A variety of (mostly) innocuous fixes to the embedded kernel-doc content in
source files, including:
* make multi-line initial descriptions single line
* denote some function names, constants and structs as such
* change erroneous opening '/*' to '/**' in a few places
* reword some text for clarity
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
This is based on a patch by Eric W. Biederman, who pointed out that pid
namespaces are still fake, and we only have one ever active.
So for the time being, we can modify any code which could access
tsk->nsproxy->pid_ns during task exit to just use &init_pid_ns instead,
and move the exit_task_namespaces call in do_exit() back above
exit_notify(), so that an exiting nfs server has a valid tsk->sighand to
work with.
Long term, pulling pid_ns out of nsproxy might be the cleanest solution.
[ Eric's patch fixed to take care of free_pid() too ]
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
This reverts commit 7a238fcba0629b6f2edbcd37458bae56fcf36be5 in
preparation for a better and simpler fix proposed by Eric Biederman
(and fixed up by Serge Hallyn)
Acked-by: Serge E. Hallyn <serue@us.ibm.com>
Fix exit race by splitting the nsproxy putting into two pieces. First
piece reduces the nsproxy refcount. If we dropped the last reference, then
it puts the mnt_ns, and returns the nsproxy as a hint to the caller. Else
it returns NULL. The second piece of exiting task namespaces sets
tsk->nsproxy to NULL, and drops the references to other namespaces and
frees the nsproxy only if an nsproxy was passed in.
A little awkward and should probably be reworked, but hopefully it fixes
the NFS oops.
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Cedric Le Goater <clg@fr.ibm.com>
Cc: Daniel Hokka Zakrisson <daniel@hozac.com>
Commit b2b2cbc4b2a2f389442549399a993a8306420baf introduced a user-
visible change: ->pdeath_signal is sent only when the entire thread
group exits.
While this change is imho good, it may break things. So restore the
old behaviour for now.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
To: Albert Cahalan <acahalan@gmail.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Andrew Morton <akpm@osdl.org>
Cc: Linus Torvalds <torvalds@osdl.org>
Cc: Qi Yong <qiyong@fc-cn.com>
Cc: Roland McGrath <roland@redhat.com>
This patch fixes the case when we reparent to a different thread in the
same thread group. This modifies the code so that we do not send
signals and do not change the signal to send to SIGCHLD unless we have
change the thread group of our parents. It also suppresses sending
pdeath_sig in this cas as well since the result of geppid doesn't
change.
Thanks to Oleg for spotting my bug of only fixing this for non-ptraced
tasks.
Cc: Albert Cahalan <acahalan@gmail.com>
Cc: Coywolf Qi Hunt <qiyong@fc-cn.com>
Acked-by: Oleg Nesterov <oleg@tv-sign.ru>
Christoph Hellwig has expressed concerns that the recent fdtable changes
expose the details of the RCU methodology used to release no-longer-used
fdtable structures to the rest of the kernel. The trivial patch below
addresses these concerns by introducing the appropriate free_fdtable()
calls, which simply wrap the release RCU usage. Since free_fdtable() is a
one-liner, it makes sense to promote it to an inline helper.
Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net>
An fdtable can either be embedded inside a files_struct or standalone (after
being expanded). When an fdtable is being discarded after all RCU references
to it have expired, we must either free it directly, in the standalone case,
or free the files_struct it is contained within, in the embedded case.
Currently the free_files field controls this behavior, but we can get rid of
it entirely, as all the necessary information is already recorded. We can
distinguish embedded and standalone fdtables using max_fds, and if it is
embedded we can divine the relevant files_struct using container_of().
Cc: Dipankar Sarma <dipankar@in.ibm.com>
Currently, each fdtable supports three dynamically-sized arrays of data: the
fdarray and two fdsets. The code allows the number of fds supported by the
fdarray (fdtable->max_fds) to differ from the number of fds supported by each
of the fdsets (fdtable->max_fdset).
In practice, it is wasteful for these two sizes to differ: whenever we hit a
limit on the smaller-capacity structure, we will reallocate the entire fdtable
and all the dynamic arrays within it, so any delta in the memory used by the
larger-capacity structure will never be touched at all.
