kthread.h can't be included in psi_types.h because it creates a circular
inclusion with kthread.h eventually including psi_types.h and
complaining on kthread structures not being defined because they are
defined further in the kthread.h. Resolve this by removing psi_types.h
inclusion from the headers included from kthread.h.
Link: http://lkml.kernel.org/r/20190319235619.260832-7-surenb@google.com
Signed-off-by: Suren Baghdasaryan <surenb@google.com>
Cc: Dennis Zhou <dennis@kernel.org>
Cc: Li Zefan <lizefan@huawei.com>
Cc: Tejun Heo <tj@kernel.org>
Introduce changed_states parameter into collect_percpu_times to track
the states changed since the last update.
This will be needed to detect whether polled states activated in the
monitor patch.
Link: http://lkml.kernel.org/r/20190319235619.260832-6-surenb@google.com
Split update_stats into collect_percpu_times and update_averages for
collect_percpu_times to be reused later inside psi monitor.
Link: http://lkml.kernel.org/r/20190319235619.260832-5-surenb@google.com
Rename psi_group structure member fields used for calculating psi totals
and averages for clear distinction between them and for trigger-related
fields that will be added by "psi: introduce psi monitor".
[surenb@google.com: v6]
Link: http://lkml.kernel.org/r/20190319235619.260832-4-surenb@google.com
Link: http://lkml.kernel.org/r/20190124211518.244221-5-surenb@google.com
psi_enable is not used outside of psi.c, make it static.
Link: http://lkml.kernel.org/r/20190319235619.260832-3-surenb@google.com
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Patch series "psi: pressure stall monitors", v6.
This is a respin of:
https://lwn.net/ml/linux-kernel/20190308184311.144521-1-surenb%40google.com/
Android is adopting psi to detect and remedy memory pressure that
results in stuttering and decreased responsiveness on mobile devices.
Psi gives us the stall information, but because we're dealing with
latencies in the millisecond range, periodically reading the pressure
files to detect stalls in a timely fashion is not feasible. Psi also
doesn't aggregate its averages at a high-enough frequency right now.
This patch series extends the psi interface such that users can
configure sensitive latency thresholds and use poll() and friends to be
notified when these are breached.
As high-frequency aggregation is costly, it implements an aggregation
method that is optimized for fast, short-interval averaging, and makes
the aggregation frequency adaptive, such that high-frequency updates
only happen while monitored stall events are actively occurring.
With these patches applied, Android can monitor for, and ward off,
mounting memory shortages before they cause problems for the user. For
example, using memory stall monitors in userspace low memory killer
daemon (lmkd) we can detect mounting pressure and kill less important
processes before device becomes visibly sluggish. In our memory stress
testing psi memory monitors produce roughly 10x less false positives
compared to vmpressure signals. Having ability to specify multiple
triggers for the same psi metric allows other parts of Android framework
to monitor memory state of the device and act accordingly.
The new interface is straight-forward. The user opens one of the
pressure files for writing and writes a trigger description into the
file descriptor that defines the stall state - some or full, and the
maximum stall time over a given window of time. E.g.:
/* Signal when stall time exceeds 100ms of a 1s window */
char trigger[] = "full 100000 1000000"
fd = open("/proc/pressure/memory")
write(fd, trigger, sizeof(trigger))
while (poll() >= 0) {
close(fd);
When the monitored stall state is entered, psi adapts its aggregation
frequency according to what the configured time window requires in order
to emit event signals in a timely fashion. Once the stalling subsides,
aggregation reverts back to normal.
The trigger is associated with the open file descriptor. To stop
monitoring, the user only needs to close the file descriptor and the
trigger is discarded.
Patches 1-6 prepare the psi code for polling support. Patch 7
implements the adaptive polling logic, the pressure growth detection
optimized for short intervals, and hooks up write() and poll() on the
pressure files.
The patches were developed in collaboration with Johannes Weiner.
This patch (of 7):
The psi monitoring patches will need to determine the same states as
record_times(). To avoid calculating them twice, maintain a state mask
that can be consulted cheaply. Do this in a separate patch to keep the
churn in the main feature patch at a minimum.
This adds 4-byte state_mask member into psi_group_cpu struct which
results in its first cacheline-aligned part becoming 52 bytes long. Add
explicit values to enumeration element counters that affect
psi_group_cpu struct size.
Link: http://lkml.kernel.org/r/20190124211518.244221-4-surenb@google.com
The RCU reader uses rcu_dereference() inside rcu_read_lock critical
sections, so the writer shall use WRITE_ONCE. Just a cleanup, we still
rely on gcc to emit atomic writes in other places.
Link: http://lkml.kernel.org/r/20190325225636.11635-3-aarcange@redhat.com
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Jann Horn <jannh@google.com>
Cc: Jason Gunthorpe <jgg@mellanox.com>
Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: Peter Xu <peterx@redhat.com>
Cc: zhong jiang <zhongjiang@huawei.com>
The task structure is freed while get_mem_cgroup_from_mm() holds
rcu_read_lock() and dereferences mm->owner.
get_mem_cgroup_from_mm() failing fork()
task = mm->owner
mm->owner = NULL;
free(task)
if (task) *task; /* use after free */
The fix consists in freeing the task with RCU also in the fork failure
case, exactly like it always happens for the regular exit(2) path. That
is enough to make the rcu_read_lock hold in get_mem_cgroup_from_mm()
(left side above) effective to avoid a use after free when dereferencing
the task structure.
An alternate possible fix would be to defer the delivery of the
userfaultfd contexts to the monitor until after fork() is guaranteed to
succeed. Such a change would require more changes because it would
create a strict ordering dependency where the uffd methods would need to
be called beyond the last potentially failing branch in order to be
safe. This solution as opposed only adds the dependency to common code
to set mm->owner to NULL and to free the task struct that was pointed by
mm->owner with RCU, if fork ends up failing. The userfaultfd methods
can still be called anywhere during the fork runtime and the monitor
will keep discarding orphaned "mm" coming from failed forks in userland.
This race condition couldn't trigger if CONFIG_MEMCG was set =n at build
time.
[aarcange@redhat.com: improve changelog, reduce #ifdefs per Michal]
Link: http://lkml.kernel.org/r/20190429035752.4508-1-aarcange@redhat.com
Link: http://lkml.kernel.org/r/20190325225636.11635-2-aarcange@redhat.com
Fixes: 893e26e61d04 ("userfaultfd: non-cooperative: Add fork() event")
Tested-by: zhong jiang <zhongjiang@huawei.com>
Reported-by: syzbot+cbb52e396df3e565ab02@syzkaller.appspotmail.com
Cc: syzbot+cbb52e396df3e565ab02@syzkaller.appspotmail.com
Cc: <stable@vger.kernel.org>
If the user downloads and applies patch-5.1.gz using patch(1), the x bit
on kernel/gen_ikh_data.sh is not set.
/bin/sh: 1: ./kernel/gen_ikh_data.sh: Permission denied
Fix this by using CONFIG_SHELL.
Merge misc updates from Andrew Morton:
- a few misc things and hotfixes
- ocfs2
- almost all of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (139 commits)
kernel/memremap.c: remove the unused device_private_entry_fault() export
mm: delete find_get_entries_tag
mm/huge_memory.c: make __thp_get_unmapped_area static
mm/mprotect.c: fix compilation warning because of unused 'mm' variable
mm/page-writeback: introduce tracepoint for wait_on_page_writeback()
mm/vmscan: simplify trace_reclaim_flags and trace_shrink_flags
mm/Kconfig: update "Memory Model" help text
mm/vmscan.c: don't disable irq again when count pgrefill for memcg
mm: memblock: make keeping memblock memory opt-in rather than opt-out
hugetlbfs: always use address space in inode for resv_map pointer
mm/z3fold.c: support page migration
mm/z3fold.c: add structure for buddy handles
mm/z3fold.c: improve compression by extending search
mm/z3fold.c: introduce helper functions
mm/page_alloc.c: remove unnecessary parameter in rmqueue_pcplist
mm/hmm: add ARCH_HAS_HMM_MIRROR ARCH_HAS_HMM_DEVICE Kconfig
mm/vmscan.c: simplify shrink_inactive_list()
fs/sync.c: sync_file_range(2) may use WB_SYNC_ALL writeback
xen/privcmd-buf.c: convert to use vm_map_pages_zero()
xen/gntdev.c: convert to use vm_map_pages()
This export has been entirely unused since it was added more than 1 1/2
years ago.
Link: http://lkml.kernel.org/r/20190429115535.12793-1-hch@lst.de
Reviewed-by: Dan Williams <dan.j.williams@intel.com>
Most architectures do not need the memblock memory after the page
allocator is initialized, but only few enable ARCH_DISCARD_MEMBLOCK in the
arch Kconfig.
Replacing ARCH_DISCARD_MEMBLOCK with ARCH_KEEP_MEMBLOCK and inverting the
logic makes it clear which architectures actually use memblock after
system initialization and skips the necessity to add ARCH_DISCARD_MEMBLOCK
to the architectures that are still missing that option.
Link: http://lkml.kernel.org/r/1556102150-32517-1-git-send-email-rppt@linux.ibm.com
Signed-off-by: Mike Rapoport <rppt@linux.ibm.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Russell King <linux@armlinux.org.uk>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Paul Burton <paul.burton@mips.com>
Cc: James Hogan <jhogan@kernel.org>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Rich Felker <dalias@libc.org>
Cc: Eric Biederman <ebiederm@xmission.com>
arch_add_memory, __add_pages take a want_memblock which controls whether
the newly added memory should get the sysfs memblock user API (e.g.
