path: root/kernel/trace/trace_hw_branches.c
2010-03-26x86, perf, bts, mm: Delete the never used BTS-ptrace codePeter Zijlstra
Support for the PMU's BTS features has been upstreamed in v2.6.32, but we still have the old and disabled ptrace-BTS, as Linus noticed it not so long ago. It's buggy: TIF_DEBUGCTLMSR is trampling all over that MSR without regard for other uses (perf) and doesn't provide the flexibility needed for perf either. Its users are ptrace-block-step and ptrace-bts, since ptrace-bts was never used and ptrace-block-step can be implemented using a much simpler approach. So axe all 3000 lines of it. That includes the *locked_memory*() APIs in mm/mlock.c as well. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Markus Metzger <markus.t.metzger@intel.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <20100325135413.938004390@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits) m68k: rename global variable vmalloc_end to m68k_vmalloc_end percpu: add missing per_cpu_ptr_to_phys() definition for UP percpu: Fix kdump failure if booted with percpu_alloc=page percpu: make misc percpu symbols unique percpu: make percpu symbols in ia64 unique percpu: make percpu symbols in powerpc unique percpu: make percpu symbols in x86 unique percpu: make percpu symbols in xen unique percpu: make percpu symbols in cpufreq unique percpu: make percpu symbols in oprofile unique percpu: make percpu symbols in tracer unique percpu: make percpu symbols under kernel/ and mm/ unique percpu: remove some sparse warnings percpu: make alloc_percpu() handle array types vmalloc: fix use of non-existent percpu variable in put_cpu_var() this_cpu: Use this_cpu_xx in trace_functions_graph.c this_cpu: Use this_cpu_xx for ftrace this_cpu: Use this_cpu_xx in nmi handling this_cpu: Use this_cpu operations in RCU this_cpu: Use this_cpu ops for VM statistics ... Fix up trivial (famous last words) global per-cpu naming conflicts in arch/x86/kvm/svm.c mm/slab.c
2009-10-29percpu: make percpu symbols in tracer uniqueTejun Heo
This patch updates percpu related symbols in kernel tracer such that percpu symbols are unique and don't clash with local symbols. This serves two purposes of decreasing the possibility of global percpu symbol collision and allowing dropping per_cpu__ prefix from percpu symbols. * kernel/trace/trace.c: s/max_data/max_tr_data/ * kernel/trace/trace_hw_branches: s/tracer/hwb_tracer/, s/buffer/hwb_buffer/ Partly based on Rusty Russell's "alloc_percpu: rename percpu vars which cause name clashes" patch. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com>
2009-10-07tracing: fix warning on kernel/trace/trace_branch.c andtrace_hw_branches.cZhenwen Xu
fix warnings that caused the API change of trace_buffer_lock_reserve() change files: kernel/trace/trace_hw_branch.c kernel/trace/trace_branch.c Signed-off-by: Zhenwen Xu <helight.xu@gmail.com> LKML-Reference: <20091008012146.GA4170@helight> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-21trivial: remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-05-07Merge branch 'tracing/hw-branch-tracing' into tracing/coreIngo Molnar
Merge reason: this topic is ready for upstream now. It passed Oleg's review and Andrew had no further mm/* objections/observations either. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14tracing/filters: use ring_buffer_discard_commit() in filter_check_discard()Tom Zanussi
This patch changes filter_check_discard() to make use of the new ring_buffer_discard_commit() function and modifies the current users to call the old commit function in the non-discard case. It also introduces a version of filter_check_discard() that uses the global trace buffer (filter_current_check_discard()) for those cases. v2 changes: - fix compile error noticed by Ingo Molnar Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: fweisbec@gmail.com LKML-Reference: <1239178554.10295.36.camel@tropicana> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14tracing/filters: add run-time field descriptions to TRACE_EVENT_FORMAT eventsTom Zanussi
This patch adds run-time field descriptions to all the event formats exported using TRACE_EVENT_FORMAT. It also hooks up all the tracers that use them (i.e. the tracers in the 'ftrace subsystem') so they can also have their output filtered by the event-filtering mechanism. When I was testing this, there were a couple of things that fooled me into thinking the filters weren't working, when actually they were - I'll mention them here so others don't make the same mistakes (and file bug reports. ;-) One is that some of the tracers trace multiple events e.g. the sched_switch tracer uses the context_switch and wakeup events, and if you don't set filters on all of the traced events, the unfiltered output from the events without filters on them can make it look like the filtering as a whole isn't working properly, when actually it is doing what it was asked to do - it just wasn't asked to do the right thing. The other is that for the really high-volume tracers e.g. the function tracer, the volume of filtered events can be so high that it pushes the unfiltered events out of the ring buffer before they can be read so e.g. cat'ing the trace file repeatedly shows either no output, or once in awhile some output but that isn't there the next time you read the trace, which isn't what you normally expect when reading the trace file. If you read from the trace_pipe file though, you can catch them before they disappear. Changes from v1: As suggested by Frederic Weisbecker: - get rid of externs in functions - added unlikely() to filter_check_discard() Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-07x86, bts, hw-branch-tracer: add _noirq variants to the debug store interfaceMarkus Metzger
