path: root/lib/Kconfig.debug
2014-01-27Merge tag 'firewire-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull firewire updates from Stefan Richter: "IEEE 1394 (FireWire) subsystem changes: - make remote debugging over 1394 a runtime option instead of a buildtime option - extend remote debug access past the 4 GB barrier on respectively capable hardware - documentation update" * tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: Enable remote DMA above 4 GB firewire: ohci: Turn remote DMA support into a module parameter Documentation/: update FireWire debugging documentation
2014-01-23test: check copy_to/from_user boundary validationKees Cook
To help avoid an architecture failing to correctly check kernel/user boundaries when handling copy_to_user, copy_from_user, put_user, or get_user, perform some simple tests and fail to load if any of them behave unexpectedly. Specifically, this is to make sure there is a way to notice if things like what was fixed in commit 8404663f81d2 ("ARM: 7527/1: uaccess: explicitly check __user pointer when !CPU_USE_DOMAINS") ever regresses again, for any architecture. Additionally, adds new "user" selftest target, which loads this module. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23test: add minimal module for verification testingKees Cook
This is a pair of test modules I'd like to see in the tree. Instead of putting these in lkdtm, where I've been adding various tests that trigger crashes, these don't make sense there since they need to be either distinctly separate, or their pass/fail state don't need to crash the machine. These live in lib/ for now, along with a few other in-kernel test modules, and use the slightly more common "test_" naming convention, instead of "test-". We should likely standardize on the former: $ find . -name 'test_*.c' | grep -v /tools/ | wc -l 4 $ find . -name 'test-*.c' | grep -v /tools/ | wc -l 2 The first is entirely a no-op module, designed to allow simple testing of the module loading and verification interface. It's useful to have a module that has no other uses or dependencies so it can be reliably used for just testing module loading and verification. The second is a module that exercises the user memory access functions, in an effort to make sure that we can quickly catch any regressions in boundary checking (e.g. like what was recently fixed on ARM). This patch (of 2): When doing module loading verification tests (for example, with module signing, or LSM hooks), it is very handy to have a module that can be built on all systems under test, isn't auto-loaded at boot, and has no device or similar dependencies. This creates the "test_module.ko" module for that purpose, which only reports its load and unload to printk. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21dma-debug: introduce debug_dma_assert_idle()Dan Williams
Record actively mapped pages and provide an api for asserting a given page is dma inactive before execution proceeds. Placing debug_dma_assert_idle() in cow_user_page() flagged the violation of the dma-api in the NET_DMA implementation (see commit 77873803363c "net_dma: mark broken"). The implementation includes the capability to count, in a limited way, repeat mappings of the same page that occur without an intervening unmap. This 'overlap' counter is limited to the few bits of tag space in a radix tree. This mechanism is added to mitigate false negative cases where, for example, a page is dma mapped twice and debug_dma_assert_idle() is called after the page is un-mapped once. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-12firewire: ohci: Turn remote DMA support into a module parameterLubomir Rintel
This makes it possible to debug kernel over FireWire without the need to recompile it. [Stefan R: changed description from "...0" to "...N"] Cc: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Lubomir Rintel <lkundrak@v3.sk> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-11-26panic: Make panic_timeout configurableJason Baron
