path: root/lib
2016-07-06Introduce rb_replace_node_rcu()David Howells
Implement an RCU-safe variant of rb_replace_node() and rearrange rb_replace_node() to do things in the same order. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
2016-05-30lib/uuid.c: use correct offset in uuid parserBjørn Mork
Use '+ 0' and '+ 1' as offsets, like they were intended, instead of adding to the result. Fixes: 2b1b0d66704a ("lib/uuid.c: introduce a few more generic helpers") Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-30lib/uuid: add a test moduleAndy Shevchenko
It appears that somehow I missed a test of the latest UUID rework which landed in the kernel. Present a small test module to avoid such cases in the future. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-28Merge branch 'hash' of git://ftp.sciencehorizons.net/linuxLinus Torvalds
Pull string hash improvements from George Spelvin: "This series does several related things: - Makes the dcache hash (fs/namei.c) useful for general kernel use. (Thanks to Bruce for noticing the zero-length corner case) - Converts the string hashes in <linux/sunrpc/svcauth.h> to use the above. - Avoids 64-bit multiplies in hash_64() on 32-bit platforms. Two 32-bit multiplies will do well enough. - Rids the world of the bad hash multipliers in hash_32. This finishes the job started in commit 689de1d6ca95 ("Minimal fix-up of bad hashing behavior of hash_64()") The vast majority of Linux architectures have hardware support for 32x32-bit multiply and so derive no benefit from "simplified" multipliers. The few processors that do not (68000, h8/300 and some models of Microblaze) have arch-specific implementations added. Those patches are last in the series. - Overhauls the dcache hash mixing. The patch in commit 0fed3ac866ea ("namei: Improve hash mixing if CONFIG_DCACHE_WORD_ACCESS") was an off-the-cuff suggestion. Replaced with a much more careful design that's simultaneously faster and better. (My own invention, as there was noting suitable in the literature I could find. Comments welcome!) - Modify the hash_name() loop to skip the initial HASH_MIX(). This would let us salt the hash if we ever wanted to. - Sort out partial_name_hash(). The hash function is declared as using a long state, even though it's truncated to 32 bits at the end and the extra internal state contributes nothing to the result. And some callers do odd things: - fs/hfs/string.c only allocates 32 bits of state - fs/hfsplus/unicode.c uses it to hash 16-bit unicode symbols not bytes - Modify bytemask_from_count to handle inputs of 1..sizeof(long) rather than 0..sizeof(long)-1. This would simplify users other than full_name_hash" Special thanks to Bruce Fields for testing and finding bugs in v1. (I learned some humbling lessons about "obviously correct" code.) On the arch-specific front, the m68k assembly has been tested in a standalone test harness, I've been in contact with the Microblaze maintainers who mostly don't care, as the hardware multiplier is never omitted in real-world applications, and I haven't heard anything from the H8/300 world" * 'hash' of git://ftp.sciencehorizons.net/linux: h8300: Add <asm/hash.h> microblaze: Add <asm/hash.h> m68k: Add <asm/hash.h> <linux/hash.h>: Add support for architecture-specific functions fs/namei.c: Improve dcache hash function Eliminate bad hash multipliers from hash_32() and hash_64() Change hash_64() return value to 32 bits <linux/sunrpc/svcauth.h>: Define hash_str() in terms of hashlen_string() fs/namei.c: Add hashlen_string() function Pull out string hash to <linux/stringhash.h>
2016-05-28<linux/hash.h>: Add support for architecture-specific functionsGeorge Spelvin
This is just the infrastructure; there are no users yet. This is modelled on CONFIG_ARCH_RANDOM; a CONFIG_ symbol declares the existence of <asm/hash.h>. That file may define its own versions of various functions, and define HAVE_* symbols (no CONFIG_ prefix!) to suppress the generic ones. Included is a self-test (in lib/test_hash.c) that verifies the basics. It is NOT in general required that the arch-specific functions compute the same thing as the generic, but if a HAVE_* symbol is defined with the value 1, then equality is tested. Signed-off-by: George Spelvin <linux@sciencehorizons.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Ungerer <gerg@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Philippe De Muyter <phdm@macq.eu> Cc: linux-m68k@lists.linux-m68k.org Cc: Alistair Francis <alistai@xilinx.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-h8-devel@lists.sourceforge.jp
