Currently the function trace callback receives only the ip and parent_ip
of the function that it traced. It would be more powerful to also return
the ops that registered the function as well. This allows the same function
to act differently depending on what ftrace_ops registered it.
Link: http://lkml.kernel.org/r/20120612225424.267254552@goodmis.org
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/core
Pull tracing fix from Steve Rostedt.
Pick up the latest ring-buffer fixes, before applying a new fix.
'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip
Pull RCU, perf, and scheduler fixes from Ingo Molnar.
The RCU fix is a revert for an optimization that could cause deadlocks.
One of the scheduler commits (164c33c6adee "sched: Fix fork() error path
to not crash") is correct but not complete (some architectures like Tile
are not covered yet) - the resulting additional fixes are still WIP and
Ingo did not want to delay these pending fixes. See this thread on
lkml:
[PATCH] fork: fix error handling in dup_task()
The perf fixes are just trivial oneliners.
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
Revert "rcu: Move PREEMPT_RCU preemption to switch_to() invocation"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf kvm: Fix segfault with report and mixed guestmount use
perf kvm: Fix regression with guest machine creation
perf script: Fix format regression due to libtraceevent merge
ring-buffer: Fix accounting of entries when removing pages
ring-buffer: Fix crash due to uninitialized new_pages list head
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
MAINTAINERS/sched: Update scheduler file pattern
sched/nohz: Rewrite and fix load-avg computation -- again
sched: Fix fork() error path to not crash
Clean up and return -ENOMEM on if the kzalloc() fails.
This also prevents a potential crash, as the pointer that failed to
allocate would be later used.
Link: http://lkml.kernel.org/r/20120711063507.GF11812@elgon.mountain
Pull tracing updates from Steve Rostedt.
Merge this branch to pick up a fixlet and to update to a more recent base.
Pull block bits from Jens Axboe:
"As vacation is coming up, thought I'd better get rid of my pending
changes in my for-linus branch for this iteration. It contains:
- Two patches for mtip32xx. Killing a non-compliant sysfs interface
and moving it to debugfs, where it belongs.
- A few patches from Asias. Two legit bug fixes, and one killing an
interface that is no longer in use.
- A patch from Jan, making the annoying partition ioctl warning a bit
less annoying, by restricting it to !CAP_SYS_RAWIO only.
- Three bug fixes for drbd from Lars Ellenberg.
- A fix for an old regression for umem, it hasn't really worked since
the plugging scheme was changed in 3.0.
- A few fixes from Tejun.
- A splice fix from Eric Dumazet, fixing an issue with pipe
resizing."
* 'for-linus' of git://git.kernel.dk/linux-block:
scsi: Silence unnecessary warnings about ioctl to partition
block: Drop dead function blk_abort_queue()
block: Mitigate lock unbalance caused by lock switching
block: Avoid missed wakeup in request waitqueue
umem: fix up unplugging
splice: fix racy pipe->buffers uses
drbd: fix null pointer dereference with on-congestion policy when diskless
drbd: fix list corruption by failing but already aborted reads
drbd: fix access of unallocated pages and kernel panic
xen/blkfront: Add WARN to deal with misbehaving backends.
blkcg: drop local variable @q from blkg_destroy()
mtip32xx: Create debugfs entries for troubleshooting
mtip32xx: Remove 'registers' and 'flags' from sysfs
blkcg: fix blkg_alloc() failure path
block: blkcg_policy_cfq shouldn't be used if !CONFIG_CFQ_GROUP_IOSCHED
block: fix return value on cfq_init() failure
mtip32xx: Remove version.h header file inclusion
xen/blkback: Copy id field when doing BLKIF_DISCARD.
When removing pages from the ring buffer, its state is not reset. This
means that the counters need to be correctly updated to account for the
pages removed.
Update the overrun counter to reflect the removed events from the pages.
