Signed-off-by: Florian Ragwitz <rafl@debian.org>
Cc: Jason Baron <jbaron@redhat.com>
* 'x86-atomic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Fix LOCK_PREFIX_HERE for uniprocessor build
x86, atomic64: In selftest, distinguish x86-64 from 586+
x86-32: Fix atomic64_inc_not_zero return value convention
lib: Fix atomic64_inc_not_zero test
lib: Fix atomic64_add_unless return value convention
x86-32: Fix atomic64_add_unless return value convention
lib: Fix atomic64_add_unless test
x86: Implement atomic[64]_dec_if_positive()
lib: Only test atomic64_dec_if_positive on archs having it
x86-32: Rewrite 32-bit atomic64 functions in assembly
lib: Add self-test for atomic64_t
x86-32: Allow UP/SMP lock replacement in cmpxchg64
x86: Add support for lock prefix in alternatives
The CPU_STALL_VERBOSE kernel configuration parameter was added to
2.6.34 to identify any preempted/blocked tasks that were preventing
the current grace period from completing when running preemptible
RCU. As is conventional for new configurations parameters, this
defaulted disabled. It is now time to enable it by default.
There is no need to disable lockdep after an RCU lockdep splat,
so remove the debug_lockdeps_off() from lockdep_rcu_dereference().
To avoid repeated lockdep splats, use a static variable in the inlined
rcu_dereference_check() and rcu_dereference_protected() macros so that
a given instance splats only once, but so that multiple instances can
be detected per boot.
This is controlled by a new config variable CONFIG_PROVE_RCU_REPEATEDLY,
which is disabled by default. This provides the normal lockdep behavior
by default, but permits people who want to find multiple RCU-lockdep
splats per boot to easily do so.
Requested-by: Eric Paris <eparis@redhat.com>
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Tested-by: Eric Paris <eparis@redhat.com>
Merge reason:
Conflict between LOCK_PREFIX_HERE and relative alternatives
pointers
Resolved Conflicts:
arch/x86/include/asm/alternative.h
arch/x86/kernel/alternative.c
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
lib/Kconfig.debug
Only missing thing was an _sdata marker in vmlinux.lds.S
Enable DEBUG_KMEMLEAK for microblaze
We see only one section mismatch now after thousands of randconfigs, and a
bug has been filed about that one.
tools/perf/util/probe-event.c
Merge reason: Pick up -rc1 and resolve the conflict as well.
Add adds a debugfs interface and additional failure modes to LKDTM to
provide similar functionality to the provoke-crash driver submitted here:
http://lwn.net/Articles/371208/
Crashes can now be induced either through module parameters (as before)
or through the debugfs interface as in provoke-crash.
The patch also provides a new "direct" interface, where KPROBES are not
used, i.e., the crash is invoked directly upon write to the debugfs
file. When built without KPROBES configured, only this mode is available.
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
Cc: M. Mohan Kumar <mohan@in.ibm.com>
Cc: Americo Wang <xiyou.wangcong@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>,
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (44 commits)
rcu: Fix accelerated GPs for last non-dynticked CPU
rcu: Make non-RCU_PROVE_LOCKING rcu_read_lock_sched_held() understand boot
rcu: Fix accelerated grace periods for last non-dynticked CPU
rcu: Export rcu_scheduler_active
rcu: Make rcu_read_lock_sched_held() take boot time into account
rcu: Make lockdep_rcu_dereference() message less alarmist
sched, cgroups: Fix module export
rcu: Add RCU_CPU_STALL_VERBOSE to dump detailed per-task information
rcu: Fix rcutorture mod_timer argument to delay one jiffy
rcu: Fix deadlock in TREE_PREEMPT_RCU CPU stall detection
rcu: Convert to raw_spinlocks
rcu: Stop overflowing signed integers
rcu: Use canonical URL for Mathieu's dissertation
rcu: Accelerate grace period if last non-dynticked CPU
rcu: Fix citation of Mathieu's dissertation
rcu: Documentation update for CONFIG_PROVE_RCU
security: Apply lockdep-based checking to rcu_dereference() uses
idr: Apply lockdep-based diagnostics to rcu_dereference() uses
radix-tree: Disable RCU lockdep checking in radix tree
vfs: Abstract rcu_dereference_check for files-fdtable use
Remove pointless union in the breakpoint field of hw_perf_event.
