Pull KVM updates from Avi Kivity:
"Highlights of the changes for this release include support for vfio
level triggered interrupts, improved big real mode support on older
Intels, a streamlines guest page table walker, guest APIC speedups,
PIO optimizations, better overcommit handling, and read-only memory."
* tag 'kvm-3.7-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (138 commits)
KVM: s390: Fix vcpu_load handling in interrupt code
KVM: x86: Fix guest debug across vcpu INIT reset
KVM: Add resampling irqfds for level triggered interrupts
KVM: optimize apic interrupt delivery
KVM: MMU: Eliminate pointless temporary 'ac'
KVM: MMU: Avoid access/dirty update loop if all is well
KVM: MMU: Eliminate eperm temporary
KVM: MMU: Optimize is_last_gpte()
KVM: MMU: Simplify walk_addr_generic() loop
KVM: MMU: Optimize pte permission checks
KVM: MMU: Update accessed and dirty bits after guest pagetable walk
KVM: MMU: Move gpte_access() out of paging_tmpl.h
KVM: MMU: Optimize gpte_access() slightly
KVM: MMU: Push clean gpte write protection out of gpte_access()
KVM: clarify kvmclock documentation
KVM: make processes waiting on vcpu mutex killable
KVM: SVM: Make use of asm.h
KVM: VMX: Make use of asm.h
KVM: VMX: Make lto-friendly
KVM: x86: lapic: Clean up find_highest_vector() and count_vectors()
arch/s390/include/asm/processor.h
arch/x86/kvm/i8259.c
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights:
- Integrity: add local fs integrity verification to detect offline
attacks
- Integrity: add digital signature verification
- Simple stacking of Yama with other LSMs (per LSS discussions)
- IBM vTPM support on ppc64
- Add new driver for Infineon I2C TIS TPM
- Smack: add rule revocation for subject labels"
Fixed conflicts with the user namespace support in kernel/auditsc.c and
security/integrity/ima/ima_policy.c.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (39 commits)
Documentation: Update git repository URL for Smack userland tools
ima: change flags container data type
Smack: setprocattr memory leak fix
Smack: implement revoking all rules for a subject label
Smack: remove task_wait() hook.
ima: audit log hashes
ima: generic IMA action flag handling
ima: rename ima_must_appraise_or_measure
audit: export audit_log_task_info
tpm: fix tpm_acpi sparse warning on different address spaces
samples/seccomp: fix 31 bit build on s390
ima: digital signature verification support
ima: add support for different security.ima data types
ima: add ima_inode_setxattr/removexattr function and calls
ima: add inode_post_setattr call
ima: replace iint spinblock with rwlock/read_lock
ima: allocating iint improvements
ima: add appraise action keywords and default rules
ima: integrity appraisal extension
vfs: move ima_file_free before releasing the file
Pull vfs update from Al Viro:
- big one - consolidation of descriptor-related logics; almost all of
that is moved to fs/file.c
(BTW, I'm seriously tempted to rename the result to fd.c. As it is,
we have a situation when file_table.c is about handling of struct
file and file.c is about handling of descriptor tables; the reasons
are historical - file_table.c used to be about a static array of
struct file we used to have way back).
A lot of stray ends got cleaned up and converted to saner primitives,
disgusting mess in android/binder.c is still disgusting, but at least
doesn't poke so much in descriptor table guts anymore. A bunch of
relatively minor races got fixed in process, plus an ext4 struct file
leak.
- related thing - fget_light() partially unuglified; see fdget() in
there (and yes, it generates the code as good as we used to have).
- also related - bits of Cyrill's procfs stuff that got entangled into
that work; _not_ all of it, just the initial move to fs/proc/fd.c and
switch of fdinfo to seq_file.
- Alex's fs/coredump.c spiltoff - the same story, had been easier to
take that commit than mess with conflicts. The rest is a separate
pile, this was just a mechanical code movement.
- a few misc patches all over the place. Not all for this cycle,
there'll be more (and quite a few currently sit in akpm's tree)."
Fix up trivial conflicts in the android binder driver, and some fairly
simple conflicts due to two different changes to the sock_alloc_file()
interface ("take descriptor handling from sock_alloc_file() to callers"
vs "net: Providing protocol type via system.sockprotoname xattr of
/proc/PID/fd entries" adding a dentry name to the socket)
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits)
MAX_LFS_FILESIZE should be a loff_t
compat: fs: Generic compat_sys_sendfile implementation
fs: push rcu_barrier() from deactivate_locked_super() to filesystems
btrfs: reada_extent doesn't need kref for refcount
coredump: move core dump functionality into its own file
coredump: prevent double-free on an error path in core dumper
usb/gadget: fix misannotations
fcntl: fix misannotations
ceph: don't abuse d_delete() on failure exits
hypfs: ->d_parent is never NULL or negative
vfs: delete surplus inode NULL check
switch simple cases of fget_light to fdget
new helpers: fdget()/fdput()
switch o2hb_region_dev_write() to fget_light()
proc_map_files_readdir(): don't bother with grabbing files
make get_file() return its argument
vhost_set_vring(): turn pollstart/pollstop into bool
switch prctl_set_mm_exe_file() to fget_light()
switch xfs_find_handle() to fget_light()
switch xfs_swapext() to fget_light()
Pull power management updates from Rafael J Wysocki:
- Improved system suspend/resume and runtime PM handling for the SH
TMU, CMT and MTU2 clock event devices (also used by ARM/shmobile).
- Generic PM domains framework extensions related to cpuidle support
and domain objects lookup using names.
- ARM/shmobile power management updates including improved support for
the SH7372's A4S power domain containing the CPU core.
