If the kernel command line declares a tracer "ftrace=sometracer" and
that tracer is either not defined or is enabled after irqsoff,
then the irqs off selftest will fail with the following error:
Testing tracer irqsoff:
WARNING: at /home/rostedt/work/autotest/nobackup/linux-test.git/kernel/trace/tra
ce.c:713 update_max_tr_single+0xfa/0x11b()
Hardware name:
Modules linked in:
Pid: 1, comm: swapper Not tainted 2.6.38-rc8-test #1
Call Trace:
[<c0441d9d>] ? warn_slowpath_common+0x65/0x7a
[<c049adb2>] ? update_max_tr_single+0xfa/0x11b
[<c0441dc1>] ? warn_slowpath_null+0xf/0x13
[<c049e454>] ? stop_critical_timing+0x154/0x204
[<c049b54b>] ? trace_selftest_startup_irqsoff+0x5b/0xc1
[<c049e529>] ? time_hardirqs_on+0x25/0x28
[<c0468bca>] ? trace_hardirqs_on_caller+0x18/0x12f
[<c0468cec>] ? trace_hardirqs_on+0xb/0xd
[<c049b6b8>] ? register_tracer+0xf8/0x1a3
[<c14e93fe>] ? init_irqsoff_tracer+0xd/0x11
[<c040115e>] ? do_one_initcall+0x71/0x121
[<c14e93f1>] ? init_irqsoff_tracer+0x0/0x11
[<c14ce3a9>] ? kernel_init+0x13a/0x1b6
[<c14ce26f>] ? kernel_init+0x0/0x1b6
[<c0403842>] ? kernel_thread_helper+0x6/0x10
---[ end trace e93713a9d40cd06c ]---
.. no entries found ..FAILED!
What happens is the "ftrace=..." will expand the ring buffer to its
default size (from its minimum size) but it will not expand the
max ring buffer (the ring buffer to store maximum latencies).
When the irqsoff test runs, it will call the ring buffer swap routine
that checks if the max ring buffer is the same size as the normal
ring buffer, and will fail if it is not. This causes the test to fail.
The solution is to expand the max ring buffer before running the self
test if the max ring buffer is used by that tracer and the normal ring
buffer is expanded. The max ring buffer should be shrunk again after
the test is done to save space.
Move elements in struct tracer for better alignment.
Trace events belonging to a module only exists when the module is
loaded. Well, we can use trace_set_clr_event funtion to enable some
trace event at the module init routine, so that we will not miss
something while loading then module.
So, Export the trace_set_clr_event function so that module can use it.
Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com>
LKML-Reference: <1289196312-25323-1-git-send-email-yuanhan.liu@linux.intel.com>
The "Delta way too big" warning might appear on a system with a
unstable shed clock right after the system is resumed and tracing
was enabled at time of suspend.
Since it's not realy a bug, and the unstable sched clock is working
fast and reliable otherwise, Steven suggested to keep using the
sched clock in any case and just to make note in the warning itself.
v2 changes:
- added #ifdef CONFIG_HAVE_UNSTABLE_SCHED_CLOCK
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
LKML-Reference: <20110218145219.GD2604@jolsa.brq.redhat.com>
Formatting change only to improve code readability. No code changes except to
introduce intermediate variables.
Signed-off-by: David Sharp <dhsharp@google.com>
LKML-Reference: <1291421609-14665-13-git-send-email-dhsharp@google.com>
[ Keep variable declarations and assignment separate ]
LKML-Reference: <1291421609-14665-6-git-send-email-dhsharp@google.com>
The lock_depth field in the event headers was added as a temporary
data point for help in removing the BKL. Now that the BKL is pretty
much been removed, we can remove this field.
This in turn changes the header from 12 bytes to 8 bytes,
removing the 4 byte buffer that gcc would insert if the first field
in the data load was 8 bytes in size.
LKML-Reference: <1291421609-14665-3-git-send-email-dhsharp@google.com>
Add an "overwrite" trace_option for ftrace to control whether the buffer should
be overwritten on overflow or not. The default remains to overwrite old events
when the buffer is full. This patch adds the option to instead discard newest
events when the buffer is full. This is useful to get a snapshot of traces just
after enabling traces. Dropping the current event is also a simpler code path.
LKML-Reference: <1291844807-15481-1-git-send-email-dhsharp@google.com>
Merge reason: Merge latest fixes.
Don't forget to release cgroup_mutex if alloc_trial_cpuset() fails.
[akpm@linux-foundation.org: avoid multiple return points]
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Miao Xie <miaox@cn.fujitsu.com>
Cc: <stable@kernel.org>
They are only used inside kernel/ptrace.c, and have been for a long
time. We don't want to go back to the bad-old-days when architectures
did things on their own, so make them static and private.