ZONE_DEVICE users do not want/need this interface). Some callers even
want to control where do we allocate the memmap from by configuring
altmap.
Add a more generic hotplug context for arch_add_memory and __add_pages.
struct mhp_restrictions contains flags which contains additional features
to be enabled by the memory hotplug (MHP_MEMBLOCK_API currently) and
altmap for alternative memmap allocator.
This patch shouldn't introduce any functional change.
[akpm@linux-foundation.org: build fix]
Link: http://lkml.kernel.org/r/20190408082633.2864-3-osalvador@suse.de
Signed-off-by: Michal Hocko <mhocko@suse.com>
Signed-off-by: Oscar Salvador <osalvador@suse.de>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: David Hildenbrand <david@redhat.com>
This updates each existing invalidation to use the correct mmu notifier
event that represent what is happening to the CPU page table. See the
patch which introduced the events to see the rational behind this.
Link: http://lkml.kernel.org/r/20190326164747.24405-7-jglisse@redhat.com
Signed-off-by: Jérôme Glisse <jglisse@redhat.com>
Reviewed-by: Ralph Campbell <rcampbell@nvidia.com>
Reviewed-by: Ira Weiny <ira.weiny@intel.com>
Cc: Christian König <christian.koenig@amd.com>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: Rodrigo Vivi <rodrigo.vivi@intel.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Felix Kuehling <Felix.Kuehling@amd.com>
Cc: Ross Zwisler <zwisler@kernel.org>
Cc: Radim Krcmar <rkrcmar@redhat.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Christian Koenig <christian.koenig@amd.com>
Cc: John Hubbard <jhubbard@nvidia.com>
CPU page table update can happens for many reasons, not only as a result
of a syscall (munmap(), mprotect(), mremap(), madvise(), ...) but also as
a result of kernel activities (memory compression, reclaim, migration,
Users of mmu notifier API track changes to the CPU page table and take
specific action for them. While current API only provide range of virtual
address affected by the change, not why the changes is happening.
This patchset do the initial mechanical convertion of all the places that
calls mmu_notifier_range_init to also provide the default MMU_NOTIFY_UNMAP
event as well as the vma if it is know (most invalidation happens against
a given vma). Passing down the vma allows the users of mmu notifier to
inspect the new vma page protection.
The MMU_NOTIFY_UNMAP is always the safe default as users of mmu notifier
should assume that every for the range is going away when that event
happens. A latter patch do convert mm call path to use a more appropriate
events for each call.
This is done as 2 patches so that no call site is forgotten especialy
as it uses this following coccinelle patch:
identifier I1, I2, I3, I4;
static inline void mmu_notifier_range_init(struct mmu_notifier_range *I1,
+enum mmu_notifier_event event,
+unsigned flags,
+struct vm_area_struct *vma,
struct mm_struct *I2, unsigned long I3, unsigned long I4) { ... }
-#define mmu_notifier_range_init(range, mm, start, end)
+#define mmu_notifier_range_init(range, event, flags, vma, mm, start, end)
expression E1, E3, E4;
identifier I1;
mmu_notifier_range_init(E1,
+MMU_NOTIFY_UNMAP, 0, I1,
I1->vm_mm, E3, E4)
expression E1, E2, E3, E4;
identifier FN, VMA;
FN(..., struct vm_area_struct *VMA, ...) {
+MMU_NOTIFY_UNMAP, 0, VMA,
E2, E3, E4)
identifier FN, VMA;
FN(...) {
struct vm_area_struct *VMA;
E2, E3, E4)
identifier FN;
FN(...) {
+MMU_NOTIFY_UNMAP, 0, NULL,
E2, E3, E4)
Applied with:
spatch --all-includes --sp-file mmu-notifier.spatch fs/proc/task_mmu.c --in-place
spatch --sp-file mmu-notifier.spatch --dir kernel/events/ --in-place
spatch --sp-file mmu-notifier.spatch --dir mm --in-place
Link: http://lkml.kernel.org/r/20190326164747.24405-6-jglisse@redhat.com
To facilitate additional options to get_user_pages_fast() change the
singular write parameter to be gup_flags.
This patch does not change any functionality. New functionality will
follow in subsequent patches.
Some of the get_user_pages_fast() call sites were unchanged because they
already passed FOLL_WRITE or 0 for the write parameter.
NOTE: It was suggested to change the ordering of the get_user_pages_fast()
arguments to ensure that callers were converted. This breaks the current
GUP call site convention of having the returned pages be the final
parameter. So the suggestion was rejected.
Link: http://lkml.kernel.org/r/20190328084422.29911-4-ira.weiny@intel.com
Link: http://lkml.kernel.org/r/20190317183438.2057-4-ira.weiny@intel.com
Signed-off-by: Ira Weiny <ira.weiny@intel.com>
Reviewed-by: Mike Marshall <hubcap@omnibond.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com>
Cc: Jason Gunthorpe <jgg@ziepe.ca>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Userfaultfd can be misued to make it easier to exploit existing
use-after-free (and similar) bugs that might otherwise only make a
short window or race condition available. By using userfaultfd to
stall a kernel thread, a malicious program can keep some state that it
wrote, stable for an extended period, which it can then access using an
existing exploit. While it doesn't cause the exploit itself, and while
it's not the only thing that can stall a kernel thread when accessing a
memory location, it's one of the few that never needs privilege.
We can add a flag, allowing userfaultfd to be restricted, so that in
general it won't be useable by arbitrary user programs, but in
environments that require userfaultfd it can be turned back on.
Add a global sysctl knob "vm.unprivileged_userfaultfd" to control
whether userfaultfd is allowed by unprivileged users. When this is
set to zero, only privileged users (root user, or users with the
CAP_SYS_PTRACE capability) will be able to use the userfaultfd
syscalls.
Andrea said:
: The only difference between the bpf sysctl and the userfaultfd sysctl
: this way is that the bpf sysctl adds the CAP_SYS_ADMIN capability
: requirement, while userfaultfd adds the CAP_SYS_PTRACE requirement,
: because the userfaultfd monitor is more likely to need CAP_SYS_PTRACE
: already if it's doing other kind of tracking on processes runtime, in
: addition of userfaultfd. In other words both syscalls works only for
: root, when the two sysctl are opt-in set to 1.
[dgilbert@redhat.com: changelog additions]
[akpm@linux-foundation.org: documentation tweak, per Mike]
Link: http://lkml.kernel.org/r/20190319030722.12441-2-peterx@redhat.com
Signed-off-by: Peter Xu <peterx@redhat.com>
Suggested-by: Andrea Arcangeli <aarcange@redhat.com>
Suggested-by: Mike Rapoport <rppt@linux.ibm.com>
Reviewed-by: Mike Rapoport <rppt@linux.ibm.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Luis Chamberlain <mcgrof@kernel.org>
Cc: Maxime Coquelin <maxime.coquelin@redhat.com>
Cc: Maya Gokhale <gokhale2@llnl.gov>
Cc: Jerome Glisse <jglisse@redhat.com>
Cc: Pavel Emelyanov <xemul@virtuozzo.com>
Cc: Martin Cracauer <cracauer@cons.org>
Cc: Denis Plotnikov <dplotnikov@virtuozzo.com>
Cc: Marty McFadden <mcfadden8@llnl.gov>
Cc: "Kirill A . Shutemov" <kirill@shutemov.name>
Cc: "Dr . David Alan Gilbert" <dgilbert@redhat.com>
While validating new map we require the @start_data to be strictly less
than @end_data, which is fine for regular applications (this is why this
nit didn't trigger for that long). These members are set from executable
loaders such as elf handers, still it is pretty valid to have a loadable
data section with zero size in file, in such case the start_data is equal
to end_data once kernel loader finishes.
As a result when we're trying to restore such programs the procedure fails
and the kernel returns -EINVAL. From the image dump of a program:
| "mm_start_code": "0x400000",
| "mm_end_code": "0x8f5fb4",
| "mm_start_data": "0xf1bfb0",
| "mm_end_data": "0xf1bfb0",
Thus we need to change validate_prctl_map from strictly less to less or
equal operator use.
Link: http://lkml.kernel.org/r/20190408143554.GY1421@uranus.lan
Fixes: f606b77f1a9e3 ("prctl: PR_SET_MM -- introduce PR_SET_MM_MAP operation")
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: Andrey Vagin <avagin@gmail.com>
Cc: Dmitry Safonov <0x7f454c46@gmail.com>
Pull networking fixes from David Miller:
"Fixes all over:
1) Netdev refcnt leak in nf_flow_table, from Taehee Yoo.
2) Fix RCU usage in nf_tables, from Florian Westphal.
3) Fix DSA build when NET_DSA_TAG_BRCM_PREPEND is not set, from Yue
Haibing.
4) Add missing page read/write ops to realtek driver, from Heiner
Kallweit.
5) Endianness fix in qrtr code, from Nicholas Mc Guire.
6) Fix various bugs in DSA_SKB_* macros, from Vladimir Oltean.
7) Several BPF documentation cures, from Quentin Monnet.
8) Fix undefined behavior in narrow load handling of BPF verifier,
from Krzesimir Nowak.
9) DMA ops crash in SGI Seeq driver due to not set netdev parent
device pointer, from Thomas Bogendoerfer.
