path: root/kernel/rcutree.c
2009-12-03rcu: Add expedited grace-period support for preemptible RCUPaul E. McKenney
Implement an synchronize_rcu_expedited() for preemptible RCU that actually is expedited. This uses synchronize_sched_expedited() to force all threads currently running in a preemptible-RCU read-side critical section onto the appropriate ->blocked_tasks[] list, then takes a snapshot of all of these lists and waits for them to drain. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1259784616158-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-03rcu: Enable fourth level of TREE_RCU hierarchyPaul E. McKenney
Enable a fourth level of rcu_node hierarchy for TREE_RCU and TREE_PREEMPT_RCU. This is for stress-testing and experiemental purposes only, although in theory this would enable 16,777,216 CPUs on 64-bit systems, though only 1,048,576 CPUs on 32-bit systems. Normal experimental use of this fourth level will normally set CONFIG_RCU_FANOUT=2, requiring a 16-CPU system, though the more adventurous (and more fortunate) experimenters may wish to chose CONFIG_RCU_FANOUT=3 for 81-CPU systems or even CONFIG_RCU_FANOUT=4 for 256-CPU systems. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12597846161257-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-03rcu: Rename "quiet" functionsPaul E. McKenney
The number of "quiet" functions has grown recently, and the names are no longer very descriptive. The point of all of these functions is to do some portion of the task of reporting a quiescent state, so rename them accordingly: o cpu_quiet() becomes rcu_report_qs_rdp(), which reports a quiescent state to the per-CPU rcu_data structure. If this turns out to be a new quiescent state for this grace period, then rcu_report_qs_rnp() will be invoked to propagate the quiescent state up the rcu_node hierarchy. o cpu_quiet_msk() becomes rcu_report_qs_rnp(), which reports a quiescent state for a given CPU (or possibly a set of CPUs) up the rcu_node hierarchy. o cpu_quiet_msk_finish() becomes rcu_report_qs_rsp(), which reports a full set of quiescent states to the global rcu_state structure. o task_quiet() becomes rcu_report_unblock_qs_rnp(), which reports a quiescent state due to a task exiting an RCU read-side critical section that had previously blocked in that same critical section. As indicated by the new name, this type of quiescent state is reported up the rcu_node hierarchy (using rcu_report_qs_rnp() to do so). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12597846163698-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-22rcu: Re-arrange code to reduce #ifdef painPaul E. McKenney
Remove #ifdefs from kernel/rcupdate.c and include/linux/rcupdate.h by moving code to include/linux/rcutiny.h, include/linux/rcutree.h, and kernel/rcutree.c. Also remove some definitions that are no longer used. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1258908830885-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-22rcu: Eliminate unneeded function wrappingPaul E. McKenney
The functions rcu_init() is a wrapper for __rcu_init(), and also sets up the CPU-hotplug notifier for rcu_barrier_cpu_hotplug(). But TINY_RCU doesn't need CPU-hotplug notification, and the rcu_barrier_cpu_hotplug() is a simple wrapper for rcu_cpu_notify(). So push rcu_init() out to kernel/rcutree.c and kernel/rcutiny.c and get rid of the wrapper function rcu_barrier_cpu_hotplug(). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12589088302320-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-22rcu: Fix grace-period-stall bug on large systems with CPU hotplugPaul E. McKenney
When the last CPU of a given leaf rcu_node structure goes offline, all of the tasks queued on that leaf rcu_node structure (due to having blocked in their current RCU read-side critical sections) are requeued onto the root rcu_node structure. This requeuing is carried out by rcu_preempt_offline_tasks(). However, it is possible that these queued tasks are the only thing preventing the leaf rcu_node structure from reporting a quiescent state up the rcu_node hierarchy. Unfortunately, the old code would fail to do this reporting, resulting in a grace-period stall given the following sequence of events: 1. Kernel built for more than 32 CPUs on 32-bit systems or for more than 64 CPUs on 64-bit systems, so that there is more than one rcu_node structure. (Or CONFIG_RCU_FANOUT is artificially set to a number smaller than CONFIG_NR_CPUS.) 2. The kernel is built with CONFIG_TREE_PREEMPT_RCU. 3. A task running on a CPU associated with a given leaf rcu_node structure blocks while in an RCU read-side critical section -and- that CPU has not yet passed through a quiescent state for the current RCU grace period. This will cause the task to be queued on the leaf rcu_node's blocked_tasks[] array, in particular, on the element of this array corresponding to the current grace period. 