path: root/kernel/exit.c
2006-06-25[PATCH] kernel/sys.c: cleanupsAdrian Bunk
- proper prototypes for the following functions: - ctrl_alt_del() (in include/linux/reboot.h) - getrusage() (in include/linux/resource.h) - make the following needlessly global functions static: - kernel_restart_prepare() - kernel_kexec() [akpm@osdl.org: compile fix] Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] More BUG_ON conversionEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: "Salyzyn, Mark" <mark_salyzyn@adaptec.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[PATCH] run_posix_cpu_timers: remove a bogus BUG_ON()Oleg Nesterov
do_exit() clears ->it_##clock##_expires, but nothing prevents another cpu to attach the timer to exiting process after that. arm_timer() tries to protect against this race, but the check is racy. After exit_notify() does 'write_unlock_irq(&tasklist_lock)' and before do_exit() calls 'schedule() local timer interrupt can find tsk->exit_state != 0. If that state was EXIT_DEAD (or another cpu does sys_wait4) interrupted task has ->signal == NULL. At this moment exiting task has no pending cpu timers, they were cleanuped in __exit_signal()->posix_cpu_timers_exit{,_group}(), so we can just return from irq. John Stultz recently confirmed this bug, see http://marc.theaimsgroup.com/?l=linux-kernel&m=115015841413687 Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] move call of audit_free() into do_exit()Al Viro
2006-04-19[PATCH] task: Make task list manipulations RCU safeEric W. Biederman
While we can currently walk through thread groups, process groups, and sessions with just the rcu_read_lock, this opens the door to walking the entire task list. We already have all of the other RCU guarantees so there is no cost in doing this, this should be enough so that proc can stop taking the tasklist lock during readdir. prev_task was killed because it has no users, and using it will miss new tasks when doing an rcu traversal. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] splice: add direct fd <-> fd splicing supportJens Axboe
It's more efficient for sendfile() emulation. Basically we cache an internal private pipe and just use that as the intermediate area for pages. Direct splicing is not available from sys_splice(), it is only meant to be used for sendfile() emulation. Additional patch from Ingo Molnar to avoid the PIPE_BUFFERS loop at exit for the normal fast path. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-31[PATCH] task: RCU protect task->usageEric W. Biederman
A big problem with rcu protected data structures that are also reference counted is that you must jump through several hoops to increase the reference count. I think someone finally implemented atomic_inc_not_zero(&count) to automate the common case. Unfortunately this means you must special case the rcu access case. When data structures are only visible via rcu in a manner that is not determined by the reference count on the object (i.e. tasks are visible until their zombies are reaped) there is a much simpler technique we can employ. Simply delaying the decrement of the reference count until the rcu interval is over. What that means is that the proc code that looks up a task and later wants to sleep can now do: rcu_read_lock(); task = find_task_by_pid(some_pid); if (task) { get_task_struct(task); } rcu_read_unlock(); The effect on the rest of the kernel is that put_task_struct becomes cheaper and immediate, and in the case where the task has been reaped it frees the task immediate instead of unnecessarily waiting an until the rcu interval is over. Cleanup of task_struct does not happen when its reference count drops to zero, instead cleanup happens when release_task is called. Tasks can only be looked up via rcu before release_task is called. All rcu protected members of task_struct are freed by release_task. Therefore we can move call_rcu from put_task_struct into release_task. And we can modify release_task to not immediately release the reference count but instead have it call put_task_struct from the function it gives to call_rcu. The end result: - get_task_struct is safe in an rcu context where we have just looked up the task. - put_task_struct() simplifies into its old pre rcu self. This reorganization also makes put_task_struct uncallable from modules as it is not exported but it does not appear to be called from any modules so this should not be an issue, and is trivially fixed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] cleanup __exit_signal->cleanup_sighand pathOleg Nesterov
Move 'tsk->sighand = NULL' from cleanup_sighand() to __exit_signal(). This makes the exit path more understandable and allows us to do cleanup_sighand() outside of ->siglock protected section. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] pids: kill PIDTYPE_TGIDOleg Nesterov
This patch kills PIDTYPE_TGID pid_type thus saving one hash table in kernel/pid.c and speeding up subthreads create/destroy a bit. It is also a preparation for the further tref/pids rework. This patch adds 'struct list_head thread_group' to 'struct task_struct' instead. We don't detach group leader from PIDTYPE_PID namespace until another thread inherits it's ->pid == ->tgid, so we are safe wrt premature free_pidmap(->tgid) call. Currently there are no users of find_task_by_pid_type(PIDTYPE_TGID). Should the need arise, we can use find_task_by_pid()->group_leader. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-By: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] do_group_exit: don't take tasklist_lockOleg Nesterov
do_group_exit() takes tasklist_lock for zap_other_threads(), this is unneeded now. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] do __unhash_process() under ->siglockOleg Nesterov
