path: root/kernel/sys.c
2011-05-11PM: Remove sysdev suspend, resume and shutdown operationsRafael J. Wysocki
Since suspend, resume and shutdown operations in struct sysdev_class and struct sysdev_driver are not used any more, remove them. Also drop sysdev_suspend(), sysdev_resume() and sysdev_shutdown() used for executing those operations and modify all of their users accordingly. This reduces kernel code size quite a bit and reduces its complexity. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23userns: user namespaces: convert all capable checks in kernel/sys.cSerge E. Hallyn
This allows setuid/setgid in containers. It also fixes some corner cases where kernel logic foregoes capability checks when uids are equivalent. The latter will need to be done throughout the whole kernel. Changelog: Jan 11: Use nsown_capable() as suggested by Bastian Blank. Jan 11: Fix logic errors in uid checks pointed out by Bastian. Feb 15: allow prlimit to current (was regression in previous version) Feb 23: remove debugging printks, uninline set_one_prio_perm and make it bool, and document its return value. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: allow sethostname in a containerSerge E. Hallyn
Changelog: Feb 23: let clone_uts_ns() handle setting uts->user_ns To do so we need to pass in the task_struct who'll get the utsname, so we can get its user_ns. Feb 23: As per Oleg's coment, just pass in tsk, instead of two of its members. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-15PM / Core: Introduce struct syscore_ops for core subsystems PMRafael J. Wysocki
Some subsystems need to carry out suspend/resume and shutdown operations with one CPU on-line and interrupts disabled. The only way to register such operations is to define a sysdev class and a sysdev specifically for this purpose which is cumbersome and inefficient. Moreover, the arguments taken by sysdev suspend, resume and shutdown callbacks are practically never necessary. For this reason, introduce a simpler interface allowing subsystems to register operations to be executed very late during system suspend and shutdown and very early during resume in the form of strcut syscore_ops objects. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-31Fix prlimit64 for suid/sgid processesKacper Kornet
Since check_prlimit_permission always fails in the case of SUID/GUID processes, such processes are not able to read or set their own limits. This commit changes this by assuming that process can always read/change its own limits. Signed-off-by: Kacper Kornet <kornet@camk.edu.pl> Acked-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13kmsg_dump: add kmsg_dump() calls to the reboot, halt, poweroff and ↵Seiji Aguchi
emergency_restart paths We need to know the reason why system rebooted in support service. However, we can't inform our customers of the reason because final messages are lost on current Linux kernel. This patch improves the situation above because the final messages are saved by adding kmsg_dump() to reboot, halt, poweroff and emergency_restart path. Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Marco Stornelli <marco.stornelli@gmail.com> Reviewed-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-30sched: Add 'autogroup' scheduling feature: automated per session task groupsMike Galbraith
A recurring complaint from CFS users is that parallel kbuild has a negative impact on desktop interactivity. This patch implements an idea from Linus, to automatically create task groups. Currently, only per session autogroups are implemented, but the patch leaves the way open for enhancement. Implementation: each task's signal struct contains an inherited pointer to a refcounted autogroup struct containing a task group pointer, the default for all tasks pointing to the init_task_group. When a task calls setsid(), a new task group is created, the process is moved into the new task group, and a reference to the preveious task group is dropped. Child processes inherit this task group thereafter, and increase it's refcount. When the last thread of a process exits, the process's reference is dropped, such that when the last process referencing an autogroup exits, the autogroup is destroyed. At runqueue selection time, IFF a task has no cgroup assignment, its current autogroup is used. Autogroup bandwidth is controllable via setting it's nice level through the proc filesystem: cat /proc/<pid>/autogroup Displays the task's group and the group's nice level. echo <nice level> > /proc/<pid>/autogroup Sets the task group's shares to the weight of nice <level> task. Setting nice level is rate limited for !admin users due to the abuse risk of task group locking. The feature is enabled from boot by default if CONFIG_SCHED_AUTOGROUP=y is selected, but can be disabled via the boot option noautogroup, and can also be turned on/off on the fly via: echo [01] > /proc/sys/kernel/sched_autogroup_enabled ... which will automatically move tasks to/from the root task group. Signed-off-by: Mike Galbraith <efault@gmx.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Paul Turner <pjt@google.com> Cc: Oleg Nesterov <oleg@redhat.com> [ Removed the task_group_path() debug code, and fixed !EVENTFD build failure. ] Signed-off-by: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1290281700.28711.9.camel@maggy.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-31pid: make setpgid() system call use RCU read-side critical sectionPaul E. McKenney
