commit 95c2b17534654829db428f11bcf4297c059a2a7e upstream.
Per-IRQ directories in procfs are created only when a handler is first
added to the irqdesc, not when the irqdesc is created. In the case of
a shared IRQ, multiple tasks can race to create a directory. This
race condition seems to have been present forever, but is easier to
hit with async probing.
Link: http://lkml.kernel.org/r/1443266636.2004.2.camel@decadent.org.uk
commit 54d27365cae88fbcc853b391dcd561e71acb81fa upstream.
The optimized task selection logic optimistically selects a new task
to run without first doing a full put_prev_task(). This is so that we
can avoid a put/set on the common ancestors of the old and new task.
Similarly, we should only call check_cfs_rq_runtime() to throttle
eligible groups if they're part of the common ancestry, otherwise it
is possible to end up with no eligible task in the simple task
selection.
Imagine:
/root
/prev /next
/A /B
If our optimistic selection ends up throttling /next, we goto simple
and our put_prev_task() ends up throttling /prev, after which we're
going to bug out in set_next_entity() because there aren't any tasks
left.
Avoid this scenario by only throttling common ancestors.
Reported-by: Mohammed Naser <mnaser@vexxhost.com>
Reported-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Signed-off-by: Ben Segall <bsegall@google.com>
[ munged Changelog ]
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: pjt@google.com
Fixes: 678d5718d8d0 ("sched/fair: Optimize cgroup pick_next_task_fair()")
Link: http://lkml.kernel.org/r/xm26wq1oswoq.fsf@sword-of-the-dawn.mtv.corp.google.com
commit 95913d97914f44db2b81271c2e2ebd4d2ac2df83 upstream.
So the problem this patch is trying to address is as follows:
CPU0 CPU1
context_switch(A, B)
ttwu(A)
LOCK A->pi_lock
A->on_cpu == 0
finish_task_switch(A)
prev_state = A->state <-.
WMB |
A->on_cpu = 0; |
UNLOCK rq0->lock |
| context_switch(C, A)
`-- A->state = TASK_DEAD
prev_state == TASK_DEAD
put_task_struct(A)
context_switch(A, C)
A->state == TASK_DEAD
put_task_struct(A)
The argument being that the WMB will allow the load of A->state on CPU0
to cross over and observe CPU1's store of A->state, which will then
result in a double-drop and use-after-free.
Now the comment states (and this was true once upon a long time ago)
that we need to observe A->state while holding rq->lock because that
will order us against the wakeup; however the wakeup will not in fact
acquire (that) rq->lock; it takes A->pi_lock these days.
We can obviously fix this by upgrading the WMB to an MB, but that is
expensive, so we'd rather avoid that.
The alternative this patch takes is: smp_store_release(&A->on_cpu, 0),
which avoids the MB on some archs, but not important ones like ARM.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: manfred@colorfullife.com
Cc: will.deacon@arm.com
Fixes: e4a52bcb9a18 ("sched: Remove rq->lock from the first half of ttwu()")
Link: http://lkml.kernel.org/r/20150929124509.GG3816@twins.programming.kicks-ass.net
commit 00cc1633816de8c95f337608a1ea64e228faf771 upstream.
Commit 2ee507c47293 ("sched: Add function single_task_running to let a task
check if it is the only task running on a cpu") referenced the current
runqueue with the smp_processor_id. When CONFIG_DEBUG_PREEMPT is enabled,
that is only allowed if preemption is disabled or the currrent task is
bound to the local cpu (e.g. kernel worker).
With commit f78195129963 ("kvm: add halt_poll_ns module parameter") KVM
calls single_task_running. If CONFIG_DEBUG_PREEMPT is enabled that
generates a lot of kernel messages.
To avoid adding preemption in that cases, as it would limit the usefulness,
we change single_task_running to access directly the cpu local runqueue.
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Suggested-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Fixes: 2ee507c472939db4b146d545352b8a7c79ef47f8
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
commit 57ffc5ca679f499f4704fd9b6a372916f59930ee upstream.
Its currently possible to drop the last refcount to the aux buffer
from NMI context, which results in the expected fireworks.
The refcounting needs a bigger overhaul, but to cure the immediate
problem, delay the freeing by using an irq_work.
Reviewed-and-tested-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Stephane Eranian <eranian@gmail.com>
Link: http://lkml.kernel.org/r/20150618103249.GK19282@twins.programming.kicks-ass.net
commit 2619d7e9c92d524cb155ec89fd72875321512e5b upstream.
The internal clocksteering done for fine-grained error
correction uses a logarithmic approximation, so any time
adjtimex() adjusts the clock steering, timekeeping_freqadjust()
quickly approximates the correct clock frequency over a series
of ticks.
Unfortunately, the logic in timekeeping_freqadjust(), introduced
in commit:
dc491596f639 ("timekeeping: Rework frequency adjustments to work better w/ nohz")
used the abs() function with a s64 error value to calculate the
size of the approximated adjustment to be made.
Per include/linux/kernel.h:
"abs() should not be used for 64-bit types (s64, u64, long long) - use abs64()".
Thus on 32-bit platforms, this resulted in the clocksteering to
take a quite dampended random walk trying to converge on the
proper frequency, which caused the adjustments to be made much
slower then intended (most easily observed when large
adjustments are made).
This patch fixes the issue by using abs64() instead.
Reported-by: Nuno Gonçalves <nunojpg@gmail.com>
Tested-by: Nuno Goncalves <nunojpg@gmail.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Cc: Miroslav Lichvar <mlichvar@redhat.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Link: http://lkml.kernel.org/r/1441840051-20244-1-git-send-email-john.stultz@linaro.org
commit 12c641ab8270f787dfcce08b5f20ce8b65008096 upstream.
In the logic in the initial commit of unshare made creating a new
thread group for a process, contingent upon creating a new memory
address space for that process. That is wrong. Two separate
processes in different thread groups can share a memory address space
and clone allows creation of such proceses.