Link: http://lkml.kernel.org/r/1340998301-1715-1-git-send-email-vnagarnaik@google.com
Cc: Justin Teravest <teravest@google.com>
Cc: David Sharp <dhsharp@google.com>
Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com>
The new_pages list head in the cpu_buffer is not initialized. When
adding pages to the ring buffer, if the memory allocation fails in
ring_buffer_resize, the clean up handler tries to free up the allocated
pages from all the cpu buffers. The panic is caused by referencing the
uninitialized new_pages list head.
Initializing the new_pages list head in rb_allocate_cpu_buffer fixes
this.
Link: http://lkml.kernel.org/r/1340391005-10880-1-git-send-email-vnagarnaik@google.com
The ring buffer reader page is used to swap a page from the writable
ring buffer. If the writer happens to be on that page, it ends up on the
reader page, but will simply move off of it, back into the writable ring
buffer as writes are added.
The time stamp passed back to the readers is stored in the cpu_buffer per
CPU descriptor. This stamp is updated when a swap of the reader page takes
place, and it reads the current stamp from the page taken from the writable
ring buffer. Everytime a writer goes to a new page, it updates the time stamp
of that page.
The problem happens if a reader reads a page from an empty per CPU ring buffer.
If the buffer is empty, the swap still takes place, placing the writer at the
start of the reader page. If at a later time, a write happens, it updates the
page's time stamp and continues. But the problem is that the read_stamp does
not get updated, because the page was already swapped.
The solution to this was to not swap the page if the ring buffer happens to
be empty. This also removes the side effect that the writes on the reader
page will not get updated because the writer never gets back on the reader
page without a swap. That is, if a read happens on an empty buffer, but then
no reads happen for a while. If a swap took place, and the writer were to start
writing a lot of data (function tracer), it will start overflowing the ring buffer
and overwrite the older data. But because the writer never goes back onto the
reader page, the data left on the reader page never gets overwritten. This
causes the reader to see really old data, followed by a jump to newer data.
Link: http://lkml.kernel.org/r/1340060577-9112-1-git-send-email-dhsharp@google.com
Google-Bug-Id: 6410455
Reported-by: David Sharp <dhsharp@google.com>
tested-by: David Sharp <dhsharp@google.com>
Replace the NR_CPUS array of buffer_iter from the trace_iterator
with an allocated array. This will just create an array of
possible CPUS instead of the max number specified.
The use of NR_CPUS in that array caused allocation failures for
machines that were tight on memory. This did not cause any failures
to the system itself (no crashes), but caused unnecessary failures
for reading the trace files.
Added a helper function called 'trace_buffer_iter()' that returns
the buffer_iter item or NULL if it is not defined or the array was
not allocated. Some routines do not require the array
(tracing_open_pipe() for one).
Reported-by: Dave Jones <davej@redhat.com>
Add a WARN_ON() output on test failures so that they are easier to detect
in automated tests. Although, the WARN_ON() will not print if the test
causes the system to crash, obviously.
Merge in all fixes before applying more changes.
All trace events including ftrace internel events (like trace_printk
and function tracing), register functions that describe how to print
their output. The events may be recorded as soon as the ring buffer
is allocated, but they are just raw binary in the buffer. The mapping
of event ids to how to print them are held within a structure that
is registered on system boot.
If a crash happens in boot up before these functions are registered
then their output (via ftrace_dump_on_oops) will be useless:
Dumping ftrace buffer:
<...>-1 0.... 319705us : Unknown type 6
This can be quite frustrating for a kernel developer trying to see
what is going wrong.
There's no reason to register them so late in the boot up process.
They can be registered by early_initcall().
Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
register_ftrace_function() checks ftrace_disabled and calls
__register_ftrace_function which does it again.
Drop the first check and add the unlikely hint to the second one. Also,
drop the label as John correctly notices.
No functional change.
