path: root/kernel/irq
2007-12-18genirq: revert lazy irq disable for simple irqsSteven Rostedt
In commit 76d2160147f43f982dfe881404cfde9fd0a9da21 lazy irq disabling was implemented, and the simple irq handler had a masking set to it. Remy Bohmer discovered that some devices in the ARM architecture would trigger the mask, but never unmask it. His patch to do the unmasking was questioned by Russell King about masking simple irqs to begin with. Looking further, it was discovered that the problems Remy was seeing was due to improper use of the simple handler by devices, and he later submitted patches to fix those. But the issue that was uncovered was that the simple handler should never mask. This patch reverts the masking in the simple handler. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-11-14__do_IRQ does not check IRQ_DISABLED when IRQ_PER_CPU is setRuss Anderson
In __do_IRQ(), the normal case is that IRQ_DISABLED is checked and if set the handler (handle_IRQ_event()) is not called. Earlier in __do_IRQ(), if IRQ_PER_CPU is set the code does not check IRQ_DISABLED and calls the handler even though IRQ_DISABLED is set. This behavior seems unintentional. One user encountering this behavior is the CPE handler (in arch/ia64/kernel/mca.c). When the CPE handler encounters too many CPEs (such as a solid single bit error), it sets up a polling timer and disables the CPE interrupt (to avoid excessive overhead logging the stream of single bit errors). disable_irq_nosync() is called which sets IRQ_DISABLED. The IRQ_PER_CPU flag was previously set (in ia64_mca_late_init()). The net result is the CPE handler gets called even though it is marked disabled. If the behavior of not checking IRQ_DISABLED when IRQ_PER_CPU is set is intentional, it would be worthy of a comment describing the intended behavior. disable_irq_nosync() does call chip->disable() to provide a chipset specifiec interface for disabling the interrupt, which avoids this issue when used. Signed-off-by: Russ Anderson <rja@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23Fix synchronize_irq races with IRQ handlerHerbert Xu
As it is some callers of synchronize_irq rely on memory barriers to provide synchronisation against the IRQ handlers. For example, the tg3 driver does tp->irq_sync = 1; smp_mb(); synchronize_irq(); and then in the IRQ handler: if (!tp->irq_sync) netif_rx_schedule(dev, &tp->napi); Unfortunately memory barriers only work well when they come in pairs. Because we don't actually have memory barriers on the IRQ path, the memory barrier before the synchronize_irq() doesn't actually protect us. In particular, synchronize_irq() may return followed by the result of netif_rx_schedule being made visible. This patch (mostly written by Linus) fixes this by using spin locks instead of memory barries on the synchronize_irq() path. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Compile handle_percpu_irq even for uniprocessor kernelsRalf Baechle
Compiling handle_percpu_irq only on uniprocessor generates an artificial special case so a typical use like: set_irq_chip_and_handler(irq, &some_irq_type, handle_percpu_irq); needs to be conditionally compiled only on SMP systems as well and an alternative UP construct is usually needed - for no good reason. This fixes uniprocessor configurations for some MIPS SMP systems. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Fix CONFIG_DEBUG_SHIRQ trigger on free_irq()David Woodhouse
Andy Gospodarek pointed out that because we return in the middle of the free_irq() function, we never actually do call the IRQ handler that just got deregistered. This should fix it, although I expect Andrew will want to convert those 'return's to 'break'. That's a separate change though. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Andy Gospodarek <andy@greyhouse.net> Cc: Fernando Luis Vzquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31request_irq: fix DEBUG_SHIRQ handlingJarek Poplawski
