commit 54f7be5b831254199522523ccab4c3d954bbf576 upstream.
The function rb_set_head_page() searches the list of ring buffer
pages for a the page that has the HEAD page flag set. If it does
not find it, it will do a WARN_ON(), disable the ring buffer and
return NULL, as this should never happen.
But if this bug happens to happen, not all callers of this function
can handle a NULL pointer being returned from it. That needs to be
fixed.
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (121 commits)
perf symbols: Increase symbol KSYM_NAME_LEN size
perf hists browser: Refuse 'a' hotkey on non symbolic views
perf ui browser: Use libslang to read keys
perf tools: Fix tracing info recording
perf hists browser: Elide DSO column when it is set to just one DSO, ditto for threads
perf hists: Don't consider filtered entries when calculating column widths
perf hists: Don't decay total_period for filtered entries
perf hists browser: Honour symbol_conf.show_{nr_samples,total_period}
perf hists browser: Do not exit on tab key with single event
perf annotate browser: Don't change selection line when returning from callq
perf tools: handle endianness of feature bitmap
perf tools: Add prelink suggestion to dso update message
perf script: Fix unknown feature comment
perf hists browser: Apply the dso and thread filters when merging new batches
perf hists: Move the dso and thread filters from hist_browser
perf ui browser: Honour the xterm colors
perf top tui: Give color hints just on the percentage, like on --stdio
perf ui browser: Make the colors configurable and change the defaults
perf tui: Remove unneeded call to newtCls on startup
perf hists: Don't format the percentage on hist_entry__snprintf
Fix up conflicts in arch/x86/kernel/kprobes.c manually.
Ingo's tree did the insane "add volatile to const array", which just
doesn't make sense ("volatile const"?). But we could remove the const
*and* make the array volatile to make doubly sure that gcc doesn't
optimize it away..
Also fix up kernel/trace/ring_buffer.c non-data-conflicts manually: the
reader_lock has been turned into a raw lock by the core locking merge,
and there was a new user of it introduced in this perf core merge. Make
sure that new use also uses the raw accessor functions.
The tracing locks can be taken in atomic context and therefore
cannot be preempted on -rt - annotate it.
In mainline this change documents the low level nature of
the lock - otherwise there's no functional difference. Lockdep
and Sparse checking will work as usual.
The stats file under per_cpu folder provides the number of entries,
overruns and other statistics about the CPU ring buffer. However, the
numbers do not provide any indication of how full the ring buffer is in
bytes compared to the overall size in bytes. Also, it is helpful to know
the rate at which the cpu buffer is filling up.
This patch adds an entry "bytes: " in printed stats for per_cpu ring
buffer which provides the actual bytes consumed in the ring buffer. This
field includes the number of bytes used by recorded events and the
padding bytes added when moving the tail pointer to next page.
It also adds the following time stamps:
"oldest event ts:" - the oldest timestamp in the ring buffer
"now ts:" - the timestamp at the time of reading
The field "now ts" provides a consistent time snapshot to the userspace
when being read. This is read from the same trace clock used by tracing
event timestamps.
Together, these values provide the rate at which the buffer is filling
up, from the formula:
bytes / (now_ts - oldest_event_ts)
Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com>
Cc: Michael Rubin <mrubin@google.com>
Cc: David Sharp <dhsharp@google.com>
Link: http://lkml.kernel.org/r/1313531179-9323-3-git-send-email-vnagarnaik@google.com
The tracing ring buffer is allocated from kernel memory. While
allocating a large chunk of memory, OOM might happen which destabilizes
the system. Thus random processes might get killed during the
allocation.
This patch adds __GFP_NORETRY flag to the ring buffer allocation calls
to make it fail more gracefully if the system will not be able to
complete the allocation request.
Acked-by: David Rientjes <rientjes@google.com>
Link: http://lkml.kernel.org/r/1307491302-9236-1-git-send-email-vnagarnaik@google.com
This patch replaces the code for getting an unsigned long from a
userspace buffer by a simple call to kstroul_from_user.
