path: root/kernel/posix-cpu-timers.c
2010-03-06kernel core: use helpers for rlimitsJiri Slaby
Make sure compiler won't do weird things with limits. E.g. fetching them twice may return 2 different values after writable limits are implemented. I.e. either use rlimit helpers added in commit 3e10e716abf3 ("resource: add helpers for fetching rlimits") or ACCESS_ONCE if not applicable. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06posix-cpu-timers: cleanup rlimits usageJiri Slaby
Fetch rlimit (both hard and soft) values only once and work on them. It removes many accesses through sig structure and makes the code cleaner. Mostly a preparation for writable resource limits support. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-18posix-cpu-timers: optimize and document timer_create callbackStanislaw Gruszka
We have already new_timer initialized to all-zeros hence in function initializations are not needed. Document function expectation about new_timer argument as well. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Cc: johnstul@us.ibm.com Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-29itimers: Add tracepoints for itimerXiao Guangrong
Add tracepoints for all itimer variants: ITIMER_REAL, ITIMER_VIRTUAL and ITIMER_PROF. [ tglx: Fixed comments and made the output more readable, parseable and consistent. Replaced pid_vnr by pid_nr because the hrtimer callback can happen in any namespace ] Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Anton Blanchard <anton@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Zhaolei <zhaolei@cn.fujitsu.com> LKML-Reference: <4A7F8B6E.2010109@cn.fujitsu.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-29Merge branch 'timers/posixtimers' into timers/tracingThomas Gleixner
Merge reason: timer tracepoint patches depend on both branches Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-08posix_cpu_timers_exit_group(): Do not use thread_group_cputimer()Stanislaw Gruszka
When the process exits we don't have to run new cputimer nor use running one (as it not accounts when tsk->exit_state != 0) to get process CPU times. As there is only one thread we can just use CPU times fields from task and signal structs. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Roland McGrath <roland@redhat.com> Cc: Vitaly Mayatskikh <vmayatsk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-03cputime: Optimize jiffies_to_cputime(1)Stanislaw Gruszka
For powerpc with CONFIG_VIRT_CPU_ACCOUNTING jiffies_to_cputime(1) is not compile time constant and run time calculations are quite expensive. To optimize we use precomputed value. For all other architectures is is preprocessor definition. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> LKML-Reference: <1248862529-6063-5-git-send-email-sgruszka@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-03itimers: Simplify arm_timer() code a bitStanislaw Gruszka
Don't update values in expiration cache when new ones are equal. Add expire_le() and expire_gt() helpers to simplify the code. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> LKML-Reference: <1248862529-6063-4-git-send-email-sgruszka@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-03itimers: Fix periodic tics precisionStanislaw Gruszka
Measure ITIMER_PROF and ITIMER_VIRT timers interval error between real ticks and requested by user. Take it into account when scheduling next tick. This patch introduce possibility where time between two consecutive tics is smaller then requested interval, it preserve however dependency that n tick is generated not earlier than n*interval time - counting from the beginning of periodic signal generation. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> LKML-Reference: <1248862529-6063-3-git-send-email-sgruszka@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-03itimers: Merge ITIMER_VIRT and ITIMER_PROFStanislaw Gruszka
Both cpu itimers have same data flow in the few places, this patch make unification of code related with VIRT and PROF itimers. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> LKML-Reference: <1248862529-6063-2-git-send-email-sgruszka@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-30kernel/posix-cpu-timers.c: fix sparse warningH Hartley Sweeten
Sparse reports the following in kernel/posix-cpu-timers.c: warning: symbol 'firing' shadows an earlier one Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Subrata Modak <subrata@linux.vnet.ibm.com> LKML-Reference: <BD79186B4FD85F4B8E60E381CAEE1909016C1AFE@mi8nycmail19.Mi8.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-09Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: do not count frozen tasks toward load sched: refresh MAINTAINERS entry sched: Print sched_group::__cpu_power in sched_domain_debug cpuacct: add per-cgroup utime/stime statistics posixtimers, sched: Fix posix clock monotonicity sched_rt: don't allocate cpumask in fastpath cpuacct: make cpuacct hierarchy walk in cpuacct_charge() safe when rcupreempt is used -v2
