path: root/kernel/irq/manage.c
2008-05-02genirq: reenable a nobody cared disabled irq when a new driver arrivesThomas Gleixner
Uwe Kleine-Koenig has some strange hardware where one of the shared interrupts can be asserted during boot before the appropriate driver loads. Requesting the shared irq line from another driver result in a spurious interrupt storm which finally disables the interrupt line. I have seen similar behaviour on resume before (the hardware does not work anymore so I can not verify). Change the spurious disable logic to increment the disable depth and mark the interrupt with an extra flag which allows us to reenable the interrupt when a new driver arrives which requests the same irq line. In the worst case this will disable the irq again via the spurious trap, but there is a decent chance that the new driver is the one which can handle the already asserted interrupt and makes the box usable again. Eric Biederman said further: This case also happens on a regular basis in kdump kernels where we deliberately don't shutdown the hardware before starting the new kernel. This patch should reduce the need for using irqpoll in that situation by a small amount. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-and-Acked-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com>
2008-04-29kernel: explicitly include required header files under kernel/Robert P. J. Day
Following an experimental deletion of the unnecessary directive #include <linux/slab.h> from the header file <linux/percpu.h>, these files under kernel/ were exposed as needing to include one of <linux/slab.h> or <linux/gfp.h>, so explicit includes were added where necessary. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30genirq: stackdump after the "Trying to free already-free IRQ" messageIngo Molnar
these bugs are harder to find than they seem, a stackdump helps. make it dependent on CONFIG_DEBUG_SHIRQ so that people can turn it off if it annoys them. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-23Fix synchronize_irq races with IRQ handlerHerbert Xu
As it is some callers of synchronize_irq rely on memory barriers to provide synchronisation against the IRQ handlers. For example, the tg3 driver does tp->irq_sync = 1; smp_mb(); synchronize_irq(); and then in the IRQ handler: if (!tp->irq_sync) netif_rx_schedule(dev, &tp->napi); Unfortunately memory barriers only work well when they come in pairs. Because we don't actually have memory barriers on the IRQ path, the memory barrier before the synchronize_irq() doesn't actually protect us. In particular, synchronize_irq() may return followed by the result of netif_rx_schedule being made visible. This patch (mostly written by Linus) fixes this by using spin locks instead of memory barries on the synchronize_irq() path. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Fix CONFIG_DEBUG_SHIRQ trigger on free_irq()David Woodhouse
Andy Gospodarek pointed out that because we return in the middle of the free_irq() function, we never actually do call the IRQ handler that just got deregistered. This should fix it, although I expect Andrew will want to convert those 'return's to 'break'. That's a separate change though. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Andy Gospodarek <andy@greyhouse.net> Cc: Fernando Luis Vzquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31request_irq: fix DEBUG_SHIRQ handlingJarek Poplawski
Mariusz Kozlowski reported lockdep's warning: > ================================= > [ INFO: inconsistent lock state ] > 2.6.23-rc2-mm1 #7 > --------------------------------- > inconsistent {in-hardirq-W} -> {hardirq-on-W} usage. > ifconfig/5492 [HC0[0]:SC0[0]:HE1:SE1] takes: > (&tp->lock){+...}, at: [<de8706e0>] rtl8139_interrupt+0x27/0x46b [8139too] > {in-hardirq-W} state was registered at: > [<c0138eeb>] __lock_acquire+0x949/0x11ac > [<c01397e7>] lock_acquire+0x99/0xb2 > [<c0452ff3>] _spin_lock+0x35/0x42 > [<de8706e0>] rtl8139_interrupt+0x27/0x46b [8139too] > [<c0147a5d>] handle_IRQ_event+0x28/0x59 > [<c01493ca>] handle_level_irq+0xad/0x10b > [<c0105a13>] do_IRQ+0x93/0xd0 > [<c010441e>] common_interrupt+0x2e/0x34 ... > other info that might help us debug this: > 1 lock held by ifconfig/5492: > #0: (rtnl_mutex){--..}, at: [<c0451778>] mutex_lock+0x1c/0x1f > > stack backtrace: ... > [<c0452ff3>] _spin_lock+0x35/0x42 > [<de8706e0>] rtl8139_interrupt+0x27/0x46b [8139too] > [<c01480fd>] free_irq+0x11b/0x146 > [<de871d59>] rtl8139_close+0x8a/0x14a [8139too] > [<c03bde63>] dev_close+0x57/0x74 ... This shows that a driver's irq handler was running both in hard interrupt and process contexts with irqs enabled. The latter was done during free_irq() call and was possible only with CONFIG_DEBUG_SHIRQ enabled. This was fixed by another patch. But similar problem is possible with request_irq(): any locks taken from irq handler could be vulnerable - especially with soft interrupts. This patch fixes it by disabling local interrupts during handler's run. (It seems, disabling softirqs should be enough, but it needs more checking on possible races or other special cases). Reported-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22free_irq(): fix DEBUG_SHIRQ handlingAndrew Morton