This is significant because it was observed that mm_users > 1 does not
mean that a process is multi-threaded, as reading /proc/PID/maps
temporarily increments mm_users, which allows other processes to
(accidentally) interfere with unshare() calls.
Correct the check in check_unshare_flags() to test for
!thread_group_empty() for CLONE_THREAD, CLONE_SIGHAND, and CLONE_VM.
For sighand->count > 1 for CLONE_SIGHAND and CLONE_VM.
For !current_is_single_threaded instead of mm_users > 1 for CLONE_VM.
By using the correct checks in unshare this removes the possibility of
an accidental denial of service attack.
Additionally using the correct checks in unshare ensures that only an
explicit unshare(CLONE_VM) can possibly trigger the slow path of
current_is_single_threaded(). As an explict unshare(CLONE_VM) is
pointless it is not expected there are many applications that make
that call.
Fixes: b2e0d98705e60e45bbb3c0032c48824ad7ae0704 userns: Implement unshare of the user namespace
Reported-by: Ricky Zhou <rickyz@chromium.org>
Reported-by: Kees Cook <keescook@chromium.org>
commit a068acf2ee77693e0bf39d6e07139ba704f461c3 upstream.
Many file systems that implement the show_options hook fail to correctly
escape their output which could lead to unescaped characters (e.g. new
lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This
could lead to confusion, spoofed entries (resulting in things like
systemd issuing false d-bus "mount" notifications), and who knows what
else. This looks like it would only be the root user stepping on
themselves, but it's possible weird things could happen in containers or
in other situations with delegated mount privileges.
Here's an example using overlay with setuid fusermount trusting the
contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use
of "sudo" is something more sneaky:
$ BASE="ovl"
$ MNT="$BASE/mnt"
$ LOW="$BASE/lower"
$ UP="$BASE/upper"
$ WORK="$BASE/work/ 0 0
none /proc fuse.pwn user_id=1000"
$ mkdir -p "$LOW" "$UP" "$WORK"
$ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt
$ cat /proc/mounts
none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0
none /proc fuse.pwn user_id=1000 0 0
$ fusermount -u /proc
$ cat /proc/mounts
cat: /proc/mounts: No such file or directory
This fixes the problem by adding new seq_show_option and
seq_show_option_n helpers, and updating the vulnerable show_option
handlers to use them as needed. Some, like SELinux, need to be open
coded due to unusual existing escape mechanisms.
[akpm@linux-foundation.org: add lost chunk, per Kees]
[keescook@chromium.org: seq_show_option should be using const parameters]
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: J. R. Okajima <hooanon05g@gmail.com>
commit dd9d3843755da95f63dd3a376f62b3e45c011210 upstream.
There is a race condition in SMP bootup code, which may result
in
WARNING: CPU: 0 PID: 1 at kernel/workqueue.c:4418
workqueue_cpu_up_callback()
or
kernel BUG at kernel/smpboot.c:135!
It can be triggered with a bit of luck in Linux guests running
on busy hosts.
CPU0 CPUn
_cpu_up()
__cpu_up()
start_secondary()
set_cpu_online()
cpumask_set_cpu(cpu,
to_cpumask(cpu_online_bits));
cpu_notify(CPU_ONLINE)
<do stuff, see below>
to_cpumask(cpu_active_bits));
During the various CPU_ONLINE callbacks CPUn is online but not
active. Several things can go wrong at that point, depending on
the scheduling of tasks on CPU0.
Variant 1:
rebind_workers()
set_cpus_allowed_ptr()
This call fails because it requires an active CPU; rebind_workers()
ends with a warning:
Variant 2:
smpboot_thread_call()
smpboot_unpark_threads()
__kthread_unpark()
__kthread_bind()
wake_up_state()
select_task_rq()
select_fallback_rq()
The ->wake_cpu of the unparked thread is not allowed, making a call
to select_fallback_rq() necessary. Then, select_fallback_rq() cannot
find an allowed, active CPU and promptly resets the allowed CPUs, so
that the task in question ends up on CPU0.
When those unparked tasks are eventually executed, they run
immediately into a BUG:
Just changing the order in which the online/active bits are set
(and adding some memory barriers), would solve the two issues
above. However, it would change the order of operations back to
the one before commit 6acbfb96976f ("sched: Fix hotplug vs.
set_cpus_allowed_ptr()"), thus, reintroducing that particular
problem.
Going further back into history, we have at least the following
commits touching this topic:
- commit 2baab4e90495 ("sched: Fix select_fallback_rq() vs cpu_active/cpu_online")
- commit 5fbd036b552f ("sched: Cleanup cpu_active madness")
Together, these give us the following non-working solutions:
- secondary CPU sets active before online, because active is assumed to
be a subset of online;
- secondary CPU sets online before active, because the primary CPU
assumes that an online CPU is also active;
- secondary CPU sets online and waits for primary CPU to set active,
because it might deadlock.
Commit 875ebe940d77 ("powerpc/smp: Wait until secondaries are
active & online") introduces an arch-specific solution to this
arch-independent problem.
Now, go for a more general solution without explicit waiting and
simply set active twice: once on the secondary CPU after online
was set and once on the primary CPU after online was seen.
Signed-off-by: Jan H. Schönherr <jschoenh@amazon.de>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Matt Wilson <msw@amazon.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Fixes: 6acbfb96976f ("sched: Fix hotplug vs. set_cpus_allowed_ptr()")
Link: http://lkml.kernel.org/r/1439408156-18840-1-git-send-email-jschoenh@amazon.de
commit b7560de198222994374c1340a389f12d5efb244a upstream.
This helper is required for irq chips which do not implement a
irq_set_type callback and need to call down the irq domain hierarchy
for the actual trigger type change.
This helper is required to fix further wreckage caused by the
conversion of TI OMAP to hierarchical irq domains and therefor tagged
for stable.