4. Each of the remaining CPUs corresponding to this same leaf rcu_node structure pass through a quiescent state. However, the task is still in its RCU read-side critical section, so these quiescent states cannot be reported further up the rcu_node hierarchy. Nevertheless, all bits in the leaf rcu_node structure's ->qsmask field are now zero. 5. Each of the remaining CPUs go offline. (The events in step #4 and #5 can happen in any order as long as each CPU passes through a quiescent state before going offline.) 6. When the last CPU goes offline, __rcu_offline_cpu() will invoke rcu_preempt_offline_tasks(), which will move the task to the root rcu_node structure, but without reporting a quiescent state up the rcu_node hierarchy (and this failure to report a quiescent state is the bug). But because this leaf rcu_node structure's ->qsmask field is already zero and its ->block_tasks[] entries are all empty, force_quiescent_state() will skip this rcu_node structure. Therefore, grace periods are now hung. This patch abstracts some code out of rcu_read_unlock_special(), calling the result task_quiet() by analogy with cpu_quiet(), and invokes task_quiet() from both rcu_read_lock_special() and __rcu_offline_cpu(). Invoking task_quiet() from __rcu_offline_cpu() reports the quiescent state up the rcu_node hierarchy, fixing the bug. This ends up requiring a separate lock_class_key per level of the rcu_node hierarchy, which this patch also provides. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12589088301770-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-14rcu: Eliminate __rcu_pending() false positivesPaul E. McKenney
Now that there are both ->gpnum and ->completed fields in the rcu_node structure, __rcu_pending() should check rdp->gpnum and rdp->completed against rnp->gpnum and rdp->completed, respectively, instead of the prior comparison against the rcu_state fields rsp->gpnum and rsp->completed. Given the old comparison, __rcu_pending() could return 1, resulting in a needless raise_softirq(RCU_SOFTIRQ). This useless work would happen if RCU responded to a scheduling-clock interrupt after the rcu_state fields had been updated, but before the rcu_node fields had been updated. Changing the comparison from the rcu_state fields to the rcu_node fields prevents this useless work from happening. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12581706991966-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-14rcu: Further cleanups of use of lastcompPaul E. McKenney
Now that a copy of the rsp->completed flag is available in all rcu_node structures, make full use of it. It is still legitimate to access rsp->completed while holding the root rcu_node structure's lock, however. Also, tighten up force_quiescent_state()'s checks for end of current grace period. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1258170699933-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-13rcu: Simplify association of forced quiescent states with grace periodsPaul E. McKenney
The force_quiescent_state() function also took a snapshot of the ->completed field, which was as obnoxious as it was in rcu_sched_qs() and friends. So snapshot ->gpnum-1. Also, since the dyntick_record_completed() and dyntick_recall_completed() functions are now simple assignments that are independent of CONFIG_NO_HZ, and since their names are now misleading, get rid of them. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12580941042308-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-13rcu: Accelerate callback processing on CPUs not detecting GP endPaul E. McKenney
An earlier fix for a race resulted in a situation where the CPUs other than the CPU that detected the end of the grace period would not process their callbacks until the next grace period started. This means that these other CPUs would unnecessarily demand that an extra grace period be started. This patch eliminates this extra grace period and speeds callback processing by propagating rsp->completed to the rcu_node structures in the case where the CPU detecting the end of the grace period sees no reason to start a new grace period. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1258094104417-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10rcu: Simplify association of quiescent states with grace periodsPaul E. McKenney
