Pull first round of SCSI updates from James Bottomley:
"The most important feature of this patch set is the new async
infrastructure that makes sure async_synchronize_full() synchronizes
all domains and allows us to remove all the hacks (like having
scsi_complete_async_scans() in the device base code) and means that
the async infrastructure will "just work" in future.
The rest is assorted driver updates (aacraid, bnx2fc, virto-scsi,
megaraid, bfa, lpfc, qla2xxx, qla4xxx) plus a lot of infrastructure
work in sas and FC.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (97 commits)
[SCSI] Revert "[SCSI] fix async probe regression"
[SCSI] cleanup usages of scsi_complete_async_scans
[SCSI] queue async scan work to an async_schedule domain
[SCSI] async: make async_synchronize_full() flush all work regardless of domain
[SCSI] async: introduce 'async_domain' type
[SCSI] bfa: Fix to set correct return error codes and misc cleanup.
[SCSI] aacraid: Series 7 Async. (performance) mode support
[SCSI] aha152x: Allow use on 64bit systems
[SCSI] virtio-scsi: Add vdrv->scan for post VIRTIO_CONFIG_S_DRIVER_OK LUN scanning
[SCSI] bfa: squelch lockdep complaint with a spin_lock_init
[SCSI] qla2xxx: remove unnecessary reads of PCI_CAP_ID_EXP
[SCSI] qla4xxx: remove unnecessary read of PCI_CAP_ID_EXP
[SCSI] ufs: fix incorrect return value about SUCCESS and FAILED
[SCSI] ufs: reverse the ufshcd_is_device_present logic
[SCSI] ufs: use module_pci_driver
[SCSI] usb-storage: update usb devices for write cache quirk in quirk list.
[SCSI] usb-storage: add support for write cache quirk
[SCSI] set to WCE if usb cache quirk is present.
[SCSI] virtio-scsi: hotplug support for virtio-scsi
[SCSI] virtio-scsi: split scatterlist per target
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup changes from Tejun Heo:
"Nothing too interesting. A minor bug fix and some cleanups."
* 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: Update remount documentation
cgroup: cgroup_rm_files() was calling simple_unlink() with the wrong inode
cgroup: Remove populate() documentation
cgroup: remove hierarchy_mutex
Pull workqueue changes from Tejun Heo:
"There are three major changes.
- WQ_HIGHPRI has been reimplemented so that high priority work items
are served by worker threads with -20 nice value from dedicated
highpri worker pools.
- CPU hotplug support has been reimplemented such that idle workers
are kept across CPU hotplug events. This makes CPU hotplug cheaper
(for PM) and makes the code simpler.
- flush_kthread_work() has been reimplemented so that a work item can
be freed while executing. This removes an annoying behavior
difference between kthread_worker and workqueue."
* 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: fix spurious CPU locality WARN from process_one_work()
kthread_worker: reimplement flush_kthread_work() to allow freeing the work item being executed
kthread_worker: reorganize to prepare for flush_kthread_work() reimplementation
workqueue: simplify CPU hotplug code
workqueue: remove CPU offline trustee
workqueue: don't butcher idle workers on an offline CPU
workqueue: reimplement CPU online rebinding to handle idle workers
workqueue: drop @bind from create_worker()
workqueue: use mutex for global_cwq manager exclusion
workqueue: ROGUE workers are UNBOUND workers
workqueue: drop CPU_DYING notifier operation
workqueue: perform cpu down operations from low priority cpu_notifier()
workqueue: reimplement WQ_HIGHPRI using a separate worker_pool
workqueue: introduce NR_WORKER_POOLS and for_each_worker_pool()
workqueue: separate out worker_pool flags
workqueue: use @pool instead of @gcwq or @cpu where applicable
workqueue: factor out worker_pool from global_cwq
workqueue: don't use WQ_HIGHPRI for unbound workqueues
Pull PCI changes from Bjorn Helgaas:
"Host bridge hotplug:
- Add MMCONFIG support for hot-added host bridges (Jiang Liu)
Device hotplug:
- Move fixups from __init to __devinit (Sebastian Andrzej Siewior)
- Call FINAL fixups for hot-added devices, too (Myron Stowe)
- Factor out generic code for P2P bridge hot-add (Yinghai Lu)
- Remove all functions in a slot, not just those with _EJx (Amos
Kong)
Dynamic resource management:
- Track bus number allocation (struct resource tree per domain)
(Yinghai Lu)
- Make P2P bridge 1K I/O windows work with resource reassignment
(Bjorn Helgaas, Yinghai Lu)
- Disable decoding while updating 64-bit BARs (Bjorn Helgaas)
Power management:
- Add PCIe runtime D3cold support (Huang Ying)
Virtualization:
- Add VFIO infrastructure (ACS, DMA source ID quirks) (Alex
Williamson)
- Add quirks for devices with broken INTx masking (Jan Kiszka)
Miscellaneous:
- Fix some PCI Express capability version issues (Myron Stowe)
- Factor out some arch code with a weak, generic, pcibios_setup()
(Myron Stowe)"
* tag 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (122 commits)
PCI: hotplug: ensure a consistent return value in error case
PCI: fix undefined reference to 'pci_fixup_final_inited'
PCI: build resource code for M68K architecture
PCI: pciehp: remove unused pciehp_get_max_lnk_width(), pciehp_get_cur_lnk_width()
PCI: reorder __pci_assign_resource() (no change)
PCI: fix truncation of resource size to 32 bits
PCI: acpiphp: merge acpiphp_debug and debug
PCI: acpiphp: remove unused res_lock
sparc/PCI: replace pci_cfg_fake_ranges() with pci_read_bridge_bases()
PCI: call final fixups hot-added devices
PCI: move final fixups from __init to __devinit
x86/PCI: move final fixups from __init to __devinit
MIPS/PCI: move final fixups from __init to __devinit
PCI: support sizing P2P bridge I/O windows with 1K granularity
PCI: reimplement P2P bridge 1K I/O windows (Intel P64H2)
PCI: disable MEM decoding while updating 64-bit MEM BARs
PCI: leave MEM and IO decoding disabled during 64-bit BAR sizing, too
PCI: never discard enable/suspend/resume_early/resume fixups
PCI: release temporary reference in __nv_msi_ht_cap_quirk()
PCI: restructure 'pci_do_fixups()'
Pull devicetree updates from Rob Herring:
"A small set of changes for devicetree:
- Couple of Documentation fixes
- Addition of new helper function of_node_full_name
- Improve of_parse_phandle_with_args return values
- Some NULL related sparse fixes"
Grant's busy packing.
