Add API to allocate at specified alloc address.
Change-Id: I188e5430220c050026c6a3e17a586012d9a9fa04
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/74468
This allows us to get a kernel stacktrace for a thread though /proc.
Also enable it by default.
Change-Id: If8c21cd02feaf9863f4841ace524fa30c7328d49
Signed-off-by: Arve Hjønnevåg <arve@android.com>
commit c30bc94758ae2a38a5eb31767c1985c0aae0950b upstream.
L2TP for example uses NLA_MSECS like this:
policy:
[L2TP_ATTR_RECV_TIMEOUT] = { .type = NLA_MSECS, },
code:
if (info->attrs[L2TP_ATTR_RECV_TIMEOUT])
cfg.reorder_timeout = nla_get_msecs(info->attrs[L2TP_ATTR_RECV_TIMEOUT]);
As nla_get_msecs() is essentially nla_get_u64() plus the
conversion to a HZ-based value, this will not properly
reject attributes from userspace that aren't long enough
and might overrun the message.
Add NLA_MSECS to the attribute minlen array to check the
size properly.
Cc: Thomas Graf <tgraf@suug.ch>
commit ebf4127cd677e9781b450e44dfaaa1cc595efcaa upstream.
kobject_uevent() uses a multicast socket and should ignore
if one of listeners cannot handle messages or nobody is
listening at all.
Easily reproducible when a process in system is cloned
with CLONE_NEWNET flag.
(See also http://article.gmane.org/gmane.linux.kernel.device-mapper.dm-crypt/5256)
Signed-off-by: Milan Broz <mbroz@redhat.com>
Acked-by: Kay Sievers <kay.sievers@vrfy.org>
xz_dec_run() could incorrectly return XZ_BUF_ERROR if all of the
following was true:
- The caller knows how many bytes of output to expect and only provides
that much output space.
- When the last output bytes are decoded, the caller-provided input
buffer ends right before the LZMA2 end of payload marker. So LZMA2
won't provide more output anymore, but it won't know it yet and thus
won't return XZ_STREAM_END yet.
- A BCJ filter is in use and it hasn't left any unfiltered bytes in the
temp buffer. This can happen with any BCJ filter, but in practice
it's more likely with filters other than the x86 BCJ.
This fixes <https://bugzilla.redhat.com/show_bug.cgi?id=735408> where
Squashfs thinks that a valid file system is corrupt.
This also fixes a similar bug in single-call mode where the uncompressed
size of a block using BCJ + LZMA2 was 0 bytes and caller provided no
output space. Many empty .xz files don't contain any blocks and thus
don't trigger this bug.
This also tweaks a closely related detail: xz_dec_bcj_run() could call
xz_dec_lzma2_run() to decode into temp buffer when it was known to be
useless. This was harmless although it wasted a minuscule number of CPU
cycles.
Signed-off-by: Lasse Collin <lasse.collin@tukaani.org>
Cc: stable <stable@kernel.org>
Include <linux/cryptohash.h> to pickup the declarations for sha_transform
and sha_init to quite the sparse noise:
warning: symbol 'sha_transform' was not declared. Should it be static?
warning: symbol 'sha_init' was not declared. Should it be static?
Acked-by: Mandeep Singh Baines <msb@chromium.org>
If there are no builtin users of find_next_bit_le() and
find_next_zero_bit_le(), these functions are not present in the kernel
image, causing m68k allmodconfig to fail with:
ERROR: "find_next_zero_bit_le" [fs/ufs/ufs.ko] undefined!
ERROR: "find_next_bit_le" [fs/udf/udf.ko] undefined!
This started to happen after commit 171d809df189 ("m68k: merge mmu and
non-mmu bitops.h"), as m68k had its own inline versions before.
commit 63e424c84429 ("arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,
BIT_LE, LAST_BIT}") added find_last_bit.o to obj-y (so it's always
included), but find_next_bit.o to lib-y (so it gets removed by the
linker if there are no builtin users).