The rdp->passed_quiesc_completed fields are used to properly associate the recorded quiescent state with a grace period. It is OK to wrongly associate a given quiescent state with a preceding grace period, but it is fatal to associate a given quiescent state with a grace period that begins after the quiescent state occurred. Grace periods are numbered, and the following fields track them: o ->gpnum is the number of the grace period currently in progress, or the number of the last grace period to complete if no grace period is currently in progress. o ->completed is the number of the last grace period to have completed. These two fields are equal if there is no grace period in progress, otherwise ->gpnum is one greater than ->completed. But the rdp->passed_quiesc_completed field compared against ->completed, and if equal, the quiescent state is presumed to count against the current grace period. The earlier code copied rdp->completed to rdp->passed_quiesc_completed, which has been made to work, but is error-prone. In contrast, copying one less than rdp->gpnum is guaranteed safe, because rdp->gpnum is not incremented until after the start of the corresponding grace period. At the end of the grace period, when ->completed has incremented, then any quiescent periods recorded previously will be discarded. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12578890421011-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10rcu: Rename dynticks_completed to completed_fqsPaul E. McKenney
This field is used whether or not CONFIG_NO_HZ is set, so the old name of ->dynticks_completed is quite misleading. Change to ->completed_fqs, given that it the value that force_quiescent_state() is trying to drive the ->completed field away from. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12578890423298-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10rcu: Fix note_new_gpnum() uses of ->gpnumPaul E. McKenney
Impose a clear locking design on the note_new_gpnum() function's use of the ->gpnum counter. This is done by updating rdp->gpnum only from the corresponding leaf rcu_node structure's rnp->gpnum field, and even then only under the protection of that same rcu_node structure's ->lock field. Performance and scalability are maintained using a form of double-checked locking, and excessive spinning is avoided by use of the spin_trylock() function. The use of spin_trylock() is safe due to the fact that CPUs who fail to acquire this lock will try again later. The hierarchical nature of the rcu_node data structure limits contention (which could be limited further if need be using the RCU_FANOUT kernel parameter). Without this patch, obscure but quite possible races could result in a quiescent state that occurred during one grace period to be accounted to the following grace period, causing this following grace period to end prematurely. Not good! Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: <stable@kernel.org> # .32.x LKML-Reference: <12571987492350-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10rcu: Fix synchronization for rcu_process_gp_end() uses of ->completed counterPaul E. McKenney
Impose a clear locking design on the rcu_process_gp_end() function's use of the ->completed counter. This is done by creating a ->completed field in the rcu_node structure, which can safely be accessed under the protection of that structure's lock. Performance and scalability are maintained by using a form of double-checked locking, so that rcu_process_gp_end() only acquires the leaf rcu_node structure's ->lock if a grace period has recently ended. This fix reduces rcutorture failure rate by at least two orders of magnitude under heavy stress with force_quiescent_state() being invoked artificially often. Without this fix, unsynchronized access to the ->completed field can cause rcu_process_gp_end() to advance callbacks whose grace period has not yet expired. (Bad idea!) Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: <stable@kernel.org> # .32.x LKML-Reference: <12571987494069-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10rcu: Prepare for synchronization fixes: clean up for non-NO_HZ handling of ↵Paul E. McKenney
->completed counter Impose a clear locking design on non-NO_HZ handling of the ->completed counter. This increases the distance between the RCU and the CPU-hotplug mechanisms. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: <stable@kernel.org> # .32.x LKML-Reference: <12571987491353-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10Merge branch 'core/urgent' into core/rcuIngo Molnar
Merge reason: Pick up RCU fixlet to base further commits on. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-02rcu: Fix long-grace-period race between forcing and initializationPaul E. McKenney
