path: root/kernel/perf_event.c
2010-12-09perf: Fix inherit vs. context rotation bugThomas Gleixner
commit dddd3379a619a4cb8247bfd3c94ca9ae3797aa2e upstream. It was found that sometimes children of tasks with inherited events had one extra event. Eventually it turned out to be due to the list rotation no being exclusive with the list iteration in the inheritance code. Cure this by temporarily disabling the rotation while we inherit the events. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22perf_events: Fix bogus context time trackingStephane Eranian
commit c530ccd9a1864a44a7ff35826681229ce9f2357a upstream. You can only call update_context_time() when the context is active, i.e., the thread it is attached to is still running. However, perf_event_read() can be called even when the context is inactive, e.g., user read() the counters. The call to update_context_time() must be conditioned on the status of the context, otherwise, bogus time_enabled, time_running may be returned. Here is an example on AMD64. The task program is an example from libpfm4. The -p prints deltas every 1s. $ task -p -e cpu_clk_unhalted sleep 5 2,266,610 cpu_clk_unhalted (0.00% scaling, ena=2,158,982, run=2,158,982) 0 cpu_clk_unhalted (0.00% scaling, ena=2,158,982, run=2,158,982) 0 cpu_clk_unhalted (0.00% scaling, ena=2,158,982, run=2,158,982) 0 cpu_clk_unhalted (0.00% scaling, ena=2,158,982, run=2,158,982) 0 cpu_clk_unhalted (0.00% scaling, ena=2,158,982, run=2,158,982) 5,242,358,071 cpu_clk_unhalted (99.95% scaling, ena=5,000,359,984, run=2,319,270) Whereas if you don't read deltas, e.g., no call to perf_event_read() until the process terminates: $ task -e cpu_clk_unhalted sleep 5 2,497,783 cpu_clk_unhalted (0.00% scaling, ena=2,376,899, run=2,376,899) Notice that time_enable, time_running are bogus in the first example causing bogus scaling. This patch fixes the problem, by conditionally calling update_context_time() in perf_event_read(). Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <4cb856dc.51edd80a.5ae0.38fb@mx.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-12perf: Fix incorrect copy_from_user() usageJohn Blackwood
perf events: repair incorrect use of copy_from_user This makes the perf_event_period() return 0 instead of -EFAULT on success. Signed-off-by: John Blackwood<john.blackwood@ccur.com> Signed-off-by: Joe Korty <joe.korty@ccur.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100928220311.GA18145@tsunami.ccur.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-09perf: Fix CPU hotplugPeter Zijlstra
Since we have UP_PREPARE, we should also have UP_CANCELED. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus <paulus@samba.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-30perf_events: Fix time tracking for events with pid != -1 and cpu != -1Stephane Eranian
Per-thread events with a cpu filter, i.e., cpu != -1, were not reporting correct timings when the thread never ran on the monitored cpu. The time enabled was reported as a negative value. This patch fixes the problem by updating tstamp_stopped, tstamp_running in event_sched_out() for events with filters and which are marked as INACTIVE. The function group_sched_out() is modified to systematically call into event_sched_out() to avoid duplicating the timing adjustment code twice. With the patch, I now get: $ task_cpu -i -e unhalted_core_cycles,unhalted_core_cycles noploop 2 noploop for 2 seconds CPU0 0 unhalted_core_cycles (ena=1,991,136,594, run=0) CPU0 0 unhalted_core_cycles (ena=1,991,136,594, run=0) CPU1 0 unhalted_core_cycles (ena=1,991,136,594, run=0) CPU1 0 unhalted_core_cycles (ena=1,991,136,594, run=0) CPU2 0 unhalted_core_cycles (ena=1,991,136,594, run=0) CPU2 0 unhalted_core_cycles (ena=1,991,136,594, run=0) CPU3 4,747,990,931 unhalted_core_cycles (ena=1,991,136,594, run=1,991,136,594) CPU3 4,747,990,931 unhalted_core_cycles (ena=1,991,136,594, run=1,991,136,594) Signed-off-by: Stephane Eranian <eranian@gmail.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus@samba.org Cc: davem@davemloft.net Cc: fweisbec@gmail.com Cc: perfmon2-devel@lists.sf.net Cc: eranian@google.com LKML-Reference: <4c76802d.aae9d80a.115d.70fe@mx.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-06Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) sched: Use correct macro to display sched_child_runs_first in /proc/sched_debug sched: No need for bootmem special cases sched: Revert nohz_ratelimit() for now sched: Reduce update_group_power() calls sched: Update rq->clock for nohz balanced cpus sched: Fix spelling of sibling sched, cpuset: Drop __cpuexit from cpu hotplug callbacks sched: Fix the racy usage of thread_group_cputimer() in fastpath_timer_check() sched: run_posix_cpu_timers: Don't check ->exit_state, use lock_task_sighand() sched: thread_group_cputime: Simplify, document the "alive" check sched: Remove the obsolete exit_state/signal hacks sched: task_tick_rt: Remove the obsolete ->signal != NULL check sched: __sched_setscheduler: Read the RLIMIT_RTPRIO value lockless sched: Fix comments to make them DocBook happy sched: Fix fix_small_capacity powerpc: Exclude arch_sd_sibiling_asym_packing() on UP powerpc: Enable asymmetric SMT scheduling on POWER7 sched: Add asymmetric group packing option for sibling domain sched: Fix capacity calculations for SMT4 sched: Change nohz idle load balancing logic to push model ...