This makes it easier to read and less error prone.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Link: http://lkml.kernel.org/r/1307476707-14762-1-git-send-email-peterhuewe@gmx.de
The tracing ring buffer is a group of per-cpu ring buffers where
allocation and logging is done on a per-cpu basis. The events that are
generated on a particular CPU are logged in the corresponding buffer.
This is to provide wait-free writes between CPUs and good NUMA node
locality while accessing the ring buffer.
However, the allocation routines consider NUMA locality only for buffer
page metadata and not for the actual buffer page. This causes the pages
to be allocated on the NUMA node local to the CPU where the allocation
routine is running at the time.
This patch fixes the problem by using a NUMA node specific allocation
routine so that the pages are allocated from a NUMA node local to the
logging CPU.
I tested with the getuid_microbench from autotest. It is a simple binary
that calls getuid() in a loop and measures the average time for the
syscall to complete. The following command was used to test:
$ getuid_microbench 1000000
Compared the numbers found on kernel with and without this patch and
found that logging latency decreases by 30-50 ns/call.
tracing with non-NUMA allocation - 569 ns/call
tracing with NUMA allocation - 512 ns/call
Link: http://lkml.kernel.org/r/1304470602-20366-1-git-send-email-vnagarnaik@google.com
Witold reported a reboot caused by the selftests of the dynamic function
tracer. He sent me a config and I used ktest to do a config_bisect on it
(as my config did not cause the crash). It pointed out that the problem
config was CONFIG_PROVE_RCU.
What happened was that if multiple callbacks are attached to the
function tracer, we iterate a list of callbacks. Because the list is
managed by synchronize_sched() and preempt_disable, the access to the
pointers uses rcu_dereference_raw().
When PROVE_RCU is enabled, the rcu_dereference_raw() calls some
debugging functions, which happen to be traced. The tracing of the debug
function would then call rcu_dereference_raw() which would then call the
debug function and then... well you get the idea.
I first wrote two different patches to solve this bug.
1) add a __rcu_dereference_raw() that would not do any checks.
2) add notrace to the offending debug functions.
Both of these patches worked.
Talking with Paul McKenney on IRC, he suggested to add recursion
detection instead. This seemed to be a better solution, so I decided to
implement it. As the task_struct already has a trace_recursion to detect
recursion in the ring buffer, and that has a very small number it
allows, I decided to use that same variable to add flags that can detect
the recursion inside the infrastructure of the function tracer.
I plan to change it so that the task struct bit can be checked in
mcount, but as that requires changes to all archs, I will hold that off
to the next merge window.
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1306348063.1465.116.camel@gandalf.stny.rr.com
Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits)
doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore
Update cpuset info & webiste for cgroups
dcdbas: force SMI to happen when expected
arch/arm/Kconfig: remove one to many l's in the word.
asm-generic/user.h: Fix spelling in comment
drm: fix printk typo 'sracth'
Remove one to many n's in a word
Documentation/filesystems/romfs.txt: fixing link to genromfs
drivers:scsi Change printk typo initate -> initiate
serial, pch uart: Remove duplicate inclusion of linux/pci.h header
fs/eventpoll.c: fix spelling
mm: Fix out-of-date comments which refers non-existent functions
drm: Fix printk typo 'failled'
coh901318.c: Change initate to initiate.
mbox-db5500.c Change initate to initiate.
edac: correct i82975x error-info reported
edac: correct i82975x mci initialisation
edac: correct commented info
fs: update comments to point correct document
target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c
Trivial conflict in fs/eventpoll.c (spelling vs addition)
The "Delta way too big" warning might appear on a system with a
unstable shed clock right after the system is resumed and tracing
was enabled at time of suspend.
