path: root/kernel/time/timekeeping.c
2010-05-10Merge branch 'linus' into timers/coreThomas Gleixner
Reason: Further posix_cpu_timer patches depend on mainline changes Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-04-13time: Remove xtime_cacheJohn Stultz
With the earlier logarithmic time accumulation patch, xtime will now always be within one "tick" of the current time, instead of possibly half a second off. This removes the need for the xtime_cache value, which always stored the time at the last interrupt, so this patch cleans that up removing the xtime_cache related code. This patch also addresses an issue with an earlier version of this change, where xtime_cache was normalizing xtime, which could in some cases be not valid (ie: tv_nsec == NSEC_PER_SEC). This is fixed by handling the edge case in update_wall_time(). Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Petr Titěra <P.Titera@century.cz> LKML-Reference: <1270589451-30773-1-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-03-23time: Fix accumulation bug triggered by long delay.John Stultz
The logarithmic accumulation done in the timekeeping has some overflow protection that limits the max shift value. That means it will take more then shift loops to accumulate all of the cycles. This causes the shift decrement to underflow, which causes the loop to never exit. The simplest fix would be simply to do a: if (shift) shift--; However that is not optimal, as we know the cycle offset is larger then the interval << shift, the above would make shift drop to zero, then we would be spinning for quite awhile accumulating at interval chunks at a time. Instead, this patch only decreases shift if the offset is smaller then cycle_interval << shift. This makes sure we accumulate using the largest chunks possible without overflowing tick_length, and limits the number of iterations through the loop. This issue was found and reported by Sonic Zhang, who also tested the fix. Many thanks your explanation and testing! Reported-by: Sonic Zhang <sonic.adi@gmail.com> Signed-off-by: John Stultz <johnstul@us.ibm.com> Tested-by: Sonic Zhang <sonic.adi@gmail.com> LKML-Reference: <1268948850-5225-1-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-03-01Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: posix-timers.c: Don't export local functions clocksource: start CMT at clocksource resume clocksource: add suspend callback clocksource: add argument to resume callback ntp: Cleanup xtime references in ntp.c ntp: Make time_esterror and time_maxerror static
2010-02-09Export the symbol of getboottime and mmonotonic_to_bootbasedJason Wang
Export getboottime and monotonic_to_bootbased in order to let them could be used by following patch. Cc: stable@kernel.org Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-02-05clocksource: add suspend callbackMagnus Damm
Add a clocksource suspend callback. This callback can be used by the clocksource driver to shutdown and perform any kind of late suspend activities even though the clocksource driver itself is a non-sysdev driver. One example where this is useful is to fix the sh_cmt.c platform driver that today suspends using the platform bus and shuts down the clocksource too early. With this callback in place the sh_cmt driver will suspend using the clocksource and clockevent hooks and leave the platform device pm callbacks unused. Signed-off-by: Magnus Damm <damm@opensource.se> Cc: Paul Mundt <lethal@linux-sh.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-12-22Revert "time: Remove xtime_cache"Linus Torvalds
This reverts commit 7bc7d637452383d56ba4368d4336b0dde1bb476d, as requested by John Stultz. Quoting John: "Petr Titěra reported an issue where he saw odd atime regressions with 2.6.33 where there were a full second worth of nanoseconds in the nanoseconds field. He also reviewed the time code and narrowed down the problem: unhandled overflow of the nanosecond field caused by rounding up the sub-nanosecond accumulated time. Details: * At the end of update_wall_time(), we currently round up the sub-nanosecond portion of accumulated time when storing it into xtime. This was added to avoid time inconsistencies caused when the sub-nanosecond portion was truncated when storing into xtime. Unfortunately we don't handle the possible second overflow caused by that rounding. * Previously the xtime_cache code hid this overflow by normalizing the xtime value when storing into the xtime_cache. * We could try to handle the second overflow after the rounding up, but since this affects the timekeeping's internal state, this would further complicate the next accumulation cycle, causing small errors in ntp steering. As much as I'd like to get rid of it, the xtime_cache code is known to work. * The correct fix is really to include the sub-nanosecond portion in the timekeeping accessor function, so we don't need to round up at during accumulation. This would greatly simplify the accumulation code. Unfortunately, we can't do this safely until the last three non-GENERIC_TIME arches (sparc32, arm, cris) are converted (those patches are in -mm) and we kill off the spots where arches set xtime directly. This is all 2.6.34 material, so I think reverting the xtime_cache change is the best approach for now. Many thanks to Petr for both reporting and finding the issue!" Reported-by: Petr Titěra <P.Titera@century.cz> Requested-by: john stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-08Merge branch 'timers-for-linus-urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: hrtimer: Fix /proc/timer_list regression itimers: Fix racy writes to cpu_itimer fields timekeeping: Fix clock_gettime vsyscall time warp
