path: root/kernel/workqueue.c
2008-04-29cleanup_workqueue_thread: remove the unneeded "cpu" parameterOleg Nesterov
cleanup_workqueue_thread() doesn't need the second argument, remove it. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29workqueues: shrink cpu_populated_map when CPU diesOleg Nesterov
When cpu_populated_map was introduced, it was supposed that cwq->thread can survive after CPU_DEAD, that is why we never shrink cpu_populated_map. This is not very nice, we can safely remove the already dead CPU from the map. The only required change is that destroy_workqueue() must hold the hotplug lock until it destroys all cwq->thread's, to protect the cpu_populated_map. We could make the local copy of cpu mask and drop the lock, but sizeof(cpumask_t) may be very large. Also, fix the comment near queue_work(). Unless _cpu_down() happens we do guarantee the cpu-affinity of the work_struct, and we have users which rely on this. [akpm@linux-foundation.org: repair comment] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17timer_list: add annotations to workqueue.cPavel Machek
Add timer list annotations to workqueue.c so we can see the call site in the timer stats. Signed-off-by: Pavel Machek <Pavel@suse.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-08workqueue: make delayed_work_timer_fn() staticLi Zefan
delayed_work_timer_fn() is a timer function, make it static. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08kernel: remove fastcall in kernel/*Harvey Harrison
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25cpu-hotplug: replace per-subsystem mutexes with get_online_cpus()Gautham R Shenoy
This patch converts the known per-subsystem mutexes to get_online_cpus put_online_cpus. It also eliminates the CPU_LOCK_ACQUIRE and CPU_LOCK_RELEASE hotplug notification events. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-16lockdep: fix workqueue creation API lockdep interactionJohannes Berg
Dave Young reported warnings from lockdep that the workqueue API can sometimes try to register lockdep classes with the same key but different names. This is not permitted in lockdep. Unfortunately, I was unaware of that restriction when I wrote the code to debug workqueue problems with lockdep and used the workqueue name as the lockdep class name. This can obviously lead to the problem if the workqueue name is dynamic. This patch solves the problem by always using a constant name for the workqueue's lockdep class, namely either the constant name that was passed in or a string consisting of the variable name. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19workqueue: debug flushing deadlocks with lockdepJohannes Berg
In the following scenario: code path 1: my_function() -> lock(L1); ...; flush_workqueue(); ... code path 2: run_workqueue() -> my_work() -> ...; lock(L1); ... you can get a deadlock when my_work() is queued or running but my_function() has acquired L1 already. This patch adds a pseudo-lock to each workqueue to make lockdep warn about this scenario. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-27fix bogus hotplug cpu warningHugh Dickins
Fix bogus DEBUG_PREEMPT warning on x86_64, when cpu brought online after bootup: current_is_keventd is right to note its use of smp_processor_id is preempt-safe, but should use raw_smp_processor_id to avoid the warning. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17destroy_workqueue() can livelockOleg Nesterov
Pointed out by Michal Schmidt <mschmidt@redhat.com>. The bug was introduced in 2.6.22 by me. cleanup_workqueue_thread() does flush_cpu_workqueue(cwq) in a loop until ->worklist becomes empty. This is live-lockable, a re-niced caller can get CPU after wake_up() and insert a new barrier before the lower-priority cwq->thread has a chance to clear ->current_work. Change cleanup_workqueue_thread() to do flush_cpu_workqueue(cwq) only once. We can rely on the fact that run_workqueue() won't return until it flushes all works. So it is safe to call kthread_stop() after that, the "should stop" request won't be noticed until run_workqueue() returns. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Michal Schmidt <mschmidt@redhat.com> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Freezer: make kernel threads nonfreezable by defaultRafael J. Wysocki
Currently, the freezer treats all tasks as freezable, except for the kernel threads that explicitly set the PF_NOFREEZE flag for themselves. This approach is problematic, since it requires every kernel thread to either set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't care for the freezing of tasks at all. It seems better to only require the kernel threads that want to or need to be frozen to use some freezer-related code and to remove any freezer-related code from the other (nonfreezable) kernel threads, which is done in this patch. The patch causes all kernel threads to be nonfreezable by default (ie. to have PF_NOFREEZE set by default) and introduces the set_freezable() function that should be called by the freezable kernel threads in order to unset PF_NOFREEZE. It also makes all of the currently freezable kernel threads call set_freezable(), so it shouldn't cause any (intentional) change of behaviour to appear. Additionally, it updates documentation to describe the freezing of tasks more accurately. [akpm@linux-foundation.org: build fixes] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16make cancel_xxx_work_sync() return a booleanOleg Nesterov