The hw-branch-tracer uses debug store functions from an on_each_cpu() context, which is simply wrong since the functions may sleep. Add _noirq variants for most functions, which may be called with interrupts disabled. Separate per-cpu and per-task tracing and allow per-cpu tracing to be controlled from any cpu. Make the hw-branch-tracer use the new debug store interface, synchronize with hotplug cpu event using get/put_online_cpus(), and remove the unnecessary spinlock. Make the ptrace bts and the ds selftest code use the new interface. Defer the ds selftest. Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Cc: roland@redhat.com Cc: eranian@googlemail.com Cc: oleg@redhat.com Cc: juan.villacis@intel.com Cc: ak@linux.jf.intel.com LKML-Reference: <20090403144555.658136000@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13x86, bts: cleanupsIngo Molnar
Impact: cleanup, no code changed Cc: Markus Metzger <markus.t.metzger@intel.com> LKML-Reference: <20090313104218.A30096@sedona.ch.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13x86, hw-branch-tracer: add selftestMarkus Metzger
Add a selftest for the hw-branch-tracer. Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> LKML-Reference: <20090313105027.A30183@sedona.ch.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13x86, hw-branch-tracer: keep resources on stopMarkus Metzger
Distinguish init/reset and start/stop: init/reset will allocate and release bts tracing resources stop/start will suspend and resume bts tracing Return an error on init() if no cpu can be traced. Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> LKML-Reference: <20090313104852.A30168@sedona.ch.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-25tracing/hw-branch-tracing: convert bts-tracer mutex to a spinlockIngo Molnar
Impact: fix CPU hotplug lockup bts_hotcpu_handler() is called with irqs disabled, so using mutex_lock() is a no-no. All the BTS codepaths here are atomic (they do not schedule), so using a spinlock is the right solution. Cc: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-24x86, ftrace: fix section mismatch in hw-branch-tracerMarkus Metzger
Fix an invalid memory reference problem when cpu hotplug support is disabled and the hw-branch-tracer is set as current tracer. Initializing the tracer calls bts_trace_init() which has already been freed at this time. Reported-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-15tracing: fix section mismatch in trace_hw_branches.cRakib Mullick
The function bts_trace_init() references a variable bts_hotcpu_notifier which is marked as __cpuinitdata. Thus causes section mismatch. This patch fixes it. LD kernel/trace/built-in.o WARNING: kernel/trace/built-in.o(.text+0xc90c): Section mismatch in reference from the function bts_trace_init() to the variable .cpuinit.data:bts_hotcpu_notifier The function bts_trace_init() references the variable __cpuinitdata bts_hotcpu_notifier. This is often because bts_trace_init lacks a __cpuinitdata annotation or the annotation of bts_hotcpu_notifier is wrong. WARNING: kernel/trace/built-in.o(.text+0xc92a): Section mismatch in reference from the function bts_trace_reset() to the variable .cpuinit.data:bts_hotcpu_notifier The function bts_trace_reset() references the variable __cpuinitdata bts_hotcpu_notifier. This is often because bts_trace_reset lacks a __cpuinitdata annotation or the annotation of bts_hotcpu_notifier is wrong. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Cc: markus.t.metzger@gmail.com Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-10tracing: fix typos in commentsWenji Huang
Impact: clean up. Fix typos in the comments. Signed-off-by: Wenji Huang <wenji.huang@oracle.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-09Merge branch 'tip/tracing/core/devel' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into tracing/ftrace Conflicts: kernel/trace/trace_hw_branches.c
2009-02-07trace: remove deprecated entry->cpuSteven Rostedt
Impact: fix to prevent developers from using entry->cpu With the new ring buffer infrastructure, the cpu for the entry is implicit with which CPU buffer it is on. The original code use to record the current cpu into the generic entry header, which can be retrieved by entry->cpu. When the ring buffer was introduced, the users were convert to use the the cpu number of which cpu ring buffer was in use (this was passed to the tracers by the iterator: iter->cpu). Unfortunately, the cpu item in the entry structure was never removed. This allowed for developers to use it instead of the proper iter->cpu, unknowingly, using an uninitialized variable. This was not the fault of the developers, since it would seem like the logical place to retrieve the cpu identifier. This patch removes the cpu item from the entry structure and fixes all the users that should have been using iter->cpu. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-06trace: Call tracing_reset_online_cpus before tracer->init()Arnaldo Carvalho de Melo