2009-12-08Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: timers, init: Limit the number of per cpu calibration bootup messages posix-cpu-timers: optimize and document timer_create callback clockevents: Add missing include to pacify sparse x86: vmiclock: Fix printk format x86: Fix printk format due to variable type change sparc: fix printk for change of variable type clocksource/events: Fix fallout of generic code changes nohz: Allow 32-bit machines to sleep for more than 2.15 seconds nohz: Track last do_timer() cpu nohz: Prevent clocksource wrapping during idle nohz: Type cast printk argument mips: Use generic mult/shift factor calculation for clocks clocksource: Provide a generic mult/shift factor calculation clockevents: Use u32 for mult and shift factors nohz: Introduce arch_needs_cpu nohz: Reuse ktime in sub-functions of tick_check_idle. time: Remove xtime_cache time: Implement logarithmic time accumulation
2009-11-17timekeeping: Fix clock_gettime vsyscall time warpLin Ming
Since commit 0a544198 "timekeeping: Move NTP adjusted clock multiplier to struct timekeeper" the clock multiplier of vsyscall is updated with the unmodified clock multiplier of the clock source and not with the NTP adjusted multiplier of the timekeeper. This causes user space observerable time warps: new CLOCK-warp maximum: 120 nsecs, 00000025c337c537 -> 00000025c337c4bf Add a new argument "mult" to update_vsyscall() and hand in the timekeeping internal NTP adjusted multiplier. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Cc: "Zhang Yanmin" <yanmin_zhang@linux.intel.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Tony Luck <tony.luck@intel.com> LKML-Reference: <1258436990.17765.83.camel@minggr.sh.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-11-13nohz: Prevent clocksource wrapping during idleJon Hunter
The dynamic tick allows the kernel to sleep for periods longer than a single tick, but it does not limit the sleep time currently. In the worst case the kernel could sleep longer than the wrap around time of the time keeping clock source which would result in losing track of time. Prevent this by limiting it to the safe maximum sleep time of the current time keeping clock source. The value is calculated when the clock source is registered. [ tglx: simplified the code a bit and massaged the commit msg ] Signed-off-by: Jon Hunter <jon-hunter@ti.com> Cc: John Stultz <johnstul@us.ibm.com> LKML-Reference: <1250617512-23567-2-git-send-email-jon-hunter@ti.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-10-05time: Remove xtime_cachejohn stultz
With the prior logarithmic time accumulation patch, xtime will now always be within one "tick" of the current time, instead of possibly half a second off. This removes the need for the xtime_cache value, which always stored the time at the last interrupt, so this patch cleans that up removing the xtime_cache related code. This is a bit simpler, but still could use some wider testing. Signed-off-by: John Stultz <johnstul@us.ibm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: John Kacur <jkacur@redhat.com> Cc: Clark Williams <williams@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <1254525855.7741.95.camel@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-05time: Implement logarithmic time accumulationjohn stultz
Accumulating one tick at a time works well unless we're using NOHZ. Then it can be an issue, since we may have to run through the loop a few thousand times, which can increase timer interrupt caused latency. The current solution was to accumulate in half-second intervals with NOHZ. This kept the number of loops down, however it did slightly change how we make NTP adjustments. While not an issue with NTPd users, as NTPd makes adjustments over a longer period of time, other adjtimex() users have noticed the half-second granularity with which we can apply frequency changes to the clock. For instance, if a application tries to apply a 100ppm frequency correction for 20ms to correct a 2us offset, with NOHZ they either get no correction, or a 50us correction. Now, there will always be some granularity error for applying frequency corrections. However with users sensitive to this error have seen a 50-500x increase with NOHZ compared to running without NOHZ. So I figured I'd try another approach then just simply increasing the interval. My approach is to consume the time interval logarithmically. This reduces the number of times through the loop needed keeping latency down, while still preserving the original granularity error for adjtimex() changes. Further, this change allows us to remove the xtime_cache code (patch to follow), as xtime is always within one tick of the current time, instead of the half-second updates it saw before. An earlier version of this patch has been shipping to x86 users in the RedHat MRG releases for awhile without issue, but I've reworked this version to be even more careful about avoiding possible overflows if the shift value gets too large. Signed-off-by: John Stultz <johnstul@us.ibm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: John Kacur <jkacur@redhat.com> Cc: Clark Williams <williams@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <1254525473.7741.88.camel@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-25timekeeping: Fix invalid getboottime() valueHiroshi Shimamoto
