The SRCU wrapper functions srcu_torture_read_lock and
srcu_torture_read_unlock in rcutorture intentionally change the SRCU
context; annotate them accordingly, to avoid a warning.
Signed-off-by: Josh Triplett <josh@freedesktop.org>
Remove unused 'new_ruid' variable.
Reported by David Binderman <dcb314@hotmail.com>.
Signed-off-by: David Rientjes <rientjes@cs.washington.edu>
In time for 2.6.20, we can get rid of this junk.
It is possible to have tasklets get scheduled before softirqd has had a chance
to spawn on all CPUs. This is totally harmless; after success during action
CPU_UP_PREPARE, action CPU_ONLINE will be called, which immediately wakes
softirqd on the appropriate CPU to process the already pending tasklets. So
there is no danger of having a missed wakeup for any tasklets that were
already pending.
In particular, i386 is affected by this during startup, and is visible when
using a very large initrd; during the time it takes for the initrd to be
decompressed, a timer IRQ can come in and schedule RCU callbacks. It is also
possible that resending of a hardware IRQ via a softirq triggers the same bug.
Because of different timing conditions, this shows up in all emulators and
virtual machines tested, including Xen, VMware, Virtual PC, and Qemu. It is
also possible to trigger on native hardware with a large enough initrd,
although I don't have a reliable case demonstrating that.
Signed-off-by: Zachary Amsden <zach@vmware.com>
Cc: <caglar@pardus.org.tr>
Cc: <stable@kernel.org>
Make the locking self-test failures (of 'FAILURE' type) easier to debug by
printing more information.
Some have reported a chain-table overflow - double its size.
At present show_state prints a header the does not match the output of
show_task, as follows:
sibling
task PC pid father child younger older
init S 00000000 0 1 0 2 (NOTLB)
This patch corrects the output of show_state so that the header is
aligned with the data, ala:
free sibling
task PC stack pid father child younger older
Signed-off-by: Chris Caputo <ccaputo@alt.net>
numbers
In the functions do_proc_dointvec() and do_proc_doulongvec_minmax(),
there seems to be a bug in string length calculation if string contains
negative integer.
The console log given below explains the bug. Setting negative values
may not be a right thing to do for "console log level" but then the test
(given below) can be used to demonstrate the bug in the code.
# echo "-1 -1 -1 -123456" > /proc/sys/kernel/printk
# cat /proc/sys/kernel/printk
-1 -1 -1 -1234
# echo "-1 -1 -1 123456" > /proc/sys/kernel/printk
-1 -1 -1 1234
(akpm: the bug is that 123456 gets truncated)
It works as expected if string contains all +ve integers
# echo "1 2 3 4" > /proc/sys/kernel/printk
1 2 3 4
The patch given below fixes the issue.
Signed-off-by: Praveen BP <praveenbp@ti.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Check register_filesystem() and kern_mount() return values.
On some workloads, (for example when lot of close() syscalls are done), RCU
qlen can be quite large, and RCU heads are no longer in cpu cache when
rcu_do_batch() is called.
This patch adds a prefetch() in rcu_do_batch() to give CPU a hint to bring
back cache lines containing 'struct rcu_head's.
Most list manipulations macros include prefetch(), but not open coded ones
(at least with current C compilers :) )
I got a nice speedup on a trivial benchmark (3.48 us per iteration instead
of 3.95 us on a 1.6 GHz Pentium-M)
while (1) { pipe(p); close(fd[0]); close(fd[1]);}
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
Remove the no longer used lockdep_internal().
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn,
prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus
generating compiler warnings of unused symbols, hence forcing people to add
#ifdefs.
the compiler can skip truly unused functions just fine:
1624412 728710 3674856 6027978 5bfaca vmlinux.before
1624412 728710 3674856 6027978 5bfaca vmlinux.after
[akpm@osdl.org: topology.c fix]
When we are unregistering a kprobe-booster, we can't release its
instruction buffer immediately on the preemptive kernel, because some
processes might be preempted on the buffer. The freeze_processes() and
thaw_processes() functions can clean most of processes up from the buffer.
There are still some non-frozen threads who have the PF_NOFREEZE flag. If
those threads are sleeping (not preempted) at the known place outside the
buffer, we can ensure safety of freeing.
However, the processing of this check routine takes a long time. So, this
patch introduces the garbage collection mechanism of insn_slot. It also
introduces the "dirty" flag to free_insn_slot because of efficiency.
The "clean" instruction slots (dirty flag is cleared) are released
immediately. But the "dirty" slots which are used by boosted kprobes, are
marked as garbages. collect_garbage_slots() will be invoked to release
"dirty" slots if there are more than INSNS_PER_PAGE garbage slots or if
there are no unused slots.