[ tglx: Massaged changelog ]
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Sudeep Holla <sudeep.holla@arm.com>
Cc: <linux@arm.linux.org.uk>
Cc: <nsekhar@ti.com>
Cc: <jason@lakedaemon.net>
Cc: <balbi@ti.com>
Cc: <linux-arm-kernel@lists.infradead.org>
Cc: <tony@atomide.com>
Cc: <marc.zyngier@arm.com>
Cc: stable@vger.kernel.org # 4.1
Link: http://lkml.kernel.org/r/1439554830-19502-3-git-send-email-grygorii.strashko@ti.com
commit 6d4affea7d5aa5ca5ff4c3e5fbf3ee16801cc527 upstream.
irq_chip_retrigger_hierarchy() returns -ENOSYS if it was not able to
find at least one .irq_retrigger() callback implemented in the IRQ
domain hierarchy.
That's wrong, because check_irq_resend() expects a 0 return value from
the callback in case that the hardware assisted resend was not
possible. If the return value is non zero the core code assumes
hardware resend success and the software resend is not invoked.
This results in lost interrupts on platforms where none of the parent
irq chips in the hierarchy implements the retrigger callback.
This is observable on TI OMAP, where the hierarchy is:
ARM GIC <- OMAP wakeupgen <- TI Crossbar
Return 0 instead so the software resend mechanism gets invoked.
Fixes: 85f08c17de26 ('genirq: Introduce helper functions...')
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Reviewed-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: <balbi@ti.com>
Link: http://lkml.kernel.org/r/1439554830-19502-2-git-send-email-grygorii.strashko@ti.com
commit 24ee3cf89bef04e8bc23788aca4e029a3f0f06d9 upstream.
The comment says it's using trialcs->mems_allowed as a temp variable but
it didn't match the code. Change the code to match the comment.
This fixes an issue when writing in cpuset.mems when a sub-directory
exists: we need to write several times for the information to persist:
| root@alban:/sys/fs/cgroup/cpuset# mkdir footest9
| root@alban:/sys/fs/cgroup/cpuset# cd footest9
| root@alban:/sys/fs/cgroup/cpuset/footest9# mkdir aa
| root@alban:/sys/fs/cgroup/cpuset/footest9# cat cpuset.mems
| root@alban:/sys/fs/cgroup/cpuset/footest9# echo 0 > cpuset.mems
| 0
| root@alban:/sys/fs/cgroup/cpuset/footest9# cat aa/cpuset.mems
| root@alban:/sys/fs/cgroup/cpuset/footest9# echo 0 > aa/cpuset.mems
| 0
This should help to fix the following issue in Docker:
https://github.com/opencontainers/runc/issues/133
In some conditions, a Docker container needs to be started twice in
order to work.
Signed-off-by: Alban Crequy <alban@endocode.com>
Tested-by: Iago López Galeiras <iago@endocode.com>
Acked-by: Li Zefan <lizefan@huawei.com>
commit c7999c6f3fed9e383d3131474588f282ae6d56b9 upstream.
I ran the perf fuzzer, which triggered some WARN()s which are due to
trying to stop/restart an event on the wrong CPU.
Use the normal IPI pattern to ensure we run the code on the correct CPU.
Cc: Vince Weaver <vincent.weaver@maine.edu>
Fixes: bad7192b842c ("perf: Fix PERF_EVENT_IOC_PERIOD to force-reset the period")
commit ee9397a6fb9bc4e52677f5e33eed4abee0f515e6 upstream.
If rb->aux_refcount is decremented to zero before rb->refcount,
__rb_free_aux() may be called twice resulting in a double free of
rb->aux_pages. Fix this by adding a check to __rb_free_aux().
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Fixes: 57ffc5ca679f ("perf: Fix AUX buffer refcounting")
Link: http://lkml.kernel.org/r/1437953468.12842.17.camel@decadent.org.uk
commit 00a2916f7f82c348a2a94dbb572874173bc308a3 upstream.
A recent fix to the shadow timestamp inadvertly broke the running time
accounting.
We must not update the running timestamp if we fail to schedule the
event, the event will not have ran. This can (and did) result in
negative total runtime because the stopped timestamp was before the
running timestamp (we 'started' but never stopped the event -- because
it never really started we didn't have to stop it either).
Reported-and-Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Fixes: 72f669c0086f ("perf: Update shadow timestamp before add event")
Cc: Shaohua Li <shli@fb.com>
commit fed66e2cdd4f127a43fd11b8d92a99bdd429528c upstream.
Vince reported that the fasync signal stuff doesn't work proper for
inherited events. So fix that.
Installing fasync allocates memory and sets filp->f_flags |= FASYNC,
which upon the demise of the file descriptor ensures the allocation is
freed and state is updated.
Now for perf, we can have the events stick around for a while after the
original FD is dead because of references from child events. So we
cannot copy the fasync pointer around. We can however consistently use
the parent's fasync, as that will be updated.
Cc: Arnaldo Carvalho deMelo <acme@kernel.org>
Cc: eranian@google.com
Link: http://lkml.kernel.org/r/1434011521.1495.71.camel@twins
commit 3c00cb5e68dc719f2fc73a33b1b230aadfcb1309 upstream.
This function can leak kernel stack data when the user siginfo_t has a
positive si_code value. The top 16 bits of si_code descibe which fields
in the siginfo_t union are active, but they are treated inconsistently
between copy_siginfo_from_user32, copy_siginfo_to_user32 and
copy_siginfo_to_user.
copy_siginfo_from_user32 is called from rt_sigqueueinfo and
rt_tgsigqueueinfo in which the user has full control overthe top 16 bits
of si_code.
This fixes the following information leaks:
x86: 8 bytes leaked when sending a signal from a 32-bit process to
itself. This leak grows to 16 bytes if the process uses x32.