Impact: cleanup To make it easy for ftrace plugin writers, as this was open coded in the existing plugins Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Frédéric Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-06tracing: Introduce trace_buffer_{lock_reserve,unlock_commit}Arnaldo Carvalho de Melo
Impact: new API These new functions do what previously was being open coded, reducing the number of details ftrace plugin writers have to worry about. It also standardizes the handling of stacktrace, userstacktrace and other trace options we may introduce in the future. With this patch, for instance, the blk tracer (and some others already in the tree) can use the "userstacktrace" /d/tracing/trace_options facility. $ codiff /tmp/vmlinux.before /tmp/vmlinux.after linux-2.6-tip/kernel/trace/trace.c: trace_vprintk | -5 trace_graph_return | -22 trace_graph_entry | -26 trace_function | -45 __ftrace_trace_stack | -27 ftrace_trace_userstack | -29 tracing_sched_switch_trace | -66 tracing_stop | +1 trace_seq_to_user | -1 ftrace_trace_special | -63 ftrace_special | +1 tracing_sched_wakeup_trace | -70 tracing_reset_online_cpus | -1 13 functions changed, 2 bytes added, 355 bytes removed, diff: -353 linux-2.6-tip/block/blktrace.c: __blk_add_trace | -58 1 function changed, 58 bytes removed, diff: -58 linux-2.6-tip/kernel/trace/trace.c: trace_buffer_lock_reserve | +88 trace_buffer_unlock_commit | +86 2 functions changed, 174 bytes added, diff: +174 /tmp/vmlinux.after: 16 functions changed, 176 bytes added, 413 bytes removed, diff: -237 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Frédéric Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-06ring_buffer: remove unused flags parameterArnaldo Carvalho de Melo
Impact: API change, cleanup >From ring_buffer_{lock_reserve,unlock_commit}. $ codiff /tmp/vmlinux.before /tmp/vmlinux.after linux-2.6-tip/kernel/trace/trace.c: trace_vprintk | -14 trace_graph_return | -14 trace_graph_entry | -10 trace_function | -8 __ftrace_trace_stack | -8 ftrace_trace_userstack | -8 tracing_sched_switch_trace | -8 ftrace_trace_special | -12 tracing_sched_wakeup_trace | -8 9 functions changed, 90 bytes removed, diff: -90 linux-2.6-tip/block/blktrace.c: __blk_add_trace | -1 1 function changed, 1 bytes removed, diff: -1 /tmp/vmlinux.after: 10 functions changed, 91 bytes removed, diff: -91 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Frédéric Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-20x86, ftrace, hw-branch-tracer: change trace formatMarkus Metzger
Change the hw-branch-tracer format to be more readable. Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-20x86, ftrace, hw-branch-tracer: reset trace buffer on closeMarkus Metzger
Reset the ftrace buffer on close. Since we use cyclic buffers, the trace is not contiguous, anyway. Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-20x86, ftrace, hw-branch-tracer: dump trace on oopsMarkus Metzger
Dump the branch trace on an oops (based on ftrace_dump_on_oops). Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-20x86, ftrace, hw-branch-tracer: support hotplug cpusMarkus Metzger
Support hotplug cpus. Reported-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06Merge branches 'tracing/kmemtrace2' and 'tracing/ftrace' into tracing/urgentIngo Molnar
2009-01-01cpumask: convert kernel trace functions furtherRusty Russell
Impact: Reduce future memory usage, use new cpumask API. Since the last patch was created and acked, more old cpumask users slipped into kernel/trace. Mostly trivial conversions, except struct trace_iterator's "started" member becomes a cpumask_var_t. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-12-29ftrace: set up trace event hash infrastructureSteven Rostedt
Impact: simplify/generalize/refactor trace.c The trace.c file is becoming more difficult to maintain due to the growing number of events. There is several formats that an event may be printed. This patch sets up the infrastructure of an event hash to allow for events to register how they should be printed. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-19ftrace: introduce tracing_reset_online_cpus() helperPekka J Enberg
Impact: cleanup This patch factors out common code from multiple tracers into a tracing_reset_online_cpus() function and converts the tracers to use it. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-12x86, bts, ftrace: adapt the hw-branch-tracer to the ds.c interfaceMarkus Metzger
Impact: restructure code, cleanup Remove BTS bits from the hw-branch-tracer (renamed from bts-tracer) and use the ds interface. Signed-off-by: Markus Metzger <markut.t.metzger@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