[ 23.584719] [ 23.584720] =================================================== [ 23.585059] [ INFO: suspicious rcu_dereference_check() usage. ] [ 23.585176] --------------------------------------------------- [ 23.585176] kernel/pid.c:419 invoked rcu_dereference_check() without protection! [ 23.585176] [ 23.585176] other info that might help us debug this: [ 23.585176] [ 23.585176] [ 23.585176] rcu_scheduler_active = 1, debug_locks = 1 [ 23.585176] 1 lock held by rc.sysinit/728: [ 23.585176] #0: (tasklist_lock){.+.+..}, at: [<ffffffff8104771f>] sys_setpgid+0x5f/0x193 [ 23.585176] [ 23.585176] stack backtrace: [ 23.585176] Pid: 728, comm: rc.sysinit Not tainted 2.6.36-rc2 #2 [ 23.585176] Call Trace: [ 23.585176] [<ffffffff8105b436>] lockdep_rcu_dereference+0x99/0xa2 [ 23.585176] [<ffffffff8104c324>] find_task_by_pid_ns+0x50/0x6a [ 23.585176] [<ffffffff8104c35b>] find_task_by_vpid+0x1d/0x1f [ 23.585176] [<ffffffff81047727>] sys_setpgid+0x67/0x193 [ 23.585176] [<ffffffff810029eb>] system_call_fastpath+0x16/0x1b [ 24.959669] type=1400 audit(1282938522.956:4): avc: denied { module_request } for pid=766 comm="hwclock" kmod="char-major-10-135" scontext=system_u:system_r:hwclock_t:s0 tcontext=system_u:system_r:kernel_t:s0 tclas It turns out that the setpgid() system call fails to enter an RCU read-side critical section before doing a PID-to-task_struct translation. This commit therefore does rcu_read_lock() before the translation, and also does rcu_read_unlock() after the last use of the returned pointer. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com>
2010-07-16rlimits: implement prlimit64 syscallJiri Slaby
This patch adds the code to support the sys_prlimit64 syscall which modifies-and-returns the rlim values of a selected process atomically. The first parameter, pid, being 0 means current process. Unlike the current implementation, it is a generic interface, architecture indepentent so that we needn't handle compat stuff anymore. In the future, after glibc start to use this we can deprecate sys_setrlimit and sys_getrlimit in favor to clean up the code finally. It also adds a possibility of changing limits of other processes. We check the user's permissions to do that and if it succeeds, the new limits are propagated online. This is good for large scale applications such as SAP or databases where administrators need to change limits time by time (e.g. on crashes increase core size). And it is unacceptable to restart the service. For safety, all rlim users now either use accessors or doesn't need them due to - locking - the fact a process was just forked and nobody else knows about it yet (and nobody can't thus read/write limits) hence it is safe to modify limits now. The limitation is that we currently stay at ulong internal representation. So the rlim64_is_infinity check is used where value is compared against ULONG_MAX on 32-bit which is the maximum value there. And since internally the limits are held in struct rlimit, converters which are used before and after do_prlimit call in sys_prlimit64 are introduced. Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2010-07-16rlimits: switch more rlimit syscalls to do_prlimitJiri Slaby
After we added more generic do_prlimit, switch sys_getrlimit to that. Also switch compat handling, so we can get rid of ugly __user casts and avoid setting process' address limit to kernel data and back. Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2010-07-16rlimits: redo do_setrlimit to more generic do_prlimitJiri Slaby
It now allows also reading of limits. I.e. all read and writes will later use this function. It takes two parameters, new and old limits which can be both NULL. If new is non-NULL, the value in it is set to rlimits. If old is non-NULL, current rlimits are stored there. If both are non-NULL, old are stored prior to setting the new ones, atomically. (Similar to sigaction.) Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2010-07-16rlimits: do security check under task_lockJiri Slaby
Do security_task_setrlimit under task_lock. Other tasks may change limits under our hands while we are checking limits inside the function. From now on, they can't. Note that all the security work is done under a spinlock here now. Security hooks count with that, they are called from interrupt context (like security_task_kill) and with spinlocks already held (e.g. capable->security_capable). Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: James Morris <jmorris@namei.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com>
2010-07-16rlimits: allow setrlimit to non-current tasksJiri Slaby
Add locking to allow setrlimit accept task parameter other than current. Namely, lock tasklist_lock for read and check whether the task structure has sighand non-null. Do all the signal processing under that lock still held. There are some points: 1) security_task_setrlimit is now called with that lock held. This is not new, many security_* functions are called with this lock held already so it doesn't harm (all this security_* stuff does almost the same). 2) task->sighand->siglock (in update_rlimit_cpu) is nested in tasklist_lock. This dependence is already existing. 3) tsk->alloc_lock is nested in tasklist_lock. This is OK too, already existing dependence. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com>