Mariusz Kozlowski reported lockdep's warning: > ================================= > [ INFO: inconsistent lock state ] > 2.6.23-rc2-mm1 #7 > --------------------------------- > inconsistent {in-hardirq-W} -> {hardirq-on-W} usage. > ifconfig/5492 [HC0[0]:SC0[0]:HE1:SE1] takes: > (&tp->lock){+...}, at: [<de8706e0>] rtl8139_interrupt+0x27/0x46b [8139too] > {in-hardirq-W} state was registered at: > [<c0138eeb>] __lock_acquire+0x949/0x11ac > [<c01397e7>] lock_acquire+0x99/0xb2 > [<c0452ff3>] _spin_lock+0x35/0x42 > [<de8706e0>] rtl8139_interrupt+0x27/0x46b [8139too] > [<c0147a5d>] handle_IRQ_event+0x28/0x59 > [<c01493ca>] handle_level_irq+0xad/0x10b > [<c0105a13>] do_IRQ+0x93/0xd0 > [<c010441e>] common_interrupt+0x2e/0x34 ... > other info that might help us debug this: > 1 lock held by ifconfig/5492: > #0: (rtnl_mutex){--..}, at: [<c0451778>] mutex_lock+0x1c/0x1f > > stack backtrace: ... > [<c0452ff3>] _spin_lock+0x35/0x42 > [<de8706e0>] rtl8139_interrupt+0x27/0x46b [8139too] > [<c01480fd>] free_irq+0x11b/0x146 > [<de871d59>] rtl8139_close+0x8a/0x14a [8139too] > [<c03bde63>] dev_close+0x57/0x74 ... This shows that a driver's irq handler was running both in hard interrupt and process contexts with irqs enabled. The latter was done during free_irq() call and was possible only with CONFIG_DEBUG_SHIRQ enabled. This was fixed by another patch. But similar problem is possible with request_irq(): any locks taken from irq handler could be vulnerable - especially with soft interrupts. This patch fixes it by disabling local interrupts during handler's run. (It seems, disabling softirqs should be enough, but it needs more checking on possible races or other special cases). Reported-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22free_irq(): fix DEBUG_SHIRQ handlingAndrew Morton
If we're going to run the handler from free_irq() then we must do it with local irq's disabled. Otherwise lockdep complains that the handler is taking irq-safe spinlocks in a non-irq-safe fashion. Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-12genirq: suppress resend of level interruptsThomas Gleixner
Level type interrupts are resent by the interrupt hardware when they are still active at irq_enable(). Suppress the resend mechanism for interrupts marked as level. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-12genirq: cleanup mismerge artifactThomas Gleixner
Commit 5a43a066b11ac2fe84cf67307f20b83bea390f83: "genirq: Allow fasteoi handler to retrigger disabled interrupts" was erroneously applied to handle_level_irq(). This added the irq retrigger / resend functionality to the level irq handler. Revert the offending bits. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-09Revert "genirq: temporary fix for level-triggered IRQ resend"Linus Torvalds
This reverts commit 0fc4969b866671dfe39b1a9119d0fdc7ea0f63e5. It was always meant to be temporary, but it's generating more useless noise than anything else, and we probably should never have done it in the generic kernel (only had the people involved test it on their own). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-01genirq: temporary fix for level-triggered IRQ resendThomas Gleixner
Marcin Slusarz reported a ne2k-pci "hung network interface" regression. delayed disable relies on the ability to re-trigger the interrupt in the case that a real interrupt happens after the software disable was set. In this case we actually disable the interrupt on the hardware level _after_ it occurred. On enable_irq, we need to re-trigger the interrupt. On i386 this relies on a hardware resend mechanism (send_IPI_self()). Actually we only need the resend for edge type interrupts. Level type interrupts come back once enable_irq() re-enables the interrupt line. I assume that the interrupt in question is level triggered because it is shared and above the legacy irqs 0-15: 17: 12 IO-APIC-fasteoi eth1, eth0 Looking into the IO_APIC code, the resend via send_IPI_self() happens unconditionally. So the resend is done for level and edge interrupts. This makes the problem more mysterious. The code in question lib8390.c does disable_irq(); fiddle_with_the_network_card_hardware() enable_irq(); The fiddle_with_the_network_card_hardware() might cause interrupts, which are cleared in the same code path again, Marcin found that when he disables the irq line on the hardware level (removing the delayed disable) the card is kept alive. So the difference is that we can get a resend on enable_irq, when an interrupt happens during the time, where we are in the disabled region. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-28rip some includes from linux/interrupt.hAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21x86_64: Report the pending irq if available in smp_affinityAndi Kleen
Otherwise smp_affinity would only update after the next interrupt on x86 systems. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Improve behaviour of spurious IRQ detectAlan Cox