2009-04-08posix-timers: fix RLIMIT_CPU && setitimer(CPUCLOCK_PROF)Oleg Nesterov
update_rlimit_cpu() tries to optimize out set_process_cpu_timer() in case when we already have CPUCLOCK_PROF timer which should expire first. But it uses cputime_lt() instead of cputime_gt(). Test case: int main(void) { struct itimerval it = { .it_value = { .tv_sec = 1000 }, }; assert(!setitimer(ITIMER_PROF, &it, NULL)); struct rlimit rl = { .rlim_cur = 1, .rlim_max = 1, }; assert(!setrlimit(RLIMIT_CPU, &rl)); for (;;) ; return 0; } Without this patch, the task is not killed as RLIMIT_CPU demands. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Peter Lojkin <ia6432@inbox.ru> Cc: Roland McGrath <roland@redhat.com> Cc: stable@kernel.org LKML-Reference: <20090327000610.GA10108@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08Merge commit 'v2.6.30-rc1' into sched/urgentIngo Molnar
Merge reason: update to latest upstream to queue up fix Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-01posixtimers, sched: Fix posix clock monotonicityHidetoshi Seto
Impact: Regression fix (against clock_gettime() backwarding bug) This patch re-introduces a couple of functions, task_sched_runtime and thread_group_sched_runtime, which was once removed at the time of 2.6.28-rc1. These functions protect the sampling of thread/process clock with rq lock. This rq lock is required not to update rq->clock during the sampling. i.e. The clock_gettime() may return ((accounted runtime before update) + (delta after update)) that is less than what it should be. v2 -> v3: - Rename static helper function __task_delta_exec() to do_task_delta_exec() since -tip tree already has a __task_delta_exec() of different version. v1 -> v2: - Revises comments of function and patch description. - Add note about accuracy of thread group's runtime. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stable@kernel.org [2.6.28.x][2.6.29.x] LKML-Reference: <49D1CC93.4080401@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-23posix timers: fix RLIMIT_CPU && fork()Oleg Nesterov
See http://bugzilla.kernel.org/show_bug.cgi?id=12911 copy_signal() copies signal->rlim, but RLIMIT_CPU is "lost". Because posix_cpu_timers_init_group() sets cputime_expires.prof_exp = 0 and thus fastpath_timer_check() returns false unless we have other cpu timers. This is the minimal fix for 2.6.29 (tested) and 2.6.28. The patch is not optimal, we need further cleanups here. With this patch update_rlimit_cpu() is not really needed, but I don't think it should be removed. The proper fix (I think) is: - set_process_cpu_timer() should just start the cputimer->running logic (it does), no need to change cputime_expires.xxx_exp - posix_cpu_timers_init_group() should set ->running when needed - fastpath_timer_check() can check ->running instead of task_cputime_zero(signal->cputime_expires) Reported-by: Peter Lojkin <ia6432@inbox.ru> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roland McGrath <roland@redhat.com> Cc: <stable@kernel.org> [for 2.6.29.x] LKML-Reference: <20090323193411.GA17514@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-13timers: more consistently use clock vs timerPeter Zijlstra
While reviewing the manpages, I noticed I'd missed some clock vs timer sites. Make sure that all timer functions call cpu_timer_sample_group() and not cpu_clock_sample_group(). This ensures that we enable the process wide timer in time, and therefore pay the O(n) thread group cost from the syscall. Not doing it here, will result in the first jiffy tick after setting the timer doing this, resulting in a very expensive tick (but only once) and a delay in actually starting the timer. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-11timers: fix TIMER_ABSTIME for process wide cpu timersPeter Zijlstra
The POSIX timer interface allows for absolute time expiry values through the TIMER_ABSTIME flag, therefore we have to synchronize the timer to the clock every time we start it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-11timers: split process wide cpu clocks/timers, fixPeter Zijlstra
To decrease the chance of a missed enable, always enable the timer when we sample it, we'll always disable it when we find that there are no active timers in the jiffy tick. This fixes a flood of warnings reported by Mike Galbraith. Reported-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-05timers: split process wide cpu clocks/timersPeter Zijlstra