- cpufreq changes related to AMD CPUs support from Matthew Garrett,
Andre Przywara and Borislav Petkov.
- cpu0 cpufreq driver from Shawn Guo.
- cpufreq governor fixes related to the relaxing of limit from Michal
Pecio.
- OMAP cpufreq updates from Axel Lin and Richard Zhao.
- cpuidle ladder governor fixes related to the disabling of states from
Carsten Emde and me.
- Runtime PM core updates related to the interactions with the system
suspend core from Alan Stern and Kevin Hilman.
- Wakeup sources modification allowing more helper functions to be
called from interrupt context from John Stultz and additional
diagnostic code from Todd Poynor.
- System suspend error code path fix from Feng Hong.
Fixed up conflicts in cpufreq/powernow-k8 that stemmed from the
workqueue fixes conflicting fairly badly with the removal of support for
hardware P-state chips. The changes were independent but somewhat
intertwined.
* tag 'pm-for-3.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (76 commits)
Revert "PM QoS: Use spinlock in the per-device PM QoS constraints code"
PM / Runtime: let rpm_resume() succeed if RPM_ACTIVE, even when disabled, v2
cpuidle: rename function name "__cpuidle_register_driver", v2
cpufreq: OMAP: Check IS_ERR() instead of NULL for omap_device_get_by_hwmod_name
cpuidle: remove some empty lines
PM: Prevent runtime suspend during system resume
PM / Sleep: use resume event when call dpm_resume_early
cpuidle / ACPI : move cpuidle_device field out of the acpi_processor_power structure
ACPI / processor: remove pointless variable initialization
ACPI / processor: remove unused function parameter
cpufreq: OMAP: remove loops_per_jiffy recalculate for smp
sections: fix section conflicts in drivers/cpufreq
cpufreq: conservative: update frequency when limits are relaxed
cpufreq / ondemand: update frequency when limits are relaxed
properly __init-annotate pm_sysrq_init()
cpufreq: Add a generic cpufreq-cpu0 driver
PM / OPP: Initialize OPP table from device tree
ARM: add cpufreq transiton notifier to adjust loops_per_jiffy for smp
cpufreq: Remove support for hardware P-state chips from powernow-k8
Pull networking changes from David Miller:
1) GRE now works over ipv6, from Dmitry Kozlov.
2) Make SCTP more network namespace aware, from Eric Biederman.
3) TEAM driver now works with non-ethernet devices, from Jiri Pirko.
4) Make openvswitch network namespace aware, from Pravin B Shelar.
5) IPV6 NAT implementation, from Patrick McHardy.
6) Server side support for TCP Fast Open, from Jerry Chu and others.
7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel
Borkmann.
8) Increate the loopback default MTU to 64K, from Eric Dumazet.
9) Use a per-task rather than per-socket page fragment allocator for
outgoing networking traffic. This benefits processes that have very
many mostly idle sockets, which is quite common.
From Eric Dumazet.
10) Use up to 32K for page fragment allocations, with fallbacks to
smaller sizes when higher order page allocations fail. Benefits are
a) less segments for driver to process b) less calls to page
allocator c) less waste of space.
From Eric Dumazet.
11) Allow GRO to be used on GRE tunnels, from Eric Dumazet.
12) VXLAN device driver, one way to handle VLAN issues such as the
limitation of 4096 VLAN IDs yet still have some level of isolation.
From Stephen Hemminger.
13) As usual there is a large boatload of driver changes, with the scale
perhaps tilted towards the wireless side this time around.
Fix up various fairly trivial conflicts, mostly caused by the user
namespace changes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits)
hyperv: Add buffer for extended info after the RNDIS response message.
hyperv: Report actual status in receive completion packet
hyperv: Remove extra allocated space for recv_pkt_list elements
hyperv: Fix page buffer handling in rndis_filter_send_request()
hyperv: Fix the missing return value in rndis_filter_set_packet_filter()
hyperv: Fix the max_xfer_size in RNDIS initialization
vxlan: put UDP socket in correct namespace
vxlan: Depend on CONFIG_INET
sfc: Fix the reported priorities of different filter types
sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP
sfc: Fix loopback self-test with separate_tx_channels=1
sfc: Fix MCDI structure field lookup
sfc: Add parentheses around use of bitfield macro arguments
sfc: Fix null function pointer in efx_sriov_channel_type
vxlan: virtual extensible lan
igmp: export symbol ip_mc_leave_group
netlink: add attributes to fdb interface
tg3: unconditionally select HWMON support when tg3 is enabled.
Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT"
gre: fix sparse warning
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace changes from Eric Biederman:
"This is a mostly modest set of changes to enable basic user namespace
support. This allows the code to code to compile with user namespaces
enabled and removes the assumption there is only the initial user
namespace. Everything is converted except for the most complex of the
filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs,
nfs, ocfs2 and xfs as those patches need a bit more review.
The strategy is to push kuid_t and kgid_t values are far down into
subsystems and filesystems as reasonable. Leaving the make_kuid and
from_kuid operations to happen at the edge of userspace, as the values
come off the disk, and as the values come in from the network.
Letting compile type incompatible compile errors (present when user
namespaces are enabled) guide me to find the issues.
The most tricky areas have been the places where we had an implicit
union of uid and gid values and were storing them in an unsigned int.
Those places were converted into explicit unions. I made certain to
handle those places with simple trivial patches.
Out of that work I discovered we have generic interfaces for storing
quota by projid. I had never heard of the project identifiers before.
Adding full user namespace support for project identifiers accounts
for most of the code size growth in my git tree.
Ultimately there will be work to relax privlige checks from
"capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing
root in a user names to do those things that today we only forbid to
non-root users because it will confuse suid root applications.
