This patch re-institutes the ability to build rcutorture directly into
the Linux kernel. The reason that this capability was removed was that
this could result in your kernel being pretty much useless, as rcutorture
would be running starting from early boot. This problem has been avoided
by (1) making rcutorture run only three seconds of every six by default,
(2) adding a CONFIG_RCU_TORTURE_TEST_RUNNABLE that permits rcutorture
to be quiesced at boot time, and (3) adding a sysctl in /proc named
/proc/sys/kernel/rcutorture_runnable that permits rcutorture to be
quiesced and unquiesced when built into the kernel.
Please note that this /proc file is -not- available when rcutorture
is built as a module. Please also note that to get the earlier
take-no-prisoners behavior, you must use the boot command line to set
rcutorture's "stutter" parameter to zero.
The rcutorture quiescing mechanism is currently quite crude: loops
in each rcutorture process that poll a global variable once per tick.
Suggestions for improvement are welcome. The default action will
be to reduce the polling rate to a few times per second.
Suggested-by: Ingo Molnar <mingo@elte.hu>
This patch takes a step towards making rcutorture more brutal by allowing
the test to be automatically periodically paused, with the default being
to run the test for five seconds then pause for five seconds and repeat.
This behavior can be controlled using a new "stutter" module parameter, so
that "stutter=0" gives the old default behavior of running continuously.
Starting and stopping rcutorture more heavily stresses RCU's interaction
with the scheduler, as well as exercising more paths through the
grace-period detection code.
Note that the default to "shuffle_interval" has also been adjusted from
5 seconds to 3 seconds to provide varying overlap with the "stutter"
interval.
I am still unable to provoke the failures that Alexey has been seeing,
even with this patch, but will be doing a few additional things to beef
up rcutorture.
this makes it easier for automated tests to pick up such failures.
Since softirq works for rcu reclaimer, rcu_tasklet is unused now.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
Fix error checking routine to catch an error which occurs in first
__register_*probe().
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Jim Keniston <jkenisto@us.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: 64-bit: fix arithmetics overflow
sched: fair group: fix overflow(was: fix divide by zero)
sched: fix TASK_WAKEKILL vs SIGKILL race
(overflow means weight >= 2^32 here, because inv_weigh = 2^32/weight)
A weight of a cfs_rq is the sum of weights of which entities
are queued on this cfs_rq, so it will overflow when there are
too many entities.
Although, overflow occurs very rarely, but it break fairness when
it occurs. 64-bits systems have more memory than 32-bit systems
and 64-bit systems can create more process usually, so overflow may
occur more frequently.
This patch guarantees fairness when overflow happens on 64-bit systems.
Thanks to the optimization of compiler, it changes nothing on 32-bit.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
I found a bug which can be reproduced by this way:(linux-2.6.26-rc5, x86-64)
(use 2^32, 2^33, ...., 2^63 as shares value)
# mkdir /dev/cpuctl
# mount -t cgroup -o cpu cpuctl /dev/cpuctl
# cd /dev/cpuctl
# mkdir sub
# echo 0x8000000000000000 > sub/cpu.shares
# echo $$ > sub/tasks
oops here! divide by zero.
This is because do_div() expects the 2th parameter to be 32 bits,
but unsigned long is 64 bits in x86_64.
Peter Zijstra pointed it out that the sane thing to do is limit the
shares value to something smaller instead of using an even more
expensive divide.
Also, I found another bug about "the shares value is too large":
pid1 and pid2 are set affinity to cpu#0
pid1 is attached to cg1 and pid2 is attached to cg2
if cg1/cpu.shares = 1024 cg2/cpu.shares = 2000000000
then pid2 got 100% usage of cpu, and pid1 0%
if cg1/cpu.shares = 1024 cg2/cpu.shares = 20000000000
then pid2 got 0% usage of cpu, and pid1 100%
And a weight of a cfs_rq is the sum of weights of which entities
are queued on this cfs_rq, so the shares value should be limited
to a smaller value.