Cc: Akinobu Mita <akinobu.mita@gmail.com>
Cc: Greg Ungerer <gerg@uclinux.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
net: Compute protocol sequence numbers and fragment IDs using MD5.
crypto: Move md5_transform to lib/md5.c
We are going to use this for TCP/IP sequence number and fragment ID
generation.
For ChromiumOS, we use SHA-1 to verify the integrity of the root
filesystem. The speed of the kernel sha-1 implementation has a major
impact on our boot performance.
To improve boot performance, we investigated using the heavily optimized
sha-1 implementation used in git. With the git sha-1 implementation, we
see a 11.7% improvement in boot time.
10 reboots, remove slowest/fastest.
Before:
Mean: 6.58 seconds Stdev: 0.14
After (with git sha-1, this patch):
Mean: 5.89 seconds Stdev: 0.07
The other cool thing about the git SHA-1 implementation is that it only
needs 64 bytes of stack for the workspace while the original kernel
implementation needed 320 bytes.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Cc: Ramsay Jones <ramsay@ramsay1.demon.co.uk>
Cc: Nicolas Pitre <nico@cam.org>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: linux-crypto@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'apei-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI, APEI, EINJ Param support is disabled by default
APEI GHES: 32-bit buildfix
ACPI: APEI build fix
ACPI, APEI, GHES: Add hardware memory error recovery support
HWPoison: add memory_failure_queue()
ACPI, APEI, GHES, Error records content based throttle
ACPI, APEI, GHES, printk support for recoverable error via NMI
lib, Make gen_pool memory allocator lockless
lib, Add lock-less NULL terminated single list
Add Kconfig option ARCH_HAVE_NMI_SAFE_CMPXCHG
ACPI, APEI, Add WHEA _OSC support
ACPI, APEI, Add APEI bit support in generic _OSC call
ACPI, APEI, GHES, Support disable GHES at boot time
ACPI, APEI, GHES, Prevent GHES to be built as module
ACPI, APEI, Use apei_exec_run_optional in APEI EINJ and ERST
ACPI, APEI, Add apei_exec_run_optional
ACPI, APEI, GHES, Do not ratelimit fatal error printk before panic
ACPI, APEI, ERST, Fix erst-dbg long record reading issue
ACPI, APEI, ERST, Prevent erst_dbg from loading if ERST is disabled
We have already acknowledged that swapoff of a tmpfs file is slower than
it was before conversion to the generic radix_tree: a little slower
there will be acceptable, if the hotter paths are faster.
But it was a shock to find swapoff of a 500MB file 20 times slower on my
laptop, taking 10 minutes; and at that rate it significantly slows down
my testing.
Now, most of that turned out to be overhead from PROVE_LOCKING and
PROVE_RCU: without those it was only 4 times slower than before; and
more realistic tests on other machines don't fare as badly.
I've tried a number of things to improve it, including tagging the swap
entries, then doing lookup by tag: I'd expected that to halve the time,
but in practice it's erratic, and often counter-productive.
The only change I've so far found to make a consistent improvement, is
to short-circuit the way we go back and forth, gang lookup packing
entries into the array supplied, then shmem scanning that array for the
target entry. Scanning in place doubles the speed, so it's now only
twice as slow as before (or three times slower when the PROVEs are on).
So, add radix_tree_locate_item() as an expedient, once-off,
single-caller hack to do the lookup directly in place. #ifdef it on
CONFIG_SHMEM and CONFIG_SWAP, as much to document its limited
applicability as save space in other configurations. And, sadly,
#include sched.h for cond_resched().
A patchset to extend tmpfs to MAX_LFS_FILESIZE by abandoning its
peculiar swap vector, instead keeping a file's swap entries in the same
radix tree as its struct page pointers: thus saving memory, and
simplifying its code and locking.
This patch:
The radix_tree is used by several subsystems for different purposes. A
major use is to store the struct page pointers of a file's pagecache for
memory management. But what if mm wanted to store something other than
page pointers there too?
