path: root/lib
2018-08-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) ICE, E1000, IGB, IXGBE, and I40E bug fixes from the Intel folks. 2) Better fix for AB-BA deadlock in packet scheduler code, from Cong Wang. 3) bpf sockmap fixes (zero sized key handling, etc.) from Daniel Borkmann. 4) Send zero IPID in TCP resets and SYN-RECV state ACKs, to prevent attackers using it as a side-channel. From Eric Dumazet. 5) Memory leak in mediatek bluetooth driver, from Gustavo A. R. Silva. 6) Hook up rt->dst.input of ipv6 anycast routes properly, from Hangbin Liu. 7) hns and hns3 bug fixes from Huazhong Tan. 8) Fix RIF leak in mlxsw driver, from Ido Schimmel. 9) iova range check fix in vhost, from Jason Wang. 10) Fix hang in do_tcp_sendpages() with tls, from John Fastabend. 11) More r8152 chips need to disable RX aggregation, from Kai-Heng Feng. 12) Memory exposure in TCA_U32_SEL handling, from Kees Cook. 13) TCP BBR congestion control fixes from Kevin Yang. 14) hv_netvsc, ignore non-PCI devices, from Stephen Hemminger. 15) qed driver fixes from Tomer Tayar. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (77 commits) net: sched: Fix memory exposure from short TCA_U32_SEL qed: fix spelling mistake "comparsion" -> "comparison" vhost: correctly check the iova range when waking virtqueue qlge: Fix netdev features configuration. net: macb: do not disable MDIO bus at open/close time Revert "net: stmmac: fix build failure due to missing COMMON_CLK dependency" net: macb: Fix regression breaking non-MDIO fixed-link PHYs mlxsw: spectrum_switchdev: Do not leak RIFs when removing bridge i40e: fix condition of WARN_ONCE for stat strings i40e: Fix for Tx timeouts when interface is brought up if DCB is enabled ixgbe: fix driver behaviour after issuing VFLR ixgbe: Prevent unsupported configurations with XDP ixgbe: Replace GFP_ATOMIC with GFP_KERNEL igb: Replace mdelay() with msleep() in igb_integrated_phy_loopback() igb: Replace GFP_ATOMIC with GFP_KERNEL in igb_sw_init() igb: Use an advanced ctx descriptor for launchtime e1000: ensure to free old tx/rx rings in set_ringparam() e1000: check on netif_running() before calling e1000_up() ixgb: use dma_zalloc_coherent instead of allocator/memset ice: Trivial formatting fixes ...
2018-08-26Merge branch 'ida-4.19' of git://git.infradead.org/users/willy/linux-daxLinus Torvalds
Pull IDA updates from Matthew Wilcox: "A better IDA API: id = ida_alloc(ida, GFP_xxx); ida_free(ida, id); rather than the cumbersome ida_simple_get(), ida_simple_remove(). The new IDA API is similar to ida_simple_get() but better named. The internal restructuring of the IDA code removes the bitmap preallocation nonsense. I hope the net -200 lines of code is convincing" * 'ida-4.19' of git://git.infradead.org/users/willy/linux-dax: (29 commits) ida: Change ida_get_new_above to return the id ida: Remove old API test_ida: check_ida_destroy and check_ida_alloc test_ida: Convert check_ida_conv to new API test_ida: Move ida_check_max test_ida: Move ida_check_leaf idr-test: Convert ida_check_nomem to new API ida: Start new test_ida module target/iscsi: Allocate session IDs from an IDA iscsi target: fix session creation failure handling drm/vmwgfx: Convert to new IDA API dmaengine: Convert to new IDA API ppc: Convert vas ID allocation to new IDA API media: Convert entity ID allocation to new IDA API ppc: Convert mmu context allocation to new IDA API Convert net_namespace to new IDA API cb710: Convert to new IDA API rsxx: Convert to new IDA API osd: Convert to new IDA API sd: Convert to new IDA API ...
2018-08-23lib/fonts: convert comments to utf-8Arnd Bergmann
The font files contain bit masks for characters in the cp437 character set, and comments showing what character this is supposed to be. This only makes sense when the terminal used to view the files is set to the same codepage, but all other files in the kernel now use utf-8 encoding. This changes those comments to utf-8 as well, for consistency. Link: http://lkml.kernel.org/r/20180724111600.4158975-3-arnd@arndb.de Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-22lib/rhashtable: guarantee initial hashtable allocationDavidlohr Bueso
rhashtable_init() may fail due to -ENOMEM, thus making the entire api unusable. This patch removes this scenario, however unlikely. In order to guarantee memory allocation, this patch always ends up doing GFP_KERNEL|__GFP_NOFAIL for both the tbl as well as alloc_bucket_spinlocks(). Upon the first table allocation failure, we shrink the size to the smallest value that makes sense and retry with __GFP_NOFAIL semantics. With the defaults, this means that from 64 buckets, we retry with only 4. Any later issues regarding performance due to collisions or larger table resizing (when more memory becomes available) is the least of our problems. Link: http://lkml.kernel.org/r/20180712185241.4017-9-manfred@colorfullife.com Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Kees Cook <keescook@chromium.org> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-22lib/rhashtable: simplify bucket_table_alloc()Davidlohr Bueso
As of ce91f6ee5b3b ("mm: kvmalloc does not fallback to vmalloc for incompatible gfp flags") we can simplify the caller and trust kvzalloc() to just do the right thing. For the case of the GFP_ATOMIC context, we can drop the __GFP_NORETRY flag for obvious reasons, and for the __GFP_NOWARN case, however, it is changed such that the caller passes the flag instead of making bucket_table_alloc() handle it. This slightly changes the gfp flags passed on to nested_table_alloc() as it will now also use GFP_ATOMIC | __GFP_NOWARN. However, I consider this a positive consequence as for the same reasons we want nowarn semantics in bucket_table_alloc(). [manfred@colorfullife.com: commit id extended to 12 digits, line wraps updated] Link: http://lkml.kernel.org/r/20180712185241.4017-8-manfred@colorfullife.com Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Kees Cook <keescook@chromium.org> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-22lib/test_hexdump.c: fix failure on big endian cpuChristophe Leroy
On a big endian cpu, test_hexdump fails as follows. The logs show that bytes are expected in reversed order. [...] test_hexdump: Len: 24 buflen: 130 strlen: 97 test_hexdump: Result: 97 'be32db7b 0a1893b2 70bac424 7d83349b a69c31ad 9c0face9 .2.{....p..$}.4...1.....' test_hexdump: Expect: 97 '7bdb32be b293180a 24c4ba70 9b34837d ad319ca6 e9ac0f9c .2.{....p..$}.4...1.....' test_hexdump: Len: 8 buflen: 130 strlen: 77 test_hexdump: Result: 77 'be32db7b0a1893b2 .2.{....' test_hexdump: Expect: 77 'b293180a7bdb32be .2.{....' test_hexdump: Len: 6 buflen: 131 strlen: 87 test_hexdump: Result: 87 'be32 db7b 0a18 .2.{..' test_hexdump: Expect: 87 '32be 7bdb 180a .2.{..' test_hexdump: Len: 24 buflen: 131 strlen: 97 test_hexdump: Result: 97 'be32db7b 0a1893b2 70bac424 7d83349b a69c31ad 9c0face9 .2.{....p..$}.4...1.....' test_hexdump: Expect: 97 '7bdb32be b293180a 24c4ba70 9b34837d ad319ca6 e9ac0f9c .2.{....p..$}.4...1.....' test_hexdump: Len: 32 buflen: 131 strlen: 101 test_hexdump: Result: 101 'be32db7b0a1893b2 70bac4247d83349b a69c31ad9c0face9 4cd1199943b1af0c .2.{....p..$}.4...1.....L...C...' test_hexdump: Expect: 101 'b293180a7bdb32be 9b34837d24c4ba70 e9ac0f9cad319ca6 0cafb1439919d14c .2.{....p..$}.4...1.....L...C...' test_hexdump: failed 801 out of 1184 tests This patch fixes it. Link: http://lkml.kernel.org/r/f3112437f62c2f48300535510918e8be1dceacfb.1533610877.git.christophe.leroy@c-s.fr Fixes: 64d1d77a44697 ("hexdump: introduce test suite") Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: rashmica <rashmicy@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-22lib/Kconfig: remove 'default n' for testsAndy Shevchenko