10) Flow dissector has to disable preemption when invoking BPF
program, from Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (48 commits)
net: ethernet: stmmac: dwmac-sun8i: enable support of unicast filtering
net: ethernet: ti: netcp_ethss: fix build
flow_dissector: disable preemption around BPF calls
bonding: fix arp_validate toggling in active-backup mode
net: meson: fixup g12a glue ephy id
net: phy: realtek: Replace phy functions with non-locked version in rtl8211e_config_init()
net: seeq: fix crash caused by not set dev.parent
of_net: Fix missing of_find_device_by_node ref count drop
net: mvpp2: cls: Add missing NETIF_F_NTUPLE flag
bpf: fix undefined behavior in narrow load handling
libbpf: detect supported kernel BTF features and sanitize BTF
selftests: bpf: Add files generated after build to .gitignore
tools: bpf: synchronise BPF UAPI header with tools
bpf: fix minor issues in documentation for BPF helpers.
bpf: fix recurring typo in documentation for BPF helpers
bpf: fix script for generating man page on BPF helpers
bpf: add various test cases for backward jumps
net: dccp : proto: remove Unneeded variable "err"
net: dsa: Remove the now unused DSA_SKB_CB_COPY() macro
net: dsa: Remove dangerous DSA_SKB_CLONE() macro
Commit 31fd85816dbe ("bpf: permits narrower load from bpf program
context fields") made the verifier add AND instructions to clear the
unwanted bits with a mask when doing a narrow load. The mask is
computed with
(1 << size * 8) - 1
where "size" is the size of the narrow load. When doing a 4 byte load
of a an 8 byte field the verifier shifts the literal 1 by 32 places to
the left. This results in an overflow of a signed integer, which is an
undefined behavior. Typically, the computed mask was zero, so the
result of the narrow load ended up being zero too.
Cast the literal to long long to avoid overflows. Note that narrow
load of the 4 byte fields does not have the undefined behavior,
because the load size can only be either 1 or 2 bytes, so shifting 1
by 8 or 16 places will not overflow it. And reading 4 bytes would not
be a narrow load of a 4 bytes field.
Fixes: 31fd85816dbe ("bpf: permits narrower load from bpf program context fields")
Reviewed-by: Alban Crequy <alban@kinvolk.io>
Reviewed-by: Iago López Galeiras <iago@kinvolk.io>
Signed-off-by: Krzesimir Nowak <krzesimir@kinvolk.io>
Cc: Yonghong Song <yhs@fb.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull gpio updates from Linus Walleij:
"This is the bulk of the GPIO changes for the v5.2 kernel cycle. A bit
later than usual because I was ironing out my own mistakes. I'm
holding some stuff back for the next kernel as a result, and this
should be a healthy and well tested batch.
Core changes:
- The gpiolib MMIO driver has been enhanced to handle two direction
registers, i.e. one register to set lines as input and one register
to set lines as output. It turns out some silicon engineer thinks
the ability to configure a line as input and output at the same
time makes sense, this can be debated but includes a lot of analog
electronics reasoning, and the registers are there and need to be
handled consistently. Unsurprisingly, we enforce the lines to be
either inputs or outputs in such schemes.
- Send in the proper argument value to .set_config() dispatched to
the pin control subsystem. Nobody used it before, now someone does,
so fix it to work as expected.
- The ACPI gpiolib portions can now handle pin bias setting (pull up
or pull down). This has been in the ACPI spec for years and we
finally have it properly integrated with Linux GPIOs. It was based
on an observation from Andy Schevchenko that Thomas Petazzoni's
changes to the core for biasing the PCA950x GPIO expander actually
happen to fit hand-in-glove with what the ACPI core needed. Such
nice synergies happen sometimes.
New drivers:
- A new driver for the Mellanox BlueField GPIO controller. This is
using 64bit MMIO registers and can configure lines as inputs and
outputs at the same time and after improving the MMIO library we
handle it just fine. Interesting.
- A new IXP4xx proper gpiochip driver with hierarchical interrupts
should be coming in from the ARM SoC tree as well.
Driver enhancements:
- The PCA053x driver handles the CAT9554 GPIO expander.
- The PCA053x driver handles the NXP PCAL6416 GPIO expander.
- Wake-up support on PCA053x GPIO lines.
- OMAP now does a nice asynchronous IRQ handling on wake-ups by
letting everything wake up on edges, and this makes runtime PM work
as expected too.
Misc:
- Several cleanups such as devres fixes.
- Get rid of some languager comstructs that cause problems when
compiling with LLVMs clang.
- Documentation review and update"
* tag 'gpio-v5.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (85 commits)
gpio: Update documentation
docs: gpio: convert docs to ReST and rename to *.rst
gpio: sch: Remove write-only core_base
gpio: pxa: Make two symbols static
gpiolib: acpi: Respect pin bias setting
gpiolib: acpi: Add acpi_gpio_update_gpiod_lookup_flags() helper
gpiolib: acpi: Set pin value, based on bias, more accurately
gpiolib: acpi: Change type of dflags
gpiolib: Introduce GPIO_LOOKUP_FLAGS_DEFAULT
gpiolib: Make use of enum gpio_lookup_flags consistent
gpiolib: Indent entry values of enum gpio_lookup_flags
gpio: pca953x: add support for pca6416
dt-bindings: gpio: pca953x: document the nxp,pca6416
gpio: pca953x: add pcal6416 to the of_device_id table
gpio: gpio-omap: Remove conditional pm_runtime handling for GPIO interrupts
gpio: gpio-omap: configure edge detection for level IRQs for idle wakeup
tracing: stop making gpio tracing configurable
gpio: pca953x: Configure wake-up path when wake-up is enabled
gpio: of: Optimize quirk checks
gpio: mmio: Drop bgpio_dir_inverted
systemtap folks reported the following splat recently:
[ 7790.862212] WARNING: CPU: 3 PID: 26759 at arch/x86/kernel/kprobes/core.c:1022 kprobe_fault_handler+0xec/0xf0
[ 7790.864113] CPU: 3 PID: 26759 Comm: sshd Not tainted 5.1.0-0.rc7.git1.1.fc31.x86_64 #1
[ 7790.864198] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS[...]
[ 7790.864314] RIP: 0010:kprobe_fault_handler+0xec/0xf0
[ 7790.864375] Code: 48 8b 50 [...]
[ 7790.864714] RSP: 0018:ffffc06800bdbb48 EFLAGS: 00010082
[ 7790.864812] RAX: ffff9e2b75a16320 RBX: 0000000000000000 RCX: 0000000000000000
[ 7790.865306] RDX: ffffffffffffffff RSI: 000000000000000e RDI: ffffc06800bdbbf8
[ 7790.865514] RBP: ffffc06800bdbbf8 R08: 0000000000000000 R09: 0000000000000000
[ 7790.865960] R10: 0000000000000000 R11: 0000000000000000 R12: ffffc06800bdbbf8
[ 7790.866037] R13: ffff9e2ab56a0418 R14: ffff9e2b6d0bb400 R15: ffff9e2b6d268000
[ 7790.866114] FS: 00007fde49937d80(0000) GS:ffff9e2b75a00000(0000) knlGS:0000000000000000
[ 7790.866193] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 7790.866318] CR2: 0000000000000000 CR3: 000000012f312000 CR4: 00000000000006e0
[ 7790.866419] Call Trace:
[ 7790.866677] do_user_addr_fault+0x64/0x480
[ 7790.867513] do_page_fault+0x33/0x210
[ 7790.868002] async_page_fault+0x1e/0x30
[ 7790.868071] RIP: 0010: (null)
[ 7790.868144] Code: Bad RIP value.
[ 7790.868229] RSP: 0018:ffffc06800bdbca8 EFLAGS: 00010282
[ 7790.868362] RAX: ffff9e2b598b60f8 RBX: ffffc06800bdbe48 RCX: 0000000000000004
[ 7790.868629] RDX: 0000000000000004 RSI: ffffc06800bdbc6c RDI: ffff9e2b598b60f0
[ 7790.868834] RBP: ffffc06800bdbcf8 R08: 0000000000000000 R09: 0000000000000004
[ 7790.870432] R10: 00000000ff6f7a03 R11: 0000000000000000 R12: 0000000000000001
[ 7790.871859] R13: ffffc06800bdbcb8 R14: 0000000000000000 R15: ffff9e2acd0a5310
[ 7790.873455] ? vfs_read+0x5/0x170
[ 7790.874639] ? vfs_read+0x1/0x170
[ 7790.875834] ? trace_call_bpf+0xf6/0x260
[ 7790.877044] ? vfs_read+0x1/0x170
[ 7790.878208] ? vfs_read+0x5/0x170
[ 7790.879345] ? kprobe_perf_func+0x233/0x260
[ 7790.880503] ? vfs_read+0x1/0x170
[ 7790.881632] ? vfs_read+0x5/0x170
[ 7790.882751] ? kprobe_ftrace_handler+0x92/0xf0
[ 7790.883926] ? __vfs_read+0x30/0x30
[ 7790.885050] ? ftrace_ops_assist_func+0x94/0x100
[ 7790.886183] ? vfs_read+0x1/0x170
[ 7790.887283] ? vfs_read+0x5/0x170
[ 7790.888348] ? ksys_read+0x5a/0xe0
[ 7790.889389] ? do_syscall_64+0x5c/0xa0
[ 7790.890401] ? entry_SYSCALL_64_after_hwframe+0x49/0xbe
After some debugging, turns out that the logic in 2cbd95a5c4fb
("bpf: change parameters of call/branch offset adjustment") has
a bug that is exposed after 52875a04f4b2 ("bpf: verifier: remove
dead code") in that we miss some of the jump offset adjustments
after code patching when we remove dead code, more concretely,
upon backward jump spanning over the area that is being removed.