2010-07-16rlimits: split sys_setrlimitJiri Slaby
Create do_setrlimit from sys_setrlimit and declare do_setrlimit in the resource header. This is the first phase to have generic do_prlimit which allows to be called from read, write and compat rlimits code. The new do_setrlimit also accepts a task pointer to change the limits of. Currently, it cannot be other than current, but this will change with locking later. Also pass tsk->group_leader to security_task_setrlimit to check whether current is allowed to change rlimits of the process and not its arbitrary thread because it makes more sense given that rlimit are per process and not per-thread. Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2010-07-16rlimits: make sure ->rlim_max never grows in sys_setrlimitOleg Nesterov
Mostly preparation for Jiri's changes, but probably makes sense anyway. sys_setrlimit() checks new_rlim.rlim_max <= old_rlim->rlim_max, but when it takes task_lock() old_rlim->rlim_max can be already lowered. Move this check under task_lock(). Currently this is not important, we can only race with our sub-thread, this means the application is stupid. But when we change the code to allow the update of !current task's limits, it becomes important to make sure ->rlim_max can be lowered "reliably" even if we race with the application doing sys_setrlimit(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2010-07-16rlimits: add task_struct to update_rlimit_cpuJiri Slaby
Add task_struct as a parameter to update_rlimit_cpu to be able to set rlimit_cpu of different task than current. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: James Morris <jmorris@namei.org>
2010-07-16rlimits: security, add task_struct to setrlimitJiri Slaby
Add task_struct to task_setrlimit of security_operations to be able to set rlimit of task other than current. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Eric Paris <eparis@redhat.com> Acked-by: James Morris <jmorris@namei.org>
2010-05-27kmod: add init function to usermodehelperNeil Horman
About 6 months ago, I made a set of changes to how the core-dump-to-a-pipe feature in the kernel works. We had reports of several races, including some reports of apps bypassing our recursion check so that a process that was forked as part of a core_pattern setup could infinitely crash and refork until the system crashed. We fixed those by improving our recursion checks. The new check basically refuses to fork a process if its core limit is zero, which works well. Unfortunately, I've been getting grief from maintainer of user space programs that are inserted as the forked process of core_pattern. They contend that in order for their programs (such as abrt and apport) to work, all the running processes in a system must have their core limits set to a non-zero value, to which I say 'yes'. I did this by design, and think thats the right way to do things. But I've been asked to ease this burden on user space enough times that I thought I would take a look at it. The first suggestion was to make the recursion check fail on a non-zero 'special' number, like one. That way the core collector process could set its core size ulimit to 1, and enable the kernel's recursion detection. This isn't a bad idea on the surface, but I don't like it since its opt-in, in that if a program like abrt or apport has a bug and fails to set such a core limit, we're left with a recursively crashing system again. So I've come up with this. What I've done is modify the call_usermodehelper api such that an extra parameter is added, a function pointer which will be called by the user helper task, after it forks, but before it exec's the required process. This will give the caller the opportunity to get a call back in the processes context, allowing it to do whatever it needs to to the process in the kernel prior to exec-ing the user space code. In the case of do_coredump, this callback is ues to set the core ulimit of the helper process to 1. This elimnates the opt-in problem that I had above, as it allows the ulimit for core sizes to be set to the value of 1, which is what the recursion check looks for in do_coredump. This patch: Create new function call_usermodehelper_fns() and allow it to assign both an init and cleanup function, as we'll as arbitrary data. The init function is called from the context of the forked process and allows for customization of the helper process prior to calling exec. Its return code gates the continuation of the process, or causes its exit. Also add an arbitrary data pointer to the subprocess_info struct allowing for data to be passed from the caller to the new process, and the subsequent cleanup process Also, use this patch to cleanup the cleanup function. It currently takes an argp and envp pointer for freeing, which is ugly. Lets instead just make the subprocess_info structure public, and pass that to the cleanup and init routines Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-06Merge branch 'master' into nextJames Morris