The low bit of a radix_tree entry is already used to denote an indirect
pointer, for internal use, and the unlikely radix_tree_deref_retry()
case.
Define the next bit as denoting an exceptional entry, and supply inline
functions radix_tree_exception() to return non-0 in either unlikely
case, and radix_tree_exceptional_entry() to return non-0 in the second
case.
If a subsystem already uses radix_tree with that bit set, no problem: it
does not affect internal workings at all, but is defined for the
convenience of those storing well-aligned pointers in the radix_tree.
The radix_tree_gang_lookups have an implicit assumption that the caller
can deduce the offset of each entry returned e.g. by the page->index of
a struct page. But that may not be feasible for some kinds of item to
be stored there.
radix_tree_gang_lookup_slot() allow for an optional indices argument,
output array in which to return those offsets. The same could be added
to other radix_tree_gang_lookups, but for now keep it to the only one
for which we need it.
The current hyper-optimized functions are overkill if you simply want to
allocate an id for a device. Create versions which use an internal
lock.
In followup patches, numerous drivers are converted to use this
interface.
Thanks to Tejun for feedback.
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
init_fault_attr_dentries() is used to export fault_attr via debugfs.
But it can only export it in debugfs root directory.
Per Forlin is working on mmc_fail_request which adds support to inject
data errors after a completed host transfer in MMC subsystem.
The fault_attr for mmc_fail_request should be defined per mmc host and
export it in debugfs directory per mmc host like
/sys/kernel/debug/mmc0/mmc_fail_request.
init_fault_attr_dentries() doesn't help for mmc_fail_request. So this
introduces fault_create_debugfs_attr() which is able to create a
directory in the arbitrary directory and replace
init_fault_attr_dentries().
[akpm@linux-foundation.org: extraneous semicolon, per Randy]
Tested-by: Per Forlin <per.forlin@linaro.org>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Some trivial conflicts due to other various merges
adding to the end of common lists sooner than this one.
arch/ia64/Kconfig
arch/powerpc/Kconfig
arch/x86/Kconfig
lib/Kconfig
lib/Makefile
Signed-off-by: Len Brown <len.brown@intel.com>
This version of the gen_pool memory allocator supports lockless
operation.
This makes it safe to use in NMI handlers and other special
unblockable contexts that could otherwise deadlock on locks. This is
implemented by using atomic operations and retries on any conflicts.
The disadvantage is that there may be livelocks in extreme cases. For
better scalability, one gen_pool allocator can be used for each CPU.
The lockless operation only works if there is enough memory available.
If new memory is added to the pool a lock has to be still taken. So
any user relying on locklessness has to ensure that sufficient memory
is preallocated.
The basic atomic operation of this allocator is cmpxchg on long. On
architectures that don't have NMI-safe cmpxchg implementation, the
allocator can NOT be used in NMI handler. So code uses the allocator
in NMI handler should depend on CONFIG_ARCH_HAVE_NMI_SAFE_CMPXCHG.
Signed-off-by: Huang Ying <ying.huang@intel.com>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cmpxchg is used to implement adding new entry to the list, deleting
all entries from the list, deleting first entry of the list and some
other operations.
Because this is a single list, so the tail can not be accessed in O(1).
If there are multiple producers and multiple consumers, llist_add can
be used in producers and llist_del_all can be used in consumers. They
can work simultaneously without lock. But llist_del_first can not be
used here. Because llist_del_first depends on list->first->next does
not changed if list->first is not changed during its operation, but
llist_del_first, llist_add, llist_add (or llist_del_all, llist_add,
llist_add) sequence in another consumer may violate that.
If there are multiple producers and one consumer, llist_add can be
used in producers and llist_del_all or llist_del_first can be used in
the consumer.
This can be summarized as follow:
| add | del_first | del_all
add | - | - | -
del_first | | L | L
del_all | | | -
Where "-" stands for no lock is needed, while "L" stands for lock is
needed.