BPF insns of a case that was hit pre 52875a04f4b2:
676: (85) call bpf_perf_event_output#-47616
677: (05) goto pc-636
678: (62) *(u32 *)(r10 -64) = 0
679: (bf) r7 = r10
680: (07) r7 += -64
681: (05) goto pc-44
682: (05) goto pc-1
683: (05) goto pc-1
BPF insns afterwards:
618: (85) call bpf_perf_event_output#-47616
619: (05) goto pc-638
620: (62) *(u32 *)(r10 -64) = 0
621: (bf) r7 = r10
622: (07) r7 += -64
623: (05) goto pc-44
To illustrate the bug, situation looks as follows:
____
0 | | <-- foo: [...]
1 |____|
2 |____| <-- pos / end_new ^
3 | | |
4 | | | len
5 |____| | (remove region)
6 | | <-- end_old v
7 | |
8 | | <-- curr (jmp foo)
9 |____|
The condition curr >= end_new && curr + off + 1 < end_new in the
branch delta adjustments is never hit because curr + off + 1 <
end_new is compared as unsigned and therefore curr + off + 1 >
end_new in unsigned realm as curr + off + 1 becomes negative
since the insns are memmove()'d before the offset adjustments.
Correct BPF insns after this fix:
618: (85) call bpf_perf_event_output#-47216
619: (05) goto pc-578
621: (bf) r7 = r10
622: (07) r7 += -64
Note that unprivileged case is not affected from this.
Fixes: 52875a04f4b2 ("bpf: verifier: remove dead code")
Fixes: 2cbd95a5c4fb ("bpf: change parameters of call/branch offset adjustment")
Reported-by: Frank Ch. Eigler <fche@redhat.com>
Reviewed-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Avoid calling cgroup_threadgroup_change_end() without having called
cgroup_threadgroup_change_begin() first.
During process creation we need to check whether the cgroup we are in
allows us to fork. To perform this check the cgroup needs to guard itself
against threadgroup changes and takes a lock.
Prior to CLONE_PIDFD the cleanup target "bad_fork_free_pid" would also need
to call cgroup_threadgroup_change_end() because said lock had already been
taken.
However, this is not the case anymore with the addition of CLONE_PIDFD. We
are now allocating a pidfd before we check whether the cgroup we're in can
fork and thus prior to taking the lock. So when copy_process() fails at the
right step it would release a lock we haven't taken.
This bug is not even very subtle to be honest. It's just not very clear
from the naming of cgroup_threadgroup_change_{begin,end}() that a lock is
taken.
Here's the relevant splat:
entry_SYSENTER_compat+0x70/0x7f arch/x86/entry/entry_64_compat.S:139
RIP: 0023:0xf7fec849
Code: 85 d2 74 02 89 0a 5b 5d c3 8b 04 24 c3 8b 14 24 c3 8b 3c 24 c3 90 90
90 90 90 90 90 90 90 90 90 90 51 52 55 89 e5 0f 34 cd 80 <5d> 5a 59 c3 90
90 90 90 eb 0d 90 90 90 90 90 90 90 90 90 90 90 90
RSP: 002b:00000000ffed5a8c EFLAGS: 00000246 ORIG_RAX: 0000000000000078
RAX: ffffffffffffffda RBX: 0000000000003ffc RCX: 0000000000000000
RDX: 00000000200005c0 RSI: 0000000000000000 RDI: 0000000000000000
RBP: 0000000000000012 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
DEBUG_LOCKS_WARN_ON(depth <= 0)
WARNING: CPU: 1 PID: 7744 at kernel/locking/lockdep.c:4052 __lock_release
kernel/locking/lockdep.c:4052 [inline]
lock_release+0x667/0xa00 kernel/locking/lockdep.c:4321
Kernel panic - not syncing: panic_on_warn set ...
CPU: 1 PID: 7744 Comm: syz-executor007 Not tainted 5.1.0+ #4
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x172/0x1f0 lib/dump_stack.c:113
panic+0x2cb/0x65c kernel/panic.c:214
__warn.cold+0x20/0x45 kernel/panic.c:566
report_bug+0x263/0x2b0 lib/bug.c:186
fixup_bug arch/x86/kernel/traps.c:179 [inline]
fixup_bug arch/x86/kernel/traps.c:174 [inline]
do_error_trap+0x11b/0x200 arch/x86/kernel/traps.c:272
do_invalid_op+0x37/0x50 arch/x86/kernel/traps.c:291
invalid_op+0x14/0x20 arch/x86/entry/entry_64.S:972
RIP: 0010:__lock_release kernel/locking/lockdep.c:4052 [inline]
RIP: 0010:lock_release+0x667/0xa00 kernel/locking/lockdep.c:4321
Code: 0f 85 a0 03 00 00 8b 35 77 66 08 08 85 f6 75 23 48 c7 c6 a0 55 6b 87
48 c7 c7 40 25 6b 87 4c 89 85 70 ff ff ff e8 b7 a9 eb ff <0f> 0b 4c 8b 85
70 ff ff ff 4c 89 ea 4c 89 e6 4c 89 c7 e8 52 63 ff
RSP: 0018:ffff888094117b48 EFLAGS: 00010086
RAX: 0000000000000000 RBX: 1ffff11012822f6f RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffffffff815af236 RDI: ffffed1012822f5b
RBP: ffff888094117c00 R08: ffff888092bfc400 R09: fffffbfff113301d
R10: fffffbfff113301c R11: ffffffff889980e3 R12: ffffffff8a451df8
R13: ffffffff8142e71f R14: ffffffff8a44cc80 R15: ffff888094117bd8
percpu_up_read.constprop.0+0xcb/0x110 include/linux/percpu-rwsem.h:92
cgroup_threadgroup_change_end include/linux/cgroup-defs.h:712 [inline]
copy_process.part.0+0x47ff/0x6710 kernel/fork.c:2222
copy_process kernel/fork.c:1772 [inline]
_do_fork+0x25d/0xfd0 kernel/fork.c:2338
__do_compat_sys_x86_clone arch/x86/ia32/sys_ia32.c:240 [inline]
__se_compat_sys_x86_clone arch/x86/ia32/sys_ia32.c:236 [inline]
__ia32_compat_sys_x86_clone+0xbc/0x140 arch/x86/ia32/sys_ia32.c:236
do_syscall_32_irqs_on arch/x86/entry/common.c:334 [inline]
do_fast_syscall_32+0x281/0xd54 arch/x86/entry/common.c:405
Kernel Offset: disabled
Rebooting in 86400 seconds..
Reported-and-tested-by: syzbot+3286e58549edc479faae@syzkaller.appspotmail.com
Fixes: b3e583825266 ("clone: add CLONE_PIDFD")
Signed-off-by: Christian Brauner <christian@brauner.io>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
"This includes Roman's cgroup2 freezer implementation.
It's a separate machanism from cgroup1 freezer. Instead of blocking
user tasks in arbitrary uninterruptible sleeps, the new implementation
extends jobctl stop - frozen tasks are trapped in jobctl stop until
thawed and can be killed and ptraced. Lots of thanks to Oleg for
sheperding the effort.
Other than that, there are a few trivial changes"
* 'for-5.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: never call do_group_exit() with task->frozen bit set
kernel: cgroup: fix misuse of %x
cgroup: get rid of cgroup_freezer_frozen_exit()
cgroup: prevent spurious transition into non-frozen state
cgroup: Remove unused cgrp variable
cgroup: document cgroup v2 freezer interface
cgroup: add tracing points for cgroup v2 freezer
cgroup: make TRACE_CGROUP_PATH irq-safe
kselftests: cgroup: add freezer controller self-tests
kselftests: cgroup: don't fail on cg_kill_all() error in cg_destroy()
cgroup: cgroup v2 freezer
cgroup: protect cgroup->nr_(dying_)descendants by css_set_lock
cgroup: implement __cgroup_task_count() helper
cgroup: rename freezer.c into legacy_freezer.c
cgroup: remove extra cgroup_migrate_finish() call
Pull workqueue updates from Tejun Heo:
"Only three commits, of which two are trivial.
The non-trivial chagne is Thomas's patch to switch workqueue from
sched RCU to regular one. The use of sched RCU is mostly historic and
doesn't really buy us anything noticeable"
* 'for-5.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: Use normal rcu
kernel/workqueue: Document wq_worker_last_func() argument
kernel/workqueue: Use __printf markup to silence compiler in function 'alloc_workqueue'
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull intgrity updates from James Morris:
"This contains just three patches, the remainder were either included
in other pull requests (eg. audit, lockdown) or will be upstreamed via
other subsystems (eg. kselftests, Power).
Included here is one bug fix, one documentation update, and extending
the x86 IMA arch policy rules to coordinate the different kernel
module signature verification methods"
* 'next-integrity' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
doc/kernel-parameters.txt: Deprecate ima_appraise_tcb
x86/ima: add missing include
x86/ima: require signed kernel modules
Pull DMA mapping updates from Christoph Hellwig:
- remove the already broken support for NULL dev arguments to the DMA
API calls
- Kconfig tidyups
* tag 'dma-mapping-5.2' of git://git.infradead.org/users/hch/dma-mapping:
dma-mapping: add a Kconfig symbol to indicate arch_dma_prep_coherent presence
dma-mapping: remove an unnecessary NULL check
x86/dma: Remove the x86_dma_fallback_dev hack
dma-mapping: remove leftover NULL device support
arm: use a dummy struct device for ISA DMA use of the DMA API
pxa3xx-gcu: pass struct device to dma_mmap_coherent
gbefb: switch to managed version of the DMA allocator
da8xx-fb: pass struct device to DMA API functions
parport_ip32: pass struct device to DMA API functions
dma: select GENERIC_ALLOCATOR for DMA_REMAP
I've got two independent reports that cgroup_task_frozen() check
in cgroup_exit() has been triggered by lkp libhugetlbfs-test and
LTP ptrace01 tests.