* tag 'dt-for-3.6' of git://sources.calxeda.com/kernel/linux:
of: mtd: nuke useless const qualifier
devicetree: add helper inline for retrieving a node's full name
of: return -ENOENT when no property
usage-model.txt: fix typo machine_init->init_machine
of: Fix null pointer related warnings in base.c file
LED: Fix missing semicolon in OF documentation
of: fix a few typos in the binding documentation
Pull networking changes from David S Miller:
1) Remove the ipv4 routing cache. Now lookups go directly into the FIB
trie and use prebuilt routes cached there.
No more garbage collection, no more rDOS attacks on the routing
cache. Instead we now get predictable and consistent performance,
no matter what the pattern of traffic we service.
This has been almost 2 years in the making. Special thanks to
Julian Anastasov, Eric Dumazet, Steffen Klassert, and others who
have helped along the way.
I'm sure that with a change of this magnitude there will be some
kind of fallout, but such things ought the be simple to fix at this
point. Luckily I'm not European so I'll be around all of August to
fix things :-)
The major stages of this work here are each fronted by a forced
merge commit whose commit message contains a top-level description
of the motivations and implementation issues.
2) Pre-demux of established ipv4 TCP sockets, saves a route demux on
input.
3) TCP SYN/ACK performance tweaks from Eric Dumazet.
4) Add namespace support for netfilter L4 conntrack helpers, from Gao
Feng.
5) Add config mechanism for Energy Efficient Ethernet to ethtool, from
Yuval Mintz.
6) Remove quadratic behavior from /proc/net/unix, from Eric Dumazet.
7) Support for connection tracker helpers in userspace, from Pablo
Neira Ayuso.
8) Allow userspace driven TX load balancing functions in TEAM driver,
from Jiri Pirko.
9) Kill off NLMSG_PUT and RTA_PUT macros, more gross stuff with
embedded gotos.
10) TCP Small Queues, essentially minimize the amount of TCP data queued
up in the packet scheduler layer. Whereas the existing BQL (Byte
Queue Limits) limits the pkt_sched --> netdevice queuing levels,
this controls the TCP --> pkt_sched queueing levels.
From Eric Dumazet.
11) Reduce the number of get_page/put_page ops done on SKB fragments,
from Alexander Duyck.
12) Implement protection against blind resets in TCP (RFC 5961), from
Eric Dumazet.
13) Support the client side of TCP Fast Open, basically the ability to
send data in the SYN exchange, from Yuchung Cheng.
Basically, the sender queues up data with a sendmsg() call using
MSG_FASTOPEN, then they do the connect() which emits the queued up
fastopen data.
14) Avoid all the problems we get into in TCP when timers or PMTU events
hit a locked socket. The TCP Small Queues changes added a
tcp_release_cb() that allows us to queue work up to the
release_sock() caller, and that's what we use here too. From Eric
Dumazet.
15) Zero copy on TX support for TUN driver, from Michael S. Tsirkin.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1870 commits)
genetlink: define lockdep_genl_is_held() when CONFIG_LOCKDEP
r8169: revert "add byte queue limit support".
ipv4: Change rt->rt_iif encoding.
net: Make skb->skb_iif always track skb->dev
ipv4: Prepare for change of rt->rt_iif encoding.
ipv4: Remove all RTCF_DIRECTSRC handliing.
ipv4: Really ignore ICMP address requests/replies.
decnet: Don't set RTCF_DIRECTSRC.
net/ipv4/ip_vti.c: Fix __rcu warnings detected by sparse.
ipv4: Remove redundant assignment
rds: set correct msg_namelen
openvswitch: potential NULL deref in sample()
tcp: dont drop MTU reduction indications
bnx2x: Add new 57840 device IDs
tcp: avoid oops in tcp_metrics and reset tcpm_stamp
niu: Change niu_rbr_fill() to use unlikely() to check niu_rbr_add_page() return value
niu: Fix to check for dma mapping errors.
net: Fix references to out-of-scope variables in put_cmsg_compat()
net: ethernet: davinci_emac: add pm_runtime support
net: ethernet: davinci_emac: Remove unnecessary #include
Pull the big VFS changes from Al Viro:
"This one is *big* and changes quite a few things around VFS. What's in there:
- the first of two really major architecture changes - death to open
intents.
