path: root/lib/swiotlb.c
2008-11-17swiotlb: use coherent_dma_mask in alloc_coherentFUJITA Tomonori
Impact: fix DMA buffer allocation coherency bug in certain configs This patch fixes swiotlb to use dev->coherent_dma_mask in swiotlb_alloc_coherent(). coherent_dma_mask is a subset of dma_mask (equal to it most of the time), enumerating the address range that a given device is able to DMA to/from in a cache-coherent way. But currently, swiotlb uses dev->dma_mask in alloc_coherent() implicitly via address_needs_mapping(), but alloc_coherent is really supposed to use coherent_dma_mask. This bug could break drivers that uses smaller coherent_dma_mask than dma_mask (though the current code works for the majority that use the same mask for coherent_dma_mask and dma_mask). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: tony.luck@intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-23swiotlb: remove panic for alloc_coherent failureFUJITA Tomonori
swiotlb_alloc_coherent calls panic() when allocated swiotlb pages is not fit for a device's dma mask. However, alloc_coherent failure is not a disaster at all. AFAIK, none of other x86 and IA64 IOMMU implementations don't crash in case of alloc_coherent failure. There are some drivers that don't check alloc_coherent failure but not many (about ten and I've already started to fix some of them). alloc_coherent returns NULL in case of failure so it's likely that these guilty drivers crash immediately. So swiotlb doesn't need to call panic() just for them. Reported-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-19convert swiotlb to use dma_get_maskFUJITA Tomonori
swiotlb can use dma_get_mask() instead of the homegrown function. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: tony.luck@intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-10swiotlb: convert swiotlb to use is_buffer_dma_capable helper functionFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-08swiotlb: add is_swiotlb_buffer helper functionFUJITA Tomonori
This adds is_swiotlb_buffer() helper function to see whether a buffer belongs to the swiotlb buffer or not. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-08swiotlb: use unmap_single instead of swiotlb_unmap_single in ↵FUJITA Tomonori
swiotlb_free_coherent We don't need any check in swiotlb_unmap_single here. unmap_single is appropriate. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-08swiotlb: use map_single instead of swiotlb_map_single in swiotlb_alloc_coherentFUJITA Tomonori
We always need swiotlb memory here so address_needs_mapping and swiotlb_force testings are irrelevant. map_single should be used here instead of swiotlb_map_single. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-08swiotlb: remove GFP_DMA hack in swiotlb_alloc_coherentFUJITA Tomonori
The callers are supposed to set up the gfp flags appropriately. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29dma/ia64: update ia64 machvecs, swiotlb.cArthur Kepner
Change all ia64 machvecs to use the new dma_*map*_attrs() interfaces. Implement the old dma_*map_*() interfaces in terms of the corresponding new interfaces. For ia64/sn, make use of one dma attribute, DMA_ATTR_WRITE_BARRIER. Introduce swiotlb_*map*_attrs() functions. Signed-off-by: Arthur Kepner <akepner@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Jes Sorensen <jes@sgi.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29swiotlb: use iommu_is_span_boundary helper functionFUJITA Tomonori
iommu_is_span_boundary in lib/iommu-helper.c was exported for PARISC IOMMUs (commit 3715863aa142c4f4c5208f5f3e5e9bac06006d2f). SWIOTLB can use it instead of the homegrown function. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29lib/swiotlb.c: cleanupsAndrew Morton
There's a pointlessly braced block of code in there. Remove the braces and save a tabstop. Cc: Andi Kleen <ak@suse.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jan Beulich <jbeulich@novell.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-13avoid endless loops in lib/swiotlb.cJan Beulich
Commit 681cc5cd3efbeafca6386114070e0bfb5012e249 ("iommu sg merging: swiotlb: respect the segment boundary limits") introduced two possibilities for entering an endless loop in lib/swiotlb.c: - if max_slots is zero (possible if mask is ~0UL) - if the number of slots requested fits into a swiotlb segment, but is too large for the part of a segment which remains after considering offset_slots This fixes them Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg merging: swiotlb: respect the segment boundary limitsFUJITA Tomonori