Change the process wide cpu timers/clocks so that we: 1) don't mess up the kernel with too many threads, 2) don't have a per-cpu allocation for each process, 3) have no impact when not used. In order to accomplish this we're going to split it into two parts: - clocks; which can take all the time they want since they run from user context -- ie. sys_clock_gettime(CLOCK_PROCESS_CPUTIME_ID) - timers; which need constant time sampling but since they're explicity used, the user can pay the overhead. The clock readout will go back to a full sum of the thread group, while the timers will run of a global 'clock' that only runs when needed, so only programs that make use of the facility pay the price. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-07itimers: remove the per-cpu-ish-nessPeter Zijlstra
Either we bounce once cacheline per cpu per tick, yielding n^2 bounces or we just bounce a single.. Also, using per-cpu allocations for the thread-groups complicates the per-cpu allocator in that its currently aimed to be a fixed sized allocator and the only possible extention to that would be vmap based, which is seriously constrained on 32 bit archs. So making the per-cpu memory requirement depend on the number of processes is an issue. Lastly, it didn't deal with cpu-hotplug, although admittedly that might be fixable. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-25Merge commit 'v2.6.28' into core/coreIngo Molnar
2008-11-24posix-cpu-timers: fix clock_gettime with CLOCK_PROCESS_CPUTIME_IDPetr Tesarik
Since CLOCK_PROCESS_CPUTIME_ID is in fact translated to -6, the switch statement in cpu_clock_sample_group() must first mask off the irrelevant bits, similar to cpu_clock_sample(). Signed-off-by: Petr Tesarik <ptesarik@suse.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> -- posix-cpu-timers.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
2008-11-17thread_group_cputime: kill the bogus ->signal != NULL checkOleg Nesterov
Impact: simplify the code thread_group_cputime() is called by current when it must have the valid ->signal, or under ->siglock, or under tasklist_lock after the ->signal check, or the caller is wait_task_zombie() which reaps the child. In any case ->signal can't be NULL. But the point of this patch is not optimization. If it is possible to call thread_group_cputime() when ->signal == NULL we are doing something wrong, and we should not mask the problem. thread_group_cputime() fills *times and the caller will use it, if we silently use task_struct->*times* we report the wrong values. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-17sched, signals: fix the racy usage of ->signal in ↵Oleg Nesterov
account_group_xxx/run_posix_cpu_timers Impact: fix potential NULL dereference Contrary to ad474caca3e2a0550b7ce0706527ad5ab389a4d4 changelog, other acct_group_xxx() helpers can be called after exit_notify() by timer tick. Thanks to Roland for pointing out this. Somehow I missed this simple fact when I read the original patch, and I am afraid I confused Frank during the discussion. Sorry. Fortunately, these helpers work with current, we can check ->exit_state to ensure that ->signal can't go away under us. Also, add the comment and compiler barrier to account_group_exec_runtime(), to make sure we load ->signal only once. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-23timers: fix itimer/many thread hang, v2Frank Mayhar
This is the second resubmission of the posix timer rework patch, posted a few days ago. This includes the changes from the previous resubmittion, which addressed Oleg Nesterov's comments, removing the RCU stuff from the patch and un-inlining the thread_group_cputime() function for SMP. In addition, per Ingo Molnar it simplifies the UP code, consolidating much of it with the SMP version and depending on lower-level SMP/UP handling to take care of the differences. It also cleans up some UP compile errors, moves the scheduler stats-related macros into kernel/sched_stats.h, cleans up a merge error in kernel/fork.c and has a few other minor fixes and cleanups as suggested by Oleg and Ingo. Thanks for the review, guys. Signed-off-by: Frank Mayhar <fmayhar@google.com> Cc: Roland McGrath <roland@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-14timers: fix itimer/many thread hang, cleanupsIngo Molnar
2008-09-14timers: fix itimer/many thread hangFrank Mayhar