Currently we handle spurious IRQ activity based upon seeing a lot of invalid interrupts, and we clear things back on the base of lots of valid interrupts. Unfortunately in some cases you get legitimate invalid interrupts caused by timing asynchronicity between the PCI bus and the APIC bus when disabling interrupts and pulling other tricks. In this case although the spurious IRQs are not a problem our unhandled counters didn't clear and they act as a slow running timebomb. (This is effectively what the serial port/tty problem that was fixed by clearing counters when registering a handler showed up) It's easy enough to add a second parameter - time. This means that if we see a regular stream of harmless spurious interrupts which are not harming processing we don't go off and do something stupid like disable the IRQ after a month of running. OTOH lockups and performance killers show up a lot more than 10/second [akpm@linux-foundation.org: cleanup] Signed-off-by: Alan Cox <alan@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-24Fix crash with irqpoll due to the IRQF_IRQPOLL flag testingLinus Torvalds
With irqpoll enabled, trying to test the IRQF_IRQPOLL flag in the actions would cause a NULL pointer dereference if no action was installed (for example, the driver might have been unloaded with interrupts still pending). So be a bit more careful about testing the flag by making sure to test for that case. (The actual _change_ is trivial, the patch is more than a one-liner because I rewrote the testing to also be much more readable. Original (discarded) bugfix by Bernhard Walle. Cc: Bernhard Walle <bwalle@suse.de> Tested-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11[IA64] SN: validate smp_affinity mask on intr redirectJohn Keller
On SN, only allow one bit to be set in the smp_affinty mask when redirecting an interrupt. Currently setting multiple bits is allowed, but only the first bit is used in determining the CPU to redirect to. This has caused confusion among some customers. [akpm@linux-foundation.org: fixes] Signed-off-by: John Keller <jpk@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-09Fix Linuxdoc commentJeff Dike
A linuxdoc comment had fallen out of date - it refers to an argument which no longer exists. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Add IRQF_IRQPOLL flag (common code)Bernhard Walle
irqpoll is broken on some architectures that don't use the IRQ 0 for the timer interrupt like IA64. This patch adds a IRQF_IRQPOLL flag. Each architecture is handled in a separate pach. As I left the irq == 0 as condition, this should not break existing architectures that use timer_irq == 0 and that I did't address with that patch (because I don't know). This patch: This patch adds a IRQF_IRQPOLL flag that the interrupt registration code could use for the interrupt it wants to use for IRQ polling. Because this must not be the timer interrupt, an additional flag was added instead of re-using the IRQF_TIMER constant. Until all architectures will have an IRQF_IRQPOLL interrupt, irq == 0 will stay as alternative as it should not break anything. Also, note_interrupt() is called on CPU-specific interrupts to be used as interrupt source for IRQ polling. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@google.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Pad irq_desc to internode cacheline sizeRavikiran G Thirumalai
We noticed a drop in n/w performance due to the irq_desc being cacheline aligned rather than internode aligned. We see 50% of expected performance when two e1000 nics local to two different nodes have consecutive irq descriptors allocated, due to false sharing. Note that this patch does away with cacheline padding for the UP case, as it does not seem useful for UP configurations. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08IRQ: check for PERCPU flag only when adding first irqactionAhmed S. Darwish
An irqaction structure won't be added to an IRQ descriptor irqaction list if it doesn't agree with other irqactions on the IRQF_PERCPU flag. Don't check for this flag to change IRQ descriptor `status' for every irqaction added to the list, Doing the check only for the first irqaction added is enough. Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08kernel/irq/proc.c: unprotected iteration over the IRQ action list in ↵Dmitry Adamushko
name_unique() setup_irq() releases a desc->lock before calling register_handler_proc(), so the iteration over the IRQ action list is not protected. (akpm: the check itself is still racy, but at least it probably won't oops now). Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02MSI: arch must connect the irq and the msi_descMichael Ellerman
