path: root/kernel
2009-06-15Merge branch 'timers-for-linus-migration' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-migration' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: timers: Logic to move non pinned timers timers: /proc/sys sysctl hook to enable timer migration timers: Identifying the existing pinned timers timers: Framework for identifying pinned timers timers: allow deferrable timers for intervals tv2-tv5 to be deferred Fix up conflicts in kernel/sched.c and kernel/timer.c manually
2009-06-15Merge branch 'timers-for-linus-clockevents' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-clockevents' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clockevent: export register_device and delta2ns clockevents: tick_broadcast_device can become static
2009-06-15Merge branch 'timers-for-linus-clocksource' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-clocksource' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clocksource: prevent selection of low resolution clocksourse also for nohz=on clocksource: sanity check sysfs clocksource changes
2009-06-14Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (53 commits) .gitignore: ignore *.lzma files kbuild: add generic --set-str option to scripts/config kbuild: simplify argument loop in scripts/config kbuild: handle non-existing options in scripts/config kallsyms: generalize text region handling kallsyms: support kernel symbols in Blackfin on-chip memory documentation: make version fix kbuild: fix a compile warning gitignore: Add GNU GLOBAL files to top .gitignore kbuild: fix delay in setlocalversion on readonly source README: fix misleading pointer to the defconf directory vmlinux.lds.h update kernel-doc: cleanup perl script Improve vmlinux.lds.h support for arch specific linker scripts kbuild: fix headers_exports with boolean expression kbuild/headers_check: refine extern check kbuild: fix "Argument list too long" error for "make headers_check", ignore *.patch files Remove bashisms from scripts menu: fix embedded menu presentation ...
2009-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (31 commits) trivial: remove the trivial patch monkey's name from SubmittingPatches trivial: Fix a typo in comment of addrconf_dad_start() trivial: usb: fix missing space typo in doc trivial: pci hotplug: adding __init/__exit macros to sgi_hotplug trivial: Remove the hyphen from git commands trivial: fix ETIMEOUT -> ETIMEDOUT typos trivial: Kconfig: .ko is normally not included in module names trivial: SubmittingPatches: fix typo trivial: Documentation/dell_rbu.txt: fix typos trivial: Fix Pavel's address in MAINTAINERS trivial: ftrace:fix description of trace directory trivial: unnecessary (void*) cast removal in sound/oss/msnd.c trivial: input/misc: Fix typo in Kconfig trivial: fix grammo in bus_for_each_dev() kerneldoc trivial: rbtree.txt: fix rb_entry() parameters in sample code trivial: spelling fix in ppc code comments trivial: fix typo in bio_alloc kernel doc trivial: Documentation/rbtree.txt: cleanup kerneldoc of rbtree.txt trivial: Miscellaneous documentation typo fixes trivial: fix typo milisecond/millisecond for documentation and source comments. ...
2009-06-13Merge branch 'x86-mce-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (80 commits) x86, mce: Add boot options for corrected errors x86, mce: Fix mce printing x86, mce: fix for mce counters x86, mce: support action-optional machine checks x86, mce: define MCE_VECTOR x86, mce: rename mce_notify_user to mce_notify_irq x86: fix panic with interrupts off (needed for MCE) x86, mce: export MCE severities coverage via debugfs x86, mce: implement new status bits x86, mce: print header/footer only once for multiple MCEs x86, mce: default to panic timeout for machine checks x86, mce: improve mce_get_rip x86, mce: make non Monarch panic message "Fatal machine check" too x86, mce: switch x86 machine check handler to Monarch election. x86, mce: implement panic synchronization x86, mce: implement bootstrapping for machine check wakeups x86, mce: check early in exception handler if panic is needed x86, mce: add table driven machine check grading x86, mce: remove TSC print heuristic x86, mce: log corrected errors when panicing ...