The former is finally there; it was very long in making, but with
Miklos getting through really hard and messy final push in
fs/namei.c, we finally have it. Unlike his variant, this one
doesn't introduce struct opendata; what we have instead is
->atomic_open() taking preallocated struct file * and passing
everything via its fields.
Instead of returning struct file *, it returns -E... on error, 0
on success and 1 in "deal with it yourself" case (e.g. symlink
found on server, etc.).
See comments before fs/namei.c:atomic_open(). That made a lot of
goodies finally possible and quite a few are in that pile:
->lookup(), ->d_revalidate() and ->create() do not get struct
nameidata * anymore; ->lookup() and ->d_revalidate() get lookup
flags instead, ->create() gets "do we want it exclusive" flag.
With the introduction of new helper (kern_path_locked()) we are rid
of all struct nameidata instances outside of fs/namei.c; it's still
visible in namei.h, but not for long. Come the next cycle,
declaration will move either to fs/internal.h or to fs/namei.c
itself. [me, miklos, hch]
- The second major change: behaviour of final fput(). Now we have
__fput() done without any locks held by caller *and* not from deep
in call stack.
That obviously lifts a lot of constraints on the locking in there.
Moreover, it's legal now to call fput() from atomic contexts (which
has immediately simplified life for aio.c). We also don't need
anti-recursion logics in __scm_destroy() anymore.
There is a price, though - the damn thing has become partially
asynchronous. For fput() from normal process we are guaranteed
that pending __fput() will be done before the caller returns to
userland, exits or gets stopped for ptrace.
For kernel threads and atomic contexts it's done via
schedule_work(), so theoretically we might need a way to make sure
it's finished; so far only one such place had been found, but there
might be more.
There's flush_delayed_fput() (do all pending __fput()) and there's
__fput_sync() (fput() analog doing __fput() immediately). I hope
we won't need them often; see warnings in fs/file_table.c for
details. [me, based on task_work series from Oleg merged last
cycle]
- sync series from Jan
- large part of "death to sync_supers()" work from Artem; the only
bits missing here are exofs and ext4 ones. As far as I understand,
those are going via the exofs and ext4 trees resp.; once they are
in, we can put ->write_super() to the rest, along with the thread
calling it.
- preparatory bits from unionmount series (from dhowells).
- assorted cleanups and fixes all over the place, as usual.
This is not the last pile for this cycle; there's at least jlayton's
ESTALE work and fsfreeze series (the latter - in dire need of fixes,
so I'm not sure it'll make the cut this cycle). I'll probably throw
symlink/hardlink restrictions stuff from Kees into the next pile, too.
Plus there's a lot of misc patches I hadn't thrown into that one -
it's large enough as it is..."
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (127 commits)
ext4: switch EXT4_IOC_RESIZE_FS to mnt_want_write_file()
btrfs: switch btrfs_ioctl_balance() to mnt_want_write_file()
switch dentry_open() to struct path, make it grab references itself
spufs: shift dget/mntget towards dentry_open()
zoran: don't bother with struct file * in zoran_map
ecryptfs: don't reinvent the wheels, please - use struct completion
don't expose I_NEW inodes via dentry->d_inode
tidy up namei.c a bit
unobfuscate follow_up() a bit
ext3: pass custom EOF to generic_file_llseek_size()
ext4: use core vfs llseek code for dir seeks
vfs: allow custom EOF in generic_file_llseek code
vfs: Avoid unnecessary WB_SYNC_NONE writeback during sys_sync and reorder sync passes
vfs: Remove unnecessary flushing of block devices
vfs: Make sys_sync writeout also block device inodes
vfs: Create function for iterating over block devices
vfs: Reorder operations during sys_sync
quota: Move quota syncing to ->sync_fs method
quota: Split dquot_quota_sync() to writeback and cache flushing part
vfs: Move noop_backing_dev_info check from sync into writeback
Pull power management updates from Rafael Wysocki:
- ACPI conversion to PM handling based on struct dev_pm_ops.
- Conversion of a number of platform drivers to PM handling based on
struct dev_pm_ops and removal of empty legacy PM callbacks from a
couple of PCI drivers.
- Suspend-to-both for in-kernel hibernation from Bojan Smojver.
- cpuidle fixes and cleanups from ShuoX Liu, Daniel Lezcano and Preeti
Murthy.
- cpufreq bug fixes from Jonghwa Lee and Stephen Boyd.
- Suspend and hibernate fixes from Srivatsa Bhat and Colin Cross.
- Generic PM domains framework updates.
- RTC CMOS wakeup signaling update from Paul Fox.
- sparse warnings fixes from Sachin Kamat.
- Build warnings fixes for the generic PM domains framework and PM
sysfs code.
- sysfs switch for printing device suspend times from Sameer Nanda.
- Documentation fix from Oskar Schirmer.