Very long RCU read-side critical sections (50 milliseconds or so) can cause a race between force_quiescent_state() and rcu_start_gp() as follows on kernel builds with multi-level rcu_node hierarchies: 1. CPU 0 calls force_quiescent_state(), sees that there is a grace period in progress, and acquires ->fsqlock. 2. CPU 1 detects the end of the grace period, and so cpu_quiet_msk_finish() sets rsp->completed to rsp->gpnum. This operation is carried out under the root rnp->lock, but CPU 0 has not yet acquired that lock. Note that rsp->signaled is still RCU_SAVE_DYNTICK from the last grace period. 3. CPU 1 calls rcu_start_gp(), but no one wants a new grace period, so it drops the root rnp->lock and returns. 4. CPU 0 acquires the root rnp->lock and picks up rsp->completed and rsp->signaled, then drops rnp->lock. It then enters the RCU_SAVE_DYNTICK leg of the switch statement. 5. CPU 2 invokes call_rcu(), and now needs a new grace period. It calls rcu_start_gp(), which acquires the root rnp->lock, sets rsp->signaled to RCU_GP_INIT (too bad that CPU 0 is already in the RCU_SAVE_DYNTICK leg of the switch statement!) and starts initializing the rcu_node hierarchy. If there are multiple levels to the hierarchy, it will drop the root rnp->lock and initialize the lower levels of the hierarchy. 6. CPU 0 notes that rsp->completed has not changed, which permits both CPU 2 and CPU 0 to try updating it concurrently. If CPU 0's update prevails, later calls to force_quiescent_state() can count old quiescent states against the new grace period, which can in turn result in premature ending of grace periods. Not good. This patch adds an RCU_GP_IDLE state for rsp->signaled that is set initially at boot time and any time a grace period ends. This prevents CPU 0 from getting into the workings of force_quiescent_state() in step 4. Additional locking and checks prevent the concurrent update of rsp->signaled in step 6. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1256742889199-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-26rcu: Simplify creating of lockdep class for root rcu_nodePeter Zijlstra
Use lockdep_set_class() to simplify the code and to avoid any additional overhead in the !LOCKDEP case. Also move the definition of rcu_root_class into kernel/rcutree.c, as suggested by Lai Jiangshan. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1256577871443-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15rcu: Fix TREE_PREEMPT_RCU CPU_HOTPLUG bad-luck hangPaul E. McKenney
If the following sequence of events occurs, then TREE_PREEMPT_RCU will hang waiting for a grace period to complete, eventually OOMing the system: o A TREE_PREEMPT_RCU build of the kernel is booted on a system with more than 64 physical CPUs present (32 on a 32-bit system). Alternatively, a TREE_PREEMPT_RCU build of the kernel is booted with RCU_FANOUT set to a sufficiently small value that the physical CPUs populate two or more leaf rcu_node structures. o A task is preempted in an RCU read-side critical section while running on a CPU corresponding to a given leaf rcu_node structure. o All CPUs corresponding to this same leaf rcu_node structure record quiescent states for the current grace period. o All of these same CPUs go offline (hence the need for enough physical CPUs to populate more than one leaf rcu_node structure). This causes the preempted task to be moved to the root rcu_node structure. At this point, there is nothing left to cause the quiescent state to be propagated up the rcu_node tree, so the current grace period never completes. The simplest fix, especially after considering the deadlock possibilities, is to detect this situation when the last CPU is offlined, and to set that CPU's ->qsmask bit in its leaf rcu_node structure. This will cause the next invocation of force_quiescent_state() to end the grace period. Without this fix, this hang can be triggered in an hour or so on some machines with rcutorture and random CPU onlining/offlining. With this fix, these same machines pass a full 10 hours of this sort of abuse. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <20091015162614.GA19131@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15rcu: Prevent RCU IPI storms in presence of high call_rcu() loadPaul E. McKenney
As the number of callbacks on a given CPU rises, invoke force_quiescent_state() only every blimit number of callbacks (defaults to 10,000), and even then only if no other CPU has invoked force_quiescent_state() in the meantime. This should fix the performance regression reported by Nick. Reported-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: jens.axboe@oracle.com LKML-Reference: <12555405592133-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-07rcu: Place root rcu_node structure in separate lockdep classPaul E. McKenney
Before this patch, all of the rcu_node structures were in the same lockdep class, so that lockdep would complain when rcu_preempt_offline_tasks() acquired the root rcu_node structure's lock while holding one of the leaf rcu_nodes' locks. This patch changes rcu_init_one() to use a separate spin_lock_init() for the root rcu_node structure's lock than is used for that of all of the rest of the rcu_node structures, which puts the root rcu_node structure's lock in its own lockdep class. Suggested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12548908983277-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-07rcu: Make hot-unplugged CPU relinquish its own RCU callbacksPaul E. McKenney
