path: root/lib/inflate.c
2008-04-29lib/inflate.c: handle failed malloc()Jim Meyering
lib/inflate.c (inflate_dynamic): Don't deref NULL upon failed malloc. Signed-off-by: Jim Meyering <meyering@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] x86-64: deflate inflate_dynamic tooJeremy Fitzhardinge
inflate_dynamic() has piggy stack usage too, so heap allocate it too. I'm not sure it actually gets used, but it shows up large in "make checkstack". Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de>
2007-05-02[PATCH] x86: deflate stack usage in lib/inflate.cJeremy Fitzhardinge
inflate_fixed and huft_build together use around 2.7k of stack. When using 4k stacks, I saw stack overflows from interrupts arriving while unpacking the root initrd: do_IRQ: stack overflow: 384 [<c0106b64>] show_trace_log_lvl+0x1a/0x30 [<c01075e6>] show_trace+0x12/0x14 [<c010763f>] dump_stack+0x16/0x18 [<c0107ca4>] do_IRQ+0x6d/0xd9 [<c010202b>] xen_evtchn_do_upcall+0x6e/0xa2 [<c0106781>] xen_hypervisor_callback+0x25/0x2c [<c010116c>] xen_restore_fl+0x27/0x29 [<c0330f63>] _spin_unlock_irqrestore+0x4a/0x50 [<c0117aab>] change_page_attr+0x577/0x584 [<c0117b45>] kernel_map_pages+0x8d/0xb4 [<c016a314>] cache_alloc_refill+0x53f/0x632 [<c016a6c2>] __kmalloc+0xc1/0x10d [<c0463d34>] malloc+0x10/0x12 [<c04641c1>] huft_build+0x2a7/0x5fa [<c04645a5>] inflate_fixed+0x91/0x136 [<c04657e2>] unpack_to_rootfs+0x5f2/0x8c1 [<c0465acf>] populate_rootfs+0x1e/0xe4 (This was under Xen, but there's no reason it couldn't happen on bare hardware.) This patch mallocs the local variables, thereby reducing the stack usage to sane levels. Also, up the heap size for the kernel decompressor to deal with the extra allocation. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Tim Yamin <plasmaroo@gentoo.org> Cc: Andi Kleen <ak@suse.de> Cc: Matt Mackall <mpm@selenic.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com>
2005-08-05[PATCH] Update in-kernel zlib routinesTim Yamin
These bugs have been fixed in the standard zlib for a while. See for example a) http://sources.redhat.com/ml/bug-gnu-utils/1999-06/msg00183.html b) http://bugs.gentoo.org/show_bug.cgi?id=94584 Signed-off-by: Tim Yamin <plasmaroo@gentoo.org> Signed-off-by: Tavis Ormandy <taviso@gentoo.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
