Commit ef0658f3de484bf9b173639cd47544584e01efa5 changed precision
from int to s8.
There is existing kernel code that uses a larger precision.
An example from the audit code:
vsnprintf(...,..., " msg='%.1024s'", (char *)data);
which overflows precision and truncates to nothing.
Extending precision size fixes the audit system issue.
Other changes:
Change the size of the struct printf_spec.type from u16 to u8 so
sizeof(struct printf_spec) stays as small as possible.
Reorder the struct members so sizeof(struct printf_spec) remains 64 bits
without alignment holes.
Document the struct members a bit more.
Original-patch-by: Eric Paris <eparis@redhat.com>
Tested-by: Justin P. Mattock <justinmattock@gmail.com>
Add support for resource windows. This is for bridge resources, i.e.,
regions where a bridge forwards transactions from the primary to the
secondary side.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Add support for bus number resources. This is for bridges with a range of
bus numbers behind them.
This adds separate I/O and memory specs, so we don't have to change the
field width in a shared spec, which then lets us make all the specs const
and static, since they never change.
Add clues about what the SMALL and SPECIAL flags do.
Reducing the size of struct printf_spec is a good thing because multiple
instances are commonly passed on stack.
It's possible for type to be u8 and field_width to be s8, but this is
likely small enough for now.
little endian
This should allow the removal of the #defines and uses
of NIPQUAD and NIPQUAD_FMT
Reported-by: Josip Rodin <joy@entuzijast.net>
Cc: Joe Perches <joe@perches.com>
On Mon, 2010-01-04 at 23:43 +0000, Maciej W. Rozycki wrote:
> The example below shows an address, and the sequence of bits or symbols
> that would be transmitted when the address is used in the Source Address
> or Destination Address fields on the MAC header. The transmission line
> shows the address bits in the order transmitted, from left to right. For
> IEEE 802 LANs these correspond to actual bits on the medium. The FDDI
> symbols line shows how the FDDI PHY sends the address bits as encoded
> symbols.
> MSB: 35:7B:12:00:00:01
> Canonical: AC-DE-48-00-00-80
> Transmission: 00110101 01111011 00010010 00000000 00000000 00000001
> FDDI Symbols: 35 7B 12 00 00 01"
> Please note that this address has its group bit clear.
> This notation is also defined in the "FDDI MEDIA ACCESS CONTROL-2
> (MAC-2)" (X3T9/92-120) document although that book does not have a need
> to use the MSB form and it's skipped.
Adds 6 bytes to object size for x86
New:
$ size lib/vsprintf.o
8664 0 2 8666 21da lib/vsprintf.o
8658 0 2 8660 21d4 lib/vsprintf.o
These were added in
9ac6e44 (lib/vsprintf.c: add %pU to print UUID/GUIDs)
c7dabef (vsprintf: use %pR, %pr instead of %pRt, %pRf)
8a27f7c (lib/vsprintf.c: Add "%pI6c" - print pointer as compressed ipv6 address)
4aa9960 (printk: add %I4, %I6, %i4, %i6 format specifiers)
dd45c9c (printk: add %pM format specifier for MAC addresses)
but only added comments to pointer() not vsnprintf() that is refered to by
printk's comments.
Cc: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Jens Rosenboom <jens@mcbone.net>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
UUID/GUIDs are somewhat common in kernel source.
Standardize the printed style of UUID/GUIDs by using
another extension to %p.
%pUb: 01020304-0506-0708-090a-0b0c0d0e0f10
%pUB: 01020304-0506-0708-090A-0B0C0D0E0F10 (upper case)
%pUl: 04030201-0605-0807-090a-0b0c0d0e0f10
%pUL: 04030201-0605-0807-090A-0B0C0D0E0F10 (upper case)
%pU defaults to %pUb
Cc: Jeff Garzik <jgarzik@redhat.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Alex Elder <aelder@sgi.com>
Cc: Artem Bityutskiy <dedekind@infradead.org>
Cc: Adrian Hunter <adrian.hunter@nokia.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Neil Brown <neilb@suse.de>
Makes use of skip_spaces() defined in lib/string.c for removing leading
spaces from strings all over the tree.
It decreases lib.a code size by 47 bytes and reuses the function tree-wide:
64688 584 592 65864 10148 (TOTALS-BEFORE)
64641 584 592 65817 10119 (TOTALS-AFTER)
Also, while at it, if we see (*str && isspace(*str)), we can be sure to
remove the first condition (*str) as the second one (isspace(*str)) also
evaluates to 0 whenever *str == 0, making it redundant. In other words,
"a char equals zero is never a space".
Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below,
and found occurrences of this pattern on 3 more files:
drivers/leds/led-class.c
drivers/leds/ledtrig-timer.c
drivers/video/output.c
expression str;
( // ignore skip_spaces cases
while (*str && isspace(*str)) { \(str++;\|++str;\) }
- *str &&
isspace(*str)
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Cc: Julia Lawall <julia@diku.dk>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Cc: <linux-ext4@vger.kernel.org>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Takashi Iwai <tiwai@suse.de>
The difference between simple_strtoul() and simple_strtoull() is just
the size of the variable used to keep track of the sum of characters
converted to numbers:
unsigned long simple_strtoul() {...}
unsigned long long simple_strtoull(){...}
Both are same size on my Core 2/gcc 4.4.1.
Overflow condition is not checked on both functions, so an extremely large
string can break these functions so that they don't even notice it.
As we do not care for overflowing on these functions, always keep the sum
using the larger variable around (unsigned long long) on simple_strtoull()
and cast it to (unsigned long) on simple_strtoul(), which then becomes
just a wrapper around simple_strtoull().
Code size decreases by 304 bytes:
15534 0 8 15542 3cb6 vsprintf.o (ex lib/lib.a-BEFORE)
15230 0 8 15238 3b86 vsprintf.o (ex lib/lib.a-AFTER)
When converting more caller sites, the inline decision will be left up to gcc.
It decreases code size:
15710 0 8 15718 3d66 vsprintf.o (ex lib/lib.a-BEFORE)
15534 0 8 15542 3cb6 vsprintf.o (ex lib/lib.a-AFTER)
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Cleanup by moving variables closer to the scope where they're used in fact.
Also, remove unneeded ones.
No functional change, just refactor the code so that it avoid checking
"if (hi)" two times in a sequence, taking advantage of previous check made.
It also reduces code size:
15726 0 8 15734 3d76 vsprintf.o (ex lib/lib.a-BEFORE)
15710 0 8 15718 3d66 vsprintf.o (ex lib/lib.a-AFTER)
It decreases code size as well:
15758 0 8 15766 3d96 vsprintf.o (ex lib/lib.a-BEFORE)
15726 0 8 15734 3d76 vsprintf.o (ex lib/lib.a-TOLOWER)
Most relevant complaints were addressed.
This patchset reduces lib/lib.a code size by 482 bytes on my Core 2 with
gcc 4.4.1 even considering that it exports a newly defined function
skip_spaces() to drivers:
64867 840 592 66299 102fb (TOTALS-lib.a-BEFORE)
64641 584 592 65817 10119 (TOTALS-lib.a-AFTER)
and implements some code tidy up.
Besides reducing lib.a size, it converts many in-tree drivers to use the
newly defined function, which makes another small reduction on kernel size
overall when those drivers are used.
This patch:
Change "<NULL>" to "(null)", unifying 3 equal strings.
glibc also uses "(null)" for the same purpose.
It decreases code size by 7 bytes:
15765 0 8 15773 3d9d vsprintf.o (ex lib/lib.a-BEFORE)
15758 0 8 15766 3d96 vsprintf.o (ex lib/lib.a-AFTER)
Jesse accidentally applied v1 [1] of the patchset instead of v2 [2]. This
is the diff between v1 and v2.
The changes in this patch are:
- tidied vsprintf stack buffer to shrink and compute size more
accurately
- use %pR for decoding and %pr for "raw" (with type and flags) instead
of adding %pRt and %pRf
[1] http://lkml.org/lkml/2009/10/6/491
[2] http://lkml.org/lkml/2009/10/13/441
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
This adds support for printing struct resource type and flag information.
For example, "%pRt" looks like "[mem 0x80080000000-0x8008001ffff 64bit pref]",
and "%pRf" looks like "[mem 0xff5e2000-0xff5e2007 pref flags 0x1]".
Print addresses (IO port numbers and memory addresses) in hex, but print
others (IRQs and DMA channels) in decimal. Only print the end if it's
different from the start.
The leading "0x" consumes field width, so leave space for it in addition to
the 4 or 8 hex digits. This means we'll print "0x0000-0x01df" rather than
"0x00-0x1df", for example.
When using %*s, sscanf should honor conversion specifiers immediately
following the %*s. For example, the following code should find the
position of the end of the string "hello".
int end;
char buf[] = "hello world";
sscanf(buf, "%*s%n", &end);
printf("%d\n", end);
Ideally, sscanf would advance the fmt and str pointers the same as it
would without the *, but the code for that is rather complicated and is
not included in the patch.