Since it's not realy a bug, and the unstable sched clock is working
fast and reliable otherwise, Steven suggested to keep using the
sched clock in any case and just to make note in the warning itself.
v2 changes:
- added #ifdef CONFIG_HAVE_UNSTABLE_SCHED_CLOCK
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
LKML-Reference: <20110218145219.GD2604@jolsa.brq.redhat.com>
Signed-off-by: David Sharp <dhsharp@google.com>
LKML-Reference: <1291421609-14665-3-git-send-email-dhsharp@google.com>
Add an "overwrite" trace_option for ftrace to control whether the buffer should
be overwritten on overflow or not. The default remains to overwrite old events
when the buffer is full. This patch adds the option to instead discard newest
events when the buffer is full. This is useful to get a snapshot of traces just
after enabling traces. Dropping the current event is also a simpler code path.
LKML-Reference: <1291844807-15481-1-git-send-email-dhsharp@google.com>
This reverts commit 5e38ca8f3ea423442eaafe1b7e206084aa38120a.
Breaks the build of several !CONFIG_HAVE_UNSTABLE_SCHED_CLOCK
architectures.
Cc: Jiri Olsa <jolsa@redhat.com>
Message-ID: <20110217171823.GB17058@elte.hu>
The warning "Delta way too big" warning might appear on a system with
was enabled during the suspend.
Since it's not realy bug, and the unstable sched clock is working
LKML-Reference: <1296649698-6003-1-git-send-email-jolsa@redhat.com>
Fix a bunch of
warning: ‘inline’ is not at beginning of declaration
messages when building a 'make allyesconfig' kernel with -Wextra.
These warnings are trivial to kill, yet rather annoying when building with
-Wextra.
The more we can cut down on pointless crap like this the better (IMHO).
A previous patch to do this for a 'allnoconfig' build has already been
merged. This just takes the cleanup a little further.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Fix two related problems in the event-copying loop of
ring_buffer_read_page.
The loop condition for copying events is off-by-one.
"len" is the remaining space in the caller-supplied page.
"size" is the size of the next event (or two events).
If len == size, then there is just enough space for the next event.
size was set to rb_event_ts_length, which may include the size of two
events if the first event is a time-extend, in order to assure time-
extends are kept together with the event after it. However,
rb_advance_reader always advances by one event. This would result in the
event after any time-extend being duplicated. Instead, get the size of
a single event for the memcpy, but use rb_event_ts_length for the loop
condition.
LKML-Reference: <1293064704-8101-1-git-send-email-dhsharp@google.com>
LKML-Reference: <AANLkTin7nLrRPc9qGjdjHbeVDDWiJjAiYyb-L=gH85bx@mail.gmail.com>
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (50 commits)
perf python scripting: Add futex-contention script
perf python scripting: Fixup cut'n'paste error in sctop script
perf scripting: Shut up 'perf record' final status
perf record: Remove newline character from perror() argument
perf python scripting: Support fedora 11 (audit 1.7.17)
perf python scripting: Improve the syscalls-by-pid script
perf python scripting: print the syscall name on sctop
perf python scripting: Improve the syscalls-counts script
perf python scripting: Improve the failed-syscalls-by-pid script
kprobes: Remove redundant text_mutex lock in optimize
x86/oprofile: Fix uninitialized variable use in debug printk
tracing: Fix 'faild' -> 'failed' typo
perf probe: Fix format specified for Dwarf_Off parameter
perf trace: Fix detection of script extension
perf trace: Use $PERF_EXEC_PATH in canned report scripts
perf tools: Document event modifiers
perf tools: Remove direct slang.h include
perf_events: Fix for transaction recovery in group_sched_in()
perf_events: Revert: Fix transaction recovery in group_sched_in()
perf, x86: Use NUMA aware allocations for PEBS/BTS/DS allocations
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (163 commits)
tracing: Fix compile issue for trace_sched_wakeup.c
[S390] hardirq: remove pointless header file includes
[IA64] Move local_softirq_pending() definition
perf, powerpc: Fix power_pmu_event_init to not use event->ctx
ftrace: Remove recursion between recordmcount and scripts/mod/empty
jump_label: Add COND_STMT(), reducer wrappery
perf: Optimize sw events
perf: Use jump_labels to optimize the scheduler hooks
jump_label: Add atomic_t interface
jump_label: Use more consistent naming
perf, hw_breakpoint: Fix crash in hw_breakpoint creation
perf: Find task before event alloc
perf: Fix task refcount bugs
perf: Fix group moving
irq_work: Add generic hardirq context callbacks
perf_events: Fix transaction recovery in group_sched_in()
perf_events: Fix bogus AMD64 generic TLB events
perf_events: Fix bogus context time tracking
tracing: Remove parent recording in latency tracer graph options
tracing: Use one prologue for the preempt irqs off tracer function tracers
With the binding of time extends to events we no longer need to use
the macro RB_TIMESTAMPS_PER_PAGE. Remove it.