Overview This patch reworks the handling of POSIX CPU timers, including the ITIMER_PROF, ITIMER_VIRT timers and rlimit handling. It was put together with the help of Roland McGrath, the owner and original writer of this code. The problem we ran into, and the reason for this rework, has to do with using a profiling timer in a process with a large number of threads. It appears that the performance of the old implementation of run_posix_cpu_timers() was at least O(n*3) (where "n" is the number of threads in a process) or worse. Everything is fine with an increasing number of threads until the time taken for that routine to run becomes the same as or greater than the tick time, at which point things degrade rather quickly. This patch fixes bug 9906, "Weird hang with NPTL and SIGPROF." Code Changes This rework corrects the implementation of run_posix_cpu_timers() to make it run in constant time for a particular machine. (Performance may vary between one machine and another depending upon whether the kernel is built as single- or multiprocessor and, in the latter case, depending upon the number of running processors.) To do this, at each tick we now update fields in signal_struct as well as task_struct. The run_posix_cpu_timers() function uses those fields to make its decisions. We define a new structure, "task_cputime," to contain user, system and scheduler times and use these in appropriate places: struct task_cputime { cputime_t utime; cputime_t stime; unsigned long long sum_exec_runtime; }; This is included in the structure "thread_group_cputime," which is a new substructure of signal_struct and which varies for uniprocessor versus multiprocessor kernels. For uniprocessor kernels, it uses "task_cputime" as a simple substructure, while for multiprocessor kernels it is a pointer: struct thread_group_cputime { struct task_cputime totals; }; struct thread_group_cputime { struct task_cputime *totals; }; We also add a new task_cputime substructure directly to signal_struct, to cache the earliest expiration of process-wide timers, and task_cputime also replaces the it_*_expires fields of task_struct (used for earliest expiration of thread timers). The "thread_group_cputime" structure contains process-wide timers that are updated via account_user_time() and friends. In the non-SMP case the structure is a simple aggregator; unfortunately in the SMP case that simplicity was not achievable due to cache-line contention between CPUs (in one measured case performance was actually _worse_ on a 16-cpu system than the same test on a 4-cpu system, due to this contention). For SMP, the thread_group_cputime counters are maintained as a per-cpu structure allocated using alloc_percpu(). The timer functions update only the timer field in the structure corresponding to the running CPU, obtained using per_cpu_ptr(). We define a set of inline functions in sched.h that we use to maintain the thread_group_cputime structure and hide the differences between UP and SMP implementations from the rest of the kernel. The thread_group_cputime_init() function initializes the thread_group_cputime structure for the given task. The thread_group_cputime_alloc() is a no-op for UP; for SMP it calls the out-of-line function thread_group_cputime_alloc_smp() to allocate and fill in the per-cpu structures and fields. The thread_group_cputime_free() function, also a no-op for UP, in SMP frees the per-cpu structures. The thread_group_cputime_clone_thread() function (also a UP no-op) for SMP calls thread_group_cputime_alloc() if the per-cpu structures haven't yet been allocated. The thread_group_cputime() function fills the task_cputime structure it is passed with the contents of the thread_group_cputime fields; in UP it's that simple but in SMP it must also safely check that tsk->signal is non-NULL (if it is it just uses the appropriate fields of task_struct) and, if so, sums the per-cpu values for each online CPU. Finally, the three functions account_group_user_time(), account_group_system_time() and account_group_exec_runtime() are used by timer functions to update the respective fields of the thread_group_cputime structure. Non-SMP operation is trivial and will not be mentioned further. The per-cpu structure is always allocated when a task creates its first new thread, via a call to thread_group_cputime_clone_thread() from copy_signal(). It is freed at process exit via a call to thread_group_cputime_free() from cleanup_signal(). All functions that formerly summed utime/stime/sum_sched_runtime values from from all threads in the thread group now use thread_group_cputime() to snapshot the values in the thread_group_cputime structure or the values in the task structure itself if the per-cpu structure hasn't been allocated. Finally, the code in kernel/posix-cpu-timers.c has changed quite