(si_code = __SI_CHLD)
x86: 100 bytes leaked when sending a signal from a 32-bit process to
a 64-bit process. (si_code = -1)
sparc: 4 bytes leaked when sending a signal from a 32-bit process to a
64-bit process. (si_code = any)
parsic and s390 have similar bugs, but they are not vulnerable because
rt_[tg]sigqueueinfo have checks that prevent sending a positive si_code
to a different process. These bugs are also fixed for consistency.
Signed-off-by: Amanieu d'Antras <amanieu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
commit 26135022f85105ad725cda103fa069e29e83bd16 upstream.
This function may copy the si_addr_lsb, si_lower and si_upper fields to
user mode when they haven't been initialized, which can leak kernel
stack data to user mode.
Just checking the value of si_code is insufficient because the same
si_code value is shared between multiple signals. This is solved by
checking the value of si_signo in addition to si_code.
commit e3eea1404f5ff7a2ceb7b5e7ba412a6fd94f2935 upstream.
Commit 4104d326b670 ("ftrace: Remove global function list and call function
directly") simplified the ftrace code by removing the global_ops list with a
new design. But this cleanup also broke the filtering of PIDs that are added
to the set_ftrace_pid file.
Add back the proper hooks to have pid filtering working once again.
Reported-by: Matt Fleming <matt@console-pimps.org>
Reported-by: Richard Weinberger <richard.weinberger@gmail.com>
Tested-by: Matt Fleming <matt@console-pimps.org>
commit 75a06189fc508a2acf470b0b12710362ffb2c4b1 upstream.
The resend mechanism happily calls the interrupt handler of interrupts
which are marked IRQ_NESTED_THREAD from softirq context. This can
result in crashes because the interrupt handler is not the proper way
to invoke the device handlers. They must be invoked via
handle_nested_irq.
Prevent the resend even if the interrupt has no valid parent irq
set. Its better to have a lost interrupt than a crashing machine.
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
commit d194e5d666225b04c7754471df0948f645b6ab3a upstream.
The final version of commit 637241a900cb ("kmsg: honor dmesg_restrict
sysctl on /dev/kmsg") lost few hooks, as result security_syslog() are
processed incorrectly:
- open of /dev/kmsg checks syslog access permissions by using
check_syslog_permissions() where security_syslog() is not called if
dmesg_restrict is set.
- syslog syscall and /proc/kmsg calls do_syslog() where security_syslog
can be executed twice (inside check_syslog_permissions() and then
directly in do_syslog())
With this patch security_syslog() is called once only in all
syslog-related operations regardless of dmesg_restrict value.
Fixes: 637241a900cb ("kmsg: honor dmesg_restrict sysctl on /dev/kmsg")
Signed-off-by: Vasily Averin <vvs@virtuozzo.com>
Cc: Josh Boyer <jwboyer@redhat.com>
Cc: Eric Paris <eparis@redhat.com>
commit fff3b16d2754a061a3549c4307a186423a0128fd upstream.
Many harddisks (mostly WD ones) have firmware problems and take too
long, more than 10 seconds, to resume from suspend. And this often
exceeds the default DPM watchdog timeout (12 seconds), resulting in a
kernel panic out of sudden.
Since most distros just take the default as is, we should give a bit
more safer value. This patch increases the default value from 12
seconds to one minute, which has been confirmed to be long enough for
such problematic disks.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=91921
Fixes: 70fea60d888d (PM / Sleep: Detect device suspend/resume lockup and log event)
commit 6224beb12e190ff11f3c7d4bf50cb2922878f600 upstream.
Fengguang Wu's tests triggered a bug in the branch tracer's start up
test when CONFIG_DEBUG_PREEMPT set. This was because that config
adds some debug logic in the per cpu field, which calls back into
the branch tracer.
The branch tracer has its own recursive checks, but uses a per cpu
variable to implement it. If retrieving the per cpu variable calls
back into the branch tracer, you can see how things will break.
Instead of using a per cpu variable, use the trace_recursion field
of the current task struct. Simply set a bit when entering the
branch tracing and clear it when leaving. If the bit is set on
entry, just don't do the tracing.
There's also the case with lockdep, as the local_irq_save() called
before the recursion can also trigger code that can call back into
the function. Changing that to a raw_local_irq_save() will protect
that as well.
This prevents the recursion and the inevitable crash that follows.
Link: http://lkml.kernel.org/r/20150630141803.GA28071@wfg-t540p.sh.intel.com
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Tested-by: Fengguang Wu <fengguang.wu@intel.com>
commit cc9e4bde03f2b4cfba52406c021364cbd2a4a0f3 upstream.
The trace.h header when called without CONFIG_EVENT_TRACING enabled
(seldom done), will not compile because of a typo in the protocol
of trace_event_enum_update().
commit 6b88f44e161b9ee2a803e5b2b1fbcf4e20e8b980 upstream.
While debugging a WARN_ON() for filtering, I found that it is possible
for the filter string to be referenced after its end. With the filter:
# echo '>' > /sys/kernel/debug/events/ext4/ext4_truncate_exit/filter
The filter_parse() function can call infix_get_op() which calls
infix_advance() that updates the infix filter pointers for the cnt
and tail without checking if the filter is already at the end, which
will put the cnt to zero and the tail beyond the end. The loop then calls
infix_next() that has
ps->infix.cnt--;
return ps->infix.string[ps->infix.tail++];
The cnt will now be below zero, and the tail that is returned is
already passed the end of the filter string. So far the allocation
of the filter string usually has some buffer that is zeroed out, but
if the filter string is of the exact size of the allocated buffer
there's no guarantee that the charater after the nul terminating
character will be zero.
Luckily, only root can write to the filter.
commit b4875bbe7e68f139bd3383828ae8e994a0df6d28 upstream.
When testing the fix for the trace filter, I could not come up with
a scenario where the operand count goes below zero, so I added a
WARN_ON_ONCE(cnt < 0) to the logic. But there is legitimate case
that it can happen (although the filter would be wrong).