Change cancel_work_sync() and cancel_delayed_work_sync() to return a boolean indicating whether the work was actually cancelled. A zero return value means that the work was not pending/queued. Without that kind of change it is not possible to avoid flush_workqueue() sometimes, see the next patch as an example. Also, this patch unifies both functions and kills the (unlikely) busy-wait loop. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16rename cancel_rearming_delayed_work() to cancel_delayed_work_sync()Oleg Nesterov
Imho, the current naming of cancel_xxx workqueue functions is very confusing. cancel_delayed_work() cancel_rearming_delayed_work() cancel_rearming_delayed_workqueue() // obsolete cancel_work_sync() This looks as if the first 2 functions differ in "type" of their argument which is not true any longer, nowadays the difference is the behaviour. The semantics of cancel_rearming_delayed_work(dwork) was changed significantly, it doesn't require that dwork rearms itself, and cancels dwork synchronously. Rename it to cancel_delayed_work_sync(). This matches cancel_delayed_work() and cancel_work_sync(). Re-create cancel_rearming_delayed_work() as a simple inline obsolete wrapper, like cancel_rearming_delayed_workqueue(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23simplify cleanup_workqueue_thread()Oleg Nesterov
cleanup_workqueue_thread() and cwq_should_stop() are overcomplicated. Convert the code to use kthread_should_stop/kthread_stop as was suggested by Gautham and Srivatsa. In particular this patch removes the (unlikely) busy-wait loop from the exit path, it was a temporary and ugly kludge (if not a bug). Note: the current code was designed to solve another old problem: work->func can't share locks with hotplug callbacks. I think this could be done, see http://marc.info/?l=linux-kernel&m=116905366428633 but this needs some more complications to preserve CPU affinity of cwq->thread during cpu_up(). A freezer-based hotplug looks more appealing. [akpm@linux-foundation.org: make it more tolerant of gcc borkenness] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Zilvinas Valinskas <zilvinas@wilibox.com> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Add suspend-related notifications for CPU hotplugRafael J. Wysocki
Since nonboot CPUs are now disabled after tasks and devices have been frozen and the CPU hotplug infrastructure is used for this purpose, we need special CPU hotplug notifications that will help the CPU-hotplug-aware subsystems distinguish normal CPU hotplug events from CPU hotplug events related to a system-wide suspend or resume operation in progress. This patch introduces such notifications and causes them to be used during suspend and resume transitions. It also changes all of the CPU-hotplug-aware subsystems to take these notifications into consideration (for now they are handled in the same way as the corresponding "normal" ones). [oleg@tv-sign.ru: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09make cancel_rearming_delayed_work() reliableOleg Nesterov
Thanks to Jarek Poplawski for the ideas and for spotting the bug in the initial draft patch. cancel_rearming_delayed_work() currently has many limitations, because it requires that dwork always re-arms itself via queue_delayed_work(). So it hangs forever if dwork doesn't do this, or cancel_rearming_delayed_work/ cancel_delayed_work was already called. It uses flush_workqueue() in a loop, so it can't be used if workqueue was freezed, and it is potentially live- lockable on busy system if delay is small. With this patch cancel_rearming_delayed_work() doesn't make any assumptions about dwork, it can re-arm itself via queue_delayed_work(), or queue_work(), or do nothing. As a "side effect", cancel_work_sync() was changed to handle re-arming works as well. Disadvantages: - this patch adds wmb() to insert_work(). - slowdowns the fast path (when del_timer() succeeds on entry) of cancel_rearming_delayed_work(), because wait_on_work() is called unconditionally. In that case, compared to the old version, we are doing "unneeded" lock/unlock for each online CPU. On the other hand, this means we don't need to use cancel_work_sync() after cancel_rearming_delayed_work(). - complicates the code (.text grows by 130 bytes). [akpm@linux-foundation.org: fix speling] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: David Chinner <dgc@sgi.com> Cc: David Howells <dhowells@redhat.com> Cc: Gautham Shenoy <ego@in.ibm.com> Acked-by: Jarek Poplawski <jarkao2@o2.pl> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09worker_thread: don't play with SIGCHLD and numa policyOleg Nesterov