The panic_timeout value can be set via the command line option 'panic=x', or via /proc/sys/kernel/panic, however that is not sufficient when the panic occurs before we are able to set up these values. Thus, add a CONFIG_PANIC_TIMEOUT so that we can set the desired value from the .config. The default panic_timeout value continues to be 0 - wait forever. Also adds set_arch_panic_timeout(new_timeout, arch_default_timeout), which is intended to be used by arches in arch_setup(). The idea being that the new_timeout is only set if the user hasn't changed from the arch_default_timeout. Signed-off-by: Jason Baron <jbaron@akamai.com> Cc: benh@kernel.crashing.org Cc: paulus@samba.org Cc: ralf@linux-mips.org Cc: mpe@ellerman.id.au Cc: felipe.contreras@gmail.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1a1674daec27c534df409697025ac568ebcee91e.1385418410.git.jbaron@akamai.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-13percpu: add test module for various percpu operationsGreg Thelen
Tests various percpu operations. Enable with CONFIG_PERCPU_TEST=m. Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-07Merge tag 'tty-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver updates from Greg KH: "Here's the big tty/serial driver update for 3.13-rc1. There's some more minor n_tty work here, but nothing like previous kernel releases. Also some new driver ids, driver updates for new hardware, and other small things. All of this has been in linux-next for a while with no issues" * tag 'tty-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (84 commits) serial: omap: fix missing comma serial: sh-sci: Enable the driver on all ARM platforms serial: mfd: Staticize local symbols serial: omap: fix a few checkpatch warnings serial: omap: improve RS-485 performance mrst_max3110: fix unbalanced IRQ issue during resume serial: omap: Add support for optional wake-up serial: sirf: remove duplicate defines tty: xuartps: Fix build error when COMMON_CLK is not set tty: xuartps: Fix build error due to missing forward declaration tty: xuartps: Fix "may be used uninitialized" build warning serial: 8250_pci: add Pericom PCIe Serial board Support (12d8:7952/4/8) - Chip PI7C9X7952/4/8 tty: xuartps: Update copyright information tty: xuartps: Implement suspend/resume callbacks tty: xuartps: Dynamically adjust to input frequency changes tty: xuartps: Updating set_baud_rate() tty: xuartps: Force enable the UART in xuartps_console_write tty: xuartps: support 64 byte FIFO size tty: xuartps: Add polled mode support for xuartps tty: xuartps: Implement BREAK detection, add SYSRQ support ...
2013-10-29Kconfig: make KOBJECT_RELEASE debugging require timer debuggingLinus Torvalds
Without the timer debugging, the delayed kobject release will just result in undebuggable oopses if it triggers any latent bugs. That doesn't actually help debugging at all. So make DEBUG_KOBJECT_RELEASE depend on DEBUG_OBJECTS_TIMERS to avoid having people enable one without the other. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16sysrq: Allow magic SysRq key functions to be disabled through KconfigBen Hutchings
Turn the initial value of sysctl kernel.sysrq (SYSRQ_DEFAULT_ENABLE) into a Kconfig variable. Original version by Bastian Blank <waldi@debian.org>. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-09-11rbtree: allow tests to run as builtinCody P Schafer
No reason require rbtree test code to be a module, allow it to be builtin (streamlines my development process) Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com> Reviewed-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: David Woodhouse <David.Woodhouse@intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Michel Lespinasse <walken@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-09Merge tag 'arc-v3.12-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC changes from Vineet Gupta: - ARC MM changes: - preparation for MMUv4 (accomodate new PTE bits, new cmds) - Rework the ASID allocation algorithm to remove asid-mm reverse map - Boilerplate code consolidation in Exception Handlers - Disable FRAME_POINTER for ARC - Unaligned Access Emulation for Big-Endian from Noam - Bunch of fixes (udelay, missing accessors) from Mischa * tag 'arc-v3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARC: fix new Section mismatches in build (post __cpuinit cleanup) Kconfig.debug: Add FRAME_POINTER anti-dependency for ARC ARC: Fix __udelay calculation ARC: remove console_verbose() from setup_arch() ARC: Add read*_relaxed to asm/io.h ARC: Handle un-aligned user space access in BE. ARC: [ASID] Track ASID allocation cycles/generations ARC: [ASID] activate_mm() == switch_mm() ARC: [ASID] get_new_mmu_context() to conditionally allocate new ASID ARC: [ASID] Refactor the TLB paranoid debug code ARC: [ASID] Remove legacy/unused debug code ARC: No need to flush the TLB in early boot ARC: MMUv4 preps/3 - Abstract out TLB Insert/Delete ARC: MMUv4 preps/2 - Reshuffle PTE bits ARC: MMUv4 preps/1 - Fold PTE K/U access flags ARC: Code cosmetics (Nothing semantical) ARC: Entry Handler tweaks: Optimize away redundant IRQ_DISABLE_SAVE ARC: Exception Handlers Code consolidation ARC: Add some .gitignore entries