The current interaction between RCU and CPU hotplug requires that RCU block in CPU notifiers waiting for callbacks to drain. This can be greatly simplified by having each CPU relinquish its own callbacks, and for both _rcu_barrier() and CPU_DEAD notifiers to adopt all callbacks that were previously relinquished. This change also eliminates the possibility of certain types of hangs due to the previous practice of waiting for callbacks to be invoked from within CPU notifiers. If you don't every wait, you cannot hang. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1254890898456-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-07rcu: Move rcu_barrier() to rcutreePaul E. McKenney
Move the existing rcu_barrier() implementation to rcutree.c, consistent with the fact that the rcu_barrier() implementation is tied quite tightly to the RCU implementation. This opens the way to simplify and fix rcutree.c's rcu_barrier() implementation in a later patch. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12548908982563-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-05rcu: Clean up code based on review feedback from Josh Triplett, part 4Paul E. McKenney
These issues identified during an old-fashioned face-to-face code review extending over many hours. This group improves an existing abstraction and introduces two new ones. It also fixes an RCU stall-warning bug found while making the other changes. o Make RCU_INIT_FLAVOR() declare its own variables, removing the need to declare them at each call site. o Create an rcu_for_each_leaf() macro that scans the leaf nodes of the rcu_node tree. o Create an rcu_for_each_node_breadth_first() macro that does a breadth-first traversal of the rcu_node tree, AKA stepping through the array in index-number order. o If all CPUs corresponding to a given leaf rcu_node structure go offline, then any tasks queued on that leaf will be moved to the root rcu_node structure. Therefore, the stall-warning code must dump out tasks queued on the root rcu_node structure as well as those queued on the leaf rcu_node structures. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12541491934126-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-05rcu: Clean up code based on review feedback from Josh Triplett, part 3Paul E. McKenney
Whitespace fixes, updated comments, and trivial code movement. o Fix whitespace error in RCU_HEAD_INIT() o Move "So where is rcu_write_lock()" comment so that it does not come between the rcu_read_unlock() header comment and the rcu_read_unlock() definition. o Move the module_param statements for blimit, qhimark, and qlowmark to immediately follow the corresponding definitions. o In __rcu_offline_cpu(), move the assignment to rdp_me inside the "if" statement, given that rdp_me is not used outside of that "if" statement. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12541491931164-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-05rcu: Fix rcu_lock_map build failure on CONFIG_PROVE_LOCKING=yPaul E. McKenney
Move the rcu_lock_map definition from rcutree.c to rcupdate.c so that TINY_RCU can use lockdep. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-23rcu: Clean up code to address Ingo's checkpatch feedbackPaul E. McKenney
Move declarations and update storage classes to make checkpatch happy. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12537246441701-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-23rcu: Clean up code based on review feedback from Josh Triplett, part 2Paul E. McKenney
These issues identified during an old-fashioned face-to-face code review extending over many hours. o Add comments for tricky parts of code, and correct comments that have passed their sell-by date. o Get rid of the vestiges of rcu_init_sched(), which is no longer needed now that PREEMPT_RCU is gone. o Move the #include of rcutree_plugin.h to the end of rcutree.c, which means that, rather than having a random collection of forward declarations, the new set of forward declarations document the set of plugins. The new home for this #include also allows __rcu_init_preempt() to move into rcutree_plugin.h. o Fix rcu_preempt_check_callbacks() to be static. Suggested-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12537246443924-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu> Peter Zijlstra <peterz@infradead.org>
2009-09-23rcu: Clean up code based on review feedback from Josh TriplettPaul E. McKenney