If we're going to run the handler from free_irq() then we must do it with local irq's disabled. Otherwise lockdep complains that the handler is taking irq-safe spinlocks in a non-irq-safe fashion. Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08IRQ: check for PERCPU flag only when adding first irqactionAhmed S. Darwish
An irqaction structure won't be added to an IRQ descriptor irqaction list if it doesn't agree with other irqactions on the IRQF_PERCPU flag. Don't check for this flag to change IRQ descriptor `status' for every irqaction added to the list, Doing the check only for the first irqaction added is enough. Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Add a function to handle interrupt affinity settingThomas Gleixner
Provide funtions to: - check, whether an interrupt can set the affinity - pin the interrupt to a given cpu Necessary for the ability to setup clocksources more flexible (e.g. use the different HPET channels per CPU) [akpm@osdl.org: alpha build fix] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Add irq flag to disable balancing for an interruptThomas Gleixner
Add a flag so we can prevent the irq balancing of an interrupt. Move the bits, so we have room for more :) Necessary for the ability to setup clocksources more flexible (e.g. use the different HPET channels per CPU) Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] kernel: shut up the IRQ mismatch messagesAlan Cox
The problem is various drivers legally validly and sensibly try to claim IRQs but the kernel insists on vomiting forth a giant irrelevant debugging spew when the types clash. Edit kernel/irq/manage.c go down to mismatch: in setup_irq() and ifdef out the if clause that checks for mismatches. It'll then just do the right thing and work sanely. For the current -mm kernel this will do the trick (and moves it into shared irq debugging as in debug mode the info spew is useful). I've had a variant of this in my private tree for some time as I got fed up on the mess on boxes where old legacy IRQs get reused. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Debug shared irqsDavid Woodhouse
Drivers registering IRQ handlers with SA_SHIRQ really ought to be able to handle an interrupt happening before request_irq() returns. They also ought to be able to handle an interrupt happening during the start of their call to free_irq(). Let's test that hypothesis.... [bunk@stusta.de: Kconfig fixes] Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] sort the devres mess outAl Viro
* Split the implementation-agnostic stuff in separate files. * Make sure that targets using non-default request_irq() pull kernel/irq/devres.o * Introduce new symbols (HAS_IOPORT and HAS_IOMEM) defaulting to positive; allow architectures to turn them off (we needed these symbols anyway for dependencies of quite a few drivers). * protect the ioport-related parts of lib/devres.o with CONFIG_HAS_IOPORT. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09devres: device resource managementTejun Heo
Implement device resource management, in short, devres. A device driver can allocate arbirary size of devres data which is associated with a release function. On driver detach, release function is invoked on the devres data, then, devres data is freed. devreses are typed by associated release functions. Some devreses are better represented by single instance of the type while others need multiple instances sharing the same release function. Both usages are supported. devreses can be grouped using devres group such that a device driver can easily release acquired resources halfway through initialization or selectively release resources (e.g. resources for port 1 out of 4 ports). This patch adds devres core including documentation and the following managed interfaces. * alloc/free : devm_kzalloc(), devm_kzfree() * IO region : devm_request_region(), devm_release_region() * IRQ : devm_request_irq(), devm_free_irq() * DMA : dmam_alloc_coherent(), dmam_free_coherent(), dmam_declare_coherent_memory(), dmam_pool_create(), dmam_pool_destroy() * PCI : pcim_enable_device(), pcim_pin_device(), pci_is_managed() * iomap : devm_ioport_map(), devm_ioport_unmap(), devm_ioremap(), devm_ioremap_nocache(), devm_iounmap(), pcim_iomap_table(), pcim_iomap(), pcim_iounmap() Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-23Clear spurious irq stat information when adding irq handlerLinus Torvalds
