Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details you
should have received a copy of the gnu general public license along
with this program if not see http www gnu org licenses
purpose see the gnu general public license for more details [based]
[from] [clk] [highbank] [c] you should have received a copy of the
gnu general public license along with this program if not see http
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 355 file(s).
Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com>
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190519154041.837383322@linutronix.de
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"The major changes in this tracing update includes:
- Removal of non-DYNAMIC_FTRACE from 32bit x86
- Removal of mcount support from x86
- Emulating a call from int3 on x86_64, fixes live kernel patching
- Consolidated Tracing Error logs file
Minor updates:
- Removal of klp_check_compiler_support()
- kdb ftrace dumping output changes
- Accessing and creating ftrace instances from inside the kernel
- Clean up of #define if macro
- Introduction of TRACE_EVENT_NOP() to disable trace events based on
config options
And other minor fixes and clean ups"
* tag 'trace-v5.2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (44 commits)
x86: Hide the int3_emulate_call/jmp functions from UML
livepatch: Remove klp_check_compiler_support()
ftrace/x86: Remove mcount support
ftrace/x86_32: Remove support for non DYNAMIC_FTRACE
tracing: Simplify "if" macro code
tracing: Fix documentation about disabling options using trace_options
tracing: Replace kzalloc with kcalloc
tracing: Fix partial reading of trace event's id file
tracing: Allow RCU to run between postponed startup tests
tracing: Fix white space issues in parse_pred() function
tracing: Eliminate const char[] auto variables
ring-buffer: Fix mispelling of Calculate
tracing: probeevent: Fix to make the type of $comm string
tracing: probeevent: Do not accumulate on ret variable
tracing: uprobes: Re-enable $comm support for uprobe events
ftrace/x86_64: Emulate call function while updating in breakpoint handler
x86_64: Allow breakpoints to emulate call instructions
x86_64: Add gap to int3 to allow for call emulation
tracing: kdb: Allow ftdump to skip all but the last few entries
tracing: Add trace_total_entries() / trace_total_entries_cpu()
The only purpose of klp_check_compiler_support() is to make sure that we
are not using ftrace on x86 via mcount (because that's executed only after
prologue has already happened, and that's too late for livepatching
purposes).
Now that mcount is not supported by ftrace any more, there is no need for
klp_check_compiler_support() either.
Link: http://lkml.kernel.org/r/nycvar.YFH.7.76.1905102346100.17054@cbobk.fhfr.pm
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core/kobject updates from Greg KH:
"Here is the "big" set of driver core patches for 5.2-rc1
There are a number of ACPI patches in here as well, as Rafael said
they should go through this tree due to the driver core changes they
required. They have all been acked by the ACPI developers.
There are also a number of small subsystem-specific changes in here,
due to some changes to the kobject core code. Those too have all been
acked by the various subsystem maintainers.
As for content, it's pretty boring outside of the ACPI changes:
- spdx cleanups
- kobject documentation updates
- default attribute groups for kobjects
- other minor kobject/driver core fixes
All have been in linux-next for a while with no reported issues"
* tag 'driver-core-5.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (47 commits)
kobject: clean up the kobject add documentation a bit more
kobject: Fix kernel-doc comment first line
kobject: Remove docstring reference to kset
firmware_loader: Fix a typo ("syfs" -> "sysfs")
kobject: fix dereference before null check on kobj
Revert "driver core: platform: Fix the usage of platform device name(pdev->name)"
init/config: Do not select BUILD_BIN2C for IKCONFIG
Provide in-kernel headers to make extending kernel easier
kobject: Improve doc clarity kobject_init_and_add()
kobject: Improve docs for kobject_add/del
livepatch: Replace klp_ktype_patch's default_attrs with groups
cpufreq: schedutil: Replace default_attrs field with groups
padata: Replace padata_attr_type default_attrs field with groups
irqdesc: Replace irq_kobj_type's default_attrs field with groups
net-sysfs: Replace ktype default_attrs field with groups
block: Replace all ktype default_attrs with groups
samples/kobject: Replace foo_ktype's default_attrs field with groups
kobject: Add support for default attribute groups to kobj_type
driver core: Postpone DMA tear-down until after devres release for probe failure
git://git.kernel.org/pub/scm/linux/kernel/git/livepatching/livepatching
Pull livepatching updates from Jiri Kosina:
- livepatching kselftests improvements from Joe Lawrence and Miroslav
Benes
- making use of gcc's -flive-patching option when available, from
Miroslav Benes
- kobject handling cleanups, from Petr Mladek
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/livepatching/livepatching:
livepatch: Remove duplicated code for early initialization
livepatch: Remove custom kobject state handling
livepatch: Convert error about unsupported reliable stacktrace into a warning
selftests/livepatch: Add functions.sh to TEST_PROGS_EXTENDED
kbuild: use -flive-patching when CONFIG_LIVEPATCH is enabled
selftests/livepatch: use TEST_PROGS for test scripts
kobject_init() call added one more operation that has to be
done when doing the early initialization of both static and
dynamic livepatch structures.
