commit 51fae6da640edf9d266c94f36bc806c63c301991 upstream.
Since f660daac474c6f (oom: thaw threads if oom killed thread is frozen
before deferring) OOM killer relies on being able to thaw a frozen task
to handle OOM situation but a3201227f803 (freezer: make freezing() test
freeze conditions in effect instead of TIF_FREEZE) has reorganized the
code and stopped clearing freeze flag in __thaw_task. This means that
the target task only wakes up and goes into the fridge again because the
freezing condition hasn't changed for it. This reintroduces the bug
fixed by f660daac474c6f.
Fix the issue by checking for TIF_MEMDIE thread flag in
freezing_slow_path and exclude the task from freezing completely. If a
task was already frozen it would get woken by __thaw_task from OOM killer
and get out of freezer after rechecking freezing().
Changes since v1
- put TIF_MEMDIE check into freezing_slowpath rather than in __refrigerator
as per Oleg
- return __thaw_task into oom_scan_process_thread because
oom_kill_process will not wake task in the fridge because it is
sleeping uninterruptible
[mhocko@suse.cz: rewrote the changelog]
Fixes: a3201227f803 (freezer: make freezing() test freeze conditions in effect instead of TIF_FREEZE)
Acked-by: Oleg Nesterov <oleg@redhat.com>
commit 85fbd722ad0f5d64d1ad15888cd1eb2188bfb557 upstream.
Freezable kthreads and workqueues are fundamentally problematic in
that they effectively introduce a big kernel lock widely used in the
kernel and have already been the culprit of several deadlock
scenarios. This is the latest occurrence.
During resume, libata rescans all the ports and revalidates all
pre-existing devices. If it determines that a device has gone
missing, the device is removed from the system which involves
invalidating block device and flushing bdi while holding driver core
layer locks. Unfortunately, this can race with the rest of device
resume. Because freezable kthreads and workqueues are thawed after
device resume is complete and block device removal depends on
freezable workqueues and kthreads (e.g. bdi_wq, jbd2) to make
progress, this can lead to deadlock - block device removal can't
proceed because kthreads are frozen and kthreads can't be thawed
because device resume is blocked behind block device removal.
839a8e8660b6 ("writeback: replace custom worker pool implementation
with unbound workqueue") made this particular deadlock scenario more
visible but the underlying problem has always been there - the
original forker task and jbd2 are freezable too. In fact, this is
highly likely just one of many possible deadlock scenarios given that
freezer behaves as a big kernel lock and we don't have any debug
mechanism around it.
I believe the right thing to do is getting rid of freezable kthreads
and workqueues. This is something fundamentally broken. For now,
implement a funny workaround in libata - just avoid doing block device
hot[un]plug while the system is frozen. Kernel engineering at its
finest. :(
v2: Add EXPORT_SYMBOL_GPL(pm_freezing) for cases where libata is built
as a module.
v3: Comment updated and polling interval changed to 10ms as suggested
by Rafael.
v4: Add #ifdef CONFIG_FREEZER around the hack as pm_freezing is not
defined when FREEZER is not configured thus breaking build.
Reported by kbuild test robot.
Reported-by: Tomaž Šolc <tomaz.solc@tablix.org>
Reviewed-by: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Link: https://bugzilla.kernel.org/show_bug.cgi?id=62801
Link: http://lkml.kernel.org/r/20131213174932.GA27070@htj.dyndns.org
Cc: Len Brown <len.brown@intel.com>
Cc: kbuild test robot <fengguang.wu@intel.com>
Calling freeze_processes sets a global flag that will cause any
process that calls try_to_freeze to enter the refrigerator. It
skips sending a signal to the current task, but if the current
task ever hits try_to_freeze, all threads will be frozen and the
system will deadlock.
Set a new flag, PF_SUSPEND_TASK, on the task that calls
freeze_processes. The flag notifies the freezer that the thread
is involved in suspend and should not be frozen. Also add a
WARN_ON in thaw_processes if the caller does not have the
PF_SUSPEND_TASK flag set to catch if a different task calls
thaw_processes than the one that called freeze_processes, leaving
a task with PF_SUSPEND_TASK permanently set on it.
Threads that spawn off a task with PF_SUSPEND_TASK set (which
swsusp does) will also have PF_SUSPEND_TASK set, preventing them
from freezing while they are helping with suspend, but they need
to be dead by the time suspend is triggered, otherwise they may
run when userspace is expected to be frozen. Add a WARN_ON in
thaw_processes if more than one thread has the PF_SUSPEND_TASK
flag set.
