path: root/kernel/time.c
2007-10-18whitespace fixes: time syscallsDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Fix discrepancy between VDSO based gettimeofday() and sys_gettimeofday().Tony Breeds
On platforms that copy sys_tz into the vdso (currently only x86_64, soon to include powerpc), it is possible for the vdso to get out of sync if a user calls (admittedly unusual) settimeofday(NULL, ptr). This patch adds a hook for architectures that set CONFIG_GENERIC_TIME_VSYSCALL to ensure when sys_tz is updated they can also updatee their copy in the vdso. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Cc: Andi Kleen <ak@suse.de> Cc: Tony Luck <tony.luck@intel.com> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Clean up duplicate includes in kernel/Jesper Juhl
This patch cleans up duplicate includes in kernel/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16time: introduce xtime_secondsIngo Molnar
improve performance of sys_time(). sys_time() returns time in seconds, but it does so by calling do_gettimeofday() and then returning the tv_sec portion of the GTOD time. But the data structure "xtime", which is updated by every timer/scheduler tick, already offers HZ granularity time. the patch improves the sysbench oltp macrobenchmark by 4-5% on an AMD dual-core system: v2.6.23: #threads 1: transactions: 4073 (407.23 per sec.) 2: transactions: 8530 (852.81 per sec.) 3: transactions: 8321 (831.88 per sec.) 4: transactions: 8407 (840.58 per sec.) 5: transactions: 8070 (806.74 per sec.) v2.6.23 + sys_time-speedup.patch: 1: transactions: 4281 (428.09 per sec.) 2: transactions: 8910 (890.85 per sec.) 3: transactions: 8659 (865.79 per sec.) 4: transactions: 8676 (867.34 per sec.) 5: transactions: 8532 (852.91 per sec.) and by 4-5% on an Intel dual-core system too: 2.6.23: 1: transactions: 4560 (455.94 per sec.) 2: transactions: 10094 (1009.30 per sec.) 3: transactions: 9755 (975.36 per sec.) 4: transactions: 9859 (985.78 per sec.) 5: transactions: 9701 (969.72 per sec.) 2.6.23 + sys_time-speedup.patch: 1: transactions: 4779 (477.84 per sec.) 2: transactions: 10103 (1010.14 per sec.) 3: transactions: 10141 (1013.93 per sec.) 4: transactions: 10371 (1036.89 per sec.) 5: transactions: 10178 (1017.50 per sec.) (the more CPUs the system has, the more speedup this patch gives for this particular workload.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-25Cleanup non-arch xtime uses, use get_seconds() or current_kernel_time().john stultz
This avoids use of the kernel-internal "xtime" variable directly outside of the actual time-related functions. Instead, use the helper functions that we already have available to us. This doesn't actually change any behaviour, but this will allow us to fix the fact that "xtime" isn't updated very often with CONFIG_NO_HZ (because much of the realtime information is maintained as separate offsets to 'xtime'), which has caused interfaces that use xtime directly to get a time that is out of sync with the real-time clock by up to a third of a second or so. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20Revert "sys_time() speedup"Linus Torvalds
This basically reverts commit 4e44f3497d41db4c3b9051c61410dee8ae4fb49c, while waiting for it to be re-done more completely. There are cases of people mixing "time()" with higher-resolution time sources, and we need to take the nanosecond offsets into account. Ingo has a patch that does that, but it's still under some discussion. In the meantime, just revert back to the old simple situation of just doing the whole exact timesource calculations. But rather than using do_gettimeofday(), use the internal nanosecond resolution getnstimeofday(), which at least avoids one unnecessary conversion (since we really don't care about whether the fractional seconds are nanoseconds or microseconds - we'll just throw them away). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20[IA64] remove time interpolatorBob Picco
Remove time_interpolator code (This is generic code, but only user was ia64. It has been superseded by the CONFIG_GENERIC_TIME code). Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Peter Keilty <peter.keilty@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-16sys_time() speedupIngo Molnar
Improve performance of sys_time(). sys_time() returns time in seconds, but it does so by calling do_gettimeofday() and then returning the tv_sec portion of the GTOD time. But the data structure "xtime", which is updated by every timer/scheduler tick, already offers HZ granularity time. The patch improves the sysbench OLTP macrobenchmark significantly: 2.6.22-rc6: #threads 1: transactions: 3733 (373.21 per sec.) 2: transactions: 6676 (667.46 per sec.) 3: transactions: 6957 (695.50 per sec.) 4: transactions: 7055 (705.48 per sec.) 5: transactions: 6596 (659.33 per sec.) 2.6.22-rc6 + sys_time.patch: 1: transactions: 4005 (400.47 per sec.) 2: transactions: 7379 (737.77 per sec.) 3: transactions: 7347 (734.49 per sec.) 4: transactions: 7468 (746.65 per sec.) 5: transactions: 7428 (742.47 per sec.) Mixed API uses of gettimeofday() and time() are guaranteed to be coherent via the use of a at-most-once-per-second slowpath that updates xtime. [akpm@linux-foundation.org: build fixes] Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Optimize timespec_trunc()Eric Dumazet
