path: root/kernel/pid_namespace.c
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-09-17pid-namespace: limit value of ns_last_pid to (0, max_pid)Andrew Vagin
The kernel doesn't check the pid for negative values, so if you try to write -2 to /proc/sys/kernel/ns_last_pid, you will get a kernel panic. The crash happens because the next pid is -1, and alloc_pidmap() will try to access to a nonexistent pidmap. map = &pid_ns->pidmap[pid/BITS_PER_PAGE]; Signed-off-by: Andrew Vagin <avagin@openvz.org> Acked-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-14pidns: Export free_pid_nsEric W. Biederman
There is a least one modular user so export free_pid_ns so modules can capture and use the pid namespace on the very rare occasion when it makes sense. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-06-20pidns: guarantee that the pidns init will be the last pidns process reapedEric W. Biederman
Today we have a twofold bug. Sometimes release_task on pid == 1 in a pid namespace can run before other processes in a pid namespace have had release task called. With the result that pid_ns_release_proc can be called before the last proc_flus_task() is done using upid->ns->proc_mnt, resulting in the use of a stale pointer. This same set of circumstances can lead to waitpid(...) returning for a processes started with clone(CLONE_NEWPID) before the every process in the pid namespace has actually exited. To fix this modify zap_pid_ns_processess wait until all other processes in the pid namespace have exited, even EXIT_DEAD zombies. The delay_group_leader and related tests ensure that the thread gruop leader will be the last thread of a process group to be reaped, or to become EXIT_DEAD and self reap. With the change to zap_pid_ns_processes we get the guarantee that pid == 1 in a pid namespace will be the last task that release_task is called on. With pid == 1 being the last task to pass through release_task pid_ns_release_proc can no longer be called too early nor can wait return before all of the EXIT_DEAD tasks in a pid namespace have exited. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Louis Rilling <louis.rilling@kerlabs.com> Cc: Mike Galbraith <efault@gmx.de> Acked-by: Pavel Emelyanov <xemul@parallels.com> Tested-by: Andrew Wagin <avagin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31sysctl: make kernel.ns_last_pid control dependent on CHECKPOINT_RESTORECyrill Gorcunov
For those who doesn't need C/R functionality there is no need to control last pid, ie the pid for the next fork() call. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31pidns: make killed children autoreapEric W. Biederman
Force SIGCHLD handling to SIG_IGN so that signals are not generated and so that the children autoreap. This increases the parallelize and in general the speed of network namespace shutdown. Note self reaping childrean can exist past zap_pid_ns_processess but they will all be reaped before we allow the pid namespace init task with pid == 1 to be reaped. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Louis Rilling <louis.rilling@kerlabs.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28pidns: add reboot_pid_ns() to handle the reboot syscallDaniel Lezcano
In the case of a child pid namespace, rebooting the system does not really makes sense. When the pid namespace is used in conjunction with the other namespaces in order to create a linux container, the reboot syscall leads to some problems. A container can reboot the host. That can be fixed by dropping the sys_reboot capability but we are unable to correctly to poweroff/ halt/reboot a container and the container stays stuck at the shutdown time with the container's init process waiting indefinitively. After several attempts, no solution from userspace was found to reliabily handle the shutdown from a container. This patch propose to make the init process of the child pid namespace to exit with a signal status set to : SIGINT if the child pid namespace called "halt/poweroff" and SIGHUP if the child pid namespace called "reboot". When the reboot syscall is called and we are not in the initial pid namespace, we kill the pid namespace for "HALT", "POWEROFF", "RESTART", and "RESTART2". Otherwise we return EINVAL. Returning EINVAL is also an easy way to check if this feature is supported by the kernel when invoking another 'reboot' option like CAD. By this way the parent process of the child pid namespace knows if it rebooted or not and can take the right decision. Test case: ========== #include <alloca.h> #include <stdio.h> #include <sched.h> #include <unistd.h> #include <signal.h> #include <sys/reboot.h> #include <sys/types.h> #include <sys/wait.h> #include <linux/reboot.h> static int do_reboot(void *arg) { int *cmd = arg; if (reboot(*cmd)) printf("failed to reboot(%d): %m\n", *cmd); } int test_reboot(int cmd, int sig) { long stack_size = 4096; void *stack = alloca(stack_size) + stack_size; int status; pid_t ret; ret = clone(do_reboot, stack, CLONE_NEWPID | SIGCHLD, &cmd); if (ret < 0) { printf("failed to clone: %m\n"); return -1; } if (wait(&status) < 0) { printf("unexpected wait error: %m\n"); return -1; } if (!WIFSIGNALED(status)) { printf("child process exited but was not signaled\n"); return -1; } if (WTERMSIG(status) != sig) { printf("signal termination is not the one expected\n"); return -1; } return 0; } int main(int argc, char *argv[]) { int status; status = test_reboot(LINUX_REBOOT_CMD_RESTART, SIGHUP); if (status < 0) return 1; printf("reboot(LINUX_REBOOT_CMD_RESTART) succeed\n"); status = test_reboot(LINUX_REBOOT_CMD_RESTART2, SIGHUP); if (status < 0) return 1; printf("reboot(LINUX_REBOOT_CMD_RESTART2) succeed\n"); status = test_reboot(LINUX_REBOOT_CMD_HALT, SIGINT); if (status < 0) return 1; printf("reboot(LINUX_REBOOT_CMD_HALT) succeed\n"); status = test_reboot(LINUX_REBOOT_CMD_POWER_OFF, SIGINT); if (status < 0) return 1; printf("reboot(LINUX_REBOOT_CMD_POWERR_OFF) succeed\n"); status = test_reboot(LINUX_REBOOT_CMD_CAD_ON, -1); if (status >= 0) { printf("reboot(LINUX_REBOOT_CMD_CAD_ON) should have failed\n"); return 1; } printf("reboot(LINUX_REBOOT_CMD_CAD_ON) has failed as expected\n"); return 0; } [akpm@linux-foundation.org: tweak and add comments] [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Tested-by: Serge Hallyn <serge.hallyn@canonical.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23signal: zap_pid_ns_processes: s/SEND_SIG_NOINFO/SEND_SIG_FORCED/Oleg Nesterov
Change zap_pid_ns_processes() to use SEND_SIG_FORCED, it looks more clear compared to SEND_SIG_NOINFO which relies on from_ancestor_ns logic send_signal(). It is also more efficient if we need to kill a lot of tasks because it doesn't alloc sigqueue. While at it, add the __fatal_signal_pending(task) check as a minor optimization. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Anton Vorontsov <anton.vorontsov@linaro.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12sysctl: add the kernel.ns_last_pid controlPavel Emelyanov
The sysctl works on the current task's pid namespace, getting and setting its last_pid field. Writing is allowed for CAP_SYS_ADMIN-capable tasks thus making it possible to create a task with desired pid value. This ability is required badly for the checkpoint/restore in userspace. This approach suits all the parties for now. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23pidns: call pid_ns_prepare_proc() from create_pid_namespace()Eric W. Biederman
Reorganize proc_get_sb() so it can be called before the struct pid of the first process is allocated. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12pid_ns: zap_pid_ns_processes: use SEND_SIG_NOINFO instead of force_sig()Oleg Nesterov
zap_pid_ns_processes() uses force_sig(SIGKILL) to ensure SIGKILL will be delivered to sub-namespace inits as well. This is correct, but we are going to change force_sig_info() semantics. See http://bugzilla.kernel.org/show_bug.cgi?id=15395#c31 We can use send_sig_info(SEND_SIG_NOINFO) instead, since 614c517d7c00af1b26ded20646b329397d6f51a1 ("signals: SEND_SIG_NOINFO should be considered as SI_FROMUSER()") SEND_SIG_NOINFO means "from user" and therefore send_signal() will get the correct from_ancestor_ns = T flag. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24pidns: deny CLONE_PARENT|CLONE_NEWPID combinationSukadev Bhattiprolu
CLONE_PARENT was used to implement an older threading model. For consistency with the CLONE_THREAD check in copy_pid_ns(), disable CLONE_PARENT with CLONE_NEWPID, at least until the required semantics of pid namespaces are clear. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Oren Laadan <orenl@cs.columbia.edu> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18pidns: rewrite copy_pid_ns()Alexey Dobriyan
copy_pid_ns() is a perfect example of a case where unwinding leads to more code and makes it less clear. Watch the diffstat. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Reviewed-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18pidns: make create_pid_namespace() accept parent pidnsAlexey Dobriyan
