Impact: change /proc/sched/debug from rw-r--r-- to r--r--r--
/proc/sched_debug is read-only.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (31 commits)
ftrace: fix current_tracer error return
tracing: fix a build error on alpha
ftrace: use a real variable for ftrace_nop in x86
tracing/ftrace: make boot tracer select the sched_switch tracer
tracepoint: check if the probe has been registered
asm-generic: define DIE_OOPS in asm-generic
trace: fix printk warning for u64
ftrace: warning in kernel/trace/ftrace.c
ftrace: fix build failure
ftrace, powerpc, sparc64, x86: remove notrace from arch ftrace file
ftrace: remove ftrace hash
ftrace: remove mcount set
ftrace: remove daemon
ftrace: disable dynamic ftrace for all archs that use daemon
ftrace: add ftrace warn on to disable ftrace
ftrace: only have ftrace_kill atomic
ftrace: use probe_kernel
ftrace: comment arch ftrace code
ftrace: return error on failed modified text.
ftrace: dynamic ftrace process only text section
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
lockdep: fix irqs on/off ip tracing
lockdep: minor fix for debug_show_all_locks()
x86: restore the old swiotlb alloc_coherent behavior
x86: use GFP_DMA for 24bit coherent_dma_mask
swiotlb: remove panic for alloc_coherent failure
xen: compilation fix of drivers/xen/events.c on IA64
xen: portability clean up and some minor clean up for xencomm.c
xen: don't reload cr3 on suspend
kernel/resource: fix reserve_region_with_split() section mismatch
printk: remove unused code from kernel/printk.c
* 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
irq: make variable static
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: fix documentation reference for sched_min_granularity_ns
sched: virtual time buddy preemption
sched: re-instate vruntime based wakeup preemption
sched: weaken sync hint
sched: more accurate min_vruntime accounting
sched: fix a find_busiest_group buglet
sched: add CONFIG_SMP consistency
The commit (in linux-tip) c2931e05ec5965597cbfb79ad332d4a29aeceb23
( ftrace: return an error when setting a nonexistent tracer )
added useful code that would error when a bad tracer was written into
the current_tracer file.
But this had a bug if the amount written was more than the amount read by
that code. The first iteration would set the tracer correctly, but since
it did not consume the rest of what was written (usually whitespace), the
userspace utility would continue to write what was not consumed. This
second iteration would fail to find a tracer and return -EINVAL. Funny
thing is that the tracer would have already been set.
This patch just consumes all the data that is written to the file.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Impact: fix lockdep lock-api-caller output when irqsoff tracing is enabled
81d68a96 "ftrace: trace irq disabled critical timings" added wrappers around
trace_hardirqs_on/off_caller. However these functions use
__builtin_return_address(0) to figure out which function actually disabled
or enabled irqs. The result is that we save the ips of trace_hardirqs_on/off
instead of the real caller. Not very helpful.
However since the patch from Steven the ip already gets passed. So use that
and get rid of __builtin_return_address(0) in these two functions.
When we failed to get tasklist_lock eventually (count equals 0),
we should only print " ignoring it.\n", and not print
" locked it.\n" needlessly.
Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
Impact: build fix on Alpha
When tracing is enabled, some arch have included <linux/irqflags.h>
on their <asm/system.h> but others like alpha or m68k don't.
Build error on alpha:
kernel/trace/trace.c: In function 'tracing_cpumask_write':
kernel/trace/trace.c:2145: error: implicit declaration of function 'raw_local_irq_disable'
kernel/trace/trace.c:2162: error: implicit declaration of function 'raw_local_irq_enable'
Tested on Alpha through a cross-compiler (should correct a similar issue on m68k).
Reported-by: Alexey Dobriyan <adobriyan@gmail.com>
Impact: build fix
If the boot tracer is selected but not the sched_switch,
there will be a build failure:
kernel/built-in.o: In function `boot_trace_init':
trace_boot.c:(.text+0x5ee38): undefined reference to `sched_switch_trace'
kernel/built-in.o: In function `disable_boot_trace':
(.text+0x5eee1): undefined reference to `tracing_stop_cmdline_record'
kernel/built-in.o: In function `enable_boot_trace':
(.text+0x5ef11): undefined reference to `tracing_start_cmdline_record'
This patch fixes it.