a bit. The run_posix_cpu_timers() function has been split into a fast path and a slow path; the former safely checks whether there are any expired thread timers and, if not, just returns, while the slow path does the heavy lifting. With the dedicated thread group fields, timers are no longer "rebalanced" and the process_timer_rebalance() function and related code has gone away. All summing loops are gone and all code that used them now uses the thread_group_cputime() inline. When process-wide timers are set, the new task_cputime structure in signal_struct is used to cache the earliest expiration; this is checked in the fast path. Performance The fix appears not to add significant overhead to existing operations. It generally performs the same as the current code except in two cases, one in which it performs slightly worse (Case 5 below) and one in which it performs very significantly better (Case 2 below). Overall it's a wash except in those two cases. I've since done somewhat more involved testing on a dual-core Opteron system. Case 1: With no itimer running, for a test with 100,000 threads, the fixed kernel took 1428.5 seconds, 513 seconds more than the unfixed system, all of which was spent in the system. There were twice as many voluntary context switches with the fix as without it. Case 2: With an itimer running at .01 second ticks and 4000 threads (the most an unmodified kernel can handle), the fixed kernel ran the test in eight percent of the time (5.8 seconds as opposed to 70 seconds) and had better tick accuracy (.012 seconds per tick as opposed to .023 seconds per tick). Case 3: A 4000-thread test with an initial timer tick of .01 second and an interval of 10,000 seconds (i.e. a timer that ticks only once) had very nearly the same performance in both cases: 6.3 seconds elapsed for the fixed kernel versus 5.5 seconds for the unfixed kernel. With fewer threads (eight in these tests), the Case 1 test ran in essentially the same time on both the modified and unmodified kernels (5.2 seconds versus 5.8 seconds). The Case 2 test ran in about the same time as well, 5.9 seconds versus 5.4 seconds but again with much better tick accuracy, .013 seconds per tick versus .025 seconds per tick for the unmodified kernel. Since the fix affected the rlimit code, I also tested soft and hard CPU limits. Case 4: With a hard CPU limit of 20 seconds and eight threads (and an itimer running), the modified kernel was very slightly favored in that while it killed the process in 19.997 seconds of CPU time (5.002 seconds of wall time), only .003 seconds of that was system time, the rest was user time. The unmodified kernel killed the process in 20.001 seconds of CPU (5.014 seconds of wall time) of which .016 seconds was system time. Really, though, the results were too close to call. The results were essentially the same with no itimer running. Case 5: With a soft limit of 20 seconds and a hard limit of 2000 seconds (where the hard limit would never be reached) and an itimer running, the modified kernel exhibited worse tick accuracy than the unmodified kernel: .050 seconds/tick versus .028 seconds/tick. Otherwise, performance was almost indistinguishable. With no itimer running this test exhibited virtually identical behavior and times in both cases. In times past I did some limited performance testing. those results are below. On a four-cpu Opteron system without this fix, a sixteen-thread test executed in 3569.991 seconds, of which user was 3568.435s and system was 1.556s. On the same system with the fix, user and elapsed time were about the same, but system time dropped to 0.007 seconds. Performance with eight, four and one thread were comparable. Interestingly, the timer ticks with the fix seemed more accurate: The sixteen-thread test with the fix received 149543 ticks for 0.024 seconds per tick, while the same test without the fix received 58720 for 0.061 seconds per tick. Both cases were configured for an interval of 0.01 seconds. Again, the other tests were comparable. Each thread in this test computed the primes up to 25,000,000. I also did a test with a large number of threads, 100,000 threads, which is impossible without the fix. In this case each thread computed the primes only up to 10,000 (to make the runtime manageable). System time dominated, at 1546.968 seconds out of a total 2176.906 seconds (giving a user time of 629.938s). It received 147651 ticks for 0.015 seconds per tick, still quite accurate. There is obviously no comparable test without the fix. Signed-off-by: Frank Mayhar <fmayhar@google.com> Cc: Roland McGrath <roland@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-24posix-timers: print RT watchdog messageHiroshi Shimamoto