It seems contributors follow the style of Kconfig entries where explicit 'default n' is present. The default 'default' is 'n' already, thus, drop these lines from Kconfig to make it more clear. Link: http://lkml.kernel.org/r/20180719085131.79541-1-andriy.shevchenko@linux.intel.com Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Coly Li <colyli@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-22lib: add crc64 calculation routinesColy Li
Patch series "add crc64 calculation as kernel library", v5. This patchset adds basic implementation of crc64 calculation as a Linux kernel library. Since bcache already does crc64 by itself, this patchset also modifies bcache code to use the new crc64 library routine. Currently bcache is the only user of crc64 calculation, another potential user is bcachefs which is on the way to be in mainline kernel. Therefore it makes sense to make crc64 calculation to be a public library. bcache uses crc64 as storage checksum, if a change of crc lib routines results an inconsistent result, the unmatched checksum may make bcache 'think' the on-disk is corrupted, such a change should be avoided or detected as early as possible. Therefore a patch is being prepared which adds a crc test framework, to check consistency of different calculations. This patch (of 2): Add the re-write crc64 calculation routines for Linux kernel. The CRC64 polynomical arithmetic follows ECMA-182 specification, inspired by CRC paper of Dr. Ross N. Williams (see http://www.ross.net/crc/download/crc_v3.txt) and other public domain implementations. All the changes work in this way, - When Linux kernel is built, host program lib/gen_crc64table.c will be compiled to lib/gen_crc64table and executed. - The output of gen_crc64table execution is an array called as lookup table (a.k.a POLY 0x42f0e1eba9ea369) which contain 256 64-bit long numbers, this table is dumped into header file lib/crc64table.h. - Then the header file is included by lib/crc64.c for normal 64bit crc calculation. - Function declaration of the crc64 calculation routines is placed in include/linux/crc64.h Currently bcache is the only user of crc64_be(), another potential user is bcachefs which is on the way to be in mainline kernel. Therefore it makes sense to move crc64 calculation into lib/crc64.c as public code. [colyli@suse.de: fix review comments from v4] Link: http://lkml.kernel.org/r/20180726053352.2781-2-colyli@suse.de Link: http://lkml.kernel.org/r/20180718165545.1622-2-colyli@suse.de Signed-off-by: Coly Li <colyli@suse.de> Co-developed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Michael Lyle <mlyle@lyle.org> Cc: Kent Overstreet <kent.overstreet@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Kate Stewart <kstewart@linuxfoundation.org> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Noah Massey <noah.massey@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-22lib/test_debug_virtual.c: make struct pointer foo staticColin Ian King
The pointer foo is local to the source and does not need to be in global scope, so make it static. Cleans up sparse warning: symbol 'foo' was not declared. Should it be static? Link: http://lkml.kernel.org/r/20180624112206.5722-1-colin.king@canonical.com Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-22lib/bitmap.c: drop unnecessary 0 check for u32 array operationsAndy Shevchenko
nbits == 0 is safe to be supplied to the function body, so remove unnecessary checks in bitmap_to_arr32() and bitmap_from_arr32(). Link: http://lkml.kernel.org/r/20180531131914.44352-1-andriy.shevchenko@linux.intel.com Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Yury Norov <ynorov@caviumnetworks.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-21ida: Change ida_get_new_above to return the idMatthew Wilcox
This calling convention makes more sense for the implementation as well as the callers. It even shaves 32 bytes off the compiled code size. Signed-off-by: Matthew Wilcox <willy@infradead.org>
2018-08-21ida: Remove old APIMatthew Wilcox
Delete ida_pre_get(), ida_get_new(), ida_get_new_above() and ida_remove() from the public API. Some of these functions still exist as internal helpers, but they should not be called by consumers. Signed-off-by: Matthew Wilcox <willy@infradead.org>
2018-08-21test_ida: check_ida_destroy and check_ida_allocMatthew Wilcox
Move these tests from the userspace test-suite to the kernel test-suite. Also convert check_ida_random to the new API. Signed-off-by: Matthew Wilcox <willy@infradead.org>
2018-08-21test_ida: Convert check_ida_conv to new APIMatthew Wilcox
Move as much as possible to kernel space; leave the parts in user space that rely on checking memory allocation failures to detect the transition between an exceptional entry and a bitmap. Signed-off-by: Matthew Wilcox <willy@infradead.org>
2018-08-21test_ida: Move ida_check_maxMatthew Wilcox
Convert to new API and move to kernel space. Signed-off-by: Matthew Wilcox <willy@infradead.org>
2018-08-21test_ida: Move ida_check_leafMatthew Wilcox
Convert to new API and move to kernel space. Take the opportunity to test the situation a little more thoroughly (ie at different offsets). Signed-off-by: Matthew Wilcox <willy@infradead.org>
2018-08-21ida: Start new test_ida moduleMatthew Wilcox
Start transitioning the IDA tests into kernel space. Framework heavily cribbed from test_xarray.c. Signed-off-by: Matthew Wilcox <willy@infradead.org>
2018-08-21ida: Add new APIMatthew Wilcox
Add ida_alloc(), ida_alloc_min(), ida_alloc_max(), ida_alloc_range() and ida_free(). The ida_alloc_max() and ida_alloc_range() functions differ from ida_simple_get() in that they take an inclusive 'max' parameter instead of an exclusive 'end' parameter. Callers are about evenly split whether they'd like inclusive or exclusive parameters and 'max' is easier to document than 'end'. Change the IDA allocation to first attempt to allocate a bit using existing memory, and only allocate memory afterwards. Also change the behaviour of 'min' > INT_MAX from being a BUG() to returning -ENOSPC. Leave compatibility wrappers in place for ida_simple_get() and ida_simple_remove() to avoid changing all callers. Signed-off-by: Matthew Wilcox <willy@infradead.org>
