path: root/lib
2009-06-11Merge branch 'serial-from-alan'Linus Torvalds
* serial-from-alan: (79 commits) moxa: prevent opening unavailable ports imx: serial: use tty_encode_baud_rate to set true rate imx: serial: add IrDA support to serial driver imx: serial: use rational library function lib: isolate rational fractions helper function imx: serial: handle initialisation failure correctly imx: serial: be sure to stop xmit upon shutdown imx: serial: notify higher layers in case xmit IRQ was not called imx: serial: fix one bit field type imx: serial: fix whitespaces (no changes in functionality) tty: use prepare/finish_wait tty: remove sleep_on sierra: driver interface blacklisting sierra: driver urb handling improvements tty: resolve some sierra breakage timbuart: Fix the termios logic serial: Added Timberdale UART driver tty: Add URL for ttydev queue devpts: unregister the file system on error tty: Untangle termios and mm mutex dependencies ...
2009-06-11lib: isolate rational fractions helper functionOskar Schirmer
Provide a helper function to determine optimum numerator denominator value pairs taking into account restricted register size. Useful especially with PLL and other clock configurations. Signed-off-by: Oskar Schirmer <os@emlix.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-10Merge branch 'printk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: vsprintf: introduce %pf format specifier printk: add support of hh length modifier for printk
2009-06-10Merge branch 'iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (61 commits) amd-iommu: remove unnecessary "AMD IOMMU: " prefix amd-iommu: detach device explicitly before attaching it to a new domain amd-iommu: remove BUS_NOTIFY_BOUND_DRIVER handling dma-debug: simplify logic in driver_filter() dma-debug: disable/enable irqs only once in device_dma_allocations dma-debug: use pr_* instead of printk(KERN_* ...) dma-debug: code style fixes dma-debug: comment style fixes dma-debug: change hash_bucket_find from first-fit to best-fit x86: enable GART-IOMMU only after setting up protection methods amd_iommu: fix lock imbalance dma-debug: add documentation for the driver filter dma-debug: add dma_debug_driver kernel command line dma-debug: add debugfs file for driver filter dma-debug: add variables and checks for driver filter dma-debug: fix debug_dma_sync_sg_for_cpu and debug_dma_sync_sg_for_device dma-debug: use sg_dma_len accessor dma-debug: use sg_dma_address accessor instead of using dma_address directly amd-iommu: don't free dma adresses below 512MB with CONFIG_IOMMU_STRESS amd-iommu: don't preallocate page tables with CONFIG_IOMMU_STRESS ...
2009-06-09cpumask: introduce zalloc_cpumask_varYinghai Lu
So can get cpumask_var with cpumask_clear Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-08dma-debug: simplify logic in driver_filter()Joerg Roedel
This patch makes the driver_filter function more readable by reorganizing the code. The removal of a code code block to an upper indentation level makes hard-to-read line-wraps unnecessary. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-06-08dma-debug: disable/enable irqs only once in device_dma_allocationsJoerg Roedel
There is no need to disable/enable irqs on each loop iteration. Just disable irqs for the whole time the loop runs. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-06-08dma-debug: use pr_* instead of printk(KERN_* ...)Joerg Roedel
The pr_* macros are shorter than the old printk(KERN_ ...) variant. Change the dma-debug code to use the new macros and save a few unnecessary line breaks. If lines don't break the source code can also be grepped more easily. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-06-08dma-debug: code style fixesJoerg Roedel
This patch changes the recent updates to dma-debug to conform with coding style guidelines of Linux and the -tip tree. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-06-08dma-debug: comment style fixesJoerg Roedel
Last patch series introduced some new comment which does not fit the Kernel comment style guidelines. Fix it with this patch. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-06-07Merge branch 'dma-debug/2.6.31' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/joro/linux-2.6-iommu into core/iommu
2009-06-07Merge branch 'linus' into core/iommuIngo Molnar
Merge reason: This branch was on an -rc5 base so pull almost-2.6.30 to resync with the latest upstream fixes and make sure the combination works fine. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-07dma-debug: change hash_bucket_find from first-fit to best-fitJoerg Roedel