Don't use timespec_add_safe() with wall_to_monotonic, because wall_to_monotonic has negative values which will cause overflow in timespec_add_safe(). That makes btime in /proc/stat invalid. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <4A937FDE.4050506@ct.jp.nec.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-21time: Introduce CLOCK_REALTIME_COARSEjohn stultz
After talking with some application writers who want very fast, but not fine-grained timestamps, I decided to try to implement new clock_ids to clock_gettime(): CLOCK_REALTIME_COARSE and CLOCK_MONOTONIC_COARSE which returns the time at the last tick. This is very fast as we don't have to access any hardware (which can be very painful if you're using something like the acpi_pm clocksource), and we can even use the vdso clock_gettime() method to avoid the syscall. The only trade off is you only get low-res tick grained time resolution. This isn't a new idea, I know Ingo has a patch in the -rt tree that made the vsyscall gettimeofday() return coarse grained time when the vsyscall64 sysctrl was set to 2. However this affects all applications on a system. With this method, applications can choose the proper speed/granularity trade-off for themselves. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: nikolag@ca.ibm.com Cc: Darren Hart <dvhltc@us.ibm.com> Cc: arjan@infradead.org Cc: jonathan@jonmasters.org LKML-Reference: <1250734414.6897.5.camel@localhost.localdomain> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15timekeeping: Introduce read_boot_clockMartin Schwidefsky
Add the new function read_boot_clock to get the exact time the system has been started. For architectures without support for exact boot time a new weak function is added that returns 0. Use the exact boot time to initialize wall_to_monotonic, or xtime if the read_boot_clock returned 0. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134811.296703241@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15timekeeping: Increase granularity of read_persistent_clock()Martin Schwidefsky
The persistent clock of some architectures (e.g. s390) have a better granularity than seconds. To reduce the delta between the host clock and the guest clock in a virtualized system change the read_persistent_clock function to return a struct timespec. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134811.013873340@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15timekeeping: Update clocksource with stop_machineMartin Schwidefsky
update_wall_time calls change_clocksource HZ times per second to check if a new clock source is available. In close to 100% of all calls there is no new clock. Replace the tick based check by an update done with stop_machine. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134810.711836357@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15timekeeping: Add timekeeper read_clock helper functionsMartin Schwidefsky
Add timekeeper_read_clock_ntp and timekeeper_read_clock_raw and use them for getnstimeofday, ktime_get, ktime_get_ts and getrawmonotonic. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134810.435105711@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15timekeeping: Move NTP adjusted clock multiplier to struct timekeeperMartin Schwidefsky
The clocksource structure has two multipliers, the unmodified multiplier clock->mult_orig and the NTP corrected multiplier clock->mult. The NTP multiplier is misplaced in the struct clocksource, this is private information of the timekeeping code. Add the mult field to the struct timekeeper to contain the NTP corrected value, keep the unmodifed multiplier in clock->mult and remove clock->mult_orig. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134810.149047645@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15timekeeping: Add xtime_shift and ntp_error_shift to struct timekeeperMartin Schwidefsky
The xtime_nsec value in the timekeeper structure is shifted by a few bits to improve precision. This happens to be the same value as the clock->shift. To improve readability add xtime_shift to the timekeeper and use it instead of the clock->shift. Likewise add ntp_error_shift and replace all (NTP_SCALE_SHIFT - clock->shift) expressions. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134809.871899606@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15timekeeping: Introduce struct timekeeperMartin Schwidefsky
Add struct timekeeper to keep the internal values timekeeping.c needs in regard to the currently selected clock source. This moves the timekeeping intervals, xtime_nsec and the ntp error value from struct clocksource to struct timekeeper. The raw_time is removed from the clocksource as well. It gets treated like xtime as a global variable. Eventually xtime raw_time should be moved to struct timekeeper. [ tglx: minor cleanup ] Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134809.613209842@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15clocksource: Cleanup clocksource selectionMartin Schwidefsky