It would have been easier when the early initialization code
was not duplicated. Let's deduplicate it for future generations
of livepatching hackers.
The patch does not change the existing behavior.
Signed-off-by: Petr Mladek <pmladek@suse.com>
Reviewed-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Acked-by: Joe Lawrence <joe.lawrence@redhat.com>
kobject_init() always succeeds and sets the reference count to 1.
It allows to always free the structures via kobject_put() and
the related release callback.
Note that the custom kobject state handling was used only
because we did not know that kobject_put() can and actually
should get called even when kobject_init_and_add() fails.
The patch should not change the existing behavior.
Suggested-by: "Tobin C. Harding" <tobin@kernel.org>
The commit d0807da78e11d46f ("livepatch: Remove immediate feature") caused
that any livepatch was refused when reliable stacktraces were not supported
on the given architecture.
The limitation is too strong. User space processes are safely migrated
even when entering or leaving the kernel. Kthreads transition would
need to get forced. But it is safe when:
+ The livepatch does not change the semantic of the code.
+ Callbacks do not depend on a safely finished transition.
Suggested-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Miroslav Benes <mbenes@suse.cz>
Replace the indirection through struct stack_trace by using the storage
array based interfaces.
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: linux-mm@kvack.org
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: kasan-dev@googlegroups.com
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: Akinobu Mita <akinobu.mita@gmail.com>
Cc: iommu@lists.linux-foundation.org
Cc: Robin Murphy <robin.murphy@arm.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
Cc: David Sterba <dsterba@suse.com>
Cc: Chris Mason <clm@fb.com>
Cc: Josef Bacik <josef@toxicpanda.com>
Cc: linux-btrfs@vger.kernel.org
Cc: dm-devel@redhat.com
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Daniel Vetter <daniel@ffwll.ch>
Cc: intel-gfx@lists.freedesktop.org
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Cc: dri-devel@lists.freedesktop.org
Cc: David Airlie <airlied@linux.ie>
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: Rodrigo Vivi <rodrigo.vivi@intel.com>
Cc: Tom Zanussi <tom.zanussi@linux.intel.com>
Link: https://lkml.kernel.org/r/20190425094803.437950229@linutronix.de
The kobj_type default_attrs field is being replaced by the
default_groups field. Replace klp_ktype_patch's default_attrs field
with default_groups and use the ATTRIBUTE_GROUPS macro to create
klp_patch_groups.
This patch was tested by loading the livepatch-sample module and
verifying that the sysfs files for the attributes in the default groups
were created.
Signed-off-by: Kimberly Brown <kimbrownkd@gmail.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: Petr Mladek <pmladek@suse.com>
The atomic replace allows to create cumulative patches. They are useful when
you maintain many livepatches and want to remove one that is lower on the
stack. In addition it is very useful when more patches touch the same function
and there are dependencies between them.
It's also a feature some of the distros are using already to distribute
their patches.
Livepatches can no longer get enabled and disabled repeatedly.
The list klp_patches contains only enabled patches and eventually
the patch in transition.
The module coming and going callbacks do no longer need to check
for these state. They have to proceed with all listed patches.
There are already macros to iterate over struct klp_func and klp_object.
Add also klp_for_each_patch(). But make it internal because also
klp_patches list is internal.
As a result of an unsupported operation is better to use EOPNOTSUPP
as error code.
ENOSYS is only used for 'invalid syscall nr' and nothing else.
Signed-off-by: Alice Ferrazzi <alice.ferrazzi@miraclelinux.com>
The fake signal is send automatically now. We can rely on it completely
and remove the sysfs attribute.
Signed-off-by: Miroslav Benes <mbenes@suse.cz>
An administrator may send a fake signal to all remaining blocking tasks
of a running transition by writing to
/sys/kernel/livepatch/<patch>/signal attribute. Let's do it
automatically after 15 seconds. The timeout is chosen deliberately. It
gives the tasks enough time to transition themselves.
Theoretically, sending it once should be more than enough. However,
every task must get outside of a patched function to be successfully
transitioned. It could prove not to be simple and resending could be
helpful in that case.
A new workqueue job could be a cleaner solution to achieve it, but it
could also introduce deadlocks and cause more headaches with
synchronization and cancelling.
[jkosina@suse.cz: removed added newline]
The atomic replace and cumulative patches were introduced as a more secure
way to handle dependent patches. They simplify the logic:
+ Any new cumulative patch is supposed to take over shadow variables
and changes made by callbacks from previous livepatches.
