instead of 0
line-range is supposed to treat "1-" as "1-endoffile", so
handle the special case by setting last_lineno to UINT_MAX.
Fixes this error:
dynamic_debug:ddebug_parse_query: last-line:0 < 1st-line:1
dynamic_debug:ddebug_exec_query: query parse failed
Link: http://lkml.kernel.org/r/10a6a101-e2be-209f-1f41-54637824788e@infradead.org
Acked-by: Jason Baron <jbaron@akamai.com>
Although dynamic debug is often only used for debug builds, sometimes
its enabled for production builds as well. Minimize its impact by using
jump labels. This reduces the text section by 7000+ bytes in the kernel
image below. It does increase data, but this should only be referenced
when changing the direction of the branches, and hence usually not in
cache.
8194852 4879776 925696 14000324 d5a0c4 vmlinux.pre
8187337 4960224 925696 14073257 d6bda9 vmlinux.post
Link: http://lkml.kernel.org/r/d165b465e8c89bc582d973758d40be44c33f018b.1467837322.git.jbaron@akamai.com
Signed-off-by: Jason Baron <jbaron@akamai.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Joe Perches <joe@perches.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
A _lot_ of ->write() instances were open-coding it; some are
converted to memdup_user_nul(), a lot more remain...
Using kstrdup_const, thus reusing .rodata when possible, saves around 2 kB
of runtime memory on my laptop/.config combination.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Jason Baron <jbaron@akamai.com>
This adds an extra argument onto parse_params() to be used
as a way to make the unused callback a bit more useful and
generic by allowing the caller to pass on a data structure
of its choice. An example use case is to allow us to easily
make module parameters for every module which we will do
next.
@ parse @
identifier name, args, params, num, level_min, level_max;
identifier unknown, param, val, doing;
type s16;
extern char *parse_args(const char *name,
char *args,
const struct kernel_param *params,
unsigned num,
s16 level_min,
s16 level_max,
+ void *arg,
int (*unknown)(char *param, char *val,
const char *doing
+ , void *arg
@ parse_mod @
type s16;
char *args,
unsigned num,
s16 level_min,
s16 level_max,
+ void *arg,
const char *doing
+ , void *arg
@ parse_args_found @
expression R, E1, E2, E3, E4, E5, E6;
identifier func;
R =
parse_args(E1, E2, E3, E4, E5, E6,
+ NULL,
func);
R =
+ NULL,
&func);
R =
+ NULL,
NULL);
+ NULL,
func);
+ NULL,
&func);
+ NULL,
NULL);
@ parse_args_unused depends on parse_args_found @
identifier parse_args_found.func;
int func(char *param, char *val, const char *unused
+ , void *arg
@ mod_unused depends on parse_args_found @
expression A1, A2, A3;
- func(A1, A2, A3);
+ func(A1, A2, A3, NULL);
Generated-by: Coccinelle SmPL
Cc: cocci@systeme.lip6.fr
Cc: Tejun Heo <tj@kernel.org>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Felipe Contreras <felipe.contreras@gmail.com>
Cc: Ewan Milne <emilne@redhat.com>
Cc: Jean Delvare <jdelvare@suse.de>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Jani Nikula <jani.nikula@intel.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
Pull trivial tree changes from Jiri Kosina:
"Patches from trivial.git that keep the world turning around.
Mostly documentation and comment fixes, and a two corner-case code
fixes from Alan Cox"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
kexec, Kconfig: spell "architecture" properly
mm: fix cleancache debugfs directory path
blackfin: mach-common: ints-priority: remove unused function
doubletalk: probe failure causes OOPS
ARM: cache-l2x0.c: Make it clear that cache-l2x0 handles L310 cache controller
msdos_fs.h: fix 'fields' in comment
scsi: aic7xxx: fix comment
ARM: l2c: fix comment
ibmraid: fix writeable attribute with no store method
dynamic_debug: fix comment
doc: usbmon: fix spelling s/unpriviledged/unprivileged/
x86: init_mem_mapping(): use capital BIOS in comment
Signed-off-by: Masatake YAMATO <yamato@redhat.com>
Use #defines instead of magic values.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Using seq_open_private() removes boilerplate code from ddebug_proc_open().
