path: root/kernel
2008-11-28debug warnings: consolidate warn_slowpath and warn_on_slowpathArjan van de Ven
Impact: cleanup, code reduction warn_slowpath is a superset of warn_on_slowpath; just have warn_on_slowpath call warn_slowpath with a NULL 3rd argument. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-26Merge commit 'v2.6.28-rc6' into core/debugIngo Molnar
2008-11-20Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ftrace: fix dyn ftrace filter selection ftrace: make filtered functions effective on setting ftrace: fix set_ftrace_filter trace: introduce missing mutex_unlock() tracing: kernel/trace/trace.c: introduce missing kfree()
2008-11-19cgroups: fix a serious bug in cgroupstatsLi Zefan
Try this, and you'll get oops immediately: # cd Documentation/accounting/ # gcc -o getdelays getdelays.c # mount -t cgroup -o debug xxx /mnt # ./getdelays -C /mnt/tasks Because a normal file's dentry->d_fsdata is a pointer to struct cftype, not struct cgroup. After the patch, it returns EINVAL if we try to get cgroupstats from a normal file. Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x, 2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-19sprint_symbol(): use less stackHugh Dickins
sprint_symbol(), itself used when dumping stacks, has been wasting 128 bytes of stack: lookup the symbol directly into the buffer supplied by the caller, instead of using a locally declared namebuf. I believe the name != buffer strcpy() is obsolete: the design here dates from when module symbol lookup pointed into a supposedly const but sadly volatile table; nowadays it copies, but an uncalled strcpy() looks better here than the risk of a recursive BUG_ON(). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-19cgroup: fix potential deadlock in pre_destroyKAMEZAWA Hiroyuki
As Balbir pointed out, memcg's pre_destroy handler has potential deadlock. It has following lock sequence. cgroup_mutex (cgroup_rmdir) -> pre_destroy -> mem_cgroup_pre_destroy-> force_empty -> cpu_hotplug.lock. (lru_add_drain_all-> schedule_work-> get_online_cpus) But, cpuset has following. cpu_hotplug.lock (call notifier) -> cgroup_mutex. (within notifier) Then, this lock sequence should be fixed. Considering how pre_destroy works, it's not necessary to holding cgroup_mutex() while calling it. As a side effect, we don't have to wait at this mutex while memcg's force_empty works.(it can be long when there are tons of pages.) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-19cpuset: update top cpuset's mems after adding a nodeMiao Xie
After adding a node into the machine, top cpuset's mems isn't updated. By reviewing the code, we found that the update function cpuset_track_online_nodes() was invoked after node_states[N_ONLINE] changes. It is wrong because N_ONLINE just means node has pgdat, and if node has/added memory, we use N_HIGH_MEMORY. So, We should invoke the update function after node_states[N_HIGH_MEMORY] changes, just like its commit says. This patch fixes it. And we use notifier of memory hotplug instead of direct calling of cpuset_track_online_nodes(). Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Paul Menage <menage@google.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-19reintroduce accept4Ulrich Drepper
Introduce a new accept4() system call. The addition of this system call matches analogous changes in 2.6.27 (dup3(), evenfd2(), signalfd4(), inotify_init1(), epoll_create1(), pipe2()) which added new system calls that differed from analogous traditional system calls in adding a flags argument that can be used to access additional functionality. The accept4() system call is exactly the same as accept(), except that it adds a flags bit-mask argument. Two flags are initially implemented. (Most of the new system calls in 2.6.27 also had both of these flags.) SOCK_CLOEXEC causes the close-on-exec (FD_CLOEXEC) flag to be enabled for the new file descriptor returned by accept4(). This is a useful security feature to avoid leaking information in a multithreaded program where one thread is doing an accept() at the same time as another thread is doing a fork() plus exec(). More details here: http://udrepper.livejournal.com/20407.html "Secure File Descriptor Handling", Ulrich Drepper). The other flag is SOCK_NONBLOCK, which causes the O_NONBLOCK flag to be enabled on the new open file description created by accept4(). (This flag is merely a convenience, saving the use of additional calls fcntl(F_GETFL) and fcntl (F_SETFL) to achieve the same result. Here's a test program. Works on x86-32. Should work on x86-64, but I (mtk) don't have a system to hand to test with. It tests accept4() with each of the four possible combinations of SOCK_CLOEXEC and