+ All replaced patches are discarded and the modules can be unloaded.
As a result, there is only one scenario when a cumulative livepatch
gets disabled.
The different handling of "normal" and cumulative patches might cause
confusion. It would make sense to keep only one mode. On the other hand,
it would be rude to enforce using the cumulative livepatches even for
trivial and independent (hot) fixes.
However, the stack of patches is not really necessary any longer.
The patch ordering was never clearly visible via the sysfs interface.
Also the "normal" patches need a lot of caution anyway.
Note that the list of enabled patches is still necessary but the ordering
is not longer enforced.
Otherwise, the code is ready to disable livepatches in an random order.
Namely, klp_check_stack_func() always looks for the function from
the livepatch that is being disabled. klp_func structures are just
removed from the related func_stack. Finally, the ftrace handlers
is removed only when the func_stack becomes empty.
Replaced patches are removed from the stack when the transition is
finished. It means that Nop structures will never be needed again
and can be removed. Why should we care?
+ Nop structures give the impression that the function is patched
even though the ftrace handler has no effect.
+ Ftrace handlers do not come for free. They cause slowdown that might
be visible in some workloads. The ftrace-related slowdown might
actually be the reason why the function is no longer patched in
the new cumulative patch. One would expect that cumulative patch
would help solve these problems as well.
+ Cumulative patches are supposed to replace any earlier version of
the patch. The amount of NOPs depends on which version was replaced.
This multiplies the amount of scenarios that might happen.
One might say that NOPs are innocent. But there are even optimized
NOP instructions for different processors, for example, see
arch/x86/kernel/alternative.c. And klp_ftrace_handler() is much
more complicated.
+ It sounds natural to clean up a mess that is no longer needed.
It could only be worse if we do not do it.
This patch allows to unpatch and free the dynamic structures independently
when the transition finishes.
The free part is a bit tricky because kobject free callbacks are called
asynchronously. We could not wait for them easily. Fortunately, we do
not have to. Any further access can be avoided by removing them from
the dynamic lists.
Sometimes we would like to revert a particular fix. Currently, this
is not easy because we want to keep all other fixes active and we
could revert only the last applied patch.
One solution would be to apply new patch that implemented all
the reverted functions like in the original code. It would work
as expected but there will be unnecessary redirections. In addition,
it would also require knowing which functions need to be reverted at
build time.
Another problem is when there are many patches that touch the same
functions. There might be dependencies between patches that are
not enforced on the kernel side. Also it might be pretty hard to
actually prepare the patch and ensure compatibility with the other
patches.
Atomic replace && cumulative patches:
A better solution would be to create cumulative patch and say that
it replaces all older ones.
This patch adds a new "replace" flag to struct klp_patch. When it is
enabled, a set of 'nop' klp_func will be dynamically created for all
functions that are already being patched but that will no longer be
modified by the new patch. They are used as a new target during
the patch transition.
The idea is to handle Nops' structures like the static ones. When
the dynamic structures are allocated, we initialize all values that
are normally statically defined.
The only exception is "new_func" in struct klp_func. It has to point
to the original function and the address is known only when the object
(module) is loaded. Note that we really need to set it. The address is
used, for example, in klp_check_stack_func().
Nevertheless we still need to distinguish the dynamically allocated
structures in some operations. For this, we add "nop" flag into
struct klp_func and "dynamic" flag into struct klp_object. They
need special handling in the following situations:
+ The structures are added into the lists of objects and functions
immediately. In fact, the lists were created for this purpose.
+ The address of the original function is known only when the patched
object (module) is loaded. Therefore it is copied later in
klp_init_object_loaded().
+ The ftrace handler must not set PC to func->new_func. It would cause
infinite loop because the address points back to the beginning of
the original function.
+ The various free() functions must free the structure itself.
Note that other ways to detect the dynamic structures are not considered
safe. For example, even the statically defined struct klp_object might
include empty funcs array. It might be there just to run some callbacks.
Also note that the safe iterator must be used in the free() functions.
Otherwise already freed structures might get accessed.
Special callbacks handling:
The callbacks from the replaced patches are _not_ called by intention.
It would be pretty hard to define a reasonable semantic and implement it.
It might even be counter-productive. The new patch is cumulative. It is
supposed to include most of the changes from older patches. In most cases,
it will not want to call pre_unpatch() post_unpatch() callbacks from
the replaced patches. It would disable/break things for no good reasons.
Also it should be easier to handle various scenarios in a single script
in the new patch than think about interactions caused by running many
scripts from older patches. Not to say that the old scripts even would
not expect to be called in this situation.