Link: http://lkml.kernel.org/r/20120329171140.GE6409@aftab
Cc: Borislav Petkov <bp@amd64.org>
Cc: John Kacur <jkacur@redhat.com>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Dave Jones reported a kernel BUG at mm/slub.c:3474! triggered
by splice_shrink_spd() called from vmsplice_to_pipe()
commit 35f3d14dbbc5 (pipe: add support for shrinking and growing pipes)
added capability to adjust pipe->buffers.
Problem is some paths don't hold pipe mutex and assume pipe->buffers
doesn't change for their duration.
Fix this by adding nr_pages_max field in struct splice_pipe_desc, and
use it in place of pipe->buffers where appropriate.
splice_shrink_spd() loses its struct pipe_inode_info argument.
Cc: Tom Herbert <therbert@google.com>
Cc: stable <stable@vger.kernel.org> # 2.6.35
Tested-by: Dave Jones <davej@redhat.com>
A recent update to have tracing_on/off() only affect the ftrace ring
buffers instead of all ring buffers had a cut and paste error.
The tracing_off() did the exact same thing as tracing_on() and
would not actually turn off tracing. Unfortunately, tracing_off()
is more important to be working than tracing_on() as this is a key
development tool, as it lets the developer turn off tracing as soon
as a problem is discovered. It is also used by panic and oops code.
This bug also breaks the 'echo func:traceoff > set_ftrace_filter'
Cc: <stable@vger.kernel.org> # 3.4
Pull perf updates from Ingo Molnar.
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits)
perf ui browser: Stop using 'self'
perf annotate browser: Read perf config file for settings
perf config: Allow '_' in config file variable names
perf annotate browser: Make feature toggles global
perf annotate browser: The idx_asm field should be used in asm only view
perf tools: Convert critical messages to ui__error()
perf ui: Make --stdio default when TUI is not supported
tools lib traceevent: Silence compiler warning on 32bit build
perf record: Fix branch_stack type in perf_record_opts
perf tools: Reconstruct event with modifiers from perf_event_attr
perf top: Fix counter name fixup when fallbacking to cpu-clock
perf tools: fix thread_map__new_by_pid_str() memory leak in error path
perf tools: Do not use _FORTIFY_SOURCE when DEBUG=1 is specified
tools lib traceevent: Fix signature of create_arg_item()
tools lib traceevent: Use proper function parameter type
tools lib traceevent: Fix freeing arg on process_dynamic_array()
tools lib traceevent: Fix a possibly wrong memory dereference
tools lib traceevent: Fix a possible memory leak
tools lib traceevent: Allow expressions in __print_symbolic() fields
perf evlist: Explicititely initialize input_name
Pull user-space probe instrumentation from Ingo Molnar:
"The uprobes code originates from SystemTap and has been used for years
in Fedora and RHEL kernels. This version is much rewritten, reviews
from PeterZ, Oleg and myself shaped the end result.
This tree includes uprobes support in 'perf probe' - but SystemTap
(and other tools) can take advantage of user probe points as well.
Sample usage of uprobes via perf, for example to profile malloc()
calls without modifying user-space binaries.
First boot a new kernel with CONFIG_UPROBE_EVENT=y enabled.
