IA64] swiotlb cleanupJan Beulich
- add proper __init decoration to swiotlb's init code (and the code calling it, where not already the case) - replace uses of 'unsigned long' with dma_addr_t where appropriate - do miscellaneous simplicfication and cleanup Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-05[IA64] make swiotlb use bus_to_virt/virt_to_busJan Beulich
Convert all phys_to_virt/virt_to_phys uses to bus_to_virt/virt_to_bus, as is what is meant and what is needed in (at least) some virtualized environments like Xen. Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-05[IA64] swiotlb bug fixesJan Beulich
This patch fixes - marking I-cache clean of pages DMAed to now only done for IA64 - broken multiple inclusion in include/asm-x86_64/swiotlb.h - missing call to mark_clean in swiotlb_sync_sg() - a (perhaps only theoretical) issue in swiotlb_dma_supported() when io_tlb_end is exactly at the end of memory Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-12-20kobject: kobject_uevent() returns manageable valueAneesh Kumar K.V
Since kobject_uevent() function does not return an integer value to indicate if its operation was completed with success or not, it is worth changing it in order to report a proper status (success or error) instead of returning void. [randy.dunlap@oracle.com: Fix inline kobject functions] Cc: Mauricio Lin <mauriciolin@gmail.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20kref refcnt and false positivesVenkatesh Pallipadi
With WARN_ON addition to kobject_init() [ http://kernel.org/pub/linux/kernel/people/akpm/patches/2.6/2.6.19/2.6.19-mm1/dont-use/broken-out/gregkh-driver-kobject-warn.patch ] I started seeing following WARNING on CPU offline followed by online on my x86_64 system. WARNING at lib/kobject.c:172 kobject_init() Call Trace: [<ffffffff8020ab45>] dump_trace+0xaa/0x3ef [<ffffffff8020aec4>] show_trace+0x3a/0x50 [<ffffffff8020b0f6>] dump_stack+0x15/0x17 [<ffffffff80350abc>] kobject_init+0x3f/0x8a [<ffffffff80350be1>] kobject_register+0x1a/0x3e [<ffffffff803bbd89>] sysdev_register+0x5b/0xf9 [<ffffffff80211d0b>] mce_create_device+0x77/0xf4 [<ffffffff80211dc2>] mce_cpu_callback+0x3a/0xe5 [<ffffffff805632fd>] notifier_call_chain+0x26/0x3b [<ffffffff8023f6f3>] raw_notifier_call_chain+0x9/0xb [<ffffffff802519bf>] _cpu_up+0xb4/0xdc [<ffffffff80251a12>] cpu_up+0x2b/0x42 [<ffffffff803bef00>] store_online+0x4a/0x72 [<ffffffff803bb6ce>] sysdev_store+0x24/0x26 [<ffffffff802baaa2>] sysfs_write_file+0xcf/0xfc [<ffffffff8027fc6f>] vfs_write+0xae/0x154 [<ffffffff80280418>] sys_write+0x47/0x6f [<ffffffff8020963e>] system_call+0x7e/0x83 DWARF2 unwinder stuck at system_call+0x7e/0x83 Leftover inexact backtrace: This is a false positive as mce.c is unregistering/registering sysfs interfaces cleanly on hotplug. kref_put() and conditional decrement of refcnt seems to be the root cause for this and the patch below resolves the issue for me. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-15Remove stack unwinder for nowLinus Torvalds
It has caused more problems than it ever really solved, and is apparently not getting cleaned up and fixed. We can put it back when it's stable and isn't likely to make warning or bug events worse. In the meantime, enable frame pointers for more readable stack traces. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] uml problems with linux/io.hAl Viro
Remove useless includes of linux/io.h, don't even try to build iomap_copy on uml (it doesn't have readb() et.al., so...) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] SLAB: use a multiply instead of a divide in obj_to_index()Eric Dumazet