While I was pushing kuid_t and kgid_t changes deep into the audit code
I made a few other cleanups. I capitalized on the fact we process
netlink messages in the context of the message sender. I removed
usage of NETLINK_CRED, and started directly using current->tty.
Some of these patches have also made it into maintainer trees, with no
problems from identical code from different trees showing up in
linux-next.
After reading through all of this code I feel like I might be able to
win a game of kernel trivial pursuit."
Fix up some fairly trivial conflicts in netfilter uid/git logging code.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits)
userns: Convert the ufs filesystem to use kuid/kgid where appropriate
userns: Convert the udf filesystem to use kuid/kgid where appropriate
userns: Convert ubifs to use kuid/kgid
userns: Convert squashfs to use kuid/kgid where appropriate
userns: Convert reiserfs to use kuid and kgid where appropriate
userns: Convert jfs to use kuid/kgid where appropriate
userns: Convert jffs2 to use kuid and kgid where appropriate
userns: Convert hpfs to use kuid and kgid where appropriate
userns: Convert btrfs to use kuid/kgid where appropriate
userns: Convert bfs to use kuid/kgid where appropriate
userns: Convert affs to use kuid/kgid wherwe appropriate
userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids
userns: On ia64 deal with current_uid and current_gid being kuid and kgid
userns: On ppc convert current_uid from a kuid before printing.
userns: Convert s390 getting uid and gid system calls to use kuid and kgid
userns: Convert s390 hypfs to use kuid and kgid where appropriate
userns: Convert binder ipc to use kuids
userns: Teach security_path_chown to take kuids and kgids
userns: Add user namespace support to IMA
userns: Convert EVM to deal with kuids and kgids in it's hmac computation
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup hierarchy update from Tejun Heo:
"Currently, different cgroup subsystems handle nested cgroups
completely differently. There's no consistency among subsystems and
the behaviors often are outright broken.
People at least seem to agree that the broken hierarhcy behaviors need
to be weeded out if any progress is gonna be made on this front and
that the fallouts from deprecating the broken behaviors should be
acceptable especially given that the current behaviors don't make much
sense when nested.
This patch makes cgroup emit warning messages if cgroups for
subsystems with broken hierarchy behavior are nested to prepare for
fixing them in the future. This was put in a separate branch because
more related changes were expected (didn't make it this round) and the
memory cgroup wanted to pull in this and make changes on top."
* 'for-3.7-hierarchy' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: mark subsystems with broken hierarchy support and whine if cgroups are nested for them
Pull cgroup updates from Tejun Heo:
- xattr support added. The implementation is shared with tmpfs. The
usage is restricted and intended to be used to manage per-cgroup
metadata by system software. tmpfs changes are routed through this
branch with Hugh's permission.
- cgroup subsystem ID handling simplified.
* 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: Define CGROUP_SUBSYS_COUNT according the configuration
cgroup: Assign subsystem IDs during compile time
cgroup: Do not depend on a given order when populating the subsys array
cgroup: Wrap subsystem selection macro
cgroup: Remove CGROUP_BUILTIN_SUBSYS_COUNT
cgroup: net_prio: Do not define task_netpioidx() when not selected
cgroup: net_cls: Do not define task_cls_classid() when not selected
cgroup: net_cls: Move sock_update_classid() declaration to cls_cgroup.h
cgroup: trivial fixes for Documentation/cgroups/cgroups.txt
xattr: mark variable as uninitialized to make both gcc and smatch happy
fs: add missing documentation to simple_xattr functions
cgroup: add documentation on extended attributes usage
cgroup: rename subsys_bits to subsys_mask
cgroup: add xattr support
cgroup: revise how we re-populate root directory
xattr: extract simple_xattr code from tmpfs
Pull workqueue changes from Tejun Heo:
"This is workqueue updates for v3.7-rc1. A lot of activities this
round including considerable API and behavior cleanups.
* delayed_work combines a timer and a work item. The handling of the
timer part has always been a bit clunky leading to confusing
cancelation API with weird corner-case behaviors. delayed_work is
updated to use new IRQ safe timer and cancelation now works as
expected.
* Another deficiency of delayed_work was lack of the counterpart of
mod_timer() which led to cancel+queue combinations or open-coded
timer+work usages. mod_delayed_work[_on]() are added.
These two delayed_work changes make delayed_work provide interface
and behave like timer which is executed with process context.
* A work item could be executed concurrently on multiple CPUs, which
is rather unintuitive and made flush_work() behavior confusing and
half-broken under certain circumstances. This problem doesn't
exist for non-reentrant workqueues. While non-reentrancy check
isn't free, the overhead is incurred only when a work item bounces
across different CPUs and even in simulated pathological scenario
the overhead isn't too high.
All workqueues are made non-reentrant. This removes the
distinction between flush_[delayed_]work() and
flush_[delayed_]_work_sync(). The former is now as strong as the
latter and the specified work item is guaranteed to have finished
execution of any previous queueing on return.
* In addition to the various bug fixes, Lai redid and simplified CPU
hotplug handling significantly.
* Joonsoo introduced system_highpri_wq and used it during CPU
hotplug.
There are two merge commits - one to pull in IRQ safe timer from
tip/timers/core and the other to pull in CPU hotplug fixes from
wq/for-3.6-fixes as Lai's hotplug restructuring depended on them."
Fixed a number of trivial conflicts, but the more interesting conflicts
were silent ones where the deprecated interfaces had been used by new
code in the merge window, and thus didn't cause any real data conflicts.
Tejun pointed out a few of them, I fixed a couple more.