Li Zefan reported that the jump label code sleeps and we're calling it
under a spinlock, *fail* ;-)
Reported-by: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <new-submission>
- Use kzalloc() to replace kmalloc() + memset().
- Remove redundant initialization, since alloc_percpu() returns
zero-filled percpu memory.
Acked-by: Stephane Eranian <eranian@google.com>
LKML-Reference: <4D6F347E.2010806@cn.fujitsu.com>
In the failure path, we call perf_detach_cgroup(), but we didn't
call perf_get_cgroup() prio to it.
LKML-Reference: <4D6F346E.9070606@cn.fujitsu.com>
In perf_cgroup_connect(), fput_light() is missing in a failure path.
LKML-Reference: <4D6F3461.6060406@cn.fujitsu.com>
Currently, the event is not initialized if pmu is found in idr. This
never causes bug just because now no pmu is associated with the idr
id.
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
LKML-Reference: <1298812411.2699.9.camel@localhost>
Merge reason: Pick up updates before queueing up dependent patches.
If we enable trace events to trace block actions, We use
blk_fill_rwbs_rq to analyze the corresponding actions
in request's cmd_flags, but we only choose the minor 2 bits
from it, so most of other flags(e.g, REQ_SYNC) are missing.
For example, with a sync write we get:
write_test-2409 [001] 160.013869: block_rq_insert: 3,64 W 0 () 258135 + =
8 [write_test]
Since now we have integrated the flags of both bio and request,
it is safe to pass rq->cmd_flags directly to blk_fill_rwbs and
blk_fill_rwbs_rq isn't needed any more.
With this patch, after a sync write we get:
write_test-2417 [000] 226.603878: block_rq_insert: 3,64 WS 0 () 258135 +=
8 [write_test]
Signed-off-by: Tao Ma <boyu.mt@taobao.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace.git into perf/core
When the per cpu timer is marked CLOCK_EVT_FEAT_C3STOP, then we only
can switch into oneshot mode, when the backup broadcast device
supports oneshot mode as well. Otherwise we would try to switch the
broadcast device into an unsupported mode unconditionally. This went
unnoticed so far as the current available broadcast devices support
oneshot mode. Seth unearthed this problem while debugging and working
around an hpet related BIOS wreckage.
Add the necessary check to tick_is_oneshot_available().
Reported-and-tested-by: Seth Forshee <seth.forshee@canonical.com>
LKML-Reference: <alpine.LFD.2.00.1102252231200.2701@localhost6.localdomain6>
Cc: stable@kernel.org # .21 ->
There is no point in us having different code paths for nmi and !nmi
here, so remove the !nmi one.
Cc: Stephane Eranian <eranian@google.com>
This patches ensures that we do not end up calling
perf_cgroup_from_task() when there is no cgroup event.
This avoids potential RCU and locking issues.
The change in perf_cgroup_set_timestamp() ensures we
check against ctx->nr_cgroups. It also avoids calling
perf_clock() tiwce in a row. It also ensures we do need
to grab ctx->lock before calling the function.
We drop update_cgrp_time() from task_clock_event_read()
because it is not needed. This also avoids having to
deal with perf_cgroup_from_task().
Thanks to Peter Zijlstra for his help on this.
Signed-off-by: Stephane Eranian <eranian@gmail.com>
LKML-Reference: <4d5e76b8.815bdf0a.7ac3.774f@mx.google.com>
* 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq: Disable the SHIRQ_DEBUG call in request_threaded_irq for now
genirq: Prevent access beyond allocated_irqs bitmap
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf: Fix throttle logic
perf, x86: P4 PMU: Fix spurious NMI messages
With CONFIG_SHIRQ_DEBUG=y we call a newly installed interrupt handler
in request_threaded_irq().
The original implementation (commit a304e1b8) called the handler
_BEFORE_ it was installed, but that caused problems with handlers
calling disable_irq_nosync(). See commit 377bf1e4.
It's braindead in the first place to call disable_irq_nosync in shared
handlers, but ....
Moving this call after we installed the handler looks innocent, but it
is very subtle broken on SMP.
Interrupt handlers rely on the fact, that the irq core prevents
reentrancy.
Now this debug call violates that promise because we run the handler
w/o the IRQ_INPROGRESS protection - which we cannot apply here because
that would result in a possibly forever masked interrupt line.
A concurrent real hardware interrupt on a different CPU results in
handler reentrancy and can lead to complete wreckage, which was
unfortunately observed in reality and took a fricking long time to
debug.
Leave the code here for now. We want this debug feature, but that's
not easy to fix. We really should get rid of those
disable_irq_nosync() abusers and remove that function completely.