If a non high-resolution clocksource is first set as override clock and then registered it becomes active even if the system is in one-shot mode. Move the override check from sysfs_override_clocksource to the clocksource selection. That fixes the bug and simplifies the code. The check in clocksource_register for double registration of the same clocksource is removed without replacement. To find the initial clocksource a new weak function in jiffies.c is defined that returns the jiffies clocksource. The architecture code can then override the weak function with a more suitable clocksource, e.g. the TOD clock on s390. [ tglx: Folded in a fix from John Stultz ] Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134808.388024160@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15timekeeping: Move reset of cycle_last for tsc clocksource to tscMartin Schwidefsky
change_clocksource resets the cycle_last value to zero then sets it to a value read from the clocksource. The reset to zero is required only for the TSC clocksource to make the read_tsc function work after a resume. The reason is that the TSC read function uses cycle_last to detect backwards going TSCs. In the resume case cycle_last contains the TSC value from the last update before the suspend. On resume the TSC starts counting from 0 again and would trip over the cycle_last comparison. This is subtle and surprising. Move the reset to a resume function in the tsc code. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134808.142191175@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15timekeeping: Remove clocksource inline functionsMartin Schwidefsky
The three inline functions clocksource_read, clocksource_enable and clocksource_disable are simple wrappers of an indirect call plus the copy from and to the mult_orig value. The functions are exclusively used by the timekeeping code which has intimate knowledge of the clocksource anyway. Therefore remove the inline functions. No functional change. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134807.903108946@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15timekeeping: Introduce timekeeping_leap_insertJohn Stultz
Move the adjustment of xtime, wall_to_monotonic and the update of the vsyscall variables to the timekeeping code. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> LKML-Reference: <20090814134807.609730216@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-07-07timekeeping: Move ktime_get() functions to timekeeping.cThomas Gleixner
The ktime_get() functions for GENERIC_TIME=n are still located in hrtimer.c. Move them to time/timekeeping.c where they belong. LKML-Reference: <new-submission> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-07-07timekeeping: optimized ktime_get[_ts] for GENERIC_TIME=yMartin Schwidefsky
The generic ktime_get function defined in kernel/hrtimer.c is suboptimial for GENERIC_TIME=y: 0) | ktime_get() { 0) | ktime_get_ts() { 0) | getnstimeofday() { 0) | read_tod_clock() { 0) 0.601 us | } 0) 1.938 us | } 0) | set_normalized_timespec() { 0) 0.602 us | } 0) 4.375 us | } 0) 5.523 us | } Overall there are two read_seqbegin/read_seqretry loops and a lot of unnecessary struct timespec calculations. ktime_get returns a nano second value which is the sum of xtime, wall_to_monotonic and the nano second delta from the clock source. ktime_get can be optimized for GENERIC_TIME=y. The new version only calls clocksource_read: 0) | ktime_get() { 0) | read_tod_clock() { 0) 0.610 us | } 0) 1.977 us | } It uses a single read_seqbegin/readseqretry loop and just adds everthing to a nano second value. ktime_get_ts is optimized in a similar fashion. [ tglx: added WARN_ON(timekeeping_suspended) as in getnstimeofday() ] Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: john stultz <johnstul@us.ibm.com> LKML-Reference: <20090707112728.3005244d@skybase> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-06-11Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2009-05-15sched, timers: move calc_load() to schedulerThomas Gleixner
Dimitri Sivanich noticed that xtime_lock is held write locked across calc_load() which iterates over all online CPUs. That can cause long latencies for xtime_lock readers on large SMP systems. The load average calculation is an rough estimate anyway so there is no real need to protect the readers vs. the update. It's not a problem when the avenrun array is updated while a reader copies the values. Instead of iterating over all online CPUs let the scheduler_tick code update the number of active tasks shortly before the avenrun update happens. The avenrun update itself is handled by the CPU which calls do_timer(). [ Impact: reduce xtime_lock write locked section ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org>
2009-05-02timekeeping: create arch_gettimeoffset infrastructurejohn stultz