Reported-and-tested-by: Michael Leun <lkml20130126@newton.leun.net>
Signed-off-by: Colin Cross <ccross@android.com>
Android goes through suspend/resume very often (every few seconds when
on a busy wifi network with the screen off), and a significant portion
of the energy used to go in and out of suspend is spent in the
freezer. If a task has called freezer_do_not_count(), don't bother
waking it up. If it happens to wake up later it will call
freezer_count() and immediately enter the refrigerator.
Combined with patches to convert freezable helpers to use
freezer_do_not_count() and convert common sites where idle userspace
tasks are blocked to use the freezable helpers, this reduces the
time and energy required to suspend and resume.
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Pavel Machek <pavel@ucw.cz>
try_to_freeze_tasks() and cgroup_freezer rely on scheduler locks
to ensure that a task doing STOPPED/TRACED -> RUNNING transition
can't escape freezing. This mostly works, but ptrace_stop() does
not necessarily call schedule(), it can change task->state back to
RUNNING and check freezing() without any lock/barrier in between.
We could add the necessary barrier, but this patch changes
ptrace_stop() and do_signal_stop() to use freezable_schedule().
This fixes the race, freezer_count() and freezer_should_skip()
carefully avoid the race.
And this simplifies the code, try_to_freeze_tasks/update_if_frozen
no longer need to use task_is_stopped_or_traced() checks with the
non trivial assumptions. We can rely on the mechanism which was
specially designed to mark the sleeping task as "frozen enough".
v2: As Tejun pointed out, we can also change get_signal_to_deliver()
and move try_to_freeze() up before 'relock' label.
This patch removes all the references in the code about the TIF_FREEZE
flag removed by commit a3201227f803ad7fd43180c5195dbe5a2bf998aa
There still are some references to TIF_FREEZE in
Documentation/power/freezing-of-tasks.txt, but it looks like that
documentation needs more thorough work to reflect how the new
freezer works, and hence merely removing the references to TIF_FREEZE
won't really help. So I have not touched that part in this patch.
Suggested-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Signed-off-by: Marcos Paulo de Souza <marcos.mage@gmail.com>
There's no in-kernel user of set_freezable_with_signal() left. Mixing
TIF_SIGPENDING with kernel threads can lead to nasty corner cases as
kernel threads never travel signal delivery path on their own.
e.g. the current implementation is buggy in the cancelation path of
__thaw_task(). It calls recalc_sigpending_and_wake() in an attempt to
clear TIF_SIGPENDING but the function never clears it regardless of
sigpending state. This means that signallable freezable kthreads may
continue executing with !freezing() && stuck TIF_SIGPENDING, which can
be troublesome.
This patch removes set_freezable_with_signal() along with
PF_FREEZER_NOSIG and recalc_sigpending*() calls in freezer. User
tasks get TIF_SIGPENDING, kernel tasks get woken up and the spurious
sigpending is dealt with in the usual signal delivery path.
After "freezer: make freezing() test freeze conditions in effect
instead of TIF_FREEZE", freezing() returns authoritative answer on
whether the current task should freeze or not and freeze_task()
doesn't need or use @sig_only. Remove it.
While at it, rewrite function comment for freeze_task() and rename
@sig_only to @user_only in try_to_freeze_tasks().
This patch doesn't cause any functional change.
cgroup_freezer calls freeze_task() without holding tasklist_lock and,
if the task is exiting, its ->sighand may be gone by the time
fake_signal_wake_up() is called. Use lock_task_sighand() instead of
accessing ->sighand directly.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Paul Menage <paul@paulmenage.org>
If another freeze happens before all tasks leave FROZEN state after
being thawed, the freezer can see the existing FROZEN and consider the
tasks to be frozen but they can clear FROZEN without checking the new
freezing().
Oleg suggested restructuring __refrigerator() such that there's single
condition check section inside freezer_lock and sigpending is cleared
afterwards, which fixes the problem and simplifies the code.
Restructure accordingly.
-v2: Frozen loop exited without releasing freezer_lock. Fixed.
A kthread doing set_freezable*() may race with on-going PM freeze and
the freezer might think all tasks are frozen while the new freezable
kthread is merrily proceeding to execute code paths which aren't
supposed to be executing during PM freeze.