* tag 'pm-for-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (70 commits)
cpufreq: Fix sysfs deadlock with concurrent hotplug/frequency switch
EXYNOS: bugfix on retrieving old_index from freqs.old
PM / Sleep: call early resume handlers when suspend_noirq fails
PM / QoS: Use NULL pointer instead of plain integer in qos.c
PM / QoS: Use NULL pointer instead of plain integer in pm_qos.h
PM / Sleep: Require CAP_BLOCK_SUSPEND to use wake_lock/wake_unlock
PM / Sleep: Add missing static storage class specifiers in main.c
cpuilde / ACPI: remove time from acpi_processor_cx structure
cpuidle / ACPI: remove usage from acpi_processor_cx structure
cpuidle / ACPI : remove latency_ticks from acpi_processor_cx structure
rtc-cmos: report wakeups from interrupt handler
PM / Sleep: Fix build warning in sysfs.c for CONFIG_PM_SLEEP unset
PM / Domains: Fix build warning for CONFIG_PM_RUNTIME unset
olpc-xo15-sci: Use struct dev_pm_ops for power management
PM / Domains: Replace plain integer with NULL pointer in domain.c file
PM / Domains: Add missing static storage class specifier in domain.c file
PM / crypto / ux500: Use struct dev_pm_ops for power management
PM / IPMI: Remove empty legacy PCI PM callbacks
tpm_nsc: Use struct dev_pm_ops for power management
tpm_tis: Use struct dev_pm_ops for power management
It doesn't matter on normal return to userland path (we'll recheck the
NOTIFY_RESUME flag anyway), but in case of exit_task_work() we'll
need that as soon as we get callbacks capable of triggering more
task_work_add().
... and get rid of PF_EXITING check in task_work_add().
task_work and rcu_head are identical now; merge them (calling the result
struct callback_head, rcu_head #define'd to it), kill separate allocation
in security/keys since we can just use cred->rcu now.
layout based on Oleg's suggestion; single-linked list,
task->task_works points to the last element, forward pointer
from said last element points to head. I'd still prefer
much more regular scheme with two pointers in task_work,
but...
get rid of the only user of ->data; this is _not_ the final variant - in the
end we'll have task_work and rcu_head identical and just use cred->rcu,
at which point the separate allocation will be gone completely.
Pull timer core changes from Ingo Molnar:
"Continued cleanups of the core time and NTP code, plus more nohz work
preparing for tick-less userspace execution."
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
time: Rework timekeeping functions to take timekeeper ptr as argument
time: Move xtime_nsec adjustment underflow handling timekeeping_adjust
time: Move arch_gettimeoffset() usage into timekeeping_get_ns()
time: Refactor accumulation of nsecs to secs
time: Condense timekeeper.xtime into xtime_sec
time: Explicitly use u32 instead of int for shift values
time: Whitespace cleanups per Ingo%27s requests
nohz: Move next idle expiry time record into idle logic area
nohz: Move ts->idle_calls incrementation into strict idle logic
nohz: Rename ts->idle_tick to ts->last_tick
nohz: Make nohz API agnostic against idle ticks cputime accounting
nohz: Separate idle sleeping time accounting from nohz logic
timers: Improve get_next_timer_interrupt()
timers: Add accounting of non deferrable timers
timers: Consolidate base->next_timer update
timers: Create detach_if_pending() and use it
Pull smp/hotplug changes from Ingo Molnar:
"Various cleanups to the SMP hotplug code - a continuing effort of
Thomas et al"
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
smpboot: Remove leftover declaration
smp: Remove num_booting_cpus()
smp: Remove ipi_call_lock[_irq]()/ipi_call_unlock[_irq]()
POWERPC: Smp: remove call to ipi_call_lock()/ipi_call_unlock()
SPARC: SMP: Remove call to ipi_call_lock_irq()/ipi_call_unlock_irq()
ia64: SMP: Remove call to ipi_call_lock_irq()/ipi_call_unlock_irq()
x86-smp-remove-call-to-ipi_call_lock-ipi_call_unlock
tile: SMP: Remove call to ipi_call_lock()/ipi_call_unlock()
S390: Smp: remove call to ipi_call_lock()/ipi_call_unlock()
parisc: Smp: remove call to ipi_call_lock()/ipi_call_unlock()
mn10300: SMP: Remove call to ipi_call_lock()/ipi_call_unlock()
hexagon: SMP: Remove call to ipi_call_lock()/ipi_call_unlock()
Pull perf events changes from Ingo Molnar:
"- kernel side:
- Intel uncore PMU support for Nehalem and Sandy Bridge CPUs, we
support both the events available via the MSR and via the PCI
access space.
- various uprobes cleanups and restructurings
- PMU driver quirks by microcode version and required x86 microcode
loader cleanups/robustization
- various tracing robustness updates
- static keys: remove obsolete static_branch()
- tooling side:
- GTK browser improvements
- perf report browser: support screenshots to file
- more automated tests
- perf kvm improvements
- perf bench refinements
- build environment improvements
- pipe mode improvements
- libtraceevent updates, we have now hopefully merged most bits with
the out of tree forked code base
... and many other goodies."