By using inline and noinline, we are able to make the fast path of
recording an event 4% faster.
There's a condition to check if we should add a time extend or
not in the fast path. But this condition is racey (in the sense
that we can add a unnecessary time extend, but nothing that
can break anything). We later check if the time or event time
delta should be zero or have real data in it (not racey), making
this first check redundant.
This check may help save space once in a while, but really is
not worth the hassle to try to save some space that happens at
most 134 ms at a time.
When the time between two timestamps is greater than
2^27 nanosecs (~134 ms) a time extend event is added that extends
the time difference to 59 bits (~18 years). This is due to
events only having a 27 bit field to store time.
Currently this time extend is a separate event. We add it just before
the event data that is being written to the buffer. But before
the event data is committed, the event data can also be discarded (as
with the case of filters). But because the time extend has already been
committed, it will stay in the buffer.
If lots of events are being filtered and no event is being
written, then every 134ms a time extend can be added to the buffer
without any data attached. To keep from filling the entire buffer
with time extends, a time extend will never be the first event
in a page because the page timestamp can be used. Time extends can
only fill the rest of a page with some data at the beginning.
This patch binds the time extend with the data. The difference here
is that the time extend is not committed before the data is added.
Instead, when a time extend is needed, the space reserved on
the ring buffer is the time extend + the data event size. The
time extend is added to the first part of the reserved block and
the data is added to the second. The time extend event is passed
back to the reserver, but since the reserver also uses a function
to find the data portion of the reserved block, no changes to the
ring buffer interface need to be made.
When a commit is discarded, we now remove both the time extend and
the event. With this approach no more than one time extend can
be in the buffer in a row. Data must always follow a time extend.
Thanks to Mathieu Desnoyers for suggesting this idea.
Suggested-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
The delta between events is passed to the timestamp code by reference
and the timestamp code will reset the value. But it can be reset
from the caller. No need to pass it in by reference.
By changing the call to pass by value, lets gcc optimize the code
a bit more where it can store the delta in a register and not
worry about updating the reference.
The original code for the ring buffer had locations that modified
the timestamp and that change was used by the callers. Now,
the timestamp is not reused by the callers and there is no reason
to pass it by reference.
a bit more where it can store the timestamp in a register and not
Gcc inlines the slow path of the ring buffer write which can
hurt performance. This patch simply forces the slow path function
rb_move_tail() to always be a function.
The ring_buffer_benchmark module with reader_disabled=1 shows that
this patch changes the time to record an event from 135 ns to
132 ns. (3 ns or 2.22% improvement)
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Time stamps for the ring buffer are created by the difference between
two events. Each page of the ring buffer holds a full 64 bit timestamp.
Each event has a 27 bit delta stamp from the last event. The unit of time
is nanoseconds, so 27 bits can hold ~134 milliseconds. If two events
happen more than 134 milliseconds apart, a time extend is inserted
to add more bits for the delta. The time extend has 59 bits, which
is good for ~18 years.