The resultant code is shorter and easier to follow.
This patch does not change any functionality.
Signed-off-by: Rob Jones <rob.jones@codethink.co.uk>
The return value is not used by callers of these functions
so change the functions to return void.
This way we'll always know in what status the device is, unless it's
running normally (i.e. NETDEV_REGISTERED).
Also, emit a warning once in case of a bad reg_state.
CC: "David S. Miller" <davem@davemloft.net>
CC: Jason Baron <jbaron@akamai.com>
CC: Eric Dumazet <edumazet@google.com>
CC: Vlad Yasevich <vyasevic@redhat.com>
CC: stephen hemminger <stephen@networkplumber.org>
CC: Jerry Chu <hkchu@google.com>
CC: Ben Hutchings <bhutchings@solarflare.com>
CC: Joe Perches <joe@perches.com>
Signed-off-by: Veaceslav Falico <vfalico@gmail.com>
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
This fixes following scenario:
$ echo 'file dynamic_debug.c line 1-123 +p' > /sys/kernel/debug/dynamic_debug/control
-bash: echo: write error: Invalid argument
$ dmesg | grep dynamic_debug
dynamic_debug:ddebug_parse_query: last-line:123 < 1st-line:1
dynamic_debug:ddebug_parse_query: query parse failed
parse_lineno() returns either negative error code or zero. We don't
need to print something here because if parse_lineno fails it will print
error message.
Add wildcard '*'(matches zero or more characters) and '?' (matches one
character) support when qurying debug flags.
Now we can open debug messages using keywords. eg:
1. open debug logs in all usb drivers
echo "file drivers/usb/* +p" > <debugfs>/dynamic_debug/control
2. open debug logs for usb xhci code
echo "file *xhci* +p" > <debugfs>/dynamic_debug/control
Signed-off-by: Du, Changbin <changbin.du@gmail.com>
Settings of the form, 'line x module y +p', can fail arbitrarily due to an
uninitialized local variable. With this patch results are consistent, as
expected.
There is kernel function to do the job in generic way. Let's use it.
Cc: Jason Baron <jbaron@redhat.com>
There are at least two users of isodigit(). Let's make it a public
function of ctype.h.
Ma noted that dynamic-debug is silent about many query errors, so add
pr_err()s to explain those errors, and tweak a few others. Also parse
flags 1st, so that match-spec errs are slightly clearer.
CC: Jianpeng Ma <majianpeng@gmail.com>
Signed-off-by: Jim Cromie <jim.cromie@gmail.com>
Signed-off-by: Jason Baron <jbaron@redhat.com>
vpr_info_dq should be a function and vpr_info should have
a do {} while (0)
Add missing newlines to pr_<level>s.
Miscellaneous neatening too.
braces, coalescing formats, alignments, etc...
Remove the custom implementation of the functionality similar to kbasename().
Convert direct calls of vprintk_emit and printk_emit to the
dev_ equivalents.
Make create_syslog_header static.
Tested-by: Jim Cromie <jim.cromie@gmail.com>
Acked-by: Jason Baron <jbaron@redhat.com>
netdev_printk originally called dev_printk with %pV.
This style emitted the complete dev_printk header with
a colon followed by the netdev_name prefix followed
by a colon.
Now that netdev_printk does not call dev_printk, the
extra colon is superfluous. Remove it.
Example:
old: sky2 0000:02:00.0: eth0: Link is up at 100 Mbps, full duplex, flow control both
new: sky2 0000:02:00.0 eth0: Link is up at 100 Mbps, full duplex, flow control both
A lot of stack is used in recursive printks with %pV.
Using multiple levels of %pV (a logging function with %pV
that calls another logging function with %pV) can consume
more stack than necessary.
Avoid excessive stack use by not calling dev_printk from
netdev_printk and dynamic_netdev_dbg. Duplicate the logic
and form of dev_printk instead.
Make __netdev_printk static.
Remove EXPORT_SYMBOL(__netdev_printk)
Whitespace and brace style neatening.
commit c4e00daaa9
("driver-core: extend dev_printk() to pass structured data")
changed __dev_printk and broke dynamic-debug's ability to control the
dynamic prefix of dev_dbg(dev,..).
commit af7f2158fd
("drivers-core: make structured logging play nice with dynamic-debug")
made a minimal correction.