I've forgot to add 'perf lock' line to command-list.txt,
so users of perf could not find perf lock when they type 'perf'.
Fixing command-list.txt requires document
(tools/perf/Documentation/perf-lock.txt).
But perf lock is too much "under construction" to write a
stable document, so this is something like pseudo document for now.
And I wrote description of perf lock at help section of
CONFIG_LOCK_STAT, this will navigate users of lock trace events.
Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
LKML-Reference: <1265267295-8388-1-git-send-email-mitake@dcl.info.waseda.ac.jp>
This patch adds self-test on boot code for atomic64_t.
This has been used to test the later changes in this patchset.
Signed-off-by: Luca Barbieri <luca@luca-barbieri.com>
LKML-Reference: <1267005265-27958-4-git-send-email-luca@luca-barbieri.com>
When RCU detects a grace-period stall, it currently just prints
out the PID of any tasks doing the stalling. This patch adds
RCU_CPU_STALL_VERBOSE, which enables the more-verbose reporting
from sched_show_task().
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <1266887105-1528-21-git-send-email-paulmck@linux.vnet.ibm.com>
Inspection is proving insufficient to catch all RCU misuses,
which is understandable given that rcu_dereference() might be
protected by any of four different flavors of RCU (RCU, RCU-bh,
RCU-sched, and SRCU), and might also/instead be protected by any
of a number of locking primitives. It is therefore time to
enlist the aid of lockdep.
This set of patches is inspired by earlier work by Peter
Zijlstra and Thomas Gleixner, and takes the following approach:
o Set up separate lockdep classes for RCU, RCU-bh, and RCU-sched.
o Set up separate lockdep classes for each instance of SRCU.
o Create primitives that check for being in an RCU read-side
critical section. These return exact answers if lockdep is
fully enabled, but if unsure, report being in an RCU read-side
critical section. (We want to avoid false positives!)
The primitives are:
For RCU: rcu_read_lock_held(void)
For RCU-bh: rcu_read_lock_bh_held(void)
For RCU-sched: rcu_read_lock_sched_held(void)
For SRCU: srcu_read_lock_held(struct srcu_struct *sp)
o Add rcu_dereference_check(), which takes a second argument
in which one places a boolean expression based on the above
primitives and/or lockdep_is_held().
o A new kernel configuration parameter, CONFIG_PROVE_RCU, enables
rcu_dereference_check(). This depends on CONFIG_PROVE_LOCKING,
and should be quite helpful during the transition period while
CONFIG_PROVE_RCU-unaware patches are in flight.
The existing rcu_dereference() primitive does no checking, but
upcoming patches will change that.
Cc: niv@us.ibm.com
LKML-Reference: <1266887105-1528-1-git-send-email-paulmck@linux.vnet.ibm.com>
Enables support for kmemleak on sh.
Signed-off-by: Chris Smith <chris.smith@st.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Add expedited functions. Review documentation and update
obsolete verbiage. Also fix the advice for the RCU CPU-stall
kernel configuration parameter, and document RCU CPU-stall
warnings.
Cc: niv@us.ibm.com
LKML-Reference: <12635142581866-git-send-email->
* 'kmemleak' of git://linux-arm.org/linux-2.6:
kmemleak: fix kconfig for crc32 build error
kmemleak: Reduce the false positives by checking for modified objects
kmemleak: Show the age of an unreferenced object
kmemleak: Release the object lock before calling put_object()
kmemleak: Scan the _ftrace_events section in modules
kmemleak: Simplify the kmemleak_scan_area() function prototype
kmemleak: Do not use off-slab management with SLAB_NOLEAKTRACE
It's easy to lose useful DEBUG_BUGVERBOSE by switching EMBEDDED left and right.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: Add debugobjects support
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits)
security/tomoyo: Remove now unnecessary handling of security_sysctl.
security/tomoyo: Add a special case to handle accesses through the internal proc mount.
sysctl: Drop & in front of every proc_handler.
sysctl: Remove CTL_NONE and CTL_UNNUMBERED
sysctl: kill dead ctl_handler definitions.