* 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits)
workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending()
workqueue: use cwq_set_max_active() helper for workqueue_set_max_active()
workqueue: introduce cwq_set_max_active() helper for thaw_workqueues()
workqueue: remove @delayed from cwq_dec_nr_in_flight()
workqueue: fix possible stall on try_to_grab_pending() of a delayed work item
workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback()
workqueue: use __cpuinit instead of __devinit for cpu callbacks
workqueue: rename manager_mutex to assoc_mutex
workqueue: WORKER_REBIND is no longer necessary for idle rebinding
workqueue: WORKER_REBIND is no longer necessary for busy rebinding
workqueue: reimplement idle worker rebinding
workqueue: deprecate __cancel_delayed_work()
workqueue: reimplement cancel_delayed_work() using try_to_grab_pending()
workqueue: use mod_delayed_work() instead of __cancel + queue
workqueue: use irqsafe timer for delayed_work
workqueue: clean up delayed_work initializers and add missing one
workqueue: make deferrable delayed_work initializer names consistent
workqueue: cosmetic whitespace updates for macro definitions
workqueue: deprecate system_nrt[_freezable]_wq
workqueue: deprecate flush[_delayed]_work_sync()
Pull TTY changes from Greg Kroah-Hartman:
"As we skipped the merge window for 3.6-rc1 for the tty tree,
everything is now settled down and working properly, so we are ready
for 3.7-rc1. Here's the patchset, it's big, but the large changes are
removing a firmware file and adding a staging tty driver (it depended
on the tty core changes, so it's going through this tree instead of
the staging tree.)
All of these patches have been in the linux-next tree for a while.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fix up more-or-less trivial conflicts in
- drivers/char/pcmcia/synclink_cs.c:
tty NULL dereference fix vs tty_port_cts_enabled() helper function
- drivers/staging/{Kconfig,Makefile}:
add-add conflict (dgrp driver added close to other staging drivers)
- drivers/staging/ipack/devices/ipoctal.c:
"split ipoctal_channel from iopctal" vs "TTY: use tty_port_register_device"
* tag 'tty-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (235 commits)
tty/serial: Add kgdb_nmi driver
tty/serial/amba-pl011: Quiesce interrupts in poll_get_char
tty/serial/amba-pl011: Implement poll_init callback
tty/serial/core: Introduce poll_init callback
kdb: Turn KGDB_KDB=n stubs into static inlines
kdb: Implement disable_nmi command
kernel/debug: Mask KGDB NMI upon entry
serial: pl011: handle corruption at high clock speeds
serial: sccnxp: Make 'default' choice in switch last
serial: sccnxp: Remove mask termios caps for SW flow control
serial: sccnxp: Report actual baudrate back to core
serial: samsung: Add poll_get_char & poll_put_char
Powerpc 8xx CPM_UART setting MAXIDL register proportionaly to baud rate
Powerpc 8xx CPM_UART maxidl should not depend on fifo size
Powerpc 8xx CPM_UART too many interrupts
Powerpc 8xx CPM_UART desynchronisation
serial: set correct baud_base for EXSYS EX-41092 Dual 16950
serial: omap: fix the reciever line error case
8250: blacklist Winbond CIR port
8250_pnp: do pnp probe before legacy probe
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64
Pull arm64 support from Catalin Marinas:
"Linux support for the 64-bit ARM architecture (AArch64)
Features currently supported:
- 39-bit address space for user and kernel (each)
- 4KB and 64KB page configurations
- Compat (32-bit) user applications (ARMv7, EABI only)
- Flattened Device Tree (mandated for all AArch64 platforms)
- ARM generic timers"
* tag 'arm64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: (35 commits)
arm64: ptrace: remove obsolete ptrace request numbers from user headers
arm64: Do not set the SMP/nAMP processor bit
arm64: MAINTAINERS update
arm64: Build infrastructure
arm64: Miscellaneous header files
arm64: Generic timers support
arm64: Loadable modules
arm64: Miscellaneous library functions
arm64: Performance counters support
arm64: Add support for /proc/sys/debug/exception-trace
arm64: Debugging support
arm64: Floating point and SIMD
arm64: 32-bit (compat) applications support
arm64: User access library functions
arm64: Signal handling support
arm64: VDSO support
arm64: System calls handling
arm64: ELF definitions
arm64: SMP support
arm64: DMA mapping API
Pull x86/asm changes from Ingo Molnar:
"The one change that stands out is the alternatives patching change
that prevents us from ever patching back instructions from SMP to UP:
this simplifies things and speeds up CPU hotplug.
Other than that it's smaller fixes, cleanups and improvements."
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Unspaghettize do_trap()
x86_64: Work around old GAS bug
x86: Use REP BSF unconditionally
x86: Prefer TZCNT over BFS
x86/64: Adjust types of temporaries used by ffs()/fls()/fls64()
x86: Drop unnecessary kernel_eflags variable on 64-bit
x86/smp: Don't ever patch back to UP if we unplug cpus
Pull timer changes from Ingo Molnar:
"Timer enhancements, generalizations and cleanups from Tejun Heo, in
preparation for workqueue facility enhancements."
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
timer: Implement TIMER_IRQSAFE
timer: Clean up timer initializers
timer: Relocate declarations of init_timer_on_stack_key()
timer: Generalize timer->base flags handling
Pull scheduler changes from Ingo Molnar:
"Continued quest to clean up and enhance the cputime code by Frederic
Weisbecker, in preparation for future tickless kernel features.
Other than that, smallish changes."
