path: root/lib/bitmap.c
2011-10-31lib/bitmap.c: quiet sparse noise about address spaceH Hartley Sweeten
__bitmap_parse() and __bitmap_parselist() both take a pointer to a kernel buffer as a parameter and then cast it to a pointer to user buffer for use in cases when the parameter is_user indicates that the buffer is actually located in user space. This casting, and the casts in the callers, results in sparse noise like the following: warning: incorrect type in initializer (different address spaces) expected char const [noderef] <asn:1>*ubuf got char const *buf warning: cast removes address space of expression Since these casts are intentional, use __force to quiet the noise. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Len Brown <len.brown@intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03Merge branch 'apei' into apei-releaseLen Brown
Some trivial conflicts due to other various merges adding to the end of common lists sooner than this one. arch/ia64/Kconfig arch/powerpc/Kconfig arch/x86/Kconfig lib/Kconfig lib/Makefile Signed-off-by: Len Brown <len.brown@intel.com>
2011-08-03lib, Make gen_pool memory allocator locklessHuang Ying
This version of the gen_pool memory allocator supports lockless operation. This makes it safe to use in NMI handlers and other special unblockable contexts that could otherwise deadlock on locks. This is implemented by using atomic operations and retries on any conflicts. The disadvantage is that there may be livelocks in extreme cases. For better scalability, one gen_pool allocator can be used for each CPU. The lockless operation only works if there is enough memory available. If new memory is added to the pool a lock has to be still taken. So any user relying on locklessness has to ensure that sufficient memory is preallocated. The basic atomic operation of this allocator is cmpxchg on long. On architectures that don't have NMI-safe cmpxchg implementation, the allocator can NOT be used in NMI handler. So code uses the allocator in NMI handler should depend on CONFIG_ARCH_HAVE_NMI_SAFE_CMPXCHG. Signed-off-by: Huang Ying <ying.huang@intel.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2011-07-26cpusets: randomize node rotor used in cpuset_mem_spread_node()Michal Hocko
[ This patch has already been accepted as commit 0ac0c0d0f837 but later reverted (commit 35926ff5fba8) because it itroduced arch specific __node_random which was defined only for x86 code so it broke other archs. This is a followup without any arch specific code. Other than that there are no functional changes.] Some workloads that create a large number of small files tend to assign too many pages to node 0 (multi-node systems). Part of the reason is that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts at node 0 for newly created tasks. This patch changes the rotor to be initialized to a random node number of the cpuset. [akpm@linux-foundation.org: fix layout] [Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration] [mhocko@suse.cz: Make it arch independent] [akpm@linux-foundation.org: fix CONFIG_NUMA=y, MAX_NUMNODES>1 build] Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Paul Menage <menage@google.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15lib/bitmap.c: fix kernel-doc notationRandy Dunlap
Fix new kernel-doc warnings in lib/bitmap.c: Warning(lib/bitmap.c:596): No description found for parameter 'buf' Warning(lib/bitmap.c:596): Excess function parameter 'bp' description in '__bitmap_parselist' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25bitmap, irq: add smp_affinity_list interface to /proc/irqMike Travis
Manually adjusting the smp_affinity for IRQ's becomes unwieldy when the cpu count is large. Setting smp affinity to cpus 256 to 263 would be: echo 000000ff,00000000,00000000,00000000,00000000,00000000,00000000,00000000 > smp_affinity instead of: echo 256-263 > smp_affinity_list Think about what it looks like for cpus around say, 4088 to 4095. We already have many alternate "list" interfaces: /sys/devices/system/cpu/cpuX/indexY/shared_cpu_list /sys/devices/system/cpu/cpuX/topology/thread_siblings_list /sys/devices/system/cpu/cpuX/topology/core_siblings_list /sys/devices/system/node/nodeX/cpulist /sys/devices/pci***/***/local_cpulist Add a companion interface, smp_affinity_list to use cpu lists instead of cpu maps. This conforms to other companion interfaces where both a map and a list interface exists. This required adding a bitmap_parselist_user() function in a manner similar to the bitmap_parse_user() function. [akpm@linux-foundation.org: make __bitmap_parselist() static] Signed-off-by: Mike Travis <travis@sgi.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jack Steiner <steiner@sgi.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/bitmap.c: use hex_to_bin()Andy Shevchenko
Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-30Revert "cpusets: randomize node rotor used in cpuset_mem_spread_node()"Linus Torvalds
This reverts commit 0ac0c0d0f837c499afd02a802f9cf52d3027fa3b, which caused cross-architecture build problems for all the wrong reasons. IA64 already added its own version of __node_random(), but the fact is, there is nothing architectural about the function, and the original commit was just badly done. Revert it, since no fix is forthcoming. Requested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cpusets: randomize node rotor used in cpuset_mem_spread_node()Jack Steiner
Some workloads that create a large number of small files tend to assign too many pages to node 0 (multi-node systems). Part of the reason is that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts at node 0 for newly created tasks. This patch changes the rotor to be initialized to a random node number of the cpuset. [akpm@linux-foundation.org: fix layout] [Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration] Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06bitmap: use for_each_set_bit()Akinobu Mita
Replace open-coded loop with for_each_set_bit(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06lib: fix first line of kernel-doc for a few functionsBen Hutchings
The function name must be followed by a space, hypen, space, and a short description. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16bitmap: introduce bitmap_set, bitmap_clear, bitmap_find_next_zero_areaAkinobu Mita
This introduces new bitmap functions: bitmap_set: Set specified bit area bitmap_clear: Clear specified bit area bitmap_find_next_zero_area: Find free bit area These are mostly stolen from iommu helper. The differences are: - Use find_next_bit instead of doing test_bit for each bit - Rewrite bitmap_set and bitmap_clear Instead of setting or clearing for each bit. - Check the last bit of the limit iommu-helper doesn't want to find such area - The return value if there is no zero area find_next_zero_area in iommu helper: returns -1 bitmap_find_next_zero_area: return >= bitmap size Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Lothar Wassmann <LW@KARO-electronics.de> Cc: Roland Dreier <rolandd@cisco.com> Cc: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-21Make bitmask 'and' operators return a result codeLinus Torvalds
When 'and'ing two bitmasks (where 'andnot' is a variation on it), some cases want to know whether the result is the empty set or not. In particular, the TLB IPI sending code wants to do cpumask operations and determine if there are any CPU's left in the final set. So this just makes the bitmask (and cpumask) functions return a boolean for whether the result has any bits set. Cc: stable@kernel.org (2.6.30, needed by TLB shootdown fix) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12bitmap: fix end condition in bitmap_find_free_regionLinus Torvalds
Guennadi Liakhovetski noticed that the end condition for the loop in bitmap_find_free_region() is wrong, and the "return if error" was also using the wrong conditional that would only trigger if the bitmap was an exact multiple of the allocation size, which is not necessarily the case with dma_alloc_from_coherent(). Such a failure would end up in bitmap_find_free_region() accessing beyond the end of the bitmap. Reported-by: Guennadi Liakhovetski <lg@denx.de> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: (47 commits) uwb: wrong sizeof argument in mac address compare uwb: don't use printk_ratelimit() so often uwb: use kcalloc where appropriate uwb: use time_after() when purging stale beacons uwb: add credits for the original developers of the UWB/WUSB/WLP subsystems uwb: add entries in the MAINTAINERS file uwb: depend on EXPERIMENTAL wusb: wusb-cbaf (CBA driver) sysfs ABI simplification uwb: document UWB and WUSB sysfs files uwb: add symlinks in sysfs between radio controllers and PALs uwb: dont tranmit identification IEs uwb: i1480/GUWA100U: fix firmware download issues uwb: i1480: remove MAC/PHY information checking function uwb: add Intel i1480 HWA to the UWB RC quirk table uwb: disable command/event filtering for D-Link DUB-1210 uwb: initialize the debug sub-system uwb: Fix handling IEs with empty IE data in uwb_est_get_size() wusb: fix bmRequestType for Abort RPipe request wusb: fix error path for wusb_set_dev_addr() wusb: add HWA host controller driver ...