worker_thread() inherits ignored SIGCHLD and numa_default_policy() from its parent, kthreadd. No need to setup this again. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09unify flush_work/flush_work_keventd and rename it to cancel_work_syncOleg Nesterov
flush_work(wq, work) doesn't need the first parameter, we can use cwq->wq (this was possible from the very beginnig, I missed this). So we can unify flush_work_keventd and flush_work. Also, rename flush_work() to cancel_work_sync() and fix all callers. Perhaps this is not the best name, but "flush_work" is really bad. (akpm: this is why the earlier patches bypassed maintainers) Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Tejun Heo <htejun@gmail.com> Cc: Auke Kok <auke-jan.h.kok@intel.com>, Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09worker_thread: fix racy try_to_freeze() usageOleg Nesterov
worker_thread() can miss freeze_process()->signal_wake_up() if it happens between try_to_freeze() and prepare_to_wait(). We should check freezing() before entering schedule(). This race was introduced by me in [PATCH 1/1] workqueue: don't migrate pending works from the dead CPU Looks like mm/vmscan.c:kswapd() has the same race. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09worker_thread: don't play with signalsOleg Nesterov
worker_thread() doesn't need to "Block and flush all signals", this was already done by its caller, kthread(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: kill NOAUTOREL worksOleg Nesterov
We don't have any users, and it is not so trivial to use NOAUTOREL works correctly. It is better to simplify API. Delete NOAUTOREL support and rename work_release to work_clear_pending to avoid a confusion. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09make cancel_rearming_delayed_work() work on any workqueue, not just keventd_wqOleg Nesterov
cancel_rearming_delayed_workqueue(wq, dwork) doesn't need the first parameter. We don't hang on un-queued dwork any longer, and work->data doesn't change its type. This means we can always figure out "wq" from dwork when it is needed. Remove this parameter, and rename the function to cancel_rearming_delayed_work(). Re-create an inline "obsolete" cancel_rearming_delayed_workqueue(wq) which just calls cancel_rearming_delayed_work(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: introduce wq_per_cpu() helperOleg Nesterov
Cleanup. A number of per_cpu_ptr(wq->cpu_wq, cpu) users have to check that cpu is valid for this wq. Make a simple helper. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09unify queue_delayed_work() and queue_delayed_work_on()Oleg Nesterov
Change queue_delayed_work() to use queue_delayed_work_on() to avoid the code duplication (saves 133 bytes). Q: queue_delayed_work() enqueues &dwork->work directly when delay == 0, why? [jirislaby@gmail.com: oops fix] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09make queue_delayed_work() friendly to flush_fork()Oleg Nesterov
Currently typeof(delayed_work->work.data) is "struct workqueue_struct" when the timer is pending "struct cpu_workqueue_struct" whe the work is queued This makes impossible to use flush_fork(delayed_work->work) in addition to cancel_delayed_work/cancel_rearming_delayed_work, not good. Change queue_delayed_work/delayed_work_timer_fn to use cwq, not wq. This complicates (and uglifies) these functions a little bit, but alows us to use flush_fork(dwork) and imho makes the whole code more consistent. Also, document the fact that cancel_rearming_delayed_work() doesn't garantee the completion of work->func() upon return. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueues: shift kthread_bind() from CPU_UP_PREPARE to CPU_ONLINEOleg Nesterov
CPU_UP_PREPARE binds cwq->thread to the new CPU. So CPU_UP_CANCELED tries to wake up the task which is bound to the failed CPU. With this patch we don't bind cwq->thread until CPU becomes online. The first wake_up() after kthread_create() is a bit special, make a simple helper for that. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: make init_workqueues() __initOleg Nesterov
The only caller of init_workqueues() is do_basic_setup(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: introduce workqueue_struct->singlethreadOleg Nesterov
Add explicit workqueue_struct->singlethread flag. This lessens .text a little, but most importantly this allows us to manipulate wq->list without changine the meaning of is_single_threaded(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: introduce cpu_singlethread_mapOleg Nesterov