2009-06-13clocksource: prevent selection of low resolution clocksourse also for nohz=onThomas Gleixner
commit 3f68535adad (clocksource: sanity check sysfs clocksource changes) prevents selection of non high resolution capable clocksources when high resolution mode is active, but did not take into account that the same rules apply for highres=off nohz=on. Check the tick device mode instead of hrtimer_hres_active() to verify whether the system needs to be protected from a switch to jiffies or other non highres capable clock sources. Reported-by: Luming Yu <luming.yu@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM: Add empty suspend/resume device irq functions PM/Hibernate: Move NVS routines into a seperate file (v2). PM/Hibernate: Rename disk.c to hibernate.c PM: Separate suspend to RAM functionality from core Driver Core: Rework platform suspend/resume, print warning PM: Remove device_type suspend()/resume() PM/Hibernate: Move memory shrinking to snapshot.c (rev. 2) PM/Suspend: Do not shrink memory before suspend PM: Remove bus_type suspend_late()/resume_early() V2 PM core: rename suspend and resume functions PM: Rename device_power_down/up() PM: Remove unused asm/suspend.h x86: unify power/cpu_(32|64).c x86: unify power/cpu_(32|64) copyright notes x86: unify power/cpu_(32|64) regarding restoring processor state x86: unify power/cpu_(32|64) regarding saving processor state x86: unify power/cpu_(32|64) global variables x86: unify power/cpu_(32|64) headers PM: Warn if interrupts are enabled during suspend-resume of sysdevs PM/ACPI/x86: Fix sparse warning in arch/x86/kernel/acpi/sleep.c
2009-06-12Merge branch 'perfcounters-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perfcounters-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf_counter: Start documenting HAVE_PERF_COUNTERS requirements perf_counter: Add forward/backward attribute ABI compatibility perf record: Explicity program a default counter perf_counter: Remove PERF_TYPE_RAW special casing perf_counter: PERF_TYPE_HW_CACHE is a hardware counter too powerpc, perf_counter: Fix performance counter event types perf_counter/x86: Add a quirk for Atom processors perf_counter tools: Remove one L1-data alias
2009-06-12PM/Hibernate: Move NVS routines into a seperate file (v2).Cornelia Huck
The *_nvs_* routines in swsusp.c make use of the io*map() functions, which are only provided for HAS_IOMEM, thus breaking compilation if HAS_IOMEM is not set. Fix this by moving the *_nvs_* routines into hibernate_nvs.c, which is only compiled if HAS_IOMEM is set. [rjw: Change the name of the new file to hibernate_nvs.c, add the license line to the header comment.] Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12PM/Hibernate: Rename disk.c to hibernate.cRafael J. Wysocki
Change the name of kernel/power/disk.c to kernel/power/hibernate.c in analogy with the file names introduced by the changes that separated the suspend to RAM and standby funtionality from the common PM functions. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz>
2009-06-12PM: Separate suspend to RAM functionality from coreRafael J. Wysocki
Move the suspend to RAM and standby code from kernel/power/main.c to two separate files, kernel/power/suspend.c containing the basic functions and kernel/power/suspend_test.c containing the automatic suspend test facility based on the RTC clock alarm. There are no changes in functionality related to these modifications. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz>
2009-06-12PM/Hibernate: Move memory shrinking to snapshot.c (rev. 2)Rafael J. Wysocki
A future patch is going to modify the memory shrinking code so that it will make memory allocations to free memory instead of using an artificial memory shrinking mechanism for that. For this purpose it is convenient to move swsusp_shrink_memory() from kernel/power/swsusp.c to kernel/power/snapshot.c, because the new memory-shrinking code is going to use things that are local to kernel/power/snapshot.c . [rev. 2: Make some functions static and remove their headers from kernel/power/power.h] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Wu Fengguang <fengguang.wu@intel.com>