I think that (1UL << 18) is a good limited value:
1) it's not too large, we can create a lot of group before overflow
2) it's several times the weight value for nice=-19 (not too small)
schedule() has the special "TASK_INTERRUPTIBLE && signal_pending()" case,
this allows us to do
current->state = TASK_INTERRUPTIBLE;
schedule();
without fear to sleep with pending signal.
However, the code like
current->state = TASK_KILLABLE;
schedule();
is not right, schedule() doesn't take TASK_WAKEKILL into account. This means
that mutex_lock_killable(), wait_for_completion_killable(), down_killable(),
schedule_timeout_killable() can miss SIGKILL (and btw the second SIGKILL has
no effect).
Introduce the new helper, signal_pending_state(), and change schedule() to
use it. Hopefully it will have more users, that is why the task's state is
passed separately.
Note this "__TASK_STOPPED | __TASK_TRACED" check in signal_pending_state().
This is needed to preserve the current behaviour (ptrace_notify). I hope
this check will be removed soon, but this (afaics good) change needs the
separate discussion.
The fast path is "(state & (INTERRUPTIBLE | WAKEKILL)) + signal_pending(p)",
basically the same that schedule() does now. However, this patch of course
bloats schedule().
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6:
capabilities: remain source compatible with 32-bit raw legacy capability support.
LSM: remove stale web site from MAINTAINERS
Adding a nonexistent cpu to a cpuset will be omitted quietly. It should
return -EINVAL.
Example: (real_nr_cpus <= 4 < NR_CPUS or cpu#4 was just offline)
# cat cpus
0-1
# /bin/echo 4 > cpus
# /bin/echo $?
0
# cat cpus
The same occurs when add a nonexistent mem.
This patch will fix this bug.
And when *buf == "", the check is unneeded.
Acked-by: Paul Jackson <pj@sgi.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb:
kgdbts: Use HW breakpoints with CONFIG_DEBUG_RODATA
kgdb: use common ascii helpers and put_unaligned_be32 helper
support.
Source code out there hard-codes a notion of what the
_LINUX_CAPABILITY_VERSION #define means in terms of the semantics of the
raw capability system calls capget() and capset(). Its unfortunate, but
true.
Since the confusing header file has been in a released kernel, there is
software that is erroneously using 64-bit capabilities with the semantics
of 32-bit compatibilities. These recently compiled programs may suffer
corruption of their memory when sys_getcap() overwrites more memory than
they are coded to expect, and the raising of added capabilities when using
sys_capset().
As such, this patch does a number of things to clean up the situation
for all. It
1. forces the _LINUX_CAPABILITY_VERSION define to always retain its
legacy value.
2. adopts a new #define strategy for the kernel's internal
implementation of the preferred magic.
3. deprecates v2 capability magic in favor of a new (v3) magic
number. The functionality of v3 is entirely equivalent to v2,
the only difference being that the v2 magic causes the kernel
to log a "deprecated" warning so the admin can find applications
that may be using v2 inappropriately.
[User space code continues to be encouraged to use the libcap API which
protects the application from details like this. libcap-2.10 is the first
to support v3 capabilities.]
Fixes issue reported in https://bugzilla.redhat.com/show_bug.cgi?id=447518.
Thanks to Bojan Smojver for the report.
[akpm@linux-foundation.org: s/depreciate/deprecate/g]
[akpm@linux-foundation.org: be robust about put_user size]
Signed-off-by: Andrew G. Morgan <morgan@kernel.org>
Cc: Serge E. Hallyn <serue@us.ibm.com>
Cc: Bojan Smojver <bojan@rexursive.com>
Cc: stable@kernel.org
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
sched: re-tune NUMA topologies
sched: stop wake_affine from causing serious imbalance
sched: fix sched_clock_cpu()
revert ("sched: fair-group: SMP-nice for group scheduling")
sched: cleanup
show_schedstat(): fix memleak
sched: unite unlikely pairs in rt_policy() and schedule_debug()
revert ("sched: fair: weight calculations")
Prevent short-running wakers of short-running threads from overloading a single
cpu via wakeup affinity, and wire up disconnected debug option.