These issues identified during an old-fashioned face-to-face code review extended over many hours. o Bury various forms of the "rsp->completed == rsp->gpnum" comparison into an rcu_gp_in_progress() function, which has the beneficial side-effect of forcing consistent use of ACCESS_ONCE(). o Replace hand-coded arithmetic with DIV_ROUND_UP(). o Bury several "!list_empty(&rnp->blocked_tasks[rnp->gpnum & 0x01])" instances into an rcu_preempted_readers() function, as this expression indicates that there are no readers blocked within RCU read-side critical sections blocking the current grace period. (Though there might well be similar readers blocking the next grace period.) o Remove a dangling rcu_restart_cpu() declaration that has been dangling for almost 20 minor releases of the kernel. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12537246442687-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19rcu: Fix whitespace inconsistenciesPaul E. McKenney
Fix a number of whitespace ^Ierrors in the include/linux/rcu* and the kernel/rcu* files. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <20090918172819.GA24405@linux.vnet.ibm.com> [ did more checkpatch fixlets ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19rcu: Fix thinko, actually initialize full treePaul E. McKenney
Commit de078d8 ("rcu: Need to update rnp->gpnum if preemptable RCU is to be reliable") repeatedly and incorrectly initializes the root rcu_node structure's ->gpnum field rather than initializing the ->gpnum field of each node in the tree. Fix this. Also add an additional consistency check to catch this in the future. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <125329262011-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19rcu: Apply results of code inspection of kernel/rcutree_plugin.hPaul E. McKenney
o Drop the calls to cpu_quiet() from the online/offline code. These are unnecessary, since force_quiescent_state() will clean up, and removing them simplifies the code a bit. o Add a warning to check that we don't enqueue the same blocked task twice onto the ->blocked_tasks[] lists. o Rework the phase computation in rcu_preempt_note_context_switch() to be more readable, as suggested by Josh Triplett. o Disable irqs to close a race between the scheduling clock interrupt and rcu_preempt_note_context_switch() WRT the ->rcu_read_unlock_special field. o Add comments to rnp->lock acquisition and release within rcu_read_unlock_special() noting that irqs are already disabled. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <12532926201851-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19rcu: Add WARN_ON_ONCE() consistency checks covering state transitionsPaul E. McKenney
o Verify that qsmask bits stay clear through GP initialization. o Verify that cpu_quiet_msk_finish() is never invoked unless there actually is an RCU grace period in progress. o Verify that all internal-node rcu_node structures have empty blocked_tasks[] lists. o Verify that child rcu_node structure's bits remain clear after acquiring parent's lock. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <12532926191947-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18rcu: Simplify rcu_read_unlock_special() quiescent-state accountingPaul E. McKenney
The earlier approach required two scheduling-clock ticks to note an preemptable-RCU quiescent state in the situation in which the scheduling-clock interrupt is unlucky enough to always interrupt an RCU read-side critical section. With this change, the quiescent state is instead noted by the outermost rcu_read_unlock() immediately following the first scheduling-clock tick, or, alternatively, by the first subsequent context switch. Therefore, this change also speeds up grace periods. Suggested-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <12528585111945-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18rcu: Add debug checks to TREE_PREEMPT_RCU for premature grace periodsPaul E. McKenney
Check to make sure that there are no blocked tasks for the previous grace period while initializing for the next grace period, verify that rcu_preempt_qs() is given the correct CPU number and is never called for an offline CPU. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <12528585111986-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18rcu: Initialize multi-level RCU grace periods holding locksPaul E. McKenney
Prior implementations initialized the root and any internal nodes without holding locks, then initialized the leaves holding locks. This is a false economy, as the leaf nodes will usually greatly outnumber the root and internal nodes. Acquiring locks on all nodes is conceptually much simpler as well. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org LKML-Reference: <12524504773190-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18rcu: Need to update rnp->gpnum if preemptable RCU is to be reliablePaul E. McKenney
