path: root/kernel
2005-11-09[PATCH] optimize activate_task()Chen, Kenneth W
recalc_task_prio() is called from activate_task() to calculate dynamic priority and interactive credit for the activating task. For real-time scheduling process, all that dynamic calculation is thrown away at the end because rt priority is fixed. Patch to optimize recalc_task_prio() away for rt processes. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <piggin@cyberone.com.au> Cc: Con Kolivas <kernel@kolivas.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09Fix ptrace self-attach ruleLinus Torvalds
Before we did CLONE_THREAD, the way to check whether we were attaching to ourselves was to just check "current == task", but with CLONE_THREAD we should check that the thread group ID matches instead. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: resched and cpu_idle reworkNick Piggin
Make some changes to the NEED_RESCHED and POLLING_NRFLAG to reduce confusion, and make their semantics rigid. Improves efficiency of resched_task and some cpu_idle routines. * In resched_task: - TIF_NEED_RESCHED is only cleared with the task's runqueue lock held, and as we hold it during resched_task, then there is no need for an atomic test and set there. The only other time this should be set is when the task's quantum expires, in the timer interrupt - this is protected against because the rq lock is irq-safe. - If TIF_NEED_RESCHED is set, then we don't need to do anything. It won't get unset until the task get's schedule()d off. - If we are running on the same CPU as the task we resched, then set TIF_NEED_RESCHED and no further action is required. - If we are running on another CPU, and TIF_POLLING_NRFLAG is *not* set after TIF_NEED_RESCHED has been set, then we need to send an IPI. Using these rules, we are able to remove the test and set operation in resched_task, and make clear the previously vague semantics of POLLING_NRFLAG. * In idle routines: - Enter cpu_idle with preempt disabled. When the need_resched() condition becomes true, explicitly call schedule(). This makes things a bit clearer (IMO), but haven't updated all architectures yet. - Many do a test and clear of TIF_NEED_RESCHED for some reason. According to the resched_task rules, this isn't needed (and actually breaks the assumption that TIF_NEED_RESCHED is only cleared with the runqueue lock held). So remove that. Generally one less locked memory op when switching to the idle thread. - Many idle routines clear TIF_POLLING_NRFLAG, and only set it in the inner most polling idle loops. The above resched_task semantics allow it to be set until before the last time need_resched() is checked before going into a halt requiring interrupt wakeup. Many idle routines simply never enter such a halt, and so POLLING_NRFLAG can be always left set, completely eliminating resched IPIs when rescheduling the idle task. POLLING_NRFLAG width can be increased, to reduce the chance of resched IPIs. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Con Kolivas <kernel@kolivas.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: consider migration thread with smp niceCon Kolivas
The intermittent scheduling of the migration thread at ultra high priority makes the smp nice handling see that runqueue as being heavily loaded. The migration thread itself actually handles the balancing so its influence on priority balancing should be ignored. Signed-off-by: Con Kolivas <kernel@kolivas.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: correct smp_nice_biasCon Kolivas
The priority biasing was off by mutliplying the total load by the total priority bias and this ruins the ratio of loads between runqueues. This patch should correct the ratios of loads between runqueues to be proportional to overall load. -2nd attempt. From: Dave Kleikamp <shaggy@austin.ibm.com> This patch fixes a divide-by-zero error that I hit on a two-way i386 machine. rq->nr_running is tested to be non-zero, but may change by the time it is used in the division. Saving the value to a local variable ensures that the same value that is checked is used in the division. Signed-off-by: Con Kolivas <kernel@kolivas.org> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: smp nice bias busy queues on idle rebalanceCon Kolivas
To intensify the 'nice' support across physical cpus on SMP we can bias the loads on idle rebalancing. To prevent idle rebalance from trying to pull tasks from queues that appear heavily loaded we only bias the load if there is more than one task running. Add some minor micro-optimisations and have only one return from __source_load and __target_load functions. Fix the fact that target_load was not biased by priority when type == 0. Signed-off-by: Con Kolivas <kernel@kolivas.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: account rt tasks in prio_bias()Con Kolivas
Real time tasks' effect on prio_bias should be based on their real time priority level instead of their static_prio which is based on nice. Signed-off-by: Con Kolivas <kernel@kolivas.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: change prio bias only if queuedCon Kolivas
prio_bias should only be adjusted in set_user_nice if p is actually currently queued. Signed-off-by: Con Kolivas <kernel@kolivas.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: implement nice support across physical cpus on SMPCon Kolivas