This patch makes swiotlb not allocate a memory area spanning LLD's segment boundary. is_span_boundary() judges whether a memory area spans LLD's segment boundary. If map_single finds such a area, map_single tries to find the next available memory area. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Greg KH <greg@kroah.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22Update swiotlb to use sg helpersJens Axboe
2007-10-17swiotlb: fix map_sg failure handlingFUJITA Tomonori
sg list elements might not be continuous. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-16swiotlb: sg chaining supportJens Axboe
2007-10-12dma_free_coherent() needs irqs enabled (sigh)David Brownell
On at least ARM (and I'm told MIPS too) dma_free_coherent() has a newish call context requirement: unlike its dma_alloc_coherent() sibling, it may not be called with IRQs disabled. (This was new behavior on ARM as of late 2005, caused by ARM SMP updates.) This little surprise can be annoyingly driver-visible. Since it looks like that restriction won't be removed, this patch changes the definition of the API to include that requirement. Also, to help catch nonportable drivers, it updates the x86 and swiotlb versions to include the relevant warnings. (I already observed that it trips on the bus_reset_tasklet of the new firewire_ohci driver.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Miller <davem@davemloft.net> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-21Fix swiotlb_sync_single_range()Keir Fraser
If the swiotlb maps a multi-slab region, swiotlb_sync_single_range() can be invoked to sync a sub-region which does not include the first slab. Unfortunately io_tlb_orig_addr[] is only initialised for the first slab, and hence the call to sync_single() will read a garbage orig_addr in this case. This patch fixes the issue by initialising all mapped slabs in io_tlb_orig_addr[]. It also correctly adjusts the buffer pointer in sync_single() to handle the case that the given dma_addr is not aligned on a slab boundary. Signed-off-by: Keir Fraser <keir.fraser@cl.cam.ac.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Acked-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fix section mismatch warning in lib/swiotlb.cSam Ravnborg
kbuild spits outs following warning on a defconfig x86_64 build: WARNING: swiotlb.o - Section mismatch: reference to .init.text:swiotlb_init from __ksymtab between '__ksymtab_swiotlb_init' (at offset 0xa0) and '__ksymtab_swiotlb_free_coherent' This warning happens because the function swiotlb_init is marked __init and EXPORT_SYMBOL(). A 'git grep swiotlb_init' showed no users in drivers/ so remove the EXPORT_SYMBOL. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-06Revert "[IA64] swiotlb abstraction (e.g. for Xen)"Tony Luck
This reverts commit 51099005ab8e09d68a13fea8d55bc739c1040ca6.
2007-02-12[PATCH] swiotlb uninliningsAndrew Morton
Optimise swiotlb.c for size. text data bss dec hex filename 5009 89 64 5162 142a lib/swiotlb.o-before 4666 89 64 4819 12d3 lib/swiotlb.o-after For some reason my gcc (4.0.2) doesn't want to tailcall these things. swiotlb_sync_sg_for_device: pushq %rbp # movl $1, %r8d #, movq %rsp, %rbp #, call swiotlb_sync_sg # leave ret .size swiotlb_sync_sg_for_device, .-swiotlb_sync_sg_for_device .section .text.swiotlb_sync_sg_for_cpu,"ax",@progbits .globl swiotlb_sync_sg_for_cpu .type swiotlb_sync_sg_for_cpu, @function swiotlb_sync_sg_for_cpu: pushq %rbp # xorl %r8d, %r8d # movq %rsp, %rbp #, call swiotlb_sync_sg # leave ret Cc: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-05[IA64] swiotlb abstraction (e.g. for Xen)Jan Beulich
Add abstraction so that the file can be used by environments other than IA64 and EM64T, namely for Xen. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-05[IA64] swiotlb cleanupJan Beulich
- add proper __init decoration to swiotlb's init code (and the code calling it, where not already the case) - replace uses of 'unsigned long' with dma_addr_t where appropriate - do miscellaneous simplicfication and cleanup Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-05[IA64] make swiotlb use bus_to_virt/virt_to_busJan Beulich
Convert all phys_to_virt/virt_to_phys uses to bus_to_virt/virt_to_bus, as is what is meant and what is needed in (at least) some virtualized environments like Xen. Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-05[IA64] swiotlb bug fixesJan Beulich
This patch fixes - marking I-cache clean of pages DMAed to now only done for IA64 - broken multiple inclusion in include/asm-x86_64/swiotlb.h - missing call to mark_clean in swiotlb_sync_sg() - a (perhaps only theoretical) issue in swiotlb_dma_supported() when io_tlb_end is exactly at the end of memory Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-24BUG_ON() Conversion in lib/swiotlb.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-11[PATCH] x86_64: Use function pointers to call DMA mapping functionsMuli Ben-Yehuda