The list entries deleted via llist_del_all can be traversed with
traversing function such as llist_for_each etc. But the list entries
can not be traversed safely before deleted from the list. The order
of deleted entries is from the newest to the oldest added one. If you
want to traverse from the oldest to the newest, you must reverse the
order by yourself before traversing.
The basic atomic operation of this list is cmpxchg on long. On
list can NOT be used in NMI handler. So code uses the list in NMI
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Use debugfs_remove_recursive() to simplify initialization and
deinitialization of fault injection debugfs files.
Minor cosmetic changes for simple attribute of stacktrace_depth:
- use min_t()
- reduce #ifdef by moving a function
- do not use partly capitalized function name
No need to include linux/kallsyms.h.
NUMA_NO_NODE and numa_node_id() have different meanings. NUMA_NO_NODE is
obviously the recommended fallback.
Adapt new API fashion.
[ This patch has already been accepted as commit 0ac0c0d0f837 but later
reverted (commit 35926ff5fba8) because it itroduced arch specific
__node_random which was defined only for x86 code so it broke other
archs. This is a followup without any arch specific code. Other than
that there are no functional changes.]
Some workloads that create a large number of small files tend to assign
too many pages to node 0 (multi-node systems). Part of the reason is
that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts
at node 0 for newly created tasks.
This patch changes the rotor to be initialized to a random node number
of the cpuset.
[akpm@linux-foundation.org: fix layout]
[Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration]
[mhocko@suse.cz: Make it arch independent]
[akpm@linux-foundation.org: fix CONFIG_NUMA=y, MAX_NUMNODES>1 build]
Signed-off-by: Jack Steiner <steiner@sgi.com>
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Paul Menage <menage@google.com>
Cc: Jack Steiner <steiner@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
* Merge akpm patch series: (122 commits)
drivers/connector/cn_proc.c: remove unused local
Documentation/SubmitChecklist: add RCU debug config options
reiserfs: use hweight_long()
reiserfs: use proper little-endian bitops
pnpacpi: register disabled resources
drivers/rtc/rtc-tegra.c: properly initialize spinlock
drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time()
drivers/rtc: add support for Qualcomm PMIC8xxx RTC
drivers/rtc/rtc-s3c.c: support clock gating
drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200
init: skip calibration delay if previously done
misc/eeprom: add eeprom access driver for digsy_mtc board
misc/eeprom: add driver for microwire 93xx46 EEPROMs
checkpatch.pl: update $logFunctions
checkpatch: make utf-8 test --strict
checkpatch.pl: add ability to ignore various messages
checkpatch: add a "prefer __aligned" check
checkpatch: validate signature styles and To: and Cc: lines
checkpatch: add __rcu as a sparse modifier
checkpatch: suggest using min_t or max_t
Did this as a merge because of (trivial) conflicts in
- Documentation/feature-removal-schedule.txt
- arch/xtensa/include/asm/uaccess.h
that were just easier to fix up in the merge than in the patch series.
This function is required by *printf and kstrto* functions that are
located in the different modules. This patch makes _tolower() public.
However, it's good idea to not use the helper outside of mentioned
functions.
Acked-by: Alexey Dobriyan <adobriyan@gmail.com>
The symbol 'lcm' is exported to the kernel (EXPORT_SYMBOL_GPL).
Pick up it's definition in <linux/lcm.h> to quiet the sparse noise:
warning: symbol 'lcm' was not declared. Should it be static?
devres uses the pointer value as key after it's freed, which is safe but
triggers spurious use-after-free warnings on some static analysis tools.
Rearrange code to avoid such warnings.
Signed-off-by: Maxin B. John <maxin.john@gmail.com>
Reviewed-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
<linux/kernel.h> is needed for min_t. The old version
happened to work on x86 because <asm/unaligned.h>
indirectly includes <linux/kernel.h>, but it didn't
work on ARM.