For example:
[ 44.576072] WARNING: CPU: 1 PID: 3028 at kernel/cgroup/cgroup.c:5932 cgroup_exit+0x148/0x160
[ 44.577724] Modules linked in: crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel sr_mod cdrom
bochs_drm sg ttm ata_generic pata_acpi ppdev drm_kms_helper snd_pcm syscopyarea aesni_intel snd_timer
sysfillrect sysimgblt snd crypto_simd cryptd glue_helper soundcore fb_sys_fops joydev drm serio_raw pcspkr
ata_piix libata i2c_piix4 floppy parport_pc parport ip_tables
[ 44.583106] CPU: 1 PID: 3028 Comm: ptrace-write-hu Not tainted 5.1.0-rc3-00053-g9262503 #5
[ 44.584600] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014
[ 44.586116] RIP: 0010:cgroup_exit+0x148/0x160
[ 44.587135] Code: 0f 84 50 ff ff ff 48 8b 85 c8 0c 00 00 48 8b 78 70 e8 ec 2e 00 00 e9 3b ff ff ff f0 ff 43 60
0f 88 72 21 89 00 e9 48 ff ff ff <0f> 0b e9 1b ff ff ff e8 3c 73 f4 ff 66 90 66 2e 0f 1f 84 00 00 00
[ 44.590113] RSP: 0018:ffffb25702dcfd30 EFLAGS: 00010002
[ 44.591167] RAX: ffff96a7fee32410 RBX: ffff96a7ff1d6000 RCX: dead000000000200
[ 44.592446] RDX: ffff96a7ff1d6080 RSI: ffff96a7fec75290 RDI: ffff96a7fec75290
[ 44.593715] RBP: ffff96a7fec745c0 R08: ffff96a7fec74658 R09: 0000000000000000
[ 44.594985] R10: 0000000000000000 R11: 0000000000000001 R12: ffff96a7fec75101
[ 44.596266] R13: ffff96a7fec745c0 R14: ffff96a7ff3bde30 R15: ffff96a7fec75130
[ 44.597550] FS: 0000000000000000(0000) GS:ffff96a7dd700000(0000) knlGS:0000000000000000
[ 44.598950] CS: 0010 DS: 002b ES: 002b CR0: 0000000080050033
[ 44.600098] CR2: 00000000f7a00000 CR3: 000000000d20e000 CR4: 00000000000406e0
[ 44.601417] Call Trace:
[ 44.602777] do_exit+0x337/0xc40
[ 44.603677] do_group_exit+0x3a/0xa0
[ 44.604610] get_signal+0x12e/0x8d0
[ 44.605533] ? __switch_to_asm+0x40/0x70
[ 44.606503] do_signal+0x36/0x650
[ 44.607409] ? __switch_to_asm+0x40/0x70
[ 44.608383] ? __schedule+0x267/0x860
[ 44.609329] exit_to_usermode_loop+0x89/0xf0
[ 44.610349] do_fast_syscall_32+0x251/0x2e3
[ 44.611357] entry_SYSENTER_compat+0x7f/0x91
[ 44.612376] ---[ end trace e4ca5cfc4b7f7964 ]---
The problem is caused by the ptrace_signal() call in the for loop
in get_signal(). There is a cgroup_enter_frozen() call inside
ptrace_signal(), so after exit from ptrace_signal() the task->frozen
bit might be set. In this case do_group_exit() can be called with the
task->frozen bit set and trigger the warning. This is only place where
we can leave the loop with the task->frozen bit set and without
setting JOBCTL_TRAP_FREEZE and TIF_SIGPENDING.
To resolve this problem, let's move cgroup_leave_frozen(true) call to
just after the fatal label. If the task is going to die, the frozen
bit must be cleared no matter how we get into this point.
Reported-by: kernel test robot <rong.a.chen@intel.com>
Reported-by: Qian Cai <cai@lca.pw>
Signed-off-by: Roman Gushchin <guro@fb.com>
Pull networking updates from David Miller:
"Highlights:
1) Support AES128-CCM ciphers in kTLS, from Vakul Garg.
2) Add fib_sync_mem to control the amount of dirty memory we allow to
queue up between synchronize RCU calls, from David Ahern.
3) Make flow classifier more lockless, from Vlad Buslov.
4) Add PHY downshift support to aquantia driver, from Heiner
Kallweit.
5) Add SKB cache for TCP rx and tx, from Eric Dumazet. This reduces
contention on SLAB spinlocks in heavy RPC workloads.
6) Partial GSO offload support in XFRM, from Boris Pismenny.
7) Add fast link down support to ethtool, from Heiner Kallweit.
8) Use siphash for IP ID generator, from Eric Dumazet.
9) Pull nexthops even further out from ipv4/ipv6 routes and FIB
entries, from David Ahern.
10) Move skb->xmit_more into a per-cpu variable, from Florian
Westphal.
11) Improve eBPF verifier speed and increase maximum program size,
from Alexei Starovoitov.
12) Eliminate per-bucket spinlocks in rhashtable, and instead use bit
spinlocks. From Neil Brown.
13) Allow tunneling with GUE encap in ipvs, from Jacky Hu.
14) Improve link partner cap detection in generic PHY code, from
Heiner Kallweit.
15) Add layer 2 encap support to bpf_skb_adjust_room(), from Alan
Maguire.
16) Remove SKB list implementation assumptions in SCTP, your's truly.
17) Various cleanups, optimizations, and simplifications in r8169
driver. From Heiner Kallweit.
18) Add memory accounting on TX and RX path of SCTP, from Xin Long.
19) Switch PHY drivers over to use dynamic featue detection, from
Heiner Kallweit.
20) Support flow steering without masking in dpaa2-eth, from Ioana
Ciocoi.
21) Implement ndo_get_devlink_port in netdevsim driver, from Jiri
Pirko.
22) Increase the strict parsing of current and future netlink
attributes, also export such policies to userspace. From Johannes
Berg.
23) Allow DSA tag drivers to be modular, from Andrew Lunn.
24) Remove legacy DSA probing support, also from Andrew Lunn.
25) Allow ll_temac driver to be used on non-x86 platforms, from Esben
Haabendal.
26) Add a generic tracepoint for TX queue timeouts to ease debugging,
from Cong Wang.
27) More indirect call optimizations, from Paolo Abeni"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1763 commits)
cxgb4: Fix error path in cxgb4_init_module
net: phy: improve pause mode reporting in phy_print_status
dt-bindings: net: Fix a typo in the phy-mode list for ethernet bindings
net: macb: Change interrupt and napi enable order in open
net: ll_temac: Improve error message on error IRQ
net/sched: remove block pointer from common offload structure
net: ethernet: support of_get_mac_address new ERR_PTR error
net: usb: smsc: fix warning reported by kbuild test robot
staging: octeon-ethernet: Fix of_get_mac_address ERR_PTR check
net: dsa: support of_get_mac_address new ERR_PTR error
net: dsa: sja1105: Fix status initialization in sja1105_get_ethtool_stats
vrf: sit mtu should not be updated when vrf netdev is the link
net: dsa: Fix error cleanup path in dsa_init_module
l2tp: Fix possible NULL pointer dereference
taprio: add null check on sched_nest to avoid potential null pointer dereference
net: mvpp2: cls: fix less than zero check on a u32 variable
net_sched: sch_fq: handle non connected flows
net_sched: sch_fq: do not assume EDT packets are ordered
net: hns3: use devm_kcalloc when allocating desc_cb
net: hns3: some cleanup for struct hns3_enet_ring
Pull misc dcache updates from Al Viro:
"Most of this pile is putting name length into struct name_snapshot and
making use of it.
The beginning of this series ("ovl_lookup_real_one(): don't bother
with strlen()") ought to have been split in two (separate switch of
name_snapshot to struct qstr from overlayfs reaping the trivial
benefits of that), but I wanted to avoid a rebase - by the time I'd
spotted that it was (a) in -next and (b) close to 5.1-final ;-/"
* 'work.dcache' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
audit_compare_dname_path(): switch to const struct qstr *
audit_update_watch(): switch to const struct qstr *
inotify_handle_event(): don't bother with strlen()
fsnotify: switch send_to_group() and ->handle_event to const struct qstr *
fsnotify(): switch to passing const struct qstr * for file_name
switch fsnotify_move() to passing const struct qstr * for old_name
ovl_lookup_real_one(): don't bother with strlen()
sysv: bury the broken "quietly truncate the long filenames" logics
nsfs: unobfuscate
unexport d_alloc_pseudo()
git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/audit
Pull audit updates from Paul Moore:
"We've got a reasonably broad set of audit patches for the v5.2 merge
window, the highlights are below:
- The biggest change, and the source of all the arch/* changes, is
the patchset from Dmitry to help enable some of the work he is
doing around PTRACE_GET_SYSCALL_INFO.
To be honest, including this in the audit tree is a bit of a
stretch, but it does help move audit a little further along towards
proper syscall auditing for all arches, and everyone else seemed to
agree that audit was a "good" spot for this to land (or maybe they
just didn't want to merge it? dunno.).
- We can now audit time/NTP adjustments.