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (138 commits)
tracing: Check for allocation failure in __tracing_open()
perf/x86: Fix intel_perfmon_event_mapformatting
jump label: Remove static_branch()
tracepoint: Use static_key_false(), since static_branch() is deprecated
perf/x86: Uncore filter support for SandyBridge-EP
perf/x86: Detect number of instances of uncore CBox
perf/x86: Fix event constraint for SandyBridge-EP C-Box
perf/x86: Use 0xff as pseudo code for fixed uncore event
perf/x86: Save a few bytes in 'struct x86_pmu'
perf/x86: Add a microcode revision check for SNB-PEBS
perf/x86: Improve debug output in check_hw_exists()
perf/x86/amd: Unify AMD's generic and family 15h pmus
perf/x86: Move Intel specific code to intel_pmu_init()
perf/x86: Rename Intel specific macros
perf/x86: Fix USER/KERNEL tagging of samples
perf tools: Split event symbols arrays to hw and sw parts
perf tools: Split out PE_VALUE_SYM parsing token to SW and HW tokens
perf tools: Add empty rule for new line in event syntax parsing
perf test: Use ARRAY_SIZE in parse events tests
tools lib traceevent: Cleanup realloc use
Pull RCU changes from Ingo Molnar:
"Quoting from Paul, the major features of this series are:
1. Preventing latency spikes of more than 200 microseconds for
kernels built with NR_CPUS=4096, which is reportedly becoming the
default for some distros. This is a first step, as it does not
help with systems that actually -have- 4096 CPUs (work on this case
is in progress, but is not yet ready for mainline).
This category also includes improving concurrency of rcu_barrier(),
placed here due to conflicts. Posted to LKML at:
https://lkml.org/lkml/2012/6/22/381
Note that patches 18-22 of that series have been defered to 3.7, as
they have not yet proven themselves to be mainline-ready (and yes,
these are the ones intended to get rid of RCU's latency spikes for
systems that actually have 4096 CPUs).
2. Updates to documentation and rcutorture fixes, the latter category
including improvements to rcu_barrier() testing. Posted to LKML at
http://lkml.indiana.edu/hypermail/linux/kernel/1206.1/04094.html.
3. Miscellaneous fixes posted to LKML at:
https://lkml.org/lkml/2012/6/22/500
with the exception of the last commit, which was posted here:
http://www.gossamer-threads.com/lists/linux/kernel/1561830
4. RCU_FAST_NO_HZ fixes and improvements. Posted to LKML at:
http://lkml.indiana.edu/hypermail/linux/kernel/1206.1/00006.html
http://www.gossamer-threads.com/lists/linux/kernel/1561833
The first four patches of the first series went into 3.5 to fix a
regression.
5. Code-style fixes. These were posted to LKML at
http://lkml.indiana.edu/hypermail/linux/kernel/1205.2/01180.html
http://lkml.indiana.edu/hypermail/linux/kernel/1205.2/01181.html"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (48 commits)
rcu: Fix broken strings in RCU's source code.
rcu: Fix code-style issues involving "else"
rcu: Introduce check for callback list/count mismatch
rcu: Make RCU_FAST_NO_HZ respect nohz= boot parameter
rcu: Fix qlen_lazy breakage
rcu: Round FAST_NO_HZ lazy timeout to nearest second
rcu: The rcu_needs_cpu() function is not a quiescent state
rcu: Dump only the current CPU's buffers for idle-entry/exit warnings
rcu: Add check for CPUs going offline with callbacks queued
rcu: Disable preemption in rcu_blocking_is_gp()
rcu: Prevent uninitialized string in RCU CPU stall info
rcu: Fix rcu_is_cpu_idle() #ifdef in TINY_RCU
rcu: Split RCU core processing out of __call_rcu()
rcu: Prevent __call_rcu() from invoking RCU core on offline CPUs
rcu: Make __call_rcu() handle invocation from idle
rcu: Remove function versions of __kfree_rcu and __is_kfree_rcu_offset
rcu: Consolidate tree/tiny __rcu_read_{,un}lock() implementations
rcu: Remove return value from rcu_assign_pointer()
key: Remove extraneous parentheses from rcu_assign_keypointer()
rcu: Remove return value from RCU_INIT_POINTER()
25511a4776 "workqueue: reimplement CPU online rebinding to handle idle
workers" added CPU locality sanity check in process_one_work(). It
triggers if a worker is executing on a different CPU without UNBOUND
or REBIND set.
This works for all normal workers but rescuers can trigger this
spuriously when they're serving the unbound or a disassociated
global_cwq - rescuers don't have either flag set and thus its
gcwq->cpu can be a different value including %WORK_CPU_UNBOUND.
Fix it by additionally testing %GCWQ_DISASSOCIATED.
Reported-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
LKML-Refence: <20120721213656.GA7783@linux.vnet.ibm.com>
item being executed
kthread_worker provides minimalistic workqueue-like interface for
users which need a dedicated worker thread (e.g. for realtime
priority). It has basic queue, flush_work, flush_worker operations
which mostly match the workqueue counterparts; however, due to the way
flush_work() is implemented, it has a noticeable difference of not
allowing work items to be freed while being executed.
While the current users of kthread_worker are okay with the current
behavior, the restriction does impede some valid use cases. Also,
removing this difference isn't difficult and actually makes the code
easier to understand.
This patch reimplements flush_kthread_work() such that it uses a
flush_work item instead of queue/done sequence numbers.
Make the following two non-functional changes.
* Separate out insert_kthread_work() from queue_kthread_work().
* Relocate struct kthread_flush_work and kthread_flush_work_fn()
definitions above flush_kthread_work().
v2: Added lockdep_assert_held() in insert_kthread_work() as suggested
by Andy Walls.
Acked-by: Andy Walls <awalls@md.metrocast.net>
Merge emailed kgdb dmesg fixups patches from Anton Vorontsov:
"The dmesg command appears to be broken after the printk rework. The
old logic in the kdb code makes no sense in terms of current
printk/logging storage format, and KDB simply hangs forever upon
entering 'dmesg' command.