The first thing done by timespec_trunc() is : if (gran <= jiffies_to_usecs(1) * 1000) This should really be a test against a constant known at compile time. Alas, it isnt. jiffies_to_usec() was unilined so C compiler emits a function call and a multiply to compute : a CONSTANT. mov $0x1,%edi mov %rbx,0xffffffffffffffe8(%rbp) mov %r12,0xfffffffffffffff0(%rbp) mov %edx,%ebx mov %rsi,0xffffffffffffffc8(%rbp) mov %rsi,%r12 callq ffffffff80232010 <jiffies_to_usecs> imul $0x3e8,%eax,%eax cmp %ebx,%eax This patch reorders kernel/time.c a bit so that jiffies_to_usecs() is defined before timespec_trunc() so that compiler now generates : cmp $0x3d0900,%edx (HZ=250 on my machine) This gives a better code (timespec_trunc() becoming a leaf function), and shorter kernel size as well. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[TCP] tcp_probe: improvements for net-2.6.22Stephen Hemminger
Change tcp_probe to use ktime (needed to add one export). Add option to only get events when cwnd changes - from Doug Leith Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: convert network timestamps to ktime_tEric Dumazet
We currently use a special structure (struct skb_timeval) and plain 'struct timeval' to store packet timestamps in sk_buffs and struct sock. This has some drawbacks : - Fixed resolution of micro second. - Waste of space on 64bit platforms where sizeof(struct timeval)=16 I suggest using ktime_t that is a nice abstraction of high resolution time services, currently capable of nanosecond resolution. As sizeof(ktime_t) is 8 bytes, using ktime_t in 'struct sock' permits a 8 byte shrink of this structure on 64bit architectures. Some other structures also benefit from this size reduction (struct ipq in ipv4/ip_fragment.c, struct frag_queue in ipv6/reassembly.c, ...) Once this ktime infrastructure adopted, we can more easily provide nanosecond resolution on top of it. (ioctl SIOCGSTAMPNS and/or SO_TIMESTAMPNS/SCM_TIMESTAMPNS) Note : this patch includes a bug correction in compat_sock_get_timestamp() where a "err = 0;" was missing (so this syscall returned -ENOENT instead of 0) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> CC: John find <linux.kernel@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-04[PATCH] kernel/time.c: add missing symbol exportsThomas Bittermann
This patch adds 2 missing symbol exports: jiffies_to_timeval() and timeval_to_jiffies(). The (not yet merged) dm-raid4-5 module will need them, and they used to be indirectly exported by virtue of being inline functions. Commit 8b9365d753d9870bb6451504c13570b81923228f ("[PATCH] Uninline jiffies.h functions") uninlined them, and thus modules now need them explicitly exported to use them. Signed-off-by: Thomas Bittermann <t.bittermann@online.de> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: john stultz <johnstul@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Fix multiple conversion bugs in msecs_to_jiffiesIngo Molnar
Fix multiple conversion bugs in msecs_to_jiffies(). The main problem is that this condition: if (m > jiffies_to_msecs(MAX_JIFFY_OFFSET)) overflows if HZ is smaller than 1000! This change is user-visible: for HZ=250 SUS-compliant poll()-timeout value of -20 is mistakenly converted to 'immediate timeout'. (The new dyntick code also triggered this, that's how we noticed.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Uninline jiffies.h functionsIngo Molnar
There are loads of fat functions hidden in jiffies.h. Uninline them. No code changes. [jeremy@goop.org: export fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-01[PATCH] NTP: Move all the NTP related code to ntp.cjohn stultz
Move all the NTP related code to ntp.c [akpm@osdl.org: cleanups, build fix] Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: Introduce arch generic time accessorsjohn stultz
Introduces clocksource switching code and the arch generic time accessor functions that use the clocksource infrastructure. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-01Fix comments: s/granuality/granularity/Kalin KOZHUHAROV
I was grepping through the code and some `grep ganularity -R .` didn't catch what I thought. Then looking closer I saw the term "granuality" used in only four places (in comments) and granularity in many more places describing the same idea. Some other facts: dictionary.com does not know such a word define:granuality on google is not found (and pages for granuality are mostly related to patches to the kernel) it has not been discussed as a term on LKML, AFAICS (=Can Search) To be consistent, I think granularity should be used everywhere. Signed-off-by: Kalin KOZHUHAROV <kalin@thinrope.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-26[PATCH] hrtimers: remove nsec_t typedefRoman Zippel