Reimplement set_freezable[_with_signal]() using __set_freezable() such
that freezable PF flags are modified under freezer_lock and
try_to_freeze() is called afterwards. This eliminates race condition
against freezing.
Note: Separated out from larger patch to resolve fix order dependency
Oleg pointed out.
should_send_signal() is only used in freezer.c. Exporting them only
increases chance of abuse. Open code the two users and remove it.
Update frozen() to return bool.
Using TIF_FREEZE for freezing worked when there was only single
freezing condition (the PM one); however, now there is also the
cgroup_freezer and single bit flag is getting clumsy.
thaw_processes() is already testing whether cgroup freezing in in
effect to avoid thawing tasks which were frozen by both PM and cgroup
freezers.
This is racy (nothing prevents race against cgroup freezing) and
fragile. A much simpler way is to test actual freeze conditions from
freezing() - ie. directly test whether PM or cgroup freezing is in
effect.
This patch adds variables to indicate whether and what type of
freezing conditions are in effect and reimplements freezing() such
that it directly tests whether any of the two freezing conditions is
active and the task should freeze. On fast path, freezing() is still
very cheap - it only tests system_freezing_cnt.
This makes the clumsy dancing aroung TIF_FREEZE unnecessary and
freeze/thaw operations more usual - updating state variables for the
new state and nudging target tasks so that they notice the new state
and comply. As long as the nudging happens after state update, it's
race-free.
* This allows use of freezing() in freeze_task(). Replace the open
coded tests with freezing().
* p != current test is added to warning printing conditions in
try_to_freeze_tasks() failure path. This is necessary as freezing()
is now true for the task which initiated freezing too.
-v2: Oleg pointed out that re-freezing FROZEN cgroup could increment
system_freezing_cnt. Fixed.
Acked-by: Paul Menage <paul@paulmenage.org> (for the cgroup portions)
freeze_processes() failure path is rather messy. Freezing is canceled
for workqueues and tasks which aren't frozen yet but frozen tasks are
left alone and should be thawed by the caller and of course some
callers (xen and kexec) didn't do it.
This patch updates __thaw_task() to handle cancelation correctly and
makes freeze_processes() and freeze_kernel_threads() call
thaw_processes() on failure instead so that the system is fully thawed
on failure. Unnecessary [suspend_]thaw_processes() calls are removed
from kernel/power/hibernate.c, suspend.c and user.c.
While at it, restructure error checking if clause in suspend_prepare()
to be less weird.
-v2: Srivatsa spotted missing removal of suspend_thaw_processes() in
suspend_prepare() and error in commit message. Updated.
Acked-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
With the previous changes, there's no meaningful difference between
PF_FREEZING and PF_FROZEN. Remove PF_FREEZING and use PF_FROZEN
instead in task_contributes_to_load().
try_to_freeze_tasks() and thaw_processes() use freezable() and
frozen() as preliminary tests before initiating operations on a task.
These are done without any synchronization and hinder with
synchronization cleanup without any real performance benefits.
In try_to_freeze_tasks(), open code self test and move PF_NOFREEZE and
frozen() tests inside freezer_lock in freeze_task().
thaw_processes() can simply drop freezable() test as frozen() test in
__thaw_task() is enough.
Note: This used to be a part of larger patch to fix set_freezable()
race. Separated out to satisfy ordering among dependent fixes.
Currently freezing (TIF_FREEZE) and frozen (PF_FROZEN) states are
interlocked - freezing is set to request freeze and when the task
actually freezes, it clears freezing and sets frozen.
This interlocking makes things more complex than necessary - freezing
doesn't mean there's freezing condition in effect and frozen doesn't
match the task actually entering and leaving frozen state (it's
cleared by the thawing task).
This patch makes freezing indicate that freeze condition is in effect.
A task enters and stays frozen if freezing. This makes PF_FROZEN
manipulation done only by the task itself and prevents wakeup from
__thaw_task() leaking outside of refrigerator.
The only place which needs to tell freezing && !frozen is
try_to_freeze_task() to whine about tasks which don't enter frozen.
It's updated to test the condition explicitly.
With the change, frozen() state my linger after __thaw_task() until
the task wakes up and exits fridge. This can trigger BUG_ON() in
update_if_frozen(). Work it around by testing freezing() && frozen()
instead of frozen().
-v2: Oleg pointed out missing re-check of freezing() when trying to
clear FROZEN and possible spurious BUG_ON() trigger in
update_if_frozen(). Both fixed.