Some device drivers map the same physical address multiple times to a dma address. Without an IOMMU this results in the same dma address being put into the dma-debug hash multiple times. With a first-fit match in hash_bucket_find() this function may return the wrong dma_debug_entry. This can result in false positive warnings. This patch fixes it by changing the first-fit behavior of hash_bucket_find() into a best-fit algorithm. Reported-by: Torsten Kaiser <just.for.lkml@googlemail.com> Reported-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: lethal@linux-sh.org Cc: just.for.lkml@googlemail.com Cc: hancockrwd@gmail.com Cc: jens.axboe@oracle.com Cc: bharrosh@panasas.com Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@kernel.org> LKML-Reference: <20090605104132.GE24836@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-02Merge branches 'dma-debug/fixes' and 'dma-debug/driver-filter' into ↵Joerg Roedel
dma-debug/2.6.31
2009-06-02dma-debug: add dma_debug_driver kernel command lineJoerg Roedel
This patch add the dma_debug_driver= boot parameter to enable the driver filter for early boot. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-06-02dma-debug: add debugfs file for driver filterJoerg Roedel
This patch adds the dma-api/driver_filter file to debugfs. The root user can write a driver name into this file to see only dma-api errors for that particular driver in the kernel log. Writing an empty string to that file disables the driver filter. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-06-02dma-debug: add variables and checks for driver filterJoerg Roedel
This patch adds the state variables for the driver filter and a function to check if the filter is enabled and matches to the current device. The check is built into the err_printk function. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-05-29dma-debug: fix debug_dma_sync_sg_for_cpu and debug_dma_sync_sg_for_deviceFUJITA Tomonori
DMA-mapping.txt says that debug_dma_sync_sg family must be called with the _same_ one you passed into the dma_map_sg call, it should _NOT_ be the 'count' value _returned_ from the dma_map_sg call. debug_dma_sync_sg_for_cpu and debug_dma_sync_sg_for_device can't handle this properly; they need to use the sg_mapped_ents in struct dma_debug_entry as debug_dma_unmap_sg() does. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-05-29dma-debug: use sg_dma_len accessorFUJITA Tomonori
debug_dma_map_sg() and debug_dma_unmap_sg() use length in struct scatterlist while debug_dma_sync_sg_for_cpu() and debug_dma_sync_sg_for_device() use dma_length. This causes bugs warnings on some IOMMU implementations since these values are not same; the length doesn't represent the dma length. We always need to use sg_dma_len() accessor to get the dma length of a scatterlist entry. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-05-29dma-debug: use sg_dma_address accessor instead of using dma_address directlyFUJITA Tomonori
Architectures might not have dma_address in struct scatterlist (PARISC doesn't). Directly accessing to dma_address in struct scatterlist is wrong; we need to use sg_dma_address() accesssor instead. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-05-28dma-debug: re-add dma memory leak detectionJoerg Roedel
This is basically a revert of commit 314eeac9 but now in a fixed version. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-05-11Merge commit 'v2.6.30-rc5' into core/iommuIngo Molnar
Merge reason: core/iommu was on an .30-rc1 base, update it to .30-rc5 to refresh. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-08Remove old PRINTK_DEBUG config itemJason Baron
On Tue, Apr 21, 2009 at 01:55:53PM +0200, Stefan Richter wrote: > Robert P. J. Day wrote: > > lib/Kconfig.debug: select PRINTK_DEBUG > > > > should that perhaps refer to "DYNAMIC_PRINTK_DEBUG"? since there is > > no such thing as a PRINTK_DEBUG Kconfig variable. > > Looks like a rudiment from an earlier version of Jason's "driver core: > basic infrastructure for per-module dynamic debug messages", > http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=346e15beb5343c2eb8216d820f2ed8f150822b08 > Search an LKML archive for '+#ifdef CONFIG_PRINTK_DEBUG'. > > Jason, should it be deleted or replaced by something? We re-named 'DYNAMIC_PRINTK_DEBUG' to 'DYNAMIC_DEBUG' in 2.6.30.... 'PRINTK_DEBUG' as pointed out never existed. So, it appears to be extraneous, and should be removed. thanks for pointing it out. Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-05Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kernel/posix-cpu-timers.c: fix sparse warning dma-debug: remove broken dma memory leak detection for 2.6.30 locking: Documentation: lockdep-design.txt, fix note of state bits
2009-04-29vsprintf: introduce %pf format specifierFrederic Weisbecker