The current dynamic debug code uses up to 3 recursion levels via %pV.
This can consume quite a bit of stack. Directly call printk_emit to
reduce the recursion depth.
These changes include:
dev_dbg:
o Create and use function create_syslog_header to format the syslog
header for printk_emit uses.
o Call create_syslog_header and neaten __dev_printk
o Make __dev_printk static not global
o Remove include header declaration of __dev_printk
o Remove now unused EXPORT_SYMBOL() of __dev_printk
o Whitespace neatening
dynamic_dev_dbg:
o Remove KERN_DEBUG from dynamic_emit_prefix
o Call create_syslog_header and printk_emit
This reverts commit 04db6e5fddca55186b6a74339a62c800150648bc.
Odds are, we really don't want to revert all of these, and need to be
more careful in the future to make sure we don't break the build of
other arches.
Cc: Jim Cromie <jim.cromie@gmail.com>
These arent currently needed, so drop them. Some will probably get
re-added when static-branches are added, but include loops prevent
that at present.
1- Call dynamic_debug_init() from early_initcall, not arch_initcall.
2- Call dynamic_debug_init_debugfs() from fs_initcall, not module_init.
RFC: This works for me on a 64 bit desktop and a i586 SBC, but is
untested on other arches. I presume there is or was a reason
original code used arch_initcall, maybe the constraints have changed.
This makes facility available as soon as possible.
2nd change has a downside when dynamic_debug.verbose=1; all the
vpr_info()s called in the proc-fs code are activated, causing
voluminous output from dmesg. TBD: Im unsure of this explanation, but
the output is there. This could be fixed by changing those callsites
to v2pr_info(if verbose > 1).
1st change is still not early enough to enable pr_debugs in
kernel/params, so parsing of boot-args isnt logged. The reparse of
those args is however visible after params.dyndbg="+p" is processed.
Pass module name into ddebug_exec_queries(), ddebug_exec_query(), and
ddebug_parse_query() as separate parameter. In ddebug_parse_query(),
the module name is added into the query struct before the query-string
is parsed. This allows the query-string to be shorter:
instead of:
$modname.dyndbg="module $modname +fp"
do this:
$modname.dyndbg="+fp"
Omitting "module $modname" from the query string is actually required
for $modname.dyndbg rules; the set-only-once check added in a previous
patch will throw an error if its added again. ddebug_query="..." has
no $modname associated with it, so the query string may include it.
This also fixes redundant "module $modname" otherwise needed to handle
multiple queries per string:
$modname.dyndbg="func foo +fp; func bar +fp"
Print ram usage of dynamic-debug tables and verbose section so user
knows cost of enabling CONFIG_DYNAMIC_DEBUG. This only counts the
size of the _ddebug tables for builtins and the __verbose section that
they refer to, not those used in loadable modules.
We dont want errors while parsing ddebug_query to unload ddebug
tables, so set success after tables are loaded, and return 0 after
query parsing is done.
Simplify error handling code since its no longer used for success,
and change goto label to out_err to clarify this.
Refactor ddebug_dyndbg_boot_param_cb and ddebug_dyndbg_module_param_cb
into a common helper function, and call it from both. The handling of
foo.dyndbg is unneeded by the latter, but harmless.
The 2 callers differ only by pr_info and the return code they pass to
the helper for when an unknown param is handled. I could slightly
reduce dmesg clutter by putting the vpr_info in the common helper,
after the return on_err, but that loses __func__ context, is overly
silent on module_cb unknown param errors, and the clutter is only when
dynamic_debug.verbose=1 anyway.
With ddebug_dyndbg_boot_params_cb() handling bare dyndbg params, we
dont need ddebug_query param anymore. Add a warning when processing
ddebug_query= param that it is deprecated, and to change it to dyndbg=
Add a deprecation notice for v3.8 to feature-removal-schedule.txt, and
add a suggested deprecation period of 3 releases to the header.
This introduces a fake module param $module.dyndbg. Its based upon
Thomas Renninger's $module.ddebug boot-time debugging patch from
https://lkml.org/lkml/2010/9/15/397
The 'fake' module parameter is provided for all modules, whether or
not they need it. It is not explicitly added to each module, but is
implemented in callbacks invoked from parse_args.