2008-10-20bitmask: remove bitmap_scnprintf_len()Lai Jiangshan
bitmap_scnprintf_len() is not used now, so we remove it. Otherwise we have to maintain it and make its return value always equal to bitmap_scnprintf()'s return value. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-17bitmap: add bitmap_copy_le()David Vrabel
bitmap_copy_le() copies a bitmap, putting the bits into little-endian order (i.e., each unsigned long word in the bitmap is put into little-endian order). The UWB stack used bitmaps to manage Medium Access Slot availability, and these bitmaps need to be written to the hardware in LE order. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-08-12seq_file: add seq_cpumask(), seq_nodemask()Alexey Dobriyan
Short enough reads from /proc/irq/*/smp_affinity return -EINVAL for no good reason. This became noticed with NR_CPUS=4096 patches, when length of printed representation of cpumask becase 1152, but cat(1) continued to read with 1024-byte chunks. bitmap_scnprintf() in good faith fills buffer, returns 1023, check returns -EINVAL. Fix it by switching to seq_file, so handler will just fill buffer and doesn't care about offsets, length, filling EOF and all this crap. For that add seq_bitmap(), and wrappers around it -- seq_cpumask() and seq_nodemask(). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Reviewed-by: Paul Jackson <pj@sgi.com> Cc: Mike Travis <travis@sgi.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13cpumask: remove bitmap_scnprintf_len and cpumask_scnprintf_lenPaul Jackson
They aren't used. They were briefly used as part of some other patches to provide an alternative format for displaying some /proc and /sys cpumasks. They probably should have been removed when those other patches were dropped, in favor of a different solution. Signed-off-by: Paul Jackson <pj@sgi.com> Cc: "Mike Travis" <travis@sgi.com> Cc: "Bert Wesarg" <bert.wesarg@googlemail.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: add bitmap_onto() and bitmap_fold() operationsPaul Jackson
The following adds two more bitmap operators, bitmap_onto() and bitmap_fold(), with the usual cpumask and nodemask wrappers. The bitmap_onto() operator computes one bitmap relative to another. If the n-th bit in the origin mask is set, then the m-th bit of the destination mask will be set, where m is the position of the n-th set bit in the relative mask. The bitmap_fold() operator folds a bitmap into a second that has bit m set iff the input bitmap has some bit n set, where m == n mod sz, for the specified sz value. There are two substantive changes between this patch and its predecessor bitmap_relative: 1) Renamed bitmap_relative() to be bitmap_onto(). 2) Added bitmap_fold(). The essential motivation for bitmap_onto() is to provide a mechanism for converting a cpuset-relative CPU or Node mask to an absolute mask. Cpuset relative masks are written as if the current task were in a cpuset whose CPUs or Nodes were just the consecutive ones numbered 0..N-1, for some N. The bitmap_onto() operator is provided in anticipation of adding support for the first such cpuset relative mask, by the mbind() and set_mempolicy() system calls, using a planned flag of MPOL_F_RELATIVE_NODES. These bitmap operators (and their nodemask wrappers, in particular) will be used in code that converts the user specified cpuset relative memory policy to a specific system node numbered policy, given the current mems_allowed of the tasks cpuset. Such cpuset relative mempolicies will address two deficiencies of the existing interface between cpusets and mempolicies: 1) A task cannot at present reliably establish a cpuset relative mempolicy because there is an essential race condition, in that the tasks cpuset may be changed in between the time the task can query its cpuset placement, and the time the task can issue the applicable mbind or set_memplicy system call. 2) A task cannot at present establish what cpuset relative mempolicy it would like to have, if it is in a smaller cpuset than it might have mempolicy preferences for, because the existing interface only allows specifying mempolicies for nodes currently allowed by the cpuset. Cpuset relative mempolicies are useful for tasks that don't distinguish particularly between one CPU or Node and another, but only between how many of each are allowed, and the proper placement of threads and memory pages on the