2018-08-21ida: Lock the IDA in ida_destroyMatthew Wilcox
The user has no need to handle locking between ida_simple_get() and ida_simple_remove(). They shouldn't be forced to think about whether ida_destroy() might be called at the same time as any of their other IDA manipulation calls. Improve the documnetation while I'm in here. Signed-off-by: Matthew Wilcox <willy@infradead.org>
2018-08-21radix-tree: Fix UBSAN warningMatthew Wilcox
get_slot_offset() can be called with a NULL 'parent' argument. In this case, the calculated value will not be used, but calculating it is undefined. Rather than fixing the caller (__radix_tree_delete) to not call get_slot_offset(), make get_slot_offset() robust against being called with a NULL parent. Signed-off-by: Matthew Wilcox <willy@infradead.org>
2018-08-20rhashtable: remove duplicated include from rhashtable.cYue Haibing
Remove duplicated include. Signed-off-by: Yue Haibing <yuehaibing@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-08-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix races in IPVS, from Tan Hu. 2) Missing unbind in matchall classifier, from Hangbin Liu. 3) Missing act_ife action release, from Vlad Buslov. 4) Cure lockdep splats in ila, from Cong Wang. 5) veth queue leak on link delete, from Toshiaki Makita. 6) Disable isdn's IIOCDBGVAR ioctl, it exposes kernel addresses. From Kees Cook. 7) RCU usage fixup in XDP, from Tariq Toukan. 8) Two TCP ULP fixes from Daniel Borkmann. 9) r8169 needs REALTEK_PHY as a Kconfig dependency, from Heiner Kallweit. 10) Always take tcf_lock with BH disabled, otherwise we can deadlock with rate estimator code paths. From Vlad Buslov. 11) Don't use MSI-X on RTL8106e r8169 chips, they don't resume properly. From Jian-Hong Pan. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (41 commits) ip6_vti: fix creating fallback tunnel device for vti6 ip_vti: fix a null pointer deferrence when create vti fallback tunnel r8169: don't use MSI-X on RTL8106e net: lan743x_ptp: convert to ktime_get_clocktai_ts64 net: sched: always disable bh when taking tcf_lock ip6_vti: simplify stats handling in vti6_xmit bpf: fix redirect to map under tail calls r8169: add missing Kconfig dependency tools/bpf: fix bpf selftest test_cgroup_storage failure bpf, sockmap: fix sock_map_ctx_update_elem race with exist/noexist bpf, sockmap: fix map elem deletion race with smap_stop_sock bpf, sockmap: fix leakage of smap_psock_map_entry tcp, ulp: fix leftover icsk_ulp_ops preventing sock from reattach tcp, ulp: add alias for all ulp modules bpf: fix a rcu usage warning in bpf_prog_array_copy_core() samples/bpf: all XDP samples should unload xdp/bpf prog on SIGTERM net/xdp: Fix suspicious RCU usage warning net/mlx5e: Delete unneeded function argument Documentation: networking: ti-cpsw: correct cbs parameters for Eth1 100Mb isdn: Disable IIOCDBGVAR ...
2018-08-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: - a new driver for Rohm BU21029 touch controller - new bitmap APIs: bitmap_alloc, bitmap_zalloc and bitmap_free - updates to Atmel, eeti. pxrc and iforce drivers - assorted driver cleanups and fixes. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (57 commits) MAINTAINERS: Add PhoenixRC Flight Controller Adapter Input: do not use WARN() in input_alloc_absinfo() Input: mark expected switch fall-throughs Input: raydium_i2c_ts - use true and false for boolean values Input: evdev - switch to bitmap API Input: gpio-keys - switch to bitmap_zalloc() Input: elan_i2c_smbus - cast sizeof to int for comparison bitmap: Add bitmap_alloc(), bitmap_zalloc() and bitmap_free() md: Avoid namespace collision with bitmap API dm: Avoid namespace collision with bitmap API Input: pm8941-pwrkey - add resin entry Input: pm8941-pwrkey - abstract register offsets and event code Input: iforce - reorganize joystick configuration lists Input: atmel_mxt_ts - move completion to after config crc is updated Input: atmel_mxt_ts - don't report zero pressure from T9 Input: atmel_mxt_ts - zero terminate config firmware file Input: atmel_mxt_ts - refactor config update code to add context struct Input: atmel_mxt_ts - config CRC may start at T71 Input: atmel_mxt_ts - remove unnecessary debug on ENOMEM Input: atmel_mxt_ts - remove duplicate setup of ABS_MT_PRESSURE ...
2018-08-18deprecate the '__deprecated' attribute warnings entirely and for goodLinus Torvalds
We haven't had lots of deprecation warnings lately, but the rdma use of it made them flare up again. They are not useful. They annoy everybody, and nobody ever does anything about them, because it's always "somebody elses problem". And when people start thinking that warnings are normal, they stop looking at them, and the real warnings that mean something go unnoticed. If you want to get rid of a function, just get rid of it. Convert every user to the new world order. And if you can't do that, then don't annoy everybody else with your marking that says "I couldn't be bothered to fix this, so I'll just spam everybody elses build logs with warnings about my laziness". Make a kernelnewbies wiki page about things that could be cleaned up, write a blog post about it, or talk to people on the mailing lists. But don't add warnings to the kernel build about cleanup that you think should happen but you aren't doing yourself. Don't. Just don't. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-18Merge tag 'driver-core-4.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here are all of the driver core and related patches for 4.19-rc1. Nothing huge here, just a number of small cleanups and the ability to now stop the deferred probing after init happens. All of these have been in linux-next for a while with only a merge issue reported" * tag 'driver-core-4.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (21 commits) base: core: Remove WARN_ON from link dependencies check drivers/base: stop new probing during shutdown drivers: core: Remove glue dirs from sysfs earlier driver core: remove unnecessary function extern declare sysfs.h: fix non-kernel-doc comment PM / Domains: Stop deferring probe at the end of initcall iommu: Remove IOMMU_OF_DECLARE iommu: Stop deferring probe at end of initcalls pinctrl: Support stopping deferred probe after initcalls dt-bindings: pinctrl: add a 'pinctrl-use-default' property driver core: allow stopping deferred probe after init driver core: add a debugfs entry to show deferred devices sysfs: Fix internal_create_group() for named group updates base: fix order of OF initialization linux/device.h: fix kernel-doc notation warning Documentation: update firmware loader fallback reference kobject: Replace strncpy with memcpy drivers: base: cacheinfo: use OF property_read_u32 instead of get_property,read_number kernfs: Replace strncpy with memcpy device: Add #define dev_fmt similar to #define pr_fmt ...