This patch implements 'nice' support across physical cpus on SMP. It introduces an extra runqueue variable prio_bias which is the sum of the (inverted) static priorities of all the tasks on the runqueue. This is then used to bias busy rebalancing between runqueues to obtain good distribution of tasks of different nice values. By biasing the balancing only during busy rebalancing we can avoid having any significant loss of throughput by not affecting the carefully tuned idle balancing already in place. If all tasks are running at the same nice level this code should also have minimal effect. The code is optimised out in the !CONFIG_SMP case. Signed-off-by: Con Kolivas <kernel@kolivas.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] swsusp: rework swsusp_suspendRafael J. Wysocki
This patch makes only the functions in swsusp.c call functions in snapshot.c and not both ways.  It also moves the check for available swap out of swsusp_suspend() which is necessary for separating the swap-handling functions in swsusp from the core code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] swsusp: simplify pagedir relocationRafael J. Wysocki
This patch simplifies the relocation of the page backup list (aka pagedir) during resume. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] swsusp: reduce code duplicationRafael J. Wysocki
The changes made by this patch are necessary for the pagedir relocation simplification in the next patch.  Additionally, these changes allow us to drop check_pagedir() and make get_safe_page() be a one-line wrapper around alloc_image_page() (get_safe_page() goes to snapshot.c, because alloc_image_page() is static and it does not make sense to export it). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sleep: Fix oops in enter_statePavel Machek
If ACPI sleep is not configured, but someone still wants to run swsusp, he'd get oops in enter_state. This is regression since 2.6.14 and this fixes it. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] quieten softlockup at bootAnton Blanchard
On a large SMP box we get a lot of softlockup thread XX started lines. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] cpu hotplug: fix locking in cpufreq driversAshok Raj
When calling target drivers to set frequency, we take cpucontrol lock. When we modified the code to accomodate CPU hotplug, there was an attempt to take a double lock of cpucontrol leading to a deadlock. Since the current thread context is already holding the cpucontrol lock, we dont need to make another attempt to acquire it. Now we leave a trace in current->flags indicating current thread already is under cpucontrol lock held, so we dont attempt to do this another time. Thanks to Andrew Morton for the beating:-) From: Brice Goglin <Brice.Goglin@ens-lyon.org> Build fix (akpm: this patch is still unpleasant. Ashok continues to look for a cleaner solution, doesn't he? ;)) Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-08[PATCH] Fix sysctl unregistration oops (CVE-2005-2709)Al Viro
You could open the /proc/sys/net/ipv4/conf/<if>/<whatever> file, then wait for interface to go away, try to grab as much memory as possible in hope to hit the (kfreed) ctl_table. Then fill it with pointers to your function. Then do read from file you've opened and if you are lucky, you'll get it called as ->proc_handler() in kernel mode. So this is at least an Oops and possibly more. It does depend on an interface going away though, so less of a security risk than it would otherwise be. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
2005-11-07[PATCH] saner handling of auto_acct_off() and DQUOT_OFF() in umountAl Viro
The way we currently deal with quota and process accounting that might keep vfsmount busy at umount time is inherently broken; we try to turn them off just in case (not quite correctly, at that) and a) pray umount doesn't fail (otherwise they'll stay turned off) b) pray nobody doesn anything funny just as we turn quota off Moreover, LSM provides hooks for doing the same sort of broken logics. The proper way to deal with that is to introduce the second kind of reference to vfsmount. Semantics: - when the last normal reference is dropped, all special ones are converted to normal ones and if there had been any, cleanup is done. - normal reference can be cloned into a special one - special reference can be converted to normal one; that's a no-op if we'd already passed the point of no return (i.e. mntput() had converted special references to normal and started cleanup). The way it works: e.g. starting process accounting converts the vfsmount reference pinned by the opened file into special one and turns it back to normal when it gets shut down; acct_auto_close() is done when no normal references are left. That way it does *not* obstruct umount(2) and it silently gets turned off when the last normal reference to vfsmount is gone. Which is exactly what we want... The same should be done by LSM module that holds some internal references to vfsmount and wants to shut them down on umount - it should make them special and security_sb_umount_close() will be called exactly when the last normal reference to vfsmount is gone. quota handling is even simpler - we don't use normal file IO anymore, so there's no need to hold vfsmounts at all. DQUOT_OFF() is done from deactivate_super(), where it really belongs. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[SPARC64] mm: context switch ptlockHugh Dickins