various CPUs and Nodes available. The motivation for the added bitmap_fold() can be seen in the following example. Let's say an application has specified some mempolicies that presume 16 memory nodes, including say a mempolicy that specified MPOL_F_RELATIVE_NODES (cpuset relative) nodes 12-15. Then lets say that application is crammed into a cpuset that only has 8 memory nodes, 0-7. If one just uses bitmap_onto(), this mempolicy, mapped to that cpuset, would ignore the requested relative nodes above 7, leaving it empty of nodes. That's not good; better to fold the higher nodes down, so that some nodes are included in the resulting mapped mempolicy. In this case, the mempolicy nodes 12-15 are taken modulo 8 (the weight of the mems_allowed of the confining cpuset), resulting in a mempolicy specifying nodes 4-7. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: <kosaki.motohiro@jp.fujitsu.com> Cc: <ray-lk@madrabbit.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19cpumask: add cpumask_scnprintf_len functionMike Travis
Add a new function cpumask_scnprintf_len() to return the number of characters needed to display "len" cpumask bits. The current method of allocating NR_CPUS bytes is incorrect as what's really needed is 9 characters per 32-bit word of cpumask bits (8 hex digits plus the seperator [','] or the terminating NULL.) This function provides the caller the means to allocate the correct string length. Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-11-05Fix bitmap_scnlistprintf for empty masksAndi Kleen
When a bitmap is empty bitmap_scnlistprintf() would leave the buffer uninitialized. Set it to an empty string in this case. I didn't see any in normal kernel callers hitting this, but some custom debug code of mine did. Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] kernel-doc fixes for 2.6.20-git15 (non-drivers)Randy Dunlap
Fix kernel-doc warnings in 2.6.20-git15 (lib/, mm/, kernel/, include/). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-11[PATCH] bitmap: parse input from kernel and user buffersReinette Chatre
lib/bitmap.c:bitmap_parse() is a library function that received as input a user buffer. This seemed to have originated from the way the write_proc function of the /proc filesystem operates. This has been reworked to not use kmalloc and eliminates a lot of get_user() overhead by performing one access_ok before using __get_user(). We need to test if we are in kernel or user space (is_user) and access the buffer differently. We cannot use __get_user() to access kernel addresses in all cases, for example in architectures with separate address space for kernel and user. This function will be useful for other uses as well; for example, taking input for /sysfs instead of /proc, so it was changed to accept kernel buffers. We have this use for the Linux UWB project, as part as the upcoming bandwidth allocator code. Only a few routines used this function and they were changed too. Signed-off-by: Reinette Chatre <reinette.chatre@linux.intel.com> Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Cc: Paul Jackson <pj@sgi.com> Cc: Joe Korty <joe.korty@ccur.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] kernel-doc for lib/bitmap.cRandy Dunlap
Make corrections/fixes to kernel-doc in lib/bitmap.c and include it in DocBook template. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: hweight() related cleanupAkinobu Mita
By defining generic hweight*() routines - hweight64() will be defined on all architectures - hweight_long() will use architecture optimized hweight32() or hweight64() I found two possible cleanups by these reasons. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] bitmap: region restructuringPaul Jackson
Restructure the bitmap_*_region() operations, to avoid code duplication. Also reduces binary text size by about 100 bytes (ia64 arch). The original Bottomley bitmap_*_region patch added about 1000 bytes of compiled kernel text (ia64). The Mundt multiword extension added another 600 bytes, and this restructuring patch gets back about 100 bytes. But the real motivation was the reduced amount of duplicated code. Tested by Paul Mundt using <= BITS_PER_LONG as well as power of 2 aligned multiword spanning allocations. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] bitmap: region multiword spanning supportPaul Mundt