SOCK_NONBLOCK set/clear in 'flags', and verifies that the appropriate flags are set on the file descriptor/open file description returned by accept4(). I tested Ulrich's patch in this thread by applying against 2.6.28-rc2, and it passes according to my test program. /* test_accept4.c Copyright (C) 2008, Linux Foundation, written by Michael Kerrisk <mtk.manpages@gmail.com> Licensed under the GNU GPLv2 or later. */ #define _GNU_SOURCE #include <unistd.h> #include <sys/syscall.h> #include <sys/socket.h> #include <netinet/in.h> #include <stdlib.h> #include <fcntl.h> #include <stdio.h> #include <string.h> #define PORT_NUM 33333 #define die(msg) do { perror(msg); exit(EXIT_FAILURE); } while (0) /**********************************************************************/ /* The following is what we need until glibc gets a wrapper for accept4() */ /* Flags for socket(), socketpair(), accept4() */ #ifndef SOCK_CLOEXEC #define SOCK_CLOEXEC O_CLOEXEC #endif #ifndef SOCK_NONBLOCK #define SOCK_NONBLOCK O_NONBLOCK #endif #ifdef __x86_64__ #define SYS_accept4 288 #elif __i386__ #define USE_SOCKETCALL 1 #define SYS_ACCEPT4 18 #else #error "Sorry -- don't know the syscall # on this architecture" #endif static int accept4(int fd, struct sockaddr *sockaddr, socklen_t *addrlen, int flags) { printf("Calling accept4(): flags = %x", flags); if (flags != 0) { printf(" ("); if (flags & SOCK_CLOEXEC) printf("SOCK_CLOEXEC"); if ((flags & SOCK_CLOEXEC) && (flags & SOCK_NONBLOCK)) printf(" "); if (flags & SOCK_NONBLOCK) printf("SOCK_NONBLOCK"); printf(")"); } printf("\n"); #if USE_SOCKETCALL long args[6]; args[0] = fd; args[1] = (long) sockaddr; args[2] = (long) addrlen; args[3] = flags; return syscall(SYS_socketcall, SYS_ACCEPT4, args); #else return syscall(SYS_accept4, fd, sockaddr, addrlen, flags); #endif } /**********************************************************************/ static int do_test(int lfd, struct sockaddr_in *conn_addr, int closeonexec_flag, int nonblock_flag) { int connfd, acceptfd; int fdf, flf, fdf_pass, flf_pass; struct sockaddr_in claddr; socklen_t addrlen; printf("=======================================\n"); connfd = socket(AF_INET, SOCK_STREAM, 0); if (connfd == -1) die("socket"); if (connect(connfd, (struct sockaddr *) conn_addr, sizeof(struct sockaddr_in)) == -1) die("connect"); addrlen = sizeof(struct sockaddr_in); acceptfd = accept4(lfd, (struct sockaddr *) &claddr, &addrlen, closeonexec_flag | nonblock_flag); if (acceptfd == -1) { perror("accept4()"); close(connfd); return 0; } fdf = fcntl(acceptfd, F_GETFD); if (fdf == -1) die("fcntl:F_GETFD"); fdf_pass = ((fdf & FD_CLOEXEC) != 0) == ((closeonexec_flag & SOCK_CLOEXEC) != 0); printf("Close-on-exec flag is %sset (%s); ", (fdf & FD_CLOEXEC) ? "" : "not ", fdf_pass ? "OK" : "failed"); flf = fcntl(acceptfd, F_GETFL); if (flf == -1) die("fcntl:F_GETFD"); flf_pass = ((flf & O_NONBLOCK) != 0) == ((nonblock_flag & SOCK_NONBLOCK) !=0); printf("nonblock flag is %sset (%s)\n", (flf & O_NONBLOCK) ? "" : "not ", flf_pass ? "OK" : "failed"); close(acceptfd); close(connfd); printf("Test result: %s\n", (fdf_pass && flf_pass) ? "PASS" : "FAIL"); return fdf_pass && flf_pass; } static int create_listening_socket(int port_num) { struct sockaddr_in svaddr; int lfd; int optval; memset(&svaddr, 0, sizeof(struct sockaddr_in)); svaddr.sin_family = AF_INET; svaddr.sin_addr.s_addr = htonl(INADDR_ANY); svaddr.sin_port = htons(port_num); lfd = socket(AF_INET, SOCK_STREAM, 0); if (lfd == -1) die("socket"); optval = 1; if (setsockopt(lfd, SOL_SOCKET, SO_REUSEADDR, &optval, sizeof(optval)) == -1) die("setsockopt"); if (bind(lfd, (struct sockaddr *) &svaddr, sizeof(struct sockaddr_in)) == -1) die("bind"); if (listen(lfd, 5) == -1) die("listen"); return lfd; } int main(int argc, char *argv[]) { struct sockaddr_in conn_addr; int lfd; int port_num; int passed; passed = 1; port_num = (argc > 1) ? atoi(argv[1]) : PORT_NUM; memset(&conn_addr, 0, sizeof(struct sockaddr_in)); conn_addr.sin_family = AF_INET; conn_addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK); conn_addr.sin_port = htons(port_num); lfd = create_listening_socket(port_num); if (!do_test(lfd, &conn_addr, 0, 0)) passed = 0; if (!do_test(lfd, &conn_addr, SOCK_CLOEXEC, 0)) passed = 0; if (!do_test(lfd, &conn_addr, 0, SOCK_NONBLOCK)) passed = 0; if (!do_test(lfd, &conn_addr, SOCK_CLOEXEC, SOCK_NONBLOCK)) passed = 0; close(lfd); exit(passed ? EXIT_SUCCESS : EXIT_FAILURE); } [mtk.manpages@gmail.com: rewrote changelog, updated test program] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Tested-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-19Merge branch 'tip/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into tracing/urgent