2010-06-18Merge commit 'v2.6.35-rc3' into sched/coreIngo Molnar
Merge reason: Update to the latest -rc.
2010-06-09Merge branch 'perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into perf/core
2010-06-09perf: Convert perf_event to local_tPeter Zijlstra
Since now all modification to event->count (and ->prev_count and ->period_left) are local to a cpu, change then to local64_t so we avoid the LOCK'ed ops. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-09perf: Add perf_event::child_countPeter Zijlstra
Only child counters adding back their values into the parent counter are responsible for cross-cpu updates to event->count. So if we pull that out into a new child_count variable, we get an event->count that is only modified locally. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-09perf: Add perf_event_count()Peter Zijlstra
Create a helper function for those sites that want to read the event count. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-09perf: Simplify the ring-buffer logic: make perf_buffer_alloc() do everything ↵Peter Zijlstra
needed Currently there are perf_buffer_alloc() + perf_buffer_init() + some separate bits, fold it all into a single perf_buffer_alloc() and only leave the attachment to the event separate. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-09perf: Rename perf_mmap_data to perf_bufferPeter Zijlstra
Rename to clarify code. s/perf_mmap_data/perf_buffer/g and selective s/data/buffer/g Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-09perf: Cleanup {start,commit,cancel}_txn detailsPeter Zijlstra
Clarify some of the transactional group scheduling API details and change it so that a successfull ->commit_txn also closes the transaction. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1274803086.5882.1752.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-09perf: Add non-exec mmap() trackingEric B Munson
Add the capacility to track data mmap()s. This can be used together with PERF_SAMPLE_ADDR for data profiling. Signed-off-by: Anton Blanchard <anton@samba.org> [Updated code for stable perf ABI] Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1274193049-25997-1-git-send-email-ebmunson@us.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-09perf, trace: Remove superfluous rcu_read_lock()Peter Zijlstra
__DO_TRACE() already calls the callbacks under rcu_read_lock_sched(), which is sufficient for our needs, avoid doing it again. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-09perf, trace: Inline perf_swevent_put_recursion_context()Peter Zijlstra
Inline perf_swevent_put_recursion_context into perf_tp_event(), this shrinks the per trace template code footprint and saves a function call. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-09sched_clock: Add local_clock() API and improve documentationPeter Zijlstra
For people who otherwise get to write: cpu_clock(smp_processor_id()), there is now: local_clock(). Also, as per suggestion from Andrew, provide some documentation on the various clock interfaces, and minimize the unsigned long long vs u64 mess. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jens Axboe <jaxboe@fusionio.com> LKML-Reference: <1275052414.1645.52.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-08perf: Drop the skip argument from perf_arch_fetch_regs_callerFrederic Weisbecker
Drop this argument now that we always want to rewind only to the state of the first caller. It means frame pointers are not necessary anymore to reliably get the source of an event. But this also means we need this helper to be a macro now, as an inline function is not an option since we need to know when to provide a default implentation. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: David Miller <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-06-08perf: Fix signed comparison in perf_adjust_period()Peter Zijlstra
Frederic reported that frequency driven swevents didn't work properly and even caused a division-by-zero error. It turns out there are two bugs, the division-by-zero comes from a failure to deal with that in perf_calculate_period(). The other was more interesting and turned out to be a wrong comparison in perf_adjust_period(). The comparison was between an s64 and u64 and got implicitly converted to an unsigned comparison. The problem is that period_left is typically < 0, so it ended up being always true. Cure this by making the local period variables s64. Reported-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-03perf: Fix crash in sweventsPeter Zijlstra
Frederic reported that because swevents handling doesn't disable IRQs anymore, we can get a recursion of perf_adjust_period(), once from overflow handling and once from the tick. If both call ->disable, we get a double hlist_del_rcu() and trigger a LIST_POISON2 dereference. Since we don't actually need to stop/start a swevent to re-programm the hardware (lack of hardware to program), simply nop out these callbacks for the swevent pmu. Reported-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1275557609.27810.35218.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-31perf_events: Fix unincremented buffer base on partial copyFrederic Weisbecker