2016-05-26dma-debug: avoid spinlock recursion when disabling dma-debugVille Syrjälä
With netconsole (at least) the pr_err("... disablingn") call can recurse back into the dma-debug code, where it'll try to grab free_entries_lock again. Avoid the problem by doing the printk after dropping the lock. Link: http://lkml.kernel.org/r/1463678421-18683-1-git-send-email-ville.syrjala@linux.intel.com Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-25Merge branch 'work.iov_iter' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs iov_iter regression fix from Al Viro: "Fix for braino in 'fold checks into iterate_and_advance()'" * 'work.iov_iter' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: do "fold checks into iterate_and_advance()" right
2016-05-25do "fold checks into iterate_and_advance()" rightAl Viro
the only case when we should skip the iterate_and_advance() guts is when nothing's left in the iterator, _not_ just when requested amount is 0. Said guts will do nothing in the latter case anyway; the problem we tried to deal with in the aforementioned commit is that when there's nothing left *and* the amount requested is 0, we might end up deferencing one iovec too many; the value we fetch from there is discarded in that case, but theoretically it might oops if the iovec array ends exactly at the end of page with the next page not mapped. Bailing out on zero size requested had an unexpected side effect - zero-length segment in the beginning of iovec array ended up throwing do_loop_readv_writev() into infinite spin; we do not advance past the empty segment at all. Reproducer is trivial: echo '#include <sys/uio.h>' >a.c echo 'main() {char c; struct iovec v[] = {{&c,0},{&c,1}}; readv(0,v,2);}' >>a.c cc a.c && ./a.out </proc/uptime which should end up with the process not hanging. Probably ought to go into LTP or xfstests... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-23kgdb: depends on VTJiri Slaby
With VT=n, the kernel build fails with: drivers/built-in.o: In function `kgdboc_pre_exp_handler': kgdboc.c:(.text+0x7b5aa): undefined reference to `fg_console' kgdboc.c:(.text+0x7b5ce): undefined reference to `vc_cons' kgdboc.c:(.text+0x7b5d5): undefined reference to `vc_cons' kgdboc.o is built when KGDB_SERIAL_CONSOLE is set. So make KGDB_SERIAL_CONSOLE depend on HW_CONSOLE which includes those symbols. Link: http://lkml.kernel.org/r/1459412955-4696-1-git-send-email-jslaby@suse.cz Signed-off-by: Jiri Slaby <jslaby@suse.cz> Reported-by: "Jim Davis" <jim.epost@gmail.com> Acked-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge more updates from Andrew Morton: - the rest of MM - KASAN updates - procfs updates - exit, fork updates - printk updates - lib/ updates - radix-tree testsuite updates - checkpatch updates - kprobes updates - a few other misc bits * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (162 commits) samples/kprobes: print out the symbol name for the hooks samples/kprobes: add a new module parameter kprobes: add the "tls" argument for j_do_fork init/main.c: simplify initcall_blacklisted() fs/efs/super.c: fix return value checkpatch: improve --git <commit-count> shortcut checkpatch: reduce number of `git log` calls with --git checkpatch: add support to check already applied git commits checkpatch: add --list-types to show message types to show or ignore checkpatch: advertise the --fix and --fix-inplace options more checkpatch: whine about ACCESS_ONCE checkpatch: add test for keywords not starting on tabstops checkpatch: improve CONSTANT_COMPARISON test for structure members checkpatch: add PREFER_IS_ENABLED test lib/GCD.c: use binary GCD algorithm instead of Euclidean radix-tree: free up the bottom bit of exceptional entries for reuse dax: move RADIX_DAX_ definitions to dax.c radix-tree: make radix_tree_descend() more useful radix-tree: introduce radix_tree_replace_clear_tags() radix-tree: tidy up __radix_tree_create() ...