Some arches don't supply their own clocksource. This is mainly the case in architectures that get their inter-tick times by reading the counter on their interval timer. Since these timers wrap every tick, they're not really useful as clocksources. Wrapping them to act like one is possible but not very efficient. So we provide a callout these arches can implement for use with the jiffies clocksource to provide finer then tick granular time. [ Impact: ease the migration to generic time keeping ] Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-04-21clocksource: add enable() and disable() callbacksMagnus Damm
Add enable() and disable() callbacks for clocksources. This allows us to put unused clocksources in power save mode. The functions clocksource_enable() and clocksource_disable() wrap the callbacks and are inserted in the timekeeping code to enable before use and disable after switching to a new clocksource. Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-31sched_clock: prevent scd->clock from moving backwards, take #2Thomas Gleixner
Redo: 5b7dba4: sched_clock: prevent scd->clock from moving backwards which had to be reverted due to s2ram hangs: ca7e716: Revert "sched_clock: prevent scd->clock from moving backwards" ... this time with resume restoring GTOD later in the sequence taken into account as well. The "timekeeping_suspended" flag is not very nice but we cannot call into GTOD before it has been properly resumed and the scheduler will run very early in the resume sequence. Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-04time: catch xtime_nsec underflows and fix themjohn stultz
Impact: fix time warp bug Alex Shi, along with Yanmin Zhang have been noticing occasional time inconsistencies recently. Through their great diagnosis, they found that the xtime_nsec value used in update_wall_time was occasionally going negative. After looking through the code for awhile, I realized we have the possibility for an underflow when three conditions are met in update_wall_time(): 1) We have accumulated a second's worth of nanoseconds, so we incremented xtime.tv_sec and appropriately decrement xtime_nsec. (This doesn't cause xtime_nsec to go negative, but it can cause it to be small). 2) The remaining offset value is large, but just slightly less then cycle_interval. 3) clocksource_adjust() is speeding up the clock, causing a corrective amount (compensating for the increase in the multiplier being multiplied against the unaccumulated offset value) to be subtracted from xtime_nsec. This can cause xtime_nsec to underflow. Unfortunately, since we notify the NTP subsystem via second_overflow() whenever we accumulate a full second, and this effects the error accumulation that has already occured, we cannot simply revert the accumulated second from xtime nor move the second accumulation to after the clocksource_adjust call without a change in behavior. This leaves us with (at least) two options: 1) Simply return from clocksource_adjust() without making a change if we notice the adjustment would cause xtime_nsec to go negative. This would work, but I'm concerned that if a large adjustment was needed (due to the error being large), it may be possible to get stuck with an ever increasing error that becomes too large to correct (since it may always force xtime_nsec negative). This may just be paranoia on my part. 2) Catch xtime_nsec if it is negative, then add back the amount its negative to both xtime_nsec and the error. This second method is consistent with how we've handled earlier rounding issues, and also has the benefit that the error being added is always in the oposite direction also always equal or smaller then the correction being applied. So the risk of a corner case where things get out of control is lessened. This patch fixes bug 11970, as tested by Yanmin Zhang http://bugzilla.kernel.org/show_bug.cgi?id=11970 Reported-by: alex.shi@intel.com Signed-off-by: John Stultz <johnstul@us.ibm.com> Acked-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Tested-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-20Merge branches 'timers/clocksource', 'timers/hrtimers', 'timers/nohz', ↵Thomas Gleixner
'timers/ntp', 'timers/posixtimers' and 'timers/debug' into v28-timers-for-linus
2008-09-24timekeeping: fix rounding problem during clock updateRoman Zippel
Due to a rounding problem during a clock update it's possible for readers to observe the clock jumping back by 1nsec. The following simplified example demonstrates the problem: cycle xtime 0 0 1000 999999.6 2000 1999999.2 3000 2999998.8 ... 1500 = 1499999.4 = 0.0 + 1499999.4 = 999999.6 + 499999.8 When reading the clock only the full nanosecond part is used, while timekeeping internally keeps nanosecond fractions. If the clock is now updated at cycle 1500 here, a nanosecond is missing due to the truncation. The simple fix is to round up the xtime value during the update, this also changes the distance to the reference time, but the adjustment will automatically take care that it stays under control. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-08-21clocksource: introduce CLOCK_MONOTONIC_RAWJohn Stultz