2008-11-19ftrace: fix dyn ftrace filter selectionSteven Rostedt
Impact: clean up and fix for dyn ftrace filter selection The previous logic of the dynamic ftrace selection of enabling or disabling functions was complex and incorrect. This patch simplifies the code and corrects the usage. This simplification also makes the code more robust. Here is the correct logic: Given a function that can be traced by dynamic ftrace: If the function is not to be traced, disable it if it was enabled. (this is if the function is in the set_ftrace_notrace file) (filter is on if there exists any functions in set_ftrace_filter file) If the filter is on, and we are enabling functions: If the function is in set_ftrace_filter, enable it if it is not already enabled. If the function is not in set_ftrace_filter, disable it if it is not already disabled. Otherwise, if the filter is off and we are enabling function tracing: Enable the function if it is not already enabled. Otherwise, if we are disabling function tracing: Disable the function if it is not already disabled. This code now sets or clears the ENABLED flag in the record, and at the end it will enable the function if the flag is set, or disable the function if the flag is cleared. The parameters for the function that does the above logic is also simplified. Instead of passing in confusing "new" and "old" where they might be swapped if the "enabled" flag is not set. The old logic even had one of the above always NULL and had to be filled in. The new logic simply passes in one parameter called "nop". A "call" is calculated in the code, and at the end of the logic, when we know we need to either disable or enable the function, we can then use the "nop" and "call" properly. This code is more robust than the previous version. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-19ftrace: make filtered functions effective on settingSteven Rostedt
Impact: fix filter selection to apply when set It can be confusing when the set_filter_functions is set (or cleared) and the functions being recorded by the dynamic tracer does not match. This patch causes the code to be updated if the function tracer is enabled and the filter is changed. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-19ftrace: fix set_ftrace_filterSteven Rostedt
Impact: fix of output of set_ftrace_filter The commit "ftrace: do not show freed records in available_filter_functions" Removed a bit too much from the set_ftrace_filter code, where we now see all functions in the set_ftrace_filter file even when we set a filter. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-18trace: introduce missing mutex_unlock()Vegard Nossum
Impact: fix tracing buffer mutex leak in case of allocation failure This error was spotted by this semantic patch: http://www.emn.fr/x-info/coccinelle/mut.html It looks correct as far as I can tell. Please review. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-18Merge branch 'linus' into tracing/urgentIngo Molnar
2008-11-18Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: hold extra reference to bio in blk_rq_map_user_iov() relay: fix cpu offline problem Release old elevator on change elevator block: fix boot failure with CONFIG_DEBUG_BLOCK_EXT_DEVT=y and nash block/md: fix md autodetection block: make add_partition() return pointer to hd_struct block: fix add_partition() error path
2008-11-18suspend: use WARN not WARN_ON to print the messageArjan van de Ven
By using WARN(), kerneloops.org can collect which component is causing the delay and make statistics about that. suspend_test_finish() is currently the number 2 item but unless we can collect who's causing it we're not going to be able to fix the hot topic ones.. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-18Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kernel/profile.c: fix section mismatch warning function tracing: fix wrong pos computing when read buffer has been fulfilled tracing: fix mmiotrace resizing crash ring-buffer: no preempt for sched_clock() ring-buffer: buffer record on/off switch
2008-11-18Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: cpuset: fix regression when failed to generate sched domains sched, signals: fix the racy usage of ->signal in account_group_xxx/run_posix_cpu_timers sched: fix kernel warning on /proc/sched_debug access sched: correct sched-rt-group.txt pathname in init/Kconfig
2008-11-18tracing: kernel/trace/trace.c: introduce missing kfree()Julia Lawall