Currently the time extend is committed separately from the event.
If an event is discarded before it is committed, due to filtering,
the time extend still exists. If all events are being filtered, then
after ~134 milliseconds a new time extend will be added to the buffer.
This can only happen till the end of the page. Since each page holds
a full timestamp, there is no reason to add a time extend to the
beginning of a page. Time extends can only fill a page that has actual
data at the beginning, so there is no fear that time extends will fill
more than a page without any data.
When reading an event, a loop is made to skip over time extends
since they are only used to maintain the time stamp and are never
given to the caller. As a paranoid check to prevent the loop running
forever, with the knowledge that time extends may only fill a page,
a check is made that tests the iteration of the loop, and if the
iteration is more than the number of time extends that can fit in a page
a warning is printed and the ring buffer is disabled (all of ftrace
is also disabled with it).
There is another event type that is called a TIMESTAMP which can
hold 64 bits of data in the theoretical case that two events happen
18 years apart. This code has not been implemented, but the name
of this event exists, as well as the structure for it. The
size of a TIMESTAMP is 16 bytes, where as a time extend is only
8 bytes. The macro used to calculate how many time extends can fit on
a page used the TIMESTAMP size instead of the time extend size
cutting the amount in half.
The following test case can easily trigger the warning since we only
need to have half the page filled with time extends to trigger the
warning:
# cd /sys/kernel/debug/tracing/
# echo function > current_tracer
# echo 'common_pid < 0' > events/ftrace/function/filter
# echo > trace
# echo 1 > trace_marker
# sleep 120
# cat trace
Enabling the function tracer and then setting the filter to only trace
functions where the process id is negative (no events), then clearing
the trace buffer to ensure that we have nothing in the buffer,
then write to trace_marker to add an event to the beginning of a page,
sleep for 2 minutes (only 35 seconds is probably needed, but this
guarantees the bug), and then finally reading the trace which will
trigger the bug.
This patch fixes the typo and prevents the false positive of that warning.
Reported-by: Hans J. Koch <hjk@linutronix.de>
Tested-by: Hans J. Koch <hjk@linutronix.de>
Cc: Stable Kernel <stable@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
No real bugs I believe, just some dead code.
Cc: andi@firstfloor.org
While discussing the strictness of the 80 character limit on the
Kernel Summit Discussion mailing list, I showed examples that I
broke that limit slightly with some algorithms. In discussing with
John Linville, what looked better, I realized that two of the
80 char breaking culprits were an identical expression.
As a clean up, this patch moves the identical expression into its
own helper function and that is used instead. As a side effect,
the offending code is now under the 80 character limit. :-)
This clean up code also changes the expression from
(A - B) - C to A - (B + C)
This makes the code look a little nicer too.
Cc: John W. Linville <linville@tuxdriver.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into trace/tip/perf/urgent-4
kernel/trace/trace_events.c
With the configuration: CONFIG_DEBUG_PAGEALLOC=y and Shaohua's patch:
[PATCH]x86: make spurious_fault check correct pte bit
Function call graph trace with the following will trigger a page fault.