Removing replaced patches:
One nice effect of the cumulative patches is that the code from the
older patches is no longer used. Therefore the replaced patches can
be removed. It has several advantages:
+ Nops' structs will no longer be necessary and might be removed.
This would save memory, restore performance (no ftrace handler),
allow clear view on what is really patched.
+ Disabling the patch will cause using the original code everywhere.
Therefore the livepatch callbacks could handle only one scenario.
Note that the complication is already complex enough when the patch
gets enabled. It is currently solved by calling callbacks only from
+ The state is clean in both the sysfs interface and lsmod. The modules
with the replaced livepatches might even get removed from the system.
Some people actually expected this behavior from the beginning. After all
a cumulative patch is supposed to "completely" replace an existing one.
It is like when a new version of an application replaces an older one.
This patch does the first step. It removes the replaced patches from
the list of patches. It is safe. The consistency model ensures that
they are no longer used. By other words, each process works only with
the structures from klp_transition_patch.
The removal is done by a special function. It combines actions done by
__disable_patch() and klp_complete_transition(). But it is a fast
track without all the transaction-related stuff.
Signed-off-by: Jason Baron <jbaron@akamai.com>
[pmladek@suse.com: Split, reuse existing code, simplified]
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jessica Yu <jeyu@kernel.org>
Cc: Jiri Kosina <jikos@kernel.org>
Cc: Miroslav Benes <mbenes@suse.cz>
Currently klp_patch contains a pointer to a statically allocated array of
struct klp_object and struct klp_objects contains a pointer to a statically
allocated array of klp_func. In order to allow for the dynamic allocation
of objects and functions, link klp_patch, klp_object, and klp_func together
via linked lists. This allows us to more easily allocate new objects and
functions, while having the iterator be a simple linked list walk.
The static structures are added to the lists early. It allows to add
the dynamically allocated objects before klp_init_object() and
klp_init_func() calls. Therefore it reduces the further changes
to the code.
This patch does not change the existing behavior.
[pmladek@suse.com: Initialize lists before init calls]
The possibility to re-enable a registered patch was useful for immediate
patches where the livepatch module had to stay until the system reboot.
The improved consistency model allows to achieve the same result by
unloading and loading the livepatch module again.
Also we are going to add a feature called atomic replace. It will allow
to create a patch that would replace all already registered patches.
The aim is to handle dependent patches more securely. It will obsolete
the stack of patches that helped to handle the dependencies so far.
Then it might be unclear when a cumulative patch re-enabling is safe.
It would be complicated to support the many modes. Instead we could
actually make the API and code easier to understand.
Therefore, remove the two step public API. All the checks and init calls
are moved from klp_register_patch() to klp_enabled_patch(). Also the patch
is automatically freed, including the sysfs interface when the transition
to the disabled state is completed.
As a result, there is never a disabled patch on the top of the stack.
Therefore we do not need to check the stack in __klp_enable_patch().
And we could simplify the check in __klp_disable_patch().
Also the API and logic is much easier. It is enough to call
klp_enable_patch() in module_init() call. The patch can be disabled
by writing '0' into /sys/kernel/livepatch/<patch>/enabled. Then the module
can be removed once the transition finishes and sysfs interface is freed.
The only problem is how to free the structures and kobjects safely.
The operation is triggered from the sysfs interface. We could not put
the related kobject from there because it would cause lock inversion
between klp_mutex and kernfs locks, see kn->count lockdep map.
Therefore, offload the free task to a workqueue. It is perfectly fine:
+ The patch can no longer be used in the livepatch operations.
+ The module could not be removed until the free operation finishes
and module_put() is called.
+ The operation is asynchronous already when the first
klp_try_complete_transition() fails and another call
is queued with a delay.
module_put() is currently never called in klp_complete_transition() when
klp_force is set. As a result, we might keep the reference count even when
klp_enable_patch() fails and klp_cancel_transition() is called.
This might give the impression that a module might get blocked in some
strange init state. Fortunately, it is not the case. The reference count
is ignored when mod->init fails and erroneous modules are always removed.
Anyway, this might be confusing. Instead, this patch moves
the global klp_forced flag into struct klp_patch. As a result,
we block only modules that might still be in use after a forced
transition. Newly loaded livepatches might be eventually completely
removed later.
It is not a big deal. But the code is at least consistent with
the reality.
The code for freeing livepatch structures is a bit scattered and tricky:
+ direct calls to klp_free_*_limited() and kobject_put() are
used to release partially initialized objects
+ klp_free_patch() removes the patch from the public list
and releases all objects except for patch->kobj
+ object_put(&patch->kobj) and the related wait_for_completion()
are called directly outside klp_mutex; this code is duplicated;
Now, we are going to remove the registration stage to simplify the API
and the code. This would require handling more situations in
klp_enable_patch() error paths.