2013-09-05Kconfig.debug: Add FRAME_POINTER anti-dependency for ARCVineet Gupta
Frame pointer on ARC doesn't serve the conventional purpose of stack unwinding due to the typical way ABI designates it's usage. Thus it's explicit usage on ARC is discouraged (gcc is free to use it, for some tricky stack frames even if -fomit-frame-pointer). Hence no point enabling it for ARC. References: http://www.spinics.net/lists/kernel/msg1593937.html Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: "Paul E. McKenney" <paul.mckenney@linaro.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Michel Lespinasse <walken@google.com> Cc: linux-kernel@vger.kernel.org
2013-07-25kobject: delayed kobject release: help find buggy driversRussell King
Implement debugging for kobject release functions. kobjects are reference counted, so the drop of the last reference to them is not predictable. However, the common case is for the last reference to be the kobject's removal from a subsystem, which results in the release function being immediately called. This can hide subtle bugs, which can occur when another thread holds a reference to the kobject at the same time that a kobject is removed. This results in the release method being delayed. In order to make these kinds of problems more visible, the following patch implements a delayed release; this has the effect that the release function will be out of order with respect to the removal of the kobject in the same manner that it would be if a reference was being held. This provides us with an easy way to allow driver writers to debug their drivers and fix otherwise hidden problems. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-14kernel: delete __cpuinit usage from all core kernel filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. This removes all the uses of the __cpuinit macros from C files in the core kernel directories (kernel, init, lib, mm, and include) that don't really have a specific maintainer. [1] https://lkml.org/lkml/2013/5/20/589 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-07-13Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "MIPS updates: - All the things that didn't make 3.10. - Removes the Windriver PPMC platform. Nobody will miss it. - Remove a workaround from kernel/irq/irqdomain.c which was there exclusivly for MIPS. Patch by Grant Likely. - More small improvments for the SEAD 3 platform - Improvments on the BMIPS / SMP support for the BCM63xx series. - Various cleanups of dead leftovers. - Platform support for the Cavium Octeon-based EdgeRouter Lite. Two large KVM patchsets didn't make it for this pull request because their respective authors are vacationing" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (124 commits) MIPS: Kconfig: Add missing MODULES dependency to VPE_LOADER MIPS: BCM63xx: CLK: Add dummy clk_{set,round}_rate() functions MIPS: SEAD3: Disable L2 cache on SEAD-3. MIPS: BCM63xx: Enable second core SMP on BCM6328 if available MIPS: BCM63xx: Add SMP support to prom.c MIPS: define write{b,w,l,q}_relaxed MIPS: Expose missing pci_io{map,unmap} declarations MIPS: Malta: Update GCMP detection. Revert "MIPS: make CAC_ADDR and UNCAC_ADDR account for PHYS_OFFSET" MIPS: APSP: Remove <asm/kspd.h> SSB: Kconfig: Amend SSB_EMBEDDED dependencies MIPS: microMIPS: Fix improper definition of ISA exception bit. MIPS: Don't try to decode microMIPS branch instructions where they cannot exist. MIPS: Declare emulate_load_store_microMIPS as a static function. MIPS: Fix typos and cleanup comment MIPS: Cleanup indentation and whitespace MIPS: BMIPS: support booting from physical CPU other than 0 MIPS: Only set cpu_has_mmips if SYS_SUPPORTS_MICROMIPS MIPS: GIC: Fix gic_set_affinity infinite loop MIPS: Don't save/restore OCTEON wide multiplier state on syscalls. ...