Rather than hogging this excess, we shouldn't even allocate it in the first
place, and keep the capacities of the fdarray and the fdsets equal. This
patch removes fdtable->max_fdset. As an added bonus, most of the supporting
code becomes simpler.
All members of the process group have the same sid and it can't be == 0.
NOTE: this code (and a similar one in sys_setpgid) was needed because it
was possibe to have ->session == 0. It's not possible any longer since
[PATCH] pidhash: don't use zero pids
Commit: c7c6464117a02b0d54feb4ebeca4db70fa493678
Add a per pid_namespace child-reaper. This is needed so processes are reaped
within the same pid space and do not spill over to the parent pid space. Its
also needed so containers preserve existing semantic that pid == 1 would reap
orphaned children.
This is based on Eric Biederman's patch: http://lkml.org/lkml/2006/2/6/285
Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
Cc: Kirill Korotaev <dev@openvz.org>
Rename 'struct namespace' to 'struct mnt_namespace' to avoid confusion with
other namespaces being developped for the containers : pid, uts, ipc, etc.
'namespace' variables and attributes are also renamed to 'mnt_ns'
Signed-off-by: Kirill Korotaev <dev@sw.ru>
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Add an anonymous union and ((deprecated)) to catch direct usage of the
session field.
[akpm@osdl.org: fix various missed conversions]
[jdike@addtoit.com: fix UML bug]
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Replace occurences of task->signal->session by a new process_session() helper
routine.
It will be useful for pid namespaces to abstract the session pid number.
Make set_special_pids() static, the only caller is daemonize().
Fix the locking of signal->tty.
Use ->sighand->siglock to protect ->signal->tty; this lock is already used
by most other members of ->signal/->sighand. And unless we are 'current'
or the tasklist_lock is held we need ->siglock to access ->signal anyway.
(NOTE: sys_unshare() is broken wrt ->sighand locking rules)
Note that tty_mutex is held over tty destruction, so while holding
tty_mutex any tty pointer remains valid. Otherwise the lifetime of ttys
are governed by their open file handles. This leaves some holes for tty
access from signal->tty (or any other non file related tty access).
It solves the tty SLAB scribbles we were seeing.
(NOTE: the change from group_send_sig_info to __group_send_sig_info needs to
be examined by someone familiar with the security framework, I think
it is safe given the SEND_SIG_PRIV from other __group_send_sig_info
invocations)
[schwidefsky@de.ibm.com: 3270 fix]
[akpm@osdl.org: various post-viro fixes]
Acked-by: Alan Cox <alan@redhat.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Jan Kara <jack@ucw.cz>
do_exit:
taskstats_exit_alloc()
taskstats_exit_send()
taskstats_exit_free()
I think this is not good, let it be a single function exported to the core
kernel, taskstats_exit(), which does alloc + send + free itself.
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Shailabh Nagar <nagar@watson.ibm.com>
Cc: Jay Lan <jlan@engr.sgi.com>
taskstats_tgid_free() is called on copy_process's error path. This is wrong.
IF (clone_flags & CLONE_THREAD)
We should not clear ->signal->taskstats, current uses it,
it probably has a valid accumulated info.
ELSE
taskstats_tgid_init() set ->signal->taskstats = NULL,
there is nothing to free.
Move the callsite to __exit_signal(). We don't need any locking, entire
thread group is exiting, nobody should have a reference to soon to be
released ->signal.
Cc: Jay Lan <jlan@sgi.com>
exit_task_namespaces() has replaced the former exit_namespace(). It
invalidates task->nsproxy and associated namespaces. This is an issue for
the (futur) pid namespace which is required to be valid in exit_notify().
This patch moves exit_task_namespaces() after exit_notify() to keep nsproxy
valid.
Cc: Serge E. Hallyn <serue@us.ibm.com>
Cc: Andrey Savochkin <saw@sw.ru>
This moves the mount namespace into the nsproxy. The mount namespace count
now refers to the number of nsproxies point to it, rather than the number of
tasks. As a result, the unshare_namespace() function in kernel/fork.c no
longer checks whether it is being shared.