For builtin modules, dynamic_debug_init() now directly calls
parse_args(..., &ddebug_dyndbg_boot_params_cb), to process the params
undeclared in the modules, just after the ddebug tables are processed.
While its slightly weird to reprocess the boot params, parse_args() is
already called repeatedly by do_initcall_levels(). More importantly,
the dyndbg queries (given in ddebug_query or dyndbg params) cannot be
activated until after the ddebug tables are ready, and reusing
parse_args is cleaner than doing an ad-hoc parse. This reparse would
break options like inc_verbosity, but they probably should be params,
like verbosity=3.
ddebug_dyndbg_boot_params_cb() handles both bare dyndbg (aka:
ddebug_query) and module-prefixed dyndbg params, and ignores all other
parameters. For example, the following will enable pr_debug()s in 4
builtin modules, in the order given:
dyndbg="module params +p; module aio +p" module.dyndbg=+p pci.dyndbg
For loadable modules, parse_args() in load_module() calls
ddebug_dyndbg_module_params_cb(). This handles bare dyndbg params as
passed from modprobe, and errors on other unknown params.
Note that modprobe reads /proc/cmdline, so "modprobe foo" grabs all
foo.params, strips the "foo.", and passes these to the kernel.
ddebug_dyndbg_module_params_cb() is again called for the unknown
params; it handles dyndbg, and errors on others. The "doing" arg
added previously contains the module name.
For non CONFIG_DYNAMIC_DEBUG builds, the stub function accepts
and ignores $module.dyndbg params, other unknowns get -ENOENT.
If no param value is given (as in pci.dyndbg example above), "+p" is
assumed, which enables all pr_debug callsites in the module.
The dyndbg fake parameter is not shown in /sys/module/*/parameters,
thus it does not use any resources. Changes to it are made via the
control file.
Also change pr_info in ddebug_exec_queries to vpr_info,
no need to see it all the time.
CC: Thomas Renninger <trenn@suse.de>
CC: Rusty Russell <rusty@rustcorp.com.au>
Use vpr_info to declutter code, reduce indenting, and change one
additional pr_info call in ddebug_exec_queries.
Insert ddebug_exec_queries() in place of ddebug_exec_query(). It
splits the query string on [;\n], and calls ddebug_exec_query() on
each. All queries are processed independent of errors, allowing a
query to fail, for example when a module is not installed. Empty
lines and comments are skipped. Errors are counted, and the last
error seen (negative) or the number of callsites found (0 or positive)
is returned. Return code checks are altered accordingly.
With this, multiple queries can be given in ddebug_query, allowing
more selective enabling of callsites. As a side effect, a set of
commands can be batched in:
cat cmd-file > $DBGMT/dynamic_debug/control
We dont want a ddebug_query syntax error to kill the dynamic debug
facility, so dynamic_debug_init() zeros ddebug_exec_queries()'s return
code after logging the appropriate message, so that ddebug tables are
preserved and $DBGMT/dynamic_debug/control file is created. This
would be appropriate even without accepting multiple queries.
This patch also alters ddebug_change() to return number of callsites
matched (which typically is the same as number of callsites changed).
ddebug_exec_query() also returns the number found, or a negative value
if theres a parse error on the query.
Splitting on [;\n] prevents their use in format-specs, but selecting
callsites on punctuation is brittle anyway, meaningful and selective
substrings are more typical.
Note: splitting queries on ';' before handling trailing #comments
means that a ';' also terminates a comment, and text after the ';' is
treated as another query. This trailing query will almost certainly
result in a parse error and thus have no effect other than the error
message. The double corner case with unexpected results is:
ddebug_query="func foo +p # enable foo ; +p"
Factor pr_info(query) out of ddebug_parse_query, into vpr_info_dq(),
for reuse later. Also change the printed labels: file, func to agree
with the query-spec keywords accepted in the control file. Pass ""
when string is null, to avoid "(null)" output from sprintf. For
format print, use precision to skip last char, assuming its '\n', no
great harm if not, its a debug msg.
trim_prefix(path) skips past the absolute source path root, and
returns the pointer to the relative path from there. It is used to
shorten the displayed path in $DBGMT/dynamic_debug/control via
ddebug_proc_show(), and in ddebug_change() to allow relative filenames
to be used in applied queries. For example:
~# echo file kernel/freezer.c +p > $DBGMT/dynamic_debug/control
kernel/freezer.c:128 [freezer]cancel_freezing p " clean up: %s\012"
trim_prefix(path) insures common prefix before trimming it, so
out-of-tree module paths are shown as full absolute paths.