2010-04-24kernel/sys.c: fix compat uname machineAndreas Schwab
On ppc64 you get this error: $ setarch ppc -R true setarch: ppc: Unrecognized architecture because uname still reports ppc64 as the machine. So mask off the personality flags when checking for PER_LINUX32. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-12security: remove dead hook task_setgidEric Paris
Unused hook. Remove. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-12security: remove dead hook task_setuidEric Paris
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12Add generic sys_olduname()Christoph Hellwig
Add generic implementations of the old and really old uname system calls. Note that sh only implements sys_olduname but not sys_oldolduname, but I'm not going to bother with another ifdef for that special case. m32r implemented an old uname but never wired it up, so kill it, too. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12improve sys_newuname() for compat architecturesChristoph Hellwig
On an architecture that supports 32-bit compat we need to override the reported machine in uname with the 32-bit value. Instead of doing this separately in every architecture introduce a COMPAT_UTS_MACHINE define in <asm/compat.h> and apply it directly in sys_newuname(). Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06kernel core: use helpers for rlimitsJiri Slaby
Make sure compiler won't do weird things with limits. E.g. fetching them twice may return 2 different values after writable limits are implemented. I.e. either use rlimit helpers added in commit 3e10e716abf3 ("resource: add helpers for fetching rlimits") or ACCESS_ONCE if not applicable. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-28Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits) sched: Fix SCHED_MC regression caused by change in sched cpu_power sched: Don't use possibly stale sched_class kthread, sched: Remove reference to kthread_create_on_cpu sched: cpuacct: Use bigger percpu counter batch values for stats counters percpu_counter: Make __percpu_counter_add an inline function on UP sched: Remove member rt_se from struct rt_rq sched: Change usage of rt_rq->rt_se to rt_rq->tg->rt_se[cpu] sched: Remove unused update_shares_locked() sched: Use for_each_bit sched: Queue a deboosted task to the head of the RT prio queue sched: Implement head queueing for sched_rt sched: Extend enqueue_task to allow head queueing sched: Remove USER_SCHED sched: Fix the place where group powers are updated sched: Assume *balance is valid sched: Remove load_balance_newidle() sched: Unify load_balance{,_newidle}() sched: Add a lock break for PREEMPT=y sched: Remove from fwd decls sched: Remove rq_iterator from move_one_task ... Fix up trivial conflicts in kernel/sched.c
2010-02-22kernel/sys.c: fix missing rcu protection for sys_getpriority()Tetsuo Handa
find_task_by_vpid() is not safe without rcu_read_lock(). 2.6.33-rc7 got RCU protection for sys_setpriority() but missed it for sys_getpriority(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-21sched: Remove USER_SCHEDDhaval Giani
Remove the USER_SCHED feature. It has been scheduled to be removed in 2.6.34 as per http://marc.info/?l=linux-kernel&m=125728479022976&w=2 Signed-off-by: Dhaval Giani <dhaval.giani@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1263990378.24844.3.camel@localhost> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-19Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sys: Fix missing rcu protection for __task_cred() access signals: Fix more rcu assumptions signal: Fix racy access to __task_cred in kill_pid_info_as_uid()
2009-12-15kernel/sys.c: fix "warning: do-while statement is not a compound statement" ↵H Hartley Sweeten
noise do_each_thread/while_each_thread wrap a block of code that is in this format: for (...) do ... while If curly braces do not surround the inner loop the following warning is generated by sparse: warning: do-while statement is not a compound statement Fix the warning by adding the braces. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-10sys: Fix missing rcu protection for __task_cred() accessThomas Gleixner
commit c69e8d9 (CRED: Use RCU to access another task's creds and to release a task's own creds) added non rcu_read_lock() protected access to task creds of the target task in set_prio_one(). The comment above the function says: * - the caller must hold the RCU read lock The calling code in sys_setpriority does read_lock(&tasklist_lock) but not rcu_read_lock(). This works only when CONFIG_TREE_PREEMPT_RCU=n. With CONFIG_TREE_PREEMPT_RCU=y the rcu_callbacks can run in the tick interrupt when they see no read side critical section. There is another instance of __task_cred() in sys_setpriority() itself which is equally unprotected. Wrap the whole code section into a rcu read side critical section to fix this quick and dirty. Will be revisited in course of the read_lock(&tasklist_lock) -> rcu crusade. Oleg noted further: This also fixes another bug here. find_task_by_vpid() is not safe without rcu_read_lock(). I do not mean it is not safe to use the result, just find_pid_ns() by itself is not safe. Usually tasklist gives enough protection, but if copy_process() fails it calls free_pid() lockless and does call_rcu(delayed_put_pid(). This means, without rcu lock find_pid_ns() can't scan the hash table safely. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <20091210004703.029784964@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2009-12-09Merge branch 'bkl-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'bkl-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sys: Remove BKL from sys_reboot pm_qos: clean up racy global "name" variable pm_qos: remove BKL