Impact: fix memory leak Error handling code following a kzalloc should free the allocated data. The semantic match that finds the problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; statement S; expression E; identifier f,l; position p1,p2; expression *ptr != NULL; @@ ( if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S | x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...); ... if (x == NULL) S ) <... when != x when != if (...) { <+...x...+> } x->f = E ...> ( return \(0\|<+...x...+>\|ptr\); | return@p2 ...; ) @script:python@ p1 << r.p1; p2 << r.p2; @@ print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-18relay: fix cpu offline problemLai Jiangshan
relay_open() will close allocated buffers when failed. but if cpu offlined, some buffer will not be closed. this patch fixed it. and did cleanup for relay_reset() too. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-18kernel/profile.c: fix section mismatch warningRakib Mullick
Impact: fix section mismatch warning in kernel/profile.c Here, profile_nop function has been called from a non-init function create_hash_tables(void). Which generetes a section mismatch warning. Previously, create_hash_tables(void) was a init function. So, removing __init from create_hash_tables(void) requires profile_nop to be non-init. This patch makes profile_nop function inline and fixes the following warning: WARNING: vmlinux.o(.text+0x6ebb6): Section mismatch in reference from the function create_hash_tables() to the function .init.text:profile_nop() The function create_hash_tables() references the function __init profile_nop(). This is often because create_hash_tables lacks a __init annotation or the annotation of profile_nop is wrong. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-18cpuset: fix regression when failed to generate sched domainsLi Zefan
Impact: properly rebuild sched-domains on kmalloc() failure When cpuset failed to generate sched domains due to kmalloc() failure, the scheduler should fallback to the single partition 'fallback_doms' and rebuild sched domains, but now it only destroys but not rebuilds sched domains. The regression was introduced by: | commit dfb512ec4834116124da61d6c1ee10fd0aa32bd6 | Author: Max Krasnyansky <maxk@qualcomm.com> | Date: Fri Aug 29 13:11:41 2008 -0700 | | sched: arch_reinit_sched_domains() must destroy domains to force rebuild After the above commit, partition_sched_domains(0, NULL, NULL) will only destroy sched domains and partition_sched_domains(1, NULL, NULL) will create the default sched domain. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Max Krasnyansky <maxk@qualcomm.com> Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-17Remove -mno-spe flags as they dont belongKumar Gala
For some unknown reason at Steven Rostedt added in disabling of the SPE instruction generation for e500 based PPC cores in commit 6ec562328fda585be2d7f472cfac99d3b44d362a. We are removing it because: 1. It generates e500 kernels that don't work 2. its not the correct set of flags to do this 3. we handle this in the arch/powerpc/Makefile already 4. its unknown in talking to Steven why he did this Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Tested-and-Acked-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-17sched, signals: fix the racy usage of ->signal in ↵Oleg Nesterov
account_group_xxx/run_posix_cpu_timers Impact: fix potential NULL dereference Contrary to ad474caca3e2a0550b7ce0706527ad5ab389a4d4 changelog, other acct_group_xxx() helpers can be called after exit_notify() by timer tick. Thanks to Roland for pointing out this. Somehow I missed this simple fact when I read the original patch, and I am afraid I confused Frank during the discussion. Sorry. Fortunately, these helpers work with current, we can check ->exit_state to ensure that ->signal can't go away under us. Also, add the comment and compiler barrier to account_group_exec_runtime(), to make sure we load ->signal only once. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-16stop_machine: fix race with return value (fixes Bug #11989)Rusty Russell
Bug #11989: Suspend failure on NForce4-based boards due to chanes in stop_machine We should not access active.fnret outside the lock; in theory the next stop_machine could overwrite it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-16function tracing: fix wrong pos computing when read buffer has been fulfilledwalimis
