path: root/kernel
2016-06-15kernel/kcov: unproxify debugfs file's fopsNicolai Stange
Since commit 49d200deaa68 ("debugfs: prevent access to removed files' private data"), a debugfs file's file_operations methods get proxied through lifetime aware wrappers. However, only a certain subset of the file_operations members is supported by debugfs and ->mmap isn't among them -- it appears to be NULL from the VFS layer's perspective. This behaviour breaks the /sys/kernel/debug/kcov file introduced concurrently with commit 5c9a8750a640 ("kernel: add kcov code coverage"). Since that file never gets removed, there is no file removal race and thus, a lifetime checking proxy isn't needed. Avoid the proxying for /sys/kernel/debug/kcov by creating it via debugfs_create_file_unsafe() rather than debugfs_create_file(). Fixes: 49d200deaa68 ("debugfs: prevent access to removed files' private data") Fixes: 5c9a8750a640 ("kernel: add kcov code coverage") Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Nicolai Stange <nicstange@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-10Merge branch 'stacking-fixes' (vfs stacking fixes from Jann)Linus Torvalds
Merge filesystem stacking fixes from Jann Horn. * emailed patches from Jann Horn <jannh@google.com>: sched: panic on corrupted stack end ecryptfs: forbid opening files without mmap handler proc: prevent stacking filesystems on top
2016-06-10sched: panic on corrupted stack endJann Horn
Until now, hitting this BUG_ON caused a recursive oops (because oops handling involves do_exit(), which calls into the scheduler, which in turn raises an oops), which caused stuff below the stack to be overwritten until a panic happened (e.g. via an oops in interrupt context, caused by the overwritten CPU index in the thread_info). Just panic directly. Signed-off-by: Jann Horn <jannh@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-10Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Two scheduler debugging fixes" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/debug: Fix 'schedstats=enable' cmdline option sched/debug: Fix /proc/sched_debug regression
2016-06-10Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "A handful of tooling fixes, two PMU driver fixes and a cleanup of redundant code that addresses a security analyzer false positive" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/core: Remove a redundant check perf/x86/intel/uncore: Remove SBOX support for Broadwell server perf ctf: Convert invalid chars in a string before set value perf record: Fix crash when kptr is restricted perf symbols: Check kptr_restrict for root perf/x86/intel/rapl: Fix pmus free during cleanup
2016-06-10Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fixes from Ingo Molnar: "Misc fixes: - a file-based futex fix - one more spin_unlock_wait() fix - a ww-mutex deadlock detection improvement/fix - and a raw_read_seqcount_latch() barrier fix" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: futex: Calculate the futex key based on a tail page for file-based futexes locking/qspinlock: Fix spin_unlock_wait() some more locking/ww_mutex: Report recursive ww_mutex locking early locking/seqcount: Re-fix raw_read_seqcount_latch()
2016-06-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) nfnetlink timestamp taken from wrong skb, fix from Florian Westphal. 2) Revert some msleep conversions in rtlwifi as these spots are in atomic context, from Larry Finger. 3) Validate that NFTA_SET_TABLE attribute is actually specified when we call nf_tables_getset(). From Phil Turnbull. 4) Don't do mdio_reset in stmmac driver with spinlock held as that can sleep, from Vincent Palatin. 5) sk_filter() does things other than run a BPF filter, so we should not elide it's call just because sk->sk_filter is NULL. Fix from Eric Dumazet. 6) Fix missing backlog updates in several packet schedulers, from Cong Wang. 7) bnx2x driver should allow VLAN add/remove while the interface is down, from Michal Schmidt. 8) Several RDS/TCP race fixes from Sowmini Varadhan. 9) fq_codel scheduler doesn't return correct queue length in dumps, from Eric Dumazet. 10) Fix TCP stats for tail loss probe and early retransmit in ipv6, from Yuchung Cheng. 11) Properly initialize udp_tunnel_socket_cfg in l2tp_tunnel_create(), from Guillaume Nault. 12) qfq scheduler leaks SKBs if a kzalloc fails, fix from Florian Westphal. 13) sock_fprog passed into PACKET_FANOUT_DATA needs compat handling, from Willem de Bruijn. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (85 commits) vmxnet3: segCnt can be 1 for LRO packets packet: compat support for sock_fprog stmmac: fix parameter to dwmac4_set_umac_addr() net/mlx5e: Fix blue flame quota logic net/mlx5e: Use ndo_stop explicitly at shutdown flow net/mlx5: E-Switch, always set mc_promisc for allmulti vports net/mlx5: E-Switch, Modify node guid on vf set MAC net/mlx5: E-Switch, Fix vport enable flow net/mlx5: E-Switch, Use the correct error check on returned pointers net/mlx5: E-Switch, Use the correct free() function net/mlx5: Fix E-Switch flow steering capabilities check net/mlx5: Fix flow steering NIC capabilities check net/mlx5: Fix root flow table update net/mlx5: Fix MLX5_CMD_OP_MAX to be defined correctly net/mlx5: Fix masking of reserved bits in XRCD number net/mlx5: Fix the size of modify QP mailbox mlxsw: spectrum: Don't sleep during ndo_get_phys_port_name() mlxsw: spectrum: Make split flow match firmware requirements wext: Fix 32 bit iwpriv compatibility issue with 64 bit Kernel cfg80211: remove get/set antenna and tx power warnings ...