That is, a single operation without any operands will hit the path
where the WARN_ON_ONCE() can trigger. Although this is harmless,
and the filter is reported as a error. But instead of spitting out
a warning to the kernel dmesg, just fail nicely and report it via
the proper channels.
Link: http://lkml.kernel.org/r/558C6082.90608@oracle.com
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit 63781394c540dd9e666a6b21d70b64dd52bce76e upstream.
request_any_context_irq() returns a negative value on failure.
It returns either IRQC_IS_HARDIRQ or IRQC_IS_NESTED on success.
So fix testing return value of request_any_context_irq().
Also fixup the return value of devm_request_any_context_irq() to make it
consistent with request_any_context_irq().
Fixes: 0668d3065128 ("genirq: Add devm_request_any_context_irq()")
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Link: http://lkml.kernel.org/r/1431334978.17783.4.camel@ingics.com
commit 9a1bd63cdae4b623494c4ebaf723a91c35ec49fb upstream.
The list of loaded modules is walked through in
module_kallsyms_on_each_symbol (called by kallsyms_on_each_symbol). The
module_mutex lock should be acquired to prevent potential corruptions
in the list.
This was uncovered with new lockdep asserts in module code introduced by
the commit 0be964be0d45 ("module: Sanitize RCU usage and locking") in
recent next- trees.
Signed-off-by: Miroslav Benes <mbenes@suse.cz>
Acked-by: Josh Poimboeuf <jpoimboe@redhat.com>
commit 6e91f8cb138625be96070b778d9ba71ce520ea7e upstream.
If, at the time __rcu_process_callbacks() is invoked, there are callbacks
in Tiny RCU's callback list, but none of them are ready to be invoked,
the current list-management code will knit the non-ready callbacks out
of the list. This can result in hangs and possibly worse. This commit
therefore inserts a check for there being no callbacks that can be
invoked immediately.
This bug is unlikely to occur -- you have to get a new callback between
the time rcu_sched_qs() or rcu_bh_qs() was called, but before we get to
__rcu_process_callbacks(). It was detected by the addition of RCU-bh
testing to rcutorture, which in turn was instigated by Iftekhar Ahmed's
mutation testing. Although this bug was made much more likely by
915e8a4fe45e (rcu: Remove fastpath from __rcu_process_callbacks()), this
did not cause the bug, but rather made it much more probable. That
said, it takes more than 40 hours of rcutorture testing, on average,
for this bug to appear, so this fix cannot be considered an emergency.
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
commit f9bb48825a6b5d02f4cabcc78967c75db903dcdc upstream.
This allows for better documentation in the code and
it allows for a simpler and fully correct version of
fs_fully_visible to be written.
The mount points converted and their filesystems are:
/sys/hypervisor/s390/ s390_hypfs
/sys/kernel/config/ configfs
/sys/kernel/debug/ debugfs
/sys/firmware/efi/efivars/ efivarfs
/sys/fs/fuse/connections/ fusectl
/sys/fs/pstore/ pstore
/sys/kernel/tracing/ tracefs
/sys/fs/cgroup/ cgroup
/sys/kernel/security/ securityfs
/sys/fs/selinux/ selinuxfs
/sys/fs/smackfs/ smackfs
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit f9bd6733d3f11e24f3949becf277507d422ee1eb upstream.
Add a magic sysctl table sysctl_mount_point that when used to
create a directory forces that directory to be permanently empty.
Update the code to use make_empty_dir_inode when accessing permanently
empty directories.
Update the code to not allow adding to permanently empty directories.
Update /proc/sys/fs/binfmt_misc to be a permanently empty directory.
commit 2f993cf093643b98477c421fa2b9a98dcc940323 upstream.
While looking for other users of get_state/cond_sync. I Found
ring_buffer_attach() and it looks obviously buggy?
Don't we need to ensure that we have "synchronize" _between_
list_del() and list_add() ?
IOW. Suppose that ring_buffer_attach() preempts right_after
get_state_synchronize_rcu() and gp completes before spin_lock().
In this case cond_synchronize_rcu() does nothing and we reuse
->rb_entry without waiting for gp in between?
It also moves the ->rcu_pending check under "if (rb)", to make it
more readable imo.
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: dave@stgolabs.net
Cc: der.herr@hofr.at
Cc: josh@joshtriplett.org
Cc: tj@kernel.org
Fixes: b69cf53640da ("perf: Fix a race between ring_buffer_detach() and ring_buffer_attach()")
Link: http://lkml.kernel.org/r/20150530200425.GA15748@redhat.com
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing filter fix from Steven Rostedt:
"Vince Weaver reported a warning when he added perf event filters into
his fuzzer tests. There's a missing check of balanced operations when
parenthesis are used, and this triggers a WARN_ON() and when reading
the failure, the filter reports no failure occurred.
The operands were not being checked if they match, this adds that"
* tag 'trace-fix-filter-4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Have filter check for balanced ops
When the following filter is used it causes a warning to trigger:
# cd /sys/kernel/debug/tracing
# echo "((dev==1)blocks==2)" > events/ext4/ext4_truncate_exit/filter
-bash: echo: write error: Invalid argument
# cat events/ext4/ext4_truncate_exit/filter
((dev==1)blocks==2)
parse_error: No error
WARNING: CPU: 2 PID: 1223 at kernel/trace/trace_events_filter.c:1640 replace_preds+0x3c5/0x990()
Modules linked in: bnep lockd grace bluetooth ...