<linux/kernel.h> includes <asm/byteorder.h> so it's
not necessary to include it explicitly anymore.
* 'for-upstream' of git://openrisc.net/jonas/linux: (24 commits)
OpenRISC: Add MAINTAINERS entry
OpenRISC: Miscellaneous
OpenRISC: Library routines
OpenRISC: Headers
OpenRISC: Traps
OpenRISC: Module support
OpenRISC: GPIO
OpenRISC: Scheduling/Process management
OpenRISC: Idle/Power management
OpenRISC: System calls
OpenRISC: IRQ
OpenRISC: Timekeeping
OpenRISC: DMA
OpenRISC: PTrace
OpenRISC: Build infrastructure
OpenRISC: Signal handling
OpenRISC: Memory management
OpenRISC: Device tree
OpenRISC: Boot code
iomap: make IOPORT/PCI mapping functions conditional
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits)
sched: Cleanup duplicate local variable in [enqueue|dequeue]_task_fair
sched: Replace use of entity_key()
sched: Separate group-scheduling code more clearly
sched: Reorder root_domain to remove 64 bit alignment padding
sched: Do not attempt to destroy uninitialized rt_bandwidth
sched: Remove unused function cpu_cfs_rq()
sched: Fix (harmless) typo 'CONFG_FAIR_GROUP_SCHED'
sched, cgroup: Optimize load_balance_fair()
sched: Don't update shares twice on on_rq parent
sched: update correct entity's runtime in check_preempt_wakeup()
xtensa: Use generic config PREEMPT definition
h8300: Use generic config PREEMPT definition
m32r: Use generic PREEMPT config
sched: Skip autogroup when looking for all rt sched groups
sched: Simplify mutex_spin_on_owner()
sched: Remove rcu_read_lock() from wake_affine()
sched: Generalize sleep inside spinlock detection
sched: Make sleeping inside spinlock detection working in !CONFIG_PREEMPT
sched: Isolate preempt counting in its own config option
sched: Remove pointless in_atomic() definition check
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
lockdep: Fix lockdep_no_validate against IRQ states
mutex: Make mutex_destroy() an inline function
plist: Remove the need to supply locks to plist heads
lockup detector: Fix reference to the non-existent CONFIG_DETECT_SOFTLOCKUP option
Use the CONFIG_HAS_IOPORT and CONFIG_PCI options to decide whether or
not functions for mapping these areas are provided.
Signed-off-by: Jonas Bonn <jonas@southpole.se>
Merge reason: pick up the latest scheduler fixes.
The draft has evolved to RFC 5952.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
net/bluetooth/l2cap_core.c
This was legacy code brought over from the RT tree and
is no longer necessary.
Signed-off-by: Dima Zavin <dima@android.com>
Cc: Daniel Walker <dwalker@codeaurora.org>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Link: http://lkml.kernel.org/r/1310084879-10351-2-git-send-email-dima@android.com
'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
debugobjects: Fix boot crash when kmemleak and debugobjects enabled
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
jump_label: Fix jump_label update for modules
oprofile, x86: Fix race in nmi handler while starting counters
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Disable (revert) SCHED_LOAD_SCALE increase
sched, cgroups: Fix MIN_SHARES on 64-bit boxen
Reduce the number of variables modified by the loop in do_csum() by 1,
which seems like a good idea. On Nios II (a RISC CPU with 3-operand
instruction set) it reduces the loop from 7 to 6 instructions, including
the conditional branch.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
option
Replace CONFIG_DETECT_SOFTLOCKUP with CONFIG_LOCKUP_DETECTOR.
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: fweisbec@gmail.com
Cc: a.p.zijlstra@chello.nl
Link: http://lkml.kernel.org/r/20110705133240.25e81a7a@kryten
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into sched/core
The sleeping inside spinlock detection is actually used
for more general sleeping inside atomic sections
debugging: preemption disabled, rcu read side critical
sections, interrupts, interrupt disabled, etc...