Fix up trivial conflicts due to additions next to each other in arch/{x86/}Kconfig
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits)
cputime: Make finegrained irqtime accounting generally available
cputime: Gather time/stats accounting config options into a single menu
ia64: Reuse system and user vtime accounting functions on task switch
ia64: Consolidate user vtime accounting
vtime: Consolidate system/idle context detection
cputime: Use a proper subsystem naming for vtime related APIs
sched: cpu_power: enable ARCH_POWER
sched/nohz: Clean up select_nohz_load_balancer()
sched: Fix load avg vs. cpu-hotplug
sched: Remove __ARCH_WANT_INTERRUPTS_ON_CTXSW
sched: Fix nohz_idle_balance()
sched: Remove useless code in yield_to()
sched: Add time unit suffix to sched sysctl knobs
sched/debug: Limit sd->*_idx range on sysctl
sched: Remove AFFINE_WAKEUPS feature flag
s390: Remove leftover account_tick_vtime() header
cputime: Consolidate vtime handling on context switch
sched: Move cputime code to its own file
cputime: Generalize CONFIG_VIRT_CPU_ACCOUNTING
tile: Remove SD_PREFER_LOCAL leftover
Pull perf update from Ingo Molnar:
"Lots of changes in this cycle as well, with hundreds of commits from
over 30 contributors. Most of the activity was on the tooling side.
Higher level changes:
- New 'perf kvm' analysis tool, from Xiao Guangrong.
- New 'perf trace' system-wide tracing tool
- uprobes fixes + cleanups from Oleg Nesterov.
- Lots of patches to make perf build on Android out of box, from
Irina Tirdea
- Extend ftrace function tracing utility to be more dynamic for its
users. It allows for data passing to the callback functions, as
well as reading regs as if a breakpoint were to trigger at function
entry.
The main goal of this patch series was to allow kprobes to use
ftrace as an optimized probe point when a probe is placed on an
ftrace nop. With lots of help from Masami Hiramatsu, and going
through lots of iterations, we finally came up with a good
solution.
- Add cpumask for uncore pmu, use it in 'stat', from Yan, Zheng.
- Various tracing updates from Steve Rostedt
- Clean up and improve 'perf sched' performance by elliminating lots
of needless calls to libtraceevent.
- Event group parsing support, from Jiri Olsa
- UI/gtk refactorings and improvements from Namhyung Kim
- Add support for non-tracepoint events in perf script python, from
Feng Tang
- Add --symbols to 'script', similar to the one in 'report', from
Feng Tang.
Infrastructure enhancements and fixes:
- Convert the trace builtins to use the growing evsel/evlist
tracepoint infrastructure, removing several open coded constructs
like switch like series of strcmp to dispatch events, etc.
Basically what had already been showcased in 'perf sched'.
- Add evsel constructor for tracepoints, that uses libtraceevent just
to parse the /format events file, use it in a new 'perf test' to
make sure the libtraceevent format parsing regressions can be more
readily caught.
- Some strange errors were happening in some builds, but not on the
next, reported by several people, problem was some parser related
files, generated during the build, didn't had proper make deps, fix
from Eric Sandeen.
- Introduce struct and cache information about the environment where
a perf.data file was captured, from Namhyung Kim.
- Fix handling of unresolved samples when --symbols is used in
'report', from Feng Tang.
- Add union member access support to 'probe', from Hyeoncheol Lee.
- Fixups to die() removal, from Namhyung Kim.
- Render fixes for the TUI, from Namhyung Kim.
- Don't enable annotation in non symbolic view, from Namhyung Kim.
- Fix pipe mode in 'report', from Namhyung Kim.
- Move related stats code from stat to util/, will be used by the
'stat' kvm tool, from Xiao Guangrong.
- Remove die()/exit() calls from several tools.
- Resolve vdso callchains, from Jiri Olsa
- Don't pass const char pointers to basename, so that we can
unconditionally use libgen.h and thus avoid ifdef BIONIC lines,
from David Ahern
- Refactor hist formatting so that it can be reused with the GTK
browser, From Namhyung Kim
- Fix build for another rbtree.c change, from Adrian Hunter.
- Make 'perf diff' command work with evsel hists, from Jiri Olsa.
- Use the only field_sep var that is set up: symbol_conf.field_sep,
fix from Jiri Olsa.
- .gitignore compiled python binaries, from Namhyung Kim.
- Get rid of die() in more libtraceevent places, from Namhyung Kim.
- Rename libtraceevent 'private' struct member to 'priv' so that it
works in C++, from Steven Rostedt
- Remove lots of exit()/die() calls from tools so that the main perf
exit routine can take place, from David Ahern
- Fix x86 build on x86-64, from David Ahern.
- {int,str,rb}list fixes from Suzuki K Poulose
- perf.data header fixes from Namhyung Kim
- Allow user to indicate objdump path, needed in cross environments,
from Maciek Borzecki
- Fix hardware cache event name generation, fix from Jiri Olsa
- Add round trip test for sw, hw and cache event names, catching the
problem Jiri fixed, after Jiri's patch, the test passes
successfully.
- Clean target should do clean for lib/traceevent too, fix from David
Ahern
- Check the right variable for allocation failure, fix from Namhyung
Kim
- Set up evsel->tp_format regardless of evsel->name being set
already, fix from Namhyung Kim
- Oprofile fixes from Robert Richter.
- Remove perf_event_attr needless version inflation, from Jiri Olsa
- Introduce libtraceevent strerror like error reporting facility,
from Namhyung Kim
- Add pmu mappings to perf.data header and use event names from cmd
line, from Robert Richter
- Fix include order for bison/flex-generated C files, from Ben
Hutchings
- Build fixes and documentation corrections from David Ahern
- Assorted cleanups from Robert Richter
- Let O= makes handle relative paths, from Steven Rostedt
- perf script python fixes, from Feng Tang.
- Initial bash completion support, from Frederic Weisbecker
- Allow building without libelf, from Namhyung Kim.