2016-06-10Merge tag 'pm-4.7-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management fixes from Rafael Wysocki: "Stable-candidate fixes for the intel_pstate driver and the cpuidle core. Specifics: - Fix two intel_pstate initialization issues, one of which was introduced during the 4.4 cycle (Srinivas Pandruvada) - Fix kernel build with CONFIG_UBSAN set and CONFIG_CPU_IDLE unset (Catalin Marinas)" * tag 'pm-4.7-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: cpufreq: intel_pstate: Fix ->set_policy() interface for no_turbo cpufreq: intel_pstate: Fix code ordering in intel_pstate_set_policy() cpuidle: Do not access cpuidle_devices when !CONFIG_CPU_IDLE
2016-06-09Merge branches 'pm-cpufreq-fixes' and 'pm-cpuidle'Rafael J. Wysocki
* pm-cpufreq-fixes: cpufreq: intel_pstate: Fix ->set_policy() interface for no_turbo cpufreq: intel_pstate: Fix code ordering in intel_pstate_set_policy() * pm-cpuidle: cpuidle: Do not access cpuidle_devices when !CONFIG_CPU_IDLE
2016-06-09kernel/relay.c: fix potential memory leakZhouyi Zhou
When relay_open_buf() fails in relay_open(), code will goto free_bufs, but chan is nowhere freed. Link: http://lkml.kernel.org/r/1464777927-19675-1-git-send-email-yizhouzhou@ict.ac.cn Signed-off-by: Zhouyi Zhou <zhouzhouyi@gmail.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-08futex: Calculate the futex key based on a tail page for file-based futexesMel Gorman
Mike Galbraith reported that the LTP test case futex_wake04 was broken by commit 65d8fc777f6d ("futex: Remove requirement for lock_page() in get_futex_key()"). This test case uses futexes backed by hugetlbfs pages and so there is an associated inode with a futex stored on such pages. The problem is that the key is being calculated based on the head page index of the hugetlbfs page and not the tail page. Prior to the optimisation, the page lock was used to stabilise mappings and pin the inode is file-backed which is overkill. If the page was a compound page, the head page was automatically looked up as part of the page lock operation but the tail page index was used to calculate the futex key. After the optimisation, the compound head is looked up early and the page lock is only relied upon to identify truncated pages, special pages or a shmem page moving to swapcache. The head page is looked up because without the page lock, special care has to be taken to pin the inode correctly. However, the tail page is still required to calculate the futex key so this patch records the tail page. On vanilla 4.6, the output of the test case is; futex_wake04 0 TINFO : Hugepagesize 2097152 futex_wake04 1 TFAIL : futex_wake04.c:126: Bug: wait_thread2 did not wake after 30 secs. With the patch applied futex_wake04 0 TINFO : Hugepagesize 2097152 futex_wake04 1 TPASS : Hi hydra, thread2 awake! Fixes: 65d8fc777f6d "futex: Remove requirement for lock_page() in get_futex_key()" Reported-and-tested-by: Mike Galbraith <umgwanakikbuti@gmail.com> Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Davidlohr Bueso <dave@stgolabs.net> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/20160608132522.GM2469@suse.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-06-08sched/debug: Fix 'schedstats=enable' cmdline optionJosh Poimboeuf
The 'schedstats=enable' option doesn't work, and also produces the following warning during boot: WARNING: CPU: 0 PID: 0 at /home/jpoimboe/git/linux/kernel/jump_label.c:61 static_key_slow_inc+0x8c/0xa0 static_key_slow_inc used before call to jump_label_init Modules linked in: CPU: 0 PID: 0 Comm: swapper Not tainted 4.7.0-rc1+ #25 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014 0000000000000086 3ae3475a4bea95d4 ffffffff81e03da8 ffffffff8143fc83 ffffffff81e03df8 0000000000000000 ffffffff81e03de8 ffffffff810b1ffb 0000003d00000096 ffffffff823514d0 ffff88007ff197c8 0000000000000000 Call Trace: [<ffffffff8143fc83>] dump_stack+0x85/0xc2 [<ffffffff810b1ffb>] __warn+0xcb/0xf0 [<ffffffff810b207f>] warn_slowpath_fmt+0x5f/0x80 [<ffffffff811e9c0c>] static_key_slow_inc+0x8c/0xa0 [<ffffffff810e07c6>] static_key_enable+0x16/0x40 [<ffffffff8216d633>] setup_schedstats+0x29/0x94 [<ffffffff82148a05>] unknown_bootoption+0x89/0x191 [<ffffffff810d8617>] parse_args+0x297/0x4b0 [<ffffffff82148d61>] start_kernel+0x1d8/0x4a9 [<ffffffff8214897c>] ? set_init_arg+0x55/0x55 [<ffffffff82148120>] ? early_idt_handler_array+0x120/0x120 [<ffffffff821482db>] x86_64_start_reservations+0x2f/0x31 [<ffffffff82148427>] x86_64_start_kernel+0x14a/0x16d The problem is that it tries to update the 'sched_schedstats' static key before jump labels have been initialized. Changing jump_label_init() to be called earlier before parse_early_param() wouldn't fix it: it would still fail trying to poke_text() because mm isn't yet initialized. Instead, just create a temporary '__sched_schedstats' variable which can be copied to the static key later during sched_init() after jump labels have been initialized. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: cb2517653fcc ("sched/debug: Make schedstats a runtime tunable that is disabled by default") Link: http://lkml.kernel.org/r/453775fe3433bed65731a583e228ccea806d18cd.1465322027.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-08sched/debug: Fix /proc/sched_debug regressionJosh Poimboeuf
Commit: cb2517653fcc ("sched/debug: Make schedstats a runtime tunable that is disabled by default") ... introduced a bug when CONFIG_SCHEDSTATS is enabled and the runtime tunable is disabled (which is the default). The wait-time, sum-exec, and sum-sleep fields are missing from the /proc/sched_debug file in the runnable_tasks section. Fix it with a new schedstat_val() macro which returns the field value when schedstats is enabled and zero otherwise. The macro works with both SCHEDSTATS and !SCHEDSTATS. I put the macro in stats.h since it might end up being useful in other places. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Mel Gorman <mgorman@techsingularity.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: cb2517653fcc ("sched/debug: Make schedstats a runtime tunable that is disabled by default") Link: http://lkml.kernel.org/r/bcda7c2790cf2ccbe586a28c02dd7b6fe7749a2b.1464994423.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-08perf/core: Remove a redundant checkAlexander Shishkin