Add support to the lib/bitmap.c bitmap_*_region() routines For bitmap regions larger than one word (nbits > BITS_PER_LONG). This removes a BUG_ON() in lib bitmap. I have an updated store queue API for SH that is currently using this with relative success, and at first glance, it seems like this could be useful for x86 (arch/i386/kernel/pci-dma.c) as well. Particularly for anything using dma_declare_coherent_memory() on large areas and that attempts to allocate large buffers from that space. Paul Jackson also did some cleanup to this patch. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] bitmap: region cleanupPaul Jackson
Paul Mundt <lethal@linux-sh.org> says: This patch set implements a number of patches to clean up and restructure the bitmap region code, in addition to extending the interface to support multiword spanning allocations. The current implementation (before this patch set) is limited by only being able to allocate pages <= BITS_PER_LONG, as noted by the strategically positioned BUG_ON() at lib/bitmap.c:752: /* We don't do regions of pages > BITS_PER_LONG. The * algorithm would be a simple look for multiple zeros in the * array, but there's no driver today that needs this. If you * trip this BUG(), you get to code it... */ BUG_ON(pages > BITS_PER_LONG); As I seem to have been the first person to trigger this, the result ends up being the following patch set with the help of Paul Jackson. The final patch in the series eliminates quite a bit of code duplication, so the bitmap code size ends up being smaller than the current implementation as an added bonus. After these are applied, it should already be possible to do multiword allocations with dma_alloc_coherent() out of ranges established by dma_declare_coherent_memory() on x86 without having to change any of the code, and the SH store queue API will follow up on this as the other user that needs support for this. This patch: Some code cleanup on the lib/bitmap.c bitmap_*_region() routines: * spacing * variable names * comments Has no change to code function. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cpuset: better bitmap remap defaultsPaul Jackson
Fix the default behaviour for the remap operators in bitmap, cpumask and nodemask. As previously submitted, the pair of masks <A, B> defined a map of the positions of the set bits in A to the corresponding bits in B. This is still true. The issue is how to map the other positions, corresponding to the unset (0) bits in A. As previously submitted, they were all mapped to the first set bit position in B, a constant map. When I tried to code per-vma mempolicy rebinding using these remap operators, I realized this was wrong. This patch changes the default to map all the unset bit positions in A to the same positions in B, the identity map. For example, if A has bits 4-7 set, and B has bits 9-12 set, then the map defined by the pair <A, B> maps each bit position in the first 32 bits as follows: 0 ==> 0 ... 3 ==> 3 4 ==> 9 ... 7 ==> 12 8 ==> 8 9 ==> 9 ... 31 ==> 31 This now corresponds to the typical behaviour desired when migrating pages and policies from one cpuset to another. The pages on nodes within the original cpuset, and the references in memory policies to nodes within the original cpuset, are migrated to the corresponding cpuset-relative nodes in the destination cpuset. Other pages and node references are left untouched. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] cpusets: bitmap and mask remap operatorsPaul Jackson
In the forthcoming task migration support, a key calculation will be mapping cpu and node numbers from the old set to the new set while preserving cpuset-relative offset. For example, if a task and its pages on nodes 8-11 are being migrated to nodes 24-27, then pages on node 9 (the 2nd node in the old set) should be moved to node 25 (the 2nd node in the new set.) As with other bitmap operations, the proper way to code this is to provide the underlying calculation in lib/bitmap.c, and then to provide the usual cpumask and nodemask wrappers. This patch provides that. These operations are termed 'remap' operations. Both remapping a single bit and a set of bits is supported. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Use ALIGN to remove duplicate codeNick Wilson
This patch makes use of ALIGN() to remove duplicate round-up code. Signed-off-by: Nick Wilson <njw@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