- Support DWARF CFI based unwind to have callchains when %bp based
unwinding is not possible, from Jiri Olsa.
- Symbol resolution fixes, while fixing support PPC64 files with an
.opt ELF section was the end goal, several fixes for code that
handles all architectures and cleanups are included, from Cody
Schafer.
- Assorted fixes for Documentation and build in 32 bit, from Robert
Richter
- Cache the libtraceevent event_format associated to each evsel
early, so that we avoid relookups, i.e. calling pevent_find_event
repeatedly when processing tracepoint events.
[ This is to reduce the surface contact with libtraceevents and
make clear what is that the perf tools needs from that lib: so
far parsing the common and per event fields. ]
- Don't stop the build if the audit libraries are not installed, fix
from Namhyung Kim.
- Fix bfd.h/libbfd detection with recent binutils, from Markus
Trippelsdorf.
- Improve warning message when libunwind devel packages not present,
from Jiri Olsa"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (282 commits)
perf trace: Add aliases for some syscalls
perf probe: Print an enum type variable in "enum variable-name" format when showing accessible variables
perf tools: Check libaudit availability for perf-trace builtin
perf hists: Add missing period_* fields when collapsing a hist entry
perf trace: New tool
perf evsel: Export the event_format constructor
perf evsel: Introduce rawptr() method
perf tools: Use perf_evsel__newtp in the event parser
perf evsel: The tracepoint constructor should store sys:name
perf evlist: Introduce set_filter() method
perf evlist: Renane set_filters method to apply_filters
perf test: Add test to check we correctly parse and match syscall open parms
perf evsel: Handle endianity in intval method
perf evsel: Know if byte swap is needed
perf tools: Allow handling a NULL cpu_map as meaning "all cpus"
perf evsel: Improve tracepoint constructor setup
tools lib traceevent: Fix error path on pevent_parse_event
perf test: Fix build failure
trace: Move trace event enable from fs_initcall to core_initcall
tracing: Add an option for disabling markers
Pull trivial irq core update from Ingo Molnar:
"Two symbol exports for modular irq-chip drivers"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
genirq: Export dummy_irq_chip
genirq: Export irq_set_chip_and_handler_name()
Pull core locking changes from Ingo Molnar:
"It includes a lockdep improvement plus a spinlock inlining Kconfig
cleanup."
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
locking: Adjust spin lock inlining Kconfig options
lockdep: Check if nested lock is actually held
Pull core kernel fixes from Ingo Molnar:
"This is a complex task_work series from Oleg that fixes the bug that
this VFS commit tried to fix:
d35abdb28824 hold task_lock around checks in keyctl
but solves the problem without the lockup regression that d35abdb28824
introduced in v3.6.
This series came late in v3.6 and I did not feel confident about it so
late in the cycle. Might be worth backporting to -stable if it proves
itself upstream."
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
task_work: Simplify the usage in ptrace_notify() and get_signal_to_deliver()
task_work: Revert "hold task_lock around checks in keyctl"
task_work: task_work_add() should not succeed after exit_task_work()
task_work: Make task_work_add() lockless
drivers/net/team/team.c
drivers/net/usb/qmi_wwan.c
net/batman-adv/bat_iv_ogm.c
net/ipv4/fib_frontend.c
net/ipv4/route.c
net/l2tp/l2tp_netlink.c
The team, fib_frontend, route, and l2tp_netlink conflicts were simply
overlapping changes.
qmi_wwan and bat_iv_ogm were of the "use HEAD" variety.
With help from Antonio Quartulli.
Linux 3.6-rc7
Requested by David Howells so he can merge his key susbsystem work into
my tree with requisite -linus changesets.
descriptor-related parts of daemonize, done right. As the
result we simplify the locking rules for ->files - we
hold task_lock in *all* cases when we modify ->files.
This command disables NMI-entry. If NMI source has been previously shared
with a serial console ("debug port"), this effectively releases the port
from KDB exclusive use, and makes the console available for normal use.
Of course, NMI can be reenabled, enable_nmi modparam is used for that:
echo 1 > /sys/module/kdb/parameters/enable_nmi
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
Acked-by: Jason Wessel <jason.wessel@windriver.com>
The new arch callback should manage NMIs that usually cause KGDB to
enter. That is, not all NMIs should be enabled/disabled, but only
those that issue kgdb_handle_exception().
We must mask it as serial-line interrupt can be used as an NMI, so
if the original KGDB-entry cause was say a breakpoint, then every
input to KDB console will cause KGDB to reenter, which we don't want.
Checking "user" before "is_idle_task()" allows better optimizations
in cases where inlining is possible. Also, "bool" should be passed
"true" or "false" rather than "1" or "0". This commit therefore makes
these changes, as noted in Josh's review.
Reported-by: Josh Triplett <josh@joshtriplett.org>
Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Provide a config option that enables the userspace
RCU extended quiescent state on every CPUs by default.
This is for testing purpose.
Cc: Alessio Igor Bogani <abogani@kernel.org>
Cc: Avi Kivity <avi@redhat.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Gilad Ben Yossef <gilad@benyossef.com>
Cc: Hakan Akkan <hakanakkan@gmail.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Kevin Hilman <khilman@ti.com>
Cc: Max Krasnyansky <maxk@qualcomm.com>
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: Sven-Thorsten Dietrich <thebigcorporation@gmail.com>
When exceptions or irq are about to resume userspace, if
the task needs to be rescheduled, the arch low level code
calls schedule() directly.
If we call it, it is because we have the TIF_RESCHED flag:
- It can be set after random local calls to set_need_resched()
(RCU, drm, ...)
- A wake up happened and the CPU needs preemption. This can
happen in several ways:
* Remotely: the remote waking CPU has set TIF_RESCHED and send the
wakee an IPI to schedule the new task.