2016-05-20Merge tag 'driver-core-4.7-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here's the "big" driver core update for 4.7-rc1. Mostly just debugfs changes, the long-known and messy races with removing debugfs files should be fixed thanks to the great work of Nicolai Stange. We also have some isa updates in here (the x86 maintainers told me to take it through this tree), a new warning when we run out of dynamic char major numbers, and a few other assorted changes, details in the shortlog. All have been in linux-next for some time with no reported issues" * tag 'driver-core-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (32 commits) Revert "base: dd: don't remove driver_data in -EPROBE_DEFER case" gpio: ws16c48: Utilize the ISA bus driver gpio: 104-idio-16: Utilize the ISA bus driver gpio: 104-idi-48: Utilize the ISA bus driver gpio: 104-dio-48e: Utilize the ISA bus driver watchdog: ebc-c384_wdt: Utilize the ISA bus driver iio: stx104: Utilize the module_isa_driver and max_num_isa_dev macros iio: stx104: Add X86 dependency to STX104 Kconfig option Documentation: Add ISA bus driver documentation isa: Implement the max_num_isa_dev macro isa: Implement the module_isa_driver macro pnp: pnpbios: Add explicit X86_32 dependency to PNPBIOS isa: Decouple X86_32 dependency from the ISA Kconfig option driver-core: use 'dev' argument in dev_dbg_ratelimited stub base: dd: don't remove driver_data in -EPROBE_DEFER case kernfs: Move faulting copy_user operations outside of the mutex devcoredump: add scatterlist support debugfs: unproxify files created through debugfs_create_u32_array() debugfs: unproxify files created through debugfs_create_blob() debugfs: unproxify files created through debugfs_create_bool() ...
2016-05-20lib/GCD.c: use binary GCD algorithm instead of EuclideanZhaoxiu Zeng
The binary GCD algorithm is based on the following facts: 1. If a and b are all evens, then gcd(a,b) = 2 * gcd(a/2, b/2) 2. If a is even and b is odd, then gcd(a,b) = gcd(a/2, b) 3. If a and b are all odds, then gcd(a,b) = gcd((a-b)/2, b) = gcd((a+b)/2, b) Even on x86 machines with reasonable division hardware, the binary algorithm runs about 25% faster (80% the execution time) than the division-based Euclidian algorithm. On platforms like Alpha and ARMv6 where division is a function call to emulation code, it's even more significant. There are two variants of the code here, depending on whether a fast __ffs (find least significant set bit) instruction is available. This allows the unpredictable branches in the bit-at-a-time shifting loop to be eliminated. If fast __ffs is not available, the "even/odd" GCD variant is used. I use the following code to benchmark: #include <stdio.h> #include <stdlib.h> #include <stdint.h> #include <string.h> #include <time.h> #include <unistd.h> #define swap(a, b) \ do { \ a ^= b; \ b ^= a; \ a ^= b; \ } while (0) unsigned long gcd0(unsigned long a, unsigned long b) { unsigned long r; if (a < b) { swap(a, b); } if (b == 0) return a; while ((r = a % b) != 0) { a = b; b = r; } return b; } unsigned long gcd1(unsigned long a, unsigned long b) { unsigned long r = a | b; if (!a || !b) return r; b >>= __builtin_ctzl(b); for (;;) { a >>= __builtin_ctzl(a); if (a == b) return a << __builtin_ctzl(r); if (a < b) swap(a, b); a -= b; } } unsigned long gcd2(unsigned long a, unsigned long b) { unsigned long r = a | b; if (!a || !b) return r; r &= -r; while (!(b & r)) b >>= 1; for (;;) { while (!(a & r)) a >>= 1; if (a == b) return a; if (a < b) swap(a, b); a -= b; a >>= 1; if (a & r) a += b; a >>= 1; } } unsigned long gcd3(unsigned long a, unsigned long b) { unsigned long r = a | b; if (!a || !b) return r; b >>= __builtin_ctzl(b); if (b == 1) return r & -r; for (;;) { a >>= __builtin_ctzl(a); if (a == 1) return r & -r; if (a == b) return a << __builtin_ctzl(r); if (a < b) swap(a, b); a -= b; } } unsigned long gcd4(unsigned long a, unsigned long b) { unsigned long r = a | b; if (!a || !b) return r; r &= -r; while (!(b & r)) b >>= 1; if (b == r) return r; for (;;) { while (!