# echo function_graph > current_tracer
# cat per_cpu/cpu1/trace_pipe_raw > /dev/null
BUG: unable to handle kernel paging request at ffff880006e99000
IP: [<ffffffff81085572>] rb_event_length+0x1/0x3f
PGD 1b19063 PUD 1b1d063 PMD 3f067 PTE 6e99160
Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
last sysfs file: /sys/devices/virtual/net/lo/operstate
CPU 1
Modules linked in:
Pid: 1982, comm: cat Not tainted 2.6.35-rc6-aes+ #300 /Bochs
RIP: 0010:[<ffffffff81085572>] [<ffffffff81085572>] rb_event_length+0x1/0x3f
RSP: 0018:ffff880006475e38 EFLAGS: 00010006
RAX: 0000000000000ff0 RBX: ffff88000786c630 RCX: 000000000000001d
RDX: ffff880006e98000 RSI: 0000000000000ff0 RDI: ffff880006e99000
RBP: ffff880006475eb8 R08: 000000145d7008bd R09: 0000000000000000
R10: 0000000000008000 R11: ffffffff815d9336 R12: ffff880006d08000
R13: ffff880006e605d8 R14: 0000000000000000 R15: 0000000000000018
FS: 00007f2b83e456f0(0000) GS:ffff880002100000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff880006e99000 CR3: 00000000064a8000 CR4: 00000000000006e0
Process cat (pid: 1982, threadinfo ffff880006474000, task ffff880006e40770)
Stack:
ffff880006475eb8 ffffffff8108730f 0000000000000ff0 000000145d7008bd
<0> ffff880006e98010 ffff880006d08010 0000000000000296 ffff88000786c640
<0> ffffffff81002956 0000000000000000 ffff8800071f4680 ffff8800071f4680
Call Trace:
[<ffffffff8108730f>] ? ring_buffer_read_page+0x15a/0x24a
[<ffffffff81002956>] ? return_to_handler+0x15/0x2f
[<ffffffff8108a575>] tracing_buffers_read+0xb9/0x164
[<ffffffff810debfe>] vfs_read+0xaf/0x150
[<ffffffff81002941>] return_to_handler+0x0/0x2f
[<ffffffff810248b0>] __bad_area_nosemaphore+0x17e/0x1a1
[<ffffffff810248e6>] bad_area_nosemaphore+0x13/0x15
Code: 80 25 b2 16 b3 00 fe c9 c3 55 48 89 e5 f0 80 0d a4 16 b3 00 02 c9 c3 55 31 c0 48 89 e5 48 83 3d 94 16 b3 00 01 c9 0f 94 c0 c3 55 <8a> 0f 48 89 e5 83 e1 1f b8 08 00 00 00 0f b6 d1 83 fa 1e 74 27
RIP [<ffffffff81085572>] rb_event_length+0x1/0x3f
RSP <ffff880006475e38>
---[ end trace a6877bb92ccb36bb ]---
The root cause is that ring_buffer_read_page() may read out of page
boundary, because the boundary checking is done after reading. This is
fixed via doing boundary checking before reading.
Reported-by: Shaohua Li <shaohua.li@intel.com>
Cc: <stable@kernel.org>
Signed-off-by: Huang Ying <ying.huang@intel.com>
LKML-Reference: <1280297641.2771.307.camel@yhuang-dev>
Reorder structure to remove 8 bytes of padding on 64 bit builds.
This shrinks the size to 128 bytes so allowing allocation from a smaller
slab & needed one fewer cache lines.
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
LKML-Reference: <1269516456.2054.8.camel@localhost>
The ftrace_preempt_disable/enable functions were to address a
recursive race caused by the function tracer. The function tracer
traces all functions which makes it easily susceptible to recursion.
One area was preempt_enable(). This would call the scheduler and
the schedulre would call the function tracer and loop.
(So was it thought).
The ftrace_preempt_disable/enable was made to protect against recursion
inside the scheduler by storing the NEED_RESCHED flag. If it was
set before the ftrace_preempt_disable() it would not call schedule
on ftrace_preempt_enable(), thinking that if it was set before then
it would have already scheduled unless it was already in the scheduler.
This worked fine except in the case of SMP, where another task would set
the NEED_RESCHED flag for a task on another CPU, and then kick off an
IPI to trigger it. This could cause the NEED_RESCHED to be saved at
ftrace_preempt_disable() but the IPI to arrive in the the preempt
disabled section. The ftrace_preempt_enable() would not call the scheduler
because the flag was already set before entring the section.
This bug would cause a missed preemption check and cause lower latencies.
