path: root/kernel/uid16.c
2011-03-23userns: user namespaces: convert several capable() callsSerge E. Hallyn
CAP_IPC_OWNER and CAP_IPC_LOCK can be checked against current_user_ns(), because the resource comes from current's own ipc namespace. setuid/setgid are to uids in own namespace, so again checks can be against current_user_ns(). Changelog: Jan 11: Use task_ns_capable() in place of sched_capable(). Jan 11: Use nsown_capable() as suggested by Bastian Blank. Jan 11: Clarify (hopefully) some logic in futex and sched.c Feb 15: use ns_capable for ipc, not nsown_capable Feb 23: let copy_ipcs handle setting ipc_ns->user_ns Feb 23: pass ns down rather than taking it from current [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 19Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 18Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 17Heiko Carstens
2008-11-14CRED: Wrap current->cred and a few other accessorsDavid Howells
Wrap current->cred and a few other accessors to hide their actual implementation. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-10asmlinkage_protect replaces prevent_tail_callRoland McGrath
The prevent_tail_call() macro works around the problem of the compiler clobbering argument words on the stack, which for asmlinkage functions is the caller's (user's) struct pt_regs. The tail/sibling-call optimization is not the only way that the compiler can decide to use stack argument words as scratch space, which we have to prevent. Other optimizations can do it too. Until we have new compiler support to make "asmlinkage" binding on the compiler's own use of the stack argument frame, we have work around all the manifestations of this issue that crop up. More cases seem to be prevented by also keeping the incoming argument variables live at the end of the function. This makes their original stack slots attractive places to leave those variables, so the compiler tends not clobber them for something else. It's still no guarantee, but it handles some observed cases that prevent_tail_call() did not. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-04-19[PATCH] Add more prevent_tail_call()OGAWA Hirofumi
Those also break userland regs like following. 00000000 <sys_chown16>: 0: 0f b7 44 24 0c movzwl 0xc(%esp),%eax 5: 83 ca ff or $0xffffffff,%edx 8: 0f b7 4c 24 08 movzwl 0x8(%esp),%ecx d: 66 83 f8 ff cmp $0xffffffff,%ax 11: 0f 44 c2 cmove %edx,%eax 14: 66 83 f9 ff cmp $0xffffffff,%cx 18: 0f 45 d1 cmovne %ecx,%edx 1b: 89 44 24 0c mov %eax,0xc(%esp) 1f: 89 54 24 08 mov %edx,0x8(%esp) 23: e9 fc ff ff ff jmp 24 <sys_chown16+0x24> where the tailcall at the end overwrites the incoming stack-frame. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> [ I would _really_ like to have a way to tell gcc about calling conventions. The "prevent_tail_call()" macro is pretty ugly ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