2013-07-04Merge branch 'kconfig-diet' from Dave HansenLinus Torvalds
Merge Kconfig menu diet patches from Dave Hansen: "I think the "Kernel Hacking" menu has gotten a bit out of hand. It is over 120 lines long on my system with everything enabled and options are scattered around it haphazardly. http://sr71.net/~dave/linux/kconfig-horror.png Let's try to introduce some sanity. This set takes that 120 lines down to 55 and makes it vastly easier to find some things. It's a start. This set stands on its own, but there is plenty of room for follow-up patches. The arch-specific debug options still end up getting stuck in the top-level "kernel hacking" menu. OPTIMIZE_INLINING, for instance, could obviously go in to the "compiler options" menu, but the fact that it is defined in arch/ in a separate Kconfig file keeps it on its own for the moment. The Signed-off-by's in here look funky. I changed employers while working on this set, so I have signoffs from both email addresses" * emailed patches from Dave Hansen <dave@sr71.net>: hang and lockup detection menu kconfig: consolidate printk options group locking debugging options consolidate compilation option configs consolidate runtime testing configs order memory debugging Kconfig options consolidate per-arch stack overflow debugging options
2013-07-04hang and lockup detection menuDave Hansen
The hard/softlockup and hung-task entries take up 6 lines of screen real-estate when enabled. I bet folks don't mess with these _that_ often, so move them in a group down a level. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-04kconfig: consolidate printk optionsDave Hansen
Same deal, take the printk-related things and hide them in a menu. This takes another 4 items out of the top-level menu. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-04group locking debugging optionsDave Hansen
Original posting: http://lkml.kernel.org/r/20121214184208.D9E5804D@kernel.stglabs.ibm.com There are quite a few of these, and we want to make sure that there is one-stop-shopping for lock debugging. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-04consolidate compilation option configsDave Hansen
Original Post: http://lkml.kernel.org/r/20121214184207.6E00DDEC@kernel.stglabs.ibm.com Again, trying to come up with some common themes of the stuff in the kernel hacking menu... There are quite a few options to tweak compilation in some way, or perform extra compile-time checks. Give them their own menu. The diff here looks a bit funny... makes it look like I'm moving debugfs even though I'm actually moving the options on either side of it. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-04consolidate runtime testing configsDave Hansen
Original posting: http://lkml.kernel.org/r/20121214184206.FC11422F@kernel.stglabs.ibm.com These runtime tests are great, except that there are a lot of them, and they are very rarely needed. Give them their own menu so that only the folks who need them will have to go looking for them. Note that there are some other runtime tests that are not in here, like for RCU or locking. This menu should only be used for tests that do not have a more appropriate home. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-04order memory debugging Kconfig optionsDave Hansen
Original posting: http://lkml.kernel.org/r/20121214184203.37E6C724@kernel.stglabs.ibm.com There are a *LOT* of memory debugging options. They are just scattered all over the "Kernel Hacking" menu. Sure, "memory debugging" is a very vague term and it's going to be hard to make absolute rules about what goes in here, but this has to be better than what we had before. This does, however, leave out the architecture-specific memory debugging options (like x86's DEBUG_SET_MODULE_RONX). There would need to be some substantial changes to move those in here. Kconfig can not easily mix arch-specific and generic options together: it really requires a file per-architecture, and I think having an arch/foo/Kconfig.debug-memory might be taking things a bit too far Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-04consolidate per-arch stack overflow debugging optionsDave Hansen
Original posting: http://lkml.kernel.org/r/20121214184202.F54094D9@kernel.stglabs.ibm.com Several architectures have similar stack debugging config options. They all pretty much do the same thing, some with slightly differing help text. This patch changes the architectures to instead enable a Kconfig boolean, and then use that boolean in the generic Kconfig.debug to present the actual menu option. This removes a bunch of duplication and adds consistency across arches. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [for tile] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-26mutex: Add w/w mutex slowpath debuggingDaniel Vetter