The first patch revives the command by switching to kmsg_dumper
iterator. As a side-effect, the code is now much more simpler.
A few changes were needed in the printk.c: we needed unlocked variant
of the kmsg_dumper iterator, but these can surely wait for 3.6.
It's probably too late even for the first patch to go to 3.5, but I'll
try to convince otherwise. :-) Here we go:
- The current code is broken for sure, and has no hope to work at
all. It is a regression
- The new code works for me, and probably works for everyone else;
- If it compiles (and I urge everyone to compile-test it on your
setup), it hardly can make things worse."
* Merge emailed patches from Anton Vorontsov: (4 commits)
kdb: Switch to nolock variants of kmsg_dump functions
printk: Implement some unlocked kmsg_dump functions
printk: Remove kdb_syslog_data
kdb: Revive dmesg command
The locked variants are prone to deadlocks (suppose we got to the
debugger w/ the logbuf lock held), so let's switch to nolock variants.
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
If used from KDB, the locked variants are prone to deadlocks (suppose we
got to the debugger w/ the logbuf lock held).
So, we have to implement a few routines that grab no logbuf lock.
Yet we don't need these functions in modules, so we don't export them.
The function is no longer needed, so remove it.
The kgdb dmesg command is broken after the printk rework. The old logic
in kdb code makes no sense in terms of current printk/logging storage
format, and KDB simply hangs forever.
This patch revives the command by switching to kmsg_dumper iterator.
The code is now much more simpler and shorter.
In response to an async related regression James noted:
"My theory is that this is an init problem: The assumption in a lot of
our code is that async_synchronize_full() waits for everything ... even
the domain specific async schedules, which isn't true."
...so make this assumption true.
Each domain, including the default one, registers itself on a global domain
list when work is scheduled. Once all entries complete it exits that
list. Waiting for the list to be empty syncs all in-flight work across
all domains.
Domains can opt-out of global syncing if they are declared as exclusive
ASYNC_DOMAIN_EXCLUSIVE(). All stack-based domains have been declared
exclusive since the domain may go out of scope as soon as the last work
item completes.
Statically declared domains are mostly ok, but async_unregister_domain()
is there to close any theoretical races with pending
async_synchronize_full waiters at module removal time.
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Reported-by: Meelis Roos <mroos@linux.ee>
Reported-by: Eldad Zack <eldadzack@gmail.com>
Tested-by: Eldad Zack <eldad@fogrefinery.com>
This is in preparation for teaching async_synchronize_full() to sync all
pending async work, and not just on the async_running domain. This
conversion is functionally equivalent, just embedding the existing list
in a new async_domain type.
The .registered attribute is used in a later patch to distinguish
between domains that want to be flushed by async_synchronize_full()
versus those that only expect async_synchronize_{full|cookie}_domain to
be used for flushing.
[jejb: add async.h to scsi_priv.h for struct async_domain]
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
drivers/net/ethernet/intel/ixgbevf/ixgbevf_main.c
Commit a7a20d103994 ("sd: limit the scope of the async probe domain")
make the SCSI device probing run device discovery in it's own async
domain.
However, as a result, the partition detection was no longer synchronized
by async_synchronize_full() (which, despite the name, only synchronizes
the global async space, not all of them). Which in turn meant that
"wait_for_device_probe()" would not wait for the SCSI partitions to be
parsed.
And "wait_for_device_probe()" was what the boot time init code relied on
for mounting the root filesystem.
Now, most people never noticed this, because not only is it
timing-dependent, but modern distributions all use initrd. So the root
filesystem isn't actually on a disk at all. And then before they
actually mount the final disk filesystem, they will have loaded the
scsi-wait-scan module, which not only does the expected
wait_for_device_probe(), but also does scsi_complete_async_scans().
[ Side note: scsi_complete_async_scans() had also been partially broken,
but that was fixed in commit 43a8d39d0137 ("fix async probe
regression"), so that same commit a7a20d103994 had actually broken
setups even if you used scsi-wait-scan explicitly ]
Solve this problem by just moving the scsi_complete_async_scans() call
into wait_for_device_probe(). Everybody who wants to wait for device
probing to finish really wants the SCSI probing to complete, so there's
no reason not to do this.
So now "wait_for_device_probe()" really does what the name implies, and
properly waits for device probing to finish. This also removes the now
unnecessary extra calls to scsi_complete_async_scans().
Reported-and-tested-by: Artem S. Tashkinov <t.artem@mailcity.com>
Cc: Dan Williams <dan.j.williams@gmail.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: James Bottomley <jbottomley@parallels.com>
Cc: Borislav Petkov <bp@amd64.org>
Cc: linux-scsi <linux-scsi@vger.kernel.org>
Require processes wanting to use the wake_lock/wake_unlock sysfs
files to have the CAP_BLOCK_SUSPEND capability, which also is
required for the eventpoll EPOLLWAKEUP flag to be effective, so that
all interfaces related to blocking autosleep depend on the same
capability.
Cc: stable@vger.kernel.org
Acked-by: Michael Kerrisk <mtk.man-pages@gmail.com>
The 'fixes' branch contains material the next commit depends on.
One more time/ntp fix pulled from Ingo Molnar.
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
ntp: Fix STA_INS/DEL clearing bug
Resolve semantic conflict in kernel/time/timekeeping.c.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/core
Pull tracing fix from Steve Rostedt.