2009-12-02sched, cputime: Introduce thread_group_times()Hidetoshi Seto
This is a real fix for problem of utime/stime values decreasing described in the thread: http://lkml.org/lkml/2009/11/3/522 Now cputime is accounted in the following way: - {u,s}time in task_struct are increased every time when the thread is interrupted by a tick (timer interrupt). - When a thread exits, its {u,s}time are added to signal->{u,s}time, after adjusted by task_times(). - When all threads in a thread_group exits, accumulated {u,s}time (and also c{u,s}time) in signal struct are added to c{u,s}time in signal struct of the group's parent. So {u,s}time in task struct are "raw" tick count, while {u,s}time and c{u,s}time in signal struct are "adjusted" values. And accounted values are used by: - task_times(), to get cputime of a thread: This function returns adjusted values that originates from raw {u,s}time and scaled by sum_exec_runtime that accounted by CFS. - thread_group_cputime(), to get cputime of a thread group: This function returns sum of all {u,s}time of living threads in the group, plus {u,s}time in the signal struct that is sum of adjusted cputimes of all exited threads belonged to the group. The problem is the return value of thread_group_cputime(), because it is mixed sum of "raw" value and "adjusted" value: group's {u,s}time = foreach(thread){{u,s}time} + exited({u,s}time) This misbehavior can break {u,s}time monotonicity. Assume that if there is a thread that have raw values greater than adjusted values (e.g. interrupted by 1000Hz ticks 50 times but only runs 45ms) and if it exits, cputime will decrease (e.g. -5ms). To fix this, we could do: group's {u,s}time = foreach(t){task_times(t)} + exited({u,s}time) But task_times() contains hard divisions, so applying it for every thread should be avoided. This patch fixes the above problem in the following way: - Modify thread's exit (= __exit_signal()) not to use task_times(). It means {u,s}time in signal struct accumulates raw values instead of adjusted values. As the result it makes thread_group_cputime() to return pure sum of "raw" values. - Introduce a new function thread_group_times(*task, *utime, *stime) that converts "raw" values of thread_group_cputime() to "adjusted" values, in same calculation procedure as task_times(). - Modify group's exit (= wait_task_zombie()) to use this introduced thread_group_times(). It make c{u,s}time in signal struct to have adjusted values like before this patch. - Replace some thread_group_cputime() by thread_group_times(). This replacements are only applied where conveys the "adjusted" cputime to users, and where already uses task_times() near by it. (i.e. sys_times(), getrusage(), and /proc/<PID>/stat.) This patch have a positive side effect: - Before this patch, if a group contains many short-life threads (e.g. runs 0.9ms and not interrupted by ticks), the group's cputime could be invisible since thread's cputime was accumulated after adjusted: imagine adjustment function as adj(ticks, runtime), {adj(0, 0.9) + adj(0, 0.9) + ....} = {0 + 0 + ....} = 0. After this patch it will not happen because the adjustment is applied after accumulated. v2: - remove if()s, put new variables into signal_struct. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Spencer Candland <spencer@bluehost.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> LKML-Reference: <4B162517.8040909@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-26sched: Introduce task_times() to replace task_{u,s}time() pairHidetoshi Seto
Functions task_{u,s}time() are called in pair in almost all cases. However task_stime() is implemented to call task_utime() from its inside, so such paired calls run task_utime() twice. It means we do heavy divisions (div_u64 + do_div) twice to get utime and stime which can be obtained at same time by one set of divisions. This patch introduces a function task_times(*tsk, *utime, *stime) to retrieve utime and stime at once in better, optimized way. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Spencer Candland <spencer@bluehost.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> LKML-Reference: <4B0E16AE.906@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-29Merge branch 'hwpoison-2.6.32' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison-2.6.32' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: HWPOISON: fix invalid page count in printk output HWPOISON: Allow schedule_on_each_cpu() from keventd HWPOISON: fix/proc/meminfo alignment HWPOISON: fix oops on ksm pages HWPOISON: Fix page count leak in hwpoison late kill in do_swap_page HWPOISON: return early on non-LRU pages HWPOISON: Add brief hwpoison description to Documentation HWPOISON: Clean up PR_MCE_KILL interface