set_irq_msi() currently connects an irq_desc to an msi_desc. The archs call it at some point in their setup routine, and then the generic code sets up the reverse mapping from the msi_desc back to the irq. set_irq_msi() should do both connections, making it the one and only call required to connect an irq with it's MSI desc and vice versa. The arch code MUST call set_irq_msi(), and it must do so only once it's sure it's not going to fail the irq allocation. Given that there's no need for the arch to return the irq anymore, the return value from the arch setup routine just becomes 0 for success and anything else for failure. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-07[PATCH] irq-devres: fix failure path of devm_request_irq()Tejun Heo
devres should be deallocated with devres_free() not kfree(). This bug corrupts slab on IRQ request failure. Fix it. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg KH <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-26[PATCH] genirq: Mask irqs when migrating them.Eric W. Biederman
move_native_irqs tries to do the right thing when migrating irqs by disabling them. However disabling them is a software logical thing, not a hardware thing. This has always been a little flaky and after Ingo's latest round of changes it is guaranteed to not mask the apic. So this patch fixes move_native_irq to directly call the mask and unmask chip methods to guarantee that we mask the irq when we are migrating it. We must do this as it is required by all code that call into the path. Since we don't know the masked status when IRQ_DISABLED is set so we will not be able to restore it. The patch makes the code just give up and trying again the next time this routing is called. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] small irq management simplificationJan Beulich
Use mask_ack_irq() where possible. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] IRQ kernel-doc fixesRandy Dunlap
Fix kernel-doc warnings in IRQ management. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] genirq: do not mask interrupts by defaultIngo Molnar
Never mask interrupts immediately upon request. Disabling interrupts in high-performance codepaths is rare, and on the other hand this change could recover lost edges (or even other types of lost interrupts) by conservatively only masking interrupts after they happen. (NOTE: with this change the highlevel irq-disable code still soft-disables this IRQ line - and if such an interrupt happens then the IRQ flow handler keeps the IRQ masked.) Mark i8529A controllers as 'never loses an edge'. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Add a function to handle interrupt affinity settingThomas Gleixner
Provide funtions to: - check, whether an interrupt can set the affinity - pin the interrupt to a given cpu Necessary for the ability to setup clocksources more flexible (e.g. use the different HPET channels per CPU) [akpm@osdl.org: alpha build fix] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Add irq flag to disable balancing for an interruptThomas Gleixner
Add a flag so we can prevent the irq balancing of an interrupt. Move the bits, so we have room for more :) Necessary for the ability to setup clocksources more flexible (e.g. use the different HPET channels per CPU) Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] kernel: shut up the IRQ mismatch messagesAlan Cox
The problem is various drivers legally validly and sensibly try to claim IRQs but the kernel insists on vomiting forth a giant irrelevant debugging spew when the types clash. Edit kernel/irq/manage.c go down to mismatch: in setup_irq() and ifdef out the if clause that checks for mismatches. It'll then just do the right thing and work sanely. For the current -mm kernel this will do the trick (and moves it into shared irq debugging as in debug mode the info spew is useful). I've had a variant of this in my private tree for some time as I got fed up on the mess on boxes where old legacy IRQs get reused. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Debug shared irqsDavid Woodhouse
Drivers registering IRQ handlers with SA_SHIRQ really ought to be able to handle an interrupt happening before request_irq() returns. They also ought to be able to handle an interrupt happening during the start of their call to free_irq(). Let's test that hypothesis.... [bunk@stusta.de: Kconfig fixes] Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] sort the devres mess outAl Viro