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
This patch adds a nsproxy structure to the task struct. Later patches will
move the fs namespace pointer into this structure, and introduce a new utsname
The vserver and openvz functionality, then, would be implemented in large part
by virtualizing/isolating more and more resources into namespaces, each
contained in the nsproxy.
[akpm@osdl.org: build fix]
There were a few accounting data/macros that are used in CSA but are #ifdef'ed
inside CONFIG_BSD_PROCESS_ACCT. This patch is to change those ifdef's from
CONFIG_BSD_PROCESS_ACCT to CONFIG_TASK_XACCT. A few defines are moved from
kernel/acct.c and include/linux/acct.h to kernel/tsacct.c and
include/linux/tsacct_kern.h.
Signed-off-by: Jay Lan <jlan@sgi.com>
Cc: Jes Sorensen <jes@sgi.com>
Cc: Chris Sturtivant <csturtiv@sgi.com>
Cc: Tony Ernst <tee@sgi.com>
Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net>
Remove the duplicate declaration of exit_io_context() from linux/sched.h.
Signed-Off-By: David Howells <dhowells@redhat.com>
I am not sure about this patch, I am asking Ingo to take a decision.
task_struct->state == EXIT_DEAD is a very special case, to avoid a confusion
it makes sense to introduce a new state, TASK_DEAD, while EXIT_DEAD should
live only in ->exit_state as documented in sched.h.
Note that this state is not visible to user-space, get_task_state() masks off
unsuitable states.
After the previous change (->flags & PF_DEAD) <=> (->state == EXIT_DEAD), we
don't need PF_DEAD any longer.
schedule() checks PF_DEAD on every context switch and sets ->state = EXIT_DEAD
to ensure that the exiting task will be deactivated. Note that this EXIT_DEAD
is in fact a "random" value, we can use any bit except normal TASK_XXX values.
It is better to set this state in do_exit() along with PF_DEAD flag and remove
that check in schedule().
We are safe wrt concurrent try_to_wake_up() (for example ptrace, tkill), it
can not change task's ->state: the 'state' argument of try_to_wake_up() can't
have EXIT_DEAD bit. And in case when try_to_wake_up() sees a stale value of
->state == TASK_RUNNING it will do nothing.
Remove open-coded has_rt_policy(), no changes in kernel/exit.o
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
If we are going to BUG() not panic() here then we should cover the case of
the BUG being compiled out
Signed-off-by: Alan Cox <alan@redhat.com>
This check has been obsolete since the introduction of TASK_TRACED. Now
TASK_STOPPED always means job control stop.
Signed-off-by: Roland McGrath <roland@redhat.com>
This is an updated version of Eric Biederman's is_init() patch.
(http://lkml.org/lkml/2006/2/6/280). It applies cleanly to 2.6.18-rc3 and
replaces a few more instances of ->pid == 1 with is_init().
Further, is_init() checks pid and thus removes dependency on Eric's other
patches for now.
Eric's original description:
There are a lot of places in the kernel where we test for init
because we give it special properties. Most significantly init
must not die. This results in code all over the kernel test
->pid == 1.
Introduce is_init to capture this case.
With multiple pid spaces for all of the cases affected we are
looking for only the first process on the system, not some other
process that has pid == 1.
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Serge Hallyn <serue@us.ibm.com>
Cc: <lxc-devel@lists.sourceforge.net>
Acked-by: Paul Mackerras <paulus@samba.org>
Fixed race on put_files_struct on exec with proc. Restoring files on
current on error path may lead to proc having a pointer to already kfree-d
files_struct.
->files changing at exit.c and khtread.c are safe as exit_files() makes all
things under lock.
Found during OpenVZ stress testing.
[akpm@osdl.org: add export]
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Signed-off-by: Kirill Korotaev <dev@openvz.org>
It is not possible to find a sub-thread in ->children/->ptrace_children
lists, ptrace_attach() does not allow to attach to sub-threads.