2018-08-18Merge tag 'char-misc-4.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here is the bit set of char/misc drivers for 4.19-rc1 There is a lot here, much more than normal, seems like everyone is writing new driver subsystems these days... Anyway, major things here are: - new FSI driver subsystem, yet-another-powerpc low-level hardware bus - gnss, finally an in-kernel GPS subsystem to try to tame all of the crazy out-of-tree drivers that have been floating around for years, combined with some really hacky userspace implementations. This is only for GNSS receivers, but you have to start somewhere, and this is great to see. Other than that, there are new slimbus drivers, new coresight drivers, new fpga drivers, and loads of DT bindings for all of these and existing drivers. All of these have been in linux-next for a while with no reported issues" * tag 'char-misc-4.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (255 commits) android: binder: Rate-limit debug and userspace triggered err msgs fsi: sbefifo: Bump max command length fsi: scom: Fix NULL dereference misc: mic: SCIF Fix scif_get_new_port() error handling misc: cxl: changed asterisk position genwqe: card_base: Use true and false for boolean values misc: eeprom: assignment outside the if statement uio: potential double frees if __uio_register_device() fails eeprom: idt_89hpesx: clean up an error pointer vs NULL inconsistency misc: ti-st: Fix memory leak in the error path of probe() android: binder: Show extra_buffers_size in trace firmware: vpd: Fix section enabled flag on vpd_section_destroy platform: goldfish: Retire pdev_bus goldfish: Use dedicated macros instead of manual bit shifting goldfish: Add missing includes to goldfish.h mux: adgs1408: new driver for Analog Devices ADGS1408/1409 mux dt-bindings: mux: add adi,adgs1408 Drivers: hv: vmbus: Cleanup synic memory free path Drivers: hv: vmbus: Remove use of slow_virt_to_phys() Drivers: hv: vmbus: Reset the channel callback in vmbus_onoffer_rescind() ...
2018-08-16Merge branch 'linus/master' into rdma.git for-nextJason Gunthorpe
rdma.git merge resolution for the 4.19 merge window Conflicts: drivers/infiniband/core/rdma_core.c - Use the rdma code and revise with the new spelling for atomic_fetch_add_unless drivers/nvme/host/rdma.c - Replace max_sge with max_send_sge in new blk code drivers/nvme/target/rdma.c - Use the blk code and revise to use NULL for ib_post_recv when appropriate - Replace max_sge with max_recv_sge in new blk code net/rds/ib_send.c - Use the net code and revise to use NULL for ib_post_recv when appropriate Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
2018-08-16ila: make lockdep happy againCong Wang
Previously, alloc_ila_locks() and bucket_table_alloc() call spin_lock_init() separately, therefore they have two different lock names and lock class keys. However, after commit b893281715ab ("ila: Call library function alloc_bucket_locks") they both call helper alloc_bucket_spinlocks() which now only has one lock name and lock class key. This causes a few bogus lockdep warnings as reported by syzbot. Fix this by making alloc_bucket_locks() a macro and pass declaration name as lock name and a static lock class key inside the macro. Fixes: b893281715ab ("ila: Call library function alloc_bucket_locks") Reported-by: <syzbot+b66a5a554991a8ed027c@syzkaller.appspotmail.com> Cc: Tom Herbert <tom@quantonium.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-08-16Merge tag 'v4.18' into rdma.git for-nextJason Gunthorpe
Resolve merge conflicts from the -rc cycle against the rdma.git tree: Conflicts: drivers/infiniband/core/uverbs_cmd.c - New ifs added to ib_uverbs_ex_create_flow in -rc and for-next - Merge removal of file->ucontext in for-next with new code in -rc drivers/infiniband/core/uverbs_main.c - for-next removed code from ib_uverbs_write() that was modified in for-rc Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
2018-08-15Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This is mostly updates to the usual drivers: mpt3sas, lpfc, qla2xxx, hisi_sas, smartpqi, megaraid_sas, arcmsr. In addition, with the continuing absence of Nic we have target updates for tcmu and target core (all with reviews and acks). The biggest observable change is going to be that we're (again) trying to switch to mulitqueue as the default (a user can still override the setting on the kernel command line). Other major core stuff is the removal of the remaining Microchannel drivers, an update of the internal timers and some reworks of completion and result handling" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (203 commits) scsi: core: use blk_mq_run_hw_queues in scsi_kick_queue scsi: ufs: remove unnecessary query(DM) UPIU trace scsi: qla2xxx: Fix issue reported by static checker for qla2x00_els_dcmd2_sp_done() scsi: aacraid: Spelling fix in comment scsi: mpt3sas: Fix calltrace observed while running IO & reset scsi: aic94xx: fix an error code in aic94xx_init() scsi: st: remove redundant pointer STbuffer scsi: qla2xxx: Update driver version to 10.00.00.08-k scsi: qla2xxx: Migrate NVME N2N handling into state machine scsi: qla2xxx: Save frame payload size from ICB scsi: qla2xxx: Fix stalled relogin scsi: qla2xxx: Fix race between switch cmd completion and timeout scsi: qla2xxx: Fix Management Server NPort handle reservation logic scsi: qla2xxx: Flush mailbox commands on chip reset scsi: qla2xxx: Fix unintended Logout scsi: qla2xxx: Fix session state stuck in Get Port DB scsi: qla2xxx: Fix redundant fc_rport registration scsi: qla2xxx: Silent erroneous message scsi: qla2xxx: Prevent sysfs access when chip is down scsi: qla2xxx: Add longer window for chip reset ...
2018-08-15Merge tag 'random_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random Pull random updates from Ted Ts'o: "Some changes to trust cpu-based hwrng (such as RDRAND) for initializing hashed pointers and (optionally, controlled by a config option) to initialize the CRNG to avoid boot hangs" * tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: random: Make crng state queryable random: remove preempt disabled region random: add a config option to trust the CPU's hwrng vsprintf: Add command line option debug_boot_weak_hash vsprintf: Use hw RNG for ptr_key random: Return nbytes filled from hw RNG random: Fix whitespace pre random-bytes work
2018-08-15Merge tag 'drm-next-2018-08-15' of git://anongit.freedesktop.org/drm/drmLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main drm pull request for 4.19. Rob has some new hardware support for new qualcomm hw that I'll send along separately. This has the display part of it, the remaining pull is for the acceleration engine. This also contains a wound-wait/wait-die mutex rework, Peter has acked it for merging via my tree. Otherwise mostly the usual level of activity. Summary: core: - Wound-wait/wait-die mutex rework - Add writeback connector type - Add "content type" property for HDMI - Move GEM bo to drm_framebuffer - Initial gpu scheduler documentation - GPU scheduler fixes for dying processes - Console deferred fbcon takeover support - Displayport support for CEC tunneling over AUX panel: - otm8009a panel driver fixes - Innolux TV123WAM and G070Y2-L01 panel driver - Ilitek ILI9881c panel driver - Rocktech RK070ER9427 LCD - EDT ETM0700G0EDH6 and EDT ETM0700G0BDH6 - DLC DLC0700YZG-1 - BOE HV070WSA-100 - newhaven, nhd-4.3-480272ef-atxl LCD - DataImage SCF0700C48GGU18 - Sharp LQ035Q7DB03 - p079zca: Refactor to support multiple panels tinydrm: - ILI9341 display panel New driver: - vkms - virtual kms driver to testing. i915: - Icelake: Display enablement DSI support IRQ support Powerwell support - GPU reset fixes and improvements - Full ppgtt support refactoring - PSR fixes and improvements - Execlist improvments - GuC related fixes amdgpu: - Initial amdgpu documentation - JPEG engine support on VCN - CIK uses powerplay by default - Move to using core PCIE functionality for gens/lanes - DC/Powerplay interface rework - Stutter mode support for RV - Vega12 Powerplay updates - GFXOFF fixes - GPUVM fault debugging - Vega12 GFXOFF - DC improvements - DC i2c/aux changes - UVD 7.2 