In talking with Josip Loncaric, and his work on clock synchronization (see btime.sf.net), he mentioned that for really close synchronization, it is useful to have access to "hardware time", that is a notion of time that is not in any way adjusted by the clock slewing done to keep close time sync. Part of the issue is if we are using the kernel's ntp adjusted representation of time in order to measure how we should correct time, we can run into what Paul McKenney aptly described as "Painting a road using the lines we're painting as the guide". I had been thinking of a similar problem, and was trying to come up with a way to give users access to a purely hardware based time representation that avoided users having to know the underlying frequency and mask values needed to deal with the wide variety of possible underlying hardware counters. My solution is to introduce CLOCK_MONOTONIC_RAW. This exposes a nanosecond based time value, that increments starting at bootup and has no frequency adjustments made to it what so ever. The time is accessed from userspace via the posix_clock_gettime() syscall, passing CLOCK_MONOTONIC_RAW as the clock_id. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-21clocksource: introduce clocksource_forward_now()Roman Zippel
To keep the raw monotonic patch simple first introduce clocksource_forward_now(), which takes care of the offset since the last update_wall_time() call and adds it to the clock, so there is no need anymore to deal with it explicitly at various places, which need to make significant changes to the clock. This is also gets rid of the timekeeping_suspend_nsecs, instead of waiting until resume, the value is accumulated during suspend. In the end there is only a single user of __get_nsec_offset() left, so I integrated it back to getnstimeofday(). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-01ntp: handle leap second via timerRoman Zippel
Remove the leap second handling from second_overflow(), which doesn't have to check for it every second anymore. With CONFIG_NO_HZ this also makes sure the leap second is handled close to the full second. Additionally this makes it possible to abort a leap second properly by resetting the STA_INS/STA_DEL status bits. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01ntp: remove current_tick_length()Roman Zippel
current_tick_length used to do a little more, but now it just returns tick_length, which we can also access directly at the few places, where it's needed. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01ntp: rename TICK_LENGTH_SHIFT to NTP_SCALE_SHIFTRoman Zippel
As TICK_LENGTH_SHIFT is used for more than just the tick length, the name isn't quite approriate anymore, so this renames it to NTP_SCALE_SHIFT. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19x86: tsc prevent time going backwardsThomas Gleixner
We already catch most of the TSC problems by sanity checks, but there is a subtle bug which has been in the code forever. This can cause time jumps in the range of hours. This was reported in: http://lkml.org/lkml/2007/8/23/96 and http://lkml.org/lkml/2008/3/31/23 I was able to reproduce the problem with a gettimeofday loop test on a dual core and a quad core machine which both have sychronized TSCs. The TSCs seems not to be perfectly in sync though, but the kernel is not able to detect the slight delta in the sync check. Still there exists an extremly small window where this delta can be observed with a real big time jump. So far I was only able to reproduce this with the vsyscall gettimeofday implementation, but in theory this might be observable with the syscall based version as well. CPU 0 updates the clock source variables under xtime/vyscall lock and CPU1, where the TSC is slighty behind CPU0, is reading the time right after the seqlock was unlocked. The clocksource reference data was updated with the TSC from CPU0 and the value which is read from TSC on CPU1 is less than the reference data. This results in a huge delta value due to the unsigned subtraction of the TSC value and the reference value. This algorithm can not be changed due to the support of wrapping clock sources like pm timer. The huge delta is converted to nanoseconds and added to xtime, which is then observable by the caller. The next gettimeofday call on CPU1 will show the correct time again as now the TSC has advanced above the reference value. To prevent this TSC specific wreckage we need to compare the TSC value against the reference value and return the latter when it is larger than the actual TSC value. I pondered to mark the TSC unstable when the readout is smaller than the reference value, but this would render an otherwise good and fast clocksource unusable without a real good reason. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-24Don't 'printk()' while holding xtime lock for writingLinus Torvalds
The printk() can deadlock because it can wake up klogd(), and task enqueueing will try to read the time in order to set a hrtimer. Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com> Debugged-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-09time: remove obsolete CLOCK_TICK_ADJUSTRoman Zippel