It's useful to detect which process is killed by RT watchdog. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-01remove div_long_long_remRoman Zippel
x86 is the only arch right now, which provides an optimized for div_long_long_rem and it has the downside that one has to be very careful that the divide doesn't overflow. The API is a little akward, as the arguments for the unsigned divide are signed. The signed version also doesn't handle a negative divisor and produces worse code on 64bit archs. There is little incentive to keep this API alive, so this converts the few users to the new API. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17posix-timers: fix shadowed variablesWANG Cong
Fix sparse warnings like this: kernel/posix-cpu-timers.c:1090:25: warning: symbol 't' shadows an earlier one kernel/posix-cpu-timers.c:1058:21: originally declared here Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-08Use find_task_by_vpid in posix timersPavel Emelyanov
All the functions that need to lookup a task by pid in posix timers obtain this pid from a user space, and thus this value refers to a task in the same namespace, as the current task lives in. So the proper behavior is to call find_task_by_vpid() here. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25sched: rt-watchdog: fix .rlim_max = RLIM_INFINITYPeter Zijlstra
Remove the curious logic to set it_sched_expires in the future. It useless because rt.timeout wouldn't be incremented anyway. Explicity check for RLIM_INFINITY as a test programm that had a 1s soft limit and a inf hard limit would SIGKILL at 1s. This is because RLIM_INFINITY+d-1 is d-2. Signed-off-by: Peter Zijlsta <a.p.zijlstra@chello.nl> CC: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-25sched: SCHED_FIFO/SCHED_RR watchdog timerPeter Zijlstra
Introduce a new rlimit that allows the user to set a runtime timeout on real-time tasks their slice. Once this limit is exceeded the task will receive SIGXCPU. So it measures runtime since the last sleep. Input and ideas by Thomas Gleixner and Lennart Poettering. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> CC: Lennart Poettering <mzxreary@0pointer.de> CC: Michael Kerrisk <mtk.manpages@googlemail.com> CC: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-19Isolate some explicit usage of task->tgidPavel Emelyanov
With pid namespaces this field is now dangerous to use explicitly, so hide it behind the helpers. Also the pid and pgrp fields o task_struct and signal_struct are to be deprecated. Unfortunately this patch cannot be sent right now as this leads to tons of warnings, so start isolating them, and deprecate later. Actually the p->tgid == pid has to be changed to has_group_leader_pid(), but Oleg pointed out that in case of posix cpu timers this is the same, and thread_group_leader() is more preferable. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-09sched: make posix-cpu-timers use CFS's accounting informationIngo Molnar
update the posix-cpu-timers code to use CFS's CPU accounting information. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-05-08Introduce a handy list_first_entry macroPavel Emelianov
There are many places in the kernel where the construction like foo = list_entry(head->next, struct foo_struct, list); are used. The code might look more descriptive and neat if using the macro list_first_entry(head, type, member) \ list_entry((head)->next, type, member) Here is the macro itself and the examples of its usage in the generic code. If it will turn out to be useful, I can prepare the set of patches to inject in into arch-specific code, drivers, networking, etc. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Zach Brown <zach.brown@oracle.com> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] posix timers: RCU optimization for clock_gettime()Paul E. McKenney
Use RCU to avoid the need to acquire tasklist_lock in the single-threaded case of clock_gettime(). It still acquires tasklist_lock when for a (potentially multithreaded) process. This change allows realtime applications to frequently monitor CPU consumption of individual tasks, as requested (and now deployed) by some off-list users. This has been in Ingo Molnar's -rt patchset since late 2005 with no problems reported, and tests successfully on 2.6.20-rc6, so I believe that it is long-since ready for mainline adoption. [paulmck@linux.vnet.ibm.com: fix exit()/posix_cpu_clock_get() race spotted by Oleg] Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-17[PATCH] posix-cpu-timers: prevent signal delivery starvationThomas Gleixner