Investigating further, I found that the recusion caused by the function
tracer was not due to schedule(), but due to preempt_schedule(). Now
that preempt_schedule is completely annotated with notrace, the recusion
no longer is an issue.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Currently the trace splice code zeros out the excess bytes in the page before
sending it off to userspace.
This is to make sure userspace is not getting anything it should not be
when reading the pages, because the excess data was never initialized
to zero before writing (for perfomance reasons).
But the splice code has no business in doing this work, it should be
done by the ring buffer. With the latest changes for recording lost
events, the splice code gets it wrong anyway.
Move the zeroing out of excess bytes into the ring buffer code.
The code to store the "lost events" requires knowing the real end
of the page. Since the 'commit' includes the padding at the end of
a page a "real_end" variable was used to keep track of the end not
including the padding.
If events were lost, the reader can place the count of events in
the padded area if there is enough room.
The bug this patch fixes is that when we fill the page we do not
reset the real_end variable, and if the writer had wrapped a few
times, the real_end would be incorrect.
This patch simply resets the real_end if the page was filled.
Wrap open-coded WARN_ONCE functionality into the equivalent macro.
Signed-off-by: Borislav Petkov <bp@alien8.de>
LKML-Reference: <20100502060354.GA5281@liondog.tnic>
When performing a non-consuming read, a synchronize_sched() is
performed once for every cpu which is actively tracing.
This is very expensive, and can make it take several seconds to open
up the 'trace' file with lots of cpus.
Only one synchronize_sched() call is actually necessary. What is
desired is for all cpus to see the disabling state change. So we
transform the existing sequence:
for_each_cpu() {
ring_buffer_read_start();
where each ring_buffer_start() call performs a synchronize_sched(),
into the following:
for_each_cpu() {
ring_buffer_read_prepare();
ring_buffer_read_prepare_sync();
for_each_cpu() {
wherein only the single ring_buffer_read_prepare_sync() call needs to
do the synchronize_sched().
The first phase, via ring_buffer_read_prepare(), allocates the 'iter'
memory and increments ->record_disabled.
In the second phase, ring_buffer_read_prepare_sync() makes sure this
->record_disabled state is visible fully to all cpus.
And in the final third phase, the ring_buffer_read_start() calls reset
the 'iter' objects allocated in the first phase since we now know that
none of the cpus are adding trace entries any more.
This makes openning the 'trace' file nearly instantaneous on a
sparc64 Niagara2 box with 128 cpus tracing.
LKML-Reference: <20100420.154711.11246950.davem@davemloft.net>
include/linux/module.h
kernel/module.c
Semantic conflict:
include/trace/events/module.h
Merge reason: Resolve the conflict with upstream commit 5fbfb18 ("Fix up
possibly racy module refcounting")
Currently, binary readers of the ring buffer only know where events were
lost, but not how many events were lost at that location.
This information is available, but it would require adding another
field to the sub buffer header to include it.
But when a event can not fit at the end of a sub buffer, it is written
to the next sub buffer. This means there is a good chance that the
buffer may have room to hold this counter. If it does, write
the counter at the end of the sub buffer and set another flag
in the data size field that states that this information exists.
Currently, when the ring buffer drops events, it does not record
the fact that it did so. It does inform the writer that the event
was dropped by returning a NULL event, but it does not put in any
place holder where the event was dropped.
This is not a trivial thing to add because the ring buffer mostly
runs in overwrite (flight recorder) mode. That is, when the ring
buffer is full, new data will overwrite old data.
In a produce/consumer mode, where new data is simply dropped when
the ring buffer is full, it is trivial to add the placeholder
for dropped events. When there's more room to write new data, then
a special event can be added to notify the reader about the dropped
events.
But in overwrite mode, any new write can overwrite events. A place
holder can not be inserted into the ring buffer since there never
may be room. A reader could also come in at anytime and miss the
placeholder.