There is no way to end up in _free_event() with event::pmu being NULL. The latter is initialized in event allocation path and remains set forever. In case of allocation failure, the error path doesn't use _free_event(). Having the check, however, suggests that it is possible to have a event::pmu==NULL situation in _free_event() and confuses the robots. This patch gets rid of the check. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: eranian@google.com Cc: vince@deater.net Link: http://lkml.kernel.org/r/1465303455-26032-1-git-send-email-alexander.shishkin@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-08locking/qspinlock: Fix spin_unlock_wait() some morePeter Zijlstra
While this prior commit: 54cf809b9512 ("locking,qspinlock: Fix spin_is_locked() and spin_unlock_wait()") ... fixes spin_is_locked() and spin_unlock_wait() for the usage in ipc/sem and netfilter, it does not in fact work right for the usage in task_work and futex. So while the 2 locks crossed problem: spin_lock(A) spin_lock(B) if (!spin_is_locked(B)) spin_unlock_wait(A) foo() foo(); ... works with the smp_mb() injected by both spin_is_locked() and spin_unlock_wait(), this is not sufficient for: flag = 1; smp_mb(); spin_lock() spin_unlock_wait() if (!flag) // add to lockless list // iterate lockless list ... because in this scenario, the store from spin_lock() can be delayed past the load of flag, uncrossing the variables and loosing the guarantee. This patch reworks spin_is_locked() and spin_unlock_wait() to work in both cases by exploiting the observation that while the lock byte store can be delayed, the contender must have registered itself visibly in other state contained in the word. It also allows for architectures to override both functions, as PPC and ARM64 have an additional issue for which we currently have no generic solution. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Boqun Feng <boqun.feng@gmail.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Giovanni Gherdovich <ggherdovich@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Pan Xinhui <xinhui.pan@linux.vnet.ibm.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Waiman Long <waiman.long@hpe.com> Cc: Will Deacon <will.deacon@arm.com> Cc: stable@vger.kernel.org # v4.2 and later Fixes: 54cf809b9512 ("locking,qspinlock: Fix spin_is_locked() and spin_unlock_wait()") Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-07bpf, trace: use READ_ONCE for retrieving file ptrDaniel Borkmann
In bpf_perf_event_read() and bpf_perf_event_output(), we must use READ_ONCE() for fetching the struct file pointer, which could get updated concurrently, so we must prevent the compiler from potential refetching. We already do this with tail calls for fetching the related bpf_prog, but not so on stored perf events. Semantics for both are the same with regards to updates. Fixes: a43eec304259 ("bpf: introduce bpf_perf_event_output() helper") Fixes: 35578d798400 ("bpf: Implement function bpf_perf_event_read() that get the selected hardware PMU conuter") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-03Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: - a few simple fixes for fallout from the recent gic-v3 changes - a workaround for a Cavium thunderX erratum - a bugfix for the pic32 irqchip to make external interrupts work proper - a missing return value in the generic IPI management code * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip/irq-pic32-evic: Fix bug with external interrupts. irqchip/gicv3-its: numa: Enable workaround for Cavium thunderx erratum 23144 irqchip/gic-v3: Fix quiescence check in gic_enable_redist irqchip/gic-v3: Fix copy+paste mistakes in defines irqchip/gic-v3: Fix ICC_SGI1R_EL1.INTID decoding mask genirq: Fix missing return value in irq_destroy_ipi()
2016-06-03Merge tag 'irqchip-4.7-rc1' of ↵Thomas Gleixner
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into irq/urgent Merge irqchip updates from Marc Zyngier: - A number of embarassing buglets (GICv3, PIC32) - A more substential errata workaround for Cavium's GICv3 ITS (kept for post-rc1 due to its dependency on NUMA)
2016-06-03locking/ww_mutex: Report recursive ww_mutex locking earlyChris Wilson
Recursive locking for ww_mutexes was originally conceived as an exception. However, it is heavily used by the DRM atomic modesetting code. Currently, the recursive deadlock is checked after we have queued up for a busy-spin and as we never release the lock, we spin until kicked, whereupon the deadlock is discovered and reported. A simple solution for the now common problem is to move the recursive deadlock discovery to the first action when taking the ww_mutex. Suggested-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1464293297-19777-1-git-send-email-chris@chris-wilson.co.uk Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-02cpuidle: Do not access cpuidle_devices when !CONFIG_CPU_IDLECatalin Marinas
The cpuidle_devices per-CPU variable is only defined when CPU_IDLE is enabled. Commit c8cc7d4de7a4 ("sched/idle: Reorganize the idle loop") removed the #ifdef CONFIG_CPU_IDLE around cpuidle_idle_call() with the compiler optimising away __this_cpu_read(cpuidle_devices). However, with CONFIG_UBSAN && !CONFIG_CPU_IDLE, this optimisation no longer happens and the kernel fails to link since cpuidle_devices is not defined. This patch introduces an accessor function for the current CPU cpuidle device (returning NULL when !CONFIG_CPU_IDLE) and uses it in cpuidle_idle_call(). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: 4.5+ <stable@vger.kernel.org> # 4.5+ Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-05-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix negative error code usage in ATM layer, from Stefan Hajnoczi. 2) If CONFIG_SYSCTL is disabled, the default TTL is not initialized properly. From Ezequiel Garcia. 3) Missing spinlock init in mvneta driver, from Gregory CLEMENT. 4) Missing unlocks in hwmb error paths, also from Gregory CLEMENT. 5) Fix deadlock on team->lock when propagating features, from Ivan Vecera. 6) Work around buffer offset hw bug in alx chips, from Feng Tang. 7) Fix double listing of SCTP entries in sctp_diag dumps, from Xin Long. 8) Various statistics bug fixes in mlx4 from Eric Dumazet. 9) Fix some randconfig build errors wrt fou ipv6 from Arnd Bergmann. 