Pick up the latest ring-buffer fixes, before applying a new fix.
With trustee gone, CPU hotplug code can be simplified.
* gcwq_claim/release_management() now grab and release gcwq lock too
respectively and gained _and_lock and _and_unlock postfixes.
* All CPU hotplug logic was implemented in workqueue_cpu_callback()
which was called by workqueue_cpu_up/down_callback() for the correct
priority. This was because up and down paths shared a lot of logic,
which is no longer true. Remove workqueue_cpu_callback() and move
all hotplug logic into the two actual callbacks.
This patch doesn't make any functional changes.
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
With the previous changes, a disassociated global_cwq now can run as
an unbound one on its own - it can create workers as necessary to
drain remaining works after the CPU has been brought down and manage
the number of workers using the usual idle timer mechanism making
trustee completely redundant except for the actual unbinding
operation.
This patch removes the trustee and let a disassociated global_cwq
manage itself. Unbinding is moved to a work item (for CPU affinity)
which is scheduled and flushed from CPU_DONW_PREPARE.
This patch moves nr_running clearing outside gcwq and manager locks to
simplify the code. As nr_running is unused at the point, this is
safe.
Currently, during CPU offlining, after all pending work items are
drained, the trustee butchers all workers. Also, on CPU onlining
failure, workqueue_cpu_callback() ensures that the first idle worker
is destroyed. Combined, these guarantee that an offline CPU doesn't
have any worker for it once all the lingering work items are finished.
This guarantee isn't really necessary and makes CPU on/offlining more
expensive than needs to be, especially for platforms which use CPU
hotplug for powersaving.
This patch lets offline CPUs removes idle worker butchering from the
trustee and let a CPU which failed onlining keep the created first
worker. The first worker is created if the CPU doesn't have any
during CPU_DOWN_PREPARE and started right away. If onlining succeeds,
the rebind_workers() call in CPU_ONLINE will rebind it like any other
workers. If onlining fails, the worker is left alone till the next
try.
This makes CPU hotplugs cheaper by allowing global_cwqs to keep
workers across them and simplifies code.
Note that trustee doesn't re-arm idle timer when it's done and thus
the disassociated global_cwq will keep all workers until it comes back
online. This will be improved by further patches.
Currently, if there are left workers when a CPU is being brough back
online, the trustee kills all idle workers and scheduled rebind_work
so that they re-bind to the CPU after the currently executing work is
finished. This works for busy workers because concurrency management
doesn't try to wake up them from scheduler callbacks, which require
the target task to be on the local run queue. The busy worker bumps
concurrency counter appropriately as it clears WORKER_UNBOUND from the
rebind work item and it's bound to the CPU before returning to the
idle state.
To reduce CPU on/offlining overhead (as many embedded systems use it
for powersaving) and simplify the code path, workqueue is planned to
be modified to retain idle workers across CPU on/offlining. This
patch reimplements CPU online rebinding such that it can also handle
idle workers.
As noted earlier, due to the local wakeup requirement, rebinding idle
workers is tricky. All idle workers must be re-bound before scheduler
callbacks are enabled. This is achieved by interlocking idle
re-binding. Idle workers are requested to re-bind and then hold until
all idle re-binding is complete so that no bound worker starts
executing work item. Only after all idle workers are re-bound and
parked, CPU_ONLINE proceeds to release them and queue rebind work item
to busy workers thus guaranteeing scheduler callbacks aren't invoked
until all idle workers are ready.
worker_rebind_fn() is renamed to busy_worker_rebind_fn() and
idle_worker_rebind() for idle workers is added. Rebinding logic is
moved to rebind_workers() and now called from CPU_ONLINE after
flushing trustee. While at it, add CPU sanity check in
worker_thread().
Note that now a worker may become idle or the manager between trustee
release and rebinding during CPU_ONLINE. As the previous patch
updated create_worker() so that it can be used by regular manager
while unbound and this patch implements idle re-binding, this is safe.
This prepares for removal of trustee and keeping idle workers across
CPU hotplugs.
Currently, create_worker()'s callers are responsible for deciding
whether the newly created worker should be bound to the associated CPU
and create_worker() sets WORKER_UNBOUND only for the workers for the
unbound global_cwq. Creation during normal operation is always via
maybe_create_worker() and @bind is true. For workers created during
hotplug, @bind is false.
Normal operation path is planned to be used even while the CPU is
going through hotplug operations or offline and this static decision
won't work.
Drop @bind from create_worker() and decide whether to bind by looking
at GCWQ_DISASSOCIATED. create_worker() will also set WORKER_UNBOUND
autmatically if disassociated. To avoid flipping GCWQ_DISASSOCIATED
while create_worker() is in progress, the flag is now allowed to be
changed only while holding all manager_mutexes on the global_cwq.
This requires that GCWQ_DISASSOCIATED is not cleared behind trustee's
back. CPU_ONLINE no longer clears DISASSOCIATED before flushing
trustee, which clears DISASSOCIATED before rebinding remaining workers
if asked to release. For cases where trustee isn't around, CPU_ONLINE
clears DISASSOCIATED after flushing trustee. Also, now, first_idle
has UNBOUND set on creation which is explicitly cleared by CPU_ONLINE
while binding it. These convolutions will soon be removed by further
simplification of CPU hotplug path.