Signed-off-by: Andy Spencer <andy753421@gmail.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/cpc-usb/TODO
drivers/staging/cpc-usb/cpc-usb_drv.c
drivers/staging/cpc-usb/cpc.h
drivers/staging/cpc-usb/cpc_int.h
drivers/staging/cpc-usb/cpcusb.h
Jens Rosenboom noticed that a possibly unaligned const char*
is cast to a const struct in6_addr *.
Avoid this at the cost of a struct in6_addr copy on the stack.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com>
Remove the duplicate comment of bstr_printf that is the same as the
vsnprintf.
Add the 's' option to the comment for the pointer function. This is
more of an internal function so the little duplication of the comment
here is OK.
Reported-by: Zhaolei <zhaolei@cn.fujitsu.com>
On PowerPC64 function pointers do not point directly at the functions,
but instead point to pointers to the functions. The output of %pF expects
to point to a pointer to the function, whereas %pS will show the function
itself.
mcount returns the direct pointer to the function and not the pointer to
the pointer. Thus %pS must be used to show this. The function tracer
requires printing of the functions without offsets and uses the %pf
instead.
%pF produces run_local_timers+0x4/0x1f
%pf produces just run_local_timers
For PowerPC64, we need to use the direct pointer, and we only have
%pS which will produce .run_local_timers+0x4/0x1f
This patch creates a %ps that matches the %pf as %pS matches %pF.
Cc: Zhao Lei <zhaolei@cn.fujitsu.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Tested-by: Jens Rosenboom <jens@mcbone.net>
A printf format specifier which would allow us to print a pure
function name has been suggested by Andrew Morton a couple of
months ago.
The current %pF is very convenient to print a function symbol,
but often we only want to print the name of the function, without
its asm offset.
That's what %pf does in this patch. The lowecase f has been chosen
for its intuitive meaning of a 'weak kind of %pF'.
The support for this new format would be welcome by the tracing code
where the need to print pure function names is often needed. This is
also true for other parts of the kernel:
$ git-grep -E "kallsyms_lookup\(.+?\)"
arch/blackfin/kernel/traps.c: symname = kallsyms_lookup(address, &symsize, &offset, &modname, namebuf);
arch/powerpc/xmon/xmon.c: name = kallsyms_lookup(pc, &size, &offset, NULL, tmpstr);
arch/sh/kernel/cpu/sh5/unwind.c: sym = kallsyms_lookup(pc, NULL, &offset, NULL, namebuf);
arch/x86/kernel/ftrace.c: kallsyms_lookup((unsigned long) syscall, NULL, NULL, NULL, str);
kernel/kprobes.c: sym = kallsyms_lookup((unsigned long)p->addr, NULL,
kernel/lockdep.c: return kallsyms_lookup((unsigned long)key, NULL, NULL, NULL, str);
kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, NULL, str);
kernel/trace/ftrace.c: kallsyms_lookup((unsigned long)rec->ops->func, NULL, NULL, NULL, str);
kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, &modname, str);
kernel/trace/ftrace.c: kallsyms_lookup(*ptr, NULL, NULL, NULL, str);
kernel/trace/trace_functions.c: kallsyms_lookup(ip, NULL, NULL, NULL, str);
kernel/trace/trace_output.c: kallsyms_lookup(address, NULL, NULL, NULL, str);
Changes in v2:
- Add the explanation of the %pf role for vsnprintf() and bstr_printf()
- Change the comments by dropping the "asm offset" notion and only
define the %pf against the actual function offset notion.
Cc: Zhaolei <zhaolei@cn.fujitsu.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <20090415154817.GC5989@nowhere>
Impact: new feature, extend vsprintf format strings
hh is used as length modifier for signed char or unsigned char.
It is supported by glibc, we add kernel support now.
Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com>
Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: torvalds@linux-foundation.org
LKML-Reference: <49CC9739.30107@cn.fujitsu.com>
printk("%Q");
Output before patch: %QQ
Output after patch: %Q
LKML-Reference: <49CC97B6.7040809@cn.fujitsu.com>
Impact: cleanup
Rename FORMAT_TYPE_WITDH
to => FORMAT_TYPE_WIDTH
Jeremy Fitzhardinge reported:
> Change fef20d9c1380f04ba9492d6463148db07b413708, "vsprintf:
> unify the format decoding layer for its 3 users", causes a
> regression in xenbus which results in no devices getting
> attached to a new domain.
%.*s is broken - fix it.
Reported-by: Jeremy Fitzhardinge <jeremy@goop.org>
Sitsofe Wheeler found and bisected that while unifying the
vsprintf format decoding in:
fef20d9: vsprintf: unify the format decoding layer for its 3 users
The sign flag has been dropped out in favour of
precise types (ie: LONG/ULONG).