Without this patch, tasks preempted in RCU read-side critical sections can fail to block the grace period, given that rnp->gpnum is used to determine which rnp->blocked_tasks[] element the preempted task is enqueued on. Before the patch, rnp->gpnum is always zero, so preempted tasks are always enqueued on rnp->blocked_tasks[0], which is correct only when the current CPU has not checked into the current grace period and the grace-period number is even, or, similarly, if the current CPU -has- checked into the current grace period and the grace-period number is odd. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org LKML-Reference: <12524504771622-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-11Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits) rcu: Move end of special early-boot RCU operation earlier rcu: Changes from reviews: avoid casts, fix/add warnings, improve comments rcu: Create rcutree plugins to handle hotplug CPU for multi-level trees rcu: Remove lockdep annotations from RCU's _notrace() API members rcu: Add #ifdef to suppress __rcu_offline_cpu() warning in !HOTPLUG_CPU builds rcu: Add CPU-offline processing for single-node configurations rcu: Add "notrace" to RCU function headers used by ftrace rcu: Remove CONFIG_PREEMPT_RCU rcu: Merge preemptable-RCU functionality into hierarchical RCU rcu: Simplify rcu_pending()/rcu_check_callbacks() API rcu: Use debugfs_remove_recursive() simplify code. rcu: Merge per-RCU-flavor initialization into pre-existing macro rcu: Fix online/offline indication for rcudata.csv trace file rcu: Consolidate sparse and lockdep declarations in include/linux/rcupdate.h rcu: Renamings to increase RCU clarity rcu: Move private definitions from include/linux/rcutree.h to kernel/rcutree.h rcu: Expunge lingering references to CONFIG_CLASSIC_RCU, optimize on !SMP rcu: Delay rcu_barrier() wait until beginning of next CPU-hotunplug operation. rcu: Fix typo in rcu_irq_exit() comment header rcu: Make rcupreempt_trace.c look at offline CPUs ...
2009-08-29rcu: Changes from reviews: avoid casts, fix/add warnings, improve commentsPaul E. McKenney
Changes suggested by review comments from Josh Triplett and Mathieu Desnoyers. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <20090827220012.GA30525@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-29rcu: Create rcutree plugins to handle hotplug CPU for multi-level treesPaul E. McKenney
When offlining CPUs from a multi-level tree, there is the possibility of offlining the last CPU from a given node when there are preempted RCU read-side critical sections that started life on one of the CPUs on that node. In this case, the corresponding tasks will be enqueued via the task_struct's rcu_node_entry list_head onto one of the rcu_node's blocked_tasks[] lists. These tasks need to be moved somewhere else so that they will prevent the current grace period from ending. That somewhere is the root rcu_node. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <20090827215816.GA30472@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-25rcu: Add #ifdef to suppress __rcu_offline_cpu() warning in !HOTPLUG_CPU buildsPaul E. McKenney
Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Paul Mundt <lethal@linux-sh.org> LKML-Reference: <20090825154025.GD6616@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-24rcu: Add CPU-offline processing for single-node configurationsPaul E. McKenney
Add preemptable-RCU plugin to handle the CPU-offline processing. An additional plugin is forthcoming to handle multinode RCU trees, but this current plugin works for configurations up to 32 CPUs (64 CPUs for 64-bit kernels). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <12511321213336-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Merge preemptable-RCU functionality into hierarchical RCUPaul E. McKenney
Create a kernel/rcutree_plugin.h file that contains definitions for preemptable RCU (or, under the #else branch of the #ifdef, empty definitions for the classic non-preemptable semantics). These definitions fit into plugins defined in kernel/rcutree.c for this purpose. This variant of preemptable RCU uses a new algorithm whose read-side expense is roughly that of classic hierarchical RCU under CONFIG_PREEMPT. This new algorithm's update-side expense is similar to that of classic hierarchical RCU, and, in absence of read-side preemption or blocking, is exactly that of classic hierarchical RCU. Perhaps more important, this new algorithm has a much simpler implementation, saving well over 1,000 lines of code compared to mainline's implementation of preemptable RCU, which will hopefully be retired in favor of this new algorithm. The simplifications are obtained by maintaining per-task nesting state for running tasks, and using a simple lock-protected algorithm to handle accounting when tasks block within RCU read-side critical sections, making use of lessons learned while creating numerous user-level RCU implementations over the past 18 months. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <12509746134003-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Simplify rcu_pending()/rcu_check_callbacks() APIPaul E. McKenney