sysctl: Remove the last of the generic binary sysctl support
sysctl net: Remove unused binary sysctl code
sysctl security/tomoyo: Don't look at ctl_name
sysctl arm: Remove binary sysctl support
sysctl x86: Remove dead binary sysctl support
sysctl sh: Remove dead binary sysctl support
sysctl powerpc: Remove dead binary sysctl support
sysctl ia64: Remove dead binary sysctl support
sysctl s390: Remove dead sysctl binary support
sysctl frv: Remove dead binary sysctl support
sysctl mips/lasat: Remove dead binary sysctl support
sysctl drivers: Remove dead binary sysctl support
sysctl crypto: Remove dead binary sysctl support
sysctl security/keys: Remove dead binary sysctl support
sysctl kernel: Remove binary sysctl logic
kernel/irq/chip.c
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (31 commits)
rcu: Make RCU's CPU-stall detector be default
rcu: Add expedited grace-period support for preemptible RCU
rcu: Enable fourth level of TREE_RCU hierarchy
rcu: Rename "quiet" functions
rcu: Re-arrange code to reduce #ifdef pain
rcu: Eliminate unneeded function wrapping
rcu: Fix grace-period-stall bug on large systems with CPU hotplug
rcu: Eliminate __rcu_pending() false positives
rcu: Further cleanups of use of lastcomp
rcu: Simplify association of forced quiescent states with grace periods
rcu: Accelerate callback processing on CPUs not detecting GP end
rcu: Mark init-time-only rcu_bootup_announce() as __init
rcu: Simplify association of quiescent states with grace periods
rcu: Rename dynticks_completed to completed_fqs
rcu: Enable synchronize_sched_expedited() fastpath
rcu: Remove inline from forward-referenced functions
rcu: Fix note_new_gpnum() uses of ->gpnum
rcu: Fix synchronization for rcu_process_gp_end() uses of ->completed counter
rcu: Prepare for synchronization fixes: clean up for non-NO_HZ handling of ->completed counter
rcu: Cleanup: balance rcu_irq_enter()/rcu_irq_exit() calls
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
The RCU_CPU_STALL_DETECTOR costs almost nothing and has located
some bugs that might otherwise have been difficult to track
down. Make it be default for the TREE RCU implementations.
The vmlinux size impact is limited (on 64-bit x86 defconfig):
8440248 1260076 995588 10695912 a334e8 vmlinux.before
8440774 1260060 995588 10696422 a336e6 vmlinux.after
+526 bytes - acceptable default cost.
For RAM starved systems, TINY_RCU does not support CPU-stall detection
and is much smaller, but then again it is a uniprocessor...
Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: niv@us.ibm.com
LKML-Reference: <12597846162906-git-send-email->
[ v2: added image size calculations to the changelog ]
Add debugobject support to track the life time of work_structs.
While at it, remove duplicate definition of
INIT_DELAYED_WORK_ON_STACK().
Now that the sys_sysctl is now a compatibility wrapper around
/proc/sys we can remove much of sysctl_check and reduce it
to a few remaining sanity checks. This completely decouples
it from the binary sysctl system call.
Little things like ensuring that the sysctl has not already
been registered are all that remain.
kmemleak uses crc32 functions so it needs to select CRC32.
Fixes build error:
kmemleak.c:(.text+0x7ce62): undefined reference to `crc32_le'
We don't need an explicit PPC64 in the DEBUG_PREEMPT dependancies as all
PPC platforms now support TRACE_IRQFLAGS_SUPPORT.
Also increase the maximum possible kmemleak early log entries since
2000 are not sufficient on s390.