If a sample size crosses to the next page boundary, the copy will be made in more than one step. However we forget to advance the source offset for the next copy, leading to unexpected double copies that completely mess up the traces. This fixes various kinds of bad traces that have irrelevant data inside, as an example: geany-4979 [001] 5758.077775: sched_switch: prev_comm=! prev_pid=121 prev_prio=0 prev_state=S|D|Z|X|x ==> next_comm= next_pid=7497072 next_prio=0 Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1274988898-5639-1-git-send-regression-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-31perf_events: Fix event scheduling issues introduced by transactional APIStephane Eranian
The transactional API patch between the generic and model-specific code introduced several important bugs with event scheduling, at least on X86. If you had pinned events, e.g., watchdog, and were over-committing the PMU, you would get bogus counts. The bug was showing up on Intel CPU because events would move around more often that on AMD. But the problem also existed on AMD, though harder to expose. The issues were: - group_sched_in() was missing a cancel_txn() in the error path - cpuc->n_added was not properly maintained, leading to missing actions in hw_perf_enable(), i.e., n_running being 0. You cannot update n_added until you know the transaction has succeeded. In case of failed transaction n_added was not adjusted back. - in case of failed transactions, event_sched_out() was called and eventually invoked x86_disable_event() to touch the HW reg. But with transactions, on X86, event_sched_in() does not touch HW registers, it simply collects events into a list. Thus, you could end up calling x86_disable_event() on a counter which did not correspond to the current event when idx != -1. The patch modifies the generic and X86 code to avoid all those problems. First, we keep track of the number of events added last. In case the transaction fails, we substract them from n_added. This approach is necessary (as opposed to delaying updates to n_added) because not all event updates use the transaction API, e.g., single events. Second, we encapsulate the event_sched_in() and event_sched_out() in group_sched_in() inside the transaction. That makes the operations symmetrical and you can also detect that you are inside a transaction and skip the HW reg access by checking cpuc->group_flag. With this patch, you can now overcommit the PMU even with pinned system-wide events present and still get valid counts. Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1274796225.5882.1389.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-31perf_events: Fix races in group compositionPeter Zijlstra
Group siblings don't pin each-other or the parent, so when we destroy events we must make sure to clean up all cross referencing pointers. In particular, for destruction of a group leader we must be able to find all its siblings and remove their reference to it. This means that detaching an event from its context must not detach it from the group, otherwise we can end up failing to clear all pointers. Solve this by clearly separating the attachment to a context and attachment to a group, and keep the group composed until we destroy the events. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-31perf_events: Fix races and clean up perf_event and perf_mmap_data interactionPeter Zijlstra
In order to move toward separate buffer objects, rework the whole perf_mmap_data construct to be a more self-sufficient entity, one with its own lifetime rules. This greatly sanitizes the whole output redirection code, which was riddled with bugs and races. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-27Fix racy use of anon_inode_getfd() in perf_event.cAl Viro
once anon_inode_getfd() is called, you can't expect *anything* about struct file that descriptor points to - another thread might be doing whatever it likes with descriptor table at that point. Cc: stable <stable@kernel.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21perf: Optimize perf_tp_event_match()Peter Zijlstra
Since we know tracepoints come from kernel context, avoid conditionals that try and establish that very fact. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20100521090710.904944001@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-21perf: Remove more code from the fastpathPeter Zijlstra
Sanity checks cost instructions. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20100521090710.852926930@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-21perf: Optimize the !vmalloc backed bufferPeter Zijlstra
Reduce code and data by using the knowledge that for !PERF_USE_VMALLOC data_order is always 0. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20100521090710.795019386@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-21perf: Optimize perf_output_copy()Peter Zijlstra