The code like if (is_single_threaded(wq)) do_something(singlethread_cpu); else { for_each_cpu_mask(cpu, cpu_populated_map) do_something(cpu); } looks very annoying. We can add "static cpumask_t cpu_singlethread_map" and simplify the code. Lessens .text a bit, and imho makes the code more readable. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: make cancel_rearming_delayed_workqueue() work on idle dworkOleg Nesterov
cancel_rearming_delayed_workqueue(dwork) will hang forever if dwork was not scheduled, because in that case cancel_delayed_work()->del_timer_sync() never returns true. I don't know if there are any callers which may have problems, but this is not so convenient, and the fix is very simple. Q: looks like we don't need "struct workqueue_struct *wq" parameter. If the timer was aborted successfully, get_wq_data() == wq. Is it worth to add the new function? Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: don't save interrupts in run_workqueue()Oleg Nesterov
work->func() may sleep, it's a bug to call run_workqueue() with irqs disabled. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: kill run_scheduled_work()Oleg Nesterov
Because it has no callers. Actually, I think the whole idea of run_scheduled_work() was not right, not good to mix "unqueue this work and execute its ->func()" in one function. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: don't migrate pending works from the dead CPUOleg Nesterov
Currently CPU_DEAD uses kthread_stop() to stop cwq->thread and then transfers cwq->worklist to another CPU. However, it is very unlikely that worker_thread() will notice kthread_should_stop() before flushing cwq->worklist. It is only possible if worker_thread() was preempted after run_workqueue(cwq), a new work_struct was added, and CPU_DEAD happened before cwq->thread has a chance to run. This means that take_over_work() mostly adds unneeded complications. Note also that kthread_stop() is not good per se, wake_up_process() may confuse work->func() if it sleeps waiting for some event. Remove take_over_work() and migrate_sequence complications. CPU_DEAD sets the cwq->should_stop flag (introduced by this patch) and waits for cwq->thread to flush cwq->worklist and exit. Because the dead CPU is not on cpu_online_map, no more works can be added to that cwq. cpu_populated_map was introduced to optimize for_each_possible_cpu(), it is not strictly needed, and it is more a documentation in fact. Saves 418 bytes. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com> Cc: Gautham shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: don't clear cwq->thread until it exitsOleg Nesterov
Pointed out by Srivatsa Vaddagiri. cleanup_workqueue_thread() sets cwq->thread = NULL and does kthread_stop(). This breaks the "if (cwq->thread == current)" logic in flush_cpu_workqueue() and leads to deadlock. Kill the thead first, then clear cwq->thread. workqueue_mutex protects us from create_workqueue_thread() so we don't need cwq->lock. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com> Cc: Gautham shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: fix flush_workqueue() vs CPU_DEAD raceOleg Nesterov
Many thanks to Srivatsa Vaddagiri for the helpful discussion and for spotting the bug in my previous attempt. work->func() (and thus flush_workqueue()) must not use workqueue_mutex, this leads to deadlock when CPU_DEAD does kthread_stop(). However without this mutex held we can't detect CPU_DEAD in progress, which can move pending works to another CPU while the dead one is not on cpu_online_map. Change flush_workqueue() to use for_each_possible_cpu(). This means that flush_cpu_workqueue() may hit CPU which is already dead. However in that case !list_empty(&cwq->worklist) || cwq->current_work != NULL means that CPU_DEAD in progress, it will do kthread_stop() + take_over_work() so we can proceed and insert a barrier. We hold cwq->lock, so we are safe. Also, add migrate_sequence incremented by take_over_work() under cwq->lock. If take_over_work() happened before we checked this CPU, we should see the new value after spin_unlock(). Further possible changes: remove CPU_DEAD handling (along with take_over_work, migrate_sequence) from workqueue.c. CPU_DEAD just sets cwq->please_exit_after_flush flag. CPU_UP_PREPARE->create_workqueue_thread() clears this flag, and creates the new thread if cwq->thread == NULL. This way the workqueue/cpu-hotplug interaction is almost zero, workqueue_mutex just protects "workqueues" list, CPU_LOCK_ACQUIRE/CPU_LOCK_RELEASE go away. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com> Cc: Gautham shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: fix freezeable workqueues implementationOleg Nesterov
Currently ->freezeable is per-cpu, this is wrong. CPU_UP_PREPARE creates cwq->thread which is not freezeable. Move ->freezeable to workqueue_struct. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com> Cc: Gautham shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09flush_cpu_workqueue: don't flush an empty ->worklistOleg Nesterov