nsec_t predates ktime_t and has mostly been superseded by it. In the few places that are left it's better to make it explicit that we're dealing with 64 bit values here. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] remove pps supportRoman Zippel
This removes the support for pps. It's completely unused within the kernel and is basically in the way for further cleanups. It should be easier to readd proper support for it after the rest has been converted to NTP4 (where the pps mechanisms are quite different from NTP3 anyway). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] Normalize timespec for negative values in ns_to_timespecGeorge Anzinger
- In case of a negative nsec value the result of the division must be normalized. - Remove inline from an exported function. Signed-off-by: George Anzinger <george@wildturkeyranch.net> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-31Don't try to "validate" a non-existing timeval.Linus Torvalds
settime() with a NULL timeval is silly but legal. Noticed by Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Remove getnstimestamp()Matt Helsley
Remove getnstimestamp() in favor of ktime.h's ktime_get_ts() Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: introduce nsec_t type and conversion functionsThomas Gleixner
- introduce the nsec_t type - basic nsec conversion routines: timespec_to_ns(), timeval_to_ns(), ns_to_timespec(), ns_to_timeval(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: validate timespec of do_sys_settimeofdayThomas Gleixner
Check if the timespec which is provided from user space is normalized. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: export deinlined mktimeAndrew Morton
This is now uninlined, but some modules use it. Make it a non-GPL export, since the inlined mktime() was also available that way. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: clean up mktime and make arguments constIngo Molnar
add 'const' to mktime arguments, and clean it up a bit Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: deinline mktime and set_normalized_timespecThomas Gleixner
mktime() and set_normalized_timespec() are large inline functions used in many places: deinline them. From: George Anzinger, off-by-1 bugfix Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] Add getnstimestamp functionMatt Helsley
There are several functions that might seem appropriate for a timestamp: get_cycles() current_kernel_time() do_gettimeofday() <read jiffies/jiffies_64> Each has problems with combinations of SMP-safety, low resolution, and monotonicity. This patch adds a new function that returns a monotonic SMP-safe timestamp with nanosecond resolution where available. Changes: Split timestamp into separate patch Moved to kernel/time.c Renamed to getnstimestamp Fixed unintended-pointer-arithmetic bug Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] NTP shift_right cleanupjohn stultz
Create a macro shift_right() that avoids the numerous ugly conditionals in the NTP code that look like: if(a < 0) b = -(-a >> shift); else b = a >> shift; Replacing it with: b = shift_right(a, shift); This should have zero effect on the logic, however it should probably have a bit of testing just to be sure. Also replace open-coded min/max with the macros. Signed-off-by : John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] missing exports of do_settimeofday() variantsAl Viro
frv, sh64, ia64 and sparc64 do not have do_settimeofday() exported (the last two are using variant in kernel/time.c). Exports added to match the rest of architectures. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-14[PATCH] Add missing export of getnstimeofday()Takashi Iwai
Adds the missing EXPORT_SYMBOL_GPL for getnstimeofday() when CONFIG_TIME_INTERPOLATION isn't set. Needed by drivers/char/mmtimer.c Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-28[PATCH] time interpolator: Fix settimeofday inaccuracyChristoph Lameter
settimeofday will set the time a little bit too early on systems using time interpolation since it subtracts the current interpolator offset from the time. This used to be necessary with the code in 2.6.9 and earlier but the new code resets the time interpolator after setting the time. Thus the time is set too early and gettimeofday will return a time slightly before the time specified with settimeofday if invoked immeditely after settimeofday. This removes the obsolete subtraction of the time interpolator offset and makes settimeofday set the time accurately. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