If you don't know which function you want to probe you can pick one
from 'perf top' or can get a list all functions that can be probed
within libc (binaries can be specified as well):
$ perf probe -F -x /lib/libc.so.6
To probe libc's malloc():
$ perf probe -x /lib64/libc.so.6 malloc
Added new event:
probe_libc:malloc (on 0x7eac0)
You can now use it in all perf tools, such as:
perf record -e probe_libc:malloc -aR sleep 1
Make use of it to create a call graph (as the flat profile is going to
look very boring):
$ perf record -e probe_libc:malloc -gR make
[ perf record: Woken up 173 times to write data ]
[ perf record: Captured and wrote 44.190 MB perf.data (~1930712
$ perf report | less
32.03% git libc-2.15.so [.] malloc
--- malloc
29.49% cc1 libc-2.15.so [.] malloc
--- malloc
|--0.95%-- 0x208eb1000000000
|--0.63%-- htab_traverse_noresize
11.04% as libc-2.15.so [.] malloc
--- malloc
7.15% ld libc-2.15.so [.] malloc
--- malloc
5.07% sh libc-2.15.so [.] malloc
--- malloc
4.99% python-config libc-2.15.so [.] malloc
--- malloc
4.54% make libc-2.15.so [.] malloc
--- malloc
|--7.34%-- glob
| |--93.18%-- 0x41588f
| --6.82%-- glob
| 0x41588f
Or:
$ perf report -g flat | less
# Overhead Command Shared Object Symbol
27.19%
malloc
24.77%
malloc
11.02%
malloc
6.57%
malloc
The core uprobes design is fairly straightforward: uprobes probe
points register themselves at (inode:offset) addresses of
libraries/binaries, after which all existing (or new) vmas that map
that address will have a software breakpoint injected at that address.
vmas are COW-ed to preserve original content. The probe points are
kept in an rbtree.
If user-space executes the probed inode:offset instruction address
then an event is generated which can be recovered from the regular
perf event channels and mmap-ed ring-buffer.
Multiple probes at the same address are supported, they create a
dynamic callback list of event consumers.
The basic model is further complicated by the XOL speedup: the
original instruction that is probed is copied (in an architecture
specific fashion) and executed out of line when the probe triggers.
The XOL area is a single vma per process, with a fixed number of
entries (which limits probe execution parallelism).
The API: uprobes are installed/removed via
/sys/kernel/debug/tracing/uprobe_events, the API is integrated to
align with the kprobes interface as much as possible, but is separate
to it.
Injecting a probe point is privileged operation, which can be relaxed
by setting perf_paranoid to -1.
You can use multiple probes as well and mix them with kprobes and
regular PMU events or tracepoints, when instrumenting a task."
Fix up trivial conflicts in mm/memory.c due to previous cleanup of
unmap_single_vma().
* 'perf-uprobes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits)
perf probe: Detect probe target when m/x options are absent
perf probe: Provide perf interface for uprobes
tracing: Fix kconfig warning due to a typo
tracing: Provide trace events interface for uprobes
tracing: Extract out common code for kprobes/uprobes trace events
tracing: Modify is_delete, is_return from int to bool
uprobes/core: Decrement uprobe count before the pages are unmapped
uprobes/core: Make background page replacement logic account for rss_stat counters
uprobes/core: Optimize probe hits with the help of a counter
uprobes/core: Allocate XOL slots for uprobes use
uprobes/core: Handle breakpoint and singlestep exceptions
uprobes/core: Rename bkpt to swbp
uprobes/core: Make order of function parameters consistent across functions
uprobes/core: Make macro names consistent
uprobes: Update copyright notices
uprobes/core: Move insn to arch specific structure
uprobes/core: Remove uprobe_opcode_sz
uprobes/core: Make instruction tables volatile
uprobes: Move to kernel/events/
uprobes/core: Clean up, refactor and improve the code
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/urgent
Pull an ftrace ring-buffer fix from Steve Rostedt:
* fix kernel crash when changing the size of the ring-buffer on
boxes where possible_cpus != online_cpus.
On some machines the number of possible CPUS is not the same as the
number of CPUs that is on the machine. Ftrace uses possible_cpus to
update the tracing structures but the ring buffer only allocates
per cpu buffers for online CPUs when they come up.