Even if it was possible to ptrace the task from the same thread group,
we can't allow to release ->group_leader while there are others (ptracer)
threads in the same group.
Cleanup allocation and freeing of tsk->delays used by delay accounting.
This solves two problems reported for delay accounting:
1. oops in __delayacct_blkio_ticks
http://www.uwsg.indiana.edu/hypermail/linux/kernel/0608.2/1844.html
Currently tsk->delays is getting freed too early in task exit which can
cause a NULL tsk->delays to get accessed via reading of /proc/<tgid>/stats.
The patch fixes this problem by freeing tsk->delays closer to when
task_struct itself is freed up. As a result, it also eliminates the use of
tsk->delays_lock which was only being used (inadequately) to safeguard
access to tsk->delays while a task was exiting.
2. Possible memory leak in kernel/delayacct.c
http://www.uwsg.indiana.edu/hypermail/linux/kernel/0608.2/1389.html
The patch cleans up tsk->delays allocations after a bad fork which was
missing earlier.
The patch has been tested to fix the problems listed above and stress
tested with rapid calls to delay accounting's taskstats command interface
(which is the other path that can access the same data, besides the /proc
interface causing the oops above).
Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com>
through cpumasks
On systems with a large number of cpus, with even a modest rate of tasks
exiting per cpu, the volume of taskstats data sent on thread exit can
overflow a userspace listener's buffers.
One approach to avoiding overflow is to allow listeners to get data for a
limited and specific set of cpus. By scaling the number of listeners
and/or the cpus they monitor, userspace can handle the statistical data
overload more gracefully.
In this patch, each listener registers to listen to a specific set of cpus
by specifying a cpumask. The interest is recorded per-cpu. When a task
exits on a cpu, its taskstats data is unicast to each listener interested
in that cpu.
Thanks to Andrew Morton for pointing out the various scalability and
general concerns of previous attempts and for suggesting this design.
Signed-off-by: Balbir Singh <balbir@in.ibm.com>
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Send per-tgid data only once during exit of a thread group instead of once
with each member thread exit.
Currently, when a thread exits, besides its per-tid data, the per-tgid data
of its thread group is also sent out, if its thread group is non-empty.
The per-tgid data sent consists of the sum of per-tid stats for all
*remaining* threads of the thread group.
This patch modifies this sending in two ways:
- the per-tgid data is sent only when the last thread of a thread group
exits. This cuts down heavily on the overhead of sending/receiving
per-tgid data, especially when other exploiters of the taskstats
interface aren't interested in per-tgid stats
- the semantics of the per-tgid data sent are changed. Instead of being
the sum of per-tid data for remaining threads, the value now sent is the
true total accumalated statistics for all threads that are/were part of
the thread group.
The patch also addresses a minor issue where failure of one accounting
subsystem to fill in the taskstats structure was causing the send of
taskstats to not be sent at all.
The patch has been tested for stability and run cerberus for over 4 hours
on an SMP.
[akpm@osdl.org: bugfixes]
Create a "taskstats" interface based on generic netlink (NETLINK_GENERIC
family), for getting statistics of tasks and thread groups during their
lifetime and when they exit. The interface is intended for use by multiple
accounting packages though it is being created in the context of delay
accounting.
This patch creates the interface without populating the fields of the data
that is sent to the user in response to a command or upon the exit of a task.
Each accounting package interested in using taskstats has to provide an
additional patch to add its stats to the common structure.
[akpm@osdl.org: cleanups, Kconfig fix]
Signed-off-by: Shailabh Nagar <nagar@us.ibm.com>
Cc: Peter Chubb <peterc@gelato.unsw.edu.au>
Cc: Erich Focht <efocht@ess.nec.de>
Cc: Levent Serinol <lserinol@gmail.com>
Initialization code related to collection of per-task "delay" statistics which
measure how long it had to wait for cpu, sync block io, swapping etc. The
collection of statistics and the interface are in other patches. This patch
sets up the data structures and allows the statistics collection to be
disabled through a kernel boot parameter.
cleanup: remove task_t and convert all the uses to struct task_struct. I
introduced it for the scheduler anno and it was a mistake.