(a & r)) a >>= 1; if (a == r) return r; if (a == b) return a; if (a < b) swap(a, b); a -= b; a >>= 1; if (a & r) a += b; a >>= 1; } } static unsigned long (*gcd_func[])(unsigned long a, unsigned long b) = { gcd0, gcd1, gcd2, gcd3, gcd4, }; #define TEST_ENTRIES (sizeof(gcd_func) / sizeof(gcd_func[0])) #if defined(__x86_64__) #define rdtscll(val) do { \ unsigned long __a,__d; \ __asm__ __volatile__("rdtsc" : "=a" (__a), "=d" (__d)); \ (val) = ((unsigned long long)__a) | (((unsigned long long)__d)<<32); \ } while(0) static unsigned long long benchmark_gcd_func(unsigned long (*gcd)(unsigned long, unsigned long), unsigned long a, unsigned long b, unsigned long *res) { unsigned long long start, end; unsigned long long ret; unsigned long gcd_res; rdtscll(start); gcd_res = gcd(a, b); rdtscll(end); if (end >= start) ret = end - start; else ret = ~0ULL - start + 1 + end; *res = gcd_res; return ret; } #else static inline struct timespec read_time(void) { struct timespec time; clock_gettime(CLOCK_PROCESS_CPUTIME_ID, &time); return time; } static inline unsigned long long diff_time(struct timespec start, struct timespec end) { struct timespec temp; if ((end.tv_nsec - start.tv_nsec) < 0) { temp.tv_sec = end.tv_sec - start.tv_sec - 1; temp.tv_nsec = 1000000000ULL + end.tv_nsec - start.tv_nsec; } else { temp.tv_sec = end.tv_sec - start.tv_sec; temp.tv_nsec = end.tv_nsec - start.tv_nsec; } return temp.tv_sec * 1000000000ULL + temp.tv_nsec; } static unsigned long long benchmark_gcd_func(unsigned long (*gcd)(unsigned long, unsigned long), unsigned long a, unsigned long b, unsigned long *res) { struct timespec start, end; unsigned long gcd_res; start = read_time(); gcd_res = gcd(a, b); end = read_time(); *res = gcd_res; return diff_time(start, end); } #endif static inline unsigned long get_rand() { if (sizeof(long) == 8) return (unsigned long)rand() << 32 | rand(); else return rand(); } int main(int argc, char **argv) { unsigned int seed = time(0); int loops = 100; int repeats = 1000; unsigned long (*res)[TEST_ENTRIES]; unsigned long long elapsed[TEST_ENTRIES]; int i, j, k; for (;;) { int opt = getopt(argc, argv, "n:r:s:"); /* End condition always first */ if (opt == -1) break; switch (opt) { case 'n': loops = atoi(optarg); break; case 'r': repeats = atoi(optarg); break; case 's': seed = strtoul(optarg, NULL, 10); break; default: /* You won't actually get here. */ break; } } res = malloc(sizeof(unsigned long) * TEST_ENTRIES * loops); memset(elapsed, 0, sizeof(elapsed)); srand(seed); for (j = 0; j < loops; j++) { unsigned long a = get_rand(); /* Do we have args? */ unsigned long b = argc > optind ? strtoul(argv[optind], NULL, 10) : get_rand(); unsigned long long min_elapsed[TEST_ENTRIES]; for (k = 0; k < repeats; k++) { for (i = 0; i < TEST_ENTRIES; i++) { unsigned long long tmp = benchmark_gcd_func(gcd_func[i], a, b, &res[j][i]); if (k == 0 || min_elapsed[i] > tmp) min_elapsed[i] = tmp; } } for (i = 0; i < TEST_ENTRIES; i++) elapsed[i] += min_elapsed[i]; } for (i = 0; i < TEST_ENTRIES; i++) printf("gcd%d: elapsed %llu\n", i, elapsed[i]); k = 0; srand(seed); for (j = 0; j < loops; j++) { unsigned long a = get_rand(); unsigned long b = argc > optind ? strtoul(argv[optind], NULL, 10) : get_rand(); for (i = 1; i < TEST_ENTRIES; i++) { if (res[j][i] != res[j][0]) break; } if (i < TEST_ENTRIES) { if (k == 0) { k = 1; fprintf(stderr, "Error:\n"); } fprintf(stderr, "gcd(%lu, %lu): ", a, b); for (i = 0; i < TEST_ENTRIES; i++) fprintf(stderr, "%ld%s", res[j][i], i < TEST_ENTRIES - 1 ? ", " : "\n"); } } if (k == 0) fprintf(stderr, "PASS\n"); free(res); return 0; } Compiled with "-O2", on "VirtualBox 4.4.0-22-generic #38-Ubuntu x86_64" got: zhaoxiuzeng@zhaoxiuzeng-VirtualBox:~/develop$ ./gcd -r 500000 -n 10 gcd0: elapsed 10174 gcd1: elapsed 2120 gcd2: elapsed 2902 gcd3: elapsed 2039 gcd4: elapsed 2812 PASS zhaoxiuzeng@zhaoxiuzeng-VirtualBox:~/develop$ ./gcd -r 500000 -n 10 gcd0: elapsed 9309 gcd1: elapsed 2280 gcd2: elapsed 2822 gcd3: elapsed 2217 gcd4: elapsed 2710 PASS zhaoxiuzeng@zhaoxiuzeng-VirtualBox:~/develop$ ./gcd -r 500000 -n 10 gcd0: elapsed 9589 gcd1: elapsed 2098 gcd2: elapsed 2815 gcd3: elapsed 2030 gcd4: elapsed 2718 PASS zhaoxiuzeng@zhaoxiuzeng-VirtualBox:~/develop$ ./gcd -r 500000 -n 10 gcd0: elapsed 9914 gcd1: elapsed 2309 gcd2: elapsed 2779 gcd3: elapsed 2228 gcd4: elapsed 2709 PASS [akpm@linux-foundation.org: avoid #defining a CONFIG_ variable] Signed-off-by: Zhaoxiu Zeng <zhaoxiu.zeng@gmail.com> Signed-off-by: George Spelvin <linux@horizon.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: make radix_tree_descend() more usefulMatthew Wilcox
Now that the shift amount is stored in the node, radix_tree_descend() can calculate offset itself from index, which removes several lines of code from each of the tree walkers. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: introduce radix_tree_replace_clear_tags()Matthew Wilcox
In addition to replacing the entry, we also clear all associated tags. This is really a one-off special for page_cache_tree_delete() which had far too much detailed knowledge about how the radix tree works. For efficiency, factor node_tag_clear() out of radix_tree_tag_clear() It can be used by radix_tree_delete_item() as well as radix_tree_replace_clear_tags(). Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: tidy up __radix_tree_create()Matthew Wilcox