The first version of the ntp_interval/tick_length inconsistent usage patch was recently merged as bbe4d18ac2e058c56adb0cd71f49d9ed3216a405 http://git.kernel.org/gitweb.cgi?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=bbe4d18ac2e058c56adb0cd71f49d9ed3216a405 While the fix did greatly improve the situation, it was correctly pointed out by Roman that it does have a small bug: If the users change clocksources after the system has been running and NTP has made corrections, the correctoins made against the old clocksource will be applied against the new clocksource, causing error. The second attempt, which corrects the issue in the NTP_INTERVAL_LENGTH definition has also made it up-stream as commit e13a2e61dd5152f5499d2003470acf9c838eab84 http://git.kernel.org/gitweb.cgi?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=e13a2e61dd5152f5499d2003470acf9c838eab84 Roman has correctly pointed out that CLOCK_TICK_ADJUST is calculated based on the PIT's frequency, and isn't really relevant to non-PIT driven clocksources (that is, clocksources other then jiffies and pit). This patch reverts both of those changes, and simply removes CLOCK_TICK_ADJUST. This does remove the granularity error correction for users of PIT and Jiffies clocksource users, but the granularity error but for the majority of users, it should be within the 500ppm range NTP can accommodate for. For systems that have granularity errors greater then 500ppm, the "ntp_tick_adj=" boot option can be used to compensate. [johnstul@us.ibm.com: provided changelog] [mattilinnanvuori@yahoo.com: maek ntp_tick_adj static] Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Acked-by: john stultz <johnstul@us.ibm.com> Signed-off-by: Matti Linnanvuori <mattilinnanvuori@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: mingo@elte.hu Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-08time: fix typo in commentsLi Zefan
Fix typo in comments. BTW: I have to fix coding style in arch/ia64/kernel/time.c also, otherwise checkpatch.pl will be complaining. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08timekeeping: rename timekeeping_is_continuous to timekeeping_valid_for_hresLi Zefan
Function timekeeping_is_continuous() no longer checks flag CLOCK_IS_CONTINUOUS, and it checks CLOCK_SOURCE_VALID_FOR_HRES now. So rename the function accordingly. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01timekeeping: update xtime_cache when time(zone) changesThomas Gleixner
xtime_cache needs to be updated whenever xtime and or wall_to_monotic are changed. Otherwise users of xtime_cache might see a stale (and in the case of timezone changes utterly wrong) value until the next update happens. Fixup the obvious places, which miss this update. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: John Stultz <johnstul@us.ibm.com> Tested-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30NTP: correct inconsistent ntp interval/tick_length usagejohn stultz
I recently noticed on one of my boxes that when synched with an NTP server, the drift value reported for the system was ~283ppm. While in some cases, clock hardware can be that bad, it struck me as unusual as the system was using the acpi_pm clocksource, which is one of the more trustworthy and accurate clocksources on x86 hardware. I brought up another system and let it sync to the same NTP server, and I noticed a similar 280some ppm drift. In looking at the code, I found that the acpi_pm's constant frequency was being computed correctly at boot-up, however once the system was up, even without the ntp daemon running, the clocksource's frequency was being modified by the clocksource_adjust() function. Digging deeper, I realized that in the code that keeps track of how much the clocksource is skewing from the ntp desired time, we were using different lengths to establish how long an time interval was. The clocksource was being setup with the following interval: NTP_INTERVAL_LENGTH = NSEC_PER_SEC/NTP_INTERVAL_FREQ While the ntp code was using the tick_length_base value: tick_length_base ~= (tick_usec * NSEC_PER_USEC * USER_HZ) /NTP_INTERVAL_FREQ The subtle difference is: (tick_usec * NSEC_PER_USEC * USER_HZ) != NSEC_PER_SEC This difference in calculation was causing the clocksource correction code to apply a correction factor to the clocksource so the two intervals were the same, however this results in the actual frequency of the clocksource to be made incorrect. I believe this difference would affect all clocksources, although to differing degrees depending on the clocksource resolution. The issue was introduced when my HZ free ntp patch landed in 2.6.21-rc1, so my apologies for the mistake, and for not noticing it until now. The following patch, corrects the clocksource's initialization code so it uses the same interval length as the code in ntp.c. After applying this patch, the drift value for the same system went from ~283ppm to only 2.635ppm. I believe this patch to be good, however it does affect all arches and I've only tested on x86, so some caution is advised. I do think it would be a likely candidate for a stable 2.6.24.x release. Any thoughts or feedback would be appreciated. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30time: fold __get_realtime_clock_ts() into getnstimeofday()Geert Uytterhoeven
- getnstimeofday() was just a wrapper around __get_realtime_clock_ts() - Replace calls to __get_realtime_clock_ts() by calls to getnstimeofday() - Fix bogus reference to get_realtime_clock_ts(), which never existed Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