2009-06-12PM/Suspend: Do not shrink memory before suspendRafael J. Wysocki
Remove the shrinking of memory from the suspend-to-RAM code, where it is not really necessary. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@tuxonice.net> Acked-by: Wu Fengguang <fengguang.wu@intel.com>
2009-06-12PM core: rename suspend and resume functionsAlan Stern
This patch (as1241) renames a bunch of functions in the PM core. Rather than go through a boring list of name changes, suffice it to say that in the end we have a bunch of pairs of functions: device_resume_noirq dpm_resume_noirq device_resume dpm_resume device_complete dpm_complete device_suspend_noirq dpm_suspend_noirq device_suspend dpm_suspend device_prepare dpm_prepare in which device_X does the X operation on a single device and dpm_X invokes device_X for all devices in the dpm_list. In addition, the old dpm_power_up and device_resume_noirq have been combined into a single function (dpm_resume_noirq). Lastly, dpm_suspend_start and dpm_resume_end are the renamed versions of the former top-level device_suspend and device_resume routines. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12PM: Rename device_power_down/up()Magnus Damm
Rename the functions performing "_noirq" dev_pm_ops operations from device_power_down() and device_power_up() to device_suspend_noirq() and device_resume_noirq(). The new function names are chosen to show that the functions are responsible for calling the _noirq() versions to finalize the suspend/resume operation. The current function names do not perform power down/up anymore so the names may be misleading. Global function renames: - device_power_down() -> device_suspend_noirq() - device_power_up() -> device_resume_noirq() Static function renames: - suspend_device_noirq() -> __device_suspend_noirq() - resume_device_noirq() -> __device_resume_noirq() Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Len Brown <lenb@kernel.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12Merge branch 'topic/slab/earlyboot-v2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'topic/slab/earlyboot-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: slab: setup cpu caches later on when interrupts are enabled slab,slub: don't enable interrupts during early boot slab: fix gfp flag in setup_cpu_cache() x86: make zap_low_mapping could be used early irq: slab alloc for default irq_affinity memcg: fix page_cgroup fatal error in FLATMEM
2009-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-lguestLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-lguest: (31 commits) lguest: add support for indirect ring entries lguest: suppress notifications in example Launcher lguest: try to batch interrupts on network receive lguest: avoid sending interrupts to Guest when no activity occurs. lguest: implement deferred interrupts in example Launcher lguest: remove obsolete LHREQ_BREAK call lguest: have example Launcher service all devices in separate threads lguest: use eventfds for device notification eventfd: export eventfd_signal and eventfd_fget for lguest lguest: allow any process to send interrupts lguest: PAE fixes lguest: PAE support lguest: Add support for kvm_hypercall4() lguest: replace hypercall name LHCALL_SET_PMD with LHCALL_SET_PGD lguest: use native_set_* macros, which properly handle 64-bit entries when PAE is activated lguest: map switcher with executable page table entries lguest: fix writev returning short on console output lguest: clean up length-used value in example launcher lguest: Segment selectors are 16-bit long. Fix lg_cpu.ss1 definition. lguest: beyond ARRAY_SIZE of cpu->arch.gdt ...
