path: root/kernel
2007-02-09devres: device resource managementTejun Heo
Implement device resource management, in short, devres. A device driver can allocate arbirary size of devres data which is associated with a release function. On driver detach, release function is invoked on the devres data, then, devres data is freed. devreses are typed by associated release functions. Some devreses are better represented by single instance of the type while others need multiple instances sharing the same release function. Both usages are supported. devreses can be grouped using devres group such that a device driver can easily release acquired resources halfway through initialization or selectively release resources (e.g. resources for port 1 out of 4 ports). This patch adds devres core including documentation and the following managed interfaces. * alloc/free : devm_kzalloc(), devm_kzfree() * IO region : devm_request_region(), devm_release_region() * IRQ : devm_request_irq(), devm_free_irq() * DMA : dmam_alloc_coherent(), dmam_free_coherent(), dmam_declare_coherent_memory(), dmam_pool_create(), dmam_pool_destroy() * PCI : pcim_enable_device(), pcim_pin_device(), pci_is_managed() * iomap : devm_ioport_map(), devm_ioport_unmap(), devm_ioremap(), devm_ioremap_nocache(), devm_iounmap(), pcim_iomap_table(), pcim_iomap(), pcim_iounmap() Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09[APM] Add shared version of APM emulationRalf Baechle
Currently ARM and MIPS both have nearly identical copies of the APM emulation code in their arch code. Add yet another copy of it to drivers char and make it selectable through SYS_SUPPORTS_APM_EMULATION. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-07Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (41 commits) Revert "PCI: remove duplicate device id from ata_piix" msi: Make MSI useable more architectures msi: Kill the msi_desc array. msi: Remove attach_msi_entry. msi: Fix msi_remove_pci_irq_vectors. msi: Remove msi_lock. msi: Kill msi_lookup_irq MSI: Combine pci_(save|restore)_msi/msix_state MSI: Remove pci_scan_msi_device() MSI: Replace pci_msi_quirk with calls to pci_no_msi() PCI: remove duplicate device id from ipr PCI: remove duplicate device id from ata_piix PCI: power management: remove noise on non-manageable hw PCI: cleanup MSI code PCI: make isa_bridge Alpha-only PCI: remove quirk_sis_96x_compatible() PCI: Speed up the Intel SMBus unhiding quirk PCI Quirk: 1k I/O space IOBL_ADR fix on P64H2 shpchp: delete trailing whitespace shpchp: remove DBG_XXX_ROUTINE ...
2007-02-07msi: Kill the msi_desc array.Eric W. Biederman
We need to be able to get from an irq number to a struct msi_desc. The msi_desc array in msi.c had several short comings the big one was that it could not be used outside of msi.c. Using irq_data in struct irq_desc almost worked except on some architectures irq_data needs to be used for something else. So this patch adds a msi_desc pointer to irq_desc, adds the appropriate wrappers and changes all of the msi code to use them. The dynamic_irq_init/cleanup code was tweaked to ensure the new field is left in a well defined state. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07/sys/modules/*/holdersKay Sievers
/sys/module/usbcore/ |-- drivers | |-- usb:hub -> ../../../subsystem/usb/drivers/hub | |-- usb:usb -> ../../../subsystem/usb/drivers/usb | `-- usb:usbfs -> ../../../subsystem/usb/drivers/usbfs |-- holders | |-- ehci_hcd -> ../../../module/ehci_hcd | |-- uhci_hcd -> ../../../module/uhci_hcd | |-- usb_storage -> ../../../module/usb_storage | `-- usbhid -> ../../../module/usbhid |-- initstate Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07Modules: only add drivers/ direcory if neededGreg Kroah-Hartman
This changes the module core to only create the drivers/ directory if we are going to put something in it. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07MODULES: add the module name for built in kernel driversKay Sievers
2007-02-01[PATCH] fork_idle() should be __cpuinit, not __devinitAl Viro
2007-01-30[PATCH] kprobes: replace magic numbers with enumMasami Hiramatsu
Replace the magic numbers with an enum, and gets rid of a warning on the specific architectures (ex. powerpc) on which the compiler considers 'char' as 'unsigned char'. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] namespaces: fix task exit disasterSerge E. Hallyn
This is based on a patch by Eric W. Biederman, who pointed out that pid namespaces are still fake, and we only have one ever active. So for the time being, we can modify any code which could access tsk->nsproxy->pid_ns during task exit to just use &init_pid_ns instead, and move the exit_task_namespaces call in do_exit() back above exit_notify(), so that an exiting nfs server has a valid tsk->sighand to work with. Long term, pulling pid_ns out of nsproxy might be the cleanest solution. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> [ Eric's patch fixed to take care of free_pid() too ] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30Revert "[PATCH] namespaces: fix exit race by splitting exit"Linus Torvalds