Impact: make output of available_filter_functions complete phenomenon: The first value of dyn_ftrace_total_info is not equal with `cat available_filter_functions | wc -l`, but they should be equal. root cause: When printing functions with seq_printf in t_show, if the read buffer is just overflowed by current function record, then this function won't be printed to user space through read buffer, it will just be dropped. So we can't see this function printing. So, every time the last function to fill the read buffer, if overflowed, will be dropped. This also applies to set_ftrace_filter if set_ftrace_filter has more bytes than read buffer. fix: Through checking return value of seq_printf, if less than 0, we know this function doesn't be printed. Then we decrease position to force this function to be printed next time, in next read buffer. Another little fix is to show correct allocating pages count. Signed-off-by: walimis <walimisdev@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-16sched: fix kernel warning on /proc/sched_debug accessIngo Molnar
Luis Henriques reported that with CONFIG_PREEMPT=y + CONFIG_PREEMPT_DEBUG=y + CONFIG_SCHED_DEBUG=y + CONFIG_LATENCYTOP=y enabled, the following warning triggers when using latencytop: > [ 775.663239] BUG: using smp_processor_id() in preemptible [00000000] code: latencytop/6585 > [ 775.663303] caller is native_sched_clock+0x3a/0x80 > [ 775.663314] Pid: 6585, comm: latencytop Tainted: G W 2.6.28-rc4-00355-g9c7c354 #1 > [ 775.663322] Call Trace: > [ 775.663343] [<ffffffff803a94e4>] debug_smp_processor_id+0xe4/0xf0 > [ 775.663356] [<ffffffff80213f7a>] native_sched_clock+0x3a/0x80 > [ 775.663368] [<ffffffff80213e19>] sched_clock+0x9/0x10 > [ 775.663381] [<ffffffff8024550d>] proc_sched_show_task+0x8bd/0x10e0 > [ 775.663395] [<ffffffff8034466e>] sched_show+0x3e/0x80 > [ 775.663408] [<ffffffff8031039b>] seq_read+0xdb/0x350 > [ 775.663421] [<ffffffff80368776>] ? security_file_permission+0x16/0x20 > [ 775.663435] [<ffffffff802f4198>] vfs_read+0xc8/0x170 > [ 775.663447] [<ffffffff802f4335>] sys_read+0x55/0x90 > [ 775.663460] [<ffffffff8020c67a>] system_call_fastpath+0x16/0x1b > ... This breakage was caused by me via: 7cbaef9: sched: optimize sched_clock() a bit Change the calls to cpu_clock(). Reported-by: Luis Henriques <henrix@sapo.pt>
2008-11-15Fix inotify watch removal/umount racesAl Viro
Inotify watch removals suck violently. To kick the watch out we need (in this order) inode->inotify_mutex and ih->mutex. That's fine if we have a hold on inode; however, for all other cases we need to make damn sure we don't race with umount. We can *NOT* just grab a reference to a watch - inotify_unmount_inodes() will happily sail past it and we'll end with reference to inode potentially outliving its superblock. Ideally we just want to grab an active reference to superblock if we can; that will make sure we won't go into inotify_umount_inodes() until we are done. Cleanup is just deactivate_super(). However, that leaves a messy case - what if we *are* racing with umount() and active references to superblock can't be acquired anymore? We can bump ->s_count, grab ->s_umount, which will almost certainly wait until the superblock is shut down and the watch in question is pining for fjords. That's fine, but there is a problem - we might have hit the window between ->s_active getting to 0 / ->s_count - below S_BIAS (i.e. the moment when superblock is past the point of no return and is heading for shutdown) and the moment when deactivate_super() acquires ->s_umount. We could just do drop_super() yield() and retry, but that's rather antisocial and this stuff is luser-triggerable. OTOH, having grabbed ->s_umount and having found that we'd got there first (i.e. that ->s_root is non-NULL) we know that we won't race with inotify_umount_inodes(). So we could grab a reference to watch and do the rest as above, just with drop_super() instead of deactivate_super(), right? Wrong. We had to drop ih->mutex before we could grab ->s_umount. So the watch could've been gone already. That still can be dealt with - we need to save watch->wd, do idr_find() and compare its result with our pointer. If they match, we either have the damn thing still alive or we'd lost not one but two races at once, the watch had been killed and a new one got created with the same ->wd at the same address. That couldn't have happened in inotify_destroy(), but inotify_rm_wd() could run into that. Still, "new one got created" is not a problem - we have every right to kill it or leave it alone, whatever's more convenient. So we can use idr_find(...) == watch && watch->inode->i_sb == sb as "grab it and kill it" check. If it's been our original watch, we are fine, if it's a newcomer - nevermind, just pretend that we'd won the race and kill the fscker anyway; we are safe since we know that its superblock won't be going away. And yes, this is far beyond mere "not very pretty"; so's the entire concept of inotify to start with. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-15Move "exit_robust_list" into mm_release()Linus Torvalds