* Split the implementation-agnostic stuff in separate files. * Make sure that targets using non-default request_irq() pull kernel/irq/devres.o * Introduce new symbols (HAS_IOPORT and HAS_IOMEM) defaulting to positive; allow architectures to turn them off (we needed these symbols anyway for dependencies of quite a few drivers). * protect the ioport-related parts of lib/devres.o with CONFIG_HAS_IOPORT. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] proc: remove useless (and buggy) ->nlink settingsAlexey Dobriyan
Bug: pnx8550 code creates directory but resets ->nlink to 1. create_proc_entry() et al will correctly set ->nlink for you. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Corey Minyard <minyard@acm.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09devres: device resource managementTejun Heo
Implement device resource management, in short, devres. A device driver can allocate arbirary size of devres data which is associated with a release function. On driver detach, release function is invoked on the devres data, then, devres data is freed. devreses are typed by associated release functions. Some devreses are better represented by single instance of the type while others need multiple instances sharing the same release function. Both usages are supported. devreses can be grouped using devres group such that a device driver can easily release acquired resources halfway through initialization or selectively release resources (e.g. resources for port 1 out of 4 ports). This patch adds devres core including documentation and the following managed interfaces. * alloc/free : devm_kzalloc(), devm_kzfree() * IO region : devm_request_region(), devm_release_region() * IRQ : devm_request_irq(), devm_free_irq() * DMA : dmam_alloc_coherent(), dmam_free_coherent(), dmam_declare_coherent_memory(), dmam_pool_create(), dmam_pool_destroy() * PCI : pcim_enable_device(), pcim_pin_device(), pci_is_managed() * iomap : devm_ioport_map(), devm_ioport_unmap(), devm_ioremap(), devm_ioremap_nocache(), devm_iounmap(), pcim_iomap_table(), pcim_iomap(), pcim_iounmap() Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-07msi: Kill the msi_desc array.Eric W. Biederman
We need to be able to get from an irq number to a struct msi_desc. The msi_desc array in msi.c had several short comings the big one was that it could not be used outside of msi.c. Using irq_data in struct irq_desc almost worked except on some architectures irq_data needs to be used for something else. So this patch adds a msi_desc pointer to irq_desc, adds the appropriate wrappers and changes all of the msi code to use them. The dynamic_irq_init/cleanup code was tweaked to ensure the new field is left in a well defined state. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-01-23Clear spurious irq stat information when adding irq handlerLinus Torvalds
Any newly added irq handler may obviously make any old spurious irq status invalid, since the new handler may well be the thing that is supposed to handle any interrupts that came in. So just clear the statistics when adding handlers. Pointed-out-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11[PATCH] x86-64: Make noirqdebug_setup function non init to fix modpost warningVivek Goyal
o noirqdebug_setup() is __init but it is being called by quirk_intel_irqbalance() which if of type __devinit. If CONFIG_HOTPLUG=y, quirk_intel_irqbalance() is put into text section and it is wrong to call a function in __init section. o MODPOST flags this on i386 if CONFIG_RELOCATABLE=y WARNING: vmlinux - Section mismatch: reference to .init.text:noirqdebug_setup from .text between 'quirk_intel_irqbalance' (at offset 0xc010969e) and 'i8237A_suspend' o Make noirqdebug_setup() non-init. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-22[PATCH] genirq: fix irq flow handler uninstallThomas Gleixner
The sanity check for no_irq_chip in __set_irq_hander() is unconditional on both install and uninstall of an handler. This triggers false warnings and replaces no_irq_chip by dummy_irq_chip in the uninstall case. Check only, when a real handler is installed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-21[PATCH] __set_irq_handler bogus spaceGeert Uytterhoeven