More importantly, we are going to add a feature called atomic replace.
It will need to dynamically create func and object structures. We will
want to reuse the existing init() and free() functions. This would
create even more error path scenarios.
This patch implements more straightforward free functions:
+ checks kobj_added flag instead of @limit[*]
+ initializes patch->list early so that the check for empty list
always works
+ The action(s) that has to be done outside klp_mutex are done
in separate klp_free_patch_finish() function. It waits only
when patch->kobj was really released via the _start() part.
[*] We need our own flag to track that the kobject was successfully
added to the hierarchy. Note that kobj.state_initialized only
indicates that kobject has been initialized, not whether is has
been added (and needs to be removed on cleanup).
Cc: Jason Baron <jbaron@akamai.com>
We are going to simplify the API and code by removing the registration
step. This would require calling init/free functions from enable/disable
ones.
This patch just moves the code to prevent more forward declarations.
This patch does not change the code except for two forward declarations.
The address of the to be patched function and new function is stored
in struct klp_func as:
void *new_func;
unsigned long old_addr;
The different naming scheme and type are derived from the way
the addresses are set. @old_addr is assigned at runtime using
kallsyms-based search. @new_func is statically initialized,
for example:
static struct klp_func funcs[] = {
.old_name = "cmdline_proc_show",
.new_func = livepatch_cmdline_proc_show,
This patch changes unsigned long old_addr -> void *old_func. It removes
some confusion when these address are later used in the code. It is
motivated by a followup patch that adds special NOP struct klp_func
where we want to assign func->new_func = func->old_addr respectively
func->new_func = func->old_func.
This patch does not modify the existing behavior.
Acked-by: Alice Ferrazzi <alice.ferrazzi@gmail.com>
Now that synchronize_rcu() waits for preempt-disable regions of code
as well as RCU read-side critical sections, synchronize_sched() can be
replaced by synchronize_rcu(). This commit therefore makes this change,
even though it is but a comment.
Signed-off-by: Paul E. McKenney <paulmck@linux.ibm.com>
livepatch module author can pass module name/old function name with more
than the defined character limit. With obj->name length greater than
MODULE_NAME_LEN, the livepatch module gets loaded but waits forever on
the module specified by obj->name to be loaded. It also populates a /sys
directory with an untruncated object name.
In the case of funcs->old_name length greater then KSYM_NAME_LEN, it
would not match against any of the symbol table entries. Instead loop
through the symbol table comparing them against a nonexisting function,
which can be avoided.
The same issues apply, to misspelled/incorrect names. At least gatekeep
the modules with over the limit string length, by checking for their
length during livepatch module registration.
Cc: stable@vger.kernel.org
Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Support for immediate flag was removed by commit d0807da78e11
("livepatch: Remove immediate feature"). We bail out during
patch registration for architectures, those don't support
reliable stack trace. Remove the check in klp_try_switch_task(),
as its not required.
Reviewed-by: Petr Mladek <pmladek@suse.com>
We might need to do some actions before the shadow variable is freed.
For example, we might need to remove it from a list or free some data
that it points to.
This is already possible now. The user can get the shadow variable
by klp_shadow_get(), do the necessary actions, and then call
klp_shadow_free().
This patch allows to do it a more elegant way. The user could implement
the needed actions in a callback that is passed to klp_shadow_free()
as a parameter. The callback usually does reverse operations to
the constructor callback that can be called by klp_shadow_*alloc().
It is especially useful for klp_shadow_free_all(). There we need to do
these extra actions for each found shadow variable with the given ID.
Note that the memory used by the shadow variable itself is still released
later by rcu callback. It is needed to protect internal structures that
keep all shadow variables. But the destructor is called immediately.
The shadow variable must not be access anyway after klp_shadow_free()
is called. The user is responsible to protect this any suitable way.
Be aware that the destructor is called under klp_shadow_lock. It is
the same as for the contructor in klp_shadow_alloc().
The existing API allows to pass a sample data to initialize the shadow
data. It works well when the data are position independent. But it fails
miserably when we need to set a pointer to the shadow structure itself.
Unfortunately, we might need to initialize the pointer surprisingly
often because of struct list_head. It is even worse because the list
might be hidden in other common structures, for example, struct mutex,
struct wait_queue_head.
For example, this was needed to fix races in ALSA sequencer. It required
to add mutex into struct snd_seq_client. See commit b3defb791b26ea06
("ALSA: seq: Make ioctls race-free") and commit d15d662e89fc667b9
("ALSA: seq: Fix racy pool initializations")
This patch makes the API more safe. A custom constructor function and data
are passed to klp_shadow_*alloc() functions instead of the sample data.