CPU: 3 PID: 1223 Comm: bash Tainted: G W 4.1.0-rc3-test+ #450
Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v02.05 05/07/2012
0000000000000668 ffff8800c106bc98 ffffffff816ed4f9 ffff88011ead0cf0
0000000000000000 ffff8800c106bcd8 ffffffff8107fb07 ffffffff8136b46c
ffff8800c7d81d48 ffff8800d4c2bc00 ffff8800d4d4f920 00000000ffffffea
Call Trace:
[<ffffffff816ed4f9>] dump_stack+0x4c/0x6e
[<ffffffff8107fb07>] warn_slowpath_common+0x97/0xe0
[<ffffffff8136b46c>] ? _kstrtoull+0x2c/0x80
[<ffffffff8107fb6a>] warn_slowpath_null+0x1a/0x20
[<ffffffff81159065>] replace_preds+0x3c5/0x990
[<ffffffff811596b2>] create_filter+0x82/0xb0
[<ffffffff81159944>] apply_event_filter+0xd4/0x180
[<ffffffff81152bbf>] event_filter_write+0x8f/0x120
[<ffffffff811db2a8>] __vfs_write+0x28/0xe0
[<ffffffff811dda43>] ? __sb_start_write+0x53/0xf0
[<ffffffff812e51e0>] ? security_file_permission+0x30/0xc0
[<ffffffff811dc408>] vfs_write+0xb8/0x1b0
[<ffffffff811dc72f>] SyS_write+0x4f/0xb0
[<ffffffff816f5217>] system_call_fastpath+0x12/0x6a
---[ end trace e11028bd95818dcd ]---
Worse yet, reading the error message (the filter again) it says that
there was no error, when there clearly was. The issue is that the
code that checks the input does not check for balanced ops. That is,
having an op between a closed parenthesis and the next token.
This would only cause a warning, and fail out before doing any real
harm, but it should still not caues a warning, and the error reported
should work:
((dev==1)blocks==2)
parse_error: Meaningless filter expression
And give no kernel warning.
Link: http://lkml.kernel.org/r/20150615175025.7e809215@gandalf.local.home
Cc: stable@vger.kernel.org # 2.6.31+
Pull lockdep fix from Ingo Molnar:
"A lockdep/modules unload race fix that can oops"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
lockdep: Fix a race between /proc/lock_stat and module unload
Pull ring buffer benchmark buglet fix from Steven Rostedt:
"Wang Long fixed a minor bug in the module parameter for the ring
buffer benchmark, where the produce_fifo was being ignored and the
producer thread's priority was being set with the consumer_fifo
parameter"
* tag 'trace-rb-bm-fix-4.1-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
ring-buffer-benchmark: Fix the wrong sched_priority of producer
The producer should be used producer_fifo as its sched_priority,
so correct it.
Link: http://lkml.kernel.org/r/1433923957-67842-1-git-send-email-long.wanglong@huawei.com
Cc: stable@vger.kernel.org # 2.6.33+
Signed-off-by: Wang Long <long.wanglong@huawei.com>
Jovi Zhangwei reported the following problem
Below kernel vm bug can be triggered by tcpdump which mmaped a lot of pages
with GFP_COMP flag.
[Mon May 25 05:29:33 2015] page:ffffea0015414000 count:66 mapcount:1 mapping: (null) index:0x0
[Mon May 25 05:29:33 2015] flags: 0x20047580004000(head)
[Mon May 25 05:29:33 2015] page dumped because: VM_BUG_ON_PAGE(compound_order(page) && !PageTransHuge(page))
[Mon May 25 05:29:33 2015] ------------[ cut here ]------------
[Mon May 25 05:29:33 2015] kernel BUG at mm/migrate.c:1661!
[Mon May 25 05:29:33 2015] invalid opcode: 0000 [#1] SMP
In this case it was triggered by running tcpdump but it's not necessary
reproducible on all systems.
sudo tcpdump -i bond0.100 'tcp port 4242' -c 100000000000 -w 4242.pcap
Compound pages cannot be migrated and it was not expected that such pages
be marked for NUMA balancing. This did not take into account that drivers
such as net/packet/af_packet.c may insert compound pages into userspace
with vm_insert_page. This patch tells the NUMA balancing protection
scanner to skip all VM_MIXEDMAP mappings which avoids the possibility that
compound pages are marked for migration.
Reported-by: Jovi Zhangwei <jovi@cloudflare.com>
Cc: <stable@vger.kernel.org>
The lock_class iteration of /proc/lock_stat is not serialized against
the lockdep_free_key_range() call from module unload.
Therefore it can happen that we find a class of which ->name/->key are
no longer valid.
There is a further bug in zap_class() that left ->name dangling. Cure
this. Use RCU_INIT_POINTER() because NULL.
Since lockdep_free_key_range() is rcu_sched serialized, we can read
both ->name and ->key under rcu_read_lock_sched() (preempt-disable)
and be assured that if we observe a !NULL value it stays safe to use
for as long as we hold that lock.
If we observe both NULL, skip the entry.
Reported-by: Jerome Marchand <jmarchan@redhat.com>
Tested-by: Jerome Marchand <jmarchan@redhat.com>
Link: http://lkml.kernel.org/r/20150602105013.GS3644@twins.programming.kicks-ass.net
Pull perf fixes from Ingo Molnar:
"The biggest chunk of the changes are two regression fixes: a HT
workaround fix and an event-group scheduling fix. It's been verified
with 5 days of fuzzer testing.
Other fixes:
- eBPF fix
- a BIOS breakage detection fix
- PMU driver fixes"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/intel/pt: Fix a refactoring bug
perf/x86: Tweak broken BIOS rules during check_hw_exists()
perf/x86/intel/pt: Untangle pt_buffer_reset_markers()
perf: Disallow sparse AUX allocations for non-SG PMUs in overwrite mode
perf/x86: Improve HT workaround GP counter constraint
perf/x86: Fix event/group validation
perf: Fix race in BPF program unregister
In the functions compat_get_bitmap() and compat_put_bitmap() the
variable nr_compat_longs stores how many compat_ulong_t words should be
copied in a loop.