1. Rename the existing variable 'slot' to 'child'. 2. Introduce a new variable called 'slot' which is the address of the slot we're dealing with. This lets us simplify the tree insertion, and removes the recalculation of 'slot' at the end of the function. 3. Using 'slot' in the sibling pointer insertion part makes the code more readable. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: tidy up range_tag_if_taggedMatthew Wilcox
Convert radix_tree_range_tag_if_tagged to name the nodes parent, node and child instead of node & slot. Use parent->offset instead of playing games with 'upindex'. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: tidy up next_chunkMatthew Wilcox
Convert radix_tree_next_chunk to use 'child' instead of 'slot' as the name of the child node. Also use node_maxindex() where it makes sense. The 'rnode' variable was unnecessary; it doesn't overlap in usage with 'node', so we can just use 'node' the whole way through the function. Improve the testcase to start the walk from every index in the carefully constructed tree, and to accept any index within the range covered by the entry. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: change naming conventions in radix_tree_shrinkMatthew Wilcox
Use the more standard 'node' and 'child' instead of 'to_free' and 'slot'. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: rename radix_tree_is_indirect_ptr()Matthew Wilcox
As with indirect_to_ptr(), ptr_to_indirect() and RADIX_TREE_INDIRECT_PTR, change radix_tree_is_indirect_ptr() to radix_tree_is_internal_node(). Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: rename indirect_to_ptr() to entry_to_node()Matthew Wilcox
Mirrors the earlier commit introducing node_to_entry(). Also change the type returned to be a struct radix_tree_node pointer. That lets us simplify a couple of places in the radix tree shrink & extend paths where we could convert an entry into a pointer, modify the node, then convert the pointer back into an entry. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: rename ptr_to_indirect() to node_to_entry()Matthew Wilcox
ptr_to_indirect() was a bad name. What it really means is "Convert this pointer to a node into an entry suitable for storing in the radix tree". So node_to_entry() seemed like a better name. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: rename INDIRECT_PTR to INTERNAL_NODEMatthew Wilcox
The name RADIX_TREE_INDIRECT_PTR doesn't really match the meaning. RADIX_TREE_INTERNAL_NODE is a better name. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: remove root->heightMatthew Wilcox
The only remaining references to root->height were in extend and shrink, where it was updated. Now we can remove it entirely. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: remove a use of root->height from delete_nodeMatthew Wilcox
If radix_tree_shrink returns whether it managed to shrink, then __radix_tree_delete_node doesn't ned to query the tree to find out whether it did any work or not. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: replace node->height with node->shiftMatthew Wilcox
node->shift represents the shift necessary for looking in the slots array at this level. It is equal to the old (node->height - 1) * RADIX_TREE_MAP_SHIFT. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: split node->path into offset and heightMatthew Wilcox
Neither piece of information we're storing in node->path can be larger than 64, so store each in its own unsigned char instead of shifting and masking to store them both in an unsigned int. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: miscellaneous fixesMatthew Wilcox
Typos, whitespace, grammar, line length, using the correct types, etc. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: add copyright statementsMatthew Wilcox
The multiorder support is a sufficiently large feature to be worth adding copyrigt lines for. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: fix radix_tree_dump() for multi-order entriesRoss Zwisler
- Print which indices are covered by every leaf entry - Print sibling entries - Print the node pointer instead of the slot entry - Build by default in userspace, and make it accessible to the test-suite Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: fix radix_tree_range_tag_if_tagged() for multiorder entriesMatthew Wilcox