All calls from outside RCU are of the form: if (rcu_pending(cpu)) rcu_check_callbacks(cpu, user); This is silly, instead we put a call to rcu_pending() in rcu_check_callbacks(), and then make the outside calls be to rcu_check_callbacks(). This cuts down on the code a bit and also gives the compiler a better chance of optimizing. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <125097461311-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Merge per-RCU-flavor initialization into pre-existing macroPaul E. McKenney
Rename the RCU_DATA_PTR_INIT() macro to RCU_INIT_FLAVOR() and make it do the rcu_init_one() and rcu_boot_init_percpu_data() calls. Merge the loop that was in the original macro with the loops that were in __rcu_init(). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <12509746133916-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Renamings to increase RCU clarityPaul E. McKenney
Make RCU-sched, RCU-bh, and RCU-preempt be underlying implementations, with "RCU" defined in terms of one of the three. Update the outdated rcu_qsctr_inc() names, as these functions no longer increment anything. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <12509746132696-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Move private definitions from include/linux/rcutree.h to kernel/rcutree.hPaul E. McKenney
Some information hiding that makes it easier to merge preemptability into rcutree without descending into #include hell. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <1250974613373-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-15rcu: Simplify RCU CPU-hotplug notificationPaul E. McKenney
Use the new cpu_notifier() API to simplify RCU's CPU-hotplug notifiers, collapsing down to a single such notifier. This makes it trivial to provide the notifier-ordering guarantee that rcu_barrier() depends on. Also remove redundant open_softirq() calls from Hierarchical RCU notifier. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: josht@linux.vnet.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: hugh.dickins@tiscali.co.uk Cc: benh@kernel.crashing.org LKML-Reference: <12503552312510-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-15rcu: Split hierarchical RCU initialization into boot-time and CPU-online piecesPaul E. McKenney
This patch divides the rcutree initialization into boot-time and hotplug-time components, so that the tree data structures are guaranteed to be fully linked at boot time regardless of what might happen in CPU hotplug operations. This makes RCU more resilient against CPU hotplug misbehavior (and vice versa), but more importantly, does a better job of compartmentalizing the code. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: josht@linux.vnet.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: hugh.dickins@tiscali.co.uk Cc: benh@kernel.crashing.org LKML-Reference: <1250355231152-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02debug lockups: Improve lockup detectionIngo Molnar
When debugging a recent lockup bug i found various deficiencies in how our current lockup detection helpers work: - SysRq-L is not very efficient as it uses a workqueue, hence it cannot punch through hard lockups and cannot see through most soft lockups either. - The SysRq-L code depends on the NMI watchdog - which is off by default. - We dont print backtraces from the RCU code's built-in 'RCU state machine is stuck' debug code. This debug code tends to be one of the first (and only) mechanisms that show that a lockup has occured. This patch changes the code so taht we: - Trigger the NMI backtrace code from SysRq-L instead of using a workqueue (which cannot punch through hard lockups) - Trigger print-all-CPU-backtraces from the RCU lockup detection code Also decouple the backtrace printing code from the NMI watchdog: - Dont use variable size cpumasks (it might not be initialized and they are a bit more fragile anyway) - Trigger an NMI immediately via an IPI, instead of waiting for the NMI tick to occur. This is a lot faster and can produce more relevant backtraces. It will also work if the NMI watchdog is disabled. - Dont print the 'dazed and confused' message when we print a backtrace from the NMI - Do a show_regs() plus a dump_stack() to get maximum info out of the dump. Worst-case we get two stacktraces - which is not a big deal. Sometimes, if register content is corrupted, the precise stack walker in show_regs() wont give us a full backtrace - in this case dump_stack() will do it. Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