This reverts commit 7a238fcba0629b6f2edbcd37458bae56fcf36be5 in preparation for a better and simpler fix proposed by Eric Biederman (and fixed up by Serge Hallyn) Acked-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] namespaces: fix exit race by splitting exitSerge E. Hallyn
Fix exit race by splitting the nsproxy putting into two pieces. First piece reduces the nsproxy refcount. If we dropped the last reference, then it puts the mnt_ns, and returns the nsproxy as a hint to the caller. Else it returns NULL. The second piece of exiting task namespaces sets tsk->nsproxy to NULL, and drops the references to other namespaces and frees the nsproxy only if an nsproxy was passed in. A little awkward and should probably be reworked, but hopefully it fixes the NFS oops. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Daniel Hokka Zakrisson <daniel@hozac.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23Clear spurious irq stat information when adding irq handlerLinus Torvalds
Any newly added irq handler may obviously make any old spurious irq status invalid, since the new handler may well be the thing that is supposed to handle any interrupts that came in. So just clear the statistics when adding handlers. Pointed-out-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23[PATCH] notifiers: fix blocking_notifier_call_chain() scalabilityIngo Molnar
while lock-profiling the -rt kernel i noticed weird contention during mmap-intense workloads, and the tracer showed the following gem, in one of our MM hotpaths: threaded-2771 1.... 65us : sys_munmap (sysenter_do_call) threaded-2771 1.... 66us : profile_munmap (sys_munmap) threaded-2771 1.... 66us : blocking_notifier_call_chain (profile_munmap) threaded-2771 1.... 66us : rt_down_read (blocking_notifier_call_chain) ouch! a global rw-semaphore taken in one of the most performance- sensitive codepaths of the kernel. And i dont even have oprofile enabled! All distro kernels have CONFIG_PROFILING enabled, so this scalability problem affects the majority of Linux users. The fix is to enhance blocking_notifier_call_chain() to only take the lock if there appears to be work on the call-chain. With this patch applied i get nicely saturated system, and much higher munmap performance, on SMP systems. And as a bonus this also fixes a similar scalability bottleneck in the thread-exit codepath: profile_task_exit() ... Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23[PATCH] fix "kvm: add vm exit profiling"Andrew Morton
export profile_hits() on !SMP too. Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11[PATCH] KVM: add VM-exit profilingIngo Molnar
This adds the profile=kvm boot option, which enables KVM to profile VM exits. Use: "readprofile -m ./System.map | sort -n" to see the resulting output: [...] 18246 serial_out 148.3415 18945 native_flush_tlb 378.9000 23618 serial_in 212.7748 29279 __spin_unlock_irq 622.9574 43447 native_apic_write 2068.9048 52702 enable_8259A_irq 742.2817 54250 vgacon_scroll 89.3740 67394 ide_inb 6126.7273 79514 copy_page_range 98.1654 84868 do_wp_page 86.6000 140266 pit_read 783.6089 151436 ide_outb 25239.3333 152668 native_io_delay 21809.7143 174783 mask_and_ack_8259A 783.7803 362404 native_set_pte_at 36240.4000 1688747 total 0.5009 Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-11[PATCH] Change cpu_up and co from __devinit to __cpuinitGautham R Shenoy
Compiling the kernel with CONFIG_HOTPLUG = y and CONFIG_HOTPLUG_CPU = n with CONFIG_RELOCATABLE = y generates the following modpost warnings WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141b7d) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141b9c) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.text:__cpu_up from .text between '_cpu_up' (at offset 0xc0141bd8) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141c05) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141c26) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141c37) and 'cpu_up' This is because cpu_up, _cpu_up and __cpu_up (in some architectures) are defined as __devinit AND __cpu_up calls some __cpuinit functions. Since __cpuinit would map to __init with this kind of a configuration, we get a .text refering .init.data warning. This patch solves the problem by converting all of __cpu_up, _cpu_up and cpu_up from __devinit to __cpuinit. The approach is justified since the callers of cpu_up are either dependent on CONFIG_HOTPLUG_CPU or are of __init type. Thus when CONFIG_HOTPLUG_CPU=y, all these cpu up functions would land up in .text section, and when CONFIG_HOTPLUG_CPU=n, all these functions would land up in .init section. Tested on a i386 SMP machine running linux-2.6.20-rc3-mm1. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-11[PATCH] sched: tasks cannot run on cpus onlined after bootNathan Lynch