When the wakeup tracer was enabled in such a case, the ftrace code
enabled all possible cpu buffers, but the code in ring_buffer_resize()
did not check to see if the buffer in question was allocated. Since
boot up CPUs did not match possible CPUs it caused the following
crash:
BUG: unable to handle kernel NULL pointer dereference at 00000020
IP: [<c1097851>] ring_buffer_resize+0x16a/0x28d
*pde = 00000000
Oops: 0000 [#1] PREEMPT SMP
(ftrace buffer empty)
Modules linked in: [last unloaded: scsi_wait_scan]
Pid: 1387, comm: bash Not tainted 3.4.0-test+ #13 /DG965MQ
EIP: 0060:[<c1097851>] EFLAGS: 00010217 CPU: 0
EIP is at ring_buffer_resize+0x16a/0x28d
EAX: f5a14340 EBX: f6026b80 ECX: 00000ff4 EDX: 00000ff3
ESI: 00000000 EDI: 00000002 EBP: f4275ecc ESP: f4275eb0
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
CR0: 80050033 CR2: 00000020 CR3: 34396000 CR4: 000007d0
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: ffff0ff0 DR7: 00000400
Process bash (pid: 1387, ti=f4274000 task=f4380cb0 task.ti=f4274000)
Stack:
c109cf9a f6026b98 00000162 00160f68 00000006 00160f68 00000002 f4275ef0
c109d013 f4275ee8 c123b72a c1c0bf00 c1cc81dc 00000005 f4275f98 00000007
f4275f70 c109d0c7 7700000e 75656b61 00000070 f5e90900 f5c4e198 00000301
Call Trace:
[<c109cf9a>] ? tracing_set_tracer+0x115/0x1e9
[<c109d013>] tracing_set_tracer+0x18e/0x1e9
[<c123b72a>] ? _copy_from_user+0x30/0x46
[<c109d0c7>] tracing_set_trace_write+0x59/0x7f
[<c10ec01e>] ? fput+0x18/0x1c6
[<c11f8732>] ? security_file_permission+0x27/0x2b
[<c10eaacd>] ? rw_verify_area+0xcf/0xf2
[<c109d06e>] ? tracing_set_tracer+0x1e9/0x1e9
[<c10ead77>] vfs_write+0x8b/0xe3
[<c10ebead>] ? fget_light+0x30/0x81
[<c10eaf54>] sys_write+0x42/0x63
[<c1834fbf>] sysenter_do_call+0x12/0x28
This happens with the latency tracer as the ftrace code updates the
saved max buffer via its cpumask and not with a global setting.
Adding a check in ring_buffer_resize() to make sure the buffer being resized
exists, fixes the problem.
Cc: Vaibhav Nagarnaik <vnagarnaik@google.com>
Pull trivial updates from Jiri Kosina:
"As usual, it's mostly typo fixes, redundant code elimination and some
documentation updates."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits)
edac, mips: don't change code that has been removed in edac/mips tree
xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer
lib: Change mail address of Oskar Schirmer
net: Change mail address of Oskar Schirmer
arm/m68k: Change mail address of Sebastian Hess
i2c: Change mail address of Oskar Schirmer
net: Fix tcp_build_and_update_options comment in struct tcp_sock
atomic64_32.h: fix parameter naming mismatch
Kconfig: replace "--- help ---" with "---help---"
c2port: fix bogus Kconfig "default no"
edac: Fix spelling errors.
qla1280: Remove redundant NULL check before release_firmware() call
remoteproc: remove redundant NULL check before release_firmware()
qla2xxx: Remove redundant NULL check before release_firmware() call.
aic94xx: Get rid of redundant NULL check before release_firmware() call
tehuti: delete redundant NULL check before release_firmware()
qlogic: get rid of a redundant test for NULL before call to release_firmware()
bna: remove redundant NULL test before release_firmware()
tg3: remove redundant NULL test before release_firmware() call
typhoon: get rid of redundant conditional before all to release_firmware()
Pull perf changes from Ingo Molnar:
"Lots of changes:
- (much) improved assembly annotation support in perf report, with
jump visualization, searching, navigation, visual output
improvements and more.
- kernel support for AMD IBS PMU hardware features. Notably 'perf
record -e cycles:p' and 'perf top -e cycles:p' should work without
skid now, like PEBS does on the Intel side, because it takes
advantage of IBS transparently.