We don't want to get rid of the futexes just at exit() time, we want to drop them when doing an execve() too, since that gets rid of the previous VM image too. Doing it at mm_release() time means that we automatically always do it when we disassociate a VM map from the task. Reported-by: pageexec@freemail.hu Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Brad Spengler <spender@grsecurity.net> Cc: Alex Efros <powerman@powerman.name> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-13tracing: fix mmiotrace resizing crashIngo Molnar
Pekka reported a crash when resizing the mmiotrace tracer (if only mmiotrace is enabled). This happens because in that case we do not allocate the max buffer, but we try to use it. Make ring_buffer_resize() idempotent against NULL buffers. Reported-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: fix init_idle()'s use of sched_clock() sched: fix stale value in average load per task
2008-11-12kernel/kprobes.c: don't pad kretprobe_table_locks[] on uniprocessor buildsAndrew Morton
We only need the cacheline padding on SMP kernels. Saves 6k: text data bss dec hex filename 5713 388 8840 14941 3a5d kernel/kprobes.o 5713 388 2632 8733 221d kernel/kprobes.o Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12kprobes: disable preempt for module_text_address() and kernel_text_address()Masami Hiramatsu
__register_kprobe() can be preempted after checking probing address but before module_text_address() or try_module_get(), and in this interval the module can be unloaded. In that case, try_module_get(probed_mod) will access to invalid address, or kprobe will probe invalid address. This patch uses preempt_disable() to protect it and uses __module_text_address() and __kernel_text_address(). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12freezer_cg: disable writing freezer.state of root cgroupLi Zefan
With this change, control file 'freezer.state' doesn't exist in root cgroup, making root cgroup unfreezable. I think it's reasonable to disallow freeze tasks in the root cgroup. And then we can avoid fork overhead when freezer subsystem is compiled but not used. Also make writing invalid value to freezer.state returns EINVAL rather than EIO. This is more consistent with other cgroup subsystem. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12freezer_cg: remove task_lock from freezer_fork()Li Zefan
In theory the task can be moved to another cgroup and the freezer will be freed right after task_lock is dropped, so the lock results in zero protection. But in the case of freezer_fork() no lock is needed, since the task is not in tasklist yet so it won't be moved to another cgroup, so task->cgroups won't be changed or invalidated. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12sched: fix init_idle()'s use of sched_clock()Ingo Molnar
Maciej Rutecki reported: > I have this bug during suspend to disk: > > [ 188.592151] Enabling non-boot CPUs ... > [ 188.592151] SMP alternatives: switching to SMP code > [ 188.666058] BUG: using smp_processor_id() in preemptible > [00000000] > code: suspend_to_disk/2934 > [ 188.666064] caller is native_sched_clock+0x2b/0x80 Which, as noted by Linus, was caused by me, via: 7cbaef9c "sched: optimize sched_clock() a bit" Move the rq locking a bit earlier in the initialization sequence, that will make the sched_clock() call in init_idle() non-preemptible. Reported-by: Maciej Rutecki <maciej.rutecki@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12sched: fix stale value in average load per taskBalbir Singh
Impact: fix load balancer load average calculation accuracy cpu_avg_load_per_task() returns a stale value when nr_running is 0. It returns an older stale (caculated when nr_running was non zero) value. This patch returns and sets rq->avg_load_per_task to zero when nr_running is 0. Compile and boot tested on a x86_64 box. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12ring-buffer: no preempt for sched_clock()Steven Rostedt
Impact: disable preemption when calling sched_clock() The ring_buffer_time_stamp still uses sched_clock as its counter. But it is a bug to call it with preemption enabled. This requirement should not be pushed to the ring_buffer_time_stamp callers, so the ring_buffer_time_stamp needs to disable preemption when calling sched_clock. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12hrtimer: clean up unused callback modesPeter Zijlstra
Impact: cleanup git grep HRTIMER_CB_IRQSAFE revealed half the callback modes are actually unused. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-11Merge branch 'devel' of ↵Ingo Molnar
2008-11-11ring-buffer: buffer record on/off switchSteven Rostedt