10) All of l2tp was namespace aware, but the ipv6 support code was not doing so. From Shmulik Ladkani. 11) Handle on-stack hrtimers properly in pktgen, from Guenter Roeck. 12) Propagate MAC changes properly through VLAN devices, from Mike Manning. 13) Fix memory leak in bnx2x_init_one(), from Vitaly Kuznetsov. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (62 commits) sfc: Track RPS flow IDs per channel instead of per function usbnet: smsc95xx: fix link detection for disabled autonegotiation virtio_net: fix virtnet_open and virtnet_probe competing for try_fill_recv bnx2x: avoid leaking memory on bnx2x_init_one() failures fou: fix IPv6 Kconfig options openvswitch: update checksum in {push,pop}_mpls sctp: sctp_diag should dump sctp socket type net: fec: update dirty_tx even if no skb vlan: Propagate MAC address to VLANs atm: iphase: off by one in rx_pkt() atm: firestream: add more reserved strings vxlan: Accept user specified MTU value when create new vxlan link net: pktgen: Call destroy_hrtimer_on_stack() timer: Export destroy_hrtimer_on_stack() net: l2tp: Make l2tp_ip6 namespace aware Documentation: ip-sysctl.txt: clarify secure_redirects sfc: use flow dissector helpers for aRFS ieee802154: fix logic error in ieee802154_llsec_parse_dev_addr net: nps_enet: Disable interrupts before napi reschedule net/lapb: tuse %*ph to dump buffers ...
2016-05-31timer: Export destroy_hrtimer_on_stack()Guenter Roeck
hrtimer_init_on_stack() needs a matching call to destroy_hrtimer_on_stack(), so both need to be exported. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "Followups to the parallel lookup work: - update docs - restore killability of the places that used to take ->i_mutex killably now that we have down_write_killable() merged - Additionally, it turns out that I missed a prerequisite for security_d_instantiate() stuff - ->getxattr() wasn't the only thing that could be called before dentry is attached to inode; with smack we needed the same treatment applied to ->setxattr() as well" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: switch ->setxattr() to passing dentry and inode separately switch xattr_handler->set() to passing dentry and inode separately restore killability of old mutex_lock_killable(&inode->i_mutex) users add down_write_killable_nested() update D/f/directory-locking
2016-05-27remove lots of IS_ERR_VALUE abusesArnd Bergmann
Most users of IS_ERR_VALUE() in the kernel are wrong, as they pass an 'int' into a function that takes an 'unsigned long' argument. This happens to work because the type is sign-extended on 64-bit architectures before it gets converted into an unsigned type. However, anything that passes an 'unsigned short' or 'unsigned int' argument into IS_ERR_VALUE() is guaranteed to be broken, as are 8-bit integers and types that are wider than 'unsigned long'. Andrzej Hajda has already fixed a lot of the worst abusers that were causing actual bugs, but it would be nice to prevent any users that are not passing 'unsigned long' arguments. This patch changes all users of IS_ERR_VALUE() that I could find on 32-bit ARM randconfig builds and x86 allmodconfig. For the moment, this doesn't change the definition of IS_ERR_VALUE() because there are probably still architecture specific users elsewhere. Almost all the warnings I got are for files that are better off using 'if (err)' or 'if (err < 0)'. The only legitimate user I could find that we get a warning for is the (32-bit only) freescale fman driver, so I did not remove the IS_ERR_VALUE() there but changed the type to 'unsigned long'. For 9pfs, I just worked around one user whose calling conventions are so obscure that I did not dare change the behavior. I was using this definition for testing: #define IS_ERR_VALUE(x) ((unsigned long*)NULL == (typeof (x)*)NULL && \ unlikely((unsigned long long)(x) >= (unsigned long long)(typeof(x))-MAX_ERRNO)) which ends up making all 16-bit or wider types work correctly with the most plausible interpretation of what IS_ERR_VALUE() was supposed to return according to its users, but also causes a compile-time warning for any users that do not pass an 'unsigned long' argument. I suggested this approach earlier this year, but back then we ended up deciding to just fix the users that are obviously broken. After the initial warning that caused me to get involved in the discussion (fs/gfs2/dir.c) showed up again in the mainline kernel, Linus asked me to send the whole thing again. [ Updated the 9p parts as per Al Viro - Linus ] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andrzej Hajda <a.hajda@samsung.com> Cc: Andrew Morton <akpm@linux-foundation.org> Link: https://lkml.org/lkml/2016/1/7/363 Link: https://lkml.org/lkml/2016/5/27/486 Acked-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> # For nvmem part Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-26Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - new option CONFIG_TRIM_UNUSED_KSYMS which does a two-pass build and unexports symbols which are not used in the current config [Nicolas Pitre] - several kbuild rule cleanups [Masahiro Yamada] - warning option adjustments for gcov etc [Arnd Bergmann] - a few more small fixes * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (31 commits) kbuild: move -Wunused-const-variable to W=1 warning level kbuild: fix if_change and friends to consider argument order kbuild: fix adjust_autoksyms.sh for modules that need only one symbol kbuild: fix ksym_dep_filter when multiple EXPORT_SYMBOL() on the same line gcov: disable -Wmaybe-uninitialized warning gcov: disable tree-loop-im to reduce stack usage gcov: disable for COMPILE_TEST Kbuild: disable 'maybe-uninitialized' warning for CONFIG_PROFILE_ALL_BRANCHES Kbuild: change CC_OPTIMIZE_FOR_SIZE definition kbuild: forbid kernel directory to contain spaces and colons kbuild: adjust ksym_dep_filter for some cmd_* renames kbuild: Fix dependencies for final vmlinux link kbuild: better abstract vmlinux sequential prerequisites kbuild: fix call to adjust_autoksyms.sh when output directory specified kbuild: Get rid of KBUILD_STR kbuild: rename cmd_as_s_S to cmd_cpp_s_S kbuild: rename cmd_cc_i_c to cmd_cpp_i_c kbuild: drop redundant "PHONY += FORCE" kbuild: delete unnecessary "@:" kbuild: mark help target as PHONY ...