A printf format specifier which would allow us to print a pure function name has been suggested by Andrew Morton a couple of months ago. The current %pF is very convenient to print a function symbol, but often we only want to print the name of the function, without its asm offset. That's what %pf does in this patch. The lowecase f has been chosen for its intuitive meaning of a 'weak kind of %pF'. The support for this new format would be welcome by the tracing code where the need to print pure function names is often needed. This is also true for other parts of the kernel: $ git-grep -E "kallsyms_lookup\(.+?\)" arch/blackfin/kernel/traps.c: symname = kallsyms_lookup(address, &symsize, &offset, &modname, namebuf); arch/powerpc/xmon/xmon.c: name = kallsyms_lookup(pc, &size, &offset, NULL, tmpstr); arch/sh/kernel/cpu/sh5/unwind.c: sym = kallsyms_lookup(pc, NULL, &offset, NULL, namebuf); arch/x86/kernel/ftrace.c: kallsyms_lookup((unsigned long) syscall, NULL, NULL, NULL, str); kernel/kprobes.c: sym = kallsyms_lookup((unsigned long)p->addr, NULL, kernel/lockdep.c: return kallsyms_lookup((unsigned long)key, NULL, NULL, NULL, str); kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, NULL, str); kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, NULL, str); kernel/trace/ftrace.c: kallsyms_lookup((unsigned long)rec->ops->func, NULL, NULL, NULL, str); kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, NULL, str); kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, NULL, str); kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, &modname, str); kernel/trace/ftrace.c: kallsyms_lookup(*ptr, NULL, NULL, NULL, str); kernel/trace/trace_functions.c: kallsyms_lookup(ip, NULL, NULL, NULL, str); kernel/trace/trace_output.c: kallsyms_lookup(address, NULL, NULL, NULL, str); Changes in v2: - Add the explanation of the %pf role for vsnprintf() and bstr_printf() - Change the comments by dropping the "asm offset" notion and only define the %pf against the actual function offset notion. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Zhaolei <zhaolei@cn.fujitsu.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20090415154817.GC5989@nowhere> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-26dma-debug: remove broken dma memory leak detection for 2.6.30Joerg Roedel
The feature needs some more work because the notfier which is used to check for pending allocations is called before the device drivers ->remove() function. Therefore this feature reports false positives. A real fix for this issue is to introduce a new notifier event which sent _after_ the driver has deinitialized itself. That will done for the next kernel version. [ Impact: reduce the scope of CONFIG_DMA_API_DEBUG=y checks ] Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: iommu@lists.linux-foundation.org LKML-Reference: <1240576557-22442-1-git-send-email-joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-24lib: find_last_bit.o needed by a module only, move it from lib to objFred Isaman
Currently, although find_last_bit is EXPORTed, it is statically linked with the kernel and is referenced only under CONFIG_SMP. When CONFIG_SMP is undefined and find_last_bit is referenced only by modules, linking fails with: ERROR: "find_last_bit" [fs/nfs/nfs.ko] undefined! Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-24Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] update default configuration. [S390] omit frame pointers on s390 when possible [S390] Use tape_generic_offline directly. [S390] /proc/stat idle field for idle cpus [S390] appldata: avoid deadlock with appldata_mem [S390] ipl: fix compile breakage
2009-04-23[S390] omit frame pointers on s390 when possibleHeiko Carstens
Always omit frame pointers on s390. They aren't too useful for the kernel since we have already the kernel stack backchain which allows us to walk the kernel stack. So eleminate the extra code for frame pointers. Only allow the extra code for the function tracer since the gcc compile options -pg and -fomit-frame-pointer are incompatible. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-04-22scatterlist: make sure sg_miter_next() doesn't return 0 sized mappingsTejun Heo
Impact: fix not-so-critical but annoying bug sg_miter_next() returns 0 sized mapping if there is an zero sized sg entry in the list or at the end of each iteration. As the users always check the ->length field, this bug shouldn't be critical other than causing unnecessary iteration. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-20driver: dont update dev_name via device_add pathKay Sievers
notice one system /proc/iomem some entries missed the name for pci_devices it turns that dev->dev.kobj name is changed after device_add. for pci code: via acpi_pci_root_driver.ops.add (aka acpi_pci_root_add) ==> pci_acpi_scan_root is used to scan pci bus/device, and at the same time we read the resource for pci_dev in the pci_read_bases, we have res->name = pci_name(pci_dev); pci_name is calling dev_name. later via acpi_pci_root_driver.ops.start (aka acpi_pci_root_start) ==> pci_bus_add_device to add all pci_dev in kobj tree. pci_bus_add_device will call device_add. actually in device_add /* first, register with generic layer. */ error = kobject_add(&dev->kobj, dev->kobj.parent, "%s", dev_name(dev)); if (error) goto Error; will get one new name for that kobj, old name is freed. [Impact: fix corrupted names in /proc/iomem ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-16driver core: allow non-root users to listen to ueventsKay Sievers