The integer divisions in the timer accounting code can round the result down to 0. Adding 0 is without effect and the signal delivery stops. Clamp the division result to minimum 1 to avoid this. Problem was reported by Seongbae Park <spark@google.com>, who provided also an inital patch. Roland sayeth: I have had some more time to think about the problem, and to reproduce it using Toyo's test case. For the record, if my understanding of the problem is correct, this happens only in one very particular case. First, the expiry time has to be so soon that in cputime_t units (usually 1s/HZ ticks) it's < nthreads so the division yields zero. Second, it only affects each thread that is so new that its CPU time accumulation is zero so now+0 is still zero and ->it_*_expires winds up staying zero. For the VIRT and PROF clocks when cputime_t is tick granularity (or the SCHED clock on configurations where sched_clock's value only advances on clock ticks), this is not hard to arrange with new threads starting up and blocking before they accumulate a whole tick of CPU time. That's what happens in Toyo's test case. Note that in general it is fine for that division to round down to zero, and set each thread's expiry time to its "now" time. The problem only arises with thread's whose "now" value is still zero, so that now+0 winds up 0 and is interpreted as "not set" instead of ">= now". So it would be a sufficient and more precise fix to just use max(ticks, 1) inside the loop when setting each it_*_expires value. But, it does no harm to round the division up to one and always advance every thread's expiry time. If the thread didn't already fire timers for the expiry time of "now", there is no expectation that it will do so before the next tick anyway. So I followed Thomas's patch in lifting the max out of the loops. This patch also covers the reload cases, which are harder to write a test for (and I didn't try). I've tested it with Toyo's case and it fixes that. [toyoa@mvista.com: fix: min_t -> max_t] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Daniel Walker <dwalker@mvista.com> Cc: Toyo Abe <toyoa@mvista.com> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Seongbae Park <spark@google.com> Cc: Peter Mattis <pmattis@google.com> Cc: Rohit Seth <rohitseth@google.com> Cc: Martin Bligh <mbligh@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] posix-timers: Fix the flags handling in posix_cpu_nsleep()Toyo Abe
When a posix_cpu_nsleep() sleep is interrupted by a signal more than twice, it incorrectly reports the sleep time remaining to the user. Because posix_cpu_nsleep() doesn't report back to the user when it's called from restart function due to the wrong flags handling. This patch, which applies after previous one, moves the nanosleep() function from posix_cpu_nsleep() to do_cpu_nanosleep() and cleans up the flags handling appropriately. Signed-off-by: Toyo Abe <toyoa@mvista.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] posix-timers: Fix clock_nanosleep() doesn't return the remaining ↵Toyo Abe
time in compatibility mode The clock_nanosleep() function does not return the time remaining when the sleep is interrupted by a signal. This patch creates a new call out, compat_clock_nanosleep_restart(), which handles returning the remaining time after a sleep is interrupted. This patch revives clock_nanosleep_restart(). It is now accessed via the new call out. The compat_clock_nanosleep_restart() is used for compatibility access. Since this is implemented in compatibility mode the normal path is virtually unaffected - no real performance impact. Signed-off-by: Toyo Abe <toyoa@mvista.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[PATCH] arm_timer: remove a racy and obsolete PF_EXITING checkOleg Nesterov
arm_timer() checks PF_EXITING to prevent BUG_ON(->exit_state) in run_posix_cpu_timers(). However, for some reason it does so only for CPUCLOCK_PERTHREAD case (which is imho wrong). Also, this check is not reliable, PF_EXITING could be set on another cpu without any locks/barriers just after the check, so it can't prevent from attaching the timer to the exiting task. The previous patch makes this check unneeded. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[PATCH] run_posix_cpu_timers: remove a bogus BUG_ON()Oleg Nesterov