Any newly added irq handler may obviously make any old spurious irq status invalid, since the new handler may well be the thing that is supposed to handle any interrupts that came in. So just clear the statistics when adding handlers. Pointed-out-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-14[PATCH] setup_irq(): better mismatch debuggingAndrew Morton
When we get a mismatch between handlers on the same IRQ, all we get is "IRQ handler type mismatch for IRQ n". Let's print the name of the presently-registered handler with which we got the mismatch. Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-05IRQ: Typedef the IRQ handler function typeDavid Howells
Typedef the IRQ handler function type. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1356d1e5fd256997e3d3dce0777ab787d0515c7a commit)
2006-07-31[PATCH] genirq: {en,dis}able_irq_wake() need refcounting tooDavid Brownell
IRQs need refcounting and a state flag to track whether the the IRQ should be enabled or disabled as a "normal IRQ" source after a series of calls to {en,dis}able_irq(). For shared IRQs, the IRQ must be enabled so long as at least one driver needs it active. Likewise, IRQs need the same support to track whether the IRQ should be enabled or disabled as a "wakeup event" source after a series of calls to {en,dis}able_irq_wake(). For shared IRQs, the IRQ must be enabled as a wakeup source during sleep so long as at least one driver needs it. But right now they _don't have_ that refcounting ... which means sharing a wakeup-capable IRQ can't work correctly in some configurations. This patch adds the refcount and flag mechanisms to set_irq_wake() -- which is what {en,dis}able_irq_wake() call -- and minimal documentation of what the irq wake mechanism does. Drivers relying on the older (broken) "toggle" semantics will trigger a warning; that'll be a handful of drivers on ARM systems. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: coreIngo Molnar
Do 'make oldconfig' and accept all the defaults for new config options - reboot into the kernel and if everything goes well it should boot up fine and you should have /proc/lockdep and /proc/lockdep_stats files. Typically if the lock validator finds some problem it will print out voluminous debug output that begins with "BUG: ..." and which syslog output can be used by kernel developers to figure out the precise locking scenario. What does the lock validator do? It "observes" and maps all locking rules as they occur dynamically (as triggered by the kernel's natural use of spinlocks, rwlocks, mutexes and rwsems). Whenever the lock validator subsystem detects a new locking scenario, it validates this new rule against the existing set of rules. If this new rule is consistent with the existing set of rules then the new rule is added transparently and the kernel continues as normal. If the new rule could create a deadlock scenario then this condition is printed out. When determining validity of locking, all possible "deadlock scenarios" are considered: assuming arbitrary number of CPUs, arbitrary irq context and task context constellations, running arbitrary combinations of all the existing locking scenarios. In a typical system this means millions of separate scenarios. This is why we call it a "locking correctness" validator - for all rules that are observed the lock validator proves it with mathematical certainty that a deadlock could not occur (assuming that the lock validator implementation itself is correct and its internal data structures are not corrupted by some other kernel subsystem). [see more details and conditionals of this statement in include/linux/lockdep.h and Documentation/lockdep-design.txt] Furthermore, this "all possible scenarios" property of the validator also enables the finding of complex, highly unlikely multi-CPU multi-context races via single single-context rules, increasing the likelyhood of finding bugs drastically. In practical terms: the lock validator already found a bug in the upstream kernel that could only occur on systems with 3 or more CPUs, and which needed 3 very unlikely code sequences to occur at once on the 3 CPUs. That bug was found and reported on a single-CPU system (!). So in essence a race will be found "piecemail-wise", triggering all the necessary components