fixes - Powerplay fixes for Polaris12, CZ/ST - command submission bo_list fixes amdkfd: - Raven support - Power management fixes udl: - Cleanups and fixes nouveau: - misc fixes and cleanups. msm: - DPU1 support display controller in sdm845 - GPU coredump support. vmwgfx: - Atomic modesetting validation fixes - Support for multisample surfaces armada: - Atomic modesetting support completed. exynos: - IPPv2 fixes - Move g2d to component framework - Suspend/resume support cleanups - Driver cleanups imx: - CSI configuration improvements - Driver cleanups - Use atomic suspend/resume helpers - ipu-v3 V4L2 XRGB32/XBGR32 support pl111: - Add Nomadik LCDC variant v3d: - GPU scheduler jobs management sun4i: - R40 display engine support - TCON TOP driver mediatek: - MT2712 SoC support rockchip: - vop fixes omapdrm: - Workaround for DRA7 errata i932 - Fix mm_list locking mali-dp: - Writeback implementation PM improvements - Internal error reporting debugfs tilcdc: - Single fix for deferred probing hdlcd: - Teardown fixes tda998x: - Converted to a bridge driver. etnaviv: - Misc fixes" * tag 'drm-next-2018-08-15' of git://anongit.freedesktop.org/drm/drm: (1506 commits) drm/amdgpu/sriov: give 8s for recover vram under RUNTIME drm/scheduler: fix param documentation drm/i2c: tda998x: correct PLL divider calculation drm/i2c: tda998x: get rid of private fill_modes function drm/i2c: tda998x: move mode_valid() to bridge drm/i2c: tda998x: register bridge outside of component helper drm/i2c: tda998x: cleanup from previous changes drm/i2c: tda998x: allocate tda998x_priv inside tda998x_create() drm/i2c: tda998x: convert to bridge driver drm/scheduler: fix timeout worker setup for out of order job completions drm/amd/display: display connected to dp-1 does not light up drm/amd/display: update clk for various HDMI color depths drm/amd/display: program display clock on cache match drm/amd/display: Add NULL check for enabling dp ss drm/amd/display: add vbios table check for enabling dp ss drm/amd/display: Don't share clk source between DP and HDMI drm/amd/display: Fix DP HBR2 Eye Diagram Pattern on Carrizo drm/amd/display: Use calculated disp_clk_khz value for dce110 drm/amd/display: Implement custom degamma lut on dcn drm/amd/display: Destroy aux_engines only once ...
2018-08-15Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto updates from Herbert Xu: "API: - Fix dcache flushing crash in skcipher. - Add hash finup self-tests. - Reschedule during speed tests. Algorithms: - Remove insecure vmac and replace it with vmac64. - Add public key verification for DH/ECDH. Drivers: - Decrease priority of sha-mb on x86. - Improve NEON latency/throughput on ARM64. - Add md5/sha384/sha512/des/3des to inside-secure. - Support eip197d in inside-secure. - Only register algorithms supported by the host in virtio. - Add cts and remove incompatible cts1 from ccree. - Add hisilicon SEC security accelerator driver. - Replace msm hwrng driver with qcom pseudo rng driver. Misc: - Centralize CRC polynomials" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (121 commits) crypto: arm64/ghash-ce - implement 4-way aggregation crypto: arm64/ghash-ce - replace NEON yield check with block limit crypto: hisilicon - sec_send_request() can be static lib/mpi: remove redundant variable esign crypto: arm64/aes-ce-gcm - don't reload key schedule if avoidable crypto: arm64/aes-ce-gcm - implement 2-way aggregation crypto: arm64/aes-ce-gcm - operate on two input blocks at a time crypto: dh - make crypto_dh_encode_key() make robust crypto: dh - fix calculating encoded key size crypto: ccp - Check for NULL PSP pointer at module unload crypto: arm/chacha20 - always use vrev for 16-bit rotates crypto: ccree - allow bigger than sector XTS op crypto: ccree - zero all of request ctx before use crypto: ccree - remove cipher ivgen left overs crypto: ccree - drop useless type flag during reg crypto: ablkcipher - fix crash flushing dcache in error path crypto: blkcipher - fix crash flushing dcache in error path crypto: skcipher - fix crash flushing dcache in error path crypto: skcipher - remove unnecessary setting of walk->nbytes crypto: scatterwalk - remove scatterwalk_samebuf() ...
2018-08-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: - Gustavo A. R. Silva keeps working on the implicit switch fallthru changes. - Support 802.11ax High-Efficiency wireless in cfg80211 et al, From Luca Coelho. - Re-enable ASPM in r8169, from Kai-Heng Feng. - Add virtual XFRM interfaces, which avoids all of the limitations of existing IPSEC tunnels. From Steffen Klassert. - Convert GRO over to use a hash table, so that when we have many flows active we don't traverse a long list during accumluation. - Many new self tests for routing, TC, tunnels, etc. Too many contributors to mention them all, but I'm really happy to keep seeing this stuff. - Hardware timestamping support for dpaa_eth/fsl-fman from Yangbo Lu. - Lots of cleanups and fixes in L2TP code from Guillaume Nault. - Add IPSEC offload support to netdevsim, from Shannon Nelson. - Add support for slotting with non-uniform distribution to netem packet scheduler, from Yousuk Seung. - Add UDP GSO support to mlx5e, from Boris Pismenny. - Support offloading of Team LAG in NFP, from John Hurley. - Allow to configure TX queue selection based upon RX queue, from Amritha Nambiar. - Support ethtool ring size configuration in aquantia, from Anton Mikaev. - Support DSCP and flowlabel per-transport in SCTP, from Xin Long. - Support list based batching and stack traversal of SKBs, this is very exciting work. From Edward Cree. - Busyloop optimizations in vhost_net, from Toshiaki Makita. - Introduce the ETF qdisc, which allows time based transmissions. IGB can offload this in hardware. From Vinicius Costa Gomes. - Add parameter support to devlink, from Moshe Shemesh. - Several multiplication and division optimizations for BPF JIT in nfp driver, from Jiong Wang. - Lots of prepatory work to make more of the packet scheduler layer lockless, when possible, from Vlad Buslov. - Add ACK filter and NAT awareness to sch_cake packet scheduler, from Toke Høiland-Jørgensen. - Support regions and region snapshots in devlink, from Alex Vesker. - Allow to attach XDP programs to both HW and SW at the same time on a given device, with initial support in nfp. From Jakub Kicinski. - Add TLS RX offload and support in mlx5, from Ilya Lesokhin. - Use PHYLIB in r8169 driver, from Heiner Kallweit. - All sorts of changes to support Spectrum 2 in mlxsw driver, from Ido Schimmel. - PTP support in mv88e6xxx DSA driver, from Andrew Lunn. - Make TCP_USER_TIMEOUT socket option more accurate, from Jon Maxwell. - Support for templates in packet scheduler classifier, from Jiri Pirko. - IPV6 support in RDS, from Ka-Cheong Poon. - Native tproxy support in nf_tables, from Máté Eckl. - Maintain IP fragment queue in an rbtree, but optimize properly for in-order frags. From Peter Oskolkov. - Improvde handling of ACKs on hole repairs, from Yuchung Cheng" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1996 commits) bpf: test: fix spelling mistake "REUSEEPORT" -> "REUSEPORT" hv/netvsc: Fix NULL dereference at single queue mode fallback net: filter: mark expected switch fall-through xen-netfront: fix warn message as irq device name has '/' cxgb4: Add new T5 PCI device ids 0x50af and 0x50b0 net: dsa: mv88e6xxx: missing unlock on error path rds: fix building with IPV6=m inet/connection_sock: prefer _THIS_IP_ to current_text_addr net: dsa: mv88e6xxx: bitwise vs logical bug net: sock_diag: Fix spectre v1 gadget in __sock_diag_cmd() ieee802154: hwsim: using right kind of iteration net: hns3: Add vlan filter setting by ethtool command -K net: hns3: Set tx ring' tc info when netdev is up net: hns3: Remove tx ring BD len register in hns3_enet net: hns3: Fix desc num set to default when setting channel net: hns3: Fix for phy link issue when using marvell phy driver net: hns3: Fix for information of phydev lost problem when down/up net: hns3: Fix for command format parsing error in hclge_is_all_function_id_zero net: hns3: Add support for serdes loopback selftest bnxt_en: take coredump_record structure off stack ...