Cc: "Keshavamurthy, Anil S" <anil.s.keshavamurthy@intel.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: "bibo,mao" <bibo.mao@intel.com>
Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com>
Cc: Yumiko Sugita <yumiko.sugita.yf@hitachi.com>
Cc: Satoshi Oshima <soshima@redhat.com>
Cc: Hideo Aoki <haoki@redhat.com>
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Attempts to read() from the non-existent dmesg buffer will return zero and
userspace tends to get stuck in a busyloop.
So just remove /dev/kmsg altogether if CONFIG_PRINTK=n.
Signed-off-by: Mike Galbraith <efault@gmx.de>
Fix two things. Firstly the unit is "Hz" not "HZ". Secondly it is useful
to have 300Hz support when doing multimedia work. 250 is fine for us in
Europe but the US frame rate is 30fps (29.99 blah for pedants). 300 gives
us a tick divisible by both 25 and 30, and for interlace work 50 and 60.
It's also giving similar performance to 250Hz.
I'd argue we should remove 250 and add 300, but that might be excess
disruption for now.
Signed-off-by: Alan Cox <alan@redhat.com>
Workqueue functions should not leak locks, assert so, printing the
last function ran.
Use macros in lockdep.h to avoid include dependency pains.
[akpm@osdl.org: build fix]
Implement prof=sleep profiling. TASK_UNINTERRUPTIBLE sleeps will be taken
as a profile hit, and every millisecond spent sleeping causes a profile-hit
for the call site that initiated the sleep.
Sample readprofile output on i386:
306 ps2_sendbyte 1.3973
432 call_usermodehelper_keys 1.9548
484 ps2_command 0.6453
790 __driver_attach 4.7879
1593 msleep 44.2500
3976 sync_buffer 64.1290
4076 do_lookup 12.4648
8587 sync_page 122.6714
20820 total 0.0067
(NOTE: architectures need to check whether get_wchan() can be called from
deep within the wakeup path.)
akpm: we need to mark more functions __sched. lock_sock(), msleep(), others..
akpm: the contention in do_lookup() is a surprise. Presumably doing disk
reads for directory contents while holding i_mutex.
[akpm@osdl.org: various fixes]
Name some of the remaning 'old_style_spin_init' locks
Add debug_show_held_locks(current) to __might_sleep() and schedule(); this
makes finding the offending lock leak easier.
Thomas Graf wrote:
> nla_nest_start() may return NULL, either rely on prepare_reply() to be
> correct and BUG() on failure or do proper error handling for all
> functions.
nla_put() in taskstat.c can fail only if the 'size' argument of alloc_skb()
was not right. This is a kernel bug, we should not hide it. So add 'BUG()'
on error path and check for 'na == NULL'.
> genlmsg_cancel() is only required in error paths for dumping
> procedures.
So we can remove 'genlmsg_cancel()' calls and 'void *reply' (saves 227 bytes).
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Shailabh Nagar <nagar@watson.ibm.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Jay Lan <jlan@sgi.com>
Currently taskstats_user_cmd()/taskstats_exit() do:
1) allocate stats
2) fill stats
3) make a temporary copy on stack (236 bytes)
4) copy that copy to skb
5) free stats
With the help of nla_reserve() we can operate on skb->data directly,
thus avoiding all these steps except 2).
So, before this patch:
// copy *stats to skb->data
int mk_reply(skb, ..., struct taskstats *stats);
fill_pid(stats);
mk_reply(skb, ..., stats);
After:
// return a pointer to skb->data
struct taskstats *mk_reply(skb, ...);
stat = mk_reply(skb, ...);
fill_pid(stats);
Shrinks taskatsks.o by 162 bytes.
A stupid benchmark (send one million TASKSTATS_CMD_ATTR_PID) shows the
real user sys
before:
4.02 0.06 3.96
4.02 0.04 3.98
4.02 0.04 3.97
after:
3.86 0.08 3.78
3.88 0.10 3.77
3.89 0.09 3.80
but this looks suspiciously good.
Acked-by: Shailabh Nagar <nagar@watson.ibm.com>
Introduce mk_reply() helper which does all nla_put()s on reply.
Saves 453 bytes and a preparation for the next patch.
Allocate ->signal->stats on demand in taskstats_exit(), this allows us to
remove taskstats_tgid_alloc() (the last non-trivial inline) from taskstat's
public interface.
Cc: Jay Lan <jlan@engr.sgi.com>
do_exit:
taskstats_exit_alloc()
taskstats_exit_send()
taskstats_exit_free()
I think this is not good, let it be a single function exported to the core
kernel, taskstats_exit(), which does alloc + send + free itself.
If there are no listeners, every task does unneeded kmem_cache alloc/free on
exit. We don't need listeners->sem for 'if (!list_empty())' check. Yes, we may
have a false positive, but this doesn't differ from the case when the listener
is unregistered after we drop the semaphore. So we don't need to do allocation
beforehand.