Current query write buffer is 256 bytes, on stack. In comparison, the
ddebug_query boot-arg is 1024. Allocate the buffer off heap, and
enlarge it to 4096 bytes, big enough for ~100 queries (at 40 bytes
each), and error out if not. This makes it play nicely with large
query sets (to be added later). The buffer should be enough for most
uses, and others should probably be split into subsets.
[jbaron@redhat.com: changed USER_BUF_PAGE from 4095 -> 4096 ]
If a token begins with #, the remainder of query string is a comment,
so drop it. Doing it here avoids '#' in quoted strings.
If _ddebug table is empty (in a CONFIG_DYNAMIC_DEBUG build this
shouldn't happen), then warn (error?) and return early. This skips
empty table scan and parsing of setup-string, including the pr_info
call noting the parse. By inspection, copy return-code handling from
1st ddebug_add_module() callsite to 2nd.
Issue error when a match-spec is given multiple times in a rule.
Previous code kept last one, but was silent about it. Docs imply only
one is allowed by saying match-specs are ANDed together, given that
module M cannot match both A and B. Also error when last_line < 1st_line.
Change describe_flags() to emit '=[pmflt_]+' for current callsite
flags, or just '=_' when they're disabled. Having '=' in output
allows a more selective grep expression; in contrast '-' may appear
in filenames, line-ranges, and format-strings. '=' also has better
mnemonics, saying; "the current setting is equal to <flags>".
This allows grep "=_" <dbgfs>/dynamic_debug/control to see disabled
callsites while avoiding the many occurrences of " = " seen in format
strings.
Enlarge flagsbufs to handle additional flag char, and alter
ddebug_parse_flags() to allow flags=0, so that user can turn off all
debug flags via:
~# echo =_ > <dbgfs>/dynamic_debug/control
Convert 'if (x !=NULL)' checks into 'if (x)'.
Issue keyword/parsing errors even w/o verbose set;
uncover otherwize mysterious non-functionality.
Replace strcpy with strlcpy, and add define for the size constant.
[jbaron@redhat.com: Use DDEBUG_STRING_SIZE for overflow check]
Allow changing dynamic_debug verbosity at run-time, to ease debugging
of ddebug queries as you add them, improving usability.
at boot time: dynamic_debug.verbose=1
at runtime:
root@voyage:~# echo 1 > /sys/module/dynamic_debug/parameters/verbose
Currently any enabled dynamic-debug flag on a pr_debug callsite will
enable printing, even if _DPRINTK_FLAGS_PRINT is off. Checking print
flag directly allows "-p" to disable callsites without fussing with
other flags, so the following disables everything, without altering
flags user may have set:
echo -p > $DBGFS/dynamic_debug/control
Style cleanups.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (38 commits)
mm: memory hotplug: Check if pages are correctly reserved on a per-section basis
Revert "memory hotplug: Correct page reservation checking"
Update email address for stable patch submission
dynamic_debug: fix undefined reference to `__netdev_printk'
dynamic_debug: use a single printk() to emit messages
dynamic_debug: remove num_enabled accounting
dynamic_debug: consolidate repetitive struct _ddebug descriptor definitions
uio: Support physical addresses >32 bits on 32-bit systems
sysfs: add unsigned long cast to prevent compile warning
drivers: base: print rejected matches with DEBUG_DRIVER
memory hotplug: Refuse to add unaligned memory regions
remove the messy code file Documentation/zh_CN/SubmitChecklist
ARM: mxc: convert device creation to use platform_device_register_full
new helper to create platform devices with dma mask
docs/driver-model: Update device class docs
docs/driver-model: Document device.groups
kobj_uevent: Ignore if some listeners cannot handle message
dynamic_debug: make netif_dbg() call __netdev_printk()
dynamic_debug: make netdev_dbg() call __netdev_printk()