Reduce the clutter in perf_output_copy() by keeping an interator in perf_output_handle. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20100521090710.742809176@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-21perf: Fix wakeup storm for RO mmap()sPeter Zijlstra
RO mmap()s don't update the tail pointer, so comparing against it for determining the written data size doesn't really do any good. Keep track of when we last did a wakeup, and compare against that. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20100521090710.684479310@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-21perf: Ensure that IOC_OUTPUT isn't used to create multi-writer buffersPeter Zijlstra
Since we want to ensure buffers only have a single writer, we must avoid creating one with multiple. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20100521090710.528215873@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-21perf, trace: Optimize tracepoints by using per-tracepoint-per-cpu hlist to ↵Peter Zijlstra
track events Avoid the swevent hash-table by using per-tracepoint hlists. Also, avoid conditionals on the fast path by ordering with probe unregister so that we should never get on the callback path without the data being there. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20100521090710.473188012@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-20perf: Fix forgotten preempt_enable by nested writersFrederic Weisbecker
A writer that gets a reference to the buffer handle disables preemption. When we put that reference, we check if we are the outer most writer and if not, we simply return and defer the head update to the outer most writer. The problem here is that preemption is only reenabled by the outer most, that produces preemption count imbalance for every nested writer that exit. So just don't forget to always re-enable preemption when we put the buffer reference, whoever we are. Fixes lots of sleeping in atomic warnings, visible with lock events recording. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> Cc: Robert Richter <robert.richter@amd.com>
2010-05-20Merge branch 'perf/urgent' of ↵Ingo Molnar
2010-05-20perf: Comply with new rcu checks APIFrederic Weisbecker
The software events hlist doesn't fully comply with the new rcu checks api. We need to consider three different sides that access the hlist: - the hlist allocation/release side. This side happens when an events is created or released, accesses to the hlist are serialized under the cpuctx mutex. - the events insertion/removal in the hlist. This side is always serialized against the above one. The hlist is always present during such operations. This side happens when a software event is scheduled in/out. The serialization that ensures the software event is really attached to the context is made under the ctx->lock. - events triggering. This is the read side, it can happen concurrently with any update side. This patch deals with them one by one and anticipates with the separate rcu mem space patches in preparation. This patch fixes various annoying rcu warnings. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org>
2010-05-18perf: Optimize perf_output_*() by avoiding local_xchg()Peter Zijlstra
Since the x86 XCHG ins implies LOCK, avoid the use by using a sequence count instead. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-18perf: Optimize the hotpath by converting the perf output buffer to local_tPeter Zijlstra
Since there is now only a single writer, we can use local_t instead and avoid all these pesky LOCK insn. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-18perf: Optimize the perf_output() path by removing IRQ-disablesPeter Zijlstra
Since we can now assume there is only a single writer to each buffer, we can remove per-cpu lock thingy and use a simply nest-count to the same effect. This removes the need to disable IRQs. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-18perf: Disallow mmap() on per-task inherited eventsPeter Zijlstra
Since we now have working per-task-per-cpu events for a while, disallow mmap() on per-task inherited events. Those things were a performance problem anyway, and doing away with it allows us to optimize the buffer somewhat by assuming there is only a single writer. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-18perf: Optimize buffer placement by allocating buffers NUMA awarePeter Zijlstra
Ensure cpu bound buffers live on the right NUMA node. Suggested-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1274114880.5605.5236.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-18perf: Fix errors path in perf_output_begin()Stephane Eranian
In case the sampling buffer has no "payload" pages, nr_pages is 0. The problem is that the error path in perf_output_begin() skips to a label which assumes perf_output_lock() has been issued which is not the case. That triggers a WARN_ON() in perf_output_unlock(). This patch fixes the problem by skipping perf_output_unlock() in case data->nr_pages is 0. Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <4bf13674.014fd80a.6c82.ffffb20c@mx.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-18perf/ftrace: Optimize perf/tracepoint interaction for single eventsPeter Zijlstra