for the race, without having to reproduce the race scenario itself! In its short existence the lock validator found and reported many bugs before they actually caused a real deadlock. To further increase the efficiency of the validator, the mapping is not per "lock instance", but per "lock-class". For example, all struct inode objects in the kernel have inode->inotify_mutex. If there are 10,000 inodes cached, then there are 10,000 lock objects. But ->inotify_mutex is a single "lock type", and all locking activities that occur against ->inotify_mutex are "unified" into this single lock-class. The advantage of the lock-class approach is that all historical ->inotify_mutex uses are mapped into a single (and as narrow as possible) set of locking rules - regardless of how many different tasks or inode structures it took to build this set of rules. The set of rules persist during the lifetime of the kernel. To see the rough magnitude of checking that the lock validator does, here's a portion of /proc/lockdep_stats, fresh after bootup: lock-classes: 694 [max: 2048] direct dependencies: 1598 [max: 8192] indirect dependencies: 17896 all direct dependencies: 16206 dependency chains: 1910 [max: 8192] in-hardirq chains: 17 in-softirq chains: 105 in-process chains: 1065 stack-trace entries: 38761 [max: 131072] combined max dependencies: 2033928 hardirq-safe locks: 24 hardirq-unsafe locks: 176 softirq-safe locks: 53 softirq-unsafe locks: 137 irq-safe locks: 59 irq-unsafe locks: 176 The lock validator has observed 1598 actual single-thread locking patterns, and has validated all possible 2033928 distinct locking scenarios. More details about the design of the lock validator can be found in Documentation/lockdep-design.txt, which can also found at: http://redhat.com/~mingo/lockdep-patches/lockdep-design.txt [bunk@stusta.de: cleanups] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] genirq:fixup missing SA_PERCPU replacementThomas Gleixner
The irqflags consolidation converted SA_PERCPU_IRQ to IRQF_PERCPU but did not define the new constant. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: generic irq: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] IRQ: warning message cleanupBjorn Helgaas
Make warnings more consistent. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] IRQ: Use SA_PERCPU_IRQ, not IRQ_PER_CPU, for irqaction.flagsBjorn Helgaas
IRQ_PER_CPU is a bit in the struct irq_desc "status" field, not in the struct irqaction "flags", so the previous code checked the wrong bit. SA_PERCPU_IRQ is only used by drivers/char/mmtimer.c for SGI ia64 boxes. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: cleanup: no_irq_type -> no_irq_chip renameIngo Molnar
Rename no_irq_type to no_irq_chip. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: add SA_TRIGGER supportThomas Gleixner
Enable drivers to request an IRQ with a given irq-flow (trigger/polarity) setting. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: add irq-wake (power-management) supportThomas Gleixner
Enable platforms to set the irq-wake (power-management) properties of an IRQ. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: coreThomas Gleixner
Core genirq support: add the irq-chip and irq-flow abstractions. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: update copyrightsIngo Molnar
Update/add copyrights in the generic IRQ code. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: add IRQ_NOAUTOEN supportThomas Gleixner
Enable platforms to disable the automatic enabling of freshly set up irqs. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: add IRQ_NOREQUEST supportThomas Gleixner
Enable platforms to disable request_irq() for certain interrupts. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: add IRQ_NOPROBE supportThomas Gleixner
Introduce IRQ_NOPROBE: enables platforms to control chip-probing. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: add genirq sw IRQ-retriggerThomas Gleixner
Enable platforms that do not have a hardware-assisted hardirq-resend mechanism to resend them via a softirq-driven IRQ emulation mechanism. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: add ->retrigger() irq op to consolidate hw_irq_resend()Ingo Molnar
Add ->retrigger() irq op to consolidate hw_irq_resend() implementations. (Most architectures had it defined to NOP anyway.) NOTE: ia64 needs testing. i386 and x86_64 tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: debug: better debug printout in enable_irq()Thomas Gleixner
Make enable_irq() debug printouts user-readable. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: cleanup: turn ARCH_HAS_IRQ_PER_CPU into CONFIG_IRQ_PER_CPUIngo Molnar