do_exit() clears ->it_##clock##_expires, but nothing prevents another cpu to attach the timer to exiting process after that. arm_timer() tries to protect against this race, but the check is racy. After exit_notify() does 'write_unlock_irq(&tasklist_lock)' and before do_exit() calls 'schedule() local timer interrupt can find tsk->exit_state != 0. If that state was EXIT_DEAD (or another cpu does sys_wait4) interrupted task has ->signal == NULL. At this moment exiting task has no pending cpu timers, they were cleanuped in __exit_signal()->posix_cpu_timers_exit{,_group}(), so we can just return from irq. John Stultz recently confirmed this bug, see http://marc.theaimsgroup.com/?l=linux-kernel&m=115015841413687 Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[PATCH] check_process_timers: fix possible lockupOleg Nesterov
If the local timer interrupt happens just after do_exit() sets PF_EXITING (and before it clears ->it_xxx_expires) run_posix_cpu_timers() will call check_process_timers() with tasklist_lock + ->siglock held and check_process_timers: t = tsk; do { .... do { t = next_thread(t); } while (unlikely(t->flags & PF_EXITING)); } while (t != tsk); the outer loop will never stop. Actually, the window is bigger. Another process can attach the timer after ->it_xxx_expires was cleared (see the next commit) and the 'if (PF_EXITING)' check in arm_timer() is racy (see the one after that). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: switch clock_nanosleep to hrtimer nanosleep APIThomas Gleixner
Switch clock_nanosleep to use the new nanosleep functions in hrtimer.c Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: make clockid_t arguments constThomas Gleixner
add const arguments to the posix-timers.h API functions Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] Fix posix-cpu-timers sched_time accumulationDavid S. Miller
I've spent the past 3 days digging into a glibc testsuite failure in current CVS, specifically libc/rt/tst-cputimer1.c The thr1 and thr2 timers fire too early in the second pass of this test. The second pass is noteworthy because it makes use of intervals, whereas the first pass does not. All throughout the posix-cpu-timers.c code, the calculation of the process sched_time sum is implemented roughly as: unsigned long long sum; sum = tsk->signal->sched_time; t = tsk; do { sum += t->sched_time; t = next_thread(t); } while (t != tsk); In fact this is the exact scheme used by check_process_timers(). In the case of check_process_timers(), current->sched_time has just been updated (via scheduler_tick(), which is invoked by update_process_times(), which subsequently invokes run_posix_cpu_timers()) So there is no special processing necessary wrt. that. In other contexts, we have to allot for the fact that tsk->sched_time might be a bit out of date if we are current. And the posix-cpu-timers.c code uses current_sched_time() to deal with that. Unfortunately it does so in an erroneous and inconsistent manner in one spot which is what results in the early timer firing. In cpu_clock_sample_group_locked(), it does this: cpu->sched = p->signal->sched_time; /* Add in each other live thread. */ while ((t = next_thread(t)) != p) { cpu->sched += t->sched_time; } if (p->tgid == current->tgid) { /* * We're sampling ourselves, so include the * cycles not yet banked. We still omit * other threads running on other CPUs, * so the total can always be behind as * much as max(nthreads-1,ncpus) * (NSEC_PER_SEC/HZ). */ cpu->sched += current_sched_time(current); } else { cpu->sched += p->sched_time; } The problem is the "p->tgid == current->tgid" test. If "p" is not current, and the tgids are the same, we will add the process t->sched_time twice into cpu->sched and omit "p"'s sched_time which is very very very wrong. posix-cpu-timers.c has a helper function, sched_ns(p) which takes care of this, so my fix is to use that here instead of this special tgid test. The fact that current can be one of the sub-threads of "p" points out that we could make things a little bit more accurate, perhaps by using sched_ns() on every thread we process in these loops. It also points out that we don't use the most accurate value for threads in the group actively running other cpus (and this is mentioned in the comment). But that is a future enhancement, and this fix here definitely makes sense. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-28[PATCH] fix 32bit overflow in timespec_to_sample()Oleg Nesterov
fix 32bit overflow in timespec_to_sample() Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] posix-timers `unlikely' rejigAndrew Morton
!unlikely(expr) hurts my brain. likely(!expr) is more straightforward. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] posix-cpu-timers: fix overrun reportingRoland McGrath
This change corrects an omission in posix_cpu_timer_schedule, so that it correctly propagates the overrun calculation to where it will get reported to the user. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