- We continue the work to connect associated audit records into a
single event"
* tag 'audit-pr-20190507' of git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/audit: (21 commits)
audit: fix a memory leak bug
ntp: Audit NTP parameters adjustment
timekeeping: Audit clock adjustments
audit: purge unnecessary list_empty calls
audit: link integrity evm_write_xattrs record to syscall event
syscall_get_arch: add "struct task_struct *" argument
unicore32: define syscall_get_arch()
Move EM_UNICORE to uapi/linux/elf-em.h
nios2: define syscall_get_arch()
nds32: define syscall_get_arch()
Move EM_NDS32 to uapi/linux/elf-em.h
m68k: define syscall_get_arch()
hexagon: define syscall_get_arch()
Move EM_HEXAGON to uapi/linux/elf-em.h
h8300: define syscall_get_arch()
c6x: define syscall_get_arch()
arc: define syscall_get_arch()
Move EM_ARCOMPACT and EM_ARCV2 to uapi/linux/elf-em.h
audit: Make audit_log_cap and audit_copy_inode static
audit: connect LOGIN record to its syscall record
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb
Pull swiotlb updates from Konrad Rzeszutek Wilk:
"Cleanups in the swiotlb code and extra debugfs knobs to help with the
field diagnostics"
* 'stable/for-linus-5.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb:
swiotlb-xen: ensure we have a single callsite for xen_dma_map_page
swiotlb-xen: simplify the DMA sync method implementations
swiotlb-xen: use ->map_page to implement ->map_sg
swiotlb-xen: make instances match their method names
swiotlb: save io_tlb_used to local variable before leaving critical section
swiotlb: dump used and total slots when swiotlb buffer is full
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core/kobject updates from Greg KH:
"Here is the "big" set of driver core patches for 5.2-rc1
There are a number of ACPI patches in here as well, as Rafael said
they should go through this tree due to the driver core changes they
required. They have all been acked by the ACPI developers.
There are also a number of small subsystem-specific changes in here,
due to some changes to the kobject core code. Those too have all been
acked by the various subsystem maintainers.
As for content, it's pretty boring outside of the ACPI changes:
- spdx cleanups
- kobject documentation updates
- default attribute groups for kobjects
- other minor kobject/driver core fixes
All have been in linux-next for a while with no reported issues"
* tag 'driver-core-5.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (47 commits)
kobject: clean up the kobject add documentation a bit more
kobject: Fix kernel-doc comment first line
kobject: Remove docstring reference to kset
firmware_loader: Fix a typo ("syfs" -> "sysfs")
kobject: fix dereference before null check on kobj
Revert "driver core: platform: Fix the usage of platform device name(pdev->name)"
init/config: Do not select BUILD_BIN2C for IKCONFIG
Provide in-kernel headers to make extending kernel easier
kobject: Improve doc clarity kobject_init_and_add()
kobject: Improve docs for kobject_add/del
livepatch: Replace klp_ktype_patch's default_attrs with groups
cpufreq: schedutil: Replace default_attrs field with groups
padata: Replace padata_attr_type default_attrs field with groups
irqdesc: Replace irq_kobj_type's default_attrs field with groups
net-sysfs: Replace ktype default_attrs field with groups
block: Replace all ktype default_attrs with groups
samples/kobject: Replace foo_ktype's default_attrs field with groups
kobject: Add support for default attribute groups to kobj_type
driver core: Postpone DMA tear-down until after devres release for probe failure
git://git.kernel.org/pub/scm/linux/kernel/git/brauner/linux
Pull pidfd updates from Christian Brauner:
"This patchset makes it possible to retrieve pidfds at process creation
time by introducing the new flag CLONE_PIDFD to the clone() system
call. Linus originally suggested to implement this as a new flag to
clone() instead of making it a separate system call.
After a thorough review from Oleg CLONE_PIDFD returns pidfds in the
parent_tidptr argument. This means we can give back the associated pid
and the pidfd at the same time. Access to process metadata information
thus becomes rather trivial.
As has been agreed, CLONE_PIDFD creates file descriptors based on
anonymous inodes similar to the new mount api. They are made
unconditional by this patchset as they are now needed by core kernel
code (vfs, pidfd) even more than they already were before (timerfd,
signalfd, io_uring, epoll etc.). The core patchset is rather small.
The bulky looking changelist is caused by David's very simple changes
to Kconfig to make anon inodes unconditional.
A pidfd comes with additional information in fdinfo if the kernel
supports procfs. The fdinfo file contains the pid of the process in
the callers pid namespace in the same format as the procfs status
file, i.e. "Pid:\t%d".
To remove worries about missing metadata access this patchset comes
with a sample/test program that illustrates how a combination of
CLONE_PIDFD and pidfd_send_signal() can be used to gain race-free
access to process metadata through /proc/<pid>.
Further work based on this patchset has been done by Joel. His work
makes pidfds pollable. It finished too late for this merge window. I
would prefer to have it sitting in linux-next for a while and send it
for inclusion during the 5.3 merge window"
* tag 'pidfd-v5.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/brauner/linux:
samples: show race-free pidfd metadata access
signal: support CLONE_PIDFD with pidfd_send_signal
Make anon_inodes unconditional
Pull vfs stable fodder fixes from Al Viro:
- acct_on() fix for deadlock caught by overlayfs folks
- autofs RCU use-after-free SNAFU (->d_manage() can be called
locklessly, so we need to RCU-delay freeing the objects it looks at)
- (hopefully) the end of "do we need freeing this dentry RCU-delayed"
whack-a-mole.
* 'stable-fodder' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
autofs: fix use-after-free in lockless ->d_manage()
dcache: sort the freeing-without-RCU-delay mess for good.
acct_on(): don't mess with freeze protection
Pull vfs inode freeing updates from Al Viro:
"Introduction of separate method for RCU-delayed part of
->destroy_inode() (if any).
Pretty much as posted, except that destroy_inode() stashes
->free_inode into the victim (anon-unioned with ->i_fops) before
scheduling i_callback() and the last two patches (sockfs conversion
and folding struct socket_wq into struct socket) are excluded - that
pair should go through netdev once davem reopens his tree"
* 'work.icache' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (58 commits)
orangefs: make use of ->free_inode()
shmem: make use of ->free_inode()
hugetlb: make use of ->free_inode()
overlayfs: make use of ->free_inode()
jfs: switch to ->free_inode()
fuse: switch to ->free_inode()
ext4: make use of ->free_inode()
ecryptfs: make use of ->free_inode()
ceph: use ->free_inode()
btrfs: use ->free_inode()
afs: switch to use of ->free_inode()
dax: make use of ->free_inode()
ntfs: switch to ->free_inode()
securityfs: switch to ->free_inode()
apparmor: switch to ->free_inode()
rpcpipe: switch to ->free_inode()
bpf: switch to ->free_inode()
mqueue: switch to ->free_inode()
ufs: switch to ->free_inode()
coda: switch to ->free_inode()
git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk
Pull printk updates from Petr Mladek:
- Allow state reset of printk_once() calls.
- Prevent crashes when dereferencing invalid pointers in vsprintf().
Only the first byte is checked for simplicity.
- Make vsprintf warnings consistent and inlined.
- Treewide conversion of obsolete %pf, %pF to %ps, %pF printf
modifiers.
- Some clean up of vsprintf and test_printf code.
* tag 'printk-for-5.2' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk:
lib/vsprintf: Make function pointer_string static
vsprintf: Limit the length of inlined error messages
vsprintf: Avoid confusion between invalid address and value
vsprintf: Prevent crash when dereferencing invalid pointers
vsprintf: Consolidate handling of unknown pointer specifiers
vsprintf: Factor out %pO handler as kobject_string()
vsprintf: Factor out %pV handler as va_format()
vsprintf: Factor out %p[iI] handler as ip_addr_string()
vsprintf: Do not check address of well-known strings
vsprintf: Consistent %pK handling for kptr_restrict == 0
vsprintf: Shuffle restricted_pointer()
printk: Tie printk_once / printk_deferred_once into .data.once for reset
treewide: Switch printk users from %pf and %pF to %ps and %pS, respectively
lib/test_printf: Switch to bitmap_zalloc()
git://git.kernel.org/pub/scm/linux/kernel/git/livepatching/livepatching
Pull livepatching updates from Jiri Kosina:
- livepatching kselftests improvements from Joe Lawrence and Miroslav
Benes
- making use of gcc's -flive-patching option when available, from
Miroslav Benes
- kobject handling cleanups, from Petr Mladek
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/livepatching/livepatching:
livepatch: Remove duplicated code for early initialization
livepatch: Remove custom kobject state handling
livepatch: Convert error about unsupported reliable stacktrace into a warning
selftests/livepatch: Add functions.sh to TEST_PROGS_EXTENDED
kbuild: use -flive-patching when CONFIG_LIVEPATCH is enabled
selftests/livepatch: use TEST_PROGS for test scripts
Pull security subsystem updates from James Morris:
"Just a few bugfixes and documentation updates"
* 'next-general' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
seccomp: fix up grammar in comment
Revert "security: inode: fix a missing check for securityfs_create_file"
Yama: mark function as static
keys: safe concurrent user->{session,uid}_keyring access
security: don't use RCU accessors for cred->session_keyring
Yama: mark local symbols as static
LSM: lsm_hooks.h: fix documentation format
LSM: fix documentation for the shm_* hooks
LSM: fix documentation for the sem_* hooks
LSM: fix documentation for the msg_queue_* hooks
LSM: fix documentation for the audit_* hooks
LSM: fix documentation for the path_chmod hook
LSM: fix documentation for the socket_getpeersec_dgram hook
LSM: fix documentation for the task_setscheduler hook
LSM: fix documentation for the socket_post_create hook
LSM: fix documentation for the syslog hook
LSM: fix documentation for sb_copy_data hook
Let pidfd_send_signal() use pidfds retrieved via CLONE_PIDFD. With this
patch pidfd_send_signal() becomes independent of procfs. This fullfils
the request made when we merged the pidfd_send_signal() patchset. The
pidfd_send_signal() syscall is now always available allowing for it to
be used by users without procfs mounted or even users without procfs
support compiled into the kernel.