2009-06-12trivial: fix ETIMEOUT -> ETIMEDOUT typosJean Delvare
fix ETIMEOUT -> ETIMEDOUT typos Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12trivial: kernel/power/poweroff.c: whitespace fixManish Katiyar
Fix coding style whitespace fixes. Patch compile tested Before :- total: 1 errors, 0 warnings, 46 lines checked After total: 0 errors, 0 warnings, 46 lines checked Before :- text data bss dec hex filename 107 48 0 155 9b kernel/power/poweroff.o After text data bss dec hex filename 107 48 0 155 9b kernel/power/poweroff.o Signed-off-by: Manish Katiyar <mkatiyar@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12sched: export kick_processRusty Russell
lguest needs kick_process: wake_up_process() does nothing if a process is running, which isn't sufficient (we need it in the kernel). And lguest support is usually modular. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2009-06-12perf_counter: Add forward/backward attribute ABI compatibilityPeter Zijlstra
Provide for means of extending the perf_counter_attr in a 'natural' way. We allow growing the structure by appending fields at the end by specifying the full structure size inside it. When a new kernel sees a smaller (old) structure, it will 0 pad the tail. When an old kernel sees a larger (new) structure, it will verify the tail consists of 0s, otherwise fail. If we fail due to a size-mismatch, we return -E2BIG and write the kernel's native attribe size back into the provided structure. Furthermore, add some attribute verification, so that we'll fail counter creation when unknown bits are present (PERF_SAMPLE, PERF_FORMAT, or in the __reserved fields). (This ABI detail is introduced while keeping the existing syscall ABI.) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-12perf_counter: Remove PERF_TYPE_RAW special casingPeter Zijlstra
The PERF_TYPE_RAW special case seems superfluous these days. Remove it and add it to the switch() stmt like the others. [ Impact: cleanup ] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-12module: trim exception table on init free.Rusty Russell
It's theoretically possible that there are exception table entries which point into the (freed) init text of modules. These could cause future problems if other modules get loaded into that memory and cause an exception as we'd see the wrong fixup. The only case I know of is kvm-intel.ko (when CONFIG_CC_OPTIMIZE_FOR_SIZE=n). Amerigo fixed this long-standing FIXME in the x86 version, but this patch is more general. This implements trim_init_extable(); most archs are simple since they use the standard lib/extable.c sort code. Alpha and IA64 use relative addresses in their fixups, so thier trimming is a slight variation. Sparc32 is unique; it doesn't seem to define ARCH_HAS_SORT_EXTABLE, yet it defines its own sort_extable() which overrides the one in lib. It doesn't sort, so we have to mark deleted entries instead of actually trimming them. Inspired-by: Amerigo Wang <amwang@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: linux-alpha@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: linux-ia64@vger.kernel.org
2009-06-12module_param: allow 'bool' module_params to be bool, not just int.Rusty Russell
Impact: API cleanup For historical reasons, 'bool' parameters must be an int, not a bool. But there are around 600 users, so a conversion seems like useless churn. So we use __same_type() to distinguish, and handle both cases. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12module_param: split perm field into flags and permRusty Russell
Impact: cleanup Rather than hack KPARAM_KMALLOCED into the perm field, separate it out. Since the perm field was 32 bits and only needs 16, we don't add bloat. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12module_param: invbool should take a 'bool', not an 'int'Rusty Russell
It takes an 'int' for historical reasons, and there are only two users: simply switch it over to bool. The other user (uvesafb.c) will get a (harmless-on-x86) warning until the next patch is applied. Cc: Brad Douglas <brad@neruo.com> Cc: Michal Januszewski <spock@gentoo.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12irq: slab alloc for default irq_affinityYinghai Lu