2016-05-26mm: oom_reaper: remove some bloatMichal Hocko
mmput_async is currently used only from the oom_reaper which is defined only for CONFIG_MMU. We can save work_struct in mm_struct for !CONFIG_MMU. [akpm@linux-foundation.org: fix typo, per Minchan] Link: http://lkml.kernel.org/r/20160520061658.GB19172@dhcp22.suse.cz Reported-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-26add down_write_killable_nested()Al Viro
2016-05-25Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Two fixes: one for a lost wakeup, the other to fix the compiler optimizing out preempt operations on ARM64 (and possibly other non-x86 architectures)" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/core: Fix remote wakeups sched/preempt: Fix preempt_count manipulations
2016-05-25Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Mostly tooling and PMU driver fixes, but also a number of late updates such as the reworking of the call-chain size limiting logic to make call-graph recording more robust, plus tooling side changes for the new 'backwards ring-buffer' extension to the perf ring-buffer" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (34 commits) perf record: Read from backward ring buffer perf record: Rename variable to make code clear perf record: Prevent reading invalid data in record__mmap_read perf evlist: Add API to pause/resume perf trace: Use the ptr->name beautifier as default for "filename" args perf trace: Use the fd->name beautifier as default for "fd" args perf report: Add srcline_from/to branch sort keys perf evsel: Record fd into perf_mmap perf evsel: Add overwrite attribute and check write_backward perf tools: Set buildid dir under symfs when --symfs is provided perf trace: Only auto set call-graph to "dwarf" when syscalls are being traced perf annotate: Sort list of recognised instructions perf annotate: Fix identification of ARM blt and bls instructions perf tools: Fix usage of max_stack sysctl perf callchain: Stop validating callchains by the max_stack sysctl perf trace: Fix exit_group() formatting perf top: Use machine->kptr_restrict_warned perf trace: Warn when trying to resolve kernel addresses with kptr_restrict=1 perf machine: Do not bail out if not managing to read ref reloc symbol perf/x86/intel/p4: Trival indentation fix, remove space ...
2016-05-25Merge tag 'pm-4.7-rc1-more' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more power management updates from Rafael Wysocki: "These are two stable-candidate fixes (PM core, cpuidle) and a bunch of cpufreq cleanups. Specifics: - Stable-candidate cpuidle fix to make it check the right variable when deciding whether or not to enable interrupts on the local CPU so as to avoid enabling iterrupts too early in some cases if the system has both coupled and per-core idle states (Daniel Lezcano). - Stable-candidate PM core fix to make it handle failures at the "late suspend" stage of device suspend consistently for all devices regardless of whether or not async suspend/resume is enabled for them (Rafael Wysocki). - Cleanups in the cpufreq core, the schedutil governor and the intel_pstate driver (Rafael Wysocki, Pankaj Gupta, Viresh Kumar)" * tag 'pm-4.7-rc1-more' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM / sleep: Handle failures in device_suspend_late() consistently cpufreq: schedutil: Improve prints messages with pr_fmt cpuidle: Fix cpuidle_state_is_coupled() argument in cpuidle_enter() cpufreq: simplified goto out in cpufreq_register_driver() cpufreq: governor: CPUFREQ_GOV_STOP never fails cpufreq: governor: CPUFREQ_GOV_POLICY_EXIT never fails intel_pstate: Simplify conditional in intel_pstate_set_policy()
2016-05-25Merge branches 'pm-cpufreq', 'pm-cpuidle' and 'pm-core'Rafael J. Wysocki
* pm-cpufreq: cpufreq: schedutil: Improve prints messages with pr_fmt cpufreq: simplified goto out in cpufreq_register_driver() cpufreq: governor: CPUFREQ_GOV_STOP never fails cpufreq: governor: CPUFREQ_GOV_POLICY_EXIT never fails intel_pstate: Simplify conditional in intel_pstate_set_policy() * pm-cpuidle: cpuidle: Fix cpuidle_state_is_coupled() argument in cpuidle_enter() * pm-core: PM / sleep: Handle failures in device_suspend_late() consistently
2016-05-25sched/core: Fix remote wakeupsPeter Zijlstra
Commit: b5179ac70de8 ("sched/fair: Prepare to fix fairness problems on migration") ... introduced a bug: Mike Galbraith found that it introduced a performance regression, while Paul E. McKenney reported lost wakeups and bisected it to this commit. The reason is that I mis-read ttwu_queue() such that I assumed any wakeup that got a remote queue must have had the task migrated. Since this is not so; we need to transfer this information between queueing the wakeup and actually doing the wakeup. Use a new task_struct::sched_flag for this, we already write to sched_contributes_to_load in the wakeup path so this is a hot and modified cacheline. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reported-by: Mike Galbraith <umgwanakikbuti@gmail.com> Tested-by: Mike Galbraith <umgwanakikbuti@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Hunter <ahh@google.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Ben Segall <bsegall@google.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Morten Rasmussen <morten.rasmussen@arm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Paul Turner <pjt@google.com> Cc: Pavan Kondeti <pkondeti@codeaurora.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: byungchul.park@lge.com Fixes: b5179ac70de8 ("sched/fair: Prepare to fix fairness problems on migration") Link: http://lkml.kernel.org/r/20160523091907.GD15728@worktop.ger.corp.