2009-10-29connector: fix regression introduced by sid connectorChristian Borntraeger
Since commit 02b51df1b07b4e9ca823c89284e704cadb323cd1 (proc connector: add event for process becoming session leader) we have the following warning: Badness at kernel/softirq.c:143 [...] Krnl PSW : 0404c00180000000 00000000001481d4 (local_bh_enable+0xb0/0xe0) [...] Call Trace: ([<000000013fe04100>] 0x13fe04100) [<000000000048a946>] sk_filter+0x9a/0xd0 [<000000000049d938>] netlink_broadcast+0x2c0/0x53c [<00000000003ba9ae>] cn_netlink_send+0x272/0x2b0 [<00000000003baef0>] proc_sid_connector+0xc4/0xd4 [<0000000000142604>] __set_special_pids+0x58/0x90 [<0000000000159938>] sys_setsid+0xb4/0xd8 [<00000000001187fe>] sysc_noemu+0x10/0x16 [<00000041616cb266>] 0x41616cb266 The warning is ---> WARN_ON_ONCE(in_irq() || irqs_disabled()); The network code must not be called with disabled interrupts but sys_setsid holds the tasklist_lock with spinlock_irq while calling the connector. After a discussion we agreed that we can move proc_sid_connector from __set_special_pids to sys_setsid. We also agreed that it is sufficient to change the check from task_session(curr) != pid into err > 0, since if we don't change the session, this means we were already the leader and return -EPERM. One last thing: There is also daemonize(), and some people might want to get a notification in that case. Since daemonize() is only needed if a user space does kernel_thread this does not look important (and there seems to be no consensus if this connector should be called in daemonize). If we really want this, we can add proc_sid_connector to daemonize() in an additional patch (Scott?) Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Scott James Remnant <scott@ubuntu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: David S. Miller <davem@davemloft.net> Acked-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-14sys: Remove BKL from sys_rebootThomas Gleixner
Serialization of sys_reboot can be done local. The BKL is not protecting anything else. LKML-Reference: <20091010153349.405590702@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-10-04HWPOISON: Clean up PR_MCE_KILL interfaceAndi Kleen
While writing the manpage I noticed some shortcomings in the current interface. - Define symbolic names for all the different values - Boundary check the kill mode values - For symmetry add a get interface too. This allows library code to get/set the current state. - For consistency define a PR_MCE_KILL_DEFAULT value Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-09-24Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits) HWPOISON: Enable error_remove_page on btrfs HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs HWPOISON: Add madvise() based injector for hardware poisoned pages v4 HWPOISON: Enable error_remove_page for NFS HWPOISON: Enable .remove_error_page for migration aware file systems HWPOISON: The high level memory error handler in the VM v7 HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process HWPOISON: shmem: call set_page_dirty() with locked page HWPOISON: Define a new error_remove_page address space op for async truncation HWPOISON: Add invalidate_inode_page HWPOISON: Refactor truncate to allow direct truncating of page v2 HWPOISON: check and isolate corrupted free pages v2 HWPOISON: Handle hardware poisoned pages in try_to_unmap HWPOISON: Use bitmask/action code for try_to_unmap behaviour HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2 HWPOISON: Add poison check to page fault handling HWPOISON: Add basic support for poisoned pages in fault handler v3 HWPOISON: Add new SIGBUS error codes for hardware poison signals HWPOISON: Add support for poison swap entries v2 HWPOISON: Export some rmap vma locking to outside world ...
2009-09-23getrusage: fill ru_maxrss valueJiri Pirko
Make ->ru_maxrss value in struct rusage filled accordingly to rss hiwater mark. This struct is filled as a parameter to getrusage syscall. ->ru_maxrss value is set to KBs which is the way it is done in BSD systems. /usr/bin/time (gnu time) application converts ->ru_maxrss to KBs which seems to be incorrect behavior. Maintainer of this util was notified by me with the patch which corrects it and cc'ed. To make this happen we extend struct signal_struct by two fields. The first one is ->maxrss which we use to store rss hiwater of the task. The second one is ->cmaxrss which we use to store highest rss hiwater of all task childs. These values are used in k_getrusage() to actually fill ->ru_maxrss. k_getrusage() uses current rss hiwater value directly if mm struct exists. Note: exec() clear mm->hiwater_rss, but doesn't clear sig->maxrss. it is intetionally behavior. *BSD getrusage have exec() inheriting. test programs ======================================================== getrusage.c =========== #include <stdio.h> #include <stdlib.h> #include <string.h> #include <sys/types.h> #include <sys/time.h> #include <sys/resource.h> #include <sys/types.h> #include <sys/wait.h> #include <unistd.h> #include <signal.h> #include <sys/mman.h> #include "common.h" #define err(str) perror(str), exit(1) int main(int argc, char** argv) { int