- the libtracevents library: it is the first step towards unifying
tracing tooling and perf, and it also gives a tracing library for
external tools like powertop to rely on.
- infrastructure: various improvements and refactoring of the UI
modules and related code
- infrastructure: cleanup and simplification of the profiling
targets code (--uid, --pid, --tid, --cpu, --all-cpus, etc.)
- tons of robustness fixes all around
- various ftrace updates: speedups, cleanups, robustness
improvements.
- typing 'make' in tools/ will now give you a menu of projects to
build and a short help text to explain what each does.
- ... and lots of other changes I forgot to list.
The perf record make bzImage + perf report regression you reported
should be fixed."
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (166 commits)
tracing: Remove kernel_lock annotations
tracing: Fix initial buffer_size_kb state
ring-buffer: Merge separate resize loops
perf evsel: Create events initially disabled -- again
perf tools: Split term type into value type and term type
perf hists: Fix callchain ip printf format
perf target: Add uses_mmap field
ftrace: Remove selecting FRAME_POINTER with FUNCTION_TRACER
ftrace/x86: Have x86 ftrace use the ftrace_modify_all_code()
ftrace: Make ftrace_modify_all_code() global for archs to use
ftrace: Return record ip addr for ftrace_location()
ftrace: Consolidate ftrace_location() and ftrace_text_reserved()
ftrace: Speed up search by skipping pages by address
ftrace: Remove extra helper functions
ftrace: Sort all function addresses, not just per page
tracing: change CPU ring buffer state from tracing_cpumask
tracing: Check return value of tracing_dentry_percpu()
ring-buffer: Reset head page before running self test
ring-buffer: Add integrity check at end of iter read
ring-buffer: Make addition of pages in ring buffer atomic
Pull workqueue changes from Tejun Heo:
"Nothing exciting. Most are updates to debug stuff and related fixes.
Two not-too-critical bugs are fixed - WARN_ON() triggering spurious
during cpu offlining and unlikely lockdep related oops."
* 'for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
lockdep: fix oops in processing workqueue
workqueue: skip nr_running sanity check in worker_enter_idle() if trustee is active
workqueue: Catch more locking problems with flush_work()
workqueue: change BUG_ON() to WARN_ON()
trace: Remove unused workqueue tracer
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/core
Fixes for perf/core:
- Rename some perf_target methods to avoid double negation, from Namhyung Kim.
- Revert change to use per task events with inheritance, from Namhyung Kim.
- Events should start disabled till children starts running, from David Ahern.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
The BKL is gone, these annotations are useless.
Link: http://lkml.kernel.org/r/1320654202-4433-1-git-send-email-richard@nod.at
Signed-off-by: Richard Weinberger <richard@nod.at>
Make sure that the state of buffer_size_kb is initialized correctly and
returns actual size of the ring buffer.
Link: http://lkml.kernel.org/r/1336066834-1673-1-git-send-email-vnagarnaik@google.com
Cc: Laurent Chavey <chavey@google.com>
There are 2 separate loops to resize cpu buffers that are online and
offline. Merge them to make the code look better.
Also change the name from update_completion to update_done to allow
shorter lines.
Link: http://lkml.kernel.org/r/1337372991-14783-1-git-send-email-vnagarnaik@google.com
Merge reason: We are going to queue up a dependent patch:
"perf tools: Move parse event automated tests to separated object"
That depends on:
commit e7c72d8
perf tools: Add 'G' and 'H' modifiers to event parsing
tools/perf/builtin-stat.c
Conflicted with the recent 'perf_target' patches when checking the
result of perf_evsel open routines to see if a retry is needed to cope
with older kernels where the exclude guest/host perf_event_attr bits
were not used.
The function tracer will enable the -pg option with gcc, which requires
that frame pointers. When FRAME_POINTER is defined in the kernel config
it adds the gcc option -fno-omit-frame-pointer which causes some problems
on some architectures. For those architectures, the FRAME_POINTER select
was not set.