When some objects are allocated by one CPU but freed by another CPU we can consume lot of cycles doing divides in obj_to_index(). (Typical load on a dual processor machine where network interrupts are handled by one particular CPU (allocating skbufs), and the other CPU is running the application (consuming and freeing skbufs)) Here on one production server (dual-core AMD Opteron 285), I noticed this divide took 1.20 % of CPU_CLK_UNHALTED events in kernel. But Opteron are quite modern cpus and the divide is much more expensive on oldest architectures : On a 200 MHz sparcv9 machine, the division takes 64 cycles instead of 1 cycle for a multiply. Doing some math, we can use a reciprocal multiplication instead of a divide. If we want to compute V = (A / B) (A and B being u32 quantities) we can instead use : V = ((u64)A * RECIPROCAL(B)) >> 32 ; where RECIPROCAL(B) is precalculated to ((1LL << 32) + (B - 1)) / B Note : I wrote pure C code for clarity. gcc output for i386 is not optimal but acceptable : mull 0x14(%ebx) mov %edx,%eax // part of the >> 32 xor %edx,%edx // useless mov %eax,(%esp) // could be avoided mov %edx,0x4(%esp) // useless mov (%esp),%ebx [akpm@osdl.org: small cleanups] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-12Fix typo in new debug options.Dave Jones
Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-10[PATCH] add MODULE_* attributes to bit reversal libraryCal Peake
Add MODULE_* attributes to the new bit reversal library. Most notably MODULE_LICENSE which prevents superfluous kernel tainting. Signed-off-by: Cal Peake <cp@absolutedigital.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] Kconfig refactoring for better menu nestingDon Mullis
Refactor Kconfig content to maximize nesting of menus by menuconfig and xconfig. Tested by simultaneously running `make xconfig` with and without patch, and comparing displays. Signed-off-by: Don Mullis <dwm@meer.net> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection: optimize and simplify should_fail()Don Mullis
Trivial optimization and simplification of should_fail(). Do cheaper disqualification tests first (performance gain not quantified). Simplify logic; eliminate goto. Signed-off-by: Don Mullis <dwm@meer.net> Cc: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection: Clamp debugfs stacktrace-depth to MAX_STACK_TRACE_DEPTHDon Mullis
Clamp /debug/fail*/stacktrace-depth to MAX_STACK_TRACE_DEPTH. Ensures that a read of /debug/fail*/stacktrace-depth always returns a truthful answer. Signed-off-by: Don Mullis <dwm@meer.net> Cc: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection: Use bool-true-false throughoutDon Mullis
Use bool-true-false throughout. Signed-off-by: Don Mullis <dwm@meer.net> Cc: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection: stacktrace filtering kconfig fixAndrew Morton
`select' doesn't work very well. With alpha `make allmodconfig' we end up with CONFIG_STACKTRACE enabled, so we end up with undefined save_stacktrace() at link time. Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: Don Mullis <dwm@meer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection Kconfig cleanupAndrew Morton
- Fix some spelling and grammatical errors - Make the Kconfig menu more conventional. First you select fault-injection, then under that you select particular clients of it. Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: Don Mullis <dwm@meer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault injection: stacktrace filteringAkinobu Mita
This patch provides stacktrace filtering feature. The stacktrace filter allows failing only for the caller you are interested in. For example someone may want to inject kmalloc() failures into only e100 module. they want to inject not only direct kmalloc() call, but also indirect allocation, too. - e100_poll --> netif_receive_skb --> packet_rcv_spkt --> skb_clone --> kmem_cache_alloc This patch enables to detect function calls like this by stacktrace and inject failures. The script Documentaion/fault-injection/failmodule.sh helps it. The range of text section of loaded e100 is expected to be [/sys/module/e100/sections/.text, /sys/module/e100/sections/.exit.text) So failmodule.sh stores these values into /debug/failslab/address-start and /debug/failslab/address-end. The maximum stacktrace depth is specified by /debug/failslab/stacktrace-depth. Please see the example that demonstrates how to inject slab allocation failures only for a specific module in Documentation/fault-injection/fault-injection.txt [dwm@meer.net: reject failure if any caller lies within specified range] Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Don Mullis <dwm@meer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