__set_irq_handler: Kill a bogus space Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] CPEI gets warning at kernel/irq/migration.c:27/move_masked_irq()Hidetoshi Seto
While running my MCA test (hardware error injection) on 2.6.19, I got some warning like following: > BUG: warning at kernel/irq/migration.c:27/move_masked_irq() > > Call Trace: > [<a000000100013d20>] show_stack+0x40/0xa0 > sp=e00000006b2578d0 bsp=e00000006b2510b0 > [<a000000100013db0>] dump_stack+0x30/0x60 > sp=e00000006b257aa0 bsp=e00000006b251098 > [<a0000001000de430>] move_masked_irq+0xb0/0x240 > sp=e00000006b257aa0 bsp=e00000006b251070 > [<a0000001000de6a0>] move_native_irq+0xe0/0x180 > sp=e00000006b257aa0 bsp=e00000006b251040 > [<a00000010004ff50>] iosapic_end_level_irq+0x30/0xe0 > sp=e00000006b257aa0 bsp=e00000006b251020 > [<a0000001000d94d0>] __do_IRQ+0x170/0x400 > sp=e00000006b257aa0 bsp=e00000006b250fd8 > [<a0000001000116f0>] ia64_handle_irq+0x1b0/0x260 > sp=e00000006b257aa0 bsp=e00000006b250fa8 > [<a00000010000c3a0>] ia64_leave_kernel+0x0/0x280 > sp=e00000006b257aa0 bsp=e00000006b250fa8 > [<a000000100690cf0>] _spin_unlock_irqrestore+0x30/0x60 > sp=e00000006b257c70 bsp=e00000006b250f90 It comes from: [kernel/irq/migration.c] 26 if (CHECK_IRQ_PER_CPU(desc->status)) { 27 WARN_ON(1); 28 return; 29 } By putting some printk in kernel, I found that irqbalance is trying to move CPEI which is handled as PER_CPU irq. That's why. CPEI(Corrected Platform Error Interrupt) is ia64 specific irq, is allowed to pin to particular processor which selected by the platform, and even it is PER_CPU but it has set_affinity handler (=iosapic_set_affinity) as same as other IO-SAPIC-level interrupts. (I don't know why, but I guess that there would be typical situation where the handler for migration is needed, such as hotplug - the processor going to be offline/hot-removed.) To shut up this warning, there are 2 way at least: a) fix CPEI stuff b) prohibit setting affinity to PER_CPU irq I'm not sure what stuff of CPEI need to be fixed, but I think that returning error to attempting move PER_CPU irq is useful for all applications since it will never work. Following small patch takes b) style. It works, the warning disappeared and irqbalance still runs well. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Arjan van de Ven <arjan@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] lockdep: name some old style locksPeter Zijlstra
Name some of the remaning 'old_style_spin_init' locks Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-22Don't call "note_interrupt()" with irq descriptor lock heldLinus Torvalds
This reverts commit f72fa707604c015a6625e80f269506032d5430dc, and solves the problem that it tried to fix by simply making "__do_IRQ()" call the note_interrupt() function without the lock held, the way everybody else does. It should be noted that all interrupt handling code must never allow the descriptor actors to be entered "recursively" (that's why we do all the magic IRQ_PENDING stuff in the first place), so there actually is exclusion at that much higher level, even in the absense of locking. Acked-by: Vivek Goyal <vgoyal@in.ibm.com> Acked-by:Pavel Emelianov <xemul@openvz.org> Cc: Andrew Morton <akpm@osdl.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-16[PATCH] some irq_chip variables point to NULLZhang, Yanmin
I got an oops when booting 2.6.19-rc5-mm1 on my ia64 machine. Below is the log. Oops 11012296146944 [1] Modules linked in: binfmt_misc dm_mirror dm_multipath dm_mod thermal processor f an container button sg eepro100 e100 mii Pid: 0, CPU 0, comm: swapper psr : 0000121008022038 ifs : 800000000000040b ip : [<a0000001000e1411>] Not tainted ip is at __do_IRQ+0x371/0x3e0 unat: 0000000000000000 pfs : 000000000000040b rsc : 0000000000000003 rnat: 656960155aa56aa5 bsps: a00000010058b890 pr : 656960155aa55a65 ldrs: 0000000000000000 ccv : 0000000000000000 fpsr: 0009804c0270033f csd : 0000000000000000 ssd : 0000000000000000 b0 : a0000001000e1390 b6 : a0000001005beac0 b7 : e00000007f01aa00 f6 : 000000000000000000000 f7 : 0ffe69090000000000000 f8 : 1000a9090000000000000 f9 : 0ffff8000000000000000 f10 : 1000a908ffffff6f70000 f11 : 1003e0000000000000909 r1 : a000000100fbbff0 r2 : 0000000000010002 r3 : 0000000000010001 r8 : fffffffffffbffff r9 : a000000100bd8060 r10 : a000000100dd83b8 r11 : fffffffffffeffff r12 : a000000100bcbbb0 r13 : a000000100bc4000 r14 : 0000000000010000 r15 : 0000000000010000 r16 : a000000100c01aa8 r17 : a000000100d2c350 r18 : 0000000000000000 r19 : a000000100d2c300 r20 : a000000100c01a88 r21 : 0000000080010100 r22 : a000000100c01ac0 r23 : a0000001000108e0 r24 : e000000477980004 r25 : 0000000000000000 r26 : 0000000000000000 r27 : e00000000913400c r28 : e0000004799ee51c r29 : e0000004778b87f0 r30 : a000000100d2c300 r31 : a00000010005c7e0 Call Trace: [<a000000100014600>] show_stack+0x40/0xa0 sp=a000000100bcb760 bsp=a000000100bc4f40 [<a000000100014f00>] show_regs+0x840/0x880 sp=a000000100bcb930 bsp=a000000100bc4ee8 [<a000000100037fb0>] die+0x250/0x320 sp=a000000100bcb930 bsp=a000000100bc4ea0 [<a00000010005e5f0>] ia64_do_page_fault+0x8d0/0xa20 sp=a000000100bcb950 bsp=a000000100bc4e50 [<a00000010000caa0>] ia64_leave_kernel+0x0/0x290 