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-05-24Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates from Ted Ts'o: "Fix a number of bugs, most notably a potential stale data exposure after a crash and a potential BUG_ON crash if a file has the data journalling flag enabled while it has dirty delayed allocation blocks that haven't been written yet. Also fix a potential crash in the new project quota code and a maliciously corrupted file system. In addition, fix some DAX-specific bugs, including when there is a transient ENOSPC situation and races between writes via direct I/O and an mmap'ed segment that could lead to lost I/O. Finally the usual set of miscellaneous cleanups" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (23 commits) ext4: pre-zero allocated blocks for DAX IO ext4: refactor direct IO code ext4: fix race in transient ENOSPC detection ext4: handle transient ENOSPC properly for DAX dax: call get_blocks() with create == 1 for write faults to unwritten extents ext4: remove unmeetable inconsisteny check from ext4_find_extent() jbd2: remove excess descriptions for handle_s ext4: remove unnecessary bio get/put ext4: silence UBSAN in ext4_mb_init() ext4: address UBSAN warning in mb_find_order_for_block() ext4: fix oops on corrupted filesystem ext4: fix check of dqget() return value in ext4_ioctl_setproject() ext4: clean up error handling when orphan list is corrupted ext4: fix hang when processing corrupted orphaned inode list ext4: remove trailing \n from ext4_warning/ext4_error calls ext4: fix races between changing inode journal mode and ext4_writepages ext4: handle unwritten or delalloc buffers before enabling data journaling ext4: fix jbd2 handle extension in ext4_ext_truncate_extend_restart() ext4: do not ask jbd2 to write data for delalloc buffers jbd2: add support for avoiding data writes during transaction commits ...
2016-05-24genirq: Fix missing return value in irq_destroy_ipi()Matt Redfearn
Commit 7cec18a3906b changed the return type of irq_destroy_ipi to int, but missed adding a value to one return statement. Fix this to silence the resulting compiler warning: kernel/irq/ipi.c In function ‘irq_destroy_ipi’: kernel/irq/ipi.c:128:3: warning: ‘return’ with no value, in function returning non-void [-Wreturn-type] Fixes: 7cec18a3906b "genirq: Add error code reporting to irq_{reserve,destroy}_ipi" Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Cc: linux-mips@linux-mips.org Link: http://lkml.kernel.org/r/1464086550-24734-1-git-send-email-matt.redfearn@imgtec.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-05-23uprobes: wait for mmap_sem for write killableMichal Hocko
xol_add_vma needs mmap_sem for write. If the waiting task gets killed by the oom killer it would block oom_reaper from asynchronous address space reclaim and reduce the chances of timely OOM resolving. Wait for the lock in the killable mode and return with EINTR if the task got killed while waiting. Do not warn in dup_xol_work if __create_xol_area failed due to fatal signal pending because this is usually considered a kernel issue. Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23prctl: make PR_SET_THP_DISABLE wait for mmap_sem killableMichal Hocko
PR_SET_THP_DISABLE requires mmap_sem for write. If the waiting task gets killed by the oom killer it would block oom_reaper from asynchronous address space reclaim and reduce the chances of timely OOM resolving. Wait for the lock in the killable mode and return with EINTR if the task got killed while waiting. Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23mm, fork: make dup_mmap wait for mmap_sem for write killableMichal Hocko
dup_mmap needs to lock current's mm mmap_sem for write. If the waiting task gets killed by the oom killer it would block oom_reaper from asynchronous address space reclaim and reduce the chances of timely OOM resolving. Wait for the lock in the killable mode and return with EINTR if the task got killed while waiting. Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23s390/kexec: consolidate crash_map/unmap_reserved_pages() and ↵Xunlei Pang
arch_kexec_protect(unprotect)_crashkres() Commit 3f625002581b ("kexec: introduce a protection mechanism for the crashkernel reserved memory") is a similar mechanism for protecting the crash kernel reserved memory to previous crash_map/unmap_reserved_pages() implementation, the new one is more generic in name and cleaner in code (besides, some arch may not be allowed to unmap the pgtable). Therefore, this patch consolidates them, and uses the new arch_kexec_protect(unprotect)_crashkres() to replace former crash_map/unmap_reserved_pages() which by now has been only used by S390. The consolidation work needs the crash memory to be mapped initially, this is done in machine_kdump_pm_init() which is after reserve_crashkernel(). Once kdump kernel is loaded, the new arch_kexec_protect_crashkres() implemented for S390 will actually unmap the pgtable like before. Signed-off-by: Xunlei Pang <xlpang@redhat.com> Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Acked-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Minfei Huang <mhuang@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Dave Young <dyoung@redhat.com> Cc: Baoquan He <bhe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23kexec: do a cleanup for function kexec_loadMinfei Huang
There are a lof of work to be done in function kexec_load, not only for allocating structs and loading initram, but also for some misc. To make it more clear, wrap a new function do_kexec_load which is used to allocate structs and load initram. And the pre-work will be done in kexec_load. Signed-off-by: Minfei Huang <mnfhuang@gmail.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Xunlei Pang <xlpang@redhat.com> Cc: Baoquan He <bhe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23kexec: make a pair of map/unmap reserved pages in error pathMinfei Huang