Freezer synchronization is needlessly complicated - it's by no means a
hot path and the priority is staying unintrusive and safe. This patch
makes it simply use a dedicated lock instead of piggy-backing on
task_lock() and playing with memory barriers.
On the failure path of try_to_freeze_tasks(), locking is moved from it
to cancel_freezing(). This makes the frozen() test racy but the race
here is a non-issue as the warning is printed for tasks which failed
to enter frozen for 20 seconds and race on PF_FROZEN at the last
moment doesn't change anything.
This simplifies freezer implementation and eases further changes
including some race fixes.
thaw_process() now has only internal users - system and cgroup
freezers. Remove the unnecessary return value, rename, unexport and
collapse __thaw_process() into it. This will help further updates to
the freezer code.
-v3: oom_kill grew a use of thaw_process() while this patch was
pending. Convert it to use __thaw_task() for now. In the longer
term, this should be handled by allowing tasks to die if killed
even if it's frozen.
-v2: minor style update as suggested by Matt.
Cc: Paul Menage <menage@google.com>
Cc: Matt Helsley <matthltc@us.ibm.com>
Writeback and thinkpad_acpi have been using thaw_process() to prevent
deadlock between the freezer and kthread_stop(); unfortunately, this
is inherently racy - nothing prevents freezing from happening between
thaw_process() and kthread_stop().
This patch implements kthread_freezable_should_stop() which enters
refrigerator if necessary but is guaranteed to return if
kthread_stop() is invoked. Both thaw_process() users are converted to
use the new function.
Note that this deadlock condition exists for many of freezable
kthreads. They need to be converted to use the new should_stop or
freezable workqueue.
Tested with synthetic test case.
Acked-by: Henrique de Moraes Holschuh <ibm-acpi@hmh.eng.br>
There is no reason to export two functions for entering the
refrigerator. Calling refrigerator() instead of try_to_freeze()
doesn't save anything noticeable or removes any race condition.
* Rename refrigerator() to __refrigerator() and make it return bool
indicating whether it scheduled out for freezing.
* Update try_to_freeze() to return bool and relay the return value of
__refrigerator() if freezing().
* Convert all refrigerator() users to try_to_freeze().
* Update documentation accordingly.
* While at it, add might_sleep() to try_to_freeze().
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Jan Kara <jack@suse.cz>
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
refrigerator() saves current->state before entering frozen state and
restores it before returning using __set_current_state(); however,
this is racy, for example, please consider the following sequence.
set_current_state(TASK_INTERRUPTIBLE);
try_to_freeze();
if (kthread_should_stop())
break;
schedule();
If kthread_stop() races with ->state restoration, the restoration can
restore ->state to TASK_INTERRUPTIBLE after kthread_stop() sets it to
TASK_RUNNING but kthread_should_stop() may still see zero
->should_stop because there's no memory barrier between restoring
TASK_INTERRUPTIBLE and kthread_should_stop() test.
This isn't restricted to kthread_should_stop(). current->state is
often used in memory barrier based synchronization and silently
restoring it w/o mb breaks them.
Use set_current_state() instead.
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
wake TASK_KILLABLE tasks too"
Commit 27920651fe "PM / Freezer: Make fake_signal_wake_up() wake
TASK_KILLABLE tasks too" updated fake_signal_wake_up() used by freezer
to wake up KILLABLE tasks. Sending unsolicited wakeups to tasks in
killable sleep is dangerous as there are code paths which depend on
tasks not waking up spuriously from KILLABLE sleep.
For example. sys_read() or page can sleep in TASK_KILLABLE assuming
that wait/down/whatever _killable can only fail if we can not return
to the usermode. TASK_TRACED is another obvious example.
The previous patch updated wait_event_freezekillable() such that it
doesn't depend on the spurious wakeup. This patch reverts the
offending commit.
Note that the spurious KILLABLE wakeup had other implicit effects in
KILLABLE sleeps in nfs and cifs and those will need further updates to
regain freezekillable behavior.
The changed files were only including linux/module.h for the
EXPORT_SYMBOL infrastructure, and nothing else. Revector them
onto the isolated export header for faster compile times.
Nothing to see here but a whole lot of instances of:
-#include <linux/module.h>
+#include <linux/export.h>
This commit is only changing the kernel dir; next targets
will probably be mm, fs, the arch dirs, etc.
TASK_KILLABLE is often used to put tasks to sleep for quite some time.