Sam suggested moving STRIP_ASM_SYMS into the Kernel hacking menu
from the General Setup menu. It makes more sense there.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (134 commits)
powerpc/nvram: Enable use Generic NVRAM driver for different size chips
powerpc/iseries: Fix oops reading from /proc/iSeries/mf/*/cmdline
powerpc/ps3: Workaround for flash memory I/O error
powerpc/booke: Don't set DABR on 64-bit BookE, use DAC1 instead
powerpc/perf_counters: Reduce stack usage of power_check_constraints
powerpc: Fix bug where perf_counters breaks oprofile
powerpc/85xx: Fix SMP compile error and allow NULL for smp_ops
powerpc/irq: Improve nanodoc
powerpc: Fix some late PowerMac G5 with PCIe ATI graphics
powerpc/fsl-booke: Use HW PTE format if CONFIG_PTE_64BIT
powerpc/book3e: Add missing page sizes
powerpc/pseries: Fix to handle slb resize across migration
powerpc/powermac: Thermal control turns system off too eagerly
powerpc/pci: Merge ppc32 and ppc64 versions of phb_scan()
powerpc/405ex: support cuImage via included dtb
powerpc/405ex: provide necessary fixup function to support cuImage
powerpc/40x: Add support for the ESTeem 195E (PPC405EP) SBC
powerpc/44x: Add Eiger AMCC (AppliedMicro) PPC460SX evaluation board support.
powerpc/44x: Update Arches defconfig
powerpc/44x: Update Arches dts
Fix up conflicts in drivers/char/agp/uninorth-agp.c
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits)
powerpc64: convert to dynamic percpu allocator
sparc64: use embedding percpu first chunk allocator
percpu: kill lpage first chunk allocator
x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA
percpu: update embedding first chunk allocator to handle sparse units
percpu: use group information to allocate vmap areas sparsely
vmalloc: implement pcpu_get_vm_areas()
vmalloc: separate out insert_vmalloc_vm()
percpu: add chunk->base_addr
percpu: add pcpu_unit_offsets[]
percpu: introduce pcpu_alloc_info and pcpu_group_info
percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward
percpu: add @align to pcpu_fc_alloc_fn_t
percpu: make @dyn_size mandatory for pcpu_setup_first_chunk()
percpu: drop @static_size from first chunk allocators
percpu: generalize first chunk allocator selection
percpu: build first chunk allocators selectively
percpu: rename 4k first chunk allocator to page
percpu: improve boot messages
percpu: fix pcpu_reclaim() locking
Fix trivial conflict as by Tejun Heo in kernel/sched.c
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits)
rcu: Move end of special early-boot RCU operation earlier
rcu: Changes from reviews: avoid casts, fix/add warnings, improve comments
rcu: Create rcutree plugins to handle hotplug CPU for multi-level trees
rcu: Remove lockdep annotations from RCU's _notrace() API members
rcu: Add #ifdef to suppress __rcu_offline_cpu() warning in !HOTPLUG_CPU builds
rcu: Add CPU-offline processing for single-node configurations
rcu: Add "notrace" to RCU function headers used by ftrace
rcu: Remove CONFIG_PREEMPT_RCU
rcu: Merge preemptable-RCU functionality into hierarchical RCU
rcu: Simplify rcu_pending()/rcu_check_callbacks() API
rcu: Use debugfs_remove_recursive() simplify code.
rcu: Merge per-RCU-flavor initialization into pre-existing macro
rcu: Fix online/offline indication for rcudata.csv trace file
rcu: Consolidate sparse and lockdep declarations in include/linux/rcupdate.h
rcu: Renamings to increase RCU clarity
rcu: Move private definitions from include/linux/rcutree.h to kernel/rcutree.h
rcu: Expunge lingering references to CONFIG_CLASSIC_RCU, optimize on !SMP
rcu: Delay rcu_barrier() wait until beginning of next CPU-hotunplug operation.
rcu: Fix typo in rcu_irq_exit() comment header
rcu: Make rcupreempt_trace.c look at offline CPUs
Add a config option (CONFIG_DEBUG_CREDENTIALS) to turn on some debug checking
for credential management. The additional code keeps track of the number of
pointers from task_structs to any given cred struct, and checks to see that
this number never exceeds the usage count of the cred struct (which includes
all references, not just those from task_structs).
Furthermore, if SELinux is enabled, the code also checks that the security
pointer in the cred struct is never seen to be invalid.
This attempts to catch the bug whereby inode_has_perm() faults in an nfsd
kernel thread on seeing cred->security be a NULL pointer (it appears that the
credential struct has been previously released):
http://www.kerneloops.org/oops.php?number=252883
Signed-off-by: James Morris <jmorris@namei.org>
Now that CONFIG_TREE_PREEMPT_RCU is in place, there is no
further need for CONFIG_PREEMPT_RCU. Remove it, along with
whatever subtle bugs it may (or may not) contain.