Note that ctor_data are no longer a template for shadow->data. It might
point to any data that might be necessary when the constructor is called.
Also note that the constructor is called under klp_shadow_lock. It is
an internal spin_lock that synchronizes alloc() vs. get() operations,
see klp_shadow_get_or_alloc(). On one hand, this adds a risk of ABBA
deadlocks. On the other hand, it allows to do some operations safely.
For example, we could add the new structure into an existing list.
This must be done only once when the structure is allocated.
Reported-by: Nicolai Stange <nstange@suse.de>
Pull 'immediate' feature removal from Miroslav Benes.
klp_send_signals() and klp_force_transition() do not acquire klp_mutex,
because it seemed to be superfluous. A potential race in
klp_send_signals() was harmless and there was nothing in
klp_force_transition() which needed to be synchronized. That changed
with the addition of klp_forced variable during the review process.
There is a small window now, when klp_complete_transition() does not see
klp_forced set to true while all tasks have been already transitioned to
the target state. module_put() is called and the module can be removed.
Acquire klp_mutex in sysfs callback to prevent it. Do the same for the
signal sending just to be sure. There is no real downside to that.
Fixes: c99a2be790b07 ("livepatch: force transition to finish")
Fixes: 43347d56c8d9d ("livepatch: send a fake signal to all blocking tasks")
Reported-by: Jason Baron <jbaron@akamai.com>
Immediate flag has been used to disable per-task consistency and patch
all tasks immediately. It could be useful if the patch doesn't change any
function or data semantics.
However, it causes problems on its own. The consistency problem is
currently broken with respect to immediate patches.
func a
patches 1i
2i
3
When the patch 3 is applied, only 2i function is checked (by stack
checking facility). There might be a task sleeping in 1i though. Such
task is migrated to 3, because we do not check 1i in
klp_check_stack_func() at all.
Coming atomic replace feature would be easier to implement and more
reliable without immediate.
Thus, remove immediate feature completely and save us from the problems.
Note that force feature has the similar problem. However it is
considered as a last resort. If used, administrator should not apply any
new live patches and should plan for reboot into an updated kernel.
The architectures would now need to provide HAVE_RELIABLE_STACKTRACE to
fully support livepatch.
If a task sleeps in a set of patched functions uninterruptedly, it could
block the whole transition indefinitely. Thus it may be useful to clear
its TIF_PATCH_PENDING to allow the process to finish.
Admin can do that now by writing to force sysfs attribute in livepatch
sysfs directory. TIF_PATCH_PENDING is then cleared for all tasks and the
transition can finish successfully.
Important note! Administrator should not use this feature without a
clearance from a patch distributor. It must be checked that by doing so
the consistency model guarantees are not violated. Removal (rmmod) of
patch modules is permanently disabled when the feature is used. It
cannot be guaranteed there is no task sleeping in such module.
Live patching consistency model is of LEAVE_PATCHED_SET and
SWITCH_THREAD. This means that all tasks in the system have to be marked
one by one as safe to call a new patched function. Safe means when a
task is not (sleeping) in a set of patched functions. That is, no
patched function is on the task's stack. Another clearly safe place is
the boundary between kernel and userspace. The patching waits for all
tasks to get outside of the patched set or to cross the boundary. The
transition is completed afterwards.
The problem is that a task can block the transition for quite a long
time, if not forever. It could sleep in a set of patched functions, for
example. Luckily we can force the task to leave the set by sending it a
fake signal, that is a signal with no data in signal pending structures
(no handler, no sign of proper signal delivered). Suspend/freezer use
this to freeze the tasks as well. The task gets TIF_SIGPENDING set and
is woken up (if it has been sleeping in the kernel before) or kicked by
rescheduling IPI (if it was running on other CPU). This causes the task
to go to kernel/userspace boundary where the signal would be handled and
the task would be marked as safe in terms of live patching.
There are tasks which are not affected by this technique though. The
fake signal is not sent to kthreads. They should be handled differently.
They can be woken up so they leave the patched set and their
TIF_PATCH_PENDING can be cleared thanks to stack checking.
For the sake of completeness, if the task is in TASK_RUNNING state but
not currently running on some CPU it doesn't get the IPI, but it would
eventually handle the signal anyway. Second, if the task runs in the
kernel (in TASK_RUNNING state) it gets the IPI, but the signal is not
handled on return from the interrupt. It would be handled on return to
the userspace in the future when the fake signal is sent again. Stack
checking deals with these cases in a better way.
If the task was sleeping in a syscall it would be woken by our fake
signal, it would check if TIF_SIGPENDING is set (by calling
signal_pending() predicate) and return ERESTART* or EINTR. Syscalls with
ERESTART* return values are restarted in case of the fake signal (see
do_signal()). EINTR is propagated back to the userspace program. This
could disturb the program, but...