When FUNCTION_TRACER was selected on these architectures that can not have
-fno-omit-frame-pointer, the -pg option is still set. But when
FRAME_POINTER is not selected, the kernel config would add the gcc option
-fomit-frame-pointer. Adding this option is incompatible with -pg
even on archs that do not need frame pointers with -pg.
The answer to this was to just not add either -fno-omit-frame-pointer
or -fomit-frame-pointer on these archs that want function tracing
but do not set FRAME_POINTER.
As it turns out, for archs that require frame pointers for function
tracing, the same can be used. If gcc requires frame pointers with
-pg, it will simply add it. The best thing to do is not select FRAME_POINTER
when function tracing is selected, and let gcc add it if needed.
Only add the -fno-omit-frame-pointer when something else selects
FRAME_POINTER, but do not add -fomit-frame-pointer if function tracing
is selected.
To remove duplicate code, have the ftrace arch_ftrace_update_code()
use the generic ftrace_modify_all_code(). This requires that the
default ftrace_replace_code() becomes a weak function so that an
arch may override it.
Rename __ftrace_modify_code() to ftrace_modify_all_code() and make
it global for all archs to use. This will remove the duplication
of code, as archs that can modify code without stop_machine()
can use it directly outside of the stop_machine() call.
ftrace_location() is passed an addr, and returns 1 if the addr is
on a ftrace nop (or caller to ftrace_caller), and 0 otherwise.
To let kprobes know if it should move a breakpoint or not, it
must return the actual addr that is the start of the ftrace nop.
This way a kprobe placed on the location of a ftrace nop, can
instead be placed on the instruction after the nop. Even if the
probe addr is on the second or later byte of the nop, it can
simply be moved forward.
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Both ftrace_location() and ftrace_text_reserved() do basically the same thing.
They search to see if an address is in the ftace table (contains an address
that may change from nop to call ftrace_caller). The difference is
that ftrace_location() searches a single address, but ftrace_text_reserved()
searches a range.
This also makes the ftrace_text_reserved() faster as it now uses a bsearch()
instead of linearly searching all the addresses within a page.
As all records in a page of the ftrace table are sorted, we can
speed up the search algorithm by checking if the address to look for
falls in between the first and last record ip on the page.
This speeds up both the ftrace_location() and ftrace_text_reserved()
algorithms, as it can skip full pages when the search address is
not in them.
The ftrace_record_ip() and ftrace_alloc_dyn_node() were from the
time of the ftrace daemon. Although they were still used, they
still make things a bit more complex than necessary.
Move the code into the one function that uses it, and remove the
helper functions.
Instead of just sorting the ip's of the functions per ftrace page,
sort the entire list before adding them to the ftrace pages.
This will allow the bsearch algorithm to be sped up as it can
also sort by pages, not just records within a page.
According to Documentation/trace/ftrace.txt:
tracing_cpumask:
This is a mask that lets the user only trace
on specified CPUS. The format is a hex string
representing the CPUS.
The tracing_cpumask currently doesn't affect the tracing state of
per-CPU ring buffers.
This patch enables/disables CPU recording as its corresponding bit in
tracing_cpumask is set/unset.
Link: http://lkml.kernel.org/r/1336096792-25373-3-git-send-email-vnagarnaik@google.com
If tracing_dentry_percpu() failed, tracing_init_debugfs_percpu()
will try to create each cpu directories on debugfs' root directory
as d_percpu is NULL.
Link: http://lkml.kernel.org/r/1335143517-2285-1-git-send-email-namhyung.kim@lge.com
Signed-off-by: Namhyung Kim <namhyung.kim@lge.com>
When the ring buffer does its consistency test on itself, it
removes the head page, runs the tests, and then adds it back
to what the "head_page" pointer was. But because the head_page
pointer may lack behind the real head page (held by the link
list pointer). The reset may be incorrect.