Signed-off-by: Mike Galbraith <efault@gmx.de>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Make sched_clock_cpu() return 0 before it has been initialized and avoid
corrupting its state due to doing so.
This fixes the weird printk timestamp jump reported.
Yanmin Zhang reported:
Comparing with 2.6.25, volanoMark has big regression with kernel 2.6.26-rc1.
It's about 50% on my 8-core stoakley, 16-core tigerton, and Itanium Montecito.
With bisect, I located the following patch:
| 18d95a2832c1392a2d63227a7a6d433cb9f2037e is first bad commit
| commit 18d95a2832c1392a2d63227a7a6d433cb9f2037e
| Author: Peter Zijlstra <a.p.zijlstra@chello.nl>
| Date: Sat Apr 19 19:45:00 2008 +0200
Revert it so that we get v2.6.25 behavior.
Bisected-by: Yanmin Zhang <yanmin_zhang@linux.intel.com>
The Coverity checker spotted a memleak introduced by commit
39106dcf85285e78f3b290022122c76f851379b8 (cpumask: use new cpus_scnprintf
function).
It seems the kfree() got lost between v2 and v3 of this patch...
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: Mike Travis <travis@sgi.com>
Removes obfuscation and may improve assembly.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Comparing with kernel 2.6.25, sysbench+mysql(oltp, readonly) has many
regressions with 2.6.26-rc1:
1) 8-core stoakley: 28%;
2) 16-core tigerton: 20%;
3) Itanium Montvale: 50%.
Bisect located this patch:
| 8f1bc385cfbab474db6c27b5af1e439614f3025c is first bad commit
| commit 8f1bc385cfbab474db6c27b5af1e439614f3025c
Revert it to the 2.6.25 state.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Splice isn't always incrementing the ppos correctly, which broke
relay splice.
Signed-off-by: Tom Zanussi <zanussi@comcast.net>
Tested-by: Dan Williams <dan.j.williams@intel.com>
Based on Roland's patch. This approach was suggested by Austin Clements
from the very beginning, and then by Linus.
As Austin pointed out, the execing task can be killed by SI_TIMER signal
because exec flushes the signal handlers, but doesn't discard the pending
signals generated by posix timers. Perhaps not a bug, but people find this
surprising. See http://bugzilla.kernel.org/show_bug.cgi?id=10460
Cc: Austin Clements <amdragon+kernelbugzilla@mit.edu>
Cc: Roland McGrath <roland@redhat.com>
Currently sigqueue_free() removes sigqueue from list, but doesn't cancel the
pending signal. This is not consistent, the task should either receive the
"full" signal along with siginfo_t, or it shouldn't receive the signal at all.
Change sigqueue_free() to clear SIGQUEUE_PREALLOC but leave sigqueue on list
if it is queued.
This is a user-visible change. If the signal is blocked, it stays queued
after sys_timer_delete() until unblocked with the "stale" si_code/si_value,
and of course it is still counted wrt RLIMIT_SIGPENDING which also limits
the number of posix timers.
This is a slight change in the namespace cgroup subsystem api.
The change is that previously when cgroup_clone() was called (currently
only from the unshare path in ns_proxy cgroup, you'd get a new group named
"node_$pid" whereas now you'll get a group named after just your pid.)
The only users who would notice it are those who are using the ns_proxy
cgroup subsystem to auto-create cgroups when namespaces are unshared -
something of an experimental feature, which I think really needs more
complete container/namespace support in order to be useful. I suspect the
only users are Cedric and Serge, or maybe a few others on
containers@lists.linux-foundation.org. And in fact it would only be
noticed by the users who make the assumption about how the name is
generated, rather than getting it from the /proc/<pid>/cgroups file for
the process in question.