Now when we have ->current_work we can avoid adding a barrier and waiting for its completition when cwq's queue is empty. Note: this change is also useful if we change flush_workqueue() to also check the dead CPUs. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Gautham Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09flush_workqueue(): use preempt_disable to hold off cpu hotplugAndrew Morton
Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Gautham Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09implement flush_work()Oleg Nesterov
A basic problem with flush_scheduled_work() is that it blocks behind _all_ presently-queued works, rather than just the work whcih the caller wants to flush. If the caller holds some lock, and if one of the queued work happens to want that lock as well then accidental deadlocks can occur. One example of this is the phy layer: it wants to flush work while holding rtnl_lock(). But if a linkwatch event happens to be queued, the phy code will deadlock because the linkwatch callback function takes rtnl_lock. So we implement a new function which will flush a *single* work - just the one which the caller wants to free up. Thus we avoid the accidental deadlocks which can arise from unrelated subsystems' callbacks taking shared locks. flush_work() non-blockingly dequeues the work_struct which we want to kill, then it waits for its handler to complete on all CPUs. Add ->current_work to the "struct cpu_workqueue_struct", it points to currently running "struct work_struct". When flush_work(work) detects ->current_work == work, it inserts a barrier at the _head_ of ->worklist (and thus right _after_ that work) and waits for completition. This means that the next work fired on that CPU will be this barrier, or another barrier queued by concurrent flush_work(), so the caller of flush_work() will be woken before any "regular" work has a chance to run. When wait_on_work() unlocks workqueue_mutex (or whatever we choose to protect against CPU hotplug), CPU may go away. But in that case take_over_work() will move a barrier we queued to another CPU, it will be fired sometime, and wait_on_work() will be woken. Actually, we are doing cleanup_workqueue_thread()->kthread_stop() before take_over_work(), so cwq->thread should complete its ->worklist (and thus the barrier), because currently we don't check kthread_should_stop() in run_workqueue(). But even if we did, everything should be ok. [akpm@osdl.org: cleanup] [akpm@osdl.org: add flush_work_keventd() wrapper] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09reimplement flush_workqueue()Oleg Nesterov
Remove ->remove_sequence, ->insert_sequence, and ->work_done from struct cpu_workqueue_struct. To implement flush_workqueue() we can queue a barrier work on each CPU and wait for its completition. The barrier is queued under workqueue_mutex to ensure that per cpu wq->cpu_wq is alive, we drop this mutex before going to sleep. If CPU goes down while we are waiting for completition, take_over_work() will move the barrier on another CPU, and the handler will wake up us eventually. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09schedule_on_each_cpu(): use preempt_disable()Andrew Morton
We take workqueue_mutex in there to keep CPU hotplug away. But preempt_disable() will suffice for that. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Add debugging feature /proc/timer_statIngo Molnar
Add /proc/timer_stats support: debugging feature to profile timer expiration. Both the starting site, process/PID and the expiration function is captured. This allows the quick identification of timer event sources in a system. Sample output: # echo 1 > /proc/timer_stats # cat /proc/timer_stats Timer Stats Version: v0.1 Sample period: 4.010 s 24, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick) 11, 0 swapper sk_reset_timer (tcp_delack_timer) 6, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick) 2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) 17, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick) 2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) 4, 2050 pcscd do_nanosleep (hrtimer_wakeup) 5, 4179 sshd sk_reset_timer (tcp_write_timer) 4, 2248 yum-updatesd schedule_timeout (process_timeout) 18, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick) 3, 0 swapper sk_reset_timer (tcp_delack_timer) 1, 1 swapper neigh_table_init_no_netlink (neigh_periodic_timer) 2, 1 swapper e1000_up (e1000_watchdog) 1, 1 init schedule_timeout (process_timeout) 100 total events, 25.24 events/sec [ cleanups and hrtimers support from Thomas Gleixner <tglx@linutronix.de> ] [bunk@stusta.de: nr_entries can become static] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-22[PATCH] fix kernel-doc warnings in 2.6.20-rc1Randy Dunlap