Impact: fix kernel crash that can trigger during tracing
If we try to remove a probe that has not been already registered,
the tracepoint_entry_remove_probe() function will dereference a NULL
pointer.
Check the probe before removing it to avoid crashes.
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Acked-by: Steven Rostedt <srostedt@redhat.com>
A powerpc ppc64_defconfig build produces these warnings:
kernel/trace/ring_buffer.c: In function 'rb_add_time_stamp':
kernel/trace/ring_buffer.c:969: warning: format '%llu' expects type 'long long unsigned int', but argument 2 has type 'u64'
kernel/trace/ring_buffer.c:969: warning: format '%llu' expects type 'long long unsigned int', but argument 3 has type 'u64'
kernel/trace/ring_buffer.c:969: warning: format '%llu' expects type 'long long unsigned int', but argument 4 has type 'u64'
Just cast the u64s to unsigned long long like we do everywhere else.
/scratch/sfr/next/kernel/cgroup.c: In function 'cgroup_tasks_start':
/scratch/sfr/next/kernel/cgroup.c:2107: warning: unused variable 'i'
Introduced in commit cc31edceee04a7b87f2be48f9489ebb72d264844 "cgroups:
convert tasks file to use a seq_file with shared pid array".
This reverts commit a802dd0eb5fc97a50cf1abb1f788a8f6cc5db635 by moving
the call to init_workqueues() back where it belongs - after SMP has been
initialized.
It also moves stop_machine_init() - which needs workqueues - to a later
phase using a core_initcall() instead of early_initcall(). That should
satisfy all ordering requirements, and was apparently the reason why
init_workqueues() was moved to be too early.
this warning:
kernel/trace/ftrace.c:189: warning: ‘frozen_record_count’ defined but not used
triggers because frozen_record_count is only used in the KCONFIG_MARKERS
case. Move the variable it there.
Alas, this frozen-record facility seems to have little use. The
frozen_record_count variable is not used by anything, nor the flags.
So this section might need a bit of dead-code-removal care as well.
Since we moved wakeup preemption back to virtual time, it makes sense to move
the buddy stuff back as well. The purpose of the buddy scheduling is to allow
a quickly scheduling pair of tasks to run away from the group as far as a
regular busy task would be allowed under wakeup preemption.
This has the advantage that the pair can ping-pong for a while, enjoying
cache-hotness. Without buddy scheduling other tasks would interleave destroying
the cache.
Also, it saves a word in cfs_rq.
Acked-by: Mike Galbraith <efault@gmx.de>
The advantage is that vruntime based wakeup preemption has a better
conceptual model. Here wakeup_gran = 0 means: preempt when 'fair'.
Therefore wakeup_gran is the granularity of unfairness we allow in order
to make progress.
Mysql+oltp and pgsql+oltp peaks are still shifted right. The below puts
the peaks back to 1 client/server pair per core.
Use the avg_overlap information to weaken the sync hint.
Signed-off-by: Mike Galbraith <efault@gmx.de>
Mike noticed the current min_vruntime tracking can go wrong and skip the
current task. If the only remaining task in the tree is a nice 19 task
with huge vruntime, new tasks will be inserted too far to the right too,
causing some interactibity issues.
min_vruntime can only change due to the leftmost entry disappearing
(dequeue_entity()), or by the leftmost entry being incremented past the
next entry, which elects a new leftmost (__update_curr())
Due to the current entry not being part of the actual tree, we have to
compare the leftmost tree entry with the current entry, and take the
leftmost of these two.
So create a update_min_vruntime() function that takes computes the
leftmost vruntime in the system (either tree of current) and increases
the cfs_rq->min_vruntime if the computed value is larger than the
previously found min_vruntime. And call this from the two sites we've
identified that can change min_vruntime.
Reported-by: Mike Galbraith <efault@gmx.de>
In one of the group load balancer patches:
commit 408ed066b11cf9ee4536573b4269ee3613bd735e
Author: Peter Zijlstra <a.p.zijlstra@chello.nl>
Date: Fri Jun 27 13:41:28 2008 +0200
Subject: sched: hierarchical load vs find_busiest_group
The following change:
- if (max_load - this_load + SCHED_LOAD_SCALE_FUZZ >=
+ if (max_load - this_load + 2*busiest_load_per_task >=
busiest_load_per_task * imbn) {
made the condition always true, because imbn is [1,2].
Therefore, remove the 2*, and give the it a fair chance.