sp=a000000100bcb9e0 bsp=a000000100bc4e50 [<a0000001000e1410>] __do_IRQ+0x370/0x3e0 sp=a000000100bcbbb0 bsp=a000000100bc4df0 [<a000000100011f50>] ia64_handle_irq+0x170/0x220 sp=a000000100bcbbb0 bsp=a000000100bc4dc0 [<a00000010000caa0>] ia64_leave_kernel+0x0/0x290 sp=a000000100bcbbb0 bsp=a000000100bc4dc0 [<a000000100012390>] ia64_pal_call_static+0x90/0xc0 sp=a000000100bcbd80 bsp=a000000100bc4d78 [<a000000100015630>] default_idle+0x90/0x160 sp=a000000100bcbd80 bsp=a000000100bc4d58 [<a000000100014290>] cpu_idle+0x1f0/0x440 sp=a000000100bcbe20 bsp=a000000100bc4d18 [<a000000100009980>] rest_init+0xc0/0xe0 sp=a000000100bcbe20 bsp=a000000100bc4d00 [<a0000001009f8ea0>] start_kernel+0x6a0/0x6c0 sp=a000000100bcbe20 bsp=a000000100bc4ca0 [<a0000001000089f0>] __end_ivt_text+0x6d0/0x6f0 sp=a000000100bcbe30 bsp=a000000100bc4c00 <0>Kernel panic - not syncing: Aiee, killing interrupt handler! The root cause is that some irq_chip variables, especially ia64_msi_chip, initiate their memeber end to point to NULL. __do_IRQ doesn't check if irq_chip->end is null and just calls it after processing the interrupt. As irq_chip->end is called at many places, so I fix it by reinitiating irq_chip->end to dummy_irq_chip.end, e.g., a noop function. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-14[PATCH] setup_irq(): better mismatch debuggingAndrew Morton
When we get a mismatch between handlers on the same IRQ, all we get is "IRQ handler type mismatch for IRQ n". Let's print the name of the presently-registered handler with which we got the mismatch. Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-13[PATCH] Fix misrouted interrupts deadlocksPavel Emelianov
While testing kernel on machine with "irqpoll" option I've caught such a lockup: __do_IRQ() spin_lock(&desc->lock); desc->chip->ack(); /* IRQ is ACKed */ note_interrupt() misrouted_irq() handle_IRQ_event() if (...) local_irq_enable_in_hardirq(); /* interrupts are enabled from now */ ... __do_IRQ() /* same IRQ we've started from */ spin_lock(&desc->lock); /* LOCKUP */ Looking at misrouted_irq() code I've found that a potential deadlock like this can also take place: 1CPU: __do_IRQ() spin_lock(&desc->lock); /* irq = A */ misrouted_irq() for (i = 1; i < NR_IRQS; i++) { spin_lock(&desc->lock); /* irq = B */ if (desc->status & IRQ_INPROGRESS) { 2CPU: __do_IRQ() spin_lock(&desc->lock); /* irq = B */ misrouted_irq() for (i = 1; i < NR_IRQS; i++) { spin_lock(&desc->lock); /* irq = A */ if (desc->status & IRQ_INPROGRESS) { As the second lock on both CPUs is taken before checking that this irq is being handled in another processor this may cause a deadlock. This issue is only theoretical. I propose the attached patch to fix booth problems: when trying to handle misrouted IRQ active desc->lock may be unlocked. Acked-by: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] genirq: clean up irq-flow-type namingIngo Molnar
Introduce desc->name and eliminate the handle_irq_name() hack. Add set_irq_chip_and_handler_name() to set the flow type and name at once. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Matthew Wilcox <willy@debian.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] bitmap: parse input from kernel and user buffersReinette Chatre
lib/bitmap.c:bitmap_parse() is a library function that received as input a user buffer. This seemed to have originated from the way the write_proc function of the /proc filesystem operates. This has been reworked to not use kmalloc and eliminates a lot of get_user() overhead by performing one access_ok before using __get_user(). We need to test if we are in kernel or user space (is_user) and access the buffer differently. We cannot use __get_user() to access kernel addresses in all cases, for example in architectures with separate address space for kernel and user. This function will be useful for other uses as well; for example, taking input for /sysfs instead of /proc, so it was changed to accept kernel buffers. We have this use for the Linux UWB project, as part as the upcoming bandwidth allocator code. Only a few routines used this function and they were changed too. Signed-off-by: Reinette Chatre <reinette.chatre@linux.intel.com> Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Cc: Paul Jackson <pj@sgi.com> Cc: Joe Korty <joe.korty@ccur.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-06[PATCH] ixp4xxdefconfig arm fixesFrederik Deweerdt
With the following patch, the ixp4xxdefconfig builds correctly. I'll test some more configs if I get some time. Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