Instead, if the head_page exists (it does not on first allocation)
reset it back to the real head page before running the consistency
tests. Then it will be put back to its original location after
the tests are complete.
There use to be ring buffer integrity checks after updating the
size of the ring buffer. But now that the ring buffer can modify
the size while the system is running, the integrity checks were
removed, as they require the ring buffer to be disabed to perform
the check.
Move the integrity check to the reading of the ring buffer via the
iterator reads (the "trace" file). As reading via an iterator requires
disabling the ring buffer, it is a perfect place to have it.
If the ring buffer happens to be disabled when updating the size,
we still perform the integrity check.
This patch adds the capability to add new pages to a ring buffer
atomically while write operations are going on. This makes it possible
to expand the ring buffer size without reinitializing the ring buffer.
The new pages are attached between the head page and its previous page.
Link: http://lkml.kernel.org/r/1336096792-25373-2-git-send-email-vnagarnaik@google.com
This patch adds the capability to remove pages from a ring buffer
without destroying any existing data in it.
This is done by removing the pages after the tail page. This makes sure
that first all the empty pages in the ring buffer are removed. If the
head page is one in the list of pages to be removed, then the page after
the removed ones is made the head page. This removes the oldest data
from the ring buffer and keeps the latest data around to be read.
To do this in a non-racey manner, tracing is stopped for a very short
time while the pages to be removed are identified and unlinked from the
ring buffer. The pages are freed after the tracing is restarted to
minimize the time needed to stop tracing.
The context in which the pages from the per-cpu ring buffer are removed
runs on the respective CPU. This minimizes the events not traced to only
NMI trace contexts.
Link: http://lkml.kernel.org/r/1336096792-25373-1-git-send-email-vnagarnaik@google.com
On gcc 4.5 the function tracing_mark_write() would give a warning
of page2 being uninitialized. This is due to a bug in gcc because
the logic prevents page2 from being used uninitialized, and
gcc 4.6+ does not complain (correctly).
Instead of adding a "unitialized" around page2, which could show
a bug later on, I combined page1 and page2 into an array map_pages[].
This binds the two and the two are modified according to nr_pages
(what gcc 4.5 seems to ignore). This no longer gives a warning with
gcc 4.5 nor with gcc 4.6.
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/uprobes
With the adding of function tracing event to perf, it caused a
side effect that produces the following warning when enabling all
events in ftrace:
# echo 1 > /sys/kernel/debug/tracing/events/enable
[console]
event trace: Could not enable event function
This is because when enabling all events via the debugfs system
it ignores events that do not have a ->reg() function assigned.
This was to skip over the ftrace internal events (as they are
not TRACE_EVENTs). But as the ftrace function event now has
a ->reg() function attached to it for use with perf, it is no
longer ignored.
Worse yet, this ->reg() function is being called when it should
not be. It returns an error and causes the above warning to
be printed.
By adding a new event_call flag (TRACE_EVENT_FL_IGNORE_ENABLE)
and have all ftrace internel event structures have it set,
setting the events/enable will no longe try to incorrectly enable
the function event and does not warn.
The ftrace_disable_cpu() and ftrace_enable_cpu() functions were
needed back before the ring buffer was lockless. Now that the
ring buffer is lockless (and has been for some time), these functions
serve no purpose, and unnecessarily slow down operations of the tracer.
It's appropriate to use __seq_open_private interface to open
some of trace seq files, because it covers all steps we are
duplicating in tracing code - zallocating the iterator and
setting it as seq_file's private.
Using this for following files:
trace
available_filter_functions
enabled_functions
Link: http://lkml.kernel.org/r/1335342219-2782-5-git-send-email-jolsa@redhat.com
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Fixed warnings for:
kernel/trace/trace.c: In function '__tracing_open':
kernel/trace/trace.c:2418:11: warning: unused variable 'ret' [-Wunused-variable]
kernel/trace/trace.c:2417:19: warning: unused variable 'm' [-Wunused-variable]