Co-developed-by: Jann Horn <jannh@google.com>
Signed-off-by: Jann Horn <jannh@google.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: "Michael Kerrisk (man-pages)" <mtk.manpages@gmail.com>
Cc: Andy Lutomirsky <luto@kernel.org>
Cc: Aleksa Sarai <cyphar@cyphar.com>
This patchset makes it possible to retrieve pid file descriptors at
process creation time by introducing the new flag CLONE_PIDFD to the
clone() system call. Linus originally suggested to implement this as a
new flag to clone() instead of making it a separate system call. As
spotted by Linus, there is exactly one bit for clone() left.
CLONE_PIDFD creates file descriptors based on the anonymous inode
implementation in the kernel that will also be used to implement the new
mount api. They serve as a simple opaque handle on pids. Logically,
this makes it possible to interpret a pidfd differently, narrowing or
widening the scope of various operations (e.g. signal sending). Thus, a
pidfd cannot just refer to a tgid, but also a tid, or in theory - given
appropriate flag arguments in relevant syscalls - a process group or
session. A pidfd does not represent a privilege. This does not imply it
cannot ever be that way but for now this is not the case.
A pidfd comes with additional information in fdinfo if the kernel supports
procfs. The fdinfo file contains the pid of the process in the callers
pid namespace in the same format as the procfs status file, i.e. "Pid:\t%d".
As suggested by Oleg, with CLONE_PIDFD the pidfd is returned in the
parent_tidptr argument of clone. This has the advantage that we can
give back the associated pid and the pidfd at the same time.
To remove worries about missing metadata access this patchset comes with
a sample program that illustrates how a combination of CLONE_PIDFD, and
pidfd_send_signal() can be used to gain race-free access to process
metadata through /proc/<pid>. The sample program can easily be
translated into a helper that would be suitable for inclusion in libc so
that users don't have to worry about writing it themselves.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto update from Herbert Xu:
"API:
- Add support for AEAD in simd
- Add fuzz testing to testmgr
- Add panic_on_fail module parameter to testmgr
- Use per-CPU struct instead multiple variables in scompress
- Change verify API for akcipher
Algorithms:
- Convert x86 AEAD algorithms over to simd
- Forbid 2-key 3DES in FIPS mode
- Add EC-RDSA (GOST 34.10) algorithm
Drivers:
- Set output IV with ctr-aes in crypto4xx
- Set output IV in rockchip
- Fix potential length overflow with hashing in sun4i-ss
- Fix computation error with ctr in vmx
- Add SM4 protected keys support in ccree
- Remove long-broken mxc-scc driver
- Add rfc4106(gcm(aes)) cipher support in cavium/nitrox"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (179 commits)
crypto: ccree - use a proper le32 type for le32 val
crypto: ccree - remove set but not used variable 'du_size'
crypto: ccree - Make cc_sec_disable static
crypto: ccree - fix spelling mistake "protedcted" -> "protected"
crypto: caam/qi2 - generate hash keys in-place
crypto: caam/qi2 - fix DMA mapping of stack memory
crypto: caam/qi2 - fix zero-length buffer DMA mapping
crypto: stm32/cryp - update to return iv_out
crypto: stm32/cryp - remove request mutex protection
crypto: stm32/cryp - add weak key check for DES
crypto: atmel - remove set but not used variable 'alg_name'
crypto: picoxcell - Use dev_get_drvdata()
crypto: crypto4xx - get rid of redundant using_sd variable
crypto: crypto4xx - use sync skcipher for fallback
crypto: crypto4xx - fix cfb and ofb "overran dst buffer" issues
crypto: crypto4xx - fix ctr-aes missing output IV
crypto: ecrdsa - select ASN1 and OID_REGISTRY for EC-RDSA
crypto: ux500 - use ccflags-y instead of CFLAGS_<basename>.o
crypto: ccree - handle tee fips error during power management resume
crypto: ccree - add function to handle cryptocell tee fips error
Pull power management updates from Rafael Wysocki:
"These fix the (Intel-specific) Performance and Energy Bias Hint (EPB)
handling and expose it to user space via sysfs, fix and clean up
several cpufreq drivers, add support for two new chips to the qoriq
cpufreq driver, fix, simplify and clean up the cpufreq core and the
schedutil governor, add support for "CPU" domains to the generic power
domains (genpd) framework and provide low-level PSCI firmware support
for that feature, fix the exynos cpuidle driver and fix a couple of
issues in the devfreq subsystem and clean it up.
Specifics:
- Fix the handling of Performance and Energy Bias Hint (EPB) on Intel
processors and expose it to user space via sysfs to avoid having to
access it through the generic MSR I/F (Rafael Wysocki).
- Improve the handling of global turbo changes made by the platform
firmware in the intel_pstate driver (Rafael Wysocki).
- Convert some slow-path static_cpu_has() callers to boot_cpu_has()
in cpufreq (Borislav Petkov).
- Fix the frequency calculation loop in the armada-37xx cpufreq
driver (Gregory CLEMENT).
- Fix possible object reference leaks in multuple cpufreq drivers
(Wen Yang).
- Fix kerneldoc comment in the centrino cpufreq driver (dongjian).
- Clean up the ACPI and maple cpufreq drivers (Viresh Kumar, Mohan
Kumar).
- Add support for lx2160a and ls1028a to the qoriq cpufreq driver
(Vabhav Sharma, Yuantian Tang).
- Fix kobject memory leak in the cpufreq core (Viresh Kumar).
- Simplify the IOwait boosting in the schedutil cpufreq governor and
rework the TSC cpufreq notifier on x86 (Rafael Wysocki).
- Clean up the cpufreq core and statistics code (Yue Hu, Kyle Lin).
- Improve the cpufreq documentation, add SPDX license tags to some PM
documentation files and unify copyright notices in them (Rafael
Wysocki).
- Add support for "CPU" domains to the generic power domains (genpd)
framework and provide low-level PSCI firmware support for that
feature (Ulf Hansson).
- Rearrange the PSCI firmware support code and add support for
SYSTEM_RESET2 to it (Ulf Hansson, Sudeep Holla).
- Improve genpd support for devices in multiple power domains (Ulf
Hansson).
- Unify target residency for the AFTR and coupled AFTR states in the
exynos cpuidle driver (Marek Szyprowski).
- Introduce new helper routine in the operating performance points
(OPP) framework (Andrew-sh.Cheng).
- Add support for passing on-die termination (ODT) and auto power
down parameters from the kernel to Trusted Firmware-A (TF-A) to the
rk3399_dmc devfreq driver (Enric Balletbo i Serra).
- Add tracing to devfreq (Lukasz Luba).
- Make the exynos-bus devfreq driver suspend all devices on system
shutdown (Marek Szyprowski).
- Fix a few minor issues in the devfreq subsystem and clean it up
somewhat (Enric Balletbo i Serra, MyungJoo Ham, Rob Herring,
Saravana Kannan, Yangtao Li).
- Improve system wakeup diagnostics (Stephen Boyd).
- Rework filesystem sync messages emitted during system suspend and
hibernation (Harry Pan)"
* tag 'pm-5.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (72 commits)
cpufreq: Fix kobject memleak
cpufreq: armada-37xx: fix frequency calculation for opp
cpufreq: centrino: Fix centrino_setpolicy() kerneldoc comment
cpufreq: qoriq: add support for lx2160a
x86: tsc: Rework time_cpufreq_notifier()
PM / Domains: Allow to attach a CPU via genpd_dev_pm_attach_by_id|name()
PM / Domains: Search for the CPU device outside the genpd lock
PM / Domains: Drop unused in-parameter to some genpd functions
PM / Domains: Use the base device for driver_deferred_probe_check_state()
cpufreq: qoriq: Add ls1028a chip support
PM / Domains: Enable genpd_dev_pm_attach_by_id|name() for single PM domain
PM / Domains: Allow OF lookup for multi PM domain case from ->attach_dev()
PM / Domains: Don't kfree() the virtual device in the error path
cpufreq: Move ->get callback check outside of __cpufreq_get()
PM / Domains: remove unnecessary unlikely()
cpufreq: Remove needless bios_limit check in show_bios_limit()
drivers/cpufreq/acpi-cpufreq.c: This fixes the following checkpatch warning
firmware/psci: add support for SYSTEM_RESET2
PM / devfreq: add tracing for scheduling work
trace: events: add devfreq trace event file
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
"Mostly just incremental improvements here:
- Introduce AT_HWCAP2 for advertising CPU features to userspace
- Expose SVE2 availability to userspace
- Support for "data cache clean to point of deep persistence" (DC PODP)
- Honour "mitigations=off" on the cmdline and advertise status via
sysfs
- CPU timer erratum workaround (Neoverse-N1 #1188873)
- Introduce perf PMU driver for the SMMUv3 performance counters
- Add config option to disable the kuser helpers page for AArch32 tasks
- Futex modifications to ensure liveness under contention
- Rework debug exception handling to seperate kernel and user
handlers
- Non-critical fixes and cleanup"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (92 commits)
Documentation: Add ARM64 to kernel-parameters.rst
arm64/speculation: Support 'mitigations=' cmdline option
arm64: ssbs: Don't treat CPUs with SSBS as unaffected by SSB
arm64: enable generic CPU vulnerabilites support
arm64: add sysfs vulnerability show for speculative store bypass
arm64: Fix size of __early_cpu_boot_status
clocksource/arm_arch_timer: Use arch_timer_read_counter to access stable counters
clocksource/arm_arch_timer: Remove use of workaround static key
clocksource/arm_arch_timer: Drop use of static key in arch_timer_reg_read_stable
clocksource/arm_arch_timer: Direcly assign set_next_event workaround
arm64: Use arch_timer_read_counter instead of arch_counter_get_cntvct
watchdog/sbsa: Use arch_timer_read_counter instead of arch_counter_get_cntvct
ARM: vdso: Remove dependency with the arch_timer driver internals
arm64: Apply ARM64_ERRATUM_1188873 to Neoverse-N1
arm64: Add part number for Neoverse N1
arm64: Make ARM64_ERRATUM_1188873 depend on COMPAT
arm64: Restrict ARM64_ERRATUM_1188873 mitigation to AArch32
arm64: mm: Remove pte_unmap_nested()
arm64: Fix compiler warning from pte_unmap() with -Wunused-but-set-variable
arm64: compat: Reduce address limit for 64K pages
Pull mmiowb removal from Will Deacon:
"Remove Mysterious Macro Intended to Obscure Weird Behaviours (mmiowb())
Remove mmiowb() from the kernel memory barrier API and instead, for
architectures that need it, hide the barrier inside spin_unlock() when
MMIO has been performed inside the critical section.