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: stable@kernel.org # .28 -> .37
Lars-Peter Clausen pointed out:
I stumbled upon this while looking through the existing archs using
SPARSE_IRQ. Even with SPARSE_IRQ the NR_IRQS is still the upper
limit for the number of IRQs.
Both PXA and MMP set NR_IRQS to IRQ_BOARD_START, with
IRQ_BOARD_START being the number of IRQs used by the core.
In various machine files the nr_irqs field of the ARM machine
defintion struct is then set to "IRQ_BOARD_START + NR_BOARD_IRQS".
As a result "nr_irqs" will greater then NR_IRQS which then again
causes the "allocated_irqs" bitmap in the core irq code to be
accessed beyond its size overwriting unrelated data.
The core code really misses a sanity check there.
This went unnoticed so far as by chance the compiler/linker places
data behind that bitmap which gets initialized later on those affected
platforms.
So the obvious fix would be to add a sanity check in early_irq_init()
and break all affected platforms. Though that check wants to be
backported to stable as well, which will require to fix all known
problematic platforms and probably some more yet not known ones as
well. Lots of churn.
A way simpler solution is to allocate a slightly larger bitmap and
avoid the whole churn w/o breaking anything. Add a few warnings when
an arch returns utter crap.
Reported-by: Lars-Peter Clausen <lars@metafoo.de>
Cc: stable@kernel.org # .37
Cc: Haojian Zhuang <haojian.zhuang@marvell.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq
* 'fixes-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: make sure MAYDAY_INITIAL_TIMEOUT is at least 2 jiffies long
workqueue, freezer: unify spelling of 'freeze' + 'able' to 'freezable'
workqueue: wake up a worker when a rescuer is leaving a gcwq
This reverts commit 5e38ca8f3ea423442eaafe1b7e206084aa38120a.
Breaks the build of several !CONFIG_HAVE_UNSTABLE_SCHED_CLOCK
architectures.
Cc: Jiri Olsa <jolsa@redhat.com>
Message-ID: <20110217171823.GB17058@elte.hu>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
Currently we return 0 in swsusp_alloc() when alloc_image_page() fails.
Fix that. Also remove unneeded "error" variable since the only
useful value of error is -ENOMEM.
[rjw: Fixed up the changelog and changed subject.]
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
MAYDAY_INITIAL_TIMEOUT is defined as HZ / 100 and depending on
configuration may end up 0 or 1. Even when it's 1, depending on when
the mayday timer is added in the current jiffy interval, it may expire
way before a jiffy has passed.
Make sure MAYDAY_INITIAL_TIMEOUT is at least two to guarantee that at
least a full jiffy has passed before calling rescuers.
Reported-by: Ray Jui <rjui@broadcom.com>
There are two spellings in use for 'freeze' + 'able' - 'freezable' and
'freezeable'. The former is the more prominent one. The latter is
mostly used by workqueue and in a few other odd places. Unify the
spelling to 'freezable'.
Reported-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Cc: Alex Dubov <oakad@yahoo.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
There is no need to re-initialize the hrtimer every time we start it,
so don't do that (shaves a few cycles). Also, since we know hrtimers
run at a fixed rate (nanoseconds) we can pre-compute the desired
frequency at which they tick. This avoids us having to go through the
whole adaptive frequency feedback logic (shaves another few cycles).
LKML-Reference: <1297448589.5226.47.camel@laptop>
By pre-computing the maximum number of samples per tick we can avoid a
multiplication and a conditional since MAX_INTERRUPTS >
max_samples_per_tick.
This kernel patch adds the ability to filter monitoring based on
container groups (cgroups). This is for use in per-cpu mode only.
The cgroup to monitor is passed as a file descriptor in the pid
argument to the syscall. The file descriptor must be opened to
the cgroup name in the cgroup filesystem. For instance, if the
cgroup name is foo and cgroupfs is mounted in /cgroup, then the
file descriptor is opened to /cgroup/foo. Cgroup mode is
activated by passing PERF_FLAG_PID_CGROUP in the flags argument
to the syscall.
For instance to measure in cgroup foo on CPU1 assuming
cgroupfs is mounted under /cgroup:
struct perf_event_attr attr;
int cgroup_fd, fd;
cgroup_fd = open("/cgroup/foo", O_RDONLY);
fd = perf_event_open(&attr, cgroup_fd, 1, -1, PERF_FLAG_PID_CGROUP);
close(cgroup_fd);
Signed-off-by: Stephane Eranian <eranian@google.com>
[ added perf_cgroup_{exit,attach} ]
LKML-Reference: <4d590250.114ddf0a.689e.4482@mx.google.com>
Make the ::exit method act like ::attach, it is after all very nearly
the same thing.