sparc64 is unique among architectures in taking the page_table_lock in its context switch (well, cris does too, but erroneously, and it's not yet SMP anyway). This seems to be a private affair between switch_mm and activate_mm, using page_table_lock as a per-mm lock, without any relation to its uses elsewhere. That's fine, but comment it as such; and unlock sooner in switch_mm, more like in activate_mm (preemption is disabled here). There is a block of "if (0)"ed code in smp_flush_tlb_pending which would have liked to rely on the page_table_lock, in switch_mm and elsewhere; but its comment explains how dup_mmap's flush_tlb_mm defeated it. And though that could have been changed at any time over the past few years, now the chance vanishes as we push the page_table_lock downwards, and perhaps split it per page table page. Just delete that block of code. Which leaves the mysterious spin_unlock_wait(&oldmm->page_table_lock) in kernel/fork.c copy_mm. Textual analysis (supported by Nick Piggin) suggests that the comment was written by DaveM, and that it relates to the defeated approach in the sparc64 smp_flush_tlb_pending. Just delete this block too. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[PATCH] unexport uts_semAdrian Bunk
I didn't find any possible modular usage in the kernel. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] unexport idle_cpuAdrian Bunk
I didn't find any possible modular usage in the kernel. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] unexport console_unblankAdrian Bunk
I didn't find any possible modular usage of console_unblank in the kernel. This patch was already ACK'ed by Alan Cox. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kernel-docs: fix kernel-doc format problemsRandy Dunlap
Convert to proper kernel-doc format. Some have extra blank lines (not allowed immed. after the function name) or need blank lines (after all parameters). Function summary must be only one line. Colon (":") in a function description does weird things (causes kernel-doc to think that it's a new section head sadly). Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] more kernel-doc cleanups, additionsRandy Dunlap
Various core kernel-doc cleanups: - add missing function parameters in ipc, irq/manage, kernel/sys, kernel/sysctl, and mm/slab; - move description to just above function for kernel_restart() Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Kprobes: preempt_disable/enable() simplificationAnanth N Mavinakayanahalli
Reorganize the preempt_disable/enable calls to eliminate the extra preempt depth. Changes based on Paul McKenney's review suggestions for the kprobes RCU changeset. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Kprobes: Use RCU for (un)register synchronization - base changesAnanth N Mavinakayanahalli
Changes to the base kprobes infrastructure to use RCU for synchronization during kprobe registration and unregistration. These changes coupled with the arch kprobe changes (next in series): a. serialize registration and unregistration of kprobes. b. enable lockless execution of handlers. Handlers can now run in parallel. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Kprobes: Track kprobe on a per_cpu basis - base changesAnanth N Mavinakayanahalli
Changes to the base kprobe infrastructure to track kprobe execution on a per-cpu basis. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] consolidate sys_ptrace()Christoph Hellwig
The sys_ptrace boilerplate code (everything outside the big switch statement for the arch-specific requests) is shared by most architectures. This patch moves it to kernel/ptrace.c and leaves the arch-specific code as arch_ptrace. Some architectures have a too different ptrace so we have to exclude them. They continue to keep their implementations. For sh64 I had to add a sh64_ptrace wrapper because it does some initialization on the first call. For um I removed an ifdefed SUBARCH_PTRACE_SPECIAL block, but SUBARCH_PTRACE_SPECIAL isn't defined anywhere in the tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fix remaining missing includesTim Schmielau
Fix more include file problems that surfaced since I submitted the previous fix-missing-includes.patch. This should now allow not to include sched.h from module.h, which is done by a followup patch. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] FUTEX_WAKE_OP: enhanced error handlingDavid Gibson
The code for FUTEX_WAKE_OP calls an arch callback, futex_atomic_op_inuser(). That callback can return an error code, but currently the caller assumes any error is EFAULT, and will try various things to resolve the fault before eventually giving up with EFAULT (regardless of the original error code). This is not a theoretical case - arch callbacks currently return -ENOSYS if the opcode they are given is bogus. This patch alters the code to detect non-EFAULT errors and return them directly to the user. Of course, whether -ENOSYS is the correct return value for the bogus opcode case, or whether EINVAL would be more appropriate is another question. Signed-off-by: David Gibson <dwg@au1.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jamie Lokier <jamie@shareable.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] aio: remove aio_max_nr accounting raceZach Brown
AIO was adding a new context's max requests to the global total before testing if that resulting total was over the global limit. This let innocent tasks get their new limit tested along with a racing guilty task that was crossing the limit. This serializes the _nr accounting with a spinlock It also switches to using unsigned long for the global totals. Individual contexts are still limited to an unsigned int's worth of requests by the syscall interface. The problem and fix were verified with a simple program that spun creating and destroying a context while holding on to another long lived context. Before the patch a task creating a tiny context could get a spurious EAGAIN if it raced with a task creating a very large context that overran the limit. Signed-off-by: Zach Brown <zach.brown@oracle.com> Cc: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Process Events ConnectorMatt Helsley