One of the most common uses is to put tasks to sleep while waiting for
replies from a server on a networked filesystem (such as CIFS or NFS).
Unfortunately, fake_signal_wake_up does not currently wake up tasks
that are sleeping in TASK_KILLABLE state. This means that even if the
code were in place to allow them to freeze while in this sleep, it
wouldn't work anyway.
This patch changes this function to wake tasks in this state as well.
This should be harmless -- if the code doing the sleeping doesn't have
handling to deal with freezer events, it should just go back to sleep.
If it does, then this will allow that code to do the right thing.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
The freezer processes are dealing with multiple threads running
simultaneously, and on a UP system, the memory reads/writes do
not need barriers to keep things in sync. These are only needed
on SMP systems, so use SMP barriers instead.
After calling freeze_task(), try_to_freeze_tasks() see whether the
task is stopped or traced and if so, considers it to be frozen;
however, nothing guarantees that either the task being frozen sees
TIF_FREEZE or the freezer sees TASK_STOPPED -> TASK_RUNNING
transition. The task being frozen may wake up and not see TIF_FREEZE
while the freezer fails to notice the transition and believes the task
is still stopped.
This patch fixes the race by making freeze_task() always go through
fake_signal_wake_up() for applicable tasks. The function goes through
the target task's scheduler lock and thus guarantees that either the
target sees TIF_FREEZE or try_to_freeze_task() sees TASK_RUNNING.
commit e3c8ca8336 (sched: do not count frozen tasks toward load) broke
the nr_uninterruptible accounting on freeze/thaw. On freeze the task
is excluded from accounting with a check for (task->flags &
PF_FROZEN), but that flag is cleared before the task is thawed. So
while we prevent that the task with state TASK_UNINTERRUPTIBLE
is accounted to nr_uninterruptible on freeze we decrement
nr_uninterruptible on thaw.
Use a separate flag which is handled by the freezing task itself. Set
it before calling the scheduler with TASK_UNINTERRUPTIBLE state and
clear it after we return from frozen state.
Cc: <stable@kernel.org>
Don't duplicate the implementation of thaw_process().
[akpm@linux-foundation.org: make __thaw_process() static]
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Cedric Le Goater <clg@fr.ibm.com>
Acked-by: Matt Helsley <matthltc@us.ibm.com>
This patch implements a new freezer subsystem in the control groups
framework. It provides a way to stop and resume execution of all tasks in
a cgroup by writing in the cgroup filesystem.
The freezer subsystem in the container filesystem defines a file named
freezer.state. Writing "FROZEN" to the state file will freeze all tasks
in the cgroup. Subsequently writing "RUNNING" will unfreeze the tasks in
the cgroup. Reading will return the current state.
* Examples of usage :
# mkdir /containers/freezer
# mount -t cgroup -ofreezer freezer /containers
# mkdir /containers/0
# echo $some_pid > /containers/0/tasks
to get status of the freezer subsystem :
# cat /containers/0/freezer.state
RUNNING
to freeze all tasks in the container :
# echo FROZEN > /containers/0/freezer.state
FREEZING
FROZEN
to unfreeze all tasks in the container :
# echo RUNNING > /containers/0/freezer.state
RUNNING
This is the basic mechanism which should do the right thing for user space
task in a simple scenario.
It's important to note that freezing can be incomplete. In that case we
return EBUSY. This means that some tasks in the cgroup are busy doing
something that prevents us from completely freezing the cgroup at this
time. After EBUSY, the cgroup will remain partially frozen -- reflected
by freezer.state reporting "FREEZING" when read. The state will remain
"FREEZING" until one of these things happens:
1) Userspace cancels the freezing operation by writing "RUNNING" to
the freezer.state file
2) Userspace retries the freezing operation by writing "FROZEN" to
the freezer.state file (writing "FREEZING" is not legal
and returns EIO)
3) The tasks that blocked the cgroup from entering the "FROZEN"
state disappear from the cgroup's set of tasks.
[akpm@linux-foundation.org: export thaw_process]
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
Signed-off-by: Matt Helsley <matthltc@us.ibm.com>
Acked-by: Serge E. Hallyn <serue@us.ibm.com>
Tested-by: Matt Helsley <matthltc@us.ibm.com>
Now that the TIF_FREEZE flag is available in all architectures, extract
the refrigerator() and freeze_task() from kernel/power/process.c and make
it available to all.
The refrigerator() can now be used in a control group subsystem
implementing a control group freezer.