The bug had no effect on correctness - fixing it is an optimization for
the scheduler. Also, later perf-cgroups patches rely on it.
Acked-by: Paul Menage <menage@google.com>
LKML-Reference: <1297160655.13327.92.camel@laptop>
Merge reason: we need to queue up dependent patch
It was possible to call pmu::start() on an already running event. In
particular this lead so some wreckage as the hrtimer events would
re-initialize active timers.
This was due to throttled events being activated again by scheduling.
Scheduling in a context would add and force start events, resulting in
running events with a possible throttle status. The next tick to hit
that task will then try to unthrottle the event and call ->start() on
Reported-by: Jeff Moyer <jmoyer@redhat.com>
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
Revert "lockdep, timer: Fix del_timer_sync() annotation"
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
timer debug: Hide kernel addresses via %pK in /proc/timer_list
x86: Fix text_poke_smp_batch() deadlock
perf tools: Fix thread_map event synthesizing in top and record
watchdog, nmi: Lower the severity of error messages
ARM: oprofile: Fix backtraces in timer mode
oprofile: Fix usage of CONFIG_HW_PERF_EVENTS for oprofile_perf_init and friends
After executing the matching works, a rescuer leaves the gcwq whether
there are more pending works or not. This may decrease the
concurrency level to zero and stall execution until a new work item is
queued on the gcwq.
Make rescuer wake up a regular worker when it leaves a gcwq if there
are more works to execute, so that execution isn't stalled.
Add NULL check for avoiding NULL pointer deref.
This bug has been introduced by:
1ff511e35ed8: tracing/kprobes: Add bitfield type
which causes a null pointer dereference bug when kprobe-tracer
parses an argument without type.
Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: 2nddept-manager@sdl.hitachi.co.jp
LKML-Reference: <20110214054807.8919.69740.stgit@ltc236.sdl.hitachi.co.jp>
Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
In the continuing effort to avoid kernel addresses leaking to
unprivileged users, this patch switches to %pK for
/proc/timer_list reporting.
Signed-off-by: Kees Cook <kees.cook@canonical.com>
Cc: John Stultz <johnstul@us.ibm.com>
Cc: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Eugene Teo <eugeneteo@kernel.org>
LKML-Reference: <20110212032125.GA23571@outflux.net>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
pci: use security_capable() when checking capablities during config space read
security: add cred argument to security_capable()
tpm_tis: Use timeouts returned from TPM
The wake_up_process() call in ptrace_detach() is spurious and not
interlocked with the tracee state. IOW, the tracee could be running or
sleeping in any place in the kernel by the time wake_up_process() is
called. This can lead to the tracee waking up unexpectedly which can be
dangerous.
The wake_up is spurious and should be removed but for now reduce its
toxicity by only waking up if the tracee is in TRACED or STOPPED state.
This bug can possibly be used as an attack vector. I don't think it
will take too much effort to come up with an attack which triggers oops
somewhere. Most sleeps are wrapped in condition test loops and should
be safe but we have quite a number of places where sleep and wakeup
conditions are expected to be interlocked. Although the window of
opportunity is tiny, ptrace can be used by non-privileged users and with
some loading the window can definitely be extended and exploited.
Acked-by: Roland McGrath <roland@redhat.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
When the fuction graph tracer starts, it needs to make a special
stack for each task to save the real return values of the tasks.
All running tasks have this stack created, as well as any new
tasks.
On CPU hot plug, the new idle task will allocate a stack as well
when init_idle() is called. The problem is that cpu hotplug does
not create a new idle_task. Instead it uses the idle task that
existed when the cpu went down.
ftrace_graph_init_task() will add a new ret_stack to the task
that is given to it. Because a clone will make the task
have a stack of its parent it does not check if the task's
ret_stack is already NULL or not. When the CPU hotplug code
starts a CPU up again, it will allocate a new stack even
though one already existed for it.
The solution is to treat the idle_task specially. In fact, the
function_graph code already does, just not at init_idle().
Instead of using the ftrace_graph_init_task() for the idle task,
which that function expects the task to be a clone, have a
separate ftrace_graph_init_idle_task(). Also, we will create a
per_cpu ret_stack that is used by the idle task. When we call
ftrace_graph_init_idle_task() it will check if the idle task's
ret_stack is NULL, if it is, then it will assign it the per_cpu
ret_stack.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Stable Tree <stable@kernel.org>
Fixups due to rename of event_t routines from event__ to perf_event__
done in perf/core.
tools/perf/builtin-record.c
tools/perf/builtin-top.c
tools/perf/util/event.c
tools/perf/util/event.h
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Expand security_capable() to include cred, so that it can be usable in a
wider range of call sites.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Signed-off-by: James Morris <jmorris@namei.org>