For some arch, kexec shall map the reserved pages, then use them, when we try to start the kdump service. kexec may return directly, without unmaping the reserved pages, if it fails during starting service. To fix it, we make a pair of map/unmap reserved pages both in generic path and error path. This patch only affects s390. Other architecturess don't implement the interface of crash_unmap_reserved_pages and crash_map_reserved_pages. It isn't a urgent patch. Kernel can work well without any risk, although the reserved pages are not unmapped before returning in error path. Signed-off-by: Minfei Huang <mnfhuang@gmail.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Xunlei Pang <xlpang@redhat.com> Cc: Baoquan He <bhe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23kexec: introduce a protection mechanism for the crashkernel reserved memoryXunlei Pang
For the cases that some kernel (module) path stamps the crash reserved memory(already mapped by the kernel) where has been loaded the second kernel data, the kdump kernel will probably fail to boot when panic happens (or even not happens) leaving the culprit at large, this is unacceptable. The patch introduces a mechanism for detecting such cases: 1) After each crash kexec loading, it simply marks the reserved memory regions readonly since we no longer access it after that. When someone stamps the region, the first kernel will panic and trigger the kdump. The weak arch_kexec_protect_crashkres() is introduced to do the actual protection. 2) To allow multiple loading, once 1) was done we also need to remark the reserved memory to readwrite each time a system call related to kdump is made. The weak arch_kexec_unprotect_crashkres() is introduced to do the actual protection. The architecture can make its specific implementation by overriding arch_kexec_protect_crashkres() and arch_kexec_unprotect_crashkres(). Signed-off-by: Xunlei Pang <xlpang@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Dave Young <dyoung@redhat.com> Cc: Minfei Huang <mhuang@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Baoquan He <bhe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23kernek/fork.c: allocate idle task for a CPU always on its local nodeAndi Kleen
Linux preallocates the task structs of the idle tasks for all possible CPUs. This currently means they all end up on node 0. This also implies that the cache line of MWAIT, which is around the flags field in the task struct, are all located in node 0. We see a noticeable performance improvement on Knights Landing CPUs when the cache lines used for MWAIT are located in the local nodes of the CPUs using them. I would expect this to give a (likely slight) improvement on other systems too. The patch implements placing the idle task in the node of its CPUs, by passing the right target node to copy_process() [akpm@linux-foundation.org: use NUMA_NO_NODE, not a bare -1] Link: http://lkml.kernel.org/r/1463492694-15833-1-git-send-email-andi@firstfloor.org Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23kernel/signal.c: convert printk(KERN_<LEVEL> ...) to pr_<level>(...)Wang Xiaoqiang
Use pr_<level> instead of printk(KERN_<LEVEL> ). Signed-off-by: Wang Xiaoqiang <wangxq10@lzu.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23wait: allow sys_waitid() to accept __WNOTHREAD/__WCLONE/__WALLOleg Nesterov
I see no reason why waitid() can't support other linux-specific flags allowed in sys_wait4(). In particular this change can help if we reconsider the previous change ("wait/ptrace: assume __WALL if the child is traced") which adds the "automagical" __WALL for debugger. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Jan Kratochvil <jan.kratochvil@redhat.com> Cc: "Michael Kerrisk (man-pages)" <mtk.manpages@gmail.com> Cc: Pedro Alves <palves@redhat.com> Cc: Roland McGrath <roland@hack.frob.com> Cc: <syzkaller@googlegroups.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23wait/ptrace: assume __WALL if the child is tracedOleg Nesterov
The following program (simplified version of generated by syzkaller) #include <pthread.h> #include <unistd.h> #include <sys/ptrace.h> #include <stdio.h> #include <signal.h> void *thread_func(void *arg) { ptrace(PTRACE_TRACEME, 0,0,0); return 0; } int main(void) { pthread_t thread; if (fork()) return 0; while (getppid() != 1) ; pthread_create(&thread, NULL, thread_func, NULL); pthread_join(thread, NULL); return 0; } creates an unreapable zombie if /sbin/init doesn't use __WALL. This is not a kernel bug, at least in a sense that everything works as expected: debugger should reap a traced sub-thread before it can reap the leader, but without __WALL/__WCLONE do_wait() ignores sub-threads. Unfortunately, it seems that /sbin/init in most (all?) distributions doesn't use it and we have to change the kernel to avoid the problem. Note also that most init's use sys_waitid() which doesn't allow __WALL, so the necessary user-space fix is not that trivial. This patch just adds the "ptrace" check into eligible_child(). To some degree this matches the "tsk->ptrace" in exit_notify(), ->exit_signal is mostly ignored when the tracee reports to debugger. Or WSTOPPED, the tracer doesn't need to set this flag to wait for the stopped tracee. This obviously means the user-visible change: __WCLONE and __WALL no longer have any meaning for debugger. And I can only hope that this won't break something, but at least strace/gdb won't suffer. We could make a more conservative change. Say, we can take __WCLONE into account, or !thread_group_leader(). But it would be nice to not complicate these historical/confusing checks. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Jan Kratochvil <jan.kratochvil@redhat.com> Cc: "Michael Kerrisk (man-pages)" <mtk.manpages@gmail.com> Cc: Pedro Alves <palves@redhat.com> Cc: Roland McGrath <roland@hack.frob.com> Cc: <syzkaller@googlegroups.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23ELF/MIPS build fixRalf Baechle