Impact: enable/disable ring buffer recording API added Several kernel developers have requested that there be a way to stop recording into the ring buffers with a simple switch that can also be enabled from userspace. This patch addes a new kernel API to the ring buffers called: tracing_on() tracing_off() When tracing_off() is called, all ring buffers will not be able to record into their buffers. tracing_on() will enable the ring buffers again. These two act like an on/off switch. That is, there is no counting of the number of times tracing_off or tracing_on has been called. A new file is added to the debugfs/tracing directory called tracing_on This allows for userspace applications to also flip the switch. echo 0 > debugfs/tracing/tracing_on disables the tracing. echo 1 > /debugfs/tracing/tracing_on enables it. Note, this does not disable or enable any tracers. It only sets or clears a flag that needs to be set in order for the ring buffers to write to their buffers. It is a global flag, and affects all ring buffers. The buffers start out with tracing_on enabled. There are now three flags that control recording into the buffers: tracing_on: which affects all ring buffer tracers. buffer->record_disabled: which affects an allocated buffer, which may be set if an anomaly is detected, and tracing is disabled. cpu_buffer->record_disabled: which is set by tracing_stop() or if an anomaly is detected. tracing_start can not reenable this if an anomaly occurred. The userspace debugfs/tracing/tracing_enabled is implemented with tracing_stop() but the user space code can not enable it if the kernel called tracing_stop(). Userspace can enable the tracing_on even if the kernel disabled it. It is just a switch used to stop tracing if a condition was hit. tracing_on is not for protecting critical areas in the kernel nor is it for stopping tracing if an anomaly occurred. This is because userspace can reenable it at any time. Side effect: With this patch, I discovered a dead variable in ftrace.c called tracing_on. This patch removes it. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2008-11-11Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: timers: handle HRTIMER_CB_IRQSAFE_UNLOCKED correctly from softirq context nohz: disable tick_nohz_kick_tick() for now irq: call __irq_enter() before calling the tick_idle_check x86: HPET: enter hpet_interrupt_handler with interrupts disabled x86: HPET: read from HPET_Tn_CMP() not HPET_T0_CMP x86: HPET: convert WARN_ON to WARN_ON_ONCE
2008-11-11Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: release buddies on yield fix for account_group_exec_runtime(), make sure ->signal can't be freed under rq->lock sched: clean up debug info
2008-11-11sched: release buddies on yieldPeter Zijlstra
Clear buddies on yield, so that the buddy rules don't schedule them despite them being placed right-most. This fixed a performance regression with yield-happy binary JVMs. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu> Tested-by: Lin Ming <ming.m.lin@intel.com>
2008-11-11timers: handle HRTIMER_CB_IRQSAFE_UNLOCKED correctly from softirq contextGautham R Shenoy
Impact: fix incorrect locking triggered during hotplug-intense stress-tests While migrating the the CB_IRQSAFE_UNLOCKED timers during a cpu-offline, we queue them on the cb_pending list, so that they won't go stale. Thus, when the callbacks of the timers run from the softirq context, they could run into potential deadlocks, since these callbacks assume that they're running with irq's disabled, thereby annoying lockdep! Fix this by emulating hardirq context while running these callbacks from the hrtimer softirq. ================================= [ INFO: inconsistent lock state ] 2.6.27 #2 -------------------------------- inconsistent {in-hardirq-W} -> {hardirq-on-W} usage. ksoftirqd/0/4 [HC0[0]:SC1[1]:HE1:SE0] takes: (&rq->lock){++..}, at: [<c011db84>] sched_rt_period_timer+0x9e/0x1fc {in-hardirq-W} state was registered at: [<c014103c>] __lock_acquire+0x549/0x121e [<c0107890>] native_sched_clock+0x88/0x99 [<c013aa12>] clocksource_get_next+0x39/0x3f [<c0139abc>] update_wall_time+0x616/0x7df [<c0141d6b>] lock_acquire+0x5a/0x74 [<c0121724>] scheduler_tick+0x3a/0x18d [<c047ed45>] _spin_lock+0x1c/0x45 [<c0121724>] scheduler_tick+0x3a/0x18d [<c0121724>] scheduler_tick+0x3a/0x18d [<c012c436>] update_process_times+0x3a/0x44 [<c013c044>] tick_periodic+0x63/0x6d [<c013c062>] tick_handle_periodic+0x14/0x5e [<c010568c>] timer_interrupt+0x44/0x4a [<c0150c9f>] handle_IRQ_event+0x13/0x3d [<c0151c14>] handle_level_irq+0x79/0xbd [<c0105634>] do_IRQ+0x69/0x7d [<c01041e4>] common_interrupt+0x28/0x30 [<c047007b>] aac_probe_one+0x1a3/0x3f3 [<c047ec2d>] _spin_unlock_irqrestore+0x36/0x39 [<c01512b4>] setup_irq+0x1be/0x1f9 [<c065d70b>] start_kernel+0x259/0x2c5 [<ffffffff>] 0xffffffff irq event stamp: 50102 hardirqs last enabled at (50102): [<c047ebf4>] _spin_unlock_irq+0x20/0x23 hardirqs last disabled at (50101): [<c047edc2>] _spin_lock_irq+0xa/0x4b softirqs last enabled at (50088): [<c0128ba6>] do_softirq+0x37/0x4d softirqs last disabled at (50099): [<c0128ba6>] do_softirq+0x37/0x4d other info that might help us debug this: no locks held by ksoftirqd/0/4. stack backtrace: Pid: 4, comm: ksoftirqd/0 Not tainted 2.6.27 #2 [<c013f6cb>] print_usage_bug+0x13e/0x147 [<c013fef5>] mark_lock+0x493/0x797 [<c01410b1>] __lock_acquire+0x5be/0x121e [<c0141d6b>] lock_acquire+0x5a/0x74 [<c011db84>] sched_rt_period_timer+0x9e/0x1fc [<c047ed45>] _spin_lock+0x1c/0x45 [<c011db84>] sched_rt_period_timer+0x9e/0x1fc [<c011db84>] sched_rt_period_timer+0x9e/0x1fc [<c01210fd>] finish_task_switch+0x41/0xbd [<c0107890>] native_sched_clock+0x88/0x99 [<c011dae6>] sched_rt_period_timer+0x0/0x1fc [<c0136dda>] run_hrtimer_pending+0x54/0xe5 [<c011dae6>] sched_rt_period_timer+0x0/0x1fc [<c0128afb>] __do_softirq+0x7b/0xef [<c0128ba6>] do_softirq+0x37/0x4d [<c0128c12>] ksoftirqd+0x56/0xc5 [<c0128bbc>] ksoftirqd+0x0/0xc5 [<c0134649>] kthread+0x38/0x5d [<c0134611>] kthread+0x0/0x5d [<c0104477>] kernel_thread_helper+0x7/0x10 ======================= Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-11fix for account_group_exec_runtime(), make sure ->signal can't be freed ↵Oleg Nesterov
under rq->lock Impact: fix hang/crash on ia64 under high load This is ugly, but the simplest patch by far. Unlike other similar routines, account_group_exec_runtime() could be called "implicitly" from within scheduler after exit_notify(). This means we can race with the parent doing release_task(), we can't just check ->signal != NULL. Change __exit_signal() to do spin_unlock_wait(&task_rq(tsk)->lock) before __cleanup_signal() to make sure ->signal can't be freed under task_rq(tsk)->lock. Note that task_rq_unlock_wait() doesn't care about the case when tsk changes cpu/rq under us, this should be OK. Thanks to Ingo who nacked my previous buggy patch. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Reported-by: Doug Chapman <doug.chapman@hp.com>
2008-11-10ring-buffer: prevent infinite looping on time stampingSteven Rostedt
Impact: removal of unnecessary looping The lockless part of the ring buffer allows for reentry into the code from interrupts. A timestamp is taken, a test is preformed and if it detects that an interrupt occurred that did tracing, it tries again. The problem arises if the timestamp code itself causes a trace. The detection will detect this and loop again. The difference between this and an interrupt doing tracing, is that this will fail every time, and cause an infinite loop. Currently, we test if the loop happens 1000 times, and if so, it will produce a warning and disable the ring buffer. The problem with this approach is that it makes it difficult to perform some types of tracing (tracing the timestamp code itself). Each trace entry has a delta timestamp from the previous entry. If a trace entry is reserved but and interrupt occurs and traces before the previous entry is commited, the delta timestamp for that entry will be zero. This actually makes sense in terms of tracing, because the interrupt entry happened before the preempted entry was commited, so one may consider the two happening at the same time. The order is still preserved in the buffer. With this idea, instead of trying to get a new timestamp if an interrupt made it in between the timestamp and the test, the entry could simply make the delta zero and continue. This will prevent interrupts or tracers in the timer code from causing the above loop. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2008-11-10ftrace: disable tracing on resizeSteven Rostedt
Impact: fix for bug on resize This patch addresses the bug found here: http://bugzilla.kernel.org/show_bug.cgi?id=11996 When ftrace converted to the new unified trace buffer, the resizing of the buffer was not protected as much as it was originally. If tracing is performed while the resize occurs, then the buffer can be corrupted. This patch disables all ftrace buffer modifications before a resize takes place. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2008-11-10nohz: disable tick_nohz_kick_tick() for nowThomas Gleixner
Impact: nohz powersavings and wakeup regression commit fb02fbc14d17837b4b7b02dbb36142c16a7bf208 (NOHZ: restart tick device from irq_enter()) causes a serious wakeup regression. While the patch is correct it does not take into account that spurious wakeups happen on x86. A fix for this issue is available, but we just revert to the .27 behaviour and let long running softirqs screw themself. Disable it for now. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