Injects EDEADLK conditions at pseudo-random interval, with exponential backoff up to UINT_MAX (to ensure that every lock operation still completes in a reasonable time). This way we can test the wound slowpath even for ww mutex users where contention is never expected, and the ww deadlock avoidance algorithm is only needed for correctness against malicious userspace. An example would be protecting kernel modesetting properties, which thanks to single-threaded X isn't really expected to contend, ever. I've looked into using the CONFIG_FAULT_INJECTION infrastructure, but decided against it for two reasons: - EDEADLK handling is mandatory for ww mutex users and should never affect the outcome of a syscall. This is in contrast to -ENOMEM injection. So fine configurability isn't required. - The fault injection framework only allows to set a simple probability for failure. Now the probability that a ww mutex acquire stage with N locks will never complete (due to too many injected EDEADLK backoffs) is zero. But the expected number of ww_mutex_lock operations for the completely uncontended case would be O(exp(N)). The per-acuiqire ctx exponential backoff solution choosen here only results in O(log N) overhead due to injection and so O(log N * N) lock operations. This way we can fail with high probability (and so have good test coverage even for fancy backoff and lock acquisition paths) without running into patalogical cases. Note that EDEADLK will only ever be injected when we managed to acquire the lock. This prevents any behaviour changes for users which rely on the EALREADY semantics. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: dri-devel@lists.freedesktop.org Cc: linaro-mm-sig@lists.linaro.org Cc: rostedt@goodmis.org Cc: daniel@ffwll.ch Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20130620113117.4001.21681.stgit@patser Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-21lib/Kconfig.debug: Restrict FRAME_POINTER for MIPSMarkos Chandras
FAULT_INJECTION_STACKTRACE_FILTER selects FRAME_POINTER but that symbol is not available for MIPS. Fixes the following problem on a randconfig: warning: (LOCKDEP && FAULT_INJECTION_STACKTRACE_FILTER && LATENCYTOP && KMEMCHECK) selects FRAME_POINTER which has unmet direct dependencies (DEBUG_KERNEL && (CRIS || M68K || FRV || UML || AVR32 || SUPERH || BLACKFIN || MN10300 || METAG) || ARCH_WANT_FRAME_POINTERS) Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Acked-by: Steven J. Hill <Steven.Hill@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5441/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-04-30notifier-error-inject: fix module names in KconfigAkinobu Mita
The Kconfig help text for MEMORY_NOTIFIER_ERROR_INJECT and OF_RECONFIG_NOTIFIER_ERROR_INJECT has mismatched module names. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKSStephen Boyd
The help text for this config is duplicated across the x86, parisc, and s390 Kconfig.debug files. Arnd Bergman noted that the help text was slightly misleading and should be fixed to state that enabling this option isn't a problem when using pre 4.4 gcc. To simplify the rewording, consolidate the text into lib/Kconfig.debug and modify it there to be more explicit about when you should say N to this config. Also, make the text a bit more generic by stating that this option enables compile time checks so we can cover architectures which emit warnings vs. ones which emit errors. The details of how an architecture decided to implement the checks isn't as important as the concept of compile time checking of copy_from_user() calls. While we're doing this, remove all the copy_from_user_overflow() code that's duplicated many times and place it into lib/ so that any architecture supporting this option can get the function for free. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Helge Deller <deller@gmx.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30lib/string_helpers: introduce generic string_unescapeAndy Shevchenko
There are several places in kernel where modules unescapes input to convert C-Style Escape Sequences into byte codes. The patch provides generic implementation of such approach. Test cases are also included into the patch. [akpm@linux-foundation.org: clarify comment] [akpm@linux-foundation.org: export get_random_int() to modules] Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jason Baron <jbaron@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: William Hubbs <w.d.hubbs@gmail.com> Cc: Chris Brannon <chris@the-brannons.com> Cc: Kirk Reiser <kirk@braille.uwo.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-03Merge tag 'metag-v3.9-rc1-v4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull new ImgTec Meta architecture from James Hogan: "This adds core architecture support for Imagination's Meta processor cores, followed by some later miscellaneous arch/metag cleanups and fixes which I kept separate to ease review: - Support for basic Meta 1 (ATP) and Meta 2 (HTP) core architecture - A few fixes all over, particularly for symbol prefixes - A few privilege protection fixes - Several cleanups (setup.c includes, split out a lot of metag_ksyms.c) - Fix some missing exports - Convert hugetlb to use vm_unmapped_area() - Copy device tree to non-init memory - Provide dma_get_sgtable()" * tag 'metag-v3.9-rc1-v4' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: (61 commits) metag: Provide dma_get_sgtable() metag: prom.h: remove declaration of metag_dt_memblock_reserve() metag: copy devicetree to non-init memory metag: cleanup metag_ksyms.c includes metag: move mm/init.c exports out of metag_ksyms.c metag: move usercopy.c exports out of metag_ksyms.c metag: move setup.c exports out of metag_ksyms.c metag: move kick.c exports out of metag_ksyms.c metag: move traps.c exports out of metag_ksyms.c metag: move irq enable out of irqflags.h on SMP genksyms: fix metag symbol prefix on crc symbols metag: hugetlb: convert to vm_unmapped_area() metag: export clear_page and copy_page metag: export metag_code_cache_flush_all metag: protect more non-MMU memory regions metag: make TXPRIVEXT bits explicit metag: kernel/setup.c: sort includes perf: Enable building perf tools for Meta metag: add boot time LNKGET/LNKSET check metag: add __init to metag_cache_probe() ...