Cc: akpm@linux-foundation.org
Cc: josht@linux.vnet.ibm.com
Cc: niv@us.ibm.com
LKML-Reference: <125097461396-git-send-email->
Create a kernel/rcutree_plugin.h file that contains definitions
for preemptable RCU (or, under the #else branch of the #ifdef,
empty definitions for the classic non-preemptable semantics).
These definitions fit into plugins defined in kernel/rcutree.c
for this purpose.
This variant of preemptable RCU uses a new algorithm whose
read-side expense is roughly that of classic hierarchical RCU
under CONFIG_PREEMPT. This new algorithm's update-side expense
is similar to that of classic hierarchical RCU, and, in absence
of read-side preemption or blocking, is exactly that of classic
hierarchical RCU. Perhaps more important, this new algorithm
has a much simpler implementation, saving well over 1,000 lines
of code compared to mainline's implementation of preemptable
RCU, which will hopefully be retired in favor of this new
algorithm.
The simplifications are obtained by maintaining per-task
nesting state for running tasks, and using a simple
lock-protected algorithm to handle accounting when tasks block
within RCU read-side critical sections, making use of lessons
learned while creating numerous user-level RCU implementations
over the past 18 months.
Cc: niv@us.ibm.com
LKML-Reference: <12509746134003-git-send-email->
Very lightly tested, doesn't crash the kernel.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Pull linus#master to merge PER_CPU_DEF_ATTRIBUTES and alpha build fix
changes. As alpha in percpu tree uses 'weak' attribute instead of
inline assembly, there's no need for __used attribute.
arch/alpha/include/asm/percpu.h
arch/mn10300/kernel/vmlinux.lds.S
include/linux/percpu-defs.h
(feature suggested by Sergey Senozhatsky)
Kmemleak needs to track all the memory allocations but some of these
happen before kmemleak is initialised. These are stored in an internal
buffer which may be exceeded in some kernel configurations. This patch
adds a configuration option with a default value of 400 and also removes
the stack dump when the early log buffer is exceeded.
Acked-by: Sergey Senozhatsky <sergey.senozhatsky@mail.by>
Some archs (alpha and s390) need to use weak definitions for percpu
variables in modules so that the compiler generates external
references for them.
This patch implements weak percpu definitions which arch can enable by
defining ARCH_NEEDS_WEAK_PER_CPU in arch percpu header file. This
weak definition adds the following two restrictions on percpu variable
definitions.
1. percpu symbols must be unique whether static or not
2. percpu variables can't be defined inside a function
To ensure that these restrictions are observed in generic code, config
option DEBUG_FORCE_WEAK_PER_CPU enables weak percpu definitions for
all cases.
This patch is inspired by Ivan Kokshaysky's alpha percpu patch.
[ Impact: stricter rules for percpu variables, one more debug config option ]
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Selecting DEBUG_SLAB or SLUB_DEBUG by the KMEMLEAK menu entry may cause
issues with other dependencies (KMEMCHECK). These configuration options
aren't strictly needed by kmemleak but they may increase the chances of
finding leaks. This patch also updates the KMEMLEAK config entry help
text.
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
lockdep: Select frame pointers on x86
dma-debug: be more careful when building reference entries
dma-debug: check for sg_call_ents in best-fit algorithm too
x86 stack traces are a piece of crap without frame pointers, and its not
like the 'performance gain' of not having stack pointers matters when you
selected lockdep.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
LKML-Reference: <new-submission>
Cc: <stable@kernel.org>
The Kconfig options of kmemcheck are hidden under arch/x86 which makes porting
to other architectures harder. To fix that, move the Kconfig bits to
lib/Kconfig.kmemcheck and introduce a CONFIG_HAVE_ARCH_KMEMCHECK config option
that architectures can define.
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
[rebased for mainline inclusion]
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
let it rip!
Signed-off-by: Vegard Nossum <vegardno@ifi.uio.no>
This patch adds a loadable module that deliberately leaks memory. It
is used for testing various memory leaking scenarios.