I had previously decided that tagging a single multiorder entry would count as tagging 2^order entries for the purposes of 'nr_to_tag'. I now believe that decision to be a mistake, and it should count as a single entry. That's more likely to be what callers expect. When walking back up the tree from a newly-tagged entry, the current code assumed we were starting from the lowest level of the tree; if we have a multiorder entry with an order at least RADIX_TREE_MAP_SHIFT in size then we need to shift the index by 'shift' before we start walking back up the tree, or we will end up not setting tags on higher entries, and then mistakenly thinking that entries below a certain point in the tree are not tagged. If the first index we examine is a sibling entry of a tagged multiorder entry, we were not tagging it. We need to examine the canonical entry, and the easiest way to do that is to use radix_tree_descend(). We then have to skip over sibling slots when looking for the next entry in the tree or we will end up walking back to the canonical entry. Add several tests for radix_tree_range_tag_if_tagged(). Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: rewrite radix_tree_locate_itemMatthew Wilcox
Use the new multi-order support functions to rewrite radix_tree_locate_item(). Modify the locate tests to test multiorder entries too. [hughd@google.com: radix_tree_locate_item() is often returning the wrong index] Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1605012108490.1166@eggly.anvils Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: fix radix_tree_create for sibling entriesMatthew Wilcox
If the radix tree user attempted to insert a colliding entry with an existing multiorder entry, then radix_tree_create() could encounter a sibling entry when walking down the tree to look for a slot. Use radix_tree_descend() to fix the problem, and add a test-case to make sure the problem doesn't come back in future. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: rewrite radix_tree_tag_getRoss Zwisler
Use the new multi-order support functions to rewrite radix_tree_tag_get() Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: rewrite radix_tree_tag_clearRoss Zwisler
Use the new multi-order support functions to rewrite radix_tree_tag_clear() Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: rewrite radix_tree_tag_setRoss Zwisler
Use the new multi-order support functions to rewrite radix_tree_tag_set() Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: add support for multi-order iteratingRoss Zwisler
This enables the macros radix_tree_for_each_slot() and friends to be used with multi-order entries. The way that this works is that we treat all entries in a given slots[] array as a single chunk. If the index given to radix_tree_next_chunk() happens to point us to a sibling entry, we will back up iter->index so that it points to the canonical entry, and that will be the place where we start our iteration. As we're processing a chunk in radix_tree_next_slot(), we process canonical entries, skip over sibling entries, and restart the chunk lookup if we find a non-sibling indirect pointer. This drops back to the radix_tree_next_chunk() code, which will re-walk the tree and look for another chunk. This allows us to properly handle multi-order entries mixed with other entries that are at various heights in the radix tree. Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: fix multiorder BUG_ON in radix_tree_insertMatthew Wilcox
These BUG_ON tests are to ensure that all the tags are clear when inserting a new entry. If we insert a multiorder entry, we'll end up looking at the tags for a different node, and so the BUG_ON can end up triggering spuriously. Also, we now have three tags, not two, so check all three are clear, and check all the root tags with a single call to BUG_ON since the bits are stored contiguously. Include a test-case to ensure this problem does not reoccur. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: rewrite __radix_tree_lookupMatthew Wilcox
Use the new multi-order support functions to rewrite __radix_tree_lookup() Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: fix several shrinking bugs with multiorder entriesMatthew Wilcox
Setting the indirect bit on the user data entry used to be unambiguous because the tree walking code knew not to expect internal nodes in the last level of the tree. Multiorder entries can appear at any level of the tree, and a leaf with the indirect bit set is indistinguishable from a pointer to a node. Introduce a special entry (RADIX_TREE_RETRY) which is neither a valid user entry, nor a valid pointer to a node. The radix_tree_deref_retry() function continues to work the same way, but tree walking code can distinguish it from a pointer to a node. Also fix the condition for setting slot->parent to NULL; it does not matter what height the tree is, it only matters whether slot is an indirect pointer. Move this code above the comment which is referring to the assignment to root->rnode. Also fix the condition for preventing the tree from shrinking to a single entry if it's a multiorder entry. Add a test-case to the test suite that checks that the tree goes back down to its original height after an item is inserted & deleted from a higher index in the tree. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: fix extending the tree for multi-order entries at offset 0Matthew Wilcox