Whether the change is actually needed or not I'm fairly agnostic on, but I
guess it is more elegant to just use the pid as the new group name rather
than adding a fairly arbitrary "node_" prefix on the front.
[menage@google.com: provided changelog]
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
Cc: "Paul Menage" <menage@google.com>
Cc: "Serge E. Hallyn" <serue@us.ibm.com>
Cc: <stable@kernel.org>
If none of the switch cases match, the PR_SET_PDEATHSIG and
PR_SET_DUMPABLE cases of the switch statement will never write to local
variable `error'.
Signed-off-by: Shi Weihua <shiwh@cn.fujitsu.com>
Cc: Andrew G. Morgan <morgan@kernel.org>
Acked-by: "Serge E. Hallyn" <serue@us.ibm.com>
__exit_signal() does flush_sigqueue(tsk->pending) outside of ->siglock.
This can race with another thread doing sigqueue_free(), we can free the
same SIGQUEUE_PREALLOC sigqueue twice or corrupt the pending->list.
Note that even sys_exit_group() can trigger this race, not only
sys_timer_delete().
Move the callsite of flush_sigqueue(tsk->pending) under ->siglock.
This patch doesn't touch flush_sigqueue(->shared_pending) below, it is
called when there are no other threads which can play with signals, and
sigqueue_free() can't be used outside of our thread group.
Acked-by: Roland McGrath <roland@redhat.com>
On kvm I have seen some rare hangs in stop_machine when I used more guest
cpus than hosts cpus. e.g. 32 guest cpus on 1 host cpu triggered the
hang quite often. I could also reproduce the problem on a 4 way z/VM host with
a 64 way guest.
It turned out that the guest was consuming all available cpus mostly for
spinning on scheduler locks like rq->lock. This is expected as the threads are
calling yield all the time.
The problem is now, that the host scheduling decisings together with the guest
scheduling decisions and spinlocks not being fair managed to create an
interesting scenario similar to a live lock. (Sometimes the hang resolved
itself after some minutes)
Changing stop_machine to yield the cpu to the hypervisor when yielding inside
the guest fixed the problem for me. While I am not completely happy with this
patch, I think it causes no harm and it really improves the situation for me.
I used cpu_relax for yielding to the hypervisor, does that work on all
architectures?
p.s.: If you want to reproduce the problem, cpu hotplug and kprobes use
stop_machine_run and both triggered the problem after some retries.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
CC: Ingo Molnar <mingo@elte.hu>
kobject: '<NULL>' (ffffffffa0104050): is not initialized, yet kobject_put() is being called.
WARNING: at /home/den/src/linux-netns26/lib/kobject.c:583 kobject_put+0x53/0x55()
Modules linked in: ipv6 nfsd lockd nfs_acl auth_rpcgss sunrpc exportfs ide_cd_mod cdrom button [last unloaded: pktgen]
comm: rmmod Tainted: G W 2.6.26-rc3 #585
Call Trace:
[<ffffffff802359ab>] warn_on_slowpath+0x58/0x7a
[<ffffffff80236aca>] ? printk+0x67/0x69
[<ffffffff80324289>] kobject_put+0x53/0x55
[<ffffffff8025e2ee>] free_module+0x87/0xfa
[<ffffffff8025fee5>] sys_delete_module+0x178/0x1e1
[<ffffffff804b1e70>] ? lockdep_sys_exit_thunk+0x35/0x67
[<ffffffff804b1dff>] ? trace_hardirqs_on_thunk+0x35/0x3a
[<ffffffff8020c0bb>] system_call_after_swapgs+0x7b/0x80
---[ end trace 8f5aafa7f6406cf8 ]---
mod->mkobj.kobj is not initialized without CONFIG_SYSFS. Do not call
kobject_put in this case.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current
* 'audit.b51' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current:
[PATCH] list_for_each_rcu must die: audit
[patch 1/1] audit_send_reply(): fix error-path memory leak
[PATCH] open sessionid permissions
Removed duplicated include file <linux/rcupdate.h> in kernel/rcupreempt.c.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
Removed duplicated include file <linux/rcupdate.h> in kernel/rcupreempt_trace.c
The comment was correct -- need to make the code match the comment.