Ingo had [ 0.000000] ------------[ cut here ]------------ [ 0.000000] WARNING: at mm/bootmem.c:537 alloc_arch_preferred_bootmem+0x2b/0x71() [ 0.000000] Hardware name: System Product Name [ 0.000000] Modules linked in: [ 0.000000] Pid: 0, comm: swapper Tainted: G W 2.6.30-tip-03087-g0bb2618-dirty #52506 [ 0.000000] Call Trace: [ 0.000000] [<81032588>] warn_slowpath_common+0x60/0x90 [ 0.000000] [<810325c5>] warn_slowpath_null+0xd/0x10 [ 0.000000] [<819d1bc0>] alloc_arch_preferred_bootmem+0x2b/0x71 [ 0.000000] [<819d1c31>] ___alloc_bootmem_nopanic+0x2b/0x9a [ 0.000000] [<81050a0a>] ? lock_release+0xac/0xb2 [ 0.000000] [<819d1d4c>] ___alloc_bootmem+0xe/0x2d [ 0.000000] [<819d1e9f>] __alloc_bootmem+0xa/0xc [ 0.000000] [<819d7c63>] alloc_bootmem_cpumask_var+0x21/0x26 [ 0.000000] [<819d0cc8>] early_irq_init+0x15/0x10d [ 0.000000] [<819bb75a>] start_kernel+0x167/0x326 [ 0.000000] [<819bb06b>] __init_begin+0x6b/0x70 [ 0.000000] ---[ end trace 4eaa2a86a8e2da23 ]--- [ 0.000000] NR_IRQS:2304 nr_irqs:424 [ 0.000000] CPU 0 irqstacks, hard=821e6000 soft=821e7000 we need to update init_irq_default_affinity Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-11Push BKL down into ->remount_fs()Alessio Igor Bogani
[xfs, btrfs, capifs, shmem don't need BKL, exempt] Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11Switch collect_mounts() to struct pathAl Viro
2009-06-11Merge branch 'linus' into x86/mce3Ingo Molnar
Conflicts: arch/x86/kernel/cpu/mcheck/mce_64.c arch/x86/kernel/irq.c Merge reason: Resolve the conflicts above. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-11Merge branch 'for-linus' of git://linux-arm.org/linux-2.6Linus Torvalds
* 'for-linus' of git://linux-arm.org/linux-2.6: kmemleak: Add the corresponding MAINTAINERS entry kmemleak: Simple testing module for kmemleak kmemleak: Enable the building of the memory leak detector kmemleak: Remove some of the kmemleak false positives kmemleak: Add modules support kmemleak: Add kmemleak_alloc callback from alloc_large_system_hash kmemleak: Add the vmalloc memory allocation/freeing hooks kmemleak: Add the slub memory allocation/freeing hooks kmemleak: Add the slob memory allocation/freeing hooks kmemleak: Add the slab memory allocation/freeing hooks kmemleak: Add documentation on the memory leak detector kmemleak: Add the base support Manual conflict resolution (with the slab/earlyboot changes) in: drivers/char/vt.c init/main.c mm/slab.c
2009-06-11Merge branch 'perfcounters-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perfcounters-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (574 commits) perf_counter: Turn off by default perf_counter: Add counter->id to the throttle event perf_counter: Better align code perf_counter: Rename L2 to LL cache perf_counter: Standardize event names perf_counter: Rename enums perf_counter tools: Clean up u64 usage perf_counter: Rename perf_counter_limit sysctl perf_counter: More paranoia settings perf_counter: powerpc: Implement generalized cache events for POWER processors perf_counters: powerpc: Add support for POWER7 processors perf_counter: Accurate period data perf_counter: Introduce struct for sample data perf_counter tools: Normalize data using per sample period data perf_counter: Annotate exit ctx recursion perf_counter tools: Propagate signals properly perf_counter tools: Small frequency related fixes perf_counter: More aggressive frequency adjustment perf_counter/x86: Fix the model number of Intel Core2 processors perf_counter, x86: Correct some event and umask values for Intel processors ...
