path: root/kernel/time/Makefile
2007-02-16[PATCH] Add debugging feature /proc/timer_statIngo Molnar
Add /proc/timer_stats support: debugging feature to profile timer expiration. Both the starting site, process/PID and the expiration function is captured. This allows the quick identification of timer event sources in a system. Sample output: # echo 1 > /proc/timer_stats # cat /proc/timer_stats Timer Stats Version: v0.1 Sample period: 4.010 s 24, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick) 11, 0 swapper sk_reset_timer (tcp_delack_timer) 6, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick) 2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) 17, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick) 2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) 4, 2050 pcscd do_nanosleep (hrtimer_wakeup) 5, 4179 sshd sk_reset_timer (tcp_write_timer) 4, 2248 yum-updatesd schedule_timeout (process_timeout) 18, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick) 3, 0 swapper sk_reset_timer (tcp_delack_timer) 1, 1 swapper neigh_table_init_no_netlink (neigh_periodic_timer) 2, 1 swapper e1000_up (e1000_watchdog) 1, 1 init schedule_timeout (process_timeout) 100 total events, 25.24 events/sec [ cleanups and hrtimers support from Thomas Gleixner <tglx@linutronix.de> ] [bunk@stusta.de: nr_entries can become static] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] tick-management: dyntick / highres functionalityThomas Gleixner
With Ingo Molnar <mingo@elte.hu> Add functions to provide dynamic ticks and high resolution timers. The code which keeps track of jiffies and handles the long idle periods is shared between tick based and high resolution timer based dynticks. The dyntick functionality can be disabled on the kernel commandline. Provide also the infrastructure to support high resolution timers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] tick-management: broadcast functionalityThomas Gleixner
With Ingo Molnar <mingo@elte.hu> Add broadcast functionality, so per cpu clock event devices can be registered as dummy devices or switched from/to broadcast on demand. The broadcast function distributes the events via the broadcast function of the clock event device. This is primarily designed to replace the switch apic timer to / from IPI in power states, where the apic stops. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] tick-management: core functionalityThomas Gleixner
With Ingo Molnar <mingo@elte.hu> The tick-management code is the first user of the clockevents layer. It takes clock event devices from the clock events core and uses them to provide the periodic tick. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] clockevents: add core functionalityThomas Gleixner
Architectures register their clock event devices, in the clock events core. Users of the clockevents core can get clock event devices for their use. The clockevents core code provides notification mechanisms for various clock related management events. This allows to control the clock event devices without the architectures having to worry about the details of function assignment. This is also a preliminary for high resolution timers and dynamic ticks to allow the core code to control the clock functionality without intrusive changes to the architecture code. [Fixes-by: Ingo Molnar <mingo@elte.hu>] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-01[PATCH] NTP: Move all the NTP related code to ntp.cjohn stultz
Move all the NTP related code to ntp.c [akpm@osdl.org: cleanups, build fix] Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: Clocksource Infrastructurejohn stultz
This introduces the clocksource management infrastructure. A clocksource is a driver-like architecture generic abstraction of a free-running counter. This code defines the clocksource structure, and provides management code for registering, selecting, accessing and scaling clocksources. Additionally, this includes the trivial jiffies clocksource, a lowest common denominator clocksource, provided mainly for use as an example. [hirofumi@mail.parknet.co.jp: Don't enable IRQ too early] Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