2018-08-15Merge tag 'kconfig-v4.19-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild Pull Kconfig consolidation from Masahiro Yamada: "Consolidation of Kconfig files by Christoph Hellwig. Move the source statements of arch-independent Kconfig files instead of duplicating the includes in every arch/$(SRCARCH)/Kconfig" * tag 'kconfig-v4.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: kconfig: add a Memory Management options" menu kconfig: move the "Executable file formats" menu to fs/Kconfig.binfmt kconfig: use a menu in arch/Kconfig to reduce clutter kconfig: include kernel/Kconfig.preempt from init/Kconfig Kconfig: consolidate the "Kernel hacking" menu kconfig: include common Kconfig files from top-level Kconfig kconfig: remove duplicate SWAP symbol defintions um: create a proper drivers Kconfig um: cleanup Kconfig files um: stop abusing KBUILD_KCONFIG
2018-08-15Merge tag 'printk-for-4.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk Pull printk updates from Petr Mladek: - Different vendors have a different expectation about a console quietness. Make it configurable to reduce bike-shedding about the upstream default - Decide about the message visibility when the message is stored. It avoids races caused by a delayed console handling - Always store printk() messages into the per-CPU buffers again in NMI. The only exception is when flushing trace log in panic(). There the risk of loosing messages is worth an eventual reordering - Handle invalid %pO printf modifiers correctly - Better handle %p printf modifier tests before crng is initialized - Some clean up * tag 'printk-for-4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk: lib/vsprintf: Do not handle %pO[^F] as %px printk: Fix warning about unused suppress_message_printing printk/nmi: Prevent deadlock when accessing the main log buffer in NMI printk: Create helper function to queue deferred console handling printk: Split the code for storing a message into the log buffer printk: Clean up syslog_print_all() printk: Remove unnecessary kmalloc() from syslog during clear printk: Make CONSOLE_LOGLEVEL_QUIET configurable printk: make sure to print log on console. lib/test_printf.c: accept "ptrval" as valid result for plain 'p' tests
2018-08-14Merge tag 'docs-4.19' of git://git.lwn.net/linuxLinus Torvalds
Pull documentation update from Jonathan Corbet: "This was a moderately busy cycle for docs, with the usual collection of small fixes and updates. We also have new ktime_get_*() docs from Arnd, some kernel-doc fixes, a new set of Italian translations (non so se vale la pena, ma non fa male - speriamo bene), and some extensive early memory-management documentation improvements from Mike Rapoport" * tag 'docs-4.19' of git://git.lwn.net/linux: (52 commits) Documentation: corrections to console/console.txt Documentation: add ioctl number entry for v4l2-subdev.h Remove gendered language from management style documentation scripts/kernel-doc: Escape all literal braces in regexes docs/mm: add description of boot time memory management docs/mm: memblock: add overview documentation docs/mm: memblock: add kernel-doc description for memblock types docs/mm: memblock: add kernel-doc comments for memblock_add[_node] docs/mm: memblock: update kernel-doc comments mm/memblock: add a name for memblock flags enumeration docs/mm: bootmem: add overview documentation docs/mm: bootmem: add kernel-doc description of 'struct bootmem_data' docs/mm: bootmem: fix kernel-doc warnings docs/mm: nobootmem: fixup kernel-doc comments mm/bootmem: drop duplicated kernel-doc comments Documentation: vm.txt: Adding 'nr_hugepages_mempolicy' parameter description. doc:it_IT: translation for kernel-hacking docs: Fix the reference labels in Locking.rst doc: tracing: Fix a typo of trace_stat mm: Introduce new type vm_fault_t ...
2018-08-14Merge tag 'mtd/for-4.19' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull mtd updates from Boris Brezillon: "JFFS2 changes: - Support 64-bit timestamps MTD core changes: - Support sub-partitions - Clarify mtd_oob_ops documentation - Make Kconfig formatting consistent - Fix potential overflows in mtdchar_{write,read}() - Fallback to ->_{read,write}() when ->_{read,write}_oob() is missing and no OOB data were requested - Remove VLA usage in the bch lib MTD driver changes: - Use mtd_device_register() instead of mtd_device_parse_register() where applicable - Use proper printk format to print physical addresses in the solutionengine driver - Add missing mtd_set_of_node() call in the powernv driver - Remove unneeded variables in a few drivers - Plug the TRX part parser to the DT partition parsers logic - Check ioremap_cache() return code in the gpio-addr-flash driver - Stop using VMLINUX_SYMBOL_STR() in gen_probe.c SPI NOR core changes: - Apply reset hacks only when reset is explicitly marked as broken in the DT SPI NOR driver changes: - Minor cleanup/fixes in the m25p80 driver - Release flash_np in the nxp-spifi driver - Add suspend/resume hooks to the atmel-quadspi driver - Include gpio/consumer.h instead of gpio.h in the atmel-quadspi driver - Use %pK instead of %p in the stm32-quadspi driver - Improve timeout handling in the cadence-quadspi driver - Use mtd_device_register() instead of mtd_device_parse_register() in the intel-spi driver NAND core changes: - Add the SPI-NAND framework. - Create a helper to find the best ECC configuration. - Create NAND controller operations. - Allocate dynamically ONFI parameters structure. - Add defines for ONFI version bits. - Add manufacturer fixup for ONFI parameter page. - Add an option to specify NAND chip as a boot device. - Add Reed-Solomon error correction algorithm. - Better name for the controller structure. - Remove unused caller_is_module() definition. - Make subop helpers return unsigned values. - Expose _notsupp() helpers for raw page accessors. - Add default values for dynamic timings. - Kill the chip->scan_bbt() hook. - Rename nand_default_bbt() into nand_create_bbt(). - Start to clean the nand_chip structure. - Remove stale prototype from rawnand.h. Raw NAND controllers drivers changes: - Qcom: structuring cleanup. - Denali: use core helper to find the best ECC configuration. - Possible build of almost all drivers by adding a dependency on COMPILE_TEST for almost all of them in Kconfig, implies various fixes, Kconfig cleanup, GPIO headers inclusion cleanup, and even changes in sparc64 and ia64 architectures. - Clean the ->probe() functions error path of a lot of drivers. - Migrate all drivers to use nand_scan() instead of nand_scan_ident()/nand_scan_tail() pair. - Use mtd_device_register() where applicable to simplify the code. - Marvell: * Handle on-die ECC. * Better clocks handling. * Remove bogus comment. * Add suspend and resume support. - Tegra: add NAND controller driver. - Atmel: * Add module param to avoid using dma. * Drop Wenyou Yang from MAINTAINERS. - Denali: optimize timings handling. - FSMC: Stop using chip->read_buf(). - FSL: * Switch to SPDX license tag identifiers. * Fix qualifiers in MXC init functions. Raw