Without this patch, if a CPU goes dynticks idle (and stays there forever)
in just the right phase of preemptible-RCU grace-period processing,
grace periods stall. The offending sequence of events (courtesy
of Promela/spin, at least after I got the liveness criterion coded
correctly...) is as follows:
o CPU 0 is in dynticks-idle mode. Its dynticks_progress_counter
is (say) 10.
o CPU 0 takes an interrupt, so rcu_irq_enter() increments CPU 0's
dynticks_progress_counter to 11.
o CPU 1 is doing RCU grace-period processing in rcu_try_flip_idle(),
sees rcu_pending(), so invokes dyntick_save_progress_counter(),
which in turn takes a snapshot of CPU 0's dynticks_progress_counter
into CPU 0's rcu_dyntick_snapshot -- now set to 11. CPU 1 then
updates the RCU grace-period state to rcu_try_flip_waitack().
o CPU 0 returns from its interrupt, so rcu_irq_exit() increments
CPU 0's dynticks_progress_counter to 12.
o CPU 1 later invokes rcu_try_flip_waitack(), which notices that
CPU 0 has not yet responded, and hence in turn invokes
rcu_try_flip_waitack_needed(). This function examines the
state of CPU 0's dynticks_progress_counter and rcu_dyntick_snapshot
variables, which it copies to curr (== 12) and snap (== 11),
respectively.
Because curr!=snap, the first condition fails.
Because curr-snap is only 1 and snap is odd, the second
condition fails.
rcu_try_flip_waitack_needed() therefore incorrectly concludes
that it must wait for CPU 0 to explicitly acknowledge the
counter flip.
o CPU 0 remains forever in dynticks-idle mode, never taking
any more hardware interrupts or any NMIs, and never running
any more tasks. (Of course, -something- will usually eventually
happen, which might be why we haven't seen this one in the
wild. Still should be fixed!)
Therefore the grace period never ends. Fix is to make the code match
the comment, as shown below. With this fix, the above scenario
would be satisfied with curr being even, and allow the grace period
to proceed.
Cc: Josh Triplett <josh@kernel.org>
Cc: Dipankar Sarma <dipankar@in.ibm.com>
Move rcu-protected lists from list.h into a new header file rculist.h.
This is done because list are a very used primitive structure all over the
kernel and it's currently impossible to include other header files in this
list.h without creating some circular dependencies.
For example, list.h implements rcu-protected list and uses rcu_dereference()
without including rcupdate.h. It actually compiles because users of
rcu_dereference() are macros. Others RCU functions could be used too but
aren't probably because of this.
Therefore this patch creates rculist.h which includes rcupdates without to
many changes/troubles.
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com>
Acked-by: Josh Triplett <josh@kernel.org>
Add entry to rcu_torture_ops allowing the correct barrier function to
be used upon exit from rcutorture. Also add torture options for the
new call_rcu_sched() API.
Add rcu_barrier_sched() and rcu_barrier_bh(). With these in place,
rcutorture no longer gives the occasional oops when repeatedly starting
and stopping torturing rcu_bh. Also adds the API needed to flush out
pre-existing call_rcu_sched() callbacks.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Add comments to the logic that infers quiescent states when interrupting
from either user mode or the idle loop. Also add a memory barrier: it
appears that James Huang was in fact onto something, as the scheduler
is much less synchronization happy than it once was, so we can no longer
rely on its memory barriers in all cases.
Reported-by: James Huang <jamesclhuang@yahoo.com>
Fourth cut of patch to provide the call_rcu_sched(). This is again to
synchronize_sched() as call_rcu() is to synchronize_rcu().