Luckily, the way the ring buffer works, the read side can find out
if events were lost or not, and how many events. Everytime a write
takes place, if it overwrites the header page (the next read) it
updates a "overrun" variable that keeps track of the number of
lost events. When a reader swaps out a page from the ring buffer,
it can record this number, perfom the swap, and then check to
see if the number changed, and take the diff if it has, which would be
the number of events dropped. This can be stored by the reader
and returned to callers of the reader.
Since the reader page swap will fail if the writer moved the head
page since the time the reader page set up the swap, this gives room
to record the overruns without worrying about races. If the reader
sets up the pages, records the overrun, than performs the swap,
if the swap succeeds, then the overrun variable has not been
updated since the setup before the swap.
For binary readers of the ring buffer, a flag is set in the header
of each sub page (sub buffer) of the ring buffer. This flag is embedded
in the size field of the data on the sub buffer, in the 31st bit (the size
can be 32 or 64 bits depending on the architecture), but only 27
bits needs to be used for the actual size (less actually).
We could add a new field in the sub buffer header to also record the
number of events dropped since the last read, but this will change the
format of the binary ring buffer a bit too much. Perhaps this change can
be made if the information on the number of events dropped is considered
important enough.
Note, the notification of dropped events is only used by consuming reads
or peeking at the ring buffer. Iterating over the ring buffer does not
keep this information because the necessary data is only available when
a page swap is made, and the iterator does not swap out pages.
Cc: Robert Richter <robert.richter@amd.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: "Luis Claudio R. Goncalves" <lclaudio@uudg.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
In some error handling cases the lock is not unlocked. The return is
converted to a goto, to share the unlock at the end of the function.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
expression E1;
identifier f;
f (...) { <+...
* spin_lock_irq (E1,...);
... when != E1
* return ...;
// </smpl>
LKML-Reference: <Pine.LNX.4.64.1003291736440.21896@ask.diku.dk>
The ring buffer uses 4 byte alignment while recording events into the
buffer, even on 64bit machines. This saves space when there are lots
of events being recorded at 4 byte boundaries.
The ring buffer has a zero copy method to write into the buffer, with
the reserving of space and then committing it. This may cause problems
when writing an 8 byte word into a 4 byte alignment (not 8). For x86 and
PPC this is not an issue, but on some architectures this would cause an
out-of-alignment exception.
This patch uses CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS to determine
if it is OK to use 4 byte alignments on 64 bit machines. If it is not,
it forces the ring buffer event header to be 8 bytes and not 4,
and will align the length of the data to be 8 byte aligned.
This keeps the data payload at 8 byte alignments and will allow these
machines to run without issue.
The trick to this is that the header can be either 4 bytes or 8 bytes
depending on the length of the data payload. The 4 byte header
has a length field that supports up to 112 bytes. If the length of
the data is more than 112, the length field is set to zero, and the actual
length is stored in the next 4 bytes after the header.
When CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS is not set, the code forces
zero in the 4 byte header forcing the length to be stored in the 4 byte
array, even with a small data load. It also forces the length of the
data load to be 8 byte aligned. The combination of these two guarantee
that the data is always at 8 byte alignment.
Tested-by: Frederic Weisbecker <fweisbec@gmail.com>
(on sparc64)
Reported-by: Frederic Weisbecker <fweisbec@gmail.com>
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tracing: Do not record user stack trace from NMI context
tracing: Disable buffer switching when starting or stopping trace
tracing: Use same local variable when resetting the ring buffer
function-graph: Init curr_ret_stack with ret_stack
ring-buffer: Move disabled check into preempt disable section
function-graph: Add tracing_thresh support to function_graph tracer
tracing: Update the comm field in the right variable in update_max_tr
function-graph: Use comment notation for func names of dangling '}'
function-graph: Fix unused reference to ftrace_set_func()
tracing: Fix warning in s_next of trace file ops
tracing: Include irqflags headers from trace clock