NAND chip drivers changes: - Micron: * Add fixup for ONFI revision. * Update ecc_stats.corrected. * Make ECC activation stateful. * Avoid enabling/disabling ECC when it can't be disabled. * Get the actual number of bitflips. * Allow forced on-die ECC. * Support 8/512 on-die ECC. * Fix on-die ECC detection logic. - Hynix: * Fix decoding the OOB size on H27UCG8T2BTR. * Use ->exec_op() in hynix_nand_reg_write_op()" * tag 'mtd/for-4.19' of git://git.infradead.org/linux-mtd: (188 commits) mtd: rawnand: atmel: Select GENERIC_ALLOCATOR MAINTAINERS: drop Wenyou Yang from Atmel NAND driver support mtd: rawnand: allocate dynamically ONFI parameters during detection mtd: spi-nor: only apply reset hacks to broken hardware mtd: spi-nor: cadence-quadspi: fix timeout handling mtd: spi-nor: atmel-quadspi: Include gpio/consumer.h instead of gpio.h mtd: spi-nor: intel-spi: use mtd_device_register() mtd: spi-nor: stm32-quadspi: replace "%p" with "%pK" mtd: spi-nor: atmel-quadspi: add suspend/resume hooks mtd: rawnand: allocate model parameter dynamically mtd: rawnand: do not export nand_scan_[ident|tail]() anymore mtd: rawnand: txx9ndfmc: convert driver to nand_scan() mtd: rawnand: txx9ndfmc: clarify ECC parameters assignation mtd: rawnand: tegra: convert driver to nand_scan() mtd: rawnand: jz4740: convert driver to nand_scan() mtd: rawnand: jz4740: group nand_scan_{ident, tail} calls mtd: rawnand: jz4740: fix probe function error path mtd: rawnand: docg4: convert driver to nand_scan() mtd: rawnand: do not execute nand_scan_ident() if maxchips is zero mtd: rawnand: atmel: convert driver to nand_scan() ...
2018-08-14Merge branch 'for-4.19-nmi' into for-linusPetr Mladek
2018-08-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Heiko Carstens: "Since Martin is on vacation you get the s390 pull request from me: - Host large page support for KVM guests. As the patches have large impact on arch/s390/mm/ this series goes out via both the KVM and the s390 tree. - Add an option for no compression to the "Kernel compression mode" menu, this will come in handy with the rework of the early boot code. - A large rework of the early boot code that will make life easier for KASAN and KASLR. With the rework the bootable uncompressed image is not generated anymore, only the bzImage is available. For debuggung purposes the new "no compression" option is used. - Re-enable the gcc plugins as the issue with the latent entropy plugin is solved with the early boot code rework. - More spectre relates changes: + Detect the etoken facility and remove expolines automatically. + Add expolines to a few more indirect branches. - A rewrite of the common I/O layer trace points to make them consumable by 'perf stat'. - Add support for format-3 PCI function measurement blocks. - Changes for the zcrypt driver: + Add attributes to indicate the load of cards and queues. + Restructure some code for the upcoming AP device support in KVM. - Build flags improvements in various Makefiles. - A few fixes for the kdump support. - A couple of patches for gcc 8 compile warning cleanup. - Cleanup s390 specific proc handlers. - Add s390 support to the restartable sequence self tests. - Some PTR_RET vs PTR_ERR_OR_ZERO cleanup. - Lots of bug fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (107 commits) s390/dasd: fix hanging offline processing due to canceled worker s390/dasd: fix panic for failed online processing s390/mm: fix addressing exception after suspend/resume rseq/selftests: add s390 support s390: fix br_r1_trampoline for machines without exrl s390/lib: use expoline for all bcr instructions s390/numa: move initial setup of node_to_cpumask_map s390/kdump: Fix elfcorehdr size calculation s390/cpum_sf: save TOD clock base in SDBs for time conversion KVM: s390: Add huge page enablement control s390/mm: Add huge page gmap linking support s390/mm: hugetlb pages within a gmap can not be freed KVM: s390: Add skey emulation fault handling s390/mm: Add huge pmd storage key handling s390/mm: Clear skeys for newly mapped huge guest pmds s390/mm: Clear huge page storage keys on enable_skey s390/mm: Add huge page dirty sync support s390/mm: Add gmap pmd invalidation and clearing s390/mm: Add gmap pmd notification bit setting s390/mm: Add gmap pmd linking ...
2018-08-13Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm updates from Thomas Gleixner: - Make lazy TLB mode even lazier to avoid pointless switch_mm() operations, which reduces CPU load by 1-2% for memcache workloads - Small cleanups and improvements all over the place * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mm: Remove redundant check for kmem_cache_create() arm/asm/tlb.h: Fix build error implicit func declaration x86/mm/tlb: Make clear_asid_other() static x86/mm/tlb: Skip atomic operations for 'init_mm' in switch_mm_irqs_off() x86/mm/tlb: Always use lazy TLB mode x86/mm/tlb: Only send page table free TLB flush to lazy TLB CPUs x86/mm/tlb: Make lazy TLB mode lazier x86/mm/tlb: Restructure switch_mm_irqs_off() x86/mm/tlb: Leave lazy TLB mode at page table free time mm: Allocate the mm_cpumask (mm->cpu_bitmap[]) dynamically based on nr_cpu_ids x86/mm: Add TLB purge to free pmd/pte page interfaces ioremap: Update pgtable free interfaces with addr x86/mm: Disable ioremap free page handling on x86-PAE
2018-08-13Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf update from Thomas Gleixner: "The perf crowd presents: Kernel updates: - Removal of jprobes - Cleanup and consolidatation the handling of kprobes - Cleanup and consolidation of hardware breakpoints - The usual pile of fixes and updates to PMUs and event descriptors Tooling updates: - Updates and improvements all over the place. Nothing outstanding, just the (good) boring incremental grump work" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (103 commits) perf trace: Do not require --no-syscalls to suppress strace like output perf bpf: Include uapi/linux/bpf.h from the 'perf trace' script's bpf.h perf tools: Allow overriding MAX_NR_CPUS at compile time perf bpf: Show better message when failing to load an object perf list: Unify metric group description format with PMU event description perf vendor events arm64: Update ThunderX2 implementation defined pmu core events perf cs-etm: Generate branch sample for CS_ETM_TRACE_ON packet perf cs-etm: Generate branch sample when receiving a CS_ETM_TRACE_ON packet perf cs-etm: Support dummy address value for CS_ETM_TRACE_ON packet perf cs-etm: Fix start tracing packet handling perf build: Fix installation directory for eBPF perf c2c report: Fix crash for empty browser perf tests: Fix indexing when invoking subtests perf trace: Beautify the AF_INET & AF_INET6 'socket' syscall 'protocol' args perf trace beauty: Add beautifiers for 'socket''s 'protocol' arg perf trace beauty: Do not print NULL strarray entries perf beauty: Add a generator for IPPROTO_ socket's protocol constants tools include uapi: Grab a copy of linux/in.h perf tests: Fix complex event name parsing perf evlist: Fix error out while applying initial delay and LBR ...