The only relatively recent changes have been addressing review
comments on the documentation, which is in a much better shape thanks
to the efforts of Ben and Ingo.
I was initially planning to split this into two pull requests so that
you could run the coccinelle script yourself, however it's been plain
sailing in linux-next so I've just included the whole lot here to keep
things simple"
* tag 'arm64-mmiowb' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (23 commits)
docs/memory-barriers.txt: Update I/O section to be clearer about CPU vs thread
docs/memory-barriers.txt: Fix style, spacing and grammar in I/O section
arch: Remove dummy mmiowb() definitions from arch code
net/ethernet/silan/sc92031: Remove stale comment about mmiowb()
i40iw: Redefine i40iw_mmiowb() to do nothing
scsi/qla1280: Remove stale comment about mmiowb()
drivers: Remove explicit invocations of mmiowb()
drivers: Remove useless trailing comments from mmiowb() invocations
Documentation: Kill all references to mmiowb()
riscv/mmiowb: Hook up mmwiob() implementation to asm-generic code
powerpc/mmiowb: Hook up mmwiob() implementation to asm-generic code
ia64/mmiowb: Add unconditional mmiowb() to arch_spin_unlock()
mips/mmiowb: Add unconditional mmiowb() to arch_spin_unlock()
sh/mmiowb: Add unconditional mmiowb() to arch_spin_unlock()
m68k/io: Remove useless definition of mmiowb()
nds32/io: Remove useless definition of mmiowb()
x86/io: Remove useless definition of mmiowb()
arm64/io: Remove useless definition of mmiowb()
ARM/io: Remove useless definition of mmiowb()
mmiowb: Hook up mmiowb helpers to spinlocks and generic I/O accessors
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
- Support for kernel address space layout randomization
- Add support for kernel image signature verification
- Convert s390 to the generic get_user_pages_fast code
- Convert s390 to the stack unwind API analog to x86
- Add support for CPU directed interrupts for PCI devices
- Provide support for MIO instructions to the PCI base layer, this will
allow the use of direct PCI mappings in user space code
- Add the basic KVM guest ultravisor interface for protected VMs
- Add AT_HWCAP bits for several new hardware capabilities
- Update the CPU measurement facility counter definitions to SVN 6
- Arnds cleanup patches for his quest to get LLVM compiles working
- A vfio-ccw update with bug fixes and support for halt and clear
- Improvements for the hardware TRNG code
- Another round of cleanup for the QDIO layer
- Numerous cleanups and bug fixes
* tag 's390-5.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (98 commits)
s390/vdso: drop unnecessary cc-ldoption
s390: fix clang -Wpointer-sign warnigns in boot code
s390: drop CONFIG_VIRT_TO_BUS
s390: boot, purgatory: pass $(CLANG_FLAGS) where needed
s390: only build for new CPUs with clang
s390: simplify disabled_wait
s390/ftrace: use HAVE_FUNCTION_GRAPH_RET_ADDR_PTR
s390/unwind: introduce stack unwind API
s390/opcodes: add missing instructions to the disassembler
s390/bug: add entry size to the __bug_table section
s390: use proper expoline sections for .dma code
s390/nospec: rename assembler generated expoline thunks
s390: add missing ENDPROC statements to assembler functions
locking/lockdep: check for freed initmem in static_obj()
s390/kernel: add support for kernel address space layout randomization (KASLR)
s390/kernel: introduce .dma sections
s390/sclp: do not use static sccbs
s390/kprobes: use static buffer for insn_page
s390/kernel: convert SYSCALL and PGM_CHECK handlers to .quad
s390/kernel: build a relocatable kernel
Pull x86 mm updates from Ingo Molnar:
"The changes in here are:
- text_poke() fixes and an extensive set of executability lockdowns,
to (hopefully) eliminate the last residual circumstances under
which we are using W|X mappings even temporarily on x86 kernels.
This required a broad range of surgery in text patching facilities,
module loading, trampoline handling and other bits.
- tweak page fault messages to be more informative and more
structured.
- remove DISCONTIGMEM support on x86-32 and make SPARSEMEM the
default.
- reduce KASLR granularity on 5-level paging kernels from 512 GB to
1 GB.
- misc other changes and updates"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (36 commits)
x86/mm: Initialize PGD cache during mm initialization
x86/alternatives: Add comment about module removal races
x86/kprobes: Use vmalloc special flag
x86/ftrace: Use vmalloc special flag
bpf: Use vmalloc special flag
modules: Use vmalloc special flag
mm/vmalloc: Add flag for freeing of special permsissions
mm/hibernation: Make hibernation handle unmapped pages
x86/mm/cpa: Add set_direct_map_*() functions
x86/alternatives: Remove the return value of text_poke_*()
x86/jump-label: Remove support for custom text poker
x86/modules: Avoid breaking W^X while loading modules
x86/kprobes: Set instruction page as executable
x86/ftrace: Set trampoline pages as executable
x86/kgdb: Avoid redundant comparison of patched code
x86/alternatives: Use temporary mm for text poking
x86/alternatives: Initialize temporary mm for patching
fork: Provide a function for copying init_mm
uprobes: Initialize uprobes earlier
x86/mm: Save debug registers when loading a temporary mm
Pull timer updates from Ingo Molnar:
"This cycle had the following changes:
- Timer tracing improvements (Anna-Maria Gleixner)
- Continued tasklet reduction work: remove the hrtimer_tasklet
(Thomas Gleixner)
- Fix CPU hotplug remove race in the tick-broadcast mask handling
code (Thomas Gleixner)
- Force upper bound for setting CLOCK_REALTIME, to fix ABI
inconsistencies with handling values that are close to the maximum
supported and the vagueness of when uptime related wraparound might
occur. Make the consistent maximum the year 2232 across all
relevant ABIs and APIs. (Thomas Gleixner)
- various cleanups and smaller fixes"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
tick: Fix typos in comments
tick/broadcast: Fix warning about undefined tick_broadcast_oneshot_offline()
timekeeping: Force upper bound for setting CLOCK_REALTIME
timer/trace: Improve timer tracing
timer/trace: Replace deprecated vsprintf pointer extension %pf by %ps
timer: Move trace point to get proper index
tick/sched: Update tick_sched struct documentation
tick: Remove outgoing CPU from broadcast masks
timekeeping: Consistently use unsigned int for seqcount snapshot
softirq: Remove tasklet_hrtimer
xfrm: Replace hrtimer tasklet with softirq hrtimer
mac80211_hwsim: Replace hrtimer tasklet with softirq hrtimer
Pull CPU hotplug updates from Ingo Molnar:
"Two changes in this cycle:
- Make the /sys/devices/system/cpu/smt/* files available on all
arches, so user space has a consistent way to detect whether SMT is
enabled.
- Sparse annotation fix"
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
smpboot: Place the __percpu annotation correctly
cpu/hotplug: Create SMT sysfs interface for all arches
Pull scheduler updates from Ingo Molnar:
"The main changes in this cycle were:
- Make nohz housekeeping processing more permissive and less
intrusive to isolated CPUs
- Decouple CPU-bound workqueue acconting from the scheduler and move
it into the workqueue code.
- Optimize topology building
- Better handle quota and period overflows
- Add more RCU annotations
- Comment updates, misc cleanups"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (25 commits)
nohz_full: Allow the boot CPU to be nohz_full
sched/isolation: Require a present CPU in housekeeping mask
kernel/cpu: Allow non-zero CPU to be primary for suspend / kexec freeze
power/suspend: Add function to disable secondaries for suspend
sched/core: Allow the remote scheduler tick to be started on CPU0
sched/nohz: Run NOHZ idle load balancer on HK_FLAG_MISC CPUs
sched/debug: Fix spelling mistake "logaritmic" -> "logarithmic"
sched/topology: Update init_sched_domains() comment
cgroup/cpuset: Update stale generate_sched_domains() comments
sched/core: Check quota and period overflow at usec to nsec conversion
sched/core: Handle overflow in cpu_shares_write_u64
sched/rt: Check integer overflow at usec to nsec conversion
sched/core: Fix typo in comment
sched/core: Make some functions static
sched/core: Unify p->on_rq updates
sched/core: Remove ttwu_activate()
sched/core, workqueues: Distangle worker accounting from rq lock
sched/fair: Remove unneeded prototype of capacity_of()
sched/topology: Skip duplicate group rewrites in build_sched_groups()
sched/topology: Fix build_sched_groups() comment