The copy loop itself is this:
if (nr_compat_longs-- > 0) {
if (__get_user(um, umask)) return -EFAULT;
} else {
um = 0;
Since nr_compat_longs gets unconditionally decremented in each loop and
since it's type is unsigned this could theoretically lead to out of
bounds accesses to userspace if nr_compat_longs wraps around to
(unsigned)(-1).
Although the callers currently do not trigger out-of-bounds accesses, we
should better implement the loop in a safe way to completely avoid such
warp-arounds.
Signed-off-by: Helge Deller <deller@gmx.de>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull fixes for cpumask and modules from Rusty Russell:
"** NOW WITH TESTING! **
Two fixes which got lost in my recent distraction. One is a weird
cpumask function which needed to be rewritten, the other is a module
bug which is cc:stable"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
cpumask_set_cpu_local_first => cpumask_local_spread, lament
module: Call module notifier on failure after complete_formation()
PMUs that don't support hardware scatter tables require big contiguous
chunks of memory and a PMI to switch between them. However, in overwrite
using a PMI for this purpose adds extra overhead that the users would
like to avoid. Thus, in overwrite mode for such PMUs we can only allow
one contiguous chunk for the entire requested buffer.
This patch changes the behavior accordingly, so that if the buddy allocator
fails to come up with a single high-order chunk for the entire requested
buffer, the allocation will fail.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: acme@infradead.org
Cc: adrian.hunter@intel.com
Cc: hpa@zytor.com
Link: http://lkml.kernel.org/r/1432308626-18845-2-git-send-email-alexander.shishkin@linux.intel.com
there is a race between perf_event_free_bpf_prog() and free_trace_kprobe():
__free_event()
event->destroy(event)
tp_perf_event_destroy()
perf_trace_destroy()
perf_trace_event_unreg()
which is dropping event->tp_event->perf_refcount and allows to proceed in:
unregister_trace_kprobe()
unregister_kprobe_event()
trace_remove_event_call()
probe_remove_event_call()
free_trace_kprobe()
while __free_event does:
call_rcu(&event->rcu_head, free_event_rcu);
free_event_rcu()
To fix the race simply move perf_event_free_bpf_prog() before
event->destroy(), since event->tp_event is still valid at that point.
Note, perf_trace_destroy() is not racing with trace_remove_event_call()
since they both grab event_mutex.
Reported-by: Wang Nan <wangnan0@huawei.com>
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: lizefan@huawei.com
Cc: pi3orama@163.com
Fixes: 2541517c32be ("tracing, perf: Implement BPF programs attached to kprobes")
Link: http://lkml.kernel.org/r/1431717321-28772-1-git-send-email-ast@plumgrid.com
Pull timer fix from Thomas Gleixner:
"One more fix from the timer departement:
- Handle division of negative nanosecond values proper on 32bit.
A recent cleanup wrecked the sign handling of the dividend and
dropped the check for negative divisors"
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
ktime: Fix ktime_divns to do signed division
Pull block fixes from Jens Axboe:
"Three small fixes that have been picked up the last few weeks.
Specifically:
- Fix a memory corruption issue in NVMe with malignant user
constructed request. From Christoph.
- Kill (now) unused blk_queue_bio(), dm was changed to not need this
anymore. From Mike Snitzer.
- Always use blk_schedule_flush_plug() from the io_schedule() path
when flushing a plug, fixing a !TASK_RUNNING warning with md. From
Shaohua"
* 'for-linus' of git://git.kernel.dk/linux-block:
sched: always use blk_schedule_flush_plug in io_schedule_out
nvme: fix kernel memory corruption with short INQUIRY buffers
block: remove export for blk_queue_bio
Commit ab992dc38f9a ("watchdog: Fix merge 'conflict'") has introduced an
obvious deadlock because of a typo. watchdog_proc_mutex should be
unlocked on exit.
Thanks to Miroslav Benes who was staring at the code with me and noticed
this.
Duh-by: Peter Zijlstra <peterz@infradead.org>
block plug callback could sleep, so we introduce a parameter
'from_schedule' and corresponding drivers can use it to destinguish a
schedule plug flush or a plug finish. Unfortunately io_schedule_out
still uses blk_flush_plug(). This causes below output (Note, I added a
might_sleep() in raid1_unplug to make it trigger faster, but the whole
thing doesn't matter if I add might_sleep). In raid1/10, this can cause
deadlock.
This patch makes io_schedule_out always uses blk_schedule_flush_plug.
This should only impact drivers (as far as I know, raid 1/10) which are
sensitive to the 'from_schedule' parameter.