Fix kernel-doc warnings in 2.6.20-rc1. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-21[PATCH] workqueue: fix schedule_on_each_cpu()Ingo Molnar
fix the schedule_on_each_cpu() implementation: __queue_work() is now stricter, hence set the work-pending bit before passing in the new work. (found in the -rt tree, using Peter Zijlstra's files-lock scalability patchset) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-16Make workqueue bit operations work on "atomic_long_t"Linus Torvalds
On architectures where the atomicity of the bit operations is handled by external means (ie a separate spinlock to protect concurrent accesses), just doing a direct assignment on the workqueue data field (as done by commit 4594bf159f1962cec3b727954b7c598b07e2e737) can cause the assignment to be lost due to lack of serialization with the bitops on the same word. So we need to serialize the assignment with the locks on those architectures (notably older ARM chips, PA-RISC and sparc32). So rather than using an "unsigned long", let's use "atomic_long_t", which already has a safe assignment operation (atomic_long_set()) on such architectures. This requires that the atomic operations use the same atomicity locks as the bit operations do, but that is largely the case anyway. Sparc32 will probably need fixing. Architectures (including modern ARM with LL/SC) that implement sane atomic operations for SMP won't see any of this matter. Cc: Russell King <rmk+lkml@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: David Miller <davem@davemloft.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Linux Arch Maintainers <linux-arch@vger.kernel.org> Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-09[PATCH] WorkStruct: Use direct assignment rather than cmpxchg()David Howells
Use direct assignment rather than cmpxchg() as the latter is unavailable and unimplementable on some platforms and is actually unnecessary. The use of cmpxchg() was to guard against two possibilities, neither of which can actually occur: (1) The pending flag may have been unset or may be cleared. However, given where it's called, the pending flag is _always_ set. I don't think it can be unset whilst we're in set_wq_data(). Once the work is enqueued to be actually run, the only way off the queue is for it to be actually run. If it's a delayed work item, then the bit can't be cleared by the timer because we haven't started the timer yet. Also, the pending bit can't be cleared by cancelling the delayed work _until_ the work item has had its timer started. (2) The workqueue pointer might change. This can only happen in two cases: (a) The work item has just been queued to actually run, and so we're protected by the appropriate workqueue spinlock. (b) A delayed work item is being queued, and so the timer hasn't been started yet, and so no one else knows about the work item or can access it (the pending bit protects us). Besides, set_wq_data() _sets_ the workqueue pointer unconditionally, so it can be assigned instead. So, replacing the set_wq_data() with a straight assignment would be okay in most cases. The problem is where we end up tangling with test_and_set_bit() emulated using spinlocks, and even then it's not a problem _provided_ test_and_set_bit() doesn't attempt to modify the word if the bit was set. If that's a problem, then a bitops-proofed assignment will be required - equivalent to atomic_set() vs other atomic_xxx() ops. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Add "run_scheduled_work()" workqueue functionLinus Torvalds
This allows workqueue users to run just their own pending work, rather than wait for the whole workqueue to finish running. This solves the deadlock with networking libphy that was due to other workqueue entries possibly needing a lock that was held by the routine that wanted to flush its own work. It's not wonderful: if you absolutely need to synchronize with the work function having been executed, any user strictly speaking should have its own completion tracking logic, since when we run things explicitly by hand, the generic workqueue layer can no longer help us synchronize. Also, this is strictly only usable for work that has been scheduled without any delayed timers. You can not mix the new interface with schedule_delayed_work(). But it's better than what we had currently. Acked-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] hotplug CPU: clean up hotcpu_notifier() useIngo Molnar
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn, prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus generating compiler warnings of unused symbols, hence forcing people to add #ifdefs. the compiler can skip truly unused functions just fine: text data bss dec hex filename 1624412 728710 3674856 6027978 5bfaca vmlinux.before 1624412 728710 3674856 6027978 5bfaca vmlinux.after [akpm@osdl.org: topology.c fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