This patch moves __unhash_process() call from realease_task() to __exit_signal(), so __detach_pid() is called with ->siglock held. This means we don't need tasklist_lock to iterate over thread group anymore: copy_process() was already changed to do attach_pid() under ->siglock. Eric's "pidhash-kill-switch_exec_pids.patch" from -mm changed de_thread() so it doesn't touch PIDTYPE_TGID. NOTE: de_thread() still needs some attention. It still changes task->pid lockless. Taking ->sighand.siglock here allows to do more tasklist_lock removals. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] revert "Optimize sys_times for a single thread process"Oleg Nesterov
This patch reverts 'CONFIG_SMP && thread_group_empty()' optimization in sys_times(). The reason is that the next patch breaks memory ordering which is needed for that optimization. tasklist_lock in sys_times() will be eliminated completely by further patch. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] move __exit_signal() to kernel/exit.cOleg Nesterov
__exit_signal() is private to release_task() now. I think it is better to make it static in kernel/exit.c and export flush_sigqueue() instead - this function is much more simple and straightforward. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] release_task: replace open-coded ptrace_unlink()Oleg Nesterov
Use ptrace_unlink() instead of open-coding. No changes in kernel/exit.o Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] reparent_thread: use remove_parent/add_parentOleg Nesterov
Use remove_parent/add_parent instead of open coding. No changes in kernel/exit.o Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] pidhash: don't count idle threadsOleg Nesterov
fork_idle() does unhash_process() just after copy_process(). Contrary, boot_cpu's idle thread explicitely registers itself for each pid_type with nr = 0. copy_process() already checks p->pid != 0 before process_counts++, I think we can just skip attach_pid() calls and job control inits for idle threads and kill unhash_process(). We don't need to cleanup ->proc_dentry in fork_idle() because with this patch idle threads are never hashed in kernel/pid.c:pid_hash[]. We don't need to hash pid == 0 in pidmap_init(). free_pidmap() is never called with pid == 0 arg, so it will never be reused. So it is still possible to use pid == 0 in any PIDTYPE_xxx namespace from kernel/pid.c's POV. However with this patch we don't hash pid == 0 for PIDTYPE_PID case. We still have have PIDTYPE_PGID/PIDTYPE_SID entries with pid == 0: /sbin/init and kernel threads which don't call daemonize(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] kill SET_LINKS/REMOVE_LINKSOleg Nesterov
Both SET_LINKS() and SET_LINKS/REMOVE_LINKS() have exactly one caller, and these callers already check thread_group_leader(). This patch kills theese macros, they mix two different things: setting process's parent and registering it in init_task.tasks list. Callers are updated to do these actions by hand. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] don't use REMOVE_LINKS/SET_LINKS for reparentingOleg Nesterov
There are places where kernel uses REMOVE_LINKS/SET_LINKS while changing process's ->parent. Use add_parent/remove_parent instead, they don't abuse of global process list. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] remove add_parent()'s parent argumentOleg Nesterov
add_parent(p, parent) is always called with parent == p->parent, and it makes no sense to do it differently. This patch removes this argument. No changes in affected .o files. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] choose_new_parent: remove unused arg, sanitize exit_state checkOleg Nesterov
'child_reaper' arg is not used in choose_new_parent(). "->exit_state >= EXIT_ZOMBIE" check is a leftover, was valid when EXIT_ZOMBIE lived in ->state var. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] exec: allow init to exec from any thread.Eric W. Biederman
After looking at the problem of init calling exec some more I figured out an easy way to make the code work. The actual symptom without out this patch is that all threads will die except pid == 1, and the thread calling exec. The thread calling exec will wait forever for pid == 1 to die. Since pid == 1 does not install a handler for SIGKILL it will never die. This modifies the tests for init from current->pid == 1 to the equivalent current == child_reaper. And then it causes exec in the ugly case to modify child_reaper. The only weird symptom is that you wind up with an init process that doesn't have the oldest start time on the box. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] lightweight robust futexes: compatIngo Molnar
32-bit syscall compatibility support. (This patch also moves all futex related compat functionality into kernel/futex_compat.c.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Acked-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] lightweight robust futexes: coreIngo Molnar
Add the core infrastructure for robust futexes: structure definitions, the new syscalls and the do_exit() based cleanup mechanism. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Acked-by: Ulrich Drepper <drepper@redhat.com> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: ttyIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-18[PATCH] don't do exit_io_context() until we know we won't be doing any IOAl Viro
testcase: mount /dev/sdb10 /mnt touch /mnt/tmp/b umount /mnt mount /dev/sdb10 /mnt rm /mnt/tmp/b </mnt/tmp/b umount /mnt and watch blkdev_ioc line in /proc/slabinfo. Vanilla kernel leaks. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-20[PATCH] kjournald keeps reference to namespaceBjörn Steinbrink