[ 370.817949] ------------[ cut here ]------------
[ 370.817960] WARNING: CPU: 7 PID: 145 at ../kernel/sched/core.c:7306 __might_sleep+0x7f/0x90()
[ 370.817969] do not call blocking ops when !TASK_RUNNING; state=2 set at [<ffffffff81092fcf>] prepare_to_wait+0x2f/0x90
[ 370.817971] Modules linked in: raid1
[ 370.817976] CPU: 7 PID: 145 Comm: kworker/u16:9 Tainted: G W 4.0.0+ #361
[ 370.817977] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140709_153802- 04/01/2014
[ 370.817983] Workqueue: writeback bdi_writeback_workfn (flush-9:1)
[ 370.817985] ffffffff81cd83be ffff8800ba8cb298 ffffffff819dd7af 0000000000000001
[ 370.817988] ffff8800ba8cb2e8 ffff8800ba8cb2d8 ffffffff81051afc ffff8800ba8cb2c8
[ 370.817990] ffffffffa00061a8 000000000000041e 0000000000000000 ffff8800ba8cba28
[ 370.817993] Call Trace:
[ 370.817999] [<ffffffff819dd7af>] dump_stack+0x4f/0x7b
[ 370.818002] [<ffffffff81051afc>] warn_slowpath_common+0x8c/0xd0
[ 370.818004] [<ffffffff81051b86>] warn_slowpath_fmt+0x46/0x50
[ 370.818006] [<ffffffff81092fcf>] ? prepare_to_wait+0x2f/0x90
[ 370.818008] [<ffffffff81092fcf>] ? prepare_to_wait+0x2f/0x90
[ 370.818010] [<ffffffff810776ef>] __might_sleep+0x7f/0x90
[ 370.818014] [<ffffffffa0000c03>] raid1_unplug+0xd3/0x170 [raid1]
[ 370.818024] [<ffffffff81421d9a>] blk_flush_plug_list+0x8a/0x1e0
[ 370.818028] [<ffffffff819e3550>] ? bit_wait+0x50/0x50
[ 370.818031] [<ffffffff819e21b0>] io_schedule_timeout+0x130/0x140
[ 370.818033] [<ffffffff819e3586>] bit_wait_io+0x36/0x50
[ 370.818034] [<ffffffff819e31b5>] __wait_on_bit+0x65/0x90
[ 370.818041] [<ffffffff8125b67c>] ? ext4_read_block_bitmap_nowait+0xbc/0x630
[ 370.818043] [<ffffffff819e3550>] ? bit_wait+0x50/0x50
[ 370.818045] [<ffffffff819e3302>] out_of_line_wait_on_bit+0x72/0x80
[ 370.818047] [<ffffffff810935e0>] ? autoremove_wake_function+0x40/0x40
[ 370.818050] [<ffffffff811de744>] __wait_on_buffer+0x44/0x50
[ 370.818053] [<ffffffff8125ae80>] ext4_wait_block_bitmap+0xe0/0xf0
[ 370.818058] [<ffffffff812975d6>] ext4_mb_init_cache+0x206/0x790
[ 370.818062] [<ffffffff8114bc6c>] ? lru_cache_add+0x1c/0x50
[ 370.818064] [<ffffffff81297c7e>] ext4_mb_init_group+0x11e/0x200
[ 370.818066] [<ffffffff81298231>] ext4_mb_load_buddy+0x341/0x360
[ 370.818068] [<ffffffff8129a1a3>] ext4_mb_find_by_goal+0x93/0x2f0
[ 370.818070] [<ffffffff81295b54>] ? ext4_mb_normalize_request+0x1e4/0x5b0
[ 370.818072] [<ffffffff8129ab67>] ext4_mb_regular_allocator+0x67/0x460
[ 370.818074] [<ffffffff81295b54>] ? ext4_mb_normalize_request+0x1e4/0x5b0
[ 370.818076] [<ffffffff8129ca4b>] ext4_mb_new_blocks+0x4cb/0x620
[ 370.818079] [<ffffffff81290956>] ext4_ext_map_blocks+0x4c6/0x14d0
[ 370.818081] [<ffffffff812a4d4e>] ? ext4_es_lookup_extent+0x4e/0x290
[ 370.818085] [<ffffffff8126399d>] ext4_map_blocks+0x14d/0x4f0
[ 370.818088] [<ffffffff81266fbd>] ext4_writepages+0x76d/0xe50
[ 370.818094] [<ffffffff81149691>] do_writepages+0x21/0x50
[ 370.818097] [<ffffffff811d5c00>] __writeback_single_inode+0x60/0x490
[ 370.818099] [<ffffffff811d630a>] writeback_sb_inodes+0x2da/0x590
[ 370.818103] [<ffffffff811abf4b>] ? trylock_super+0x1b/0x50
[ 370.818105] [<ffffffff811abf4b>] ? trylock_super+0x1b/0x50
[ 370.818107] [<ffffffff811d665f>] __writeback_inodes_wb+0x9f/0xd0
[ 370.818109] [<ffffffff811d69db>] wb_writeback+0x34b/0x3c0
[ 370.818111] [<ffffffff811d70df>] bdi_writeback_workfn+0x23f/0x550
[ 370.818116] [<ffffffff8106bbd8>] process_one_work+0x1c8/0x570
[ 370.818117] [<ffffffff8106bb5b>] ? process_one_work+0x14b/0x570
[ 370.818119] [<ffffffff8106c09b>] worker_thread+0x11b/0x470
[ 370.818121] [<ffffffff8106bf80>] ? process_one_work+0x570/0x570
[ 370.818124] [<ffffffff81071868>] kthread+0xf8/0x110
[ 370.818126] [<ffffffff81071770>] ? kthread_create_on_node+0x210/0x210
[ 370.818129] [<ffffffff819e9322>] ret_from_fork+0x42/0x70
[ 370.818131] [<ffffffff81071770>] ? kthread_create_on_node+0x210/0x210
[ 370.818132] ---[ end trace 7b4deb71e68b6605 ]---
V2: don't change ->in_iowait
Cc: NeilBrown <neilb@suse.de>
Signed-off-by: Shaohua Li <shli@fb.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Two watchdog changes that came through different trees had a non
conflicting conflict, that is, one changed the semantics of a variable
but no actual code conflict happened. So the merge appeared fine, but
the resulting code did not behave as expected.
Commit 195daf665a62 ("watchdog: enable the new user interface of the
watchdog mechanism") changes the semantics of watchdog_user_enabled,
which thereafter is only used by the functions introduced by
b3738d293233 ("watchdog: Add watchdog enable/disable all functions").
There further appears to be a distinct lack of serialization between
setting and using watchdog_enabled, so perhaps we should wrap the
{en,dis}able_all() things in watchdog_proc_mutex.
This patch fixes a s2r failure reported by Michal; which I cannot
readily explain. But this does make the code internally consistent
again.
Reported-and-tested-by: Michal Hocko <mhocko@suse.cz>
Pull scheduler fixes from Ingo Molnar:
"Two fixes: a suspend/resume related regression fix, and an RT priority
boosting fix"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/core: Fix regression in cpuset_cpu_inactive() for suspend
sched: Handle priority boosted tasks proper in setscheduler()