Impact: cleanup, small kernel text size reduction, no functionality changed
reserve_region_with_split() calls in to __reserve_region_with_split(),
which is an __init function. The only caller of reserve_region_with_split()
is an __init function, so make it __init too.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
both log_buf_copy() and log_buf_len are unused.
Move free_module_param_attrs() into the CONFIG_MODULES section, since
it's only used inside there. Thus avoiding the warning
kernel/params.c:514: warning: 'free_module_param_attrs' defined but not used
git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc
* 'proc' of git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc: (35 commits)
proc: remove fs/proc/proc_misc.c
proc: move /proc/vmcore creation to fs/proc/vmcore.c
proc: move pagecount stuff to fs/proc/page.c
proc: move all /proc/kcore stuff to fs/proc/kcore.c
proc: move /proc/schedstat boilerplate to kernel/sched_stats.h
proc: move /proc/modules boilerplate to kernel/module.c
proc: move /proc/diskstats boilerplate to block/genhd.c
proc: move /proc/zoneinfo boilerplate to mm/vmstat.c
proc: move /proc/vmstat boilerplate to mm/vmstat.c
proc: move /proc/pagetypeinfo boilerplate to mm/vmstat.c
proc: move /proc/buddyinfo boilerplate to mm/vmstat.c
proc: move /proc/vmallocinfo to mm/vmalloc.c
proc: move /proc/slabinfo boilerplate to mm/slub.c, mm/slab.c
proc: move /proc/slab_allocators boilerplate to mm/slab.c
proc: move /proc/interrupts boilerplate code to fs/proc/interrupts.c
proc: move /proc/stat to fs/proc/stat.c
proc: move rest of /proc/partitions code to block/genhd.c
proc: move /proc/cpuinfo code to fs/proc/cpuinfo.c
proc: move /proc/devices code to fs/proc/devices.c
proc: move rest of /proc/locks to fs/locks.c
* 'v28-range-hrtimers-for-linus-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (37 commits)
hrtimers: add missing docbook comments to struct hrtimer
hrtimers: simplify hrtimer_peek_ahead_timers()
hrtimers: fix docbook comments
DECLARE_PER_CPU needs linux/percpu.h
hrtimers: fix typo
rangetimers: fix the bug reported by Ingo for real
rangetimer: fix BUG_ON reported by Ingo
rangetimer: fix x86 build failure for the !HRTIMERS case
select: fix alpha OSF wrapper
hrtimer: peek at the timer queue just before going idle
hrtimer: make the futex() system call use the per process slack value
hrtimer: make the nanosleep() syscall use the per process slack
hrtimer: fix signed/unsigned bug in slack estimator
hrtimer: show the timer ranges in /proc/timer_list
hrtimer: incorporate feedback from Peter Zijlstra
hrtimer: add a hrtimer_start_range() function
hrtimer: another build fix
hrtimer: fix build bug found by Ingo
hrtimer: make select() and poll() use the hrtimer range feature
* git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev: (66 commits)
[PATCH] kill the rest of struct file propagation in block ioctls
[PATCH] get rid of struct file use in blkdev_ioctl() BLKBSZSET
[PATCH] get rid of blkdev_locked_ioctl()
[PATCH] get rid of blkdev_driver_ioctl()
[PATCH] sanitize blkdev_get() and friends
[PATCH] remember mode of reiserfs journal
[PATCH] propagate mode through swsusp_close()
[PATCH] propagate mode through open_bdev_excl/close_bdev_excl
[PATCH] pass fmode_t to blkdev_put()
[PATCH] kill the unused bsize on the send side of /dev/loop
[PATCH] trim file propagation in block/compat_ioctl.c
[PATCH] end of methods switch: remove the old ones
[PATCH] switch sr
[PATCH] switch sd
[PATCH] switch ide-scsi
[PATCH] switch tape_block
[PATCH] switch dcssblk
[PATCH] switch dasd
[PATCH] switch mtd_blkdevs
[PATCH] switch mmc
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (46 commits)
[PATCH] fs: add a sanity check in d_free
[PATCH] i_version: remount support
[patch] vfs: make security_inode_setattr() calling consistent
[patch 1/3] FS_MBCACHE: don't needlessly make it built-in
[PATCH] move executable checking into ->permission()
[PATCH] fs/dcache.c: update comment of d_validate()
[RFC PATCH] touch_mnt_namespace when the mount flags change
[PATCH] reiserfs: add missing llseek method
[PATCH] fix ->llseek for more directories
[PATCH vfs-2.6 6/6] vfs: add LOOKUP_RENAME_TARGET intent
[PATCH vfs-2.6 5/6] vfs: remove LOOKUP_PARENT from non LOOKUP_PARENT lookup
[PATCH vfs-2.6 4/6] vfs: remove unnecessary fsnotify_d_instantiate()
[PATCH vfs-2.6 3/6] vfs: add __d_instantiate() helper
[PATCH vfs-2.6 2/6] vfs: add d_ancestor()
[PATCH vfs-2.6 1/6] vfs: replace parent == dentry->d_parent by IS_ROOT()
[PATCH] get rid of on-stack dentry in udf
[PATCH 2/2] anondev: switch to IDA
[PATCH 1/2] anondev: init IDR statically
[JFFS2] Use d_splice_alias() not d_add() in jffs2_lookup()
[PATCH] Optimise NFS readdir hack slightly.