Change the name of the config and its help section to
reflect its more general role.
drivers/net/wireless/iwlwifi/iwl-agn-rxon.c
drivers/net/wireless/rtlwifi/pci.c
net/netfilter/ipvs/ip_vs_core.c
Order of initialization look like this:
debugobjects
kmemleak
...(lots of other subsystems)...
workqueues (through early initcall)
debugobjects use schedule_work for batch freeing of its data and kmemleak
heavily use debugobjects, so when it comes to freeing and workqueues were
not initialized yet, kernel crashes:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff810854d1>] __queue_work+0x29/0x41a
[<ffffffff81085910>] queue_work_on+0x16/0x1d
[<ffffffff81085abc>] queue_work+0x29/0x55
[<ffffffff81085afb>] schedule_work+0x13/0x15
[<ffffffff81242de1>] free_object+0x90/0x95
[<ffffffff81242f6d>] debug_check_no_obj_freed+0x187/0x1d3
[<ffffffff814b6504>] ? _raw_spin_unlock_irqrestore+0x30/0x4d
[<ffffffff8110bd14>] ? free_object_rcu+0x68/0x6d
[<ffffffff8110890c>] kmem_cache_free+0x64/0x12c
[<ffffffff8110bd14>] free_object_rcu+0x68/0x6d
[<ffffffff810b58bc>] __rcu_process_callbacks+0x1b6/0x2d9
because system_wq is NULL.
Fix it by checking if workqueues susbystem was initialized before using.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Dipankar Sarma <dipankar@in.ibm.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: stable@kernel.org
Link: http://lkml.kernel.org/r/20110528112342.GA3068@joi.lan
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
AFS: Use i_generation not i_version for the vnode uniquifier
AFS: Set s_id in the superblock to the volume name
vfs: Fix data corruption after failed write in __block_write_begin()
afs: afs_fill_page reads too much, or wrong data
VFS: Fix vfsmount overput on simultaneous automount
fix wrong iput on d_inode introduced by e6bc45d65d
Delay struct net freeing while there's a sysfs instance refering to it
afs: fix sget() races, close leak on umount
ubifs: fix sget races
ubifs: split allocation of ubifs_info into a separate function
fix leak in proc_set_super()
Fix new kernel-doc warnings in lib/bitmap.c:
Warning(lib/bitmap.c:596): No description found for parameter 'buf'
Warning(lib/bitmap.c:596): Excess function parameter 'bp' description in '__bitmap_parselist'
* new refcount in struct net, controlling actual freeing of the memory
* new method in kobj_ns_type_operations (->drop_ns())
* ->current_ns() semantics change - it's supposed to be followed by
corresponding ->drop_ns(). For struct net in case of CONFIG_NET_NS it bumps
the new refcount; net_drop_ns() decrements it and calls net_free() if the
last reference has been dropped. Method renamed to ->grab_current_ns().
* old net_free() callers call net_drop_ns() instead.
* sysfs_exit_ns() is gone, along with a large part of callchain
leading to it; now that the references stored in ->ns[...] stay valid we
do not need to hunt them down and replace them with NULL. That fixes
problems in sysfs_lookup() and sysfs_readdir(), along with getting rid
of sb->s_instances abuse.
Note that struct net *shutdown* logics has not changed - net_cleanup()
is called exactly when it used to be called. The only thing postponed by
having a sysfs instance refering to that struct net is actual freeing of
memory occupied by struct net.
Select CONFIG_PREEMPT_COUNT when we enable the sleeping inside
spinlock detection, so that the preempt offset gets correctly
incremented/decremented from preempt_disable()/preempt_enable().
This makes the preempt count eventually working in !CONFIG_PREEMPT
when that debug option is set and thus fixes the detection of explicit
preemption disabled sections under such config. Code that sleeps
in explicitly preempt disabled section can be finally spotted
in non-preemptible kernels.