* each process dealing with signals should react accordingly to EINTR
return values.
* syscalls returning EINTR happen to be quite common situation in the
system even if no fake signal is sent.
* freezer sends the fake signal and does not deal with EINTR anyhow.
Thus EINTR values are returned when the system is resumed.
The very safe marking is done in architectures' "entry" on syscall and
interrupt/exception exit paths, and in a stack checking functions of
livepatch. TIF_PATCH_PENDING is cleared and the next
recalc_sigpending() drops TIF_SIGPENDING. In connection with this, also
call klp_update_patch_state() before do_signal(), so that
recalc_sigpending() in dequeue_signal() can clear TIF_PATCH_PENDING
immediately and thus prevent a double call of do_signal().
Note that the fake signal is not sent to stopped/traced tasks. Such task
prevents the patching to finish till it continues again (is not traced
anymore).
Last, sending the fake signal is not automatic. It is done only when
admin requests it by writing 1 to signal sysfs attribute in livepatch
sysfs directory.
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: x86@kernel.org
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching
- shadow variables support, allowing livepatches to associate new
"shadow" fields to existing data structures, from Joe Lawrence
- pre/post patch callbacks API, allowing livepatch writers to register
callbacks to be called before and after patch application, from Joe
Lawrence
* 'for-linus' of ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching:
livepatch: __klp_disable_patch() should never be called for disabled patches
livepatch: Correctly call klp_post_unpatch_callback() in error paths
livepatch: add transition notices
livepatch: move transition "complete" notice into klp_complete_transition()
livepatch: add (un)patch callbacks
livepatch: Small shadow variable documentation fixes
livepatch: __klp_shadow_get_or_alloc() is local to shadow.c
livepatch: introduce shadow variable API
This pulls in an infrastructure/API that allows livepatch writers to
register pre-patch and post-patch callbacks that allow for running a
glue code necessary for finalizing the patching if necessary.
kernel/livepatch/core.c
- trivial conflict by adding a callback call into
module going notifier vs. moving that code block
to klp_cleanup_module_patches_limited()
Shadow variables allow callers to associate new shadow fields to existing data
structures. This is intended to be used by livepatch modules seeking to
emulate additions to data structure definitions.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
__klp_disable_patch() should never be called when the patch is not
enabled. Let's add the same warning that we have in __klp_enable_patch().
This allows to remove the check when calling klp_pre_unpatch_callback().
It was strange anyway because it repeatedly checked per-patch flag
for each patched object.
The post_unpatch_enabled flag in struct klp_callbacks is set when a
pre-patch callback successfully executes, indicating that we need to
call a corresponding post-unpatch callback when the patch is reverted.
This is true for ordinary patch disable as well as the error paths of
klp_patch_object() callers.
As currently coded, we inadvertently execute the post-patch callback
twice in klp_module_coming() when klp_patch_object() fails:
- We explicitly call klp_post_unpatch_callback() for the failed object
- We call it again for the same object (and all the others) via
We should clear the flag in klp_post_unpatch_callback() to make
sure that the callback is not called twice. It makes the API
more safe.
(We could have removed the callback from the former error path as it
would be covered by the latter call, but I think that is is cleaner to
clear the post_unpatch_enabled after its invoked. For example, someone
might later decide to call the callback only when obj->patched flag is
set.)
There is another mistake in the error path of klp_coming_module() in
which it skips the post-unpatch callback for the klp_transition_patch.
However, the pre-patch callback was called even for this patch, so be
sure to make the corresponding callbacks for all patches.
Finally, I used this opportunity to make klp_pre_patch_callback() more
readable.
[jkosina@suse.cz: incorporate changelog wording changes proposed by Joe Lawrence]
Log a few kernel debug messages at the beginning of the following livepatch
transition functions:
klp_init_transition()
klp_reverse_transition()
Also update the log notice message in klp_start_transition() for similar
verbiage as the above messages.
Signed-off-by: Joe Lawrence <joe.lawrence@redhat.com>
klp_complete_transition() performs a bit of housework before a
transition to KLP_PATCHED or KLP_UNPATCHED is actually completed
(including post-(un)patch callbacks). To be consistent, move the
transition "complete" kernel log notice out of
klp_try_complete_transition() and into klp_complete_transition().
Provide livepatch modules a klp_object (un)patching notification
mechanism. Pre and post-(un)patch callbacks allow livepatch modules to
setup or synchronize changes that would be difficult to support in only
patched-or-unpatched code contexts.
Callbacks can be registered for target module or vmlinux klp_objects,
but each implementation is klp_object specific.
- Pre-(un)patch callbacks run before any (un)patching transition
starts.