* Remotely enqueued: the remote waking CPU sends an IPI to the target
and the wake up is made by the target.
* Locally: waking CPU == wakee CPU and the wakeup is done locally.
set_need_resched() is called without IPI.
In the case of local and remotely enqueued wake ups, the tick can
be restarted when we enqueue the new task and RCU can exit the
extended quiescent state at the same time. Then by the time we reach
irq exit path and we call schedule, we are not in RCU user mode.
But if we call schedule() only because something called set_need_resched(),
RCU may still be in user mode when we reach schedule.
Also if a wake up is done remotely, the CPU might see the TIF_RESCHED
flag and call schedule while the IPI has not yet happen to restart the
tick and exit RCU user mode.
We need to manually protect against these corner cases.
Create a new API schedule_user() that calls schedule() inside
rcu_user_exit()-rcu_user_enter() in order to protect it. Archs
will need to rely on it now to implement user preemption safely.
When an exception or an irq exits, and we are going to resume into
interrupted kernel code, the low level architecture code calls
preempt_schedule_irq() if there is a need to reschedule.
If the interrupt/exception occured between a call to rcu_user_enter()
(from syscall exit, exception exit, do_notify_resume exit, ...) and
a real resume to userspace (iret,...), preempt_schedule_irq() can be
called whereas RCU thinks we are in userspace. But preempt_schedule_irq()
is going to run kernel code and may be some RCU read side critical
section. We must exit the userspace extended quiescent state before
we call it.
To solve this, just call rcu_user_exit() in the beginning of
preempt_schedule_irq().
Clear the syscalls hook of a task when it's scheduled out so that if
the task migrates, it doesn't run the syscall slow path on a CPU
that might not need it.
Also set the syscalls hook on the next task if needed.
By default we don't want to enter into RCU extended quiescent
state while in userspace because doing this produces some overhead
(eg: use of syscall slowpath). Set it off by default and ready to
run when some feature like adaptive tickless need it.
Allow calls to rcu_user_enter() even if we are already
in userspace (as seen by RCU) and allow calls to rcu_user_exit()
even if we are already in the kernel.
This makes the APIs more flexible to be called from architectures.
Exception entries for example won't need to know if they come from
userspace before calling rcu_user_exit().
Create a new config option under the RCU menu that put
CPUs under RCU extended quiescent state (as in dynticks
idle mode) when they run in userspace. This require
some contribution from architectures to hook into kernel
and userspace boundaries.
The current implementation of RCU_FAST_NO_HZ tries reasonably hard to rid
the current CPU of RCU callbacks. This is appropriate when the CPU is
entering idle, where it doesn't have much useful to do anyway, but is most
definitely not what you want when transitioning to user-mode execution.
This commit therefore detects the adaptive-tick case, and refrains from
burning CPU time getting rid of RCU callbacks in that case.
In some cases, it is necessary to enter or exit userspace-RCU-idle mode
from an interrupt handler, for example, if some other CPU sends this
CPU a resched IPI. In this case, the current CPU would enter the IPI
handler in userspace-RCU-idle mode, but would need to exit the IPI handler
after having exited that mode.
To allow this to work, this commit adds two new APIs to TREE_RCU:
- rcu_user_enter_after_irq(). This must be called from an interrupt between
rcu_irq_enter() and rcu_irq_exit(). After the irq calls rcu_irq_exit(),
the irq handler will return into an RCU extended quiescent state.
In theory, this interrupt is never a nested interrupt, but in practice
it might interrupt softirq, which looks to RCU like a nested interrupt.
- rcu_user_exit_after_irq(). This must be called from a non-nesting
interrupt, interrupting an RCU extended quiescent state, also
between rcu_irq_enter() and rcu_irq_exit(). After the irq calls
rcu_irq_exit(), the irq handler will return in an RCU non-quiescent
state.
[ Combined with "Allow calls to rcu_exit_user_irq from nesting irqs." ]
RCU currently insists that only idle tasks can enter RCU idle mode, which
prohibits an adaptive tickless kernel (AKA nohz cpusets), which in turn
would mean that usermode execution would always take scheduling-clock
interrupts, even when there is only one task runnable on the CPU in
question.
This commit therefore adds rcu_user_enter() and rcu_user_exit(), which
allow non-idle tasks to enter RCU idle mode. These are quite similar
to rcu_idle_enter() and rcu_idle_exit(), respectively, except that they
omit the idle-task checks.
[ Updated to use "user" flag rather than separate check functions. ]
[ paulmck: Updated to drop exports of new functions based on Josh's patch
getting rid of the need for them. ]
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Resolved conflict in kernel/sched/core.c using Peter Zijlstra's
approach from https://lkml.org/lkml/2012/9/5/585.
The conflicts between kernel/rcutree.h and kernel/rcutree_plugin.h
were due to adjacent insertions and deletions, which were resolved
by simply accepting the changes on both branches.
Move the code that finds out to which context we account the
cputime into generic layer.
Archs that consider the whole time spent in the idle task as idle
time (ia64, powerpc) can rely on the generic vtime_account()
and implement vtime_account_system() and vtime_account_idle(),
letting the generic code to decide when to call which API.
Archs that have their own meaning of idle time, such as s390
that only considers the time spent in CPU low power mode as idle
time, can just override vtime_account().
Use a naming based on vtime as a prefix for virtual based
cputime accounting APIs:
- account_system_vtime() -> vtime_account()
- account_switch_vtime() -> vtime_task_switch()
It makes it easier to allow for further declension such
as vtime_account_system(), vtime_account_idle(), ... if we
want to find out the context we account to from generic code.
This also make it better to know on which subsystem these APIs
refer to.