2013-03-02Kconfig.debug: add METAG to dependency listsJames Hogan
Add [!]METAG to a couple of Kconfig dependencies in lib/Kconfig.debug. Don't allow stack utilization instrumentation on metag, and allow building with frame pointers. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: "Paul E. McKenney" <paul.mckenney@linaro.org> Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: Michel Lespinasse <walken@google.com> Cc: Catalin Marinas <catalin.marinas@arm.com>
2013-02-21Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge misc patches from Andrew Morton: - Florian has vanished so I appear to have become fbdev maintainer again :( - Joel and Mark are distracted to welcome to the new OCFS2 maintainer - The backlight queue - Small core kernel changes - lib/ updates - The rtc queue - Various random bits * akpm: (164 commits) rtc: rtc-davinci: use devm_*() functions rtc: rtc-max8997: use devm_request_threaded_irq() rtc: rtc-max8907: use devm_request_threaded_irq() rtc: rtc-da9052: use devm_request_threaded_irq() rtc: rtc-wm831x: use devm_request_threaded_irq() rtc: rtc-tps80031: use devm_request_threaded_irq() rtc: rtc-lp8788: use devm_request_threaded_irq() rtc: rtc-coh901331: use devm_clk_get() rtc: rtc-vt8500: use devm_*() functions rtc: rtc-tps6586x: use devm_request_threaded_irq() rtc: rtc-imxdi: use devm_clk_get() rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug() rtc: rtc-pcf8583: use dev_warn() instead of printk() rtc: rtc-sun4v: use pr_warn() instead of printk() rtc: rtc-vr41xx: use dev_info() instead of printk() rtc: rtc-rs5c313: use pr_err() instead of printk() rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug() rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug() rtc: rtc-ds2404: use dev_err() instead of printk() rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk() ...
2013-02-21lib/Kconfig.debug: unhide CONFIG_PANIC_ON_OOPSKyle McMartin
CONFIG_EXPERT doesn't really make sense, and hides it unintentionally. Remove superfluous "default n" pointed out by Ingo as well. Signed-off-by: Kyle McMartin <kyle@redhat.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-04Merge branch 'rcu/next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu Pull RCU updates from Paul E. McKenney: 1. Changes to rcutorture and to RCU documentation. Posted to LKML at https://lkml.org/lkml/2013/1/26/188. 2. Enhancements to uniprocessor handling in tiny RCU. Posted to LKML at https://lkml.org/lkml/2013/1/27/2. 3. Tag RCU callbacks with grace-period number to simplify callback advancement. Posted to LKML at https://lkml.org/lkml/2013/1/26/203. 4. Miscellaneous fixes. Posted to LKML at https://lkml.org/lkml/2013/1/26/204. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-28Merge branches 'doctorture.2013.01.29a', 'fixes.2013.01.26a', ↵Paul E. McKenney
'tagcb.2013.01.24a' and 'tiny.2013.01.29b' into HEAD doctorture.2013.01.11a: Changes to rcutorture and to RCU documentation. fixes.2013.01.26a: Miscellaneous fixes. tagcb.2013.01.24a: Tag RCU callbacks with grace-period number to simplify callback advancement. tiny.2013.01.29b: Enhancements to uniprocessor handling in tiny RCU.