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
stop_machine: fix error code handling on multiple cpus
stop_machine: use workqueues instead of kernel threads
workqueue: introduce create_rt_workqueue
Call init_workqueues before pre smp initcalls.
Make panic= and panic_on_oops into core_params
Make initcall_debug a core_param
core_param() for genuinely core kernel parameters
param: Fix duplicate module prefixes
module: check kernel param length at compile time, not runtime
Remove stop_machine during module load v2
module: simplify load_module.
* 'v28-timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
NOHZ: fix thinko in the timer restart code path
rcupdate: fix bug of rcu_barrier*()
profiling: fix !procfs build
Fixed trivial conflicts in 'include/linux/profile.h'
sched: disable the hrtick for now
sched: revert back to per-rq vruntime
sched: fair scheduler should not resched rt tasks
sched: optimize group load balancer
sched: minor fast-path overhead reduction
sched: fix the wrong mask_len, cleanup
sched: kill unused scheduler decl.
sched: only update rq->clock while holding rq->lock
genirq: NULL struct irq_desc's member 'name' in dynamic_irq_cleanup()
genirq: fix off by one and coding style
genirq: fix set_irq_type() when recording trigger type
fix:
kernel/trace/ftrace.c: In function 'ftrace_release':
kernel/trace/ftrace.c:271: error: implicit declaration of function 'ftrace_release_hash'
release_hash is not needed without dftraced.
The ftrace hash was used by the ftrace_daemon code. The record ip function
would place the calling address (ip) into the hash. The daemon would later
read the hash and modify that code.
The hash complicates the code. This patch removes it.
The arch dependent function ftrace_mcount_set was only used by the daemon
start up code. This patch removes it.
The ftrace daemon is complex and error prone. This patch strips it out
of the code.
Add ftrace warn on to disable ftrace as well as report a warning.
[ Thanks to Andrew Morton for suggesting using the WARN_ON return value ]
When an anomaly is detected, we need a way to completely disable
ftrace. Right now we have two functions: ftrace_kill and ftrace_kill_atomic.
The ftrace_kill tries to do it in a "nice" way by converting everything
back to a nop.
The "nice" way is dangerous itself, so this patch removes it and only
has the "atomic" version, which is all that is needed.
Have the ftrace_modify_code return error values:
-EFAULT on error of reading the address
-EINVAL if what is read does not match what it expected
-EPERM if the write fails to update after a successful match.
The pages of a buffer was originally pointing to the page struct, it
now points to the page address. The freeing of the page still uses
the page frame free "__free_page" instead of the correct free_page to
the address.
a patch from Henrik Austad did this:
>> Do not declare select_task_rq as part of sched_class when CONFIG_SMP is
>> not set.
Peter observed:
> While a proper cleanup, could you do it by re-arranging the methods so
> as to not create an additional ifdef?
Do not declare select_task_rq and some other methods as part of sched_class
when CONFIG_SMP is not set.
Also gather those methods to avoid CONFIG_SMP mess.
Idea-by: Henrik Austad <henrik.austad@gmail.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Henrik Austad <henrik@austad.us>
kernel/time/tick-sched.c
We seem to have plenty tracers, lets create a menu and not clutter
the already cluttered debug menu more.
Acked-by: Frédéric Weisbecker <fweisbec@gmail.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