'fixes.2012.09.23a', 'hotplug.2012.09.23a' and 'idlechop.2012.09.23a' into HEAD
bigrt.2012.09.23a contains additional commits to reduce scheduling latency
from RCU on huge systems (many hundrends or thousands of CPUs).
doctorture.2012.09.23a contains documentation changes and rcutorture fixes.
fixes.2012.09.23a contains miscellaneous fixes.
hotplug.2012.09.23a contains CPU-hotplug-related changes.
idle.2012.09.23a fixes architectures for which RCU no longer considered
the idle loop to be a quiescent state due to earlier
adaptive-dynticks changes. Affected architectures are alpha,
cris, frv, h8300, m32r, m68k, mn10300, parisc, score, xtensa,
and ia64.
We currently use a per socket order-0 page cache for tcp_sendmsg()
operations.
This page is used to build fragments for skbs.
Its done to increase probability of coalescing small write() into
single segments in skbs still in write queue (not yet sent)
But it wastes a lot of memory for applications handling many mostly
idle sockets, since each socket holds one page in sk->sk_sndmsg_page
Its also quite inefficient to build TSO 64KB packets, because we need
about 16 pages per skb on arches where PAGE_SIZE = 4096, so we hit
page allocator more than wanted.
This patch adds a per task frag allocator and uses bigger pages,
if available. An automatic fallback is done in case of memory pressure.
(up to 32768 bytes per frag, thats order-3 pages on x86)
This increases TCP stream performance by 20% on loopback device,
but also benefits on other network devices, since 8x less frags are
mapped on transmit and unmapped on tx completion. Alexander Duyck
mentioned a probable performance win on systems with IOMMU enabled.
Its possible some SG enabled hardware cant cope with bigger fragments,
but their ndo_start_xmit() should already handle this, splitting a
fragment in sub fragments, since some arches have PAGE_SIZE=65536
Successfully tested on various ethernet devices.
(ixgbe, igb, bnx2x, tg3, mellanox mlx4)
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Vijay Subramanian <subramanian.vijay@gmail.com>
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Tested-by: Vijay Subramanian <subramanian.vijay@gmail.com>
This patch splits trace event initialization in two stages:
* ftrace enable
* sysfs event entry creation
This allows to capture trace events from an earlier point
by using 'trace_event' kernel parameter and is important
to trace boot-up allocations.
Note that, in order to enable events at core_initcall,
it's necessary to move init_ftrace_syscalls() from
core_initcall to early_initcall.
Link: http://lkml.kernel.org/r/1347461277-25302-1-git-send-email-elezegarcia@gmail.com
Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com>
In our application, we have trace markers spread through user-space.
We have markers in GL, X, etc. These are super handy for Chrome's
about:tracing feature (Chrome + system + kernel trace view), but
can be very distracting when you're trying to debug a kernel issue.
I normally, use "grep -v tracing_mark_write" but it would be nice
if I could just temporarily disable markers all together.
Link: http://lkml.kernel.org/r/1347066739-26285-1-git-send-email-msb@chromium.org
CC: Frederic Weisbecker <fweisbec@gmail.com>
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Rabik and Paul reported two different issues related to the same few
lines of code.
Rabik's issue is that the nr_uninterruptible migration code is wrong in
that he sees artifacts due to this (Rabik please do expand in more
detail).
Paul's issue is that this code as it stands relies on us using
stop_machine() for unplug, we all would like to remove this assumption
so that eventually we can remove this stop_machine() usage altogether.
The only reason we'd have to migrate nr_uninterruptible is so that we
could use for_each_online_cpu() loops in favour of
for_each_possible_cpu() loops, however since nr_uninterruptible() is the
only such loop and its using possible lets not bother at all.
The problem Rabik sees is (probably) caused by the fact that by
migrating nr_uninterruptible we screw rq->calc_load_active for both rqs
involved.
So don't bother with fancy migration schemes (meaning we now have to
keep using for_each_possible_cpu()) and instead fold any nr_active delta
after we migrate all tasks away to make sure we don't have any skewed
nr_active accounting.
[ paulmck: Move call to calc_load_migration to CPU_DEAD to avoid
miscounting noted by Rakib. ]
Reported-by: Rakib Mullick <rakib.mullick@gmail.com>
Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Posting a callback after the CPU_DEAD notifier effectively leaks
that callback unless/until that CPU comes back online. Silence is
unhelpful when attempting to track down such leaks, so this commit emits
a WARN_ON_ONCE() and unconditionally leaks the callback when an offline
CPU attempts to register a callback. The rdp->nxttail[RCU_NEXT_TAIL] is
set to NULL in the CPU_DEAD notifier and restored in the CPU_UP_PREPARE
notifier, allowing _call_rcu() to determine exactly when posting callbacks
is illegal.
Currently, _rcu_barrier() relies on preempt_disable() to prevent
any CPU from going offline, which in turn depends on CPU hotplug's
use of __stop_machine().
This patch therefore makes _rcu_barrier() use get_online_cpus() to
block CPU-hotplug operations. This has the added benefit of removing
the need for _rcu_barrier() to adopt callbacks: Because CPU-hotplug
operations are excluded, there can be no callbacks to adopt. This
commit simplifies the code accordingly.
The print_cpu_stall_fast_no_hz() function attempts to print -1 when
the ->idle_gp_timer is not pending, but unsigned arithmetic causes it
to instead print ULONG_MAX, which is 4294967295 on 32-bit systems and
18446744073709551615 on 64-bit systems. Neither of these are the most
reader-friendly values, so this commit instead causes "timer not pending"
to be printed when ->idle_gp_timer is not pending.
Reported-by: Paul Walmsley <paul@pwsan.com>