create_pid_namespace() creates everything, but caller has to assign parent pidns by hand, which is unnatural. At the moment of call new ->level has to be taken from somewhere and parent pidns is already available. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02signals: zap_pid_ns_process() should use force_sig()Sukadev Bhattiprolu
send_signal() assumes that signals with SEND_SIG_PRIV are generated from within the same namespace. So any nested container-init processes become immune to the SIGKILL generated by kill_proc_info() in zap_pid_ns_processes(). Use force_sig() in zap_pid_ns_processes() instead - force_sig() clears the SIGNAL_UNKILLABLE flag ensuring the signal is processed by container-inits. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02pid_ns: (BUG 11391) change ->child_reaper when init->group_leader exitsOleg Nesterov
We don't change pid_ns->child_reaper when the main thread of the subnamespace init exits. As Robert Rex <robert.rex@exasol.com> pointed out this is wrong. Yes, the re-parenting itself works correctly, but if the reparented task exits it needs ->parent->nsproxy->pid_ns in do_notify_parent(), and if the main thread is zombie its ->nsproxy was already cleared by exit_task_namespaces(). Introduce the new function, find_new_reaper(), which finds the new ->parent for the re-parenting and changes ->child_reaper if needed. Kill the now unneeded exit_child_reaper(). Also move the changing of ->child_reaper from zap_pid_ns_processes() to find_new_reaper(), this consolidates the games with ->child_reaper and makes it stable under tasklist_lock. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=11391 Reported-by: Robert Rex <robert.rex@exasol.com> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02pid_ns: zap_pid_ns_processes: fix the ->child_reaper changingOleg Nesterov
zap_pid_ns_processes() sets pid_ns->child_reaper = NULL, this is wrong. Yes, we have already killed all tasks in this namespace, and sys_wait4() doesn't see any child. But this doesn't mean ->children list is empty, we may have EXIT_DEAD tasks which are not visible to do_wait(). In that case the subsequent forget_original_parent() will crash the kernel because it will try to re-parent these tasks to the NULL reaper. Even if there are no childs, it is not good that forget_original_parent() uses reaper == NULL. Change the code to set ->child_reaper = init_pid_ns.child_reaper instead. We could use pid_ns->parent->child_reaper as well, I think this does not really matter. These EXIT_DEAD tasks are not visible to the new ->parent after re-parenting, they will silently do release_task() eventually. Note that we must change ->child_reaper, otherwise forget_original_parent() will use reaper == father, and in that case we will hit the (correct) BUG_ON(!list_empty(&father->children)). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25bsdacct: switch from global bsd_acct_struct instance to per-pidns onePavel Emelyanov
Allocate the structure on the first call to sys_acct(). After this each namespace, that ordered the accounting, will live with this structure till its own death. Two notes - routines, that close the accounting on fs umount time use the init_pid_ns's acct by now; - accounting routine accounts to dying task's namespace (also by now). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25pidns: use kzalloc when allocating new pid_namespace structPavel Emelyanov
It makes many fields initialization implicit helping in auto-setting #ifdef-ed fields (bsd-acct related pointer will be such). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30pidns: make pid->level and pid_ns->level unsignedPavel Emelyanov
These values represent the nesting level of a namespace and pids living in it, and it's always non-negative. Turning this from int to unsigned int saves some space in pid.c (11 bytes on x86 and 64 on ia64) by letting the compiler optimize the pid_nr_ns a bit. E.g. on ia64 this removes the sign extension calls, which compiler adds to optimize access to pid->nubers[ns->level]. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28kernel: fix integer as NULL pointer warningsHarvey Harrison
kernel/cpuset.c:1268:52: warning: Using plain integer as NULL pointer kernel/pid_namespace.c:95:24: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Reviewed-by: Paul Jackson <pj@sgi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08namespaces: cleanup the code managed with PID_NS optionPavel Emelyanov
Just like with the user namespaces, move the namespace management code into the separate .c file and mark the (already existing) PID_NS option as "depend on NAMESPACES" [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