AK: I hacked Muli's original patch a lot and there were a lot of changes - all bugs are probably to blame on me now. There were also some changes in the fall back behaviour for swiotlb - in particular it doesn't try to use GFP_DMA now anymore. Also all DMA mapping operations use the same core dma_alloc_coherent code with proper fallbacks now. And various other changes and cleanups. Known problems: iommu=force swiotlb=force together breaks needs more testing. This patch cleans up x86_64's DMA mapping dispatching code. Right now we have three possible IOMMU types: AGP GART, swiotlb and nommu, and in the future we will also have Xen's x86_64 swiotlb and other HW IOMMUs for x86_64. In order to support all of them cleanly, this patch: - introduces a struct dma_mapping_ops with function pointers for each of the DMA mapping operations of gart (AMD HW IOMMU), swiotlb (software IOMMU) and nommu (no IOMMU). - gets rid of: if (swiotlb) return swiotlb_xxx(); - PCI_DMA_BUS_IS_PHYS is now checked against the dma_ops being set This makes swiotlb faster by avoiding double copying in some cases. Signed-Off-By: Muli Ben-Yehuda <mulix@mulix.org> Signed-Off-By: Jon D. Mason <jdmason@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] Cleanup bootmem allocator and fix alloc_bootmem_lowRavikiran G Thirumalai
Patch cleans up the alloc_bootmem fix for swiotlb. Patch removes alloc_bootmem_*_limit api and fixes alloc_boot_*low api to do the right thing -- allocate from low32 memory. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-20[PATCH] Fix swiotlb pci_map_sg error handlingAndi Kleen
The overflow checking condition in lib/swiotlb.c was wrong. It would first run a NULL pointer through virt_to_phys before testing it. Since pci_map_sg overflow is not that uncommon and causes data corruption (including broken file systems) when not properly detected I think it's better to fix it in 2.6.15. This affects x86-64 and IA64. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-31manual update from upstream:Tony Luck
Applied Al's change 06a544971fad0992fe8b92c5647538d573089dd4 to new location of swiotlb.c Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-10-20Update from upstream with manual merge of Yasunori Goto'sTony Luck
changes to swiotlb.c made in commit 281dd25cdc0d6903929b79183816d151ea626341 since this file has been moved from arch/ia64/lib/swiotlb.c to lib/swiotlb.c Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-29[PATCH] Removed remaining PCI specific references from swiotlb.cTony Luck
Matthew Wilcox pointed out that swiotlb.c implements a generic interface that is not tied to just PCI. Remove includes of <linux/pci.h>, <asm/pci.h>. Fix comments and printk() messages to no longer refer to PCI. Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-29[PATCH] swiotlb: file header commentsJohn W. Linville
Change comment at top of swiotlb.c to reflect that the code is shared with EM64T (i.e. Intel x86_64). Also add an entry for myself so that if I "broke it", everyone knows who "bought it"... :-) Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-29[PATCH] swiotlb: support syncing DMA_BIDIRECTIONAL mappingsJohn W. Linville
The current implementation of sync_single in swiotlb.c chokes on DMA_BIDIRECTIONAL mappings. This patch adds the capability to sync those mappings, and optimizes other syncs by accounting for the sync target (i.e. cpu or device) in addition to the DMA direction of the mapping. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-29[PATCH] swiotlb: support syncing sub-ranges of mappingsJohn W. Linville
This patch implements swiotlb_sync_single_range_for_{cpu,device}. This is intended to support an x86_64 implementation of dma_sync_single_range_for_{cpu,device}. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-29[PATCH] swiotlb: cleanup some code duplication cruftJohn W. Linville
The implementations of swiotlb_sync_single_for_{cpu,device} are identical. Likewise for swiotlb_syng_sg_for_{cpu,device}. This patch move the guts of those functions to two new inline functions, and calls the appropriate one from the bodies of those functions. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-29[PATCH] swiotlb: move from arch/ia64/lib/ to lib/John W. Linville
The swiotlb implementation is shared by both IA-64 and EM64T. However, the source itself lives under arch/ia64. This patch moves swiotlb.c from arch/ia64/lib to lib/ and fixes-up the appropriate Makefile and Kconfig files. No actual changes are made to swiotlb.c. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