CONFIG_MIPS32_N32=y but CONFIG_BINFMT_ELF disabled results in the following linker errors: arch/mips/built-in.o: In function `elf_core_dump': binfmt_elfn32.c:(.text+0x23dbc): undefined reference to `elf_core_extra_phdrs' binfmt_elfn32.c:(.text+0x246e4): undefined reference to `elf_core_extra_data_size' binfmt_elfn32.c:(.text+0x248d0): undefined reference to `elf_core_write_extra_phdrs' binfmt_elfn32.c:(.text+0x24ac4): undefined reference to `elf_core_write_extra_data' CONFIG_MIPS32_O32=y but CONFIG_BINFMT_ELF disabled results in the following linker errors: arch/mips/built-in.o: In function `elf_core_dump': binfmt_elfo32.c:(.text+0x28a04): undefined reference to `elf_core_extra_phdrs' binfmt_elfo32.c:(.text+0x29330): undefined reference to `elf_core_extra_data_size' binfmt_elfo32.c:(.text+0x2951c): undefined reference to `elf_core_write_extra_phdrs' binfmt_elfo32.c:(.text+0x29710): undefined reference to `elf_core_write_extra_data' This is because binfmt_elfn32 and binfmt_elfo32 are using symbols from elfcore but for these configurations elfcore will not be built. Fixed by making elfcore selectable by a separate config symbol which unlike the current mechanism can also be used from other directories than kernel/, then having each flavor of ELF that relies on elfcore.o, select it in Kconfig, including CONFIG_MIPS32_N32 and CONFIG_MIPS32_O32 which fixes this issue. Link: http://lkml.kernel.org/r/20160520141705.GA1913@linux-mips.org Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23bpf, inode: disallow userns mountsDaniel Borkmann
Follow-up to commit e27f4a942a0e ("bpf: Use mount_nodev not mount_ns to mount the bpf filesystem"), which removes the FS_USERNS_MOUNT flag. The original idea was to have a per mountns instance instead of a single global fs instance, but that didn't work out and we had to switch to mount_nodev() model. The intent of that middle ground was that we avoid users who don't play nice to create endless instances of bpf fs which are difficult to control and discover from an admin point of view, but at the same time it would have allowed us to be more flexible with regard to namespaces. Therefore, since we now did the switch to mount_nodev() as a fix where individual instances are created, we also need to remove userns mount flag along with it to avoid running into mentioned situation. I don't expect any breakage at this early point in time with removing the flag and we can revisit this later should the requirement for this come up with future users. This and commit e27f4a942a0e have been split to facilitate tracking should any of them run into the unlikely case of causing a regression. Fixes: b2197755b263 ("bpf: add support for persistent maps/progs") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-22Merge tag 'trace-v4.7-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull motr tracing updates from Steven Rostedt: "Three more changes. - I forgot that I had another selftest to stress test the ftrace instance creation. It was actually suppose to go into the 4.6 merge window, but I never committed it. I almost forgot about it again, but noticed it was missing from your tree. - Soumya PN sent me a clean up patch to not disable interrupts when taking the tasklist_lock for read, as it's unnecessary because that lock is never taken for write in irq context. - Newer gcc's can cause the jump in the function_graph code to the global ftrace_stub label to be a short jump instead of a long one. As that jump is dynamically converted to jump to the trace code to do function graph tracing, and that conversion expects a long jump it can corrupt the ftrace_stub itself (it's directly after that call). One way to prevent gcc from using a short jump is to declare the ftrace_stub as a weak function, which we do here to keep gcc from optimizing too much" * tag 'trace-v4.7-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ftrace/x86: Set ftrace_stub to weak to prevent gcc from using short jumps to it ftrace: Don't disable irqs when taking the tasklist_lock read_lock ftracetest: Add instance created, delete, read and enable event test
2016-05-22x86: remove more uaccess_32.h complexityLinus Torvalds
I'm looking at trying to possibly merge the 32-bit and 64-bit versions of the x86 uaccess.h implementation, but first this needs to be cleaned up. For example, the 32-bit version of "__copy_from_user_inatomic()" is mostly the special cases for the constant size, and it's actually almost never relevant. Most users aren't actually using a constant size anyway, and the few cases that do small constant copies are better off just using __get_user() instead. So get rid of the unnecessary complexity. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge more updates from Andrew Morton: - the rest of MM - KASAN updates - procfs updates - exit, fork updates - printk updates - lib/ updates - radix-tree testsuite updates - checkpatch updates - kprobes updates - a few other misc bits * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (162 commits) samples/kprobes: print out the symbol name for the hooks samples/kprobes: add a new module parameter kprobes: add the "tls" argument for j_do_fork init/main.c: simplify initcall_blacklisted() fs/efs/super.c: fix return value checkpatch: improve --git <commit-count> shortcut checkpatch: reduce number of `git log` calls with --git checkpatch: add support to check already applied git commits checkpatch: add --list-types to show message types to show or ignore checkpatch: advertise the --fix and --fix-inplace options more checkpatch: whine about ACCESS_ONCE checkpatch: add test for keywords not starting on tabstops checkpatch: improve CONSTANT_COMPARISON test for structure members checkpatch: add PREFER_IS_ENABLED test lib/GCD.c: use binary GCD algorithm instead of Euclidean radix-tree: free up the bottom bit of exceptional entries for reuse dax: move RADIX_DAX_ definitions to dax.c radix-tree: make radix_tree_descend() more useful radix-tree: introduce radix_tree_replace_clear_tags() radix-tree: tidy up __radix_tree_create() ...