Users can read sysfs files, there is no reason they should not be allowed to listen to uevents. This lets xorg and other userspace programs properly get these messages without having to be root. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-16Revert "kobject: don't block for each kobject_uevent".Hugh Dickins
This reverts commit f520360d93cdc37de5d972dac4bf3bdef6a7f6a7. Tetsuo Handa, running a kernel with CONFIG_DEBUG_PAGEALLOC=y and CONFIG_UEVENT_HELPER_PATH=/sbin/hotplug, has been hitting RCU detected CPU stalls: it's been spinning in the loop where do_execve() counts up the args (but why wasn't fixup_exception working? dunno). The recent change, switching kobject_uevent_env() from UMH_WAIT_EXEC to UMH_NO_WAIT, is broken: the exec uses args on the local stack here, and an env which is kfreed as soon as call_usermodehelper() returns. It very much needs to wait for the exec to be done. An alternative would be to keep the UMH_NO_WAIT, and complicate the code to allocate and free these resources correctly? but no, as GregKH pointed out when making the commit, CONFIG_UEVENT_HELPER_PATH="" is a much better optimization - though some distros are still saying /sbin/hotplug in their .config, yet with no such binary in their initrd or their root. Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Will Newton <will.newton@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-15dma-debug: add dma_debug_resize_entries() to adjust the number of ↵FUJITA Tomonori
dma_debug_entries We use a static value for the number of dma_debug_entries. It can be overwritten by a kernel command line option. Some IOMMUs (e.g. GART) can't set an appropriate value by a kernel command line option because they can't know such value until they finish initializing up their hardware. This patch adds dma_debug_resize_entries() enables IOMMUs to adjust the number of dma_debug_entries anytime. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Cc: fujita.tomonori@lab.ntt.co.jp Cc: akpm@linux-foundation.org LKML-Reference: <20090415182234R.fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-12lockdep: warn about lockdep disabling after kernel taintFrederic Weisbecker
Impact: provide useful missing info for developers Kernel taint can occur in several situations such as warnings, load of prorietary or staging modules, bad page, etc... But when such taint happens, a developer might still be working on the kernel, expecting that lockdep is still enabled. But a taint disables lockdep without ever warning about it. Such a kernel behaviour doesn't really help for kernel development. This patch adds this missing warning. Since the taint is done most of the time after the main message that explain the real source issue, it seems safe to warn about it inside add_taint() so that it appears at last, without hurting the main information. v2: Use a generic helper to disable lockdep instead of an open coded xchg(). Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1239412638-6739-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08printk: add support of hh length modifier for printkZhaolei
Impact: new feature, extend vsprintf format strings hh is used as length modifier for signed char or unsigned char. It is supported by glibc, we add kernel support now. Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com> Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: torvalds@linux-foundation.org Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <49CC9739.30107@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08printk: fix wrong format string iter for printkZhaolei
printk("%Q"); Output before patch: %QQ Output after patch: %Q Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com> Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: torvalds@linux-foundation.org Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <49CC97B6.7040809@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08swiotlb: change swiotlb_bus_to[phys,virt] prototypesBecky Bruce
Add a hwdev argument that is needed on some architectures in order to access a per-device offset that is taken into account when producing a physical address (also needed to get from bus address to virtual address because the physical address is an intermediate step). Also make swiotlb_bus_to_virt weak so architectures can override it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-8-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08swiotlb: use swiotlb_sync_single instead of duplicating codeBecky Bruce
Right now both swiotlb_sync_single_range and swiotlb_sync_sg were duplicating the code in swiotlb_sync_single. Just call it instead. Also rearrange the sync_single code for readability. Note that the swiotlb_sync_sg code was previously doing a complicated comparison to determine if an addresses needed to be unmapped where a simple is_swiotlb_buffer() call would have sufficed. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-7-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08swiotlb: rename unmap_single to do_unmap_singleBecky Bruce