Should be fine for experimental and -rt use, but not ready for inclusion.
With some luck, I will be able to tell Andrew to come out of hiding on
the next round.
Passes multi-day rcutorture sessions with concurrent CPU hotplugging.
Fixes since the first version include a bug that could result in
indefinite blocking (spotted by Gautham Shenoy), better resiliency
against CPU-hotplug operations, and other minor fixes.
Fixes since the second version include reworking grace-period detection
to avoid deadlocks that could happen when running concurrently with
CPU hotplug, adding Mathieu's fix to avoid the softlockup messages,
as well as Mathieu's fix to allow use earlier in boot.
Fixes since the third version include a wrong-CPU bug spotted by
Andrew, getting rid of the obsolete synchronize_kernel API that somehow
snuck back in, merging spin_unlock() and local_irq_restore() in a
few places, commenting the code that checks for quiescent states based
on interrupting from user-mode execution or the idle loop, removing
some inline attributes, and some code-style changes.
Known/suspected shortcomings:
o I still do not entirely trust the sleep/wakeup logic. Next step
will be to use a private snapshot of the CPU online mask in
rcu_sched_grace_period() -- if the CPU wasn't there at the start
of the grace period, we don't need to hear from it. And the
bit about accounting for changes in online CPUs inside of
rcu_sched_grace_period() is ugly anyway.
o It might be good for rcu_sched_grace_period() to invoke
resched_cpu() when a given CPU wasn't responding quickly,
but resched_cpu() is declared static...
This patch also fixes a long-standing bug in the earlier preemptable-RCU
implementation of synchronize_rcu() that could result in loss of
concurrent external changes to a task's CPU affinity mask. I still cannot
remember who reported this...
rcu_batches_completed and rcu_patches_completed_bh are both declared
in rcuclassic.h and rcupreempt.h. This patch removes the extra
prototypes for them from rcupdate.h.
rcu_batches_completed_bh is defined as a static inline in the rcupreempt.h
header file. Trying to export this as EXPORT_SYMBOL_GPL causes linking problems
with the powerpc linker. There's no need to export a static inlined function.
Modules must be compiled with the same type of RCU implementation as the
kernel they are for.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
All uses of list_for_each_rcu() can be profitably replaced by the
easier-to-use list_for_each_entry_rcu(). This patch makes this change
for the Audit system, in preparation for removing the list_for_each_rcu()
API entirely. This time with well-formed SOB.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=10663
Reporter: Daniel Marjamki <danielm77@spray.se>
Limit sysctl_nr_open - we don't want ->max_fds to exceed MAX_INT and
we don't want size calculation for ->fd[] to overflow.
Move the sucker to fs/file.c in preparation to the rest
Add a common hex array in hexdump.c so everyone can use it.
Add a common hi/lo helper to avoid the shifting masking that is
done to get the upper and lower nibbles of a byte value.
Pull the pack_hex_byte helper from kgdb as it is opencoded many
places in the tree that will be consolidated.
Acked-by: Paul Mundt <lethal@linux-sh.org>
Cc: Jason Wessel <jason.wessel@windriver.com>
Return type of cpu_rt_runtime_write() should be int instead of ssize_t.
Signed-off-by: Mirco Tischler <mt-ml@gmx.de>
Acked-by: Paul Menage <menage@google.com>
It acts exactly like a regular 'cond_resched()', but will not get
optimized away when CONFIG_PREEMPT is set.
Normal kernel code is already preemptable in the presense of
CONFIG_PREEMPT, so cond_resched() is optimized away (see commit
02b67cc3ba36bdba351d6c3a00593f4ec550d9d3 "sched: do not do
cond_resched() when CONFIG_PREEMPT").
But when wanting to conditionally reschedule while holding a lock, you
need to use "cond_sched_lock(lock)", and the new function is the BKL
equivalent of that.
Also make fs/locks.c use it.