In daemonize() a new thread gets cleaned up and 'merged' with init_task. The current fs_struct is handled there, but not the current namespace. This adds the namespace part. [ Eric Biederman pointed out the namespace wrappers, and also notes that we can't ever count on using our parents namespace because we already have called exit_fs(), which is the only way to the namespace from a process. ] Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de> Acked-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] sched: add new SCHED_BATCH policyIngo Molnar
Add a new SCHED_BATCH (3) scheduling policy: such tasks are presumed CPU-intensive, and will acquire a constant +5 priority level penalty. Such policy is nice for workloads that are non-interactive, but which do not want to give up their nice levels. The policy is also useful for workloads that want a deterministic scheduling policy without interactivity causing extra preemptions (between that workload's tasks). Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Decrease number of pointer derefs in exit.cJesper Juhl
Decrease the number of pointer derefs in kernel/exit.c Benefits of the patch: - Fewer pointer dereferences should make the code slightly faster. - Size of generated code is smaller - improved readability Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: switch itimers to hrtimerThomas Gleixner
switch itimers to a hrtimers-based implementation Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, more debugging codeIngo Molnar
more mutex debugging: check for held locks during memory freeing, task exit, enable sysrq printouts, etc. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
2006-01-08[PATCH] setpgid: should work for sub-threadsOren Laadan
setsid() does not work unless the calling process is a thread_group_leader(). 'man setpgid' does not tell anything about that, so I consider this behaviour is a bug. Signed-off-by: Oren Laadan <orenl@cs.columbia.edu> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] little do_group_exit() cleanupOleg Nesterov
zap_other_threads() sets SIGNAL_GROUP_EXIT at the very start, do_group_exit() doesn't need to do it. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] RCU signal handlingIngo Molnar
RCU tasklist_lock and RCU signal handling: send signals RCU-read-locked instead of tasklist_lock read-locked. This is a scalability improvement on SMP and a preemption-latency improvement under PREEMPT_RCU. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: William Irwin <wli@holomorphy.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] m68k: introduce task_thread_infoAl Viro
new helper - task_thread_info(task). On platforms that have thread_info allocated separately (i.e. in default case) it simply returns task->thread_info. m68k wants (and for good reasons) to embed its thread_info into task_struct. So it will (in later patch) have task_thread_info() of its own. For now we just add a macro for generic case and convert existing instances of its body in core kernel to uses of new macro. Obviously safe - all normal architectures get the same preprocessor output they used to get. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Process Events ConnectorMatt Helsley
This patch adds a connector that reports fork, exec, id change, and exit events for all processes to userspace. It replaces the fork_advisor patch that ELSA is currently using. Applications that may find these events useful include accounting/auditing (e.g. ELSA), system activity monitoring (e.g. top), security, and resource management (e.g. CKRM). Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] remove hardcoded SEND_SIG_xxx constantsOleg Nesterov
This patch replaces hardcoded SEND_SIG_xxx constants with their symbolic names. No changes in affected .o files. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] wait4 PTRACE_ATTACH race fixRoland McGrath
Back about a year ago when I last fiddled heavily with the do_wait code, I was thinking too hard about the wrong thing and I now think I introduced a bug whose inverse thought I was fixing. Apparently noone was looking too hard over much shoulder, so as to cite my bogus reasoning at the time. In the race condition when PTRACE_ATTACH is about to steal a child and then the child hits a tracing event (what my_ptrace_child checks for), the real parent does need to set its flag noting it has some eligible live children. Otherwise a spurious ECHILD error is possible, since the child in question is not yet on the ptrace_children list. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] PF_DEAD cleanupCoywolf Qi Hunt
The PF_DEAD setting doesn't belong to exit_notify(), move it to a proper place. Signed-off-by: Coywolf Qi Hunt <qiyong@fc-cn.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: update_hiwaters just in timeHugh Dickins
update_mem_hiwater has attracted various criticisms, in particular from those concerned with mm scalability. Originally it was called whenever rss or total_vm got raised. Then many of those callsites were replaced by a timer tick call from account_system_time. Now Frank van Maarseveen reports that to be found inadequate. How about this? Works for Frank. Replace update_mem_hiwater, a poor combination of two unrelated ops, by macros update_hiwater_rss and update_hiwater_vm. Don't attempt to keep mm->hiwater_rss up to date at timer tick, nor every time we raise rss (usually by 1): those are hot paths. Do the opposite, update only when about to lower rss (usually by many), or just before final accounting in do_exit. Handle mm->hiwater_vm in the same way, though it's much less of an issue. Demand that whoever collects these hiwater statistics do the work of taking the maximum with rss or total_vm. And there has been no collector of these hiwater statistics in the tree. The new convention needs an example, so match Frank's usage by adding a VmPeak line above VmSize to /proc/<pid>/status, and also a VmHWM line above VmRSS (High-Water-Mark or High-Water-Memory). There was a particular anomaly during mremap move, that hiwater_vm might be captured too high. A fleeting such anomaly remains, but it's quickly corrected now, whereas before it would stick. What locking? None: if the app is racy then these statistics will be racy, it's not worth any overhead to make them exact. But whenever it suits, hiwater_vm is updated under exclusive mmap_sem, and hiwater_rss under page_table_lock (for now) or with preemption disabled (later on): without going to any trouble, minimize the time between reading current values and updating, to minimize those occasions when a racing thread bumps a count up and back down in between. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-27Revert "remove false BUG_ON() from run_posix_cpu_timers()"Linus Torvalds
This reverts commit 3de463c7d9d58f8cf3395268230cb20a4c15bffa. Roland has another patch that allows us to leave the BUG_ON() in place by just making sure that the condition it tests for really is always true. That goes in next. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-24[PATCH] posix-timers: remove false BUG_ON() from run_posix_cpu_timers()Oleg Nesterov
do_exit() clears ->it_##clock##_expires, but nothing prevents another cpu to attach the timer to exiting process after that. After exit_notify() does 'write_unlock_irq(&tasklist_lock)' and before do_exit() calls 'schedule() local timer interrupt can find tsk->exit_state != 0. If that state was EXIT_DEAD (or another cpu does sys_wait4) interrupted task has ->signal == NULL. At this moment exiting task has no pending cpu timers, they were cleaned up in __exit_signal()->posix_cpu_timers_exit{,_group}(), so we can just return from irq. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-21[PATCH] Call exit_itimers from do_exit, not __exit_signalRoland McGrath
When I originally moved exit_itimers into __exit_signal, that was the only place where we could reliably know it was the last thread in the group dying, without races. Since then we've gotten the signal_struct.live counter, and do_exit can reliably do group-wide cleanup work. This patch moves the call to do_exit, where it's made without locks. This avoids the deadlock issues that the old __exit_signal code's comment talks about, and the one that Oleg found recently with process CPU timers. [ This replaces e03d13e985d48ac4885382c9e3b1510c78bd047f, which is why it was just reverted. ] Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-01Fix inequality comparison against "task->state"Linus Torvalds
We should always use bitmask ops, rather than depend on some ordering of the different states. With the TASK_NONINTERACTIVE flag, the inequality doesn't really work. Oleg Nesterov argues (likely correctly) that this test is unnecessary in the first place. However, the minimal fix for now is to at least make it work in the presense of TASK_NONINTERACTIVE. Waiting for consensus from Roland & co on potential bigger cleanups. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] files: fix preemption issuesDipankar Sarma
With the new fdtable locking rules, you have to protect fdtable with either ->file_lock or rcu_read_lock/unlock(). There are some places where we aren't doing either. This patch fixes those places. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: files struct with RCUDipankar Sarma
Patch to eliminate struct files_struct.file_lock spinlock on the reader side and use rcu refcounting rcuref_xxx api for the f_count refcounter. The updates to the fdtable are done by allocating a new fdtable structure and setting files->fdt to point to the new structure. The fdtable structure is protected by RCU thereby allowing lock-free lookup. For fd arrays/sets that are vmalloced, we use keventd to free them since RCU callbacks can't sleep. A global list of fdtable to be freed is not scalable, so we use a per-cpu list. If keventd is already handling the current cpu's work, we use a timer to defer queueing of that work. Since the last publication, this patch has been re-written to avoid using explicit memory barriers and use rcu_assign_pointer(), rcu_dereference() premitives instead. This required that the fd information is kept in a separate structure (fdtable) and updated atomically. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: break up files structDipankar Sarma
In order for the RCU to work, the file table array, sets and their sizes must be updated atomically. Instead of ensuring this through too many memory barriers, we put the arrays and their sizes in a separate structure. This patch takes the first step of putting the file table elements in a separate structure fdtable that is embedded withing files_struct. It also changes all the users to refer to the file table using files_fdtable() macro. Subsequent applciation of RCU becomes easier after this. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-04[PATCH] revert "timer exit cleanup"Andrew Morton
Revert this June 17 patch: it broke persistence of timers across execve(). Cc: Roland McGrath <roland@redhat.com> Cc: george anzinger <george@mvista.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] Update cfq io scheduler to time sliced designJens Axboe
This updates the CFQ io scheduler to the new time sliced design (cfq v3). It provides full process fairness, while giving excellent aggregate system throughput even for many competing processes. It supports io priorities, either inherited from the cpu nice value or set directly with the ioprio_get/set syscalls. The latter closely mimic set/getpriority. This import is based on my latest from -mm. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