The CLONE_CHILD_CLEARTID flag is used by NPTL to have its threads
communicate via memory/futex when they exit, so pthread_join can
synchronize using a simple futex wait. The word of user memory where NPTL
stores a thread's own TID is what it passes; this gets reset to zero at
thread exit.
It is not desireable to touch this user memory when threads are dying due
to a fatal signal. A core dump is more usefully representative of the
dying program state if the threads live at the time of the crash have their
NPTL data structures unperturbed. The userland expectation of
CLONE_CHILD_CLEARTID has only ever been that it works for a thread making
an _exit system call.
This problem was identified by Ernie Petrides <petrides@redhat.com>.
Signed-off-by: Roland McGrath <roland@redhat.com>
Cc: Ernie Petrides <petrides@redhat.com>
Cc: Jakub Jelinek <jakub@redhat.com>
Cc: Ulrich Drepper <drepper@redhat.com>
- numeric string size replaced with constant in print_lock_name and
print_lockdep_cache,
- return on null pointer in print_lock_dependencies,
- one more lockdep return with 0 with unlocking fix in mark_lock.
Signed-off-by: Jarek Poplawski <jarkao2@o2.pl>
Here are mainly some lockdep returns with 0 with unlocking fixes.
A couple of minor code simplifications to the kernel/cpuset.c code. No
functional change. Just a little less code and a little more readable.
Signed-off-by: Paul Jackson <pj@sgi.com>
The new shared APM emulation just like its ARM and MIPS predecessors uses
pm_suspend() which was only exported on SH. Move export to close to it's
definition where it really should be anyway.
Add SysRq-X support: show blocked (TASK_UNINTERRUPTIBLE) tasks only.
Useful for debugging IO stalls.
This patch addresses incorrect symbol type information reported through
/proc/kallsyms. A lowercase character should designate the symbol as local
(or non-exported). An uppercase character should designate the symbol as
global (or external).
Without this patch, some non-exported symbols are incorrectly assigned an
upper-case designation in /proc/kallsyms. This patch corrects this
condition by converting non-exported symbols types to lower case when
appropriate and eliminates the superfluous upcase_if_global function
Signed-off-by: Adam B. Jerome <abj@novell.com>
Stick NFS sockets in their own class to avoid some lockdep warnings. NFS
sockets are never exposed to user-space, and will hence not trigger certain
code paths that would otherwise pose deadlock scenarios.
[akpm@osdl.org: cleanups]
Signed-off-by: Steven Dickson <SteveD@redhat.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Acked-by: Neil Brown <neilb@suse.de>
[ Fixed patch corruption by quilt, pointed out by Peter Zijlstra ]
Make it possible to create a workqueue the worker thread of which will be
frozen during suspend, along with other kernel threads.
Acked-by: Pavel Machek <pavel@ucw.cz>
Cc: Nigel Cunningham <nigel@suspend2.net>
Cc: David Chinner <dgc@sgi.com>
Cleanup write-only variable, suggested by D Binderman.
Signed-off-by: Pavel Machek <pavel@suse.cz>
The 'testproc' swsusp debug mode thaws tasks twice in a row, which is _very_
confusing. Fix that.
Move all labels in the swsusp code to the second column, so that they won't
fool diff -p.
Fix coding style in suspend.c.
Move the loop from freeze_processes() to a separate function and call it
independently for user space processes and kernel threads so that the order
of freezing tasks is clearly visible.
Cc: Pavel Machek <pavel@ucw.cz>
Move the loop from thaw_processes() to a separate function and call it
independently for kernel threads and user space processes so that the order
of thawing tasks is clearly visible.
Drop thaw_kernel_threads() which is never used.
The power management semaphore is only used as mutex, so convert it.
[akpm@osdl.org: fix rotten bug]
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Fix http://bugzilla.kernel.org/show_bug.cgi?id=7534
Fix the freezing of processes so that it won't fail if there is a traced
process the parent of which has been stopped.
Cc: maurice barnum <pixi+kbug@burble.org>
Make swsusp measure and print the time needed to shrink memory during the
suspend.
Don't modify the cpus_allowed of the task initiating the suspend.
_cpu_down() already makes sure that the task doing the suspend doesn't run
on dying cpu.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Make swsusp support i386 systems with PAE or without PSE.
This is done by creating temporary page tables located in resume-safe page
frames before the suspend image is restored in the same way as x86_64 does
it.
Cc: Andi Kleen <ak@suse.de>
Cc: Dave Jones <davej@redhat.com>
Cc: Nigel Cunningham <ncunningham@linuxmail.org>
Modify process thawing so that we can thaw kernel space without thawing
userspace, and thaw kernelspace first. This will be useful in later
patches, where I intend to get swsusp thawing kernel threads only before
seeking to free memory.
Signed-off-by: Nigel Cunningham <nigel@suspend2.net>
Minor whitespace and formatting modifications for the freezer.