Commit 5c1e176781f43bc902a51e5832f789756bff911b ("sched: force /sbin/init off isolated cpus") sets init's cpus_allowed to a subset of cpu_online_map at boot time, which means that tasks won't be scheduled on cpus that are added to the system later. Make init's cpus_allowed a subset of cpu_possible_map instead. This should still preserve the behavior that Nick's change intended. Thanks to Giuliano Pochini for reporting this and testing the fix: http://ozlabs.org/pipermail/linuxppc-dev/2006-December/029397.html Signed-off-by: Nathan Lynch <ntl@pobox.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-11[PATCH] x86-64: Make noirqdebug_setup function non init to fix modpost warningVivek Goyal
o noirqdebug_setup() is __init but it is being called by quirk_intel_irqbalance() which if of type __devinit. If CONFIG_HOTPLUG=y, quirk_intel_irqbalance() is put into text section and it is wrong to call a function in __init section. o MODPOST flags this on i386 if CONFIG_RELOCATABLE=y WARNING: vmlinux - Section mismatch: reference to .init.text:noirqdebug_setup from .text between 'quirk_intel_irqbalance' (at offset 0xc010969e) and 'i8237A_suspend' o Make noirqdebug_setup() non-init. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de>
2007-01-06Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6: [PATCH] Driver core: Fix prefix driver links in /sys/module by bus-name
2007-01-05[PATCH] profiling: fix sched profiling typoIngo Molnar
Fix sched profiling typo, introduced by the sleep profiling patch. This bug caused profile=sched to not work. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-05[PATCH] swsusp: Do not fail if resume device is not setRafael J. Wysocki
In the kernels later than 2.6.19 there is a regression that makes swsusp fail if the resume device is not explicitly specified. It can be fixed by adding an additional parameter to mm/swapfile.c:swap_type_of() allowing us to pass the (struct block_device *) corresponding to the first available swap back to the caller. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-05[PATCH] kernelparams: detect if and which parameter parsing enabled irq'sArd van Breemen
The parsing of some kernel parameters seem to enable irq's at a stage that irq's are not supposed to be enabled (Particularly the ide kernel parameters). Having irq's enabled before the irq controller is initialized might lead to a kernel panic. This patch only detects this behaviour and warns about wich parameter caused it. [akpm@osdl.org: cleanups] Signed-off-by: Ard van Breemen <ard@telegraafnet.nl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-05[PATCH] Driver core: Fix prefix driver links in /sys/module by bus-nameKay Sievers
Modules may have drivers with the same name on different buses. This patch fixes this problem. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-31[PATCH] restore ->pdeath_signal behaviourOleg Nesterov
Commit b2b2cbc4b2a2f389442549399a993a8306420baf introduced a user- visible change: ->pdeath_signal is sent only when the entire thread group exits. While this change is imho good, it may break things. So restore the old behaviour for now. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> To: Albert Cahalan <acahalan@gmail.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Andrew Morton <akpm@osdl.org> Cc: Linus Torvalds <torvalds@osdl.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Qi Yong <qiyong@fc-cn.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] lockdep: printk warning fixAndrew Morton
kernel/lockdep.c: In function `lookup_chain_cache': kernel/lockdep.c:1339: warning: long long unsigned int format, u64 arg (arg 2) kernel/lockdep.c:1344: warning: long long unsigned int format, u64 arg (arg 2) Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] cpuset procfs warning fixAndrew Morton
fs/proc/base.c:1869: warning: initialization discards qualifiers from pointer target type fs/proc/base.c:2150: warning: initialization discards qualifiers from pointer target type Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] module: fix mod_sysfs_setup() return valueAkinobu Mita
mod_sysfs_setup() doesn't return error when kobject_add_dir() failed. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] sched: fix cond_resched_softirq() offsetIngo Molnar