2013-01-28rcu: Provide RCU CPU stall warnings for tiny RCUPaul E. McKenney
Tiny RCU has historically omitted RCU CPU stall warnings in order to reduce memory requirements, however, lack of these warnings caused Thomas Gleixner some debugging pain recently. Therefore, this commit adds RCU CPU stall warnings to tiny RCU if RCU_TRACE=y. This keeps the memory footprint small, while still enabling CPU stall warnings in kernels built to enable them. Updated to include Josh Triplett's suggested use of RCU_STALL_COMMON config variable to simplify #if expressions. Reported-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2013-01-26rcu: Consolidate debugging Kconfig optionsDave Hansen
The RCU-related debugging Kconfig options are in two different places, and consume too much screen real estate. This commit therefore consolidates them into their own menu. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2013-01-17lib: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Andrew Morton <akpm@linux-foundation.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> CC: Dmitry Kasatkin <dmitry.kasatkin@intel.com> CC: James Morris <james.l.morris@oracle.com> CC: "Michael S. Tsirkin" <mst@redhat.com> CC: Akinobu Mita <akinobu.mita@gmail.com> CC: Ingo Molnar <mingo@kernel.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-08rcu: Reduce rcutorture tracingPaul E. McKenney
Currently, rcutorture traces every read-side access. This can be problematic because even a two-minute rcutorture run on a two-CPU system can generate 28,853,363 reads. Normally, only a failing read is of interest, so this commit traces adjusts rcutorture's tracing to only trace failing reads. The resulting event tracing records the time and the ->completed value captured at the beginning of the RCU read-side critical section, allowing correlation with other event-tracing messages. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> [ paulmck: Add fix to build problem located by Randy Dunlap based on diagnosis by Steven Rostedt. ]
2013-01-03misc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the last of the __dev* markings from the kernel from a variety of different, tiny, places. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-18Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc update from Benjamin Herrenschmidt: "The main highlight is probably some base POWER8 support. There's more to come such as transactional memory support but that will wait for the next one. Overall it's pretty quiet, or rather I've been pretty poor at picking things up from patchwork and reviewing them this time around and Kumar no better on the FSL side it seems..." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (73 commits) powerpc+of: Rename and fix OF reconfig notifier error inject module powerpc: mpc5200: Add a3m071 board support powerpc/512x: don't compile any platform DIU code if the DIU is not enabled powerpc/mpc52xx: use module_platform_driver macro powerpc+of: Export of_reconfig_notifier_[register,unregister] powerpc/dma/raidengine: add raidengine device powerpc/iommu/fsl: Add PAMU bypass enable register to ccsr_guts struct powerpc/mpc85xx: Change spin table to cached memory powerpc/fsl-pci: Add PCI controller ATMU PM support powerpc/86xx: fsl_pcibios_fixup_bus requires CONFIG_PCI drivers/virt: the Freescale hypervisor driver doesn't need to check MSR[GS] powerpc/85xx: p1022ds: Use NULL instead of 0 for pointers powerpc: Disable relocation on exceptions when kexecing powerpc: Enable relocation on during exceptions at boot powerpc: Move get_longbusy_msecs into hvcall.h and remove duplicate function powerpc: Add wrappers to enable/disable relocation on exceptions powerpc: Add set_mode hcall powerpc: Setup relocation on exceptions for bare metal systems powerpc: Move initial mfspr LPCR out of __init_LPCR powerpc: Add relocation on exception vector handlers ...