POOL_MANAGING_WORKERS is used to ensure that at most one worker takes
the manager role at any given time on a given global_cwq. Trustee
later hitched on it to assume manager adding blocking wait for the
bit. As trustee already needed a custom wait mechanism, waiting for
MANAGING_WORKERS was rolled into the same mechanism.
Trustee is scheduled to be removed. This patch separates out
MANAGING_WORKERS wait into per-pool mutex. Workers use
mutex_trylock() to test for manager role and trustee uses mutex_lock()
to claim manager roles.
gcwq_claim/release_management() helpers are added to grab and release
manager roles of all pools on a global_cwq. gcwq_claim_management()
always grabs pool manager mutexes in ascending pool index order and
uses pool index as lockdep subclass.
Currently, WORKER_UNBOUND is used to mark workers for the unbound
global_cwq and WORKER_ROGUE is used to mark workers for disassociated
per-cpu global_cwqs. Both are used to make the marked worker skip
concurrency management and the only place they make any difference is
in worker_enter_idle() where WORKER_ROGUE is used to skip scheduling
idle timer, which can easily be replaced with trustee state testing.
This patch replaces WORKER_ROGUE with WORKER_UNBOUND and drops
WORKER_ROGUE. This is to prepare for removing trustee and handling
disassociated global_cwqs as unbound.
Workqueue used CPU_DYING notification to mark GCWQ_DISASSOCIATED.
This was necessary because workqueue's CPU_DOWN_PREPARE happened
before other DOWN_PREPARE notifiers and workqueue needed to stay
associated across the rest of DOWN_PREPARE.
After the previous patch, workqueue's DOWN_PREPARE happens after
others and can set GCWQ_DISASSOCIATED directly. Drop CPU_DYING and
let the trustee set GCWQ_DISASSOCIATED after disabling concurrency
management.
Currently, all workqueue cpu hotplug operations run off
CPU_PRI_WORKQUEUE which is higher than normal notifiers. This is to
ensure that workqueue is up and running while bringing up a CPU before
other notifiers try to use workqueue on the CPU.
Per-cpu workqueues are supposed to remain working and bound to the CPU
for normal CPU_DOWN_PREPARE notifiers. This holds mostly true even
with workqueue offlining running with higher priority because
workqueue CPU_DOWN_PREPARE only creates a bound trustee thread which
runs the per-cpu workqueue without concurrency management without
explicitly detaching the existing workers.
However, if the trustee needs to create new workers, it creates
unbound workers which may wander off to other CPUs while
CPU_DOWN_PREPARE notifiers are in progress. Furthermore, if the CPU
down is cancelled, the per-CPU workqueue may end up with workers which
aren't bound to the CPU.
While reliably reproducible with a convoluted artificial test-case
involving scheduling and flushing CPU burning work items from CPU down
notifiers, this isn't very likely to happen in the wild, and, even
when it happens, the effects are likely to be hidden by the following
successful CPU down.
Fix it by using different priorities for up and down notifiers - high
priority for up operations and low priority for down operations.
Workqueue cpu hotplug operations will soon go through further cleanup.
The leap second rework unearthed another issue of inconsistent data.
On timekeeping_resume() the timekeeper data is updated, but nothing
calls timekeeping_update(), so now the update code in the timer
interrupt sees stale values.
This has been the case before those changes, but then the timer
interrupt was using stale data as well so this went unnoticed for quite
some time.
Add the missing update call, so all the data is consistent everywhere.
Reported-by: Andreas Schwab <schwab@linux-m68k.org>
Reported-and-tested-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Reported-and-tested-by: Martin Steigerwald <Martin@lichtvoll.de>
Cc: LKML <linux-kernel@vger.kernel.org>
Cc: Linux PM list <linux-pm@vger.kernel.org>
Cc: John Stultz <johnstul@us.ibm.com>
Cc: Peter Zijlstra <a.p.zijlstra@chello.nl>,
Cc: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: John Stultz <johnstul@us.ibm.com>
As part of cleaning up the timekeeping code, this patch converts
a number of internal functions to takei a timekeeper ptr as an
argument, so that the internal functions don't access the global
timekeeper structure directly. This allows for further optimizations
to reduce lock hold time later.
This patch has been updated to include more consistent usage of the
timekeeper value, by making sure it is always passed as a argument
to non top-level functions.
Signed-off-by: John Stultz <john.stultz@linaro.org>
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Cc: Richard Cochran <richardcochran@gmail.com>
Link: http://lkml.kernel.org/r/1342156917-25092-9-git-send-email-john.stultz@linaro.org
When we make adjustments speeding up the clock, its possible
for xtime_nsec to underflow. We already handle this properly,
but we do so from update_wall_time() instead of the more logical
timekeeping_adjust(), where the possible underflow actually
occurs.
Thus, move the correction logic to the timekeeping_adjust, which
is the function that causes the issue. Making update_wall_time()
more readable.
Link: http://lkml.kernel.org/r/1342156917-25092-8-git-send-email-john.stultz@linaro.org
Since we call arch_gettimeoffset() in all the accessor
functions, move arch_gettimeoffset() calls into
timekeeping_get_ns() and timekeeping_get_ns_raw() to simplify
the code.
This also makes the code easier to maintain as we don't have to
worry about forgetting the arch_gettimeoffset() as has happened
in the past.
Link: http://lkml.kernel.org/r/1342156917-25092-7-git-send-email-john.stultz@linaro.org