- Post-(un)patch callbacks run once an object has been (un)patched and
the klp_patch fully transitioned to its target state.
Example use cases include modification of global data and registration
of newly available services/handlers.
See Documentation/livepatch/callbacks.txt for details and
samples/livepatch/ for examples.
When an incoming module is considered for livepatching by
klp_module_coming(), it iterates over multiple patches and multiple
kernel objects in this order:
list_for_each_entry(patch, &klp_patches, list) {
klp_for_each_object(patch, obj) {
which means that if one of the kernel objects fails to patch,
klp_module_coming()'s error path needs to unpatch and cleanup any kernel
objects that were already patched by a previous patch.
Reported-by: Miroslav Benes <mbenes@suse.cz>
Suggested-by: Petr Mladek <pmladek@suse.com>
... therefore make it static.
Fixes: 439e7271dc2 ("livepatch: introduce shadow variable API")
Add exported API for livepatch modules:
klp_shadow_get()
klp_shadow_alloc()
klp_shadow_free()
that implement "shadow" variables, which allow callers to associate new
shadow fields to existing data structures. This is intended to be used
by livepatch modules seeking to emulate additions to data structure
definitions.
See Documentation/livepatch/shadow-vars.txt for a summary of the new
shadow variable API, including a few common use cases.
See samples/livepatch/livepatch-shadow-* for example modules that
demonstrate shadow variables.
[jkosina@suse.cz: fix __klp_shadow_get_or_alloc() comment as spotted by
Josh]
rcu_read_(un)lock(), list_*_rcu(), and synchronize_rcu() are used for a secure
access and manipulation of the list of patches that modify the same function.
In particular, it is the variable func_stack that is accessible from the ftrace
handler via struct ftrace_ops and klp_ops.
Of course, it synchronizes also some states of the patch on the top of the
stack, e.g. func->transition in klp_ftrace_handler.
At the same time, this mechanism guards also the manipulation of
task->patch_state. It is modified according to the state of the transition and
the state of the process.
Now, all this works well as long as RCU works well. Sadly livepatching might
get into some corner cases when this is not true. For example, RCU is not
watching when rcu_read_lock() is taken in idle threads. It is because they
might sleep and prevent reaching the grace period for too long.
There are ways how to make RCU watching even in idle threads, see
rcu_irq_enter(). But there is a small location inside RCU infrastructure when
even this does not work.
This small problematic location can be detected either before calling
rcu_irq_enter() by rcu_irq_enter_disabled() or later by rcu_is_watching().
Sadly, there is no safe way how to handle it. Once we detect that RCU was not
watching, we might see inconsistent state of the function stack and the related
variables in klp_ftrace_handler(). Then we could do a wrong decision, use an
incompatible implementation of the function and break the consistency of the
system. We could warn but we could not avoid the damage.
Fortunately, ftrace has similar problems and they seem to be solved well there.
It uses a heavy weight implementation of some RCU operations. In particular, it
replaces:
+ rcu_read_lock() with preempt_disable_notrace()
+ rcu_read_unlock() with preempt_enable_notrace()
+ synchronize_rcu() with schedule_on_each_cpu(sync_work)
My understanding is that this is RCU implementation from a stone age. It meets
the core RCU requirements but it is rather ineffective. Especially, it does not
allow to batch or speed up the synchronize calls.
On the other hand, it is very trivial. It allows to safely trace and/or
livepatch even the RCU core infrastructure. And the effectiveness is a not a
big issue because using ftrace or livepatches on productive systems is a rare
operation. The safety is much more important than a negligible extra load.
Note that the alternative implementation follows the RCU principles. Therefore,
we could and actually must use list_*_rcu() variants when manipulating the
func_stack. These functions allow to access the pointers in the right
order and with the right barriers. But they do not use any other
information that would be set only by rcu_read_lock().
Also note that there are actually two problems solved in ftrace:
First, it cares about the consistency of RCU read sections. It is being solved
the way as described and used in this patch.
Second, ftrace needs to make sure that nobody is inside the dynamic trampoline
when it is being freed. For this, it also calls synchronize_rcu_tasks() in
preemptive kernel in ftrace_shutdown().
Livepatch has similar problem but it is solved by ftrace for free.
klp_ftrace_handler() is a good guy and never sleeps. In addition, it is
registered with FTRACE_OPS_FL_DYNAMIC. It causes that
unregister_ftrace_function() calls:
* schedule_on_each_cpu(ftrace_sync) - always
* synchronize_rcu_tasks() - in preemptive kernel
The effect is that nobody is neither inside the dynamic trampoline nor inside
the ftrace handler after unregister_ftrace_function() returns.
[jkosina@suse.cz: reformat changelog, fix comment]