This patch adds a connector that reports fork, exec, id change, and exit events for all processes to userspace. It replaces the fork_advisor patch that ELSA is currently using. Applications that may find these events useful include accounting/auditing (e.g. ELSA), system activity monitoring (e.g. top), security, and resource management (e.g. CKRM). Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] swsusp: remove unused variablePavel Machek
Remove unused variable, and make code less evil that way. Fix whitespace around for-loop-like macro. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] swsusp cleanupsPavel Machek
This cleans spaces between * and pointer up, and adds "int" in "unsigned int". Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] cpu hoptlug: avoid usage of smp_processor_id() in preemptible codeHeiko Carstens
Replace smp_processor_id() with any_online_cpu(cpu_online_map) in order to avoid lots of "BUG: using smp_processor_id() in preemptible [00000001] code:..." messages in case taking a cpu online fails. All the traces start at the last notifier_call_chain(...) in kernel/cpu.c. Since we hold the cpu_control semaphore it shouldn't be any problem to access cpu_online_map. The reason why cpu_up failed is simply that the cpu that was supposed to be taken online wasn't even there. That is because on s390 we never know when a new cpu comes and therefore cpu_possible_map consists of only ones and doesn't reflect reality. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] posix-timers `unlikely' rejigAndrew Morton
!unlikely(expr) hurts my brain. likely(!expr) is more straightforward. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-04[PATCH] improve scheduler fairness a bitOleg Nesterov
Do not transfer remaining time slice to another cpu on process exit. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-31Merge ../linux-2.6 by handPaul Mackerras
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Remove duplicate code in signal.cPaul E. McKenney
Combine a bit of redundant code between force_sig_info() and force_sig_specific(). Signed-off-by: paulmck@us.ibm.com Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] remove unneeded SI_TIMER checksOleg Nesterov
This patch removes checks for ->si_code == SI_TIMER from send_signal, specific_send_sig_info, __group_send_sig_info. I think posix-timers.c used these functions some time ago, now it sends signals via send_{,group_}sigqueue, so these hooks are unneeded. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] cleanup the usage of SEND_SIG_xxx constantsOleg Nesterov
This patch simplifies some checks for magic siginfo values. It should not change the behaviour in any way. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] remove hardcoded SEND_SIG_xxx constantsOleg Nesterov
This patch replaces hardcoded SEND_SIG_xxx constants with their symbolic names. No changes in affected .o files. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] sched: hardcode non-smp set_cpus_allowedPaul Jackson
Simplify the UP (1 CPU) implementatin of set_cpus_allowed. The one CPU is hardcoded to be cpu 0 - so just test for that bit, and avoid having to pick up the cpu_online_map. Also, unexport cpu_online_map: it was only needed for set_cpus_allowed(). Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] posix-cpu-timers: fix overrun reportingRoland McGrath
This change corrects an omission in posix_cpu_timer_schedule, so that it correctly propagates the overrun calculation to where it will get reported to the user. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] RCU torture-testing kernel modulePaul E. McKenney
This patch is a rewrite of the one submitted on October 1st, using modules (http://marc.theaimsgroup.com/?l=linux-kernel&m=112819093522998&w=2). This rewrite adds a tristate CONFIG_RCU_TORTURE_TEST, which enables an intense torture test of the RCU infratructure. This is needed due to the continued changes to the RCU infrastructure to accommodate dynamic ticks, CPU hotplug, realtime, and so on. Most of the code is in a separate file that is compiled only if the CONFIG variable is set. Documentation on how to run the test and interpret the output is also included. This code has been tested on i386 and ppc64, and an earlier version of the code has received extensive testing on a number of architectures as part of the PREEMPT_RT patchset. Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] jiffies_64 cleanupThomas Gleixner
Define jiffies_64 in kernel/timer.c rather than having 24 duplicated defines in each architecture. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] wait4 PTRACE_ATTACH race fixRoland McGrath
Back about a year ago when I last fiddled heavily with the do_wait code, I was thinking too hard about the wrong thing and I now think I introduced a bug whose inverse thought I was fixing. Apparently noone was looking too hard over much shoulder, so as to cite my bogus reasoning at the time. In the race condition when PTRACE_ATTACH is about to steal a child and then the child hits a tracing event (what my_ptrace_child checks for), the real parent does need to set its flag noting it has some eligible live children. Otherwise a spurious ECHILD error is possible, since the child in question is not yet on the ptrace_children list. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] PF_DEAD cleanupCoywolf Qi Hunt
The PF_DEAD setting doesn't belong to exit_notify(), move it to a proper place. Signed-off-by: Coywolf Qi Hunt <qiyong@fc-cn.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] cleanup for kernel/printk.cJesper Juhl
- Removes some trailing whitespace - Breaks long lines and make other small changes to conform to CodingStyle - Add explicit printk loglevels in two places. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