2012-12-14powerpc+of: Rename and fix OF reconfig notifier error inject moduleBenjamin Herrenschmidt
This module used to inject errors in the pSeries specific dynamic reconfiguration notifiers. Those are gone however, replaced by generic notifiers for changes to the device-tree. So let's update the module to deal with these instead and rename it along the way. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Akinobu Mita <akinobu.mita@gmail.com>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-03treewide: Fix typos in various KconfigMasanari Iida
Correct spelling typo within various Kconfig. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-11-13rcu: Reduce default RCU CPU stall warning timeoutPaul E. McKenney
The RCU CPU stall warning timeout has defaulted to 60 seconds for some years, with almost no false positives. This commit therefore reduces the default to 21 seconds, slightly shorter than the new soft-lockup timeout. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2012-10-09mm: add CONFIG_DEBUG_VM_RB build optionMichel Lespinasse
Add a CONFIG_DEBUG_VM_RB build option for the previously existing DEBUG_MM_RB code. Now that Andi Kleen modified it to avoid using recursive algorithms, we can expose it a bit more. Also extend this code to validate_mm() after stack expansion, and to check that the vma's start and last pgoffs have not changed since the nodes were inserted on the anon vma interval tree (as it is important that the nodes be reindexed after each such update). Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Daniel Santos <daniel.santos@pobox.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09prio_tree: removeMichel Lespinasse
After both prio_tree users have been converted to use red-black trees, there is no need to keep around the prio tree library anymore. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09rbtree: add prio tree and interval tree testsMichel Lespinasse
Patch 1 implements support for interval trees, on top of the augmented rbtree API. It also adds synthetic tests to compare the performance of interval trees vs prio trees. Short answers is that interval trees are slightly faster (~25%) on insert/erase, and much faster (~2.4 - 3x) on search. It is debatable how realistic the synthetic test is, and I have not made such measurements yet, but my impression is that interval trees would still come out faster. Patch 2 uses a preprocessor template to make the interval tree generic, and uses it as a replacement for the vma prio_tree. Patch 3 takes the other prio_tree user, kmemleak, and converts it to use a basic rbtree. We don't actually need the augmented rbtree support here because the intervals are always non-overlapping. Patch 4 removes the now-unused prio tree library. Patch 5 proposes an additional optimization to rb_erase_augmented, now providing it as an inline function so that the augmented callbacks can be inlined in. This provides an additional 5-10% performance improvement for the interval tree insert/erase benchmark. There is a maintainance cost as it exposes augmented rbtree users to some of the rbtree library internals; however I think this cost shouldn't be too high as I expect the augmented rbtree will always have much less users than the base rbtree. I should probably add a quick summary of why I think it makes sense to replace prio trees with augmented rbtree based interval trees now. One of the drivers is that we need augmented rbtrees for Rik's vma gap finding code, and once you have them, it just makes sense to use them for interval trees as well, as this is the simpler and more well known algorithm. prio trees, in comparison, seem *too* clever: they impose an additional 'heap' constraint on the tree, which they use to guarantee a faster worst-case complexity of O(k+log N) for stabbing queries in a well-balanced prio tree, vs O(k*log N) for interval trees (where k=number of matches, N=number of intervals). Now this sounds great, but in practice prio trees don't realize this theorical benefit. First, the additional constraint makes them harder to update, so that the kernel implementation has to simplify things by balancing them like a radix tree, which is not always ideal. Second, the fact that there are both index and heap properties makes both tree manipulation and search more complex, which results in a higher multiplicative time constant. As it turns out, the simple interval tree algorithm ends up running faster than the more clever prio tree. This patch: Add two test modules: - prio_tree_test measures the performance of lib/prio_tree.c, both for insertion/removal and for stabbing searches - interval_tree_test measures the performance of a library of equivalent functionality, built using the augmented rbtree support. In order to support the second test module, lib/interval_tree.c is introduced. It is kept separate from the interval_tree_test main file for two reasons: first we don't want to provide an unfair advantage over prio_tree_test by having everything in a single compilation unit, and second there is the possibility that the interval tree functionality could get some non-test users in kernel over time. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