status; printf("allocate 100MB\n"); consume(100); printf("testcase1: fork inherit? \n"); printf(" expect: initial.self ~= child.self\n"); show_rusage("initial"); if (__fork()) { wait(&status); } else { show_rusage("fork child"); _exit(0); } printf("\n"); printf("testcase2: fork inherit? (cont.) \n"); printf(" expect: initial.children ~= 100MB, but child.children = 0\n"); show_rusage("initial"); if (__fork()) { wait(&status); } else { show_rusage("child"); _exit(0); } printf("\n"); printf("testcase3: fork + malloc \n"); printf(" expect: child.self ~= initial.self + 50MB\n"); show_rusage("initial"); if (__fork()) { wait(&status); } else { printf("allocate +50MB\n"); consume(50); show_rusage("fork child"); _exit(0); } printf("\n"); printf("testcase4: grandchild maxrss\n"); printf(" expect: post_wait.children ~= 300MB\n"); show_rusage("initial"); if (__fork()) { wait(&status); show_rusage("post_wait"); } else { system("./child -n 0 -g 300"); _exit(0); } printf("\n"); printf("testcase5: zombie\n"); printf(" expect: pre_wait ~= initial, IOW the zombie process is not accounted.\n"); printf(" post_wait ~= 400MB, IOW wait() collect child's max_rss. \n"); show_rusage("initial"); if (__fork()) { sleep(1); /* children become zombie */ show_rusage("pre_wait"); wait(&status); show_rusage("post_wait"); } else { system("./child -n 400"); _exit(0); } printf("\n"); printf("testcase6: SIG_IGN\n"); printf(" expect: initial ~= after_zombie (child's 500MB alloc should be ignored).\n"); show_rusage("initial"); signal(SIGCHLD, SIG_IGN); if (__fork()) { sleep(1); /* children become zombie */ show_rusage("after_zombie"); } else { system("./child -n 500"); _exit(0); } printf("\n"); signal(SIGCHLD, SIG_DFL); printf("testcase7: exec (without fork) \n"); printf(" expect: initial ~= exec \n"); show_rusage("initial"); execl("./child", "child", "-v", NULL); return 0; } child.c ======= #include <sys/types.h> #include <unistd.h> #include <sys/types.h> #include <sys/wait.h> #include <stdio.h> #include <stdlib.h> #include <string.h> #include <sys/types.h> #include <sys/time.h> #include <sys/resource.h> #include "common.h" int main(int argc, char** argv) { int status; int c; long consume_size = 0; long grandchild_consume_size = 0; int show = 0; while ((c = getopt(argc, argv, "n:g:v")) != -1) { switch (c) { case 'n': consume_size = atol(optarg); break; case 'v': show = 1; break; case 'g': grandchild_consume_size = atol(optarg); break; default: break; } } if (show) show_rusage("exec"); if (consume_size) { printf("child alloc %ldMB\n", consume_size); consume(consume_size); } if (grandchild_consume_size) { if (fork()) { wait(&status); } else { printf("grandchild alloc %ldMB\n", grandchild_consume_size); consume(grandchild_consume_size); exit(0); } } return 0; } common.c ======== #include <stdio.h> #include <stdlib.h> #include <string.h> #include <sys/types.h> #include <sys/time.h> #include <sys/resource.h> #include <sys/types.h> #include <sys/wait.h> #include <unistd.h> #include <signal.h> #include <sys/mman.h> #include "common.h" #define err(str) perror(str), exit(1) void show_rusage(char *prefix) { int err, err2; struct rusage rusage_self; struct rusage rusage_children; printf("%s: ", prefix); err = getrusage(RUSAGE_SELF, &rusage_self); if (!err) printf("self %ld ", rusage_self.ru_maxrss); err2 = getrusage(RUSAGE_CHILDREN, &rusage_children); if (!err2) printf("children %ld ", rusage_children.ru_maxrss); printf("\n"); } /* Some buggy OS need this worthless CPU waste. */ void make_pagefault(void) { void *addr; int size = getpagesize(); int i; for (i=0; i<1000; i++) { addr = mmap(NULL, size, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANON, -1, 0); if (addr == MAP_FAILED) err("make_pagefault"); memset(addr, 0, size); munmap(addr, size); } } void consume(int mega) { size_t sz = mega * 1024 * 1024; void *ptr; ptr = malloc(sz); memset(ptr, 0, sz); make_pagefault(); } pid_t __fork(void) { pid_t pid; pid = fork(); make_pagefault(); return pid; } common.h ======== void show_rusage(char *prefix); void make_pagefault(void); void consume(int mega); pid_t __fork(void); FreeBSD result (expected result) ======================================================== allocate 100MB testcase1: fork inherit? expect: initial.self ~= child.self initial: self 103492 children 0 fork child: self 103540 children 0 testcase2: fork inherit? (cont.) expect: initial.children ~= 100MB, but child.children = 0 initial: self 103540 children 103540 child: self 103564 children 0 testcase3: fork + malloc expect: child.self ~= initial.self + 50MB initial: self 103564 children 103564 allocate +50MB fork child: self 154860 children 0 testcase4: grandchild maxrss expect: post_wait.children ~= 300MB initial: self 103564 children 154860 grandchild alloc 300MB post_wait: self 103564 children 308720 testcase5: zombie expect: pre_wait ~= initial, IOW the zombie process is not accounted. post_wait ~= 400MB, IOW wait() collect child's max_rss. initial: self 103564 children 308720 child alloc 400MB pre_wait: self 103564 children 308720 post_wait: self 103564 children 411312 testcase6: SIG_IGN expect: initial ~= after_zombie (child's 500MB alloc should be ignored). initial: self 103564 children 411312 child alloc 500MB after_zombie: self 103624 