The current code will insert entries at each level, as if we're going to add a new entry at the bottom level, so we then get an -EEXIST when we try to insert the entry into the tree. The best way to fix this is to not check 'order' when inserting into an empty tree. We still need to 'extend' the tree to the height necessary for the maximum index corresponding to this entry, so pass that value to radix_tree_extend() rather than the index we're asked to create, or we won't create a tree that's deep enough. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: introduce radix_tree_load_root()Matthew Wilcox
All the tree walking functions start with some variant of this code; centralise it in one place so we're not chasing subtly different bugs everywhere. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: remove restriction on multi-order entriesMatthew Wilcox
Now that sibling pointers are handled explicitly, there is no purpose served by restricting the order to be >= RADIX_TREE_MAP_SHIFT. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: fix deleting a multi-order entry through an aliasMatthew Wilcox
If we deleted an entry through an index which looked up a sibling pointer, we'd end up zeroing out the wrong slots in the node. Use get_slot_offset() to find the right slot. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: fix sibling entry insertionMatthew Wilcox
The subtraction was the wrong way round, leading to undefined behaviour (shift by an amount larger than the size of the type). Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20radix-tree: add missing sibling entry functionalityMatthew Wilcox
The code I previously added to enable multiorder radix tree entries was untested and therefore buggy. This commit adds the support functions that Ross and I decided were necessary over a four-week period of iterating various designs. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20raxix-tree: introduce CONFIG_RADIX_TREE_MULTIORDERMatthew Wilcox
I've been receiving increasingly concerned notes from 0day about how much my recent changes have been bloating the radix tree. Make it happier by only including multiorder support if CONFIG_TRANSPARENT_HUGEPAGES is set. This is an independent Kconfig option, so other radix tree users can also set it if they have a need. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Jan Kara <jack@suse.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20lib/uuid.c: remove FSF addressAndy Shevchenko
There is no point in keeping an address in the file since it's subject to change. While here, update Intel Copyright years. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk> Cc: Dmitry Kasatkin <dmitry.kasatkin@gmail.com> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20lib/uuid.c: introduce a few more generic helpersAndy Shevchenko
There are new helpers in this patch: uuid_is_valid checks if a UUID is valid uuid_be_to_bin converts from string to binary (big endian) uuid_le_to_bin converts from string to binary (little endian) They will be used in future, i.e. in the following patches in the series. This also moves the indices arrays to lib/uuid.c to be shared accross modules. [andriy.shevchenko@linux.intel.com: fix typo] Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk> Cc: Dmitry Kasatkin <dmitry.kasatkin@gmail.com> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20lib/uuid.c: move generate_random_uuid() to uuid.cAndy Shevchenko
Let's gather the UUID related functions under one hood. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk> Cc: Dmitry Kasatkin <dmitry.kasatkin@gmail.com> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20lib/vsprintf: simplify UUID printingAndy Shevchenko
There are few functions here and there along with type definitions that provide UUID API. This series consolidates everything under one hood and converts current users. This has been tested for a while internally, however it doesn't mean we covered all possible cases (especially accuracy of UUID constants after conversion). So, please test this as much as you can and provide your tag. We appreciate the effort. The ACPI conversion is postponed for now to sort more generic things out first. This patch (of 9): Since we have hex_byte_pack_upper() we may use it directly and avoid second loop. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk> Cc: Dmitry Kasatkin <dmitry.kasatkin@gmail.com> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