But the format helper number() still needs this flag to keep track of
the signedness unless it will consider all numbers as unsigned.
Also add an explicit cast to int (for %d) while parsing with va_arg()
to ensure the highest bit is well extended on the 64 bits number that
hosts the value in case of negative values.
Reported-Bisected-Tested-by: Sitsofe Wheeler <sitsofe@yahoo.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
LKML-Reference: <20090309201503.GA5010@nowhere>
An new optimization is making its way to ftrace. Its purpose is to
make trace_printk() consuming less memory and be faster.
Written by Lai Jiangshan, the approach is to delay the formatting
job from tracing time to output time.
Currently, a call to trace_printk() will format the whole string and
insert it into the ring buffer. Then you can read it on /debug/tracing/trace
file.
The new implementation stores the address of the format string and
the binary parameters into the ring buffer, making the packet more compact
and faster to insert.
Later, when the user exports the traces, the format string is retrieved
with the binary parameters and the formatting job is eventually done.
The new implementation rewrites a lot of format decoding bits from
vsnprintf() function, making now 3 differents functions to maintain
in their duplicated parts of printf format decoding bits.
Suggested by Ingo Molnar, this patch tries to factorize the most
possible common bits from these functions.
The real common part between them is the format decoding. Although
they do somewhat similar jobs, their way to export or import the parameters
is very different. Thus, only the decoding layer is extracted, unless you see
other parts that could be worth factorized.
Changes in V2:
- Address a suggestion from Linus to group the format_decode() parameters inside
a structure.
Changes in v3:
- Address other cleanups suggested by Ingo and Linus such as passing the
printf_spec struct to the format helpers: pointer()/number()/string()
Note that this struct is passed by copy and not by address. This is to
avoid side effects because these functions often change these values and the
changes shoudn't be persistant when a callee helper returns.
It would be too risky.
- Various cleanups (code alignement, switch/case instead of if/else fountains).
- Fix a bug that printed the first format specifier following a %p
Changes in v4:
- drop unapropriate const qualifier loss while casting fmt to a char *
(thanks to Vegard Nossum for having pointed this out).
Acked-by: Steven Rostedt <rostedt@goodmis.org>
LKML-Reference: <1236356510-8381-6-git-send-email-fweisbec@gmail.com>
Impact: add new APIs for binary trace printk infrastructure
vbin_printf(): write args to binary buffer, string is copied
when "%s" is occurred.
bstr_printf(): read from binary buffer for args and format a string
[fweisbec@gmail.com: rebase]
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
LKML-Reference: <1236356510-8381-2-git-send-email-fweisbec@gmail.com>
It decodes "\n" as 0, which is bad, because stray echo into backlight
will turn your backlight off, etc...
Signed-off-by: Pavel Machek <pavel@suse.cz>
Cc: Yi Yang <yi.y.yang@intel.com>
Before, when we only ever printed out the pointer value itself, a NULL
pointer would never cause issues and might as well be printed out as
just its numeric value.
However, with the extended %p formats, especially %pR, we might validly
want to print out resources for debugging. And sometimes they don't
even exist, and the resource pointer is just NULL. Print it out as
such, rather than oopsing.
This is a more generic version of a patch done by Trent Piepho (catching
all %p cases rather than just %pR, and using "(null)" instead of
"[NULL]" to match glibc).
Requested-by: Trent Piepho <xyzzy@speakeasy.org>
Acked-by: Harvey Harrison <harvey.harrison@gmail.com>
Add %pm to omit the colons when printing a mac address.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
put_dec_trunc prints the digits in reverse order and is reversed
inside number(). Continue using put_dec_trunc, but reverse each quad
in ip4_addr_string.
[Noticed by Julius Volz]
For use in printing IPv4, or IPv6 addresses in the usual way:
%i4 and %I4 are currently equivalent and print the address in
dot-separated decimal x.x.x.x
%I6 prints 16-bit network order hex with colon separators:
xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx
%i6 omits the colons.
Takes a pointer to a IPv6 address and formats it in the usual
colon-separated hex format:
Each 16 bit word is printed in network-endian byteorder.
%#p6 is also supported and will omit the colons.
%p6 is a replacement for NIP6_FMT and NIP6()
%#p6 is a replacement for NIP6_SEQFMT and NIP6()
Note that NIP6() took a struct in6_addr whereas this takes a pointer
to a struct in6_addr.
Add format specifiers for printing out six colon-separated bytes:
MAC addresses (%pM):
xx:xx:xx:xx:xx:xx
%#pM is also supported and omits the colon separators.
Add a %pR option to the kernel vsnprintf that prints the range of
addresses inside a struct resource passed by pointer.