2009-06-11Merge branch 'topic/slab/earlyboot' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'topic/slab/earlyboot' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: vgacon: use slab allocator instead of the bootmem allocator irq: use kcalloc() instead of the bootmem allocator sched: use slab in cpupri_init() sched: use alloc_cpumask_var() instead of alloc_bootmem_cpumask_var() memcg: don't use bootmem allocator in setup code irq/cpumask: make memoryless node zero happy x86: remove some alloc_bootmem_cpumask_var calling vt: use kzalloc() instead of the bootmem allocator sched: use kzalloc() instead of the bootmem allocator init: introduce mm_init() vmalloc: use kzalloc() instead of alloc_bootmem() slab: setup allocators earlier in the boot sequence bootmem: fix slab fallback on numa bootmem: use slab if bootmem is no longer available
2009-06-11slow_work_thread() should do the exclusive waitOleg Nesterov
slow_work_thread() sleeps on slow_work_thread_wq without WQ_FLAG_EXCLUSIVE, this means that slow_work_enqueue()->__wake_up(nr_exclusive => 1) wakes up all kslowd threads. This is not what we want, so we change slow_work_thread() to use prepare_to_wait_exclusive() instead. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Merge branch 'for-2.6.31' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.31' of git://git.kernel.dk/linux-2.6-block: (153 commits) block: add request clone interface (v2) floppy: fix hibernation ramdisk: remove long-deprecated "ramdisk=" boot-time parameter fs/bio.c: add missing __user annotation block: prevent possible io_context->refcount overflow Add serial number support for virtio_blk, V4a block: Add missing bounce_pfn stacking and fix comments Revert "block: Fix bounce limit setting in DM" cciss: decode unit attention in SCSI error handling code cciss: Remove no longer needed sendcmd reject processing code cciss: change SCSI error handling routines to work with interrupts enabled. cciss: separate error processing and command retrying code in sendcmd_withirq_core() cciss: factor out fix target status processing code from sendcmd functions cciss: simplify interface of sendcmd() and sendcmd_withirq() cciss: factor out core of sendcmd_withirq() for use by SCSI error handling code cciss: Use schedule_timeout_uninterruptible in SCSI error handling code block: needs to set the residual length of a bidi request Revert "block: implement blkdev_readpages" block: Fix bounce limit setting in DM Removed reference to non-existing file Documentation/PCI/PCI-DMA-mapping.txt ... Manually fix conflicts with tracing updates in: block/blk-sysfs.c drivers/ide/ide-atapi.c drivers/ide/ide-cd.c drivers/ide/ide-floppy.c drivers/ide/ide-tape.c include/trace/events/block.h kernel/trace/blktrace.c
2009-06-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (266 commits) sh: Tie sparseirq in to Kconfig. sh: Wire up sys_rt_tgsigqueueinfo. sh: Fix sys_pwritev() syscall table entry for sh32. sh: Fix sh4a llsc-based cmpxchg() sh: sh7724: Add JPU support sh: sh7724: INTC setting update sh: sh7722 clock framework rewrite sh: sh7366 clock framework rewrite sh: sh7343 clock framework rewrite sh: sh7724 clock framework rewrite V3 sh: sh7723 clock framework rewrite V2 sh: add enable()/disable()/set_rate() to div6 code sh: add AP325RXA mode pin configuration sh: add Migo-R mode pin configuration sh: sh7722 mode pin definitions sh: sh7724 mode pin comments sh: sh7723 mode pin V2 sh: rework mode pin code sh: clock div6 helper code sh: clock div4 frequency table offset fix ...
2009-06-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (44 commits) nommu: Provide mmap_min_addr definition. TOMOYO: Add description of lists and structures. TOMOYO: Remove unused field. integrity: ima audit dentry_open failure TOMOYO: Remove unused parameter. security: use mmap_min_addr indepedently of security models TOMOYO: Simplify policy reader. TOMOYO: Remove redundant markers. SELinux: define audit permissions for audit tree netlink messages TOMOYO: Remove unused mutex. tomoyo: avoid get+put of task_struct smack: Remove redundant initialization. integrity: nfsd imbalance bug fix rootplug: Remove redundant initialization. smack: do not beyond ARRAY_SIZE of data integrity: move ima_counts_get integrity: path_check update IMA: Add __init notation to ima functions IMA: Minimal IMA policy and boot param for TCB IMA policy selinux: remove obsolete read buffer limit from sel_read_bool ...