When we've got but a single event per tracepoint there is no reason to try and multiplex it so don't. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-11perf: Fix exit() vs event-groupsPeter Zijlstra
Corey reported that the value scale times of group siblings are not updated when the monitored task dies. The problem appears to be that we only update the group leader's time values, fix it by updating the whole group. Reported-by: Corey Ashford <cjashfor@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: <stable@kernel.org> # .34.x LKML-Reference: <1273588935.1810.6.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-11perf: Fix exit() vs PERF_FORMAT_GROUPPeter Zijlstra
Both Stephane and Corey reported that PERF_FORMAT_GROUP didn't work as expected if the task the counters were attached to quit before the read() call. The cause is that we unconditionally destroy the grouping when we remove counters from their context. Fix this by splitting off the group destroy from the list removal such that perf_event_remove_from_context() does not do this and change perf_event_release() to do so. Reported-by: Corey Ashford <cjashfor@linux.vnet.ibm.com> Reported-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: <stable@kernel.org> # .34.x LKML-Reference: <1273571513.5605.3527.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-11Revert "perf: Fix exit() vs PERF_FORMAT_GROUP"Ingo Molnar
This reverts commit 4fd38e4595e2f6c9d27732c042a0e16b2753049c. It causes various crashes and hangs when events are activated. The cause is not fully understood yet but we need to revert it because the effects are severe. Reported-by: Stephane Eranian <eranian@google.com> Reported-by: Lin Ming <ming.m.lin@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-08perf_event: Make software events work againPaul Mackerras
Commit 6bde9b6ce0127e2a56228a2071536d422be31336 ("perf: Add group scheduling transactional APIs") added code to allow a group to be scheduled in a single transaction. However, it introduced a bug in handling events whose pmu does not implement transactions -- at the end of scheduling in the events in the group, in the non-transactional case the code now falls through to the group_error label, and proceeds to unschedule all the events in the group and return failure. This fixes it by returning 0 (success) in the non-transactional case. Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: eranian@gmail.com LKML-Reference: <20100508105800.GB10650@brick.ozlabs.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-07perf: Add group scheduling transactional APIsLin Ming
Add group scheduling transactional APIs to struct pmu. These APIs will be implemented in arch code, based on Peter's idea as below. > the idea behind hw_perf_group_sched_in() is to not perform > schedulability tests on each event in the group, but to add the group > as a whole and then perform one test. > > Of course, when that test fails, you'll have to roll-back the whole > group again. > > So start_txn (or a better name) would simply toggle a flag in the pmu > implementation that will make pmu::enable() not perform the > schedulablilty test. > > Then commit_txn() will perform the schedulability test (so note the > method has to have a !void return value. > > This will allow us to use the regular > kernel/perf_event.c::group_sched_in() and all the rollback code. > Currently each hw_perf_group_sched_in() implementation duplicates all > the rolllback code (with various bugs). ->start_txn: Start group events scheduling transaction, set a flag to make pmu::enable() not perform the schedulability test, it will be performed at commit time. ->commit_txn: Commit group events scheduling transaction, perform the group schedulability as a whole ->cancel_txn: Stop group events scheduling transaction, clear the flag so pmu::enable() will perform the schedulability test. Reviewed-by: Stephane Eranian <eranian@google.com> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1272002160.5707.60.camel@minggr.sh.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-07perf: Annotate perf_event_read_group() vs perf_event_release_kernel()Peter Zijlstra
Stephane reported a lockdep warning while using PERF_FORMAT_GROUP. The issue is that perf_event_read_group() takes faults while holding the ctx->mutex, while perf_event_release_kernel() can be called from munmap(). Which makes for an AB-BA deadlock. Except we can never establish the deadlock because we'll only ever call perf_event_release_kernel() after all file descriptors are dead so there is no concurrency possible. Reported-by: Stephane Eranian <eranian@google.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-07Merge branch 'perf/urgent' into perf/coreIngo Molnar
Merge reason: Resolve patch dependency Signed-off-by: Ingo Molnar <mingo@elte.hu>