Previously, swiotlb_unmap_page and swiotlb_unmap_sg were duplicating very similar code. Refactor that code into a new unmap_single and unmap_single use do_unmap_single. Note that the swiotlb_unmap_sg code was previously doing a complicated comparison to determine if an addresses needed to be unmapped where a simple is_swiotlb_buffer() call would have sufficed. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-6-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08swiotlb: allow arch override of address_needs_mappingBecky Bruce
Some architectures require additional checking to determine if a device can dma to an address and need to provide their own address_needs_mapping.. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-5-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08swiotlb: map_page fix for highmem systemsBecky Bruce
The current code calls virt_to_phys() on address that might be in highmem, which is bad. This wasn't needed, anyway, because we already have the physical address we need. Get rid of the now-unused virtual address as well. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-4-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08swiotlb: fix compile warningBecky Bruce
Squash a build warning seen on 32-bit powerpc caused by calling min() with 2 different types. Use min_t() instead. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-3-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08swiotlb: comment correctionsBecky Bruce
Impact: cleanup swiotlb_map/unmap_single are now swiotlb_map/unmap_page; trivially change all the comments to reference new names. Also, there were some comments that should have been referring to just plain old map_single, not swiotlb_map_single; fix those as well. Also change a use of the word "pointer", when what is referred to is actually a dma/physical address. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-2-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-07Merge branch 'core/softlockup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/softlockup' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: softlockup: make DETECT_HUNG_TASK default depend on DETECT_SOFTLOCKUP softlockup: move 'one' to the softlockup section in sysctl.c softlockup: ensure the task has been switched out once softlockup: remove timestamp checking from hung_task softlockup: convert read_lock in hung_task to rcu_read_lock softlockup: check all tasks in hung_task softlockup: remove unused definition for spawn_softlockup_task softlockup: fix potential race in hung_task when resetting timeout softlockup: fix to allow compiling with !DETECT_HUNG_TASK softlockup: decouple hung tasks check from softlockup detection
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Merge branch 'linus' into core/softlockupIngo Molnar
Conflicts: kernel/sysctl.c
2009-04-07softlockup: make DETECT_HUNG_TASK default depend on DETECT_SOFTLOCKUPIngo Molnar
Don't offer a default-y option when the user has turned off CONFIG_DETECT_SOFTLOCKUP already. Do offer it as 'y' only if DETECT_SOFTLOCKUP is on already. This makes it match previous behavior - where the hung-task check was embedded i CONFIG_DETECT_SOFTLOCKUP code. Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-06Merge branch 'kmemtrace-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'kmemtrace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kmemtrace: trace kfree() calls with NULL or zero-length objects kmemtrace: small cleanups kmemtrace: restore original tracing data binary format, improve ABI kmemtrace: kmemtrace_alloc() must fill type_id kmemtrace: use tracepoints kmemtrace, rcu: don't include unnecessary headers, allow kmemtrace w/ tracepoints kmemtrace, rcu: fix rcupreempt.c data structure dependencies kmemtrace, rcu: fix rcu_tree_trace.c data structure dependencies kmemtrace, rcu: fix linux/rcutree.h and linux/rcuclassic.h dependencies kmemtrace, mm: fix slab.h dependency problem in mm/failslab.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_unlzma.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_bunzip2.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.c kmemtrace, squashfs: fix slab.h dependency problem in squasfs kmemtrace, befs: fix slab.h dependency problem kmemtrace, security: fix linux/key.h header file dependencies kmemtrace, fs: fix linux/fdtable.h header file dependencies kmemtrace, fs: uninline simple_transaction_set() kmemtrace, fs, security: move alloc_secdata() and free_secdata() to linux/security.h
2009-04-05Merge branch 'core/debugobjects' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/debugobjects' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: debugobjects: delay free of internal objects debugobjects: replace static objects when slab cache becomes available debug_objects: add boot-parameter toggle to turn object debugging off again