Conversion was mostly scripted, the result was reviewed and all
secondary whitespace and style impact (if any) was fixed up by hand.
Generic lock debugging:
- generalized lock debugging framework. For example, a bug in one lock
subsystem turns off debugging in all lock subsystems.
- got rid of the caller address passing (__IP__/__IP_DECL__/etc.) from
the mutex/rtmutex debugging code: it caused way too much prototype
hackery, and lockdep will give the same information anyway.
- ability to do silent tests
- check lock freeing in vfree too.
- more finegrained debugging options, to allow distributions to
turn off more expensive debugging features.
There's no separate 'held mutexes' list anymore - but there's a 'held locks'
stack within lockdep, which unifies deadlock detection across all lock
classes. (this is independent of the lockdep validation stuff - lockdep first
checks whether we are holding a lock already)
Here are the current debugging options:
CONFIG_DEBUG_MUTEXES=y
CONFIG_DEBUG_LOCK_ALLOC=y
which do:
config DEBUG_MUTEXES
bool "Mutex debugging, basic checks"
config DEBUG_LOCK_ALLOC
bool "Detect incorrect freeing of live mutexes"
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This adds the actual pi-futex implementation, based on rt-mutexes.
[dino@in.ibm.com: fix an oops-causing race]
Signed-off-by: Dinakar Guniguntala <dino@in.ibm.com>
Runtime debugging functionality for rt-mutexes.
To keep the dcache from filling up with dead /proc entries we flush them on
process exit. However over the years that code has gotten hairy with a
dentry_pointer and a lock in task_struct and misdocumented as a correctness
feature.
I have rewritten this code to look and see if we have a corresponding entry in
the dcache and if so flush it on process exit. This removes the extra fields
in the task_struct and allows me to trivially handle the case of a
/proc/<tgid>/task/<pid> entry as well as the current /proc/<pid> entries.
process
When pacct facility generate an 'ac_flag' field in accounting record, it
refers a task_struct of the thread which died last in the process. But any
other task_structs are ignored.
Therefore, pacct facility drops ASU flag even if root-privilege operations are
used by any other threads except the last one. In addition, AFORK flag is
always set when the thread of group-leader didn't die last, although this
process has called execve() after fork().
We have a same matter in ac_exitcode. The recorded ac_exitcode is an exit
code of the last thread in the process. There is a possibility this exitcode
is not the group leader's one.
The pacct facility need an i/o operation when an accounting record is
generated. There is a possibility to wake OOM killer up. If OOM killer is
activated, it kills some processes to make them release process memory
regions.
But acct_process() is called in the killed processes context before calling
exit_mm(), so those processes cannot release own memory. In the results, any
processes stop in this point and it finally cause a system stall.
If futexes are disabled we fail to link on ppc64.
Cc: <stable@kernel.org>
- proper prototypes for the following functions:
- ctrl_alt_del() (in include/linux/reboot.h)
- getrusage() (in include/linux/resource.h)
- make the following needlessly global functions static:
- kernel_restart_prepare()
- kernel_kexec()
[akpm@osdl.org: compile fix]
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Acked-by: "Salyzyn, Mark" <mark_salyzyn@adaptec.com>
do_exit() clears ->it_##clock##_expires, but nothing prevents
another cpu to attach the timer to exiting process after that.
arm_timer() tries to protect against this race, but the check
is racy.
After exit_notify() does 'write_unlock_irq(&tasklist_lock)' and
before do_exit() calls 'schedule() local timer interrupt can find
tsk->exit_state != 0. If that state was EXIT_DEAD (or another cpu
does sys_wait4) interrupted task has ->signal == NULL.
At this moment exiting task has no pending cpu timers, they were
cleanuped in __exit_signal()->posix_cpu_timers_exit{,_group}(),
so we can just return from irq.
John Stultz recently confirmed this bug, see
http://marc.theaimsgroup.com/?l=linux-kernel&m=115015841413687