Cleanup: change ARCH_HAS_IRQ_PER_CPU into a Kconfig method. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: cleanup: merge pending_irq_cpumask[] into irq_desc[]Ingo Molnar
Consolidation: remove the pending_irq_cpumask[NR_IRQS] array and move it into the irq_desc[NR_IRQS].pending_mask field. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: cleanup: reduce irq_desc_t use, mark it obsoleteIngo Molnar
Cleanup: remove irq_desc_t use from the generic IRQ code, and mark it obsolete. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: cleanup: misc code cleanupsIngo Molnar
Assorted code cleanups to the generic IRQ code. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: cleanup: merge irq_affinity[] into irq_desc[]Ingo Molnar
Consolidation: remove the irq_affinity[NR_IRQS] array and move it into the irq_desc[NR_IRQS].affinity field. [akpm@osdl.org: sparc64 build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-28[PATCH] request_irq(): remove warnings from irq probingAndrew Morton
- Add new SA_PROBEIRQ which suppresses the new sharing-mismatch warning. Some drivers like to use request_irq() to find an unused interrupt slot. - Use it in i82365.c - Kill unused SA_PROBE. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] warn if free_irq() is called from IRQ contextIngo Molnar
Warn if free_irq() is called in IRQ context - free_irq() can execute /proc VFS work, which must not be done in IRQ context. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] Add SA_PERCPU_IRQ flag supportDimitri Sivanich
Add support for SA_PERCPU_IRQ (only mmtimer.c uses this at this stage). Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] Alpha: convert to generic irq framework (generic part)Ivan Kokshaysky
Thanks to Christoph for doing most of the work. This allows automatic SMP IRQ affinity assignment other than default "all interrupts on all CPUs" which is rather expensive. This might be useful if the hardware can be programmed to distribute interrupts among different CPUs, like Alpha does. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Christoph Hellwig <hch@lst.de> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-23[PATCH] Check the irq number is within boundsMatthew Wilcox
Most of the functions already check. Do the ones that didn't. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] more kernel-doc cleanups, additionsRandy Dunlap
Various core kernel-doc cleanups: - add missing function parameters in ipc, irq/manage, kernel/sys, kernel/sysctl, and mm/slab; - move description to just above function for kernel_restart() Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] x86/x86_64: deferred handling of writes to /proc/irqxx/smp_affinityAshok Raj
When handling writes to /proc/irq, current code is re-programming rte entries directly. This is not recommended and could potentially cause chipset's to lockup, or cause missing interrupts. CONFIG_IRQ_BALANCE does this correctly, where it re-programs only when the interrupt is pending. The same needs to be done for /proc/irq handling as well. Otherwise user space irq balancers are really not doing the right thing. - Changed pending_irq_balance_cpumask to pending_irq_migrate_cpumask for lack of a generic name. - added move_irq out of IRQ_BALANCE, and added this same to X86_64 - Added new proc handler for write, so we can do deferred write at irq handling time. - Display of /proc/irq/XX/smp_affinity used to display CPU_MASKALL, instead it now shows only active cpu masks, or exactly what was set. - Provided a common move_irq implementation, instead of duplicating when using generic irq framework. Tested on i386/x86_64 and ia64 with CONFIG_PCI_MSI turned on and off. Tested UP builds as well. MSI testing: tbd: I have cards, need to look for a x-over cable, although I did test an earlier version of this patch. Will test in a couple days. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Acked-by: Zwane Mwaikambo <zwane@holomorphy.com> Grudgingly-acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Coywolf Qi Hunt <coywolf@lovecn.org> Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] uml: make hw_controller_type->release exist only for archs needing itPaolo 'Blaisorblade' Giarrusso
With Chris Wedgwood <cw@f00f.org> As suggested by Chris, we can make the "just added" method ->release conditional to UML only (better: to archs requesting it, i.e. only UML currently), so that other archs don't get this unneeded crud, and if UML won't need it any more we can kill this. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> CC: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