2018-08-13Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking/atomics update from Thomas Gleixner: "The locking, atomics and memory model brains delivered: - A larger update to the atomics code which reworks the ordering barriers, consolidates the atomic primitives, provides the new atomic64_fetch_add_unless() primitive and cleans up the include hell. - Simplify cmpxchg() instrumentation and add instrumentation for xchg() and cmpxchg_double(). - Updates to the memory model and documentation" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (48 commits) locking/atomics: Rework ordering barriers locking/atomics: Instrument cmpxchg_double*() locking/atomics: Instrument xchg() locking/atomics: Simplify cmpxchg() instrumentation locking/atomics/x86: Reduce arch_cmpxchg64*() instrumentation tools/memory-model: Rename litmus tests to comply to norm7 tools/memory-model/Documentation: Fix typo, smb->smp sched/Documentation: Update wake_up() & co. memory-barrier guarantees locking/spinlock, sched/core: Clarify requirements for smp_mb__after_spinlock() sched/core: Use smp_mb() in wake_woken_function() tools/memory-model: Add informal LKMM documentation to MAINTAINERS locking/atomics/Documentation: Describe atomic_set() as a write operation tools/memory-model: Make scripts executable tools/memory-model: Remove ACCESS_ONCE() from model tools/memory-model: Remove ACCESS_ONCE() from recipes locking/memory-barriers.txt/kokr: Update Korean translation to fix broken DMA vs. MMIO ordering example MAINTAINERS: Add Daniel Lustig as an LKMM reviewer tools/memory-model: Fix ISA2+pooncelock+pooncelock+pombonce name tools/memory-model: Add litmus test for full multicopy atomicity locking/refcount: Always allow checked forms ...
2018-08-13Merge branch 'core-debugobjects-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull debugobjects update from Thomas Gleixner: "Two simple updates for the debug objects code: - Make the stack check warning more informative by adding the object and the stack page address to the printout - Remove a redundant NULL pointer check" * 'core-debugobjects-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: debugobjects: Remove redundant NULL pointer check debugobjects: Make stack check warning more informative
2018-08-11Merge ra.kernel.org:/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2018-08-11Merge tag 'nand/for-4.19' of git://git.infradead.org/linux-mtd into mtd/nextBoris Brezillon
Pull NAND updates from Miquel Raynal: " NAND core changes: - Add the SPI-NAND framework. - Create a helper to find the best ECC configuration. - Create NAND controller operations. - Allocate dynamically ONFI parameters structure. - Add defines for ONFI version bits. - Add manufacturer fixup for ONFI parameter page. - Add an option to specify NAND chip as a boot device. - Add Reed-Solomon error correction algorithm. - Better name for the controller structure. - Remove unused caller_is_module() definition. - Make subop helpers return unsigned values. - Expose _notsupp() helpers for raw page accessors. - Add default values for dynamic timings. - Kill the chip->scan_bbt() hook. - Rename nand_default_bbt() into nand_create_bbt(). - Start to clean the nand_chip structure. - Remove stale prototype from rawnand.h. Raw NAND controllers drivers changes: - Qcom: structuring cleanup. - Denali: use core helper to find the best ECC configuration. - Possible build of almost all drivers by adding a dependency on COMPILE_TEST for almost all of them in Kconfig, implies various fixes, Kconfig cleanup, GPIO headers inclusion cleanup, and even changes in sparc64 and ia64 architectures. - Clean the ->probe() functions error path of a lot of drivers. - Migrate all drivers to use nand_scan() instead of nand_scan_ident()/nand_scan_tail() pair. - Use mtd_device_register() where applicable to simplify the code. - Marvell: * Handle on-die ECC. * Better clocks handling. * Remove bogus comment. * Add suspend and resume support. - Tegra: add NAND controller driver. - Atmel: * Add module param to avoid using dma. * Drop Wenyou Yang from MAINTAINERS. - Denali: optimize timings handling. - FSMC: Stop using chip->read_buf(). - FSL: * Switch to SPDX license tag identifiers. * Fix qualifiers in MXC init functions. Raw NAND chip drivers changes: - Micron: * Add fixup for ONFI revision. * Update ecc_stats.corrected. * Make ECC activation stateful. * Avoid enabling/disabling ECC when it can't be disabled. * Get the actual number of bitflips. * Allow forced on-die ECC. * Support 8/512 on-die ECC. * Fix on-die ECC detection logic. - Hynix: * Fix decoding the OOB size on H27UCG8T2BTR. * Use ->exec_op() in hynix_nand_reg_write_op(). "
2018-08-10lib/ubsan: remove null-pointer checksAndrey Ryabinin
With gcc-8 fsanitize=null become very noisy. GCC started to complain about things like &a->b, where 'a' is NULL pointer. There is no NULL dereference, we just calculate address to struct member. It's technically undefined behavior so UBSAN is correct to report it. But as long as there is no real NULL-dereference, I think, we should be fine. -fno-delete-null-pointer-checks compiler flag should protect us from any consequences. So let's just no use -fsanitize=null as it's not useful for us. If there is a real NULL-deref we will see crash. Even if userspace mapped something at NULL (root can do this), with things like SMAP should catch the issue. Link: http://lkml.kernel.org/r/20180802153209.813-1-aryabinin@virtuozzo.com Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-08test_overflow: Add shift overflow testsKees Cook
This adds overflow tests for the new check_shift_overflow() helper to validate overflow, signedness glitches, storage glitches, etc. Co-developed-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
2018-08-07lib/mpi: remove redundant variable esignColin Ian King
Variable esign is being assigned but is never used hence it is redundant and can be removed. Cleans up clang warning: warning: variable 'esign' set but not used [-Wunused-but-set-variable] Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2018-08-07lib/vsprintf: Do not handle %pO[^F] as %pxBart Van Assche
This patch avoids that gcc reports the following when building with W=1: lib/vsprintf.c:1941:3: warning: this statement may fall through [-Wimplicit-fallthrough=] switch (fmt[1]) { ^~~~~~ Fixes: 7b1924a1d930eb2 ("vsprintf: add printk specifier %px") Link: http://lkml.kernel.org/r/20180806223421.11995-1-bart.vanassche@wdc.com Cc: linux-kernel@vger.kernel.org Cc: Bart Van Assche <bart.vanassche@wdc.com> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Joe Perches <joe@perches.com> Cc: Rob Herring <robh@kernel.org> Cc: v4.15+ <stable@vger.kernel.org> Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