2009-06-11irq: use kcalloc() instead of the bootmem allocatorPekka Enberg
Fixes the following problem: [ 0.000000] Experimental hierarchical RCU init done. [ 0.000000] NR_IRQS:4352 nr_irqs:256 [ 0.000000] ------------[ cut here ]------------ [ 0.000000] WARNING: at mm/bootmem.c:537 alloc_arch_preferred_bootmem+0x40/0x7e() [ 0.000000] Hardware name: To Be Filled By O.E.M. [ 0.000000] Pid: 0, comm: swapper Not tainted 2.6.30-tip-02161-g7a74539-dirty #59709 [ 0.000000] Call Trace: [ 0.000000] [<ffffffff823f8c8e>] ? alloc_arch_preferred_bootmem+0x40/0x7e [ 0.000000] [<ffffffff81067168>] warn_slowpath_common+0x88/0xcb [ 0.000000] [<ffffffff810671d2>] warn_slowpath_null+0x27/0x3d [ 0.000000] [<ffffffff823f8c8e>] alloc_arch_preferred_bootmem+0x40/0x7e [ 0.000000] [<ffffffff823f9307>] ___alloc_bootmem_nopanic+0x4e/0xec [ 0.000000] [<ffffffff823f93c5>] ___alloc_bootmem+0x20/0x61 [ 0.000000] [<ffffffff823f962e>] __alloc_bootmem+0x1e/0x34 [ 0.000000] [<ffffffff823f757c>] early_irq_init+0x6d/0x118 [ 0.000000] [<ffffffff823e0140>] ? early_idt_handler+0x0/0x71 [ 0.000000] [<ffffffff823e0cf7>] start_kernel+0x192/0x394 [ 0.000000] [<ffffffff823e0140>] ? early_idt_handler+0x0/0x71 [ 0.000000] [<ffffffff823e02ad>] x86_64_start_reservations+0xb4/0xcf [ 0.000000] [<ffffffff823e0000>] ? __init_begin+0x0/0x140 [ 0.000000] [<ffffffff823e0420>] x86_64_start_kernel+0x158/0x17b [ 0.000000] ---[ end trace a7919e7f17c0a725 ]--- [ 0.000000] Fast TSC calibration using PIT [ 0.000000] Detected 2002.510 MHz processor. [ 0.004000] Console: colour VGA+ 80x25 Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-11sched: use slab in cpupri_init()Pekka Enberg
Lets not use the bootmem allocator in cpupri_init() as slab is already up when it is run. Cc: Ingo Molnar <mingo@elte.hu> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-11sched: use alloc_cpumask_var() instead of alloc_bootmem_cpumask_var()Pekka Enberg
Slab is initialized when sched_init() runs now so lets use alloc_cpumask_var(). Cc: Ingo Molnar <mingo@elte.hu> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-11irq/cpumask: make memoryless node zero happyYinghai Lu
Don't hardcode to node zero for early boot IRQ setup memory allocations. [ penberg@cs.helsinki.fi: minor cleanups ] Cc: Ingo Molnar <mingo@elte.hu> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-11x86: remove some alloc_bootmem_cpumask_var callingYinghai Lu
Now that we set up the slab allocator earlier, we can get rid of some alloc_bootmem_cpumask_var() calls in boot code. Cc: Ingo Molnar <mingo@elte.hu> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-11sched: use kzalloc() instead of the bootmem allocatorPekka Enberg
Now that kmem_cache_init() happens before sched_init(), we should use kzalloc() and not the bootmem allocator. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-11kmemleak: Add modules supportCatalin Marinas
This patch handles the kmemleak operations needed for modules loading so that memory allocations from inside a module are properly tracked. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-06-11Merge branch 'linus' into perfcounters/coreIngo Molnar
Conflicts: arch/x86/kernel/irqinit.c arch/x86/kernel/irqinit_64.c arch/x86/kernel/traps.c arch/x86/mm/fault.c include/linux/sched.h kernel/exit.c
2009-06-11perf_counter: Add counter->id to the throttle eventPeter Zijlstra
So as to be able to distuinguish between multiple counters. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-11perf_counter: Standardize event namesPeter Zijlstra
Pure renames only, to PERF_COUNT_HW_* and PERF_COUNT_SW_*. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-11perf_counter: Rename enumsPeter Zijlstra
Rename the perf enums to be in the 'perf_' namespace and strictly enumerate the ABI bits. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-11perf_counter: Rename perf_counter_limit sysctlPeter Zijlstra
Rename perf_counter_limit to perf_counter_max_sample_rate and prohibit creation of counters with a known higher sample frequency. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