children 411312 testcase7: exec (without fork) expect: initial ~= exec initial: self 103624 children 411312 exec: self 103624 children 411312 Linux result (actual test result) ======================================================== allocate 100MB testcase1: fork inherit? expect: initial.self ~= child.self initial: self 102848 children 0 fork child: self 102572 children 0 testcase2: fork inherit? (cont.) expect: initial.children ~= 100MB, but child.children = 0 initial: self 102876 children 102644 child: self 102572 children 0 testcase3: fork + malloc expect: child.self ~= initial.self + 50MB initial: self 102876 children 102644 allocate +50MB fork child: self 153804 children 0 testcase4: grandchild maxrss expect: post_wait.children ~= 300MB initial: self 102876 children 153864 grandchild alloc 300MB post_wait: self 102876 children 307536 testcase5: zombie expect: pre_wait ~= initial, IOW the zombie process is not accounted. post_wait ~= 400MB, IOW wait() collect child's max_rss. initial: self 102876 children 307536 child alloc 400MB pre_wait: self 102876 children 307536 post_wait: self 102876 children 410076 testcase6: SIG_IGN expect: initial ~= after_zombie (child's 500MB alloc should be ignored). initial: self 102876 children 410076 child alloc 500MB after_zombie: self 102880 children 410076 testcase7: exec (without fork) expect: initial ~= exec initial: self 102880 children 410076 exec: self 102880 children 410076 Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-16HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per processAndi Kleen
This allows processes to override their early/late kill behaviour on hardware memory errors. Typically applications which are memory error aware is better of with early kill (see the error as soon as possible), all others with late kill (only see the error when the error is really impacting execution) There's a global sysctl, but this way an application can set its specific policy. We're using two bits, one to signify that the process stated its intention and that I also made the prctl future proof by enforcing the unused arguments are 0. The state is inherited to children. Note this makes us officially run out of process flags on 32bit, but the next patch can easily add another field. Manpage patch will be supplied separately. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-06-16groups: move code to kernel/groups.cAlexey Dobriyan
Move supplementary groups implementation to kernel/groups.c . kernel/sys.c already accumulated quite a few random stuff. Do strictly copy/paste + add required headers to compile. Compile-tested on many configs and archs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-29Merge branch 'linus' into perfcounters/coreIngo Molnar
Merge reason: This brach was on -rc1, refresh it to almost-rc4 to pick up the latest upstream fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-13kernel/sys.c: clean up sys_shutdown exit pathAndi Kleen
Impact: cleanup, fix Clean up sys_shutdown() exit path. Factor out common code. Return correct error code instead of always 0 on failure. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06Merge branch 'linus' into perfcounters/core-v2Ingo Molnar
Merge reason: we have gathered quite a few conflicts, need to merge upstream Conflicts: arch/powerpc/kernel/Makefile arch/x86/ia32/ia32entry.S arch/x86/include/asm/hardirq.h arch/x86/include/asm/unistd_32.h arch/x86/include/asm/unistd_64.h arch/x86/kernel/cpu/common.c arch/x86/kernel/irq.c arch/x86/kernel/syscall_table_32.S arch/x86/mm/iomap_32.c include/linux/sched.h kernel/Makefile Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: Remove two unneeded exports and make two symbols static in fs/mpage.c Cleanup after commit 585d3bc06f4ca57f975a5a1f698f65a45ea66225 Trim includes of fdtable.h Don't crap into descriptor table in binfmt_som Trim includes in binfmt_elf Don't mess with descriptor table in load_elf_binary() Get rid of indirect include of fs_struct.h New helper - current_umask() check_unsafe_exec() doesn't care about signal handlers sharing New locking/refcounting for fs_struct Take fs_struct handling to new file (fs/fs_struct.c) Get rid of bumping fs_struct refcount in pivot_root(2) Kill unsharing fs_struct in __set_personality()
2009-04-02pids: kill signal_struct-> __pgrp/__session and friendsOleg Nesterov
We are wasting 2 words in signal_struct without any reason to implement task_pgrp_nr() and task_session_nr(). task_session_nr() has no callers since 2e2ba22ea4fd4bb85f0fa37c521066db6775cbef, we can remove it. task_pgrp_nr() is still (I believe wrongly) used in fs/autofsX and fs/coda. This patch reimplements task_pgrp_nr() via task_pgrp_nr_ns(), and kills __pgrp/__session and the related helpers. The change in drivers/char/tty_io.c is cosmetic, but hopefully makes sense anyway. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Alan Cox <number6@the-village.bc.nu> [tty parts] Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31Get rid of indirect include of fs_struct.hAl Viro
Don't pull it in sched.h; very few files actually need it and those can include directly. sched.h itself only needs forward declaration of struct fs_struct; Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