Remove the __resched_legal() check: it is conceptually broken. The biggest problem it had is that it can mask buggy cond_resched() calls. A cond_resched() call is only legal if we are not in an atomic context, with two narrow exceptions: - if the system is booting - a reacquire_kernel_lock() down() done while PREEMPT_ACTIVE is set But __resched_legal() hid this and just silently returned whenever these primitives were called from invalid contexts. (Same goes for cond_resched_locked() and cond_resched_softirq()). Furthermore, the __legal_resched(0) call was buggy in that it caused unnecessarily long softirq latencies via cond_resched_softirq(). (which is only called from softirq-off sections, hence the code did nothing.) The fix is to resurrect the efficiency of the might_sleep checks and to only allow the narrow exceptions. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] rcu: rcutorture suspend fixIngo Molnar
Fix suspend hang: rcutorture threads need to be nofreeze. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-23[PATCH] suspend: fix suspend on single-CPU systemsIngo Molnar
Clark Williams reported that suspend doesnt work on his laptop on 2.6.20-rc1-rt kernels. The bug was introduced by the following cleanup commit: commit 112cecb2cc0e7341db92281ba04b26c41bb8146d Author: Siddha, Suresh B <suresh.b.siddha@intel.com> Date: Wed Dec 6 20:34:31 2006 -0800 [PATCH] suspend: don't change cpus_allowed for task initiating the suspend because with this change 'error' is not initialized to 0 anymore, if there are no other online CPUs. (i.e. if the system is single-CPU). the fix is the initialize it to 0. The really weird thing is that my version of gcc does not warn about this non-initialized variable situation ... (also fix the kernel printk in the error branch, it was missing a newline) Reported-by: Clark Williams <williams@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (68 commits) ACPI: replace kmalloc+memset with kzalloc ACPI: Add support for acpi_load_table/acpi_unload_table_id fbdev: update after backlight argument change ACPI: video: Add dev argument for backlight_device_register ACPI: Implement acpi_video_get_next_level() ACPI: Kconfig - depend on PM rather than selecting it ACPI: fix NULL check in drivers/acpi/osl.c ACPI: make drivers/acpi/ec.c:ec_ecdt static ACPI: prevent processor module from loading on failures ACPI: fix single linked list manipulation ACPI: ibm_acpi: allow clean removal ACPI: fix git automerge failure ACPI: ibm_acpi: respond to workqueue update ACPI: dock: add uevent to indicate change in device status ACPI: ec: Lindent once again ACPI: ec: Change #define to enums there possible. ACPI: ec: Style changes. ACPI: ec: Acquire Global Lock under EC mutex. ACPI: ec: Drop udelay() from poll mode. Loop by reading status field instead. ACPI: ec: Rename gpe_bit to gpe ...
2006-12-22[PATCH] Fix reparenting to the same thread group. (take 2)Eric W. Biederman
This patch fixes the case when we reparent to a different thread in the same thread group. This modifies the code so that we do not send signals and do not change the signal to send to SIGCHLD unless we have change the thread group of our parents. It also suppresses sending pdeath_sig in this cas as well since the result of geppid doesn't change. Thanks to Oleg for spotting my bug of only fixing this for non-ptraced tasks. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Albert Cahalan <acahalan@gmail.com> Cc: Andrew Morton <akpm@osdl.org> Cc: Roland McGrath <roland@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Coywolf Qi Hunt <qiyong@fc-cn.com> Acked-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] relay: remove inliningAndrew Morton
text data bss dec hex filename before: 4036 44 0 4080 ff0 kernel/relay.o after: 3727 44 0 3771 ebb kernel/relay.o Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] fdtable: Provide free_fdtable() wrapperVadim Lobanov
Christoph Hellwig has expressed concerns that the recent fdtable changes expose the details of the RCU methodology used to release no-longer-used fdtable structures to the rest of the kernel. The trivial patch below addresses these concerns by introducing the appropriate free_fdtable() calls, which simply wrap the release RCU usage. Since free_fdtable() is a one-liner, it makes sense to promote it to an inline helper. Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] schedule_timeout(): improve warning messageAndrew Morton
Kyle is hitting this warning, and we don't have a clue what it's caused by. Add the obligatory dump_stack(). Cc: kyle <kylewong@southa.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] audit: fix kstrdup() error checkAkinobu Mita
kstrdup() returns NULL on error. Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] genirq: fix irq flow handler uninstallThomas Gleixner
The sanity check for no_irq_chip in __set_irq_hander() is unconditional on both install and uninstall of an handler. This triggers false warnings and replaces no_irq_chip by dummy_irq_chip in the uninstall case. Check only, when a real handler is installed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] sched: remove __cpuinitdata anotation to cpu_isolated_mapTim Chen
The structure cpu_isolated_map is used not only during initialization. Multi-core scheduler configuration changes and exclusive cpusets use this during run time. During setting of sched_mc_power_savings policy, this structure is accessed to update sched_domains. Signed-off-by: Tim Chen <tim.c.chen@intel.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] make kernel/printk.c:ignore_loglevel_setup() staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] fix kernel-doc warnings in 2.6.20-rc1Randy Dunlap
Fix kernel-doc warnings in 2.6.20-rc1. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] Conditionally check expected_preempt_count in __resched_legal()Mark Fasheh
Commit 2d7d253548cffdce80f4e03664686e9ccb1b0ed7 ("fix cond_resched() fix") introduced an 'expected_preempt_count' parameter to __resched_legal() to fix a bug where it was returning a false negative when called from cond_resched_lock() and preemption was enabled. Unfortunately this broke things for when preemption is disabled. preempt_count() will always return zero, thus failing the check against any value of expected_preempt_count not equal to zero. cond_resched_lock() for example, passes an expected_preempt_count value of 1. So fix the fix for the cond_resched() fix by skipping the check of preempt_count() against expected_preempt_count when preemption is disabled. Credit should go to Sunil Mushran for spotting the bug during testing. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-21[PATCH] workqueue: fix schedule_on_each_cpu()Ingo Molnar
fix the schedule_on_each_cpu() implementation: __queue_work() is now stricter, hence set the work-pending bit before passing in the new work. (found in the -rt tree, using Peter Zijlstra's files-lock scalability patchset) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-21[PATCH] sched: improve efficiency of sched_fork()Peter Williams
Problem: sched_fork() has always called scheduler_tick() in some (unlikely) circumstances in order to update the current task in light of those circumstances. It has always been the case that the work done by scheduler_tick() was more than was required to handle the problem in hand but no harm was done except for the waste of a few CPU cycles. However, the splitting of scheduler_tick() into two procedures in 2.6.20-rc1 enables the wasted cycles to be saved as the new procedure task_running_tick() does all the work that is required to rectify the problem being handled. Solution: Replace the call to scheduler_tick() in sched_fork() with a call to task_running_tick(). Signed-off-by: Peter Williams <pwil3058@bigpond.com.au> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-21[PATCH] __set_irq_handler bogus spaceGeert Uytterhoeven
__set_irq_handler: Kill a bogus space Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-20merge linus into test branchLen Brown
2006-12-16Make workqueue bit operations work on "atomic_long_t"Linus Torvalds
On architectures where the atomicity of the bit operations is handled by external means (ie a separate spinlock to protect concurrent accesses), just doing a direct assignment on the workqueue data field (as done by commit 4594bf159f1962cec3b727954b7c598b07e2e737) can cause the assignment to be lost due to lack of serialization with the bitops on the same word. So we need to serialize the assignment with the locks on those architectures (notably older ARM chips, PA-RISC and sparc32). So rather than using an "unsigned long", let's use "atomic_long_t", which already has a safe assignment operation (atomic_long_set()) on such architectures. This requires that the atomic operations use the same atomicity locks as the bit operations do, but that is largely the case anyway. Sparc32 will probably need fixing. Architectures (including modern ARM with LL/SC) that implement sane atomic operations for SMP won't see any of this matter. Cc: Russell King <rmk+lkml@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: David Miller <davem@davemloft.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Linux Arch Maintainers <linux-arch@vger.kernel.org> Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-16Pull bugfix into test branchLen Brown
Conflicts: kernel/power/disk.c
2006-12-15Remove stack unwinder for nowLinus Torvalds
It has caused more problems than it ever really solved, and is apparently not getting cleaned up and fixed. We can put it back when it's stable and isn't likely to make warning or bug events worse. In the meantime, enable frame pointers for more readable stack traces. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13Driver core: deprecate PM_LEGACY, default it to NDavid Brownell
Deprecate the old "legacy" PM API, and more importantly default it to "n". Virtually nothing